Analyzers
5255 Discussions
I want to see Remote Correction (host and T/Gt are both Windows) memory transactions with Vtune Prof
正西村
Hi Community support
Thank you for you support.
BSOD occurs on the target board.
<<Environment>>
・CPU: EHL
・OS: Windows 10 IoT Enterprise LTSC.
・Information from OS dump: The page table in the Windows kernel area is destroyed.
・Occurrence rate: BSOD occurs once a month if the number of units is increased, once every 200 days if the number of units is not increased.
・Occurs even with the basic OS (apps have little impact)
I want to see Remote Correction (host and T/Gt are both Windows) memory transactions with Vtune Profiler.
I understand that Memory transactions at an appropriate time can be seen by clicking ▷ below Configure Analysis -> How -> Memory Access.
<< Question>>
In this Issue case, it is necessary to see memory transactions from long time before the BSOD occurs.
Is there a way to set it up like that?
Best regards
