Analyzers
5269 Discussions
Exporting results out of vtlec
sharshera
I have lots of results inside of vtlec.
I want to export this to Excel to make statistics/comparisions and stuff like that.
Is there a way to do this?
I cannot copy the Call-graph or the resulting tables of data or anything to the outside of vtlec except by hand.
Does anybody have any suggestion?
Hameed.
David_A_Intel1
Hi Hameed!
Yes, you can export the results by using the command line interface: vtl. Using the vtl project command, you can set vtl to operate on the project you created in vtlec. Then, use the vtl view command to dump the results. See man callgraph for more info on formatting the output. Also, you can pipe it through scripts or sed/awk/etc to format it the way you want.
Message Edited by DaveA on 10-06-2005 02:00 PM
