Analyzers
5296 Discussions
Install trouble - "error occured during the installation of assembly component"
STEPHANIE_J_
Hi all,
I'm trying to install Vtune Amplifier XE 2013 Update 16 on Windows 7 Enterprise x64 and running into an error.
I've tried installing the Intel Vtune initial Setup and the update 16, and both return this error.  I tried turning off Windows update before installing, and I make sure I run as administrator.  Vtune fails to install the file msvcrt_x64.msi
I'm also attaching the log file it returned.  I saw a couple of similar forum threads like this but one was left unresolved and the other said it was resolved with update 15 ( http://software.intel.com/en-us/forums/topic/401514 and http://software.intel.com/en-us/forums/topic/485642 )
Log file:
317377
Any help would be great.
Stephanie
STEPHANIE_J_
Sorry, it looks like my files don't show up normally in my post.
The Error message is:
An error occured during the installation of assembly component
{98CB24AD-52FB-DB5F-A01F-C8B3B9A1E18E}. HRESULT: 0x80070BC9
The log file:
This log file is generated by C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\setup.exe
Copyright (c) 2012, Intel Corporation.
ISSA(i) [13:54:54.209] | (5729.2526): LicenseHandler::GetIntelLicenseFileEnvVar(): pzLicFileDirs - C:\Program Files (x86)\Common Files\Intel\Licenses
ISSA(i) [13:54:54.209] | (5729.2401): lzBaseDir and stuff: C:\Program Files (x86)\Common Files\Intel\Licenses\*.lic
ISSA(i) [13:54:54.209] | (5729.1690): LicenseHandler::getLicenseFileDir() - CommonFilesDir C:\Program Files (x86)\Common Files
ISSA(i) [13:54:54.209] | (5729.1719): LicenseHandler::getLicenseFileDir() - C:\Program Files (x86)\Common Files\Intel\Licenses
PSET(i) [13:54:54.213] | (2145.165): Using resource dll C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\1033\Resources.dll
PSET(i) [13:54:54.217] | (2145.1577): MSI log file temp name (its content will be merged into the main log file): C:\Users\PCCA-PM\AppData\Local\Temp\MSIED31.tmp
PSET(i) [13:54:54.284] | (3073.783): MsiOpenPackageEx(C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\indicator\indicator.msi)
MSI(i) [13:54:54.444] | === Verbose logging started: 4/8/2014  13:54:54  Build type: SHIP UNICODE 5.00.7601.00  Calling process: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\setup.exe ===
MSI(i) [13:54:54.444] | MSI (c) (B0:9C) [13:54:54:292]: SOFTWARE RESTRICTION POLICY: Verifying package --> 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\indicator\indicator.msi' against software restriction policy
MSI(i) [13:54:54.444] | MSI (c) (B0:9C) [13:54:54:292]: SOFTWARE RESTRICTION POLICY: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\indicator\indicator.msi has a digital signature
MSI(i) [13:54:54.444] | MSI (c) (B0:9C) [13:54:54:389]: SOFTWARE RESTRICTION POLICY: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\indicator\indicator.msi is permitted to run at the 'unrestricted' authorization level.
MSI(i) [13:54:54.444] | MSI (c) (B0:9C) [13:54:54:415]: Cloaking enabled.
MSI(i) [13:54:54.444] | MSI (c) (B0:9C) [13:54:54:415]: Attempting to enable all disabled privileges before calling Install on Server
MSI(i) [13:54:54.444] | MSI (c) (B0:9C) [13:54:54:417]: End dialog not enabled
MSI(i) [13:54:54.444] | MSI (c) (B0:9C) [13:54:54:417]: Original package ==> C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\indicator\indicator.msi
MSI(i) [13:54:54.444] | MSI (c) (B0:9C) [13:54:54:417]: Package we're running from ==> C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\indicator\indicator.msi
MSI(i) [13:54:54.444] | MSI (c) (B0:9C) [13:54:54:418]: Machine policy value 'DisableUserInstalls' is 0
MSI(i) [13:54:54.444] | MSI (c) (B0:9C) [13:54:54:419]: APPCOMPAT: Compatibility mode property overrides found.
MSI(i) [13:54:54.444] | MSI (c) (B0:9C) [13:54:54:419]: APPCOMPAT: looking for appcompat database entry with ProductCode '{0C13F8EE-A432-495D-8F77-EDB3F3778D2D}'.
MSI(i) [13:54:54.444] | MSI (c) (B0:9C) [13:54:54:419]: APPCOMPAT: no matching ProductCode found in database.
MSI(i) [13:54:54.444] | MSI (c) (B0:9C) [13:54:54:424]: MSCOREE not loaded loading copy from system32
MSI(i) [13:54:54.444] | MSI (c) (B0:9C) [13:54:54:427]: Machine policy value 'TransformsSecure' is 0
MSI(i) [13:54:54.444] | MSI (c) (B0:9C) [13:54:54:427]: User policy value 'TransformsAtSource' is 0
MSI(i) [13:54:54.444] | MSI (c) (B0:9C) [13:54:54:427]: Note: 1: 2262 2: File 3: -2147287038
MSI(i) [13:54:54.444] | MSI (c) (B0:9C) [13:54:54:427]: Note: 1: 2205 2:  3: MsiFileHash
MSI(i) [13:54:54.444] | MSI (c) (B0:9C) [13:54:54:428]: Machine policy value 'DisablePatch' is 0
MSI(i) [13:54:54.444] | MSI (c) (B0:9C) [13:54:54:428]: Machine policy value 'AllowLockdownPatch' is 0
MSI(i) [13:54:54.444] | MSI (c) (B0:9C) [13:54:54:428]: Machine policy value 'DisableLUAPatching' is 0
MSI(i) [13:54:54.444] | MSI (c) (B0:9C) [13:54:54:428]: Machine policy value 'DisableFlyWeightPatching' is 0
MSI(i) [13:54:54.444] | MSI (c) (B0:9C) [13:54:54:428]: Enabling baseline caching for this transaction since all active patches are MSI 3.0 style MSPs or at least one MSI 3.0 minor update patch is active
MSI(i) [13:54:54.444] | MSI (c) (B0:9C) [13:54:54:428]: APPCOMPAT: looking for appcompat database entry with ProductCode '{0C13F8EE-A432-495D-8F77-EDB3F3778D2D}'.
MSI(i) [13:54:54.444] | MSI (c) (B0:9C) [13:54:54:428]: APPCOMPAT: no matching ProductCode found in database.
MSI(i) [13:54:54.444] | MSI (c) (B0:9C) [13:54:54:428]: Transforms are not secure.
MSI(i) [13:54:54.444] | MSI (c) (B0:9C) [13:54:54:428]: Note: 1: 2205 2:  3: Control
MSI(i) [13:54:54.444] | MSI (c) (B0:9C) [13:54:54:428]: PROPERTY CHANGE: Adding MsiLogFileLocation property. Its value is 'C:\Users\PCCA-PM\AppData\Local\Temp\MSIED31.tmp'.
MSI(i) [13:54:54.444] | MSI (c) (B0:9C) [13:54:54:428]: No Command Line.
MSI(i) [13:54:54.444] | MSI (c) (B0:9C) [13:54:54:428]: PROPERTY CHANGE: Adding PackageCode property. Its value is '{F7333571-5276-4BF4-A6E2-695FDAC1CD7F}'.
MSI(i) [13:54:54.444] | MSI (c) (B0:9C) [13:54:54:428]: Product Code passed to Engine.Initialize:           '(none)'
MSI(i) [13:54:54.444] | MSI (c) (B0:9C) [13:54:54:428]: Product Code from property table before transforms: '{0C13F8EE-A432-495D-8F77-EDB3F3778D2D}'
MSI(i) [13:54:54.444] | MSI (c) (B0:9C) [13:54:54:428]: Product Code from property table after transforms:  '{0C13F8EE-A432-495D-8F77-EDB3F3778D2D}'
MSI(i) [13:54:54.444] | MSI (c) (B0:9C) [13:54:54:428]: Product not registered: beginning first-time install
MSI(i) [13:54:54.444] | MSI (c) (B0:9C) [13:54:54:428]: PROPERTY CHANGE: Adding ProductState property. Its value is '-1'.
MSI(i) [13:54:54.444] | MSI (c) (B0:9C) [13:54:54:428]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer 3: 2
MSI(i) [13:54:54.444] | MSI (c) (B0:9C) [13:54:54:429]: Entering CMsiConfigurationManager::SetLastUsedSource.
MSI(i) [13:54:54.444] | MSI (c) (B0:9C) [13:54:54:429]: User policy value 'SearchOrder' is 'nmu'
MSI(i) [13:54:54.444] | MSI (c) (B0:9C) [13:54:54:429]: Adding new sources is allowed.
MSI(i) [13:54:54.444] | MSI (c) (B0:9C) [13:54:54:429]: PROPERTY CHANGE: Adding PackagecodeChanging property. Its value is '1'.
MSI(i) [13:54:54.444] | MSI (c) (B0:9C) [13:54:54:429]: Package name extracted from package path: 'indicator.msi'
MSI(i) [13:54:54.444] | MSI (c) (B0:9C) [13:54:54:429]: Package to be registered: 'indicator.msi'
MSI(i) [13:54:54.444] | MSI (c) (B0:9C) [13:54:54:429]: Note: 1: 2205 2:  3: Error
MSI(i) [13:54:54.445] | MSI (c) (B0:9C) [13:54:54:430]: Note: 1: 2262 2: AdminProperties 3: -2147287038
MSI(i) [13:54:54.445] | MSI (c) (B0:9C) [13:54:54:430]: Machine policy value 'DisableMsi' is 0
MSI(i) [13:54:54.445] | MSI (c) (B0:9C) [13:54:54:430]: Machine policy value 'AlwaysInstallElevated' is 0
MSI(i) [13:54:54.445] | MSI (c) (B0:9C) [13:54:54:430]: User policy value 'AlwaysInstallElevated' is 0
MSI(i) [13:54:54.445] | MSI (c) (B0:9C) [13:54:54:430]: Product installation will be elevated because user is admin and product is being installed per-machine.
MSI(i) [13:54:54.445] | MSI (c) (B0:9C) [13:54:54:430]: Running product '{0C13F8EE-A432-495D-8F77-EDB3F3778D2D}' with elevated privileges: Product is assigned.
MSI(i) [13:54:54.445] | MSI (c) (B0:9C) [13:54:54:430]: PROPERTY CHANGE: Adding MsiSystemRebootPending property. Its value is '1'.
MSI(i) [13:54:54.445] | MSI (c) (B0:9C) [13:54:54:430]: TRANSFORMS property is now:
MSI(i) [13:54:54.445] | MSI (c) (B0:9C) [13:54:54:430]: PROPERTY CHANGE: Adding VersionDatabase property. Its value is '200'.
MSI(i) [13:54:54.445] | MSI (c) (B0:9C) [13:54:54:431]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming
MSI(i) [13:54:54.445] | MSI (c) (B0:9C) [13:54:54:431]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Favorites
MSI(i) [13:54:54.445] | MSI (c) (B0:9C) [13:54:54:431]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Network Shortcuts
MSI(i) [13:54:54.445] | MSI (c) (B0:9C) [13:54:54:431]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Documents
MSI(i) [13:54:54.445] | MSI (c) (B0:9C) [13:54:54:432]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
MSI(i) [13:54:54.445] | MSI (c) (B0:9C) [13:54:54:432]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Recent
MSI(i) [13:54:54.445] | MSI (c) (B0:9C) [13:54:54:432]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\SendTo
MSI(i) [13:54:54.445] | MSI (c) (B0:9C) [13:54:54:433]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Templates
MSI(i) [13:54:54.445] | MSI (c) (B0:9C) [13:54:54:433]: SHELL32::SHGetFolderPath returned: C:\ProgramData
MSI(i) [13:54:54.445] | MSI (c) (B0:9C) [13:54:54:433]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Local
MSI(i) [13:54:54.445] | MSI (c) (B0:9C) [13:54:54:433]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Pictures
MSI(i) [13:54:54.445] | MSI (c) (B0:9C) [13:54:54:434]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI(i) [13:54:54.445] | MSI (c) (B0:9C) [13:54:54:434]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
MSI(i) [13:54:54.445] | MSI (c) (B0:9C) [13:54:54:435]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu
MSI(i) [13:54:54.445] | MSI (c) (B0:9C) [13:54:54:435]: SHELL32::SHGetFolderPath returned: C:\Users\Public\Desktop
MSI(i) [13:54:54.445] | MSI (c) (B0:9C) [13:54:54:435]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI(i) [13:54:54.445] | MSI (c) (B0:9C) [13:54:54:436]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
MSI(i) [13:54:54.445] | MSI (c) (B0:9C) [13:54:54:436]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Desktop
MSI(i) [13:54:54.445] | MSI (c) (B0:9C) [13:54:54:437]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Templates
MSI(i) [13:54:54.445] | MSI (c) (B0:9C) [13:54:54:437]: SHELL32::SHGetFolderPath returned: C:\Windows\Fonts
MSI(i) [13:54:54.445] | MSI (c) (B0:9C) [13:54:54:438]: Note: 1: 2898 2: MS Sans Serif 3: MS Sans Serif 4: 0 5: 16
MSI(i) [13:54:54.445] | MSI (c) (B0:9C) [13:54:54:443]: MSI_LUA: Setting AdminUser property to 1 because this is the client or the user has already permitted elevation
MSI(i) [13:54:54.445] | MSI (c) (B0:9C) [13:54:54:443]: MSI_LUA: Setting MsiRunningElevated property to 1 because the install is already running elevated.
MSI(i) [13:54:54.445] | MSI (c) (B0:9C) [13:54:54:443]: PROPERTY CHANGE: Adding MsiRunningElevated property. Its value is '1'.
MSI(i) [13:54:54.445] | MSI (c) (B0:9C) [13:54:54:443]: PROPERTY CHANGE: Adding Privileged property. Its value is '1'.
MSI(i) [13:54:54.445] | MSI (c) (B0:9C) [13:54:54:443]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\MS Setup (ACME)\User Info 3: 2
MSI(i) [13:54:54.445] | MSI (c) (B0:9C) [13:54:54:443]: PROPERTY CHANGE: Adding USERNAME property. Its value is 'A Valued IT Customer'.
MSI(i) [13:54:54.445] | MSI (c) (B0:9C) [13:54:54:443]: PROPERTY CHANGE: Adding COMPANYNAME property. Its value is 'Intel Corporation'.
MSI(i) [13:54:54.445] | MSI (c) (B0:9C) [13:54:54:443]: PROPERTY CHANGE: Adding DATABASE property. Its value is 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\indicator\indicator.msi'.
MSI(i) [13:54:54.445] | MSI (c) (B0:9C) [13:54:54:443]: PROPERTY CHANGE: Adding OriginalDatabase property. Its value is 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\indicator\indicator.msi'.
MSI(i) [13:54:54.445] | MSI (c) (B0:9C) [13:54:54:444]: Machine policy value 'MsiDisableEmbeddedUI' is 0
MSI(i) [13:54:54.445] | MSI (c) (B0:9C) [13:54:54:444]: EEUI - Disabling MsiEmbeddedUI in quiet mode
MSI(i) [13:54:54.445] | === Logging started: 4/8/2014  13:54:54 ===
MSI(i) [13:54:54.445] | MSI (c) (B0:9C) [13:54:54:444]: Note: 1: 2205 2:  3: PatchPackage
MSI(i) [13:54:54.445] | MSI (c) (B0:9C) [13:54:54:444]: Machine policy value 'DisableRollback' is 0
MSI(i) [13:54:54.445] | MSI (c) (B0:9C) [13:54:54:444]: User policy value 'DisableRollback' is 0
MSI(i) [13:54:54.445] | MSI (c) (B0:9C) [13:54:54:444]: PROPERTY CHANGE: Adding UILevel property. Its value is '2'.
MSI(i) [13:54:54.445] | MSI (c) (B0:9C) [13:54:54:444]: Creating MSIHANDLE (1) of type 790537 for thread 3996
MSI(i) [13:54:54.445] | MSI (c) (B0:9C) [13:54:54:444]: MsiOpenPackageEx is returning 0
MSI(i) [13:54:54.445] | MSI (c) (B0:9C) [13:54:54:444]: Closing MSIHANDLE (1) of type 790537 for thread 3996
MSI(i) [13:54:54.445] | === Verbose logging stopped: 4/8/2014  13:54:54 ===
PSET(i) [13:54:54.454] | (4225.2963): MsiOpenPackageEx(C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\Setup\setup.msi)
MSI(i) [13:54:54.529] | === Verbose logging started: 4/8/2014  13:54:54  Build type: SHIP UNICODE 5.00.7601.00  Calling process: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\setup.exe ===
MSI(i) [13:54:54.529] | MSI (c) (B0:9C) [13:54:54:455]: SOFTWARE RESTRICTION POLICY: Verifying package --> 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\Setup\setup.msi' against software restriction policy
MSI(i) [13:54:54.529] | MSI (c) (B0:9C) [13:54:54:455]: SOFTWARE RESTRICTION POLICY: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\Setup\setup.msi has a digital signature
MSI(i) [13:54:54.529] | MSI (c) (B0:9C) [13:54:54:508]: SOFTWARE RESTRICTION POLICY: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\Setup\setup.msi is permitted to run at the 'unrestricted' authorization level.
