Analyzers
5342 Discussions
How to profile miniconda python?
agko
Profiling a test script test.py with /usr/bin/python works fine, however if I want to profile the same script with /home/myname/miniconda/envs/myenv/bin/python, the test script is not executed and thus not profiled.
I would be thankful for any ideas to make this work!
Aleksei_O
Hello agko,
Thanks for your question.
What python version did you use in both cases?
What analysis did you run?
What are symptoms in case when script is not exuceted? Any warning, error in the output?
Aleksei.
agko
Thanks for the reply, @Aleksei_O .
usr: python3.6
miniconda3: python3.8
Hotspots Analysis
No, errors. In "Top-Down Tree" the miniconda python Versions, does not get past the _start function.
agko
I just tried with usr python3.8 and the analysis does not get past the _start function. I guess you were asking for the python version, because 3.8 might be problematic...?
Aleksei_O
Let me ask you more details
1) Have you ran User-Mode or HW Event based Hotspots analysis?
2) If you switch to Bottom-up tab, can you see the python code from your workload?
agko
1) User mode
2) Just Python internal output, no lines from my .py script.
Aleksei_O
Thanks for your reply.
Let me know which version of VTune did you use?
Please try using the newest VTune and let me know about results.
JananiC_Intel
Did you try Aleksei_O's suggestion?Do you have any update?
Janani Chandran
agko
Installing the newest Vtune solved the problem. Thank you for the help!
JananiC_Intel
Glad to know that your issue is resolved. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Janani Chandran
