Analyzers
5307 Discussions
Floating License with USE_SERVER doesn't work since VTuneAmplifierXE 2013update14
Bertrand_O_
we have a remote floating license that we access with the 2 lines above:
   SERVER machine ANY 27000
   USE_SERVER
It works fine with VTune Amplifier XE 2013 update13.
But, from VTune Amplifier XE 2013 update14 to VTune Amplifier XE 2013 update16, we can't use the same syntax.
It said: "no valid license can be found" when using with the syntax USE_SERVER.
With "export INTEL_LMD_DEBUG=1", it says: "Error: A license for PerfAnl is not available (-5,412)"
But it works fine when we use on the client a full license file with all the lines SERVER,PACKAGE,FEATURE,INCREMENT.
Nothing has been changed on the remote floating server.
For security reason, we have to keep this license working with only the 2 lines "SERVER + USE_SERVER", as before update13.
Thanks for any help.
John_Z_1
My company had the same issue. Fixed by upgrading Intel® Software License Manager running on the license server to version 2.2.
David_A_Intel1
Yes, thank you, John.  Bertrand, please see this article.
Bertrand_O_
I did the test with the last release of INTEL daemon, I mean "INTEL FlexNet Licensing v11.11.1.1 build 119913" and it was good.
With an older version like "INTEL FlexNet Licensing version v11.11.0.0 build 106800", it was failed.
Thank you very much for your speed of your answer.