MSI(i) [13:54:54.529] | MSI (c) (B0:9C) [13:54:54:509]: Cloaking enabled.
MSI(i) [13:54:54.529] | MSI (c) (B0:9C) [13:54:54:509]: Attempting to enable all disabled privileges before calling Install on Server
MSI(i) [13:54:54.529] | MSI (c) (B0:9C) [13:54:54:509]: End dialog not enabled
MSI(i) [13:54:54.529] | MSI (c) (B0:9C) [13:54:54:509]: Original package ==> C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\Setup\setup.msi
MSI(i) [13:54:54.529] | MSI (c) (B0:9C) [13:54:54:509]: Package we're running from ==> C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\Setup\setup.msi
MSI(i) [13:54:54.529] | MSI (c) (B0:9C) [13:54:54:511]: APPCOMPAT: Compatibility mode property overrides found.
MSI(i) [13:54:54.529] | MSI (c) (B0:9C) [13:54:54:511]: APPCOMPAT: looking for appcompat database entry with ProductCode '{8E0C0057-1CDD-42B7-A460-AA7202DAC533}'.
MSI(i) [13:54:54.529] | MSI (c) (B0:9C) [13:54:54:512]: APPCOMPAT: no matching ProductCode found in database.
MSI(i) [13:54:54.529] | MSI (c) (B0:9C) [13:54:54:516]: MSCOREE not loaded loading copy from system32
MSI(i) [13:54:54.529] | MSI (c) (B0:9C) [13:54:54:519]: Machine policy value 'TransformsSecure' is 0
MSI(i) [13:54:54.529] | MSI (c) (B0:9C) [13:54:54:519]: User policy value 'TransformsAtSource' is 0
MSI(i) [13:54:54.529] | MSI (c) (B0:9C) [13:54:54:520]: Machine policy value 'DisablePatch' is 0
MSI(i) [13:54:54.529] | MSI (c) (B0:9C) [13:54:54:520]: Machine policy value 'AllowLockdownPatch' is 0
MSI(i) [13:54:54.529] | MSI (c) (B0:9C) [13:54:54:520]: Machine policy value 'DisableLUAPatching' is 0
MSI(i) [13:54:54.529] | MSI (c) (B0:9C) [13:54:54:520]: Machine policy value 'DisableFlyWeightPatching' is 0
MSI(i) [13:54:54.529] | MSI (c) (B0:9C) [13:54:54:520]: Enabling baseline caching for this transaction since all active patches are MSI 3.0 style MSPs or at least one MSI 3.0 minor update patch is active
MSI(i) [13:54:54.529] | MSI (c) (B0:9C) [13:54:54:520]: APPCOMPAT: looking for appcompat database entry with ProductCode '{8E0C0057-1CDD-42B7-A460-AA7202DAC533}'.
MSI(i) [13:54:54.529] | MSI (c) (B0:9C) [13:54:54:520]: APPCOMPAT: no matching ProductCode found in database.
MSI(i) [13:54:54.529] | MSI (c) (B0:9C) [13:54:54:520]: Transforms are not secure.
MSI(i) [13:54:54.529] | MSI (c) (B0:9C) [13:54:54:520]: PROPERTY CHANGE: Adding MsiLogFileLocation property. Its value is 'C:\Users\PCCA-PM\AppData\Local\Temp\MSIED31.tmp'.
MSI(i) [13:54:54.529] | MSI (c) (B0:9C) [13:54:54:520]: No Command Line.
MSI(i) [13:54:54.529] | MSI (c) (B0:9C) [13:54:54:520]: PROPERTY CHANGE: Adding PackageCode property. Its value is '{CCEDFB3C-BE80-461B-A9C0-7FBF82144791}'.
MSI(i) [13:54:54.529] | MSI (c) (B0:9C) [13:54:54:520]: Product Code passed to Engine.Initialize:           '(none)'
MSI(i) [13:54:54.529] | MSI (c) (B0:9C) [13:54:54:520]: Product Code from property table before transforms: '{8E0C0057-1CDD-42B7-A460-AA7202DAC533}'
MSI(i) [13:54:54.529] | MSI (c) (B0:9C) [13:54:54:520]: Product Code from property table after transforms:  '{8E0C0057-1CDD-42B7-A460-AA7202DAC533}'
MSI(i) [13:54:54.529] | MSI (c) (B0:9C) [13:54:54:520]: Product not registered: beginning first-time install
MSI(i) [13:54:54.529] | MSI (c) (B0:9C) [13:54:54:520]: PROPERTY CHANGE: Adding ProductState property. Its value is '-1'.
MSI(i) [13:54:54.529] | MSI (c) (B0:9C) [13:54:54:521]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer 3: 2
MSI(i) [13:54:54.529] | MSI (c) (B0:9C) [13:54:54:521]: Entering CMsiConfigurationManager::SetLastUsedSource.
MSI(i) [13:54:54.529] | MSI (c) (B0:9C) [13:54:54:521]: User policy value 'SearchOrder' is 'nmu'
MSI(i) [13:54:54.529] | MSI (c) (B0:9C) [13:54:54:521]: Adding new sources is allowed.
MSI(i) [13:54:54.529] | MSI (c) (B0:9C) [13:54:54:521]: PROPERTY CHANGE: Adding PackagecodeChanging property. Its value is '1'.
MSI(i) [13:54:54.529] | MSI (c) (B0:9C) [13:54:54:521]: Package name extracted from package path: 'setup.msi'
MSI(i) [13:54:54.529] | MSI (c) (B0:9C) [13:54:54:521]: Package to be registered: 'setup.msi'
MSI(i) [13:54:54.529] | MSI (c) (B0:9C) [13:54:54:521]: Note: 1: 2262 2: AdminProperties 3: -2147287038
MSI(i) [13:54:54.529] | MSI (c) (B0:9C) [13:54:54:521]: Machine policy value 'DisableMsi' is 0
MSI(i) [13:54:54.529] | MSI (c) (B0:9C) [13:54:54:521]: Machine policy value 'AlwaysInstallElevated' is 0
MSI(i) [13:54:54.529] | MSI (c) (B0:9C) [13:54:54:521]: User policy value 'AlwaysInstallElevated' is 0
MSI(i) [13:54:54.529] | MSI (c) (B0:9C) [13:54:54:521]: Product installation will be elevated because user is admin and product is being installed per-machine.
MSI(i) [13:54:54.529] | MSI (c) (B0:9C) [13:54:54:521]: Running product '{8E0C0057-1CDD-42B7-A460-AA7202DAC533}' with elevated privileges: Product is assigned.
MSI(i) [13:54:54.529] | MSI (c) (B0:9C) [13:54:54:522]: PROPERTY CHANGE: Adding MsiSystemRebootPending property. Its value is '1'.
MSI(i) [13:54:54.529] | MSI (c) (B0:9C) [13:54:54:522]: TRANSFORMS property is now:
MSI(i) [13:54:54.529] | MSI (c) (B0:9C) [13:54:54:522]: PROPERTY CHANGE: Adding VersionDatabase property. Its value is '200'.
MSI(i) [13:54:54.529] | MSI (c) (B0:9C) [13:54:54:522]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming
MSI(i) [13:54:54.529] | MSI (c) (B0:9C) [13:54:54:522]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Favorites
MSI(i) [13:54:54.529] | MSI (c) (B0:9C) [13:54:54:522]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Network Shortcuts
MSI(i) [13:54:54.529] | MSI (c) (B0:9C) [13:54:54:522]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Documents
MSI(i) [13:54:54.529] | MSI (c) (B0:9C) [13:54:54:522]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
MSI(i) [13:54:54.529] | MSI (c) (B0:9C) [13:54:54:522]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Recent
MSI(i) [13:54:54.529] | MSI (c) (B0:9C) [13:54:54:522]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\SendTo
MSI(i) [13:54:54.529] | MSI (c) (B0:9C) [13:54:54:522]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Templates
MSI(i) [13:54:54.529] | MSI (c) (B0:9C) [13:54:54:522]: SHELL32::SHGetFolderPath returned: C:\ProgramData
MSI(i) [13:54:54.529] | MSI (c) (B0:9C) [13:54:54:522]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Local
MSI(i) [13:54:54.529] | MSI (c) (B0:9C) [13:54:54:522]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Pictures
MSI(i) [13:54:54.529] | MSI (c) (B0:9C) [13:54:54:522]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI(i) [13:54:54.529] | MSI (c) (B0:9C) [13:54:54:522]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
MSI(i) [13:54:54.529] | MSI (c) (B0:9C) [13:54:54:522]: SHELL32::SHGetFolderPath returned: C:\Users\Public\Desktop
MSI(i) [13:54:54.529] | MSI (c) (B0:9C) [13:54:54:522]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI(i) [13:54:54.529] | MSI (c) (B0:9C) [13:54:54:522]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
MSI(i) [13:54:54.529] | MSI (c) (B0:9C) [13:54:54:522]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Desktop
MSI(i) [13:54:54.529] | MSI (c) (B0:9C) [13:54:54:522]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Templates
MSI(i) [13:54:54.529] | MSI (c) (B0:9C) [13:54:54:522]: SHELL32::SHGetFolderPath returned: C:\Windows\Fonts
MSI(i) [13:54:54.529] | MSI (c) (B0:9C) [13:54:54:523]: Note: 1: 2898 2: MS Sans Serif 3: MS Sans Serif 4: 0 5: 16
MSI(i) [13:54:54.529] | MSI (c) (B0:9C) [13:54:54:528]: MSI_LUA: Setting AdminUser property to 1 because this is the client or the user has already permitted elevation
MSI(i) [13:54:54.529] | MSI (c) (B0:9C) [13:54:54:528]: MSI_LUA: Setting MsiRunningElevated property to 1 because the install is already running elevated.
MSI(i) [13:54:54.529] | MSI (c) (B0:9C) [13:54:54:528]: PROPERTY CHANGE: Adding MsiRunningElevated property. Its value is '1'.
MSI(i) [13:54:54.529] | MSI (c) (B0:9C) [13:54:54:528]: PROPERTY CHANGE: Adding Privileged property. Its value is '1'.
MSI(i) [13:54:54.529] | MSI (c) (B0:9C) [13:54:54:528]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\MS Setup (ACME)\User Info 3: 2
MSI(i) [13:54:54.529] | MSI (c) (B0:9C) [13:54:54:528]: PROPERTY CHANGE: Adding USERNAME property. Its value is 'A Valued IT Customer'.
MSI(i) [13:54:54.529] | MSI (c) (B0:9C) [13:54:54:528]: PROPERTY CHANGE: Adding COMPANYNAME property. Its value is 'Intel Corporation'.
MSI(i) [13:54:54.529] | MSI (c) (B0:9C) [13:54:54:528]: PROPERTY CHANGE: Adding DATABASE property. Its value is 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\Setup\setup.msi'.
MSI(i) [13:54:54.529] | MSI (c) (B0:9C) [13:54:54:528]: PROPERTY CHANGE: Adding OriginalDatabase property. Its value is 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\Setup\setup.msi'.
MSI(i) [13:54:54.529] | MSI (c) (B0:9C) [13:54:54:528]: Machine policy value 'MsiDisableEmbeddedUI' is 0
MSI(i) [13:54:54.529] | MSI (c) (B0:9C) [13:54:54:528]: EEUI - Disabling MsiEmbeddedUI in quiet mode
MSI(i) [13:54:54.529] | === Logging started: 4/8/2014  13:54:54 ===
MSI(i) [13:54:54.529] | MSI (c) (B0:9C) [13:54:54:528]: Note: 1: 2205 2:  3: PatchPackage
MSI(i) [13:54:54.529] | MSI (c) (B0:9C) [13:54:54:528]: Machine policy value 'DisableRollback' is 0
MSI(i) [13:54:54.529] | MSI (c) (B0:9C) [13:54:54:528]: User policy value 'DisableRollback' is 0
MSI(i) [13:54:54.529] | MSI (c) (B0:9C) [13:54:54:528]: PROPERTY CHANGE: Adding UILevel property. Its value is '2'.
MSI(i) [13:54:54.529] | MSI (c) (B0:9C) [13:54:54:528]: Creating MSIHANDLE (2) of type 790537 for thread 3996
MSI(i) [13:54:54.529] | MSI (c) (B0:9C) [13:54:54:528]: MsiOpenPackageEx is returning 0
MSI(i) [13:54:54.529] | MSI (c) (B0:9C) [13:54:54:528]: Closing MSIHANDLE (2) of type 790537 for thread 3996
MSI(i) [13:54:54.529] | === Verbose logging stopped: 4/8/2014  13:54:54 ===
PSET(i) [13:54:54.537] | (4225.285): MsiOpenPackageEx(C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\Setup\setup.msi)
MSI(i) [13:54:54.639] | === Verbose logging started: 4/8/2014  13:54:54  Build type: SHIP UNICODE 5.00.7601.00  Calling process: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\setup.exe ===
MSI(i) [13:54:54.639] | MSI (c) (B0:9C) [13:54:54:538]: SOFTWARE RESTRICTION POLICY: Verifying package --> 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\Setup\setup.msi' against software restriction policy
MSI(i) [13:54:54.639] | MSI (c) (B0:9C) [13:54:54:538]: SOFTWARE RESTRICTION POLICY: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\Setup\setup.msi has a digital signature
MSI(i) [13:54:54.639] | MSI (c) (B0:9C) [13:54:54:591]: SOFTWARE RESTRICTION POLICY: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\Setup\setup.msi is permitted to run at the 'unrestricted' authorization level.
MSI(i) [13:54:54.639] | MSI (c) (B0:9C) [13:54:54:592]: Cloaking enabled.
MSI(i) [13:54:54.639] | MSI (c) (B0:9C) [13:54:54:592]: Attempting to enable all disabled privileges before calling Install on Server
MSI(i) [13:54:54.639] | MSI (c) (B0:9C) [13:54:54:592]: End dialog not enabled
MSI(i) [13:54:54.639] | MSI (c) (B0:9C) [13:54:54:593]: Original package ==> C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\Setup\setup.msi
MSI(i) [13:54:54.639] | MSI (c) (B0:9C) [13:54:54:593]: Package we're running from ==> C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\Setup\setup.msi
MSI(i) [13:54:54.639] | MSI (c) (B0:9C) [13:54:54:593]: Machine policy value 'DisableUserInstalls' is 0
MSI(i) [13:54:54.639] | MSI (c) (B0:9C) [13:54:54:594]: APPCOMPAT: Compatibility mode property overrides found.
MSI(i) [13:54:54.639] | MSI (c) (B0:9C) [13:54:54:595]: APPCOMPAT: looking for appcompat database entry with ProductCode '{8E0C0057-1CDD-42B7-A460-AA7202DAC533}'.
MSI(i) [13:54:54.639] | MSI (c) (B0:9C) [13:54:54:595]: APPCOMPAT: no matching ProductCode found in database.
MSI(i) [13:54:54.639] | MSI (c) (B0:9C) [13:54:54:599]: MSCOREE not loaded loading copy from system32
MSI(i) [13:54:54.639] | MSI (c) (B0:9C) [13:54:54:602]: Machine policy value 'TransformsSecure' is 0
MSI(i) [13:54:54.639] | MSI (c) (B0:9C) [13:54:54:602]: User policy value 'TransformsAtSource' is 0
MSI(i) [13:54:54.639] | MSI (c) (B0:9C) [13:54:54:603]: Machine policy value 'DisablePatch' is 0
MSI(i) [13:54:54.639] | MSI (c) (B0:9C) [13:54:54:603]: Machine policy value 'AllowLockdownPatch' is 0
MSI(i) [13:54:54.639] | MSI (c) (B0:9C) [13:54:54:603]: Machine policy value 'DisableLUAPatching' is 0
MSI(i) [13:54:54.639] | MSI (c) (B0:9C) [13:54:54:603]: Machine policy value 'DisableFlyWeightPatching' is 0
MSI(i) [13:54:54.639] | MSI (c) (B0:9C) [13:54:54:603]: Enabling baseline caching for this transaction since all active patches are MSI 3.0 style MSPs or at least one MSI 3.0 minor update patch is active
MSI(i) [13:54:54.639] | MSI (c) (B0:9C) [13:54:54:603]: APPCOMPAT: looking for appcompat database entry with ProductCode '{8E0C0057-1CDD-42B7-A460-AA7202DAC533}'.
MSI(i) [13:54:54.639] | MSI (c) (B0:9C) [13:54:54:603]: APPCOMPAT: no matching ProductCode found in database.
MSI(i) [13:54:54.639] | MSI (c) (B0:9C) [13:54:54:603]: Transforms are not secure.
