Analyzers
5253 Discussions
Error when building the sampling driver of vtune 9.1
windeagle
Hi. When I installed VTune 9.1 on Redhat Enterprise Server 5.1, whose kernalwas Linux 2.6.18-53.el5xen, I got an error when building the sampling driver. The error log was below:
/usr/bin/make "V=0" -C /lib/modules/2.6.18-53.el5xen/build SUBDIRS=/opt/intel/vtune/vdk/src modules
make[1]: Entering directory `/usr/src/kernels/2.6.18-53.el5-xen-x86_64'
CC /opt/intel/vtune/vdk/src/vtune.o
CC /opt/intel/vtune/vdk/src/random.o
CC /opt/intel/vtune/vdk/src/pcg.o
CC /opt/intel/vtune/vdk/src/per_cpu_buffer.o
CC /opt/intel/vtune/vdk/src/os_dependent.o
CC /opt/intel/vtune/vdk/src/user_status.o
CC /opt/intel/vtune/vdk/src/plugin.o
CC /opt/intel/vtune/vdk/src/utility.o
CC /opt/intel/vtune/vdk/src/vtlib32_64.o
/opt/intel/vtune/vdk/src/vtlib32_64.c: In function 'get_node_id':
/opt/intel/vtune/vdk/src/vtlib32_64.c:787: error: implicit declaration of function 'phys_to_nid'
make[2]: *** [/opt/intel/vtune/vdk/src/vtlib32_64.o] Error 1
make[1]: *** [_module_/opt/intel/vtune/vdk/src] Error 2
make[1]: Leaving directory `/usr/src/kernels/2.6.18-53.el5-xen-x86_64'
make: *** [default] Error 2
Installing sampling driver boot script ...
Copying /opt/intel/vtune/vdk/vtune to /etc/rc.d/init.d ... done.
Configuring autoload of sampling driver for runlevels 2 through 5 ... done.
Loading the driver ...
Warning: sampling driver "vtune_drv-x32_64-2.6.18-53.el5xensmp.ko"
was not found in directory "/opt/intel/vtune/vdk" !
Cananybody help me solve this problem? Any help is welcome. Thank you very much.
Peter_W_Intel
VTune Analyzer doesn't support on XEN based operation system.
Please check if your OS is supported in release notes.
Build a vtune driver for running OS, ensure you have corresponding Linux* kernel source installed
Peter_W_Intel
windeagle
You mean my kernel Linux 2.6.18-53.el5xen is an XEN based OS and VTune doesn't support it, then I should install another OS which issupported for using VTune Analyzer?
Arethere anyother solutions to solve the driver problem? The machine I work on is a server in our lab, so Iam notpermitted toreinstall OS on it.
Peter_W_Intel
Quoting - windeagle
There is no way to install current product on XEN based OS, you may find other machine to install supported OS. See product's system requirements - http://www.intel.com/cd/software/products/asmo-na/eng/vtune/vlin/239147.htm
TimP
Quoting - windeagle
The Red Hat distros come with an alternate non-Xen kernel, which can be added as a boot option, leaving the Xen installation in place.
mvista
Hi, I have the same problem building the sampling driver.
I am running :
MontaVista Linux Version 5.0, Carrier Grade Edition (0704580)
My uname -m -r -v output:
2.6.21_mvlcge500-dbe2 #1 SMP PREEMPT Sat Apr 18 14:35:59 CDT 2009 x86_64
Is this also not supported? Any relevant information is appreciated.
thanks.
Peter_W_Intel
Quoting - mvista
I am running :
thanks.
Please use - MontaVista* LinuxCarrier Grade Edition 4*, 2.6.10, which is supported in latest v9.1 Update 2.
lexusmegamix
Any plans on supporting CGE5? CGE4 is very old, MontaVista is already on release 6.
One more question - are Nehalem chips supported, and if not, is there a timeline?
Thanks!
TimP
Quoting - lexusmegamix
Current VTune supports Nehalem family chips. They would be referred to as Core i7.
