Analyzers
5268 Discussions
Hotspot analysis , lock wait analysis results in failed to finalize data
Krupesh_D_
I am using intex VTune amplifier XE 2013.
I am using this tool to measure the performance of my application.
My application spwans more than one child processes hence I have selected "Analyse child processes" check box from project properties.
Whenever I run following analysis it results into the "Failed to finalize result".
(1) Hot spot analysis
(2) Locks and waits
The steps I am following are mentioned below:
(1) File->New->Analysis
(2) Select Hotspot or Locks and waits analysis
(3) Go to project properties
(4) Target type: Attach to Process
(5) I am providing process name and search directories for the source.
(6) Press OK select Start
When I select Stop it shows the error as "Failed to finalize the result".
Kindly look into the matter.
Please let me know in case if you want any further information for the same.
Krupesh