MSI(i) [13:54:54.639] | MSI (c) (B0:9C) [13:54:54:603]: PROPERTY CHANGE: Adding MsiLogFileLocation property. Its value is 'C:\Users\PCCA-PM\AppData\Local\Temp\MSIED31.tmp'.
MSI(i) [13:54:54.639] | MSI (c) (B0:9C) [13:54:54:603]: No Command Line.
MSI(i) [13:54:54.639] | MSI (c) (B0:9C) [13:54:54:603]: PROPERTY CHANGE: Adding PackageCode property. Its value is '{CCEDFB3C-BE80-461B-A9C0-7FBF82144791}'.
MSI(i) [13:54:54.639] | MSI (c) (B0:9C) [13:54:54:603]: Product Code passed to Engine.Initialize:           '(none)'
MSI(i) [13:54:54.639] | MSI (c) (B0:9C) [13:54:54:603]: Product Code from property table before transforms: '{8E0C0057-1CDD-42B7-A460-AA7202DAC533}'
MSI(i) [13:54:54.639] | MSI (c) (B0:9C) [13:54:54:603]: Product Code from property table after transforms:  '{8E0C0057-1CDD-42B7-A460-AA7202DAC533}'
MSI(i) [13:54:54.639] | MSI (c) (B0:9C) [13:54:54:603]: Product not registered: beginning first-time install
MSI(i) [13:54:54.639] | MSI (c) (B0:9C) [13:54:54:603]: PROPERTY CHANGE: Adding ProductState property. Its value is '-1'.
MSI(i) [13:54:54.639] | MSI (c) (B0:9C) [13:54:54:604]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer 3: 2
MSI(i) [13:54:54.639] | MSI (c) (B0:9C) [13:54:54:604]: Entering CMsiConfigurationManager::SetLastUsedSource.
MSI(i) [13:54:54.639] | MSI (c) (B0:9C) [13:54:54:604]: User policy value 'SearchOrder' is 'nmu'
MSI(i) [13:54:54.639] | MSI (c) (B0:9C) [13:54:54:604]: Adding new sources is allowed.
MSI(i) [13:54:54.639] | MSI (c) (B0:9C) [13:54:54:604]: PROPERTY CHANGE: Adding PackagecodeChanging property. Its value is '1'.
MSI(i) [13:54:54.639] | MSI (c) (B0:9C) [13:54:54:604]: Package name extracted from package path: 'setup.msi'
MSI(i) [13:54:54.639] | MSI (c) (B0:9C) [13:54:54:604]: Package to be registered: 'setup.msi'
MSI(i) [13:54:54.639] | MSI (c) (B0:9C) [13:54:54:604]: Note: 1: 2262 2: AdminProperties 3: -2147287038
MSI(i) [13:54:54.639] | MSI (c) (B0:9C) [13:54:54:604]: Machine policy value 'DisableMsi' is 0
MSI(i) [13:54:54.639] | MSI (c) (B0:9C) [13:54:54:604]: Machine policy value 'AlwaysInstallElevated' is 0
MSI(i) [13:54:54.639] | MSI (c) (B0:9C) [13:54:54:604]: User policy value 'AlwaysInstallElevated' is 0
MSI(i) [13:54:54.639] | MSI (c) (B0:9C) [13:54:54:604]: Product installation will be elevated because user is admin and product is being installed per-machine.
MSI(i) [13:54:54.639] | MSI (c) (B0:9C) [13:54:54:604]: Running product '{8E0C0057-1CDD-42B7-A460-AA7202DAC533}' with elevated privileges: Product is assigned.
MSI(i) [13:54:54.639] | MSI (c) (B0:9C) [13:54:54:605]: PROPERTY CHANGE: Adding MsiSystemRebootPending property. Its value is '1'.
MSI(i) [13:54:54.639] | MSI (c) (B0:9C) [13:54:54:605]: TRANSFORMS property is now:
MSI(i) [13:54:54.639] | MSI (c) (B0:9C) [13:54:54:605]: PROPERTY CHANGE: Adding VersionDatabase property. Its value is '200'.
MSI(i) [13:54:54.639] | MSI (c) (B0:9C) [13:54:54:605]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming
MSI(i) [13:54:54.639] | MSI (c) (B0:9C) [13:54:54:605]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Favorites
MSI(i) [13:54:54.639] | MSI (c) (B0:9C) [13:54:54:605]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Network Shortcuts
MSI(i) [13:54:54.639] | MSI (c) (B0:9C) [13:54:54:605]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Documents
MSI(i) [13:54:54.639] | MSI (c) (B0:9C) [13:54:54:605]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
MSI(i) [13:54:54.639] | MSI (c) (B0:9C) [13:54:54:605]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Recent
MSI(i) [13:54:54.639] | MSI (c) (B0:9C) [13:54:54:605]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\SendTo
MSI(i) [13:54:54.639] | MSI (c) (B0:9C) [13:54:54:605]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Templates
MSI(i) [13:54:54.639] | MSI (c) (B0:9C) [13:54:54:605]: SHELL32::SHGetFolderPath returned: C:\ProgramData
MSI(i) [13:54:54.639] | MSI (c) (B0:9C) [13:54:54:605]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Local
MSI(i) [13:54:54.639] | MSI (c) (B0:9C) [13:54:54:605]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Pictures
MSI(i) [13:54:54.639] | MSI (c) (B0:9C) [13:54:54:605]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI(i) [13:54:54.639] | MSI (c) (B0:9C) [13:54:54:605]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
MSI(i) [13:54:54.639] | MSI (c) (B0:9C) [13:54:54:605]: SHELL32::SHGetFolderPath returned: C:\Users\Public\Desktop
MSI(i) [13:54:54.639] | MSI (c) (B0:9C) [13:54:54:605]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI(i) [13:54:54.639] | MSI (c) (B0:9C) [13:54:54:605]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
MSI(i) [13:54:54.639] | MSI (c) (B0:9C) [13:54:54:605]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Desktop
MSI(i) [13:54:54.639] | MSI (c) (B0:9C) [13:54:54:605]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Templates
MSI(i) [13:54:54.639] | MSI (c) (B0:9C) [13:54:54:605]: SHELL32::SHGetFolderPath returned: C:\Windows\Fonts
MSI(i) [13:54:54.639] | MSI (c) (B0:9C) [13:54:54:605]: Note: 1: 2898 2: MS Sans Serif 3: MS Sans Serif 4: 0 5: 16
MSI(i) [13:54:54.639] | MSI (c) (B0:9C) [13:54:54:611]: MSI_LUA: Setting AdminUser property to 1 because this is the client or the user has already permitted elevation
MSI(i) [13:54:54.639] | MSI (c) (B0:9C) [13:54:54:611]: MSI_LUA: Setting MsiRunningElevated property to 1 because the install is already running elevated.
MSI(i) [13:54:54.639] | MSI (c) (B0:9C) [13:54:54:611]: PROPERTY CHANGE: Adding MsiRunningElevated property. Its value is '1'.
MSI(i) [13:54:54.639] | MSI (c) (B0:9C) [13:54:54:611]: PROPERTY CHANGE: Adding Privileged property. Its value is '1'.
MSI(i) [13:54:54.639] | MSI (c) (B0:9C) [13:54:54:611]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\MS Setup (ACME)\User Info 3: 2
MSI(i) [13:54:54.639] | MSI (c) (B0:9C) [13:54:54:611]: PROPERTY CHANGE: Adding USERNAME property. Its value is 'A Valued IT Customer'.
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:611]: PROPERTY CHANGE: Adding COMPANYNAME property. Its value is 'Intel Corporation'.
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:611]: PROPERTY CHANGE: Adding DATABASE property. Its value is 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\Setup\setup.msi'.
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:611]: PROPERTY CHANGE: Adding OriginalDatabase property. Its value is 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\Setup\setup.msi'.
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:611]: Machine policy value 'MsiDisableEmbeddedUI' is 0
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:611]: EEUI - Disabling MsiEmbeddedUI in quiet mode
MSI(i) [13:54:54.640] | === Logging started: 4/8/2014  13:54:54 ===
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:611]: Note: 1: 2205 2:  3: PatchPackage
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:611]: Machine policy value 'DisableRollback' is 0
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:611]: User policy value 'DisableRollback' is 0
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:611]: PROPERTY CHANGE: Adding UILevel property. Its value is '2'.
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:611]: Creating MSIHANDLE (3) of type 790537 for thread 3996
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:611]: MsiOpenPackageEx is returning 0
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:611]: Creating MSIHANDLE (4) of type 790541 for thread 3996
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:611]: Closing MSIHANDLE (4) of type 790541 for thread 3996
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:612]: Doing action: AppSearch
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:612]: Note: 1: 2205 2:  3: ActionText
MSI(i) [13:54:54.640] | Action 13:54:54: AppSearch. Searching for installed applications
MSI(i) [13:54:54.640] | Action start 13:54:54: AppSearch.
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:613]: Note: 1: 2205 2:  3: AppSearch
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:613]: Note: 1: 2228 2:  3: AppSearch 4: SELECT `Property`, `Signature_` FROM `AppSearch`
MSI(i) [13:54:54.640] | Action ended 13:54:54: AppSearch. Return value 0.
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:613]: Doing action: CostInitialize
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:613]: Note: 1: 2205 2:  3: ActionText
MSI(i) [13:54:54.640] | Action 13:54:54: CostInitialize. Computing space requirements
MSI(i) [13:54:54.640] | Action start 13:54:54: CostInitialize.
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:614]: Machine policy value 'MaxPatchCacheSize' is 10
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:614]: Baseline: Sorting baselines for {8E0C0057-1CDD-42B7-A460-AA7202DAC533}.
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:614]: Baseline: New baseline 13.1.0 from transaction.
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:614]: Baseline: Sorted order Native: Order 0.
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:614]: Baseline Data Table:
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:614]: ProductCode: {8E0C0057-1CDD-42B7-A460-AA7202DAC533} Version: 13.1.0 Attributes: 0 PatchId: Native BaselineId: -2147483648 Order: 0
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:614]: Baseline File Table:
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:615]: PROPERTY CHANGE: Adding ROOTDRIVE property. Its value is 'C:\'.
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:615]: PROPERTY CHANGE: Adding CostingComplete property. Its value is '0'.
MSI(i) [13:54:54.640] | Action ended 13:54:54: CostInitialize. Return value 1.
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:615]: Doing action: FileCost
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:615]: Note: 1: 2205 2:  3: ActionText
MSI(i) [13:54:54.640] | Action 13:54:54: FileCost. Computing space requirements
MSI(i) [13:54:54.640] | Action start 13:54:54: FileCost.
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:616]: Note: 1: 2205 2:  3: MsiAssembly
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:616]: Note: 1: 2205 2:  3: Class
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:616]: Note: 1: 2205 2:  3: Extension
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:616]: Note: 1: 2205 2:  3: TypeLib
MSI(i) [13:54:54.640] | Action ended 13:54:54: FileCost. Return value 1.
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:616]: Doing action: CostFinalize
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:616]: Note: 1: 2205 2:  3: ActionText
MSI(i) [13:54:54.640] | Action 13:54:54: CostFinalize. Computing space requirements
MSI(i) [13:54:54.640] | Action start 13:54:54: CostFinalize.
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:617]: PROPERTY CHANGE: Adding OutOfDiskSpace property. Its value is '0'.
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:617]: PROPERTY CHANGE: Adding OutOfNoRbDiskSpace property. Its value is '0'.
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:617]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceAvailable property. Its value is '0'.
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:617]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRequired property. Its value is '0'.
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:617]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRemaining property. Its value is '0'.
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:617]: Note: 1: 2205 2:  3: Patch
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:617]: Note: 1: 2205 2:  3: Condition
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:618]: PROPERTY CHANGE: Adding TARGETDIR property. Its value is 'C:\'.
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:618]: PROPERTY CHANGE: Adding INTEL property. Its value is 'C:\Program Files (x86)\Intel\'.
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:618]: PROPERTY CHANGE: Adding INSTALLFILESFOLDER property. Its value is 'C:\Program Files (x86)\Intel\Installer\'.
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:618]: PROPERTY CHANGE: Adding SETUPINSTDIR property. Its value is 'C:\Program Files (x86)\Intel\Installer\Intel VTune Amplifier XE 2013 build 243421\'.
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:618]: PROPERTY CHANGE: Adding setup property. Its value is 'C:\Program Files (x86)\Intel\Installer\Intel VTune Amplifier XE 2013 build 243421\setup\'.
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:618]: PROPERTY CHANGE: Adding Plugin property. Its value is 'C:\Program Files (x86)\Intel\Installer\Intel VTune Amplifier XE 2013 build 243421\setup\Plugin\'.
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:618]: PROPERTY CHANGE: Adding licenses property. Its value is 'C:\Program Files (x86)\Intel\Installer\Intel VTune Amplifier XE 2013 build 243421\setup\licenses\'.
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:618]: PROPERTY CHANGE: Adding openssl property. Its value is 'C:\Program Files (x86)\Intel\Installer\Intel VTune Amplifier XE 2013 build 243421\setup\licenses\openssl\'.
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:618]: PROPERTY CHANGE: Adding expat property. Its value is 'C:\Program Files (x86)\Intel\Installer\Intel VTune Amplifier XE 2013 build 243421\setup\licenses\expat\'.
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:618]: PROPERTY CHANGE: Adding BigInteger property. Its value is 'C:\Program Files (x86)\Intel\Installer\Intel VTune Amplifier XE 2013 build 243421\setup\licenses\BigInteger\'.
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:618]: PROPERTY CHANGE: Adding axis property. Its value is 'C:\Program Files (x86)\Intel\Installer\Intel VTune Amplifier XE 2013 build 243421\setup\licenses\axis\'.
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:618]: PROPERTY CHANGE: Adding ares property. Its value is 'C:\Program Files (x86)\Intel\Installer\Intel VTune Amplifier XE 2013 build 243421\setup\licenses\ares\'.
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:618]: PROPERTY CHANGE: Adding Installs property. Its value is 'C:\Program Files (x86)\Intel\Installer\Intel VTune Amplifier XE 2013 build 243421\setup\Installs\'.
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:618]: PROPERTY CHANGE: Adding ism property. Its value is 'C:\Program Files (x86)\Intel\Installer\Intel VTune Amplifier XE 2013 build 243421\setup\Installs\ism\'.
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:618]: PROPERTY CHANGE: Adding fli property. Its value is 'C:\Program Files (x86)\Intel\Installer\Intel VTune Amplifier XE 2013 build 243421\setup\fli\'.
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:618]: PROPERTY CHANGE: Adding _1033 property. Its value is 'C:\Program Files (x86)\Intel\Installer\Intel VTune Amplifier XE 2013 build 243421\setup\1033\'.
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:618]: PROPERTY CHANGE: Adding SplashScreen property. Its value is 'C:\Program Files (x86)\Intel\Installer\Intel VTune Amplifier XE 2013 build 243421\setup\1033\SplashScreen\'.
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:618]: PROPERTY CHANGE: Adding BillBoard property. Its value is 'C:\Program Files (x86)\Intel\Installer\Intel VTune Amplifier XE 2013 build 243421\setup\1033\BillBoard\'.
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:618]: PROPERTY CHANGE: Adding Finish property. Its value is 'C:\Program Files (x86)\Intel\Installer\Intel VTune Amplifier XE 2013 build 243421\setup\1033\BillBoard\Finish\'.
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:618]: Target path resolution complete. Dumping Directory table...
