Analyzers
5307 Discussions
Inspector 2013 for WINDOWS to debug mingw-gcc compiled code
sigmahat
Can code compiled with mingw-gcc on windows be analyzed using Inspector? Does the intel debugger recozgnize gdb debugging symbols? Does the code need to be compiled with specific debug switches (-ggdb, -g-dwarf2 etc.)? Thanks,
Peter_W_Intel
Sorry that code compiled with minggw-cc is NOT supported for both Inspector XE and VTune(TM) Amplifier XE, for now.
TimP
Even on linux, where gcc and icc use the same debug symbol formats, Inspector instructions specify that Intel compilers must be used. If you can generate debug symbols compatible with Visual Studio debugger, it may be worth trying.
