Analyzers
How to export a result of an analyze to readable format?
Matheus_S_
初学者
1,400 次查看
Hi everyboby,
I'm new here in the forum so i would like to apologize if my post isn't in accordance with the rules.
I'm working on a scientífic paper on the university and need scan a code regardind the amount and tipe of branchs and export a log file that is readble nd contains the base adress and the target adress of each branch, and it was taken or not.
I started using the Vtune a short time and I couldn't find a way to do what i need.
So i want to know if it is possible to do this?If Yes, how can i do?And if no, you could apoint me some tool that i can do this?
Thank you.
0 项奖励
3 回复数
David_A_Intel1
1,400 次查看
Hi Mattheus S.:
No, VTune Amplifier doesn't do this kind of monitoring. That is something more for a simulator rather than a profiler.
You might find a pintool, or write one, to log branches and if they are taken or not.  Lots of people have written pintools, so there might be something out there, but I am not aware of any.
0 项奖励
TimP
名誉分销商 III
1,400 次查看
Such functionality is in the profile guided data collection of Intel compilers. Surely you could find references perhaps about similar use of other compiler.
0 项奖励
Matheus_S_
初学者
1,400 次查看
Thanks!!
0 项奖励
回复
