Analyzers
Group results by synchronization event
Elsayed__Shehab
Hello All,
I was wondering if there is a way from the command line to group the results by synchronization event. By synchronization event I mean each time a synchronization was called. For example, if the same barrier wait is called multiple times, I would like to see stats for each of these times individually.
Thank you very much in advance
Dmitry_P_Intel1
Hello Shehab,
By grouping results you mean that you want to see wait time on a barrier for each barrier instances?
What is the semantic - are the barrier instances called in the loop or they are used to sync different algorithm pieces (and as a result called from different functions for example)?
And what threading model do you use? OpenMP, TBB or row OS threads?
Thank you, Regards, Dmitry
Elsayed__Shehab
Thank you for your reply.
Wait time at each barrier can be one thing. Other stats I am interested are similar to those you can get from "General Exploration" such as instructions retired, cache miss rates, etc ...
I am trying different applications that have different semantics.
The applications I am studying are using pthreads.