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:618]: Note: target paths subject to change (via custom actions or browsing)
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:618]: Dir (target): Key: TARGETDIR    , Object: C:\
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:618]: Dir (target): Key: WindowsFolder    , Object: C:\Windows\
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:618]: Dir (target): Key: ProgramFilesFolder    , Object: C:\Program Files (x86)\
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:618]: Dir (target): Key: INTEL    , Object: C:\Program Files (x86)\Intel\
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:618]: Dir (target): Key: INSTALLFILESFOLDER    , Object: C:\Program Files (x86)\Intel\Installer\
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:618]: Dir (target): Key: SETUPINSTDIR    , Object: C:\Program Files (x86)\Intel\Installer\Intel VTune Amplifier XE 2013 build 243421\
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:618]: Dir (target): Key: setup    , Object: C:\Program Files (x86)\Intel\Installer\Intel VTune Amplifier XE 2013 build 243421\setup\
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:618]: Dir (target): Key: Plugin    , Object: C:\Program Files (x86)\Intel\Installer\Intel VTune Amplifier XE 2013 build 243421\setup\Plugin\
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:618]: Dir (target): Key: licenses    , Object: C:\Program Files (x86)\Intel\Installer\Intel VTune Amplifier XE 2013 build 243421\setup\licenses\
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:618]: Dir (target): Key: openssl    , Object: C:\Program Files (x86)\Intel\Installer\Intel VTune Amplifier XE 2013 build 243421\setup\licenses\openssl\
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:618]: Dir (target): Key: expat    , Object: C:\Program Files (x86)\Intel\Installer\Intel VTune Amplifier XE 2013 build 243421\setup\licenses\expat\
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:618]: Dir (target): Key: BigInteger    , Object: C:\Program Files (x86)\Intel\Installer\Intel VTune Amplifier XE 2013 build 243421\setup\licenses\BigInteger\
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:618]: Dir (target): Key: axis    , Object: C:\Program Files (x86)\Intel\Installer\Intel VTune Amplifier XE 2013 build 243421\setup\licenses\axis\
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:618]: Dir (target): Key: ares    , Object: C:\Program Files (x86)\Intel\Installer\Intel VTune Amplifier XE 2013 build 243421\setup\licenses\ares\
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:618]: Dir (target): Key: Installs    , Object: C:\Program Files (x86)\Intel\Installer\Intel VTune Amplifier XE 2013 build 243421\setup\Installs\
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:618]: Dir (target): Key: ism    , Object: C:\Program Files (x86)\Intel\Installer\Intel VTune Amplifier XE 2013 build 243421\setup\Installs\ism\
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:618]: Dir (target): Key: fli    , Object: C:\Program Files (x86)\Intel\Installer\Intel VTune Amplifier XE 2013 build 243421\setup\fli\
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:618]: Dir (target): Key: _1033    , Object: C:\Program Files (x86)\Intel\Installer\Intel VTune Amplifier XE 2013 build 243421\setup\1033\
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:618]: Dir (target): Key: SplashScreen    , Object: C:\Program Files (x86)\Intel\Installer\Intel VTune Amplifier XE 2013 build 243421\setup\1033\SplashScreen\
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:618]: Dir (target): Key: BillBoard    , Object: C:\Program Files (x86)\Intel\Installer\Intel VTune Amplifier XE 2013 build 243421\setup\1033\BillBoard\
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:618]: Dir (target): Key: Finish    , Object: C:\Program Files (x86)\Intel\Installer\Intel VTune Amplifier XE 2013 build 243421\setup\1033\BillBoard\Finish\
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:618]: PROPERTY CHANGE: Adding INSTALLLEVEL property. Its value is '1'.
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:618]: Note: 1: 2205 2:  3: MsiAssembly
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:618]: Note: 1: 2228 2:  3: MsiAssembly 4:  SELECT `MsiAssembly`.`Attributes`, `MsiAssembly`.`File_Application`, `MsiAssembly`.`File_Manifest`,  `Component`.`KeyPath` FROM `MsiAssembly`, `Component` WHERE  `MsiAssembly`.`Component_` = `Component`.`Component` AND `MsiAssembly`.`Component_` = ?
MSI(i) [13:54:54.640] | Action ended 13:54:54: CostFinalize. Return value 1.
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:619]: Doing action: InstallValidate
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:619]: Note: 1: 2205 2:  3: ActionText
MSI(i) [13:54:54.640] | Action 13:54:54: InstallValidate. Validating install
MSI(i) [13:54:54.640] | Action start 13:54:54: InstallValidate.
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:621]: Note: 1: 2205 2:  3: Dialog
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:621]: Feature: CoreAppFiles; Installed: Absent;   Request: Local;   Action: Local
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:621]: Component: ProductFamilyAnchor; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:621]: Component: ProductVersionAnchor; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:621]: Component: SetupMsiMarker; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:621]: Component: _shared_client_guid; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:621]: Component: arp_entry; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:621]: Component: Comp_autorun.inf; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:621]: Component: Comp_EULA.rtf; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:621]: Component: Comp_FNP_Act_Installer.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:621]: Component: Comp_libeay32.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:621]: Component: Comp_libexpat.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:621]: Component: Comp_libssl32.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:621]: Component: Comp_MinAxis.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:621]: Component: Comp_Setup.exe; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:621]: Component: Comp_Setup_FNP.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:621]: Component: Comp_ssleay32.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:621]: Component: Comp_ss_asr.xml; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:621]: Component: Comp_EULA.rtf0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:621]: Component: Comp_mediaconfig.xml; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:621]: Component: Comp_release_notes_amplifier_xe_windows.pdf; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:621]: Component: Comp_Resources.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:621]: Component: Comp_Welcome.rtf; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:621]: Component: Comp__00_AmXE_intro.png; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:621]: Component: Comp__01_AmXE_hotspot.png; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:621]: Component: Comp__02_AmXE_concurrency.png; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:621]: Component: Comp__03_AmXE_source_view.png; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:621]: Component: Comp__04_AmXE_easy_setup.png; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:621]: Component: Comp__05_AmXE_Timeline.png; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:621]: Component: Comp__06_AmXE_Mark_Timeline_During_Collection.png; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:621]: Component: Comp__07_filter_noise.png; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:621]: Component: Comp__08_remote_collection.png; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:621]: Component: Comp_Thumbs.db; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:621]: Component: Comp__99_install_complete_472x179.png; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:621]: Component: Comp_splash_amplifier_xe.png; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:621]: Component: Comp_chklics.exe; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:621]: Component: Comp_chklics_libfnp.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:621]: Component: Comp_FNP_Act_Installer.dll0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:621]: Component: Comp_arpicon.ico; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:621]: Component: Comp_searc.dat; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:621]: Component: Comp_SetupRemove.exe; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:621]: Component: Comp_ism.msi; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:621]: Component: Comp_license; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:621]: Component: Comp_README; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:621]: Component: Comp_LICENSE0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:621]: Component: Comp_LICENSE1; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:621]: Component: Comp_Readme0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:621]: Component: Comp_COPYING; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:621]: Component: Comp_README1; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:621]: Component: Comp_license.txt; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:621]: Component: Comp_readme.txt; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:621]: Component: Comp_Distributed_Install_detector.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:621]: Component: Comp_Distributed_Install_detector_res_1033.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:621]: Component: Comp_pset_plugin.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:621]: Component: __arp_entry65; Installed: Null;   Request: Local;   Action: Local;   Client State: Null
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:621]: Note: 1: 2205 2:  3: BindImage
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:621]: Note: 1: 2205 2:  3: ProgId
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:621]: Note: 1: 2205 2:  3: PublishComponent
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:621]: Note: 1: 2205 2:  3: SelfReg
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:621]: Note: 1: 2205 2:  3: Extension
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:621]: Note: 1: 2205 2:  3: Font
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:621]: Note: 1: 2205 2:  3: Shortcut
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:621]: Note: 1: 2205 2:  3: Class
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:621]: Note: 1: 2205 2:  3: Icon
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:621]: Note: 1: 2205 2:  3: TypeLib
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:621]: Note: 1: 2205 2:  3: _RemoveFilePath
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:624]: PROPERTY CHANGE: Modifying CostingComplete property. Its current value is '0'. Its new value: '1'.
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:624]: Note: 1: 2205 2:  3: BindImage
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:624]: Note: 1: 2205 2:  3: ProgId
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:624]: Note: 1: 2205 2:  3: PublishComponent
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:624]: Note: 1: 2205 2:  3: SelfReg
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:624]: Note: 1: 2205 2:  3: Extension
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:624]: Note: 1: 2205 2:  3: Font
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:624]: Note: 1: 2205 2:  3: Shortcut
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:624]: Note: 1: 2205 2:  3: Class
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:624]: Note: 1: 2205 2:  3: Icon
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:624]: Note: 1: 2205 2:  3: TypeLib
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:624]: Note: 1: 2727 2:
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:638]: Note: 1: 2727 2:
MSI(i) [13:54:54.640] | Action ended 13:54:54: InstallValidate. Return value 1.
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:638]: Creating MSIHANDLE (5) of type 790541 for thread 3996
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:639]: Creating MSIHANDLE (6) of type 790540 for thread 3996
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:639]: Creating MSIHANDLE (7) of type 790531 for thread 3996
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:639]: Note: 1: 2205 2:  3: Condition
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:639]: Note: 1: 2228 2:  3: Condition 4: SELECT * FROM Condition WHERE Feature_ = 'CoreAppFiles'
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:639]: Creating MSIHANDLE (8) of type 790540 for thread 3996
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:639]: Closing MSIHANDLE (8) of type 790540 for thread 3996
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:639]: Closing MSIHANDLE (7) of type 790531 for thread 3996
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:639]: Closing MSIHANDLE (6) of type 790540 for thread 3996
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:639]: Closing MSIHANDLE (5) of type 790541 for thread 3996
MSI(i) [13:54:54.640] | MSI (c) (B0:9C) [13:54:54:639]: Leaked MSIHANDLE (3) of type 790537 for thread 3996
MSI(i) [13:54:54.640] | === Verbose logging stopped: 4/8/2014  13:54:54 ===
PSET(i) [13:54:54.649] | (4225.1904): Dependency {ACD97E2A-090D-46ea-9983-6E44BCA28575} always show dialog
PSET(i) [13:54:54.649] | (4225.2963): MsiOpenPackageEx(C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\indicator\indicator.msi)
MSI(i) [13:54:54.683] | === Verbose logging started: 4/8/2014  13:54:54  Build type: SHIP UNICODE 5.00.7601.00  Calling process: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\setup.exe ===
MSI(i) [13:54:54.683] | MSI (c) (B0:9C) [13:54:54:650]: SOFTWARE RESTRICTION POLICY: Verifying package --> 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\indicator\indicator.msi' against software restriction policy
MSI(i) [13:54:54.683] | MSI (c) (B0:9C) [13:54:54:651]: SOFTWARE RESTRICTION POLICY: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\indicator\indicator.msi has a digital signature
MSI(i) [13:54:54.683] | MSI (c) (B0:9C) [13:54:54:663]: SOFTWARE RESTRICTION POLICY: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\indicator\indicator.msi is permitted to run at the 'unrestricted' authorization level.
MSI(i) [13:54:54.683] | MSI (c) (B0:9C) [13:54:54:664]: Cloaking enabled.
MSI(i) [13:54:54.683] | MSI (c) (B0:9C) [13:54:54:664]: Attempting to enable all disabled privileges before calling Install on Server
MSI(i) [13:54:54.683] | MSI (c) (B0:9C) [13:54:54:664]: End dialog not enabled
MSI(i) [13:54:54.683] | MSI (c) (B0:9C) [13:54:54:664]: Original package ==> C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\indicator\indicator.msi
MSI(i) [13:54:54.683] | MSI (c) (B0:9C) [13:54:54:665]: Package we're running from ==> C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\indicator\indicator.msi
MSI(i) [13:54:54.683] | MSI (c) (B0:9C) [13:54:54:666]: APPCOMPAT: Compatibility mode property overrides found.
MSI(i) [13:54:54.683] | MSI (c) (B0:9C) [13:54:54:666]: APPCOMPAT: looking for appcompat database entry with ProductCode '{0C13F8EE-A432-495D-8F77-EDB3F3778D2D}'.
MSI(i) [13:54:54.683] | MSI (c) (B0:9C) [13:54:54:666]: APPCOMPAT: no matching ProductCode found in database.
MSI(i) [13:54:54.683] | MSI (c) (B0:9C) [13:54:54:670]: MSCOREE not loaded loading copy from system32
MSI(i) [13:54:54.683] | MSI (c) (B0:9C) [13:54:54:674]: Machine policy value 'TransformsSecure' is 0
MSI(i) [13:54:54.683] | MSI (c) (B0:9C) [13:54:54:674]: User policy value 'TransformsAtSource' is 0
MSI(i) [13:54:54.683] | MSI (c) (B0:9C) [13:54:54:674]: Note: 1: 2262 2: File 3: -2147287038
MSI(i) [13:54:54.683] | MSI (c) (B0:9C) [13:54:54:674]: Note: 1: 2205 2:  3: MsiFileHash
MSI(i) [13:54:54.683] | MSI (c) (B0:9C) [13:54:54:674]: Machine policy value 'DisablePatch' is 0
MSI(i) [13:54:54.683] | MSI (c) (B0:9C) [13:54:54:674]: Machine policy value 'AllowLockdownPatch' is 0
MSI(i) [13:54:54.683] | MSI (c) (B0:9C) [13:54:54:674]: Machine policy value 'DisableLUAPatching' is 0
MSI(i) [13:54:54.683] | MSI (c) (B0:9C) [13:54:54:674]: Machine policy value 'DisableFlyWeightPatching' is 0
MSI(i) [13:54:54.683] | MSI (c) (B0:9C) [13:54:54:674]: Enabling baseline caching for this transaction since all active patches are MSI 3.0 style MSPs or at least one MSI 3.0 minor update patch is active
MSI(i) [13:54:54.683] | MSI (c) (B0:9C) [13:54:54:674]: APPCOMPAT: looking for appcompat database entry with ProductCode '{0C13F8EE-A432-495D-8F77-EDB3F3778D2D}'.
MSI(i) [13:54:54.683] | MSI (c) (B0:9C) [13:54:54:674]: APPCOMPAT: no matching ProductCode found in database.
MSI(i) [13:54:54.683] | MSI (c) (B0:9C) [13:54:54:674]: Transforms are not secure.
MSI(i) [13:54:54.683] | MSI (c) (B0:9C) [13:54:54:675]: PROPERTY CHANGE: Adding MsiLogFileLocation property. Its value is 'C:\Users\PCCA-PM\AppData\Local\Temp\MSIED31.tmp'.
MSI(i) [13:54:54.683] | MSI (c) (B0:9C) [13:54:54:675]: No Command Line.
MSI(i) [13:54:54.683] | MSI (c) (B0:9C) [13:54:54:675]: PROPERTY CHANGE: Adding PackageCode property. Its value is '{F7333571-5276-4BF4-A6E2-695FDAC1CD7F}'.
MSI(i) [13:54:54.683] | MSI (c) (B0:9C) [13:54:54:675]: Product Code passed to Engine.Initialize:           '(none)'
MSI(i) [13:54:54.683] | MSI (c) (B0:9C) [13:54:54:675]: Product Code from property table before transforms: '{0C13F8EE-A432-495D-8F77-EDB3F3778D2D}'
MSI(i) [13:54:54.683] | MSI (c) (B0:9C) [13:54:54:675]: Product Code from property table after transforms:  '{0C13F8EE-A432-495D-8F77-EDB3F3778D2D}'
MSI(i) [13:54:54.683] | MSI (c) (B0:9C) [13:54:54:675]: Product not registered: beginning first-time install
MSI(i) [13:54:54.683] | MSI (c) (B0:9C) [13:54:54:675]: PROPERTY CHANGE: Adding ProductState property. Its value is '-1'.
MSI(i) [13:54:54.683] | MSI (c) (B0:9C) [13:54:54:675]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer 3: 2
MSI(i) [13:54:54.683] | MSI (c) (B0:9C) [13:54:54:675]: Entering CMsiConfigurationManager::SetLastUsedSource.
MSI(i) [13:54:54.683] | MSI (c) (B0:9C) [13:54:54:675]: User policy value 'SearchOrder' is 'nmu'
MSI(i) [13:54:54.683] | MSI (c) (B0:9C) [13:54:54:675]: Adding new sources is allowed.
MSI(i) [13:54:54.683] | MSI (c) (B0:9C) [13:54:54:675]: PROPERTY CHANGE: Adding PackagecodeChanging property. Its value is '1'.
MSI(i) [13:54:54.683] | MSI (c) (B0:9C) [13:54:54:675]: Package name extracted from package path: 'indicator.msi'
MSI(i) [13:54:54.683] | MSI (c) (B0:9C) [13:54:54:675]: Package to be registered: 'indicator.msi'
MSI(i) [13:54:54.683] | MSI (c) (B0:9C) [13:54:54:675]: Note: 1: 2205 2:  3: Error
MSI(i) [13:54:54.683] | MSI (c) (B0:9C) [13:54:54:676]: Note: 1: 2262 2: AdminProperties 3: -2147287038
MSI(i) [13:54:54.683] | MSI (c) (B0:9C) [13:54:54:676]: Machine policy value 'DisableMsi' is 0
MSI(i) [13:54:54.683] | MSI (c) (B0:9C) [13:54:54:676]: Machine policy value 'AlwaysInstallElevated' is 0
MSI(i) [13:54:54.683] | MSI (c) (B0:9C) [13:54:54:676]: User policy value 'AlwaysInstallElevated' is 0
MSI(i) [13:54:54.683] | MSI (c) (B0:9C) [13:54:54:676]: Product installation will be elevated because user is admin and product is being installed per-machine.
MSI(i) [13:54:54.683] | MSI (c) (B0:9C) [13:54:54:676]: Running product '{0C13F8EE-A432-495D-8F77-EDB3F3778D2D}' with elevated privileges: Product is assigned.
MSI(i) [13:54:54.683] | MSI (c) (B0:9C) [13:54:54:676]: PROPERTY CHANGE: Adding MsiSystemRebootPending property. Its value is '1'.
MSI(i) [13:54:54.683] | MSI (c) (B0:9C) [13:54:54:676]: TRANSFORMS property is now:
MSI(i) [13:54:54.683] | MSI (c) (B0:9C) [13:54:54:676]: PROPERTY CHANGE: Adding VersionDatabase property. Its value is '200'.
