Analyzers
5271 Discussions
How to delay the analysis in Intel Inspector?
Akhilesh_Naidu
Just want to know if we can delay the analysis or we can start the analysis in the later phase in Intel Inspector?
RahulU_Intel
Thanks for posting in Intel Forums.
Could you please confirm the OS you are using.
Intel Inspector provides the opportunity to investigate more deeply with an interactive debugging session during analysis. Select analysis start location with debugger configuration which delays problem detection until a selected point in the application. This option lets you choose an arbitrary location to turn on error detection, allowing faster execution until that point.
There is no start paused analysis support for inspector. We need to use gdb in case on Linux or MSVC in Windows by putting breakpoint from where to start. There is no itt_pause resume support in Inspector.
If you are using windows please refer the following link:
If you are using linux refer the below link:
Rahul
Akhilesh_Naidu
Thanks for the response.
Want to know more about this. Suppose I want to detect error in later part of the code, so what all things I need to do?
Akhilesh
RahulU_Intel
Thanks for your response. Could you please confirm the OS that you are using so that we can provide the detailed steps for you to follow. If you are on windows, please let us know whether Inspector is integrated with Visual Studio.
Rahul
Akhilesh_Naidu
I am on Linux machine, currently running the tool on a machine with OS Redhat 6.7.
Akhilesh
Akhilesh_Naidu
RahulU_Intel
Sorry for your late reply. We are looking into your case, we'll get back to you. Can you please confirm what debugger you are using.
Rahul
Akhilesh_Naidu
Do I need to externally link a debugger or it is already present in the tool?
When ever I start analysis using debugger, a separate terminals open and nothing happens.
Please kindly let me know what to do!!
Akhilesh
Akhilesh_Naidu
When can I expect the solution?
Mark_L_Intel
Hello Akhilesh,
Were you able to follow instructions from the last message?
Mark_L_Intel
Due to lack of activity, this ticket will no longer be supported by Intel team. Please rely on the community support. Thank you.
