Analyzers
5307 Discussions
GDI Resource leak with QuickWin Fortran
lokida
I use an evaluation inspection XE 2011 (download last week) to test it. It is under windows XP.
My main problem is that during memory leak inspection, At the end of the execution, I have a lot of GDI Resource leaks about QuickWin. For example with SETBKCOLOR, SETWINDOWCONFIG, CLEARSCREEN,...
I really don't know why I have theses memory leak. What could be the problem ?
I have seen on this thread:http://software.intel.com/en-us/forums/showthread.php?t=83696
that "The GDI leak diagnostic only appears at level 1. At higher diagnostics levels, this is not reported.""
How do I change the diagnostics levels ? Is-it in intel inspector or in the project ?
Thank you.
lokida
So, no one to advise me on this "problem" ?
Rob5
New Contributor II
In regards to the question about changing the diagnostic level, you can change the diagnostic level by selecting among the analysis types. The following link provides information about selecting a Memory Error Analysis type.
http://software.intel.com/sites/products/documentation/hpc/inspectorxe/en-us/lin/start/conf/GSTs/memory_leak/conf_memory_configure_analysis.htm
You can select a different Memory Error Analysis type for example (Detect Leaks mi1, Detect Memory Problems mi2, Locate Memory Problems mi3) and click on the Show Command Line button in the lower right corner of the Intel Inspector XE GUI to see the formulated command and more specifically what -collect is set to (Example mi1, mi2, mi3).
After the analysis has completed and data finalized, the following document discusses interpreting result data for detected memory errors.
http://software.intel.com/sites/products/documentation/hpc/inspectorxe/en-us/lin/start/conf/GSTs/memory_leak/conf_memory_interpret_result_data.htm
In regards to resource leaks you are experiencing related to SETBKCOLOR, SETWINDOWCONFIG,CLEARSCREEN in your application, perhaps there is someone else on the forum who knows something about this off the top of their head. If not, we may need additional information or a sample reproducer to interpret and provide suggestions.