MSI(i) [13:54:54.683] | MSI (c) (B0:9C) [13:54:54:676]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming
MSI(i) [13:54:54.683] | MSI (c) (B0:9C) [13:54:54:676]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Favorites
MSI(i) [13:54:54.683] | MSI (c) (B0:9C) [13:54:54:676]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Network Shortcuts
MSI(i) [13:54:54.683] | MSI (c) (B0:9C) [13:54:54:676]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Documents
MSI(i) [13:54:54.683] | MSI (c) (B0:9C) [13:54:54:676]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
MSI(i) [13:54:54.683] | MSI (c) (B0:9C) [13:54:54:676]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Recent
MSI(i) [13:54:54.683] | MSI (c) (B0:9C) [13:54:54:676]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\SendTo
MSI(i) [13:54:54.683] | MSI (c) (B0:9C) [13:54:54:676]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Templates
MSI(i) [13:54:54.683] | MSI (c) (B0:9C) [13:54:54:676]: SHELL32::SHGetFolderPath returned: C:\ProgramData
MSI(i) [13:54:54.683] | MSI (c) (B0:9C) [13:54:54:676]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Local
MSI(i) [13:54:54.683] | MSI (c) (B0:9C) [13:54:54:676]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Pictures
MSI(i) [13:54:54.683] | MSI (c) (B0:9C) [13:54:54:676]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI(i) [13:54:54.683] | MSI (c) (B0:9C) [13:54:54:676]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
MSI(i) [13:54:54.683] | MSI (c) (B0:9C) [13:54:54:676]: SHELL32::SHGetFolderPath returned: C:\Users\Public\Desktop
MSI(i) [13:54:54.683] | MSI (c) (B0:9C) [13:54:54:676]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI(i) [13:54:54.683] | MSI (c) (B0:9C) [13:54:54:676]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
MSI(i) [13:54:54.683] | MSI (c) (B0:9C) [13:54:54:676]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Desktop
MSI(i) [13:54:54.683] | MSI (c) (B0:9C) [13:54:54:676]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Templates
MSI(i) [13:54:54.683] | MSI (c) (B0:9C) [13:54:54:677]: SHELL32::SHGetFolderPath returned: C:\Windows\Fonts
MSI(i) [13:54:54.683] | MSI (c) (B0:9C) [13:54:54:677]: Note: 1: 2898 2: MS Sans Serif 3: MS Sans Serif 4: 0 5: 16
MSI(i) [13:54:54.683] | MSI (c) (B0:9C) [13:54:54:682]: MSI_LUA: Setting AdminUser property to 1 because this is the client or the user has already permitted elevation
MSI(i) [13:54:54.683] | MSI (c) (B0:9C) [13:54:54:682]: MSI_LUA: Setting MsiRunningElevated property to 1 because the install is already running elevated.
MSI(i) [13:54:54.683] | MSI (c) (B0:9C) [13:54:54:682]: PROPERTY CHANGE: Adding MsiRunningElevated property. Its value is '1'.
MSI(i) [13:54:54.683] | MSI (c) (B0:9C) [13:54:54:682]: PROPERTY CHANGE: Adding Privileged property. Its value is '1'.
MSI(i) [13:54:54.683] | MSI (c) (B0:9C) [13:54:54:682]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\MS Setup (ACME)\User Info 3: 2
MSI(i) [13:54:54.683] | MSI (c) (B0:9C) [13:54:54:682]: PROPERTY CHANGE: Adding USERNAME property. Its value is 'A Valued IT Customer'.
MSI(i) [13:54:54.683] | MSI (c) (B0:9C) [13:54:54:682]: PROPERTY CHANGE: Adding COMPANYNAME property. Its value is 'Intel Corporation'.
MSI(i) [13:54:54.683] | MSI (c) (B0:9C) [13:54:54:682]: PROPERTY CHANGE: Adding DATABASE property. Its value is 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\indicator\indicator.msi'.
MSI(i) [13:54:54.683] | MSI (c) (B0:9C) [13:54:54:682]: PROPERTY CHANGE: Adding OriginalDatabase property. Its value is 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\indicator\indicator.msi'.
MSI(i) [13:54:54.683] | MSI (c) (B0:9C) [13:54:54:682]: Machine policy value 'MsiDisableEmbeddedUI' is 0
MSI(i) [13:54:54.683] | MSI (c) (B0:9C) [13:54:54:682]: EEUI - Disabling MsiEmbeddedUI in quiet mode
MSI(i) [13:54:54.683] | === Logging started: 4/8/2014  13:54:54 ===
MSI(i) [13:54:54.683] | MSI (c) (B0:9C) [13:54:54:683]: Note: 1: 2205 2:  3: PatchPackage
MSI(i) [13:54:54.683] | MSI (c) (B0:9C) [13:54:54:683]: Machine policy value 'DisableRollback' is 0
MSI(i) [13:54:54.683] | MSI (c) (B0:9C) [13:54:54:683]: User policy value 'DisableRollback' is 0
MSI(i) [13:54:54.683] | MSI (c) (B0:9C) [13:54:54:683]: PROPERTY CHANGE: Adding UILevel property. Its value is '2'.
MSI(i) [13:54:54.683] | MSI (c) (B0:9C) [13:54:54:683]: Creating MSIHANDLE (9) of type 790537 for thread 3996
MSI(i) [13:54:54.683] | MSI (c) (B0:9C) [13:54:54:683]: MsiOpenPackageEx is returning 0
MSI(i) [13:54:54.683] | MSI (c) (B0:9C) [13:54:54:683]: Closing MSIHANDLE (9) of type 790537 for thread 3996
MSI(i) [13:54:54.683] | === Verbose logging stopped: 4/8/2014  13:54:54 ===
PSET(i) [13:54:54.691] | (4225.285): MsiOpenPackageEx(C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\indicator\indicator.msi)
MSI(i) [13:54:54.747] | === Verbose logging started: 4/8/2014  13:54:54  Build type: SHIP UNICODE 5.00.7601.00  Calling process: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\setup.exe ===
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:692]: SOFTWARE RESTRICTION POLICY: Verifying package --> 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\indicator\indicator.msi' against software restriction policy
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:692]: SOFTWARE RESTRICTION POLICY: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\indicator\indicator.msi has a digital signature
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:704]: SOFTWARE RESTRICTION POLICY: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\indicator\indicator.msi is permitted to run at the 'unrestricted' authorization level.
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:705]: Cloaking enabled.
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:705]: Attempting to enable all disabled privileges before calling Install on Server
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:705]: End dialog not enabled
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:706]: Original package ==> C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\indicator\indicator.msi
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:706]: Package we're running from ==> C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\indicator\indicator.msi
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:706]: Machine policy value 'DisableUserInstalls' is 0
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:707]: APPCOMPAT: Compatibility mode property overrides found.
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:707]: APPCOMPAT: looking for appcompat database entry with ProductCode '{0C13F8EE-A432-495D-8F77-EDB3F3778D2D}'.
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:707]: APPCOMPAT: no matching ProductCode found in database.
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:711]: MSCOREE not loaded loading copy from system32
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:715]: Machine policy value 'TransformsSecure' is 0
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:715]: User policy value 'TransformsAtSource' is 0
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:715]: Note: 1: 2262 2: File 3: -2147287038
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:715]: Note: 1: 2205 2:  3: MsiFileHash
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:715]: Machine policy value 'DisablePatch' is 0
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:715]: Machine policy value 'AllowLockdownPatch' is 0
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:715]: Machine policy value 'DisableLUAPatching' is 0
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:715]: Machine policy value 'DisableFlyWeightPatching' is 0
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:715]: Enabling baseline caching for this transaction since all active patches are MSI 3.0 style MSPs or at least one MSI 3.0 minor update patch is active
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:716]: APPCOMPAT: looking for appcompat database entry with ProductCode '{0C13F8EE-A432-495D-8F77-EDB3F3778D2D}'.
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:716]: APPCOMPAT: no matching ProductCode found in database.
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:716]: Transforms are not secure.
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:716]: PROPERTY CHANGE: Adding MsiLogFileLocation property. Its value is 'C:\Users\PCCA-PM\AppData\Local\Temp\MSIED31.tmp'.
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:716]: No Command Line.
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:716]: PROPERTY CHANGE: Adding PackageCode property. Its value is '{F7333571-5276-4BF4-A6E2-695FDAC1CD7F}'.
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:716]: Product Code passed to Engine.Initialize:           '(none)'
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:716]: Product Code from property table before transforms: '{0C13F8EE-A432-495D-8F77-EDB3F3778D2D}'
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:716]: Product Code from property table after transforms:  '{0C13F8EE-A432-495D-8F77-EDB3F3778D2D}'
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:716]: Product not registered: beginning first-time install
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:716]: PROPERTY CHANGE: Adding ProductState property. Its value is '-1'.
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:716]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer 3: 2
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:716]: Entering CMsiConfigurationManager::SetLastUsedSource.
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:716]: User policy value 'SearchOrder' is 'nmu'
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:716]: Adding new sources is allowed.
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:716]: PROPERTY CHANGE: Adding PackagecodeChanging property. Its value is '1'.
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:716]: Package name extracted from package path: 'indicator.msi'
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:716]: Package to be registered: 'indicator.msi'
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:716]: Note: 1: 2205 2:  3: Error
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:717]: Note: 1: 2262 2: AdminProperties 3: -2147287038
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:717]: Machine policy value 'DisableMsi' is 0
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:717]: Machine policy value 'AlwaysInstallElevated' is 0
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:717]: User policy value 'AlwaysInstallElevated' is 0
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:717]: Product installation will be elevated because user is admin and product is being installed per-machine.
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:717]: Running product '{0C13F8EE-A432-495D-8F77-EDB3F3778D2D}' with elevated privileges: Product is assigned.
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:717]: PROPERTY CHANGE: Adding MsiSystemRebootPending property. Its value is '1'.
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:717]: TRANSFORMS property is now:
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:717]: PROPERTY CHANGE: Adding VersionDatabase property. Its value is '200'.
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:717]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:717]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Favorites
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:717]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Network Shortcuts
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:717]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Documents
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:717]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:717]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Recent
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:717]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\SendTo
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:717]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Templates
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:717]: SHELL32::SHGetFolderPath returned: C:\ProgramData
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:717]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Local
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:717]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Pictures
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:717]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:717]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:717]: SHELL32::SHGetFolderPath returned: C:\Users\Public\Desktop
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:717]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:717]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:717]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Desktop
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:718]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Templates
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:718]: SHELL32::SHGetFolderPath returned: C:\Windows\Fonts
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:718]: Note: 1: 2898 2: MS Sans Serif 3: MS Sans Serif 4: 0 5: 16
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:723]: MSI_LUA: Setting AdminUser property to 1 because this is the client or the user has already permitted elevation
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:723]: MSI_LUA: Setting MsiRunningElevated property to 1 because the install is already running elevated.
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:723]: PROPERTY CHANGE: Adding MsiRunningElevated property. Its value is '1'.
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:723]: PROPERTY CHANGE: Adding Privileged property. Its value is '1'.
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:723]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\MS Setup (ACME)\User Info 3: 2
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:723]: PROPERTY CHANGE: Adding USERNAME property. Its value is 'A Valued IT Customer'.
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:723]: PROPERTY CHANGE: Adding COMPANYNAME property. Its value is 'Intel Corporation'.
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:723]: PROPERTY CHANGE: Adding DATABASE property. Its value is 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\indicator\indicator.msi'.
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:723]: PROPERTY CHANGE: Adding OriginalDatabase property. Its value is 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\indicator\indicator.msi'.
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:723]: Machine policy value 'MsiDisableEmbeddedUI' is 0
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:723]: EEUI - Disabling MsiEmbeddedUI in quiet mode
MSI(i) [13:54:54.747] | === Logging started: 4/8/2014  13:54:54 ===
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:724]: Note: 1: 2205 2:  3: PatchPackage
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:724]: Machine policy value 'DisableRollback' is 0
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:724]: User policy value 'DisableRollback' is 0
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:724]: PROPERTY CHANGE: Adding UILevel property. Its value is '2'.
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:724]: Creating MSIHANDLE (10) of type 790537 for thread 3996
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:724]: MsiOpenPackageEx is returning 0
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:724]: Creating MSIHANDLE (11) of type 790541 for thread 3996
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:724]: Closing MSIHANDLE (11) of type 790541 for thread 3996
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:724]: Doing action: AppSearch
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:724]: Note: 1: 2205 2:  3: ActionText
MSI(i) [13:54:54.747] | Action 13:54:54: AppSearch. Searching for installed applications
MSI(i) [13:54:54.747] | Action start 13:54:54: AppSearch.
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:725]: Note: 1: 2205 2:  3: AppSearch
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:725]: Note: 1: 2228 2:  3: AppSearch 4: SELECT `Property`, `Signature_` FROM `AppSearch`
MSI(i) [13:54:54.747] | Action ended 13:54:54: AppSearch. Return value 0.
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:725]: Doing action: CostInitialize
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:725]: Note: 1: 2205 2:  3: ActionText
MSI(i) [13:54:54.747] | Action 13:54:54: CostInitialize. Computing space requirements
MSI(i) [13:54:54.747] | Action start 13:54:54: CostInitialize.
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:726]: Machine policy value 'MaxPatchCacheSize' is 10
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:726]: Baseline: Sorting baselines for {0C13F8EE-A432-495D-8F77-EDB3F3778D2D}.
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:726]: Baseline: New baseline 13.1.0 from transaction.
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:726]: Baseline: Sorted order Native: Order 0.
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:726]: Baseline Data Table:
MSI(i) [13:54:54.747] | MSI (c) (B0:9C) [13:54:54:726]: ProductCode: {0C13F8EE-A432-495D-8F77-EDB3F3778D2D} Version: 13.1.0 Attributes: 0 PatchId: Native BaselineId: -2147483648 Order: 0
MSI(i) [13:54:54.748] | MSI (c) (B0:9C) [13:54:54:726]: Baseline File Table:
MSI(i) [13:54:54.748] | MSI (c) (B0:9C) [13:54:54:727]: PROPERTY CHANGE: Adding ROOTDRIVE property. Its value is 'C:\'.
MSI(i) [13:54:54.748] | MSI (c) (B0:9C) [13:54:54:727]: PROPERTY CHANGE: Adding CostingComplete property. Its value is '0'.
MSI(i) [13:54:54.748] | Action ended 13:54:54: CostInitialize. Return value 1.
MSI(i) [13:54:54.748] | MSI (c) (B0:9C) [13:54:54:727]: Doing action: FileCost
MSI(i) [13:54:54.748] | MSI (c) (B0:9C) [13:54:54:727]: Note: 1: 2205 2:  3: ActionText
MSI(i) [13:54:54.748] | Action 13:54:54: FileCost. Computing space requirements
MSI(i) [13:54:54.748] | Action start 13:54:54: FileCost.
MSI(i) [13:54:54.748] | MSI (c) (B0:9C) [13:54:54:728]: Note: 1: 2205 2:  3: MsiAssembly
MSI(i) [13:54:54.748] | MSI (c) (B0:9C) [13:54:54:728]: Note: 1: 2205 2:  3: Registry
MSI(i) [13:54:54.748] | MSI (c) (B0:9C) [13:54:54:728]: Note: 1: 2205 2:  3: Class
MSI(i) [13:54:54.748] | MSI (c) (B0:9C) [13:54:54:728]: Note: 1: 2205 2:  3: Extension
MSI(i) [13:54:54.748] | MSI (c) (B0:9C) [13:54:54:728]: Note: 1: 2205 2:  3: TypeLib
MSI(i) [13:54:54.748] | Action ended 13:54:54: FileCost. Return value 1.
MSI(i) [13:54:54.748] | MSI (c) (B0:9C) [13:54:54:729]: Doing action: CostFinalize
MSI(i) [13:54:54.748] | MSI (c) (B0:9C) [13:54:54:729]: Note: 1: 2205 2:  3: ActionText
MSI(i) [13:54:54.748] | Action 13:54:54: CostFinalize. Computing space requirements
MSI(i) [13:54:54.748] | Action start 13:54:54: CostFinalize.
MSI(i) [13:54:54.748] | MSI (c) (B0:9C) [13:54:54:730]: PROPERTY CHANGE: Adding OutOfDiskSpace property. Its value is '0'.
MSI(i) [13:54:54.748] | MSI (c) (B0:9C) [13:54:54:730]: PROPERTY CHANGE: Adding OutOfNoRbDiskSpace property. Its value is '0'.
MSI(i) [13:54:54.748] | MSI (c) (B0:9C) [13:54:54:730]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceAvailable property. Its value is '0'.
MSI(i) [13:54:54.748] | MSI (c) (B0:9C) [13:54:54:730]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRequired property. Its value is '0'.
MSI(i) [13:54:54.748] | MSI (c) (B0:9C) [13:54:54:730]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRemaining property. Its value is '0'.
MSI(i) [13:54:54.748] | MSI (c) (B0:9C) [13:54:54:730]: Note: 1: 2205 2:  3: Patch
MSI(i) [13:54:54.748] | MSI (c) (B0:9C) [13:54:54:730]: Note: 1: 2205 2:  3: Condition
MSI(i) [13:54:54.748] | MSI (c) (B0:9C) [13:54:54:730]: PROPERTY CHANGE: Adding TARGETDIR property. Its value is 'C:\'.
