Analyzers
5271 Discussions
How to run memory-access profiling in driverless mode
cutefisher
Hi all,
How to run a memory-access profiling with a driveless mode?
First, i've tried to directly run memory-access using following cmd,
amplxe-cl -collect memory-access -target-pid `pidof mysqld` -r /tmp/xxx
Error to the screen is
amplxe: Error: Cannot collect memory bandwidth data. Make sure the sampling driver is installed and enabled on your system. See the Sampling Drivers help topic for more details. Note that memory bandwidth collection is not possible if you are profiling inside a virtualized environment.
Then, i've tried to install sampling drivers. However, it fails due to PAX load issue.
The PAX service is not loaded anymore.
Checking for PMU arbitration service (PAX) ... not detected.
Attempting to start PAX service ...
Executing: insmod ./pax/pax-x32_64-3.10.107-1-tlinux2-0054smp.ko
insmod: ERROR: could not insert module ./pax/pax-x32_64-3.10.107-1-tlinux2-0054smp.ko: Required key not available
I can not solve this issue. That's why i tried to use driverless mode by setting
echo 0 > /proc/sys/kernel/perf_event_paranoid
Still, it did not work after rerun
The error msg is the same as previous.
Could anyone tell me how to solve the Sampling Driver installation issue or How to use driverless mode to collect memory-access profiling ?
Best Regards
Soumya_M_Intel
Hi cutefisher,
Thanks for posting your concern on the forum. Since your query is related to the Intel® VTune™ Profiler, we are moving this topic to the 'Analyzers' community for further assistance.
Have a nice day ahead.
Soumya
AlekhyaV_Intel
We will work on this issue internally and get back to you with an update. Regarding the driverless mode profiling, please refer this documentation: https://www.intel.com/content/www/us/en/develop/documentation/vtune-cookbook/top/configuration-recipes/profiling-hardware-without-sampling-drivers.html. Meanwhile we would like you to provide some information to us so that we can debug your issue further:
1) The sample reproducer so that we can try profiling on that application from our side.
2) Your OS details along with version.
3) List of drivers installed along with your VTune Profiler
4) Your VTune version.
5) Self checker logs
6) dmesg logs. Please run the analysis and after it fails, run the below command:
      dmesg > dmesg.log
please share the dmesg.log i.e. generated after running the above command.
We have a couple of suggestions for you too. Please check if the drivers are properly installed with the below steps:
1) In this path- cd /opt/intel/oneapi/vtune/latest/sepdk/src
sudo ./insmod-sep -q
2) Try building the drivers once again and check if it solves your issue.
./build-driver -r
If this answers your query, Please accept this as solution so that this helps others with similar issue. Thank you!
Alekhya
cutefisher
shows
Copyright (C) 2009-2019 Intel Corporation. All rights reserved.
Intel(R) VTune(TM) Amplifier 2019 (build 604197)
-bash-4.2$ amplxe-cl -collect memory-access -target-pid `pidof mysqld` -r /tmp/xxx
amplxe: Warning: Measuring peak bandwidth may be not accurate in the attach mode since the system can be heavily loaded at the time of the measurement. Accurate peak DRAM bandwidth is important for further analysis. When collection is done, check the Bandwidth Utilization Histogram on the Summary view and make sure the Low/Medium/High utilization thresholds are correct for your system and manually adjust them, if required.
-bash-4.2$
It's a Centos variation 3.10.107
No Sampling Driver installed due to install failure.
-bash-4.2$ ./insmod-sep -r -g georgezqiao
NOTE:  super-user or "root" privileges are required in order to continue.
Please enter "root" Password:
Warning:  the following driver(s) were not found loaded in the kernel:  sep5.
Warning:  no vtsspp driver was found loaded in the kernel.
Warning:  the following driver(s) were not found loaded in the kernel:  socperf3.
Executing: insmod ./pax/pax-x32_64-3.10.107-0054smp.ko
insmod: ERROR: could not insert module ./pax/pax-x32_64-3.10.107-0054smp.ko: Required key not available
Error:  pax driver failed to load!
You may need to build pax driver for your kernel.
Please see the pax driver README for instructions.
Error: failed to start or connect to required PAX service
Linux-2019Update8
Hangs in
-bash-4.2$ sudo ./amplxe-self-checker.sh
Intel(R) VTune(TM) Amplifier Self Check Utility
Build Number: 604197
     No dmesg here.
AlekhyaV_Intel
From your OS details, we observe that CentOS 3* is not a supported operating system for VTune Profiler. We've provided the system requirements of VTune:https://www.intel.com/content/www/us/en/developer/articles/system-requirements/vtune-profiler-system-requirements.html
We recommend you to use Vtune in any of the supported operating systems. You could try in Intel DevCloud as well. We have provided a VTune cookbook about how to use VTune in DevCloud for oneapi below: https://www.intel.com/content/www/us/en/develop/documentation/vtune-cookbook/top/configuration-recipes/using-vtune-server-with-vs-code-intel-devcloud.html
If you're not a DevCloud user, please enroll here: https://devcloud.intel.com/oneapi/
Alekhya
AlekhyaV_Intel
Has the solution provided helped?
Could you please give us an update regarding this issue?
Alekhya
AlekhyaV_Intel
We assume that your issue is resolved. If you need any further assistance, please post a new question as this thread will no longer be monitored by Intel.
Alekhya
