I have re-installed several times the Inspector XE 2011 on a Dual-Quad Xeon, running XP SP3 OSthat uses VS2005.
The PC already hadthe Standard Parallel Studio tools installed and working fine.
While perform a run to detect data races, I decided to quit.
Instead STOP followed by CLOSE, I hitted CLOSE, directly.
At this point a message box appeared telling me:
"The Application has failed to start because framedyn.dll was not foud, Re-Installing application might fix. problem."
I completely removed the tool, and re-installed twice, already.
What is going on?
I retried the above test that failed on the XP machine on another PC running Win 7, latest SP.
It has the same Parallel Studio there + XE tool set, also
The only difference is that the Win 7 machine has VS2005 + VS2010.
On this machine, the Inspector XE closes fine.
Any idea on how to make fully operational the Inspector XE on the XP machine?
I need a resolution to this, since the Inspector XE keeps on running, forcing a hard reset to regain control of the PC.
Sal
What is going on?
Sal
- Tags:
- CC++
- Debugging
- Development Tools
- Fortran
- Intel® Inspector
- Optimization
- Parallel Computing
- Vectorization