MSI(i) [13:54:54.748] | MSI (c) (B0:9C) [13:54:54:730]: PROPERTY CHANGE: Adding INTEL property. Its value is 'C:\Program Files (x86)\Intel\'.
MSI(i) [13:54:54.748] | MSI (c) (B0:9C) [13:54:54:730]: PROPERTY CHANGE: Adding BASEINSTALLDIR property. Its value is 'C:\Program Files (x86)\Intel\'.
MSI(i) [13:54:54.748] | MSI (c) (B0:9C) [13:54:54:730]: PROPERTY CHANGE: Adding INSTALLDIR property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\'.
MSI(i) [13:54:54.748] | MSI (c) (B0:9C) [13:54:54:730]: Target path resolution complete. Dumping Directory table...
MSI(i) [13:54:54.748] | MSI (c) (B0:9C) [13:54:54:730]: Note: target paths subject to change (via custom actions or browsing)
MSI(i) [13:54:54.748] | MSI (c) (B0:9C) [13:54:54:730]: Dir (target): Key: TARGETDIR    , Object: C:\
MSI(i) [13:54:54.748] | MSI (c) (B0:9C) [13:54:54:730]: Dir (target): Key: ProgramFilesFolder    , Object: C:\Program Files (x86)\
MSI(i) [13:54:54.748] | MSI (c) (B0:9C) [13:54:54:730]: Dir (target): Key: INTEL    , Object: C:\Program Files (x86)\Intel\
MSI(i) [13:54:54.748] | MSI (c) (B0:9C) [13:54:54:730]: Dir (target): Key: BASEINSTALLDIR    , Object: C:\Program Files (x86)\Intel\
MSI(i) [13:54:54.748] | MSI (c) (B0:9C) [13:54:54:730]: Dir (target): Key: INSTALLDIR    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\
MSI(i) [13:54:54.748] | MSI (c) (B0:9C) [13:54:54:730]: PROPERTY CHANGE: Adding INSTALLLEVEL property. Its value is '1'.
MSI(i) [13:54:54.748] | Action ended 13:54:54: CostFinalize. Return value 1.
MSI(i) [13:54:54.748] | MSI (c) (B0:9C) [13:54:54:730]: Doing action: InstallValidate
MSI(i) [13:54:54.748] | MSI (c) (B0:9C) [13:54:54:730]: Note: 1: 2205 2:  3: ActionText
MSI(i) [13:54:54.748] | Action 13:54:54: InstallValidate. Validating install
MSI(i) [13:54:54.748] | Action start 13:54:54: InstallValidate.
MSI(i) [13:54:54.748] | MSI (c) (B0:9C) [13:54:54:731]: Note: 1: 2205 2:  3: Dialog
MSI(i) [13:54:54.748] | MSI (c) (B0:9C) [13:54:54:731]: Feature: CoreAppFiles; Installed: Absent;   Request: Local;   Action: Local
MSI(i) [13:54:54.748] | MSI (c) (B0:9C) [13:54:54:731]: Component: CommonInstallRoot; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:54.748] | MSI (c) (B0:9C) [13:54:54:731]: Component: ProductFamilyAnchor; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:54.748] | MSI (c) (B0:9C) [13:54:54:731]: Component: ProductVersionAnchor; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:54.748] | MSI (c) (B0:9C) [13:54:54:731]: Component: CompMsiMarker; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:54.748] | MSI (c) (B0:9C) [13:54:54:731]: Note: 1: 2205 2:  3: Registry
MSI(i) [13:54:54.748] | MSI (c) (B0:9C) [13:54:54:731]: Note: 1: 2205 2:  3: BindImage
MSI(i) [13:54:54.748] | MSI (c) (B0:9C) [13:54:54:731]: Note: 1: 2205 2:  3: ProgId
MSI(i) [13:54:54.748] | MSI (c) (B0:9C) [13:54:54:731]: Note: 1: 2205 2:  3: PublishComponent
MSI(i) [13:54:54.748] | MSI (c) (B0:9C) [13:54:54:731]: Note: 1: 2205 2:  3: SelfReg
MSI(i) [13:54:54.748] | MSI (c) (B0:9C) [13:54:54:731]: Note: 1: 2205 2:  3: Extension
MSI(i) [13:54:54.748] | MSI (c) (B0:9C) [13:54:54:731]: Note: 1: 2205 2:  3: Font
MSI(i) [13:54:54.748] | MSI (c) (B0:9C) [13:54:54:731]: Note: 1: 2205 2:  3: Shortcut
MSI(i) [13:54:54.748] | MSI (c) (B0:9C) [13:54:54:731]: Note: 1: 2205 2:  3: Class
MSI(i) [13:54:54.748] | MSI (c) (B0:9C) [13:54:54:731]: Note: 1: 2205 2:  3: Icon
MSI(i) [13:54:54.748] | MSI (c) (B0:9C) [13:54:54:731]: Note: 1: 2205 2:  3: TypeLib
MSI(i) [13:54:54.748] | MSI (c) (B0:9C) [13:54:54:731]: Note: 1: 2205 2:  3: MsiAssembly
MSI(i) [13:54:54.748] | MSI (c) (B0:9C) [13:54:54:731]: Note: 1: 2228 2:  3: MsiAssembly 4:  SELECT `MsiAssembly`.`Attributes`, `MsiAssembly`.`File_Application`, `MsiAssembly`.`File_Manifest`,  `Component`.`KeyPath` FROM `MsiAssembly`, `Component` WHERE  `MsiAssembly`.`Component_` = `Component`.`Component` AND `MsiAssembly`.`Component_` = ?
MSI(i) [13:54:54.748] | MSI (c) (B0:9C) [13:54:54:731]: PROPERTY CHANGE: Modifying CostingComplete property. Its current value is '0'. Its new value: '1'.
MSI(i) [13:54:54.748] | MSI (c) (B0:9C) [13:54:54:732]: Note: 1: 2205 2:  3: Registry
MSI(i) [13:54:54.748] | MSI (c) (B0:9C) [13:54:54:732]: Note: 1: 2205 2:  3: BindImage
MSI(i) [13:54:54.748] | MSI (c) (B0:9C) [13:54:54:732]: Note: 1: 2205 2:  3: ProgId
MSI(i) [13:54:54.748] | MSI (c) (B0:9C) [13:54:54:732]: Note: 1: 2205 2:  3: PublishComponent
MSI(i) [13:54:54.748] | MSI (c) (B0:9C) [13:54:54:732]: Note: 1: 2205 2:  3: SelfReg
MSI(i) [13:54:54.748] | MSI (c) (B0:9C) [13:54:54:732]: Note: 1: 2205 2:  3: Extension
MSI(i) [13:54:54.748] | MSI (c) (B0:9C) [13:54:54:732]: Note: 1: 2205 2:  3: Font
MSI(i) [13:54:54.748] | MSI (c) (B0:9C) [13:54:54:732]: Note: 1: 2205 2:  3: Shortcut
MSI(i) [13:54:54.748] | MSI (c) (B0:9C) [13:54:54:732]: Note: 1: 2205 2:  3: Class
MSI(i) [13:54:54.748] | MSI (c) (B0:9C) [13:54:54:732]: Note: 1: 2205 2:  3: Icon
MSI(i) [13:54:54.748] | MSI (c) (B0:9C) [13:54:54:732]: Note: 1: 2205 2:  3: TypeLib
MSI(i) [13:54:54.748] | MSI (c) (B0:9C) [13:54:54:732]: Note: 1: 2727 2:
MSI(i) [13:54:54.748] | MSI (c) (B0:9C) [13:54:54:746]: Note: 1: 2727 2:
MSI(i) [13:54:54.748] | Action ended 13:54:54: InstallValidate. Return value 1.
MSI(i) [13:54:54.748] | MSI (c) (B0:9C) [13:54:54:746]: Creating MSIHANDLE (12) of type 790541 for thread 3996
MSI(i) [13:54:54.748] | MSI (c) (B0:9C) [13:54:54:747]: Creating MSIHANDLE (13) of type 790540 for thread 3996
MSI(i) [13:54:54.748] | MSI (c) (B0:9C) [13:54:54:747]: Creating MSIHANDLE (14) of type 790531 for thread 3996
MSI(i) [13:54:54.748] | MSI (c) (B0:9C) [13:54:54:747]: Note: 1: 2205 2:  3: Condition
MSI(i) [13:54:54.748] | MSI (c) (B0:9C) [13:54:54:747]: Note: 1: 2228 2:  3: Condition 4: SELECT * FROM Condition WHERE Feature_ = 'CoreAppFiles'
MSI(i) [13:54:54.748] | MSI (c) (B0:9C) [13:54:54:747]: Creating MSIHANDLE (15) of type 790540 for thread 3996
MSI(i) [13:54:54.748] | MSI (c) (B0:9C) [13:54:54:747]: Closing MSIHANDLE (15) of type 790540 for thread 3996
MSI(i) [13:54:54.748] | MSI (c) (B0:9C) [13:54:54:747]: Closing MSIHANDLE (14) of type 790531 for thread 3996
MSI(i) [13:54:54.748] | MSI (c) (B0:9C) [13:54:54:747]: Closing MSIHANDLE (13) of type 790540 for thread 3996
MSI(i) [13:54:54.748] | MSI (c) (B0:9C) [13:54:54:747]: Closing MSIHANDLE (12) of type 790541 for thread 3996
MSI(i) [13:54:54.748] | MSI (c) (B0:9C) [13:54:54:747]: Leaked MSIHANDLE (10) of type 790537 for thread 3996
MSI(i) [13:54:54.748] | === Verbose logging stopped: 4/8/2014  13:54:54 ===
PSET(i) [13:54:54.756] | (4225.2963): MsiOpenPackageEx(C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\ps_he_cli\ps_he_cli.msi)
MSI(i) [13:54:54.801] | === Verbose logging started: 4/8/2014  13:54:54  Build type: SHIP UNICODE 5.00.7601.00  Calling process: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\setup.exe ===
MSI(i) [13:54:54.801] | MSI (c) (B0:9C) [13:54:54:758]: SOFTWARE RESTRICTION POLICY: Verifying package --> 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\ps_he_cli\ps_he_cli.msi' against software restriction policy
MSI(i) [13:54:54.801] | MSI (c) (B0:9C) [13:54:54:758]: SOFTWARE RESTRICTION POLICY: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\ps_he_cli\ps_he_cli.msi has a digital signature
MSI(i) [13:54:54.801] | MSI (c) (B0:9C) [13:54:54:778]: SOFTWARE RESTRICTION POLICY: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\ps_he_cli\ps_he_cli.msi is permitted to run at the 'unrestricted' authorization level.
MSI(i) [13:54:54.801] | MSI (c) (B0:9C) [13:54:54:779]: Cloaking enabled.
MSI(i) [13:54:54.801] | MSI (c) (B0:9C) [13:54:54:779]: Attempting to enable all disabled privileges before calling Install on Server
MSI(i) [13:54:54.801] | MSI (c) (B0:9C) [13:54:54:779]: End dialog not enabled
MSI(i) [13:54:54.801] | MSI (c) (B0:9C) [13:54:54:779]: Original package ==> C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\ps_he_cli\ps_he_cli.msi
MSI(i) [13:54:54.801] | MSI (c) (B0:9C) [13:54:54:779]: Package we're running from ==> C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\ps_he_cli\ps_he_cli.msi
MSI(i) [13:54:54.801] | MSI (c) (B0:9C) [13:54:54:783]: APPCOMPAT: Compatibility mode property overrides found.
MSI(i) [13:54:54.801] | MSI (c) (B0:9C) [13:54:54:783]: APPCOMPAT: looking for appcompat database entry with ProductCode '{589E1BCD-8E36-492B-AB10-DB2A90789DD8}'.
MSI(i) [13:54:54.801] | MSI (c) (B0:9C) [13:54:54:783]: APPCOMPAT: no matching ProductCode found in database.
MSI(i) [13:54:54.801] | MSI (c) (B0:9C) [13:54:54:787]: MSCOREE not loaded loading copy from system32
MSI(i) [13:54:54.801] | MSI (c) (B0:9C) [13:54:54:791]: Machine policy value 'TransformsSecure' is 0
MSI(i) [13:54:54.801] | MSI (c) (B0:9C) [13:54:54:791]: User policy value 'TransformsAtSource' is 0
MSI(i) [13:54:54.801] | MSI (c) (B0:9C) [13:54:54:792]: Machine policy value 'DisablePatch' is 0
MSI(i) [13:54:54.801] | MSI (c) (B0:9C) [13:54:54:792]: Machine policy value 'AllowLockdownPatch' is 0
MSI(i) [13:54:54.801] | MSI (c) (B0:9C) [13:54:54:792]: Machine policy value 'DisableLUAPatching' is 0
MSI(i) [13:54:54.801] | MSI (c) (B0:9C) [13:54:54:792]: Machine policy value 'DisableFlyWeightPatching' is 0
MSI(i) [13:54:54.801] | MSI (c) (B0:9C) [13:54:54:792]: Enabling baseline caching for this transaction since all active patches are MSI 3.0 style MSPs or at least one MSI 3.0 minor update patch is active
MSI(i) [13:54:54.801] | MSI (c) (B0:9C) [13:54:54:792]: APPCOMPAT: looking for appcompat database entry with ProductCode '{589E1BCD-8E36-492B-AB10-DB2A90789DD8}'.
MSI(i) [13:54:54.801] | MSI (c) (B0:9C) [13:54:54:792]: APPCOMPAT: no matching ProductCode found in database.
MSI(i) [13:54:54.801] | MSI (c) (B0:9C) [13:54:54:792]: Transforms are not secure.
MSI(i) [13:54:54.801] | MSI (c) (B0:9C) [13:54:54:792]: PROPERTY CHANGE: Adding MsiLogFileLocation property. Its value is 'C:\Users\PCCA-PM\AppData\Local\Temp\MSIED31.tmp'.
MSI(i) [13:54:54.801] | MSI (c) (B0:9C) [13:54:54:792]: No Command Line.
MSI(i) [13:54:54.801] | MSI (c) (B0:9C) [13:54:54:792]: PROPERTY CHANGE: Adding PackageCode property. Its value is '{879E1F82-E198-4F69-A187-49FC54A0E3A0}'.
MSI(i) [13:54:54.801] | MSI (c) (B0:9C) [13:54:54:792]: Product Code passed to Engine.Initialize:           '(none)'
MSI(i) [13:54:54.801] | MSI (c) (B0:9C) [13:54:54:792]: Product Code from property table before transforms: '{589E1BCD-8E36-492B-AB10-DB2A90789DD8}'
MSI(i) [13:54:54.801] | MSI (c) (B0:9C) [13:54:54:792]: Product Code from property table after transforms:  '{589E1BCD-8E36-492B-AB10-DB2A90789DD8}'
MSI(i) [13:54:54.801] | MSI (c) (B0:9C) [13:54:54:792]: Product not registered: beginning first-time install
MSI(i) [13:54:54.801] | MSI (c) (B0:9C) [13:54:54:792]: PROPERTY CHANGE: Adding ProductState property. Its value is '-1'.
MSI(i) [13:54:54.801] | MSI (c) (B0:9C) [13:54:54:793]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer 3: 2
MSI(i) [13:54:54.801] | MSI (c) (B0:9C) [13:54:54:793]: Entering CMsiConfigurationManager::SetLastUsedSource.
MSI(i) [13:54:54.801] | MSI (c) (B0:9C) [13:54:54:793]: User policy value 'SearchOrder' is 'nmu'
MSI(i) [13:54:54.801] | MSI (c) (B0:9C) [13:54:54:793]: Adding new sources is allowed.
MSI(i) [13:54:54.801] | MSI (c) (B0:9C) [13:54:54:793]: PROPERTY CHANGE: Adding PackagecodeChanging property. Its value is '1'.
MSI(i) [13:54:54.801] | MSI (c) (B0:9C) [13:54:54:793]: Package name extracted from package path: 'ps_he_cli.msi'
MSI(i) [13:54:54.801] | MSI (c) (B0:9C) [13:54:54:793]: Package to be registered: 'ps_he_cli.msi'
MSI(i) [13:54:54.801] | MSI (c) (B0:9C) [13:54:54:793]: Note: 1: 2262 2: AdminProperties 3: -2147287038
MSI(i) [13:54:54.801] | MSI (c) (B0:9C) [13:54:54:793]: Machine policy value 'DisableMsi' is 0
MSI(i) [13:54:54.801] | MSI (c) (B0:9C) [13:54:54:793]: Machine policy value 'AlwaysInstallElevated' is 0
MSI(i) [13:54:54.801] | MSI (c) (B0:9C) [13:54:54:793]: User policy value 'AlwaysInstallElevated' is 0
MSI(i) [13:54:54.801] | MSI (c) (B0:9C) [13:54:54:793]: Product installation will be elevated because user is admin and product is being installed per-machine.
MSI(i) [13:54:54.801] | MSI (c) (B0:9C) [13:54:54:793]: Running product '{589E1BCD-8E36-492B-AB10-DB2A90789DD8}' with elevated privileges: Product is assigned.
