Analyzers
5342 Discussions
Install Thread Checker on Ubuntu 7.10 problem
atlruds
Hi
I know the Ubuntu 7.10 is not supported, but I get a strange error when running sudo ./install.sh:
./install.sh: line 332: 8373 Floating point exception(core dumped) $install_prog $@
Is this the expected error? I have successfully installed the compiler and VTune on Ubuntu 7.10 and only need the thread checker.
I have seen some other threads modifying the /data/install-tc.sh and installing using that file, but they only work with licence files. I am using a non-commercial version with a serial code. Is there any workaround with serial code installation?
- Atle
