Analyzers
5284 Discussions
Hotspot analysis is not providing bottom-up analysis
Ayam
I am running the svm application on intel vtune for hotspot analysis. The input file size is 2GB. The application run fine however the hotspot analysis on intel vtune GUI just provides the following summary information:
Collection and Platform Info
 Application Command Line:    /usr/local/hadoop/scr_svm
 Operating System:    3.8.0-19-generic DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=13.04
DISTRIB_CODENAME=raring
DISTRIB_DESCRIPTION="Ubuntu 13.04"
  Computer Name:    HH-Xeon
  Result Size:    933 MB
  CPU
    Name:    Intel(R) Xeon(R) E5 processor
    Logical CPU Count:    24
No bottom-up analysis is created that shows the modules and the functions for hotspot. In analysis type tab of intel vtune, I have used parameter "duration time estimate: over 3 hours".
Can you please explain, why I am not getting hotspot information?
Vitaly_S_Intel
Hi Maria!
Can you please post screenshot of VTune GUI when analysis completed?
Also, can you please provide output of the following commands:
> amplxe-cl -R summary -r <path_to_result>
> amplxe-cl -R hotspots -r <path_to_result>
For the last one I only need to know does it print the list of functions or not.
Ayam
First Command output:
amplxe-cl -R summary -r intel/amplxe/projects/fccm_hotspot/r005ah/
amplxe: Using result path `/home/hduser/intel/amplxe/projects/fccm_hotspot/r005ah'
amplxe: Executing actions 50 % Generating a report
Parameter                 r005ah
Application Command Line  /usr/local/hadoop/scr_kmean
Operating System          Linux
Computer Name             HH-Xeon
Result Size               3878111
CPU
Parameter          r005ah
Name               Intel(R) Xeon(R) E5 processor
Logical CPU Count  1
Summary
Elapsed Time:  2.120
amplxe: Executing actions 100 % done
Second Command output:
amplxe-cl -R hotspots -r intel/amplxe/projects/fccm_hotspot/r005ah/
This result does not have data that can be displayed with the following specified 'group-by' argument:
amplxe: Error: Error 0x40000024 (Reporter error)
It does not show the list of functions.
Vitaly_S_Intel
Thanks Maria, looks like nothing was collected for some reason.
Can you please provide output of:
$ ls -al <path_to_result>/data.0
$ ls -al <path_to_result>/config
I suppose result directory is small, can you send it to me via private message?
Ayam
@Vitaly Slobodskoy. I have tried to send you the private message but i guess i do not have the privilege. I have attached the output of the requested commands with this message. If you need more information, please let me know. Thanks
Vitaly_S_Intel
Thanks Maria!
Based on the output file you attached there is no PMU events trace in your result which leads to absence of hotspots. Can you please share exact command line you used to collect this result? Also, weren't there any error messages when you run collection? Can you run collection again and provide the output of amplxe-cl ?
Vitaly_S_Intel
Small addition: if you used GUI to collect result, please attach file <result_dir>/config/runsa.options or simply provide its content (it should be small). You can remove any sensitive information in its content (e.g. application name).
Deepak_S_2
I am also getting nearly similar problem.I am running the a C++ binary file as input  on intel vtune for hotspot analysis.  The application running correctly however the hotspot analysis on intel vtune GUI just provides the following summary information:
Thanks in advance.
David_A_Intel1
So what happens when you click on the "Bottom-up" tab?
David_A_Intel1
Never mind.  Dude!  You are collecting data for .002 seconds.  That is way too short!!!  Try profiling something of substance!! ;)
We include several samples in the product installation for this purpose.  Please see <install-dir>/samples/en.
Bernard
Valued Contributor I
That is an equivalent of probably two samples way to small for gathering any profiling results.