MSI(i) [13:54:54.801] | MSI (c) (B0:9C) [13:54:54:794]: PROPERTY CHANGE: Adding MsiSystemRebootPending property. Its value is '1'.
MSI(i) [13:54:54.801] | MSI (c) (B0:9C) [13:54:54:794]: TRANSFORMS property is now:
MSI(i) [13:54:54.801] | MSI (c) (B0:9C) [13:54:54:794]: PROPERTY CHANGE: Adding VersionDatabase property. Its value is '200'.
MSI(i) [13:54:54.801] | MSI (c) (B0:9C) [13:54:54:794]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming
MSI(i) [13:54:54.801] | MSI (c) (B0:9C) [13:54:54:794]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Favorites
MSI(i) [13:54:54.801] | MSI (c) (B0:9C) [13:54:54:794]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Network Shortcuts
MSI(i) [13:54:54.801] | MSI (c) (B0:9C) [13:54:54:794]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Documents
MSI(i) [13:54:54.801] | MSI (c) (B0:9C) [13:54:54:794]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
MSI(i) [13:54:54.801] | MSI (c) (B0:9C) [13:54:54:794]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Recent
MSI(i) [13:54:54.801] | MSI (c) (B0:9C) [13:54:54:794]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\SendTo
MSI(i) [13:54:54.801] | MSI (c) (B0:9C) [13:54:54:794]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Templates
MSI(i) [13:54:54.801] | MSI (c) (B0:9C) [13:54:54:794]: SHELL32::SHGetFolderPath returned: C:\ProgramData
MSI(i) [13:54:54.801] | MSI (c) (B0:9C) [13:54:54:794]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Local
MSI(i) [13:54:54.801] | MSI (c) (B0:9C) [13:54:54:794]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Pictures
MSI(i) [13:54:54.801] | MSI (c) (B0:9C) [13:54:54:794]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI(i) [13:54:54.801] | MSI (c) (B0:9C) [13:54:54:794]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
MSI(i) [13:54:54.801] | MSI (c) (B0:9C) [13:54:54:794]: SHELL32::SHGetFolderPath returned: C:\Users\Public\Desktop
MSI(i) [13:54:54.801] | MSI (c) (B0:9C) [13:54:54:794]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI(i) [13:54:54.801] | MSI (c) (B0:9C) [13:54:54:794]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
MSI(i) [13:54:54.801] | MSI (c) (B0:9C) [13:54:54:794]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Desktop
MSI(i) [13:54:54.801] | MSI (c) (B0:9C) [13:54:54:794]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Templates
MSI(i) [13:54:54.801] | MSI (c) (B0:9C) [13:54:54:794]: SHELL32::SHGetFolderPath returned: C:\Windows\Fonts
MSI(i) [13:54:54.801] | MSI (c) (B0:9C) [13:54:54:795]: Note: 1: 2898 2: MS Sans Serif 3: MS Sans Serif 4: 0 5: 16
MSI(i) [13:54:54.801] | MSI (c) (B0:9C) [13:54:54:800]: MSI_LUA: Setting AdminUser property to 1 because this is the client or the user has already permitted elevation
MSI(i) [13:54:54.801] | MSI (c) (B0:9C) [13:54:54:800]: MSI_LUA: Setting MsiRunningElevated property to 1 because the install is already running elevated.
MSI(i) [13:54:54.801] | MSI (c) (B0:9C) [13:54:54:800]: PROPERTY CHANGE: Adding MsiRunningElevated property. Its value is '1'.
MSI(i) [13:54:54.801] | MSI (c) (B0:9C) [13:54:54:800]: PROPERTY CHANGE: Adding Privileged property. Its value is '1'.
MSI(i) [13:54:54.801] | MSI (c) (B0:9C) [13:54:54:800]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\MS Setup (ACME)\User Info 3: 2
MSI(i) [13:54:54.801] | MSI (c) (B0:9C) [13:54:54:800]: PROPERTY CHANGE: Adding USERNAME property. Its value is 'A Valued IT Customer'.
MSI(i) [13:54:54.801] | MSI (c) (B0:9C) [13:54:54:800]: PROPERTY CHANGE: Adding COMPANYNAME property. Its value is 'Intel Corporation'.
MSI(i) [13:54:54.801] | MSI (c) (B0:9C) [13:54:54:800]: PROPERTY CHANGE: Adding DATABASE property. Its value is 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\ps_he_cli\ps_he_cli.msi'.
MSI(i) [13:54:54.801] | MSI (c) (B0:9C) [13:54:54:800]: PROPERTY CHANGE: Adding OriginalDatabase property. Its value is 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\ps_he_cli\ps_he_cli.msi'.
MSI(i) [13:54:54.801] | MSI (c) (B0:9C) [13:54:54:800]: Machine policy value 'MsiDisableEmbeddedUI' is 0
MSI(i) [13:54:54.801] | MSI (c) (B0:9C) [13:54:54:800]: EEUI - Disabling MsiEmbeddedUI in quiet mode
MSI(i) [13:54:54.801] | === Logging started: 4/8/2014  13:54:54 ===
MSI(i) [13:54:54.801] | MSI (c) (B0:9C) [13:54:54:800]: Note: 1: 2205 2:  3: PatchPackage
MSI(i) [13:54:54.801] | MSI (c) (B0:9C) [13:54:54:800]: Machine policy value 'DisableRollback' is 0
MSI(i) [13:54:54.801] | MSI (c) (B0:9C) [13:54:54:800]: User policy value 'DisableRollback' is 0
MSI(i) [13:54:54.801] | MSI (c) (B0:9C) [13:54:54:800]: PROPERTY CHANGE: Adding UILevel property. Its value is '2'.
MSI(i) [13:54:54.801] | MSI (c) (B0:9C) [13:54:54:801]: Creating MSIHANDLE (16) of type 790537 for thread 3996
MSI(i) [13:54:54.801] | MSI (c) (B0:9C) [13:54:54:801]: MsiOpenPackageEx is returning 0
MSI(i) [13:54:54.801] | MSI (c) (B0:9C) [13:54:54:801]: Closing MSIHANDLE (16) of type 790537 for thread 3996
MSI(i) [13:54:54.801] | === Verbose logging stopped: 4/8/2014  13:54:54 ===
PSET(i) [13:54:54.810] | (4225.285): MsiOpenPackageEx(C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\ps_he_cli\ps_he_cli.msi)
MSI(i) [13:54:55.001] | === Verbose logging started: 4/8/2014  13:54:54  Build type: SHIP UNICODE 5.00.7601.00  Calling process: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\setup.exe ===
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:811]: SOFTWARE RESTRICTION POLICY: Verifying package --> 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\ps_he_cli\ps_he_cli.msi' against software restriction policy
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:811]: SOFTWARE RESTRICTION POLICY: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\ps_he_cli\ps_he_cli.msi has a digital signature
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:832]: SOFTWARE RESTRICTION POLICY: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\ps_he_cli\ps_he_cli.msi is permitted to run at the 'unrestricted' authorization level.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:832]: Cloaking enabled.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:832]: Attempting to enable all disabled privileges before calling Install on Server
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:832]: End dialog not enabled
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:833]: Original package ==> C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\ps_he_cli\ps_he_cli.msi
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:833]: Package we're running from ==> C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\ps_he_cli\ps_he_cli.msi
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:835]: Machine policy value 'DisableUserInstalls' is 0
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:836]: APPCOMPAT: Compatibility mode property overrides found.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:837]: APPCOMPAT: looking for appcompat database entry with ProductCode '{589E1BCD-8E36-492B-AB10-DB2A90789DD8}'.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:837]: APPCOMPAT: no matching ProductCode found in database.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:841]: MSCOREE not loaded loading copy from system32
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:844]: Machine policy value 'TransformsSecure' is 0
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:845]: User policy value 'TransformsAtSource' is 0
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:845]: Machine policy value 'DisablePatch' is 0
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:845]: Machine policy value 'AllowLockdownPatch' is 0
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:845]: Machine policy value 'DisableLUAPatching' is 0
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:845]: Machine policy value 'DisableFlyWeightPatching' is 0
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:845]: Enabling baseline caching for this transaction since all active patches are MSI 3.0 style MSPs or at least one MSI 3.0 minor update patch is active
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:846]: APPCOMPAT: looking for appcompat database entry with ProductCode '{589E1BCD-8E36-492B-AB10-DB2A90789DD8}'.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:846]: APPCOMPAT: no matching ProductCode found in database.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:846]: Transforms are not secure.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:846]: PROPERTY CHANGE: Adding MsiLogFileLocation property. Its value is 'C:\Users\PCCA-PM\AppData\Local\Temp\MSIED31.tmp'.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:846]: No Command Line.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:846]: PROPERTY CHANGE: Adding PackageCode property. Its value is '{879E1F82-E198-4F69-A187-49FC54A0E3A0}'.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:846]: Product Code passed to Engine.Initialize:           '(none)'
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:846]: Product Code from property table before transforms: '{589E1BCD-8E36-492B-AB10-DB2A90789DD8}'
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:846]: Product Code from property table after transforms:  '{589E1BCD-8E36-492B-AB10-DB2A90789DD8}'
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:846]: Product not registered: beginning first-time install
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:846]: PROPERTY CHANGE: Adding ProductState property. Its value is '-1'.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:846]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer 3: 2
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:846]: Entering CMsiConfigurationManager::SetLastUsedSource.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:846]: User policy value 'SearchOrder' is 'nmu'
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:846]: Adding new sources is allowed.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:846]: PROPERTY CHANGE: Adding PackagecodeChanging property. Its value is '1'.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:846]: Package name extracted from package path: 'ps_he_cli.msi'
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:846]: Package to be registered: 'ps_he_cli.msi'
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:847]: Note: 1: 2262 2: AdminProperties 3: -2147287038
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:847]: Machine policy value 'DisableMsi' is 0
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:847]: Machine policy value 'AlwaysInstallElevated' is 0
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:847]: User policy value 'AlwaysInstallElevated' is 0
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:847]: Product installation will be elevated because user is admin and product is being installed per-machine.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:847]: Running product '{589E1BCD-8E36-492B-AB10-DB2A90789DD8}' with elevated privileges: Product is assigned.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:847]: PROPERTY CHANGE: Adding MsiSystemRebootPending property. Its value is '1'.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:847]: TRANSFORMS property is now:
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:847]: PROPERTY CHANGE: Adding VersionDatabase property. Its value is '200'.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:847]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:847]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Favorites
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:847]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Network Shortcuts
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:847]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Documents
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:847]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:847]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Recent
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:847]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\SendTo
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:847]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Templates
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:847]: SHELL32::SHGetFolderPath returned: C:\ProgramData
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:847]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Local
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:847]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Pictures
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:847]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:847]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:847]: SHELL32::SHGetFolderPath returned: C:\Users\Public\Desktop
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:847]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:847]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:847]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Desktop
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:848]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Templates
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:848]: SHELL32::SHGetFolderPath returned: C:\Windows\Fonts
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:848]: Note: 1: 2898 2: MS Sans Serif 3: MS Sans Serif 4: 0 5: 16
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:853]: MSI_LUA: Setting AdminUser property to 1 because this is the client or the user has already permitted elevation
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:853]: MSI_LUA: Setting MsiRunningElevated property to 1 because the install is already running elevated.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:853]: PROPERTY CHANGE: Adding MsiRunningElevated property. Its value is '1'.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:853]: PROPERTY CHANGE: Adding Privileged property. Its value is '1'.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:853]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\MS Setup (ACME)\User Info 3: 2
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:853]: PROPERTY CHANGE: Adding USERNAME property. Its value is 'A Valued IT Customer'.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:853]: PROPERTY CHANGE: Adding COMPANYNAME property. Its value is 'Intel Corporation'.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:854]: PROPERTY CHANGE: Adding DATABASE property. Its value is 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\ps_he_cli\ps_he_cli.msi'.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:854]: PROPERTY CHANGE: Adding OriginalDatabase property. Its value is 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\ps_he_cli\ps_he_cli.msi'.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:854]: Machine policy value 'MsiDisableEmbeddedUI' is 0
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:854]: EEUI - Disabling MsiEmbeddedUI in quiet mode
MSI(i) [13:54:55.001] | === Logging started: 4/8/2014  13:54:54 ===
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:854]: Note: 1: 2205 2:  3: PatchPackage
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:854]: Machine policy value 'DisableRollback' is 0
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:854]: User policy value 'DisableRollback' is 0
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:854]: PROPERTY CHANGE: Adding UILevel property. Its value is '2'.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:854]: Creating MSIHANDLE (17) of type 790537 for thread 3996
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:854]: MsiOpenPackageEx is returning 0
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:854]: Creating MSIHANDLE (18) of type 790541 for thread 3996
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:854]: Closing MSIHANDLE (18) of type 790541 for thread 3996
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:854]: Doing action: AppSearch
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:854]: Note: 1: 2205 2:  3: ActionText
MSI(i) [13:54:55.001] | Action 13:54:54: AppSearch. Searching for installed applications
MSI(i) [13:54:55.001] | Action start 13:54:54: AppSearch.
MSI(i) [13:54:55.001] | AppSearch: Property: NETFRAMEWORK40CLIENT, Signature: NetFramework40Client
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:856]: PROPERTY CHANGE: Adding NETFRAMEWORK40CLIENT property. Its value is '#1'.
MSI(i) [13:54:55.001] | AppSearch: Property: FULL_PKG_INSTALLED, Signature: findFullPackage
MSI(i) [13:54:55.001] | AppSearch: Property: NETFRAMEWORK20, Signature: NetFramework20
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:856]: PROPERTY CHANGE: Adding NETFRAMEWORK20 property. Its value is '#1'.
MSI(i) [13:54:55.001] | AppSearch: Property: NETFRAMEWORK30, Signature: NetFramework30
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:857]: PROPERTY CHANGE: Adding NETFRAMEWORK30 property. Its value is '#1'.
MSI(i) [13:54:55.001] | AppSearch: Property: NETFRAMEWORK35, Signature: NetFramework35
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:857]: PROPERTY CHANGE: Adding NETFRAMEWORK35 property. Its value is '#1'.
MSI(i) [13:54:55.001] | AppSearch: Property: NETFRAMEWORK35_SP_LEVEL, Signature: NetFramework35SP
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:857]: PROPERTY CHANGE: Adding NETFRAMEWORK35_SP_LEVEL property. Its value is '#1'.
MSI(i) [13:54:55.001] | AppSearch: Property: VC2008.A6B9614E_3208_40D1_9317_66B6C7C34FC5, Signature: vcvarsall.bat_2008.A6B9614E_3208_40D1_9317_66B6C7C34FC5
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:857]: Note: 1: 1322 2:
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:857]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE32\SOFTWARE\Microsoft\VisualStudio\9.0\Setup\VS 3: 2
MSI(i) [13:54:55.001] | AppSearch: Property: VC2008_X64.A6B9614E_3208_40D1_9317_66B6C7C34FC5, Signature: vcvarsx86_amd64.bat_2008.A6B9614E_3208_40D1_9317_66B6C7C34FC5
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:858]: Note: 1: 1322 2:
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:858]: Note: 1: 1324 2: bin\x86_amd64 3: 1
MSI(i) [13:54:55.001] | AppSearch: Property: VC2010.A6B9614E_3208_40D1_9317_66B6C7C34FC5, Signature: vcvarsall.bat_2010.A6B9614E_3208_40D1_9317_66B6C7C34FC5
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:858]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE32\SOFTWARE\Microsoft\VisualStudio\10.0\Setup\VS 3: 2
MSI(i) [13:54:55.001] | AppSearch: Property: VC2010_X64.A6B9614E_3208_40D1_9317_66B6C7C34FC5, Signature: vcvarsx86_amd64.bat_2010.A6B9614E_3208_40D1_9317_66B6C7C34FC5
MSI(i) [13:54:55.001] | AppSearch: Property: VC2011.A6B9614E_3208_40D1_9317_66B6C7C34FC5, Signature: vcvarsall.bat_2011.A6B9614E_3208_40D1_9317_66B6C7C34FC5
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:859]: Note: 1: 1322 2:
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:859]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE32\SOFTWARE\Microsoft\VisualStudio\11.0\Setup\VS 3: 2
MSI(i) [13:54:55.001] | AppSearch: Property: VC2011_X64.A6B9614E_3208_40D1_9317_66B6C7C34FC5, Signature: vcvarsx86_amd64.bat_2011.A6B9614E_3208_40D1_9317_66B6C7C34FC5
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:859]: Note: 1: 1324 2: bin\x86_amd64 3: 1
MSI(i) [13:54:55.001] | Action ended 13:54:54: AppSearch. Return value 1.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:859]: Doing action: CostInitialize
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:859]: Note: 1: 2205 2:  3: ActionText
MSI(i) [13:54:55.001] | Action 13:54:54: CostInitialize. Computing space requirements
MSI(i) [13:54:55.001] | Action start 13:54:54: CostInitialize.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:861]: Machine policy value 'MaxPatchCacheSize' is 10
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:861]: Baseline: Sorting baselines for {589E1BCD-8E36-492B-AB10-DB2A90789DD8}.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:861]: Baseline: New baseline 13.1.0 from transaction.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:861]: Baseline: Sorted order Native: Order 0.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:861]: Baseline Data Table:
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:861]: ProductCode: {589E1BCD-8E36-492B-AB10-DB2A90789DD8} Version: 13.1.0 Attributes: 0 PatchId: Native BaselineId: -2147483648 Order: 0
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:861]: Baseline File Table:
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:861]: PROPERTY CHANGE: Adding ROOTDRIVE property. Its value is 'C:\'.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:862]: PROPERTY CHANGE: Adding CostingComplete property. Its value is '0'.
