Analyzers
How to identify the cause for the high CPI rate
mahesh_w_
I was trying to identify the reason for the lateness of my program. And I notice that one function has high CPI value (4.5), and it says the reason may
  • Memory stalls
  • Instruction starvation
  • Branch misprediction
  • Long latency instructions
How can I explore those things using Vtune. Can anyone help me to identify the specific reason for the high CPI?
I am using vtune 2015 U1 (trial version). and i am a windows user
Peter_W_Intel
CPI value is high, this is performance result. You need to identify why by using General Exploration analysis to know detail.
Please see if there is any highlight item (pink color) in bottom-up report, item(s) will be in:
Filled Pipeline Slots :  Retiring (General Retirement,  Microcode Sequencer), Bad Speculation
Back-end Bound: Memory Bound(L1 Bound, Store Bound, L3 Bound), Core Bound (Port Utilization)
Front-end Bound: Front-end Latency, Front-End Bandwidth.
Peter_W_Intel
mahesh_w_
@peter,
Thank You.
In the general  exploration following values were high(marked in pink), so that means memory stalls caused the problem?
Unfilled Pipeline Slots
    memory latency
        LLC miss (0.247)
        LLC Hit (0.262)
        DTLB Overhead (0.264)
Bernard
Valued Contributor I
I think that LLC miss rate and DTLB page walking overhead could have contributed to large CPI rate.
Peter_W_Intel
mahesh w.
Please drill down source view to investigate why LLC miss and DTLB page walk overhead, you might change data structure for optimizing memory layout.
mahesh_w_
@iliyapolak and @Peter
Thank you for your kind helps. I got the answer I wanted.I can continue From here(probably).
Bernard
@mahesh
You are welcome.
