Analyzers
5253 Discussions
How to Change the Target type drop-down to Correctness Analysis
jguillau
Hi. This is my first post to the forum. I am testing advisor_xe_2016.1.0.423501 on a E5-2690 v3 cpu using the nqueens tutorial. According to the html doc "Predict Parallel Data Sharing Problems", i should be able to: Change Intel Advisor Project Properties: In the Intel Advisor GUI, choose File > Project Properties.... In the Analysis Target tab: Change the Target type drop-down to Correctness Analysis. but this is not available for me, see attached screenshot. I believe i compiled and setup the code correctly. Did i miss an important step ? Than you in advance for your help. jg.
TimP
Maybe you wanted inspector.
jguillau
I was a bit confused by the documentation because advisor_xe_2016 does not look exactly the same compared to previous versions.
I found my way now, thank you for your help.
jg.
Kevin_O_Intel1
In the 2016 version of Advisor we renamed the "Correctness Analysis" to "Dependencies Analysis"
Let me know if you have any further questions.
Kevin
