Analyzers
5296 Discussions
Inspector 2018 - Internal error contact Intel
carr__phil
I have downloaded Intel Studio Parallel  Studio on Centos 7 64bit and have tried to use Inspector, however when I try to run the project I get an internal error contact Intel.
Anybody have an idea?
Kevin_O_Intel1
We need to look at the results generated to check the error log files.
Can you file a support issue for Inspector? Attach the result directory generated.
https://software.intel.com/en-us/articles/how-to-create-a-support-request-at-online-service-center
Thanks!
Baranov__Paul
I failed to file a support issue following the procedure described in https://software.intel.com/en-us/articles/how-to-create-a-support-request-at-online-service-center When I click on the 'Request support' link I get on the 'Create a Support Account' page https://www.intel.com/content/www/us/en/forms/support-registration-form.html where I'm supposed to enter my personal information. The problem is that the 'Next' button on that page stays disabled (as well as some of the fields like first name, last name etc) even after I enter the information into the enabled fields so I can't progress past this page and as result can't file any issue into your system.
Paul
Kevin_O_Intel1
Could you try to clear cache and cookies. Then try again.
Thanks!
Kevin_O_Intel1
Can you file a support issue for Inspector? One of our engineers will be in contact with you. You will need to generate some
additional log files that will allow us to debug the issues. These log files can be attached to the support issue.
