Analyzers
5341 Discussions
Profiled program fails to write files
Baris_M_
I am a newbie using vtune
I am trying to profile a portion of Quantum Espresso (http://www.quantum-espresso.org/)
However, when run under (or attached to) VTune gui, program raises a file handling error signal (38) and crashes. The program runs normally otherwise.
I have tried AMPLXE_RUNTOOL_OPTIONS="--profiling-signal <another signal>" where another signal is 16, 39 etc. however, this did not resolve the situation.
What might be going wrong?
Bernard
Valued Contributor I
Can you provide more description about the error?
Vitaly_S_Intel
Baris, do you use Hotspots analysis type? Does it happen with Advanced Hotspots (with/without stacks)?
Which VTune version do you use?
Baris_M_
I am using the basic hotspot analysis.
The program fails writing a file to the disk, citing a signal 38 was caught (although I am using a different profiling signal as mentioned above)
Details attached.
Thanks!
Update: Apparently it is not a file written to a disk this time.
Version
Package Contents: Intel(R) VTune(TM) Amplifier XE 2013 Update 15
Build Number: 328102
Log
Collection and Platform Info
  Application Command Line:    pw4gww.x < GWL-profile/example01/methane_pw4gww.in  >GWL-profile/example01/out.pw4gww.methane
  Environment Variables:
  Operating System:    3.11.0-18-generic DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=12.04
DISTRIB_CODENAME=precise
DISTRIB_DESCRIPTION="Ubuntu 12.04.4 LTS"
  Computer Name:    gravitas-what-gravitas-ubuntu
  Result Size:    3 MB
  CPU
    Name:    3rd generation Intel(R) Core(TM) Processor family
    Frequency:    2.7 GHz
    Logical CPU Count:    4
Screen output:
(I was using export AMPLXE_RUNTOOL_OPTIONS="--profiling-signal 40" in this case. No warning notice about internal use of that signal was shown)
forrtl: Invalid argument
forrtl: severe (38): error during write, unit 6, file /proc/9427/fd/1
Image              PC                Routine            Line        Source
pw4gww.x           0000000000A4E603  Unknown               Unknown  Unknown
pw4gww.x           00000000004F8727  o_bands_                  260  o_bands.f90
pw4gww.x           0000000000446E05  produce_wannier_g         318  produce_wannier_gamma.f90
pw4gww.x           000000000043BD3B  MAIN__                    492  pw4gww.f90
pw4gww.x           000000000043AEB6  Unknown               Unknown  Unknown
libc.so.6          00007F49CC17776D  Unknown               Unknown  Unknown
pw4gww.x           000000000043ADA9  Unknown               Unknown  Unknown
