Analyzers
Export results to CSV
Ryan_L_2
I run an analysis in Amplifier XE 2013 GUI collecting hardware event counts.
Under the Top-down Tree tab, I am able to visualize the total event counts for each selected counter as a function of either the CPU timestamp or the elapsed application runtime. I would like to be able export this time-series data, rather than just the cumulative results, to a format such as CSV for analysis through an external program.
Does such a capability exist, either directly through the GUI or through some other means such as an API, etc.? If so, how do I go about extracting this information from the analysis results?
Peter_W_Intel
From command line, use:
amplxe-cl -report top-down -time-filter=<begin_time>:<end_time> -r result-dir
From GUI, select interest of time stamp begin and end, zoon-in and filter in selection. In filtered result, right-click to do "Export to CSV.." to save result to CSV file.
Ryan_L_2
Peter,
Thank you, this is helpful. Though not directly what I was hoping for - I'd like to be able to export the hardware event data from the bottom pane of the Top-Down Tree tab - I am able to accomplish the equivalent through the use of the command-line option.
Thanks again.