MSI(i) [13:54:55.001] | Action ended 13:54:54: CostInitialize. Return value 1.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:863]: Doing action: FileCost
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:863]: Note: 1: 2205 2:  3: ActionText
MSI(i) [13:54:55.001] | Action 13:54:54: FileCost. Computing space requirements
MSI(i) [13:54:55.001] | Action start 13:54:54: FileCost.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:865]: Note: 1: 2205 2:  3: Class
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:865]: Note: 1: 2205 2:  3: Extension
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:865]: Note: 1: 2205 2:  3: TypeLib
MSI(i) [13:54:55.001] | Action ended 13:54:54: FileCost. Return value 1.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:865]: Doing action: CostFinalize
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:865]: Note: 1: 2205 2:  3: ActionText
MSI(i) [13:54:55.001] | Action 13:54:54: CostFinalize. Computing space requirements
MSI(i) [13:54:55.001] | Action start 13:54:54: CostFinalize.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:867]: PROPERTY CHANGE: Adding OutOfDiskSpace property. Its value is '0'.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:867]: PROPERTY CHANGE: Adding OutOfNoRbDiskSpace property. Its value is '0'.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:867]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceAvailable property. Its value is '0'.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:867]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRequired property. Its value is '0'.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:867]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRemaining property. Its value is '0'.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:867]: Note: 1: 2205 2:  3: Patch
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:869]: PROPERTY CHANGE: Adding TARGETDIR property. Its value is 'C:\'.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:869]: PROPERTY CHANGE: Adding HEBundleMenuDir.A6B9614E_3208_40D1_9317_66B6C7C34FC5 property. Its value is 'C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Intel Parallel Studio XE 2013\'.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:869]: PROPERTY CHANGE: Adding CmdPromptMenuDir.A6B9614E_3208_40D1_9317_66B6C7C34FC5 property. Its value is 'C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Intel Parallel Studio XE 2013\Command prompt\'.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:869]: PROPERTY CHANGE: Adding CmdPromptSubMenuDir.A6B9614E_3208_40D1_9317_66B6C7C34FC5 property. Its value is 'C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Intel Parallel Studio XE 2013\Command prompt\Parallel Studio XE\'.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:869]: PROPERTY CHANGE: Adding HEBundleMenuDir.6CE6DF50_ACB9_4BD7_8CFF_FD23CF90CE42 property. Its value is 'C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Intel Parallel Studio XE 2013\'.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:869]: PROPERTY CHANGE: Adding ProductMenuFolder property. Its value is 'C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Intel VTune Amplifier XE 2013\'.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:869]: PROPERTY CHANGE: Adding HEMenuDocumentsFolder_1 property. Its value is 'C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Intel VTune Amplifier XE 2013\Documentation\'.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:869]: PROPERTY CHANGE: Adding HEMenuTutorialsFolder_1 property. Its value is 'C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Intel VTune Amplifier XE 2013\Tutorials\'.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:869]: PROPERTY CHANGE: Adding HEMenuGettingStartedFolder_1 property. Its value is 'C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Intel VTune Amplifier XE 2013\Getting Started\'.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:869]: PROPERTY CHANGE: Adding HEMenuFolder property. Its value is 'C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Intel Parallel Studio XE 2013\'.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:869]: PROPERTY CHANGE: Adding HEMenuDocumentsFolder property. Its value is 'C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Intel Parallel Studio XE 2013\Documentation\'.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:869]: PROPERTY CHANGE: Adding HEMenuTutorialsFolder property. Its value is 'C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Intel Parallel Studio XE 2013\Tutorials\'.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:869]: PROPERTY CHANGE: Adding HEMenuGettingStartedFolder property. Its value is 'C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Intel Parallel Studio XE 2013\Getting Started\'.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:869]: PROPERTY CHANGE: Adding INTEL property. Its value is 'C:\Program Files (x86)\Intel\'.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:869]: PROPERTY CHANGE: Adding INSTALLDIR property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\'.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:869]: PROPERTY CHANGE: Adding ProgramFilesFolder.A6B9614E_3208_40D1_9317_66B6C7C34FC5 property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\'.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:869]: PROPERTY CHANGE: Adding PffIntel.A6B9614E_3208_40D1_9317_66B6C7C34FC5 property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\Intel\'.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:869]: PROPERTY CHANGE: Adding CmnIntel.A6B9614E_3208_40D1_9317_66B6C7C34FC5 property. Its value is 'C:\Program Files (x86)\Common Files\Intel\'.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:869]: PROPERTY CHANGE: Adding CmnIntelHEBundle.A6B9614E_3208_40D1_9317_66B6C7C34FC5 property. Its value is 'C:\Program Files (x86)\Common Files\Intel\Parallel Studio XE 2013\'.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:869]: PROPERTY CHANGE: Adding CmnIntel.6CE6DF50_ACB9_4BD7_8CFF_FD23CF90CE42 property. Its value is 'C:\Program Files (x86)\Common Files\Intel\'.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:869]: PROPERTY CHANGE: Adding CmnIntelISM.6CE6DF50_ACB9_4BD7_8CFF_FD23CF90CE42 property. Its value is 'C:\Program Files (x86)\Common Files\Intel\Intel Software Manager\'.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:869]: PROPERTY CHANGE: Adding include0 property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\include\'.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:869]: PROPERTY CHANGE: Adding legacy property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\include\legacy\'.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:869]: PROPERTY CHANGE: Adding resource property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\resource\'.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:869]: PROPERTY CHANGE: Adding sdk property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\sdk\'.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:869]: PROPERTY CHANGE: Adding src property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\sdk\src\'.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:869]: PROPERTY CHANGE: Adding ittnotify property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\sdk\src\ittnotify\'.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:869]: PROPERTY CHANGE: Adding user_metrics property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\sdk\user_metrics\'.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:869]: PROPERTY CHANGE: Adding lib32 property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\lib32\'.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:869]: PROPERTY CHANGE: Adding python property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\lib32\python\'.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:869]: PROPERTY CHANGE: Adding reporter2 property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\lib32\python\reporter2\'.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:869]: PROPERTY CHANGE: Adding sqlite3 property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\lib32\python\sqlite3\'.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:869]: PROPERTY CHANGE: Adding test property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\lib32\python\sqlite3\test\'.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:869]: PROPERTY CHANGE: Adding dvt6 property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\lib32\python\dvt6\'.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:869]: PROPERTY CHANGE: Adding pythonhelpers1 property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\lib32\python\pythonhelpers1\'.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:869]: PROPERTY CHANGE: Adding dicerhelpers10 property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\lib32\python\dicerhelpers1\'.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:869]: PROPERTY CHANGE: Adding dicer20 property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\lib32\python\dicer2\'.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:869]: PROPERTY CHANGE: Adding perfconfigs property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\lib32\python\perfconfigs\'.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:869]: PROPERTY CHANGE: Adding bin32 property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\bin32\'.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:869]: PROPERTY CHANGE: Adding sepdrv0 property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\bin32\sepdrv\'.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:869]: PROPERTY CHANGE: Adding win70 property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\bin32\sepdrv\win7\'.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:869]: PROPERTY CHANGE: Adding wnet0 property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\bin32\sepdrv\wnet\'.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:869]: PROPERTY CHANGE: Adding runtime0 property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\bin32\runtime\'.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:869]: PROPERTY CHANGE: Adding config property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\config\'.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:869]: PROPERTY CHANGE: Adding dicerengine20 property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\config\dicerengine2\'.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:869]: PROPERTY CHANGE: Adding manip property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\config\manip\'.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:869]: PROPERTY CHANGE: Adding colorblind property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\config\manip\colorblind\'.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:869]: PROPERTY CHANGE: Adding default property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\config\manip\default\'.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:869]: PROPERTY CHANGE: Adding resolver property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\config\resolver\'.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:869]: PROPERTY CHANGE: Adding dbinterface1 property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\config\dbinterface1\'.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:869]: PROPERTY CHANGE: Adding display property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\config\display\'.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:869]: PROPERTY CHANGE: Adding target property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\config\target\'.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:869]: PROPERTY CHANGE: Adding attach property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\config\target\attach\'.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:869]: PROPERTY CHANGE: Adding system property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\config\target\system\'.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:869]: PROPERTY CHANGE: Adding launch property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\config\target\launch\'.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:869]: PROPERTY CHANGE: Adding report property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\config\report\'.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:869]: PROPERTY CHANGE: Adding experimental.power0 property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\config\report\experimental.power\'.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:869]: PROPERTY CHANGE: Adding analysis_type property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\config\analysis_type\'.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:869]: PROPERTY CHANGE: Adding collector property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\config\collector\'.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:869]: PROPERTY CHANGE: Adding query_library property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\config\query_library\'.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:869]: PROPERTY CHANGE: Adding viewpoint property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\config\viewpoint\'.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:869]: PROPERTY CHANGE: Adding include property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\config\viewpoint\include\'.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:869]: PROPERTY CHANGE: Adding experimental.counters property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\config\viewpoint\experimental.counters\'.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:869]: PROPERTY CHANGE: Adding experimental.power property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\config\viewpoint\experimental.power\'.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:869]: PROPERTY CHANGE: Adding message property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\message\'.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:869]: PROPERTY CHANGE: Adding en3 property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\message\en\'.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:869]: PROPERTY CHANGE: Adding tpssplug2 property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\message\en\tpssplug2\'.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:870]: PROPERTY CHANGE: Adding perfrun1 property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\message\en\perfrun1\'.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:870]: PROPERTY CHANGE: Adding dicerhelpers1 property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\message\en\dicerhelpers1\'.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:870]: PROPERTY CHANGE: Adding manip0 property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\message\en\manip\'.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:870]: PROPERTY CHANGE: Adding dicerengine2 property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\message\en\dicerengine2\'.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:870]: PROPERTY CHANGE: Adding dpihelpers1 property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\message\en\dpihelpers1\'.
MSI(i) [13:54:55.001] | MSI (c) (B0:9C) [13:54:54:870]: PROPERTY CHANGE: Adding templates property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\message\en\templates\'.
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: PROPERTY CHANGE: Adding analysis_type0 property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\message\en\analysis_type\'.
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: PROPERTY CHANGE: Adding viewpoint0 property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\message\en\viewpoint\'.
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: PROPERTY CHANGE: Adding dicer2 property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\message\en\dicer2\'.
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: PROPERTY CHANGE: Adding samples property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\samples\'.
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: PROPERTY CHANGE: Adding en2 property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\samples\en\'.
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: PROPERTY CHANGE: Adding Fortran0 property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\samples\en\Fortran\'.
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: PROPERTY CHANGE: Adding C_ property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\samples\en\C#\'.
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: PROPERTY CHANGE: Adding C__2 property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\samples\en\C++\'.
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: PROPERTY CHANGE: Adding documentation property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\documentation\'.
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: PROPERTY CHANGE: Adding msvhelp property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\documentation\msvhelp\'.
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: PROPERTY CHANGE: Adding en1 property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\documentation\msvhelp\en\'.
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: PROPERTY CHANGE: Adding en0 property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\documentation\en\'.
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: PROPERTY CHANGE: Adding welcomepage property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\documentation\en\welcomepage\'.
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: PROPERTY CHANGE: Adding get_started_files property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\documentation\en\welcomepage\get_started_files\'.
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: PROPERTY CHANGE: Adding images property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\documentation\en\welcomepage\get_started_files\images\'.
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: PROPERTY CHANGE: Adding tutorials property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\documentation\en\tutorials\'.
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: PROPERTY CHANGE: Adding find_hotspots property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\documentation\en\tutorials\find_hotspots\'.
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: PROPERTY CHANGE: Adding Fortran property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\documentation\en\tutorials\find_hotspots\Fortran\'.
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: PROPERTY CHANGE: Adding Resources0 property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\documentation\en\tutorials\find_hotspots\Fortran\Resources\'.
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: PROPERTY CHANGE: Adding C__1 property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\documentation\en\tutorials\find_hotspots\C++\'.
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: PROPERTY CHANGE: Adding Resources property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\documentation\en\tutorials\find_hotspots\C++\Resources\'.
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: PROPERTY CHANGE: Adding identify_hw_issues property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\documentation\en\tutorials\identify_hw_issues\'.
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: PROPERTY CHANGE: Adding C__0 property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\documentation\en\tutorials\identify_hw_issues\C++\'.
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: PROPERTY CHANGE: Adding Resources1 property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\documentation\en\tutorials\identify_hw_issues\C++\Resources\'.
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: PROPERTY CHANGE: Adding analyze_locks property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\documentation\en\tutorials\analyze_locks\'.
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: PROPERTY CHANGE: Adding C__ property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\documentation\en\tutorials\analyze_locks\C++\'.
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: PROPERTY CHANGE: Adding Resources2 property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\documentation\en\tutorials\analyze_locks\C++\Resources\'.
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: PROPERTY CHANGE: Adding instructions property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\documentation\en\instructions\'.
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: PROPERTY CHANGE: Adding help property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\documentation\en\help\'.
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: PROPERTY CHANGE: Adding vshelp property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\documentation\vshelp\'.
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: PROPERTY CHANGE: Adding en property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\documentation\vshelp\en\'.
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: PROPERTY CHANGE: Adding intel.perfhe.en property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\documentation\vshelp\en\intel.perfhe.en\'.
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: PROPERTY CHANGE: Adding _ property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\_\'.
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: PROPERTY CHANGE: Adding bin320 property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\_\bin32\'.
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: PROPERTY CHANGE: Adding bin640 property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\_\bin64\'.
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: PROPERTY CHANGE: Adding lib64 property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\lib64\'.
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: PROPERTY CHANGE: Adding bin64 property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\bin64\'.
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: PROPERTY CHANGE: Adding sepdrv property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\bin64\sepdrv\'.
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: PROPERTY CHANGE: Adding win7 property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\bin64\sepdrv\win7\'.
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: PROPERTY CHANGE: Adding wnet property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\bin64\sepdrv\wnet\'.
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: PROPERTY CHANGE: Adding runtime property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\bin64\runtime\'.
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: PROPERTY CHANGE: Adding BASEINSTALLDIR property. Its value is 'C:\Program Files (x86)\Intel\'.
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: PROPERTY CHANGE: Adding LINK property. Its value is 'C:\Program Files (x86)\Intel\VTune Amplifier XE\'.
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: Target path resolution complete. Dumping Directory table...
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: Note: target paths subject to change (via custom actions or browsing)
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: Dir (target): Key: TARGETDIR    , Object: C:\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: Dir (target): Key: WindowsFolder    , Object: C:\Windows\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: Dir (target): Key: ProgramMenuFolder    , Object: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: Dir (target): Key: HEBundleMenuDir.A6B9614E_3208_40D1_9317_66B6C7C34FC5    , Object: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Intel Parallel Studio XE 2013\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: Dir (target): Key: CmdPromptMenuDir.A6B9614E_3208_40D1_9317_66B6C7C34FC5    , Object: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Intel Parallel Studio XE 2013\Command prompt\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: Dir (target): Key: CmdPromptSubMenuDir.A6B9614E_3208_40D1_9317_66B6C7C34FC5    , Object: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Intel Parallel Studio XE 2013\Command prompt\Parallel Studio XE\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: Dir (target): Key: HEBundleMenuDir.6CE6DF50_ACB9_4BD7_8CFF_FD23CF90CE42    , Object: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Intel Parallel Studio XE 2013\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: Dir (target): Key: ProductMenuFolder    , Object: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Intel VTune Amplifier XE 2013\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: Dir (target): Key: HEMenuDocumentsFolder_1    , Object: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Intel VTune Amplifier XE 2013\Documentation\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: Dir (target): Key: HEMenuTutorialsFolder_1    , Object: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Intel VTune Amplifier XE 2013\Tutorials\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: Dir (target): Key: HEMenuGettingStartedFolder_1    , Object: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Intel VTune Amplifier XE 2013\Getting Started\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: Dir (target): Key: HEMenuFolder    , Object: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Intel Parallel Studio XE 2013\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: Dir (target): Key: HEMenuDocumentsFolder    , Object: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Intel Parallel Studio XE 2013\Documentation\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: Dir (target): Key: HEMenuTutorialsFolder    , Object: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Intel Parallel Studio XE 2013\Tutorials\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: Dir (target): Key: HEMenuGettingStartedFolder    , Object: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Intel Parallel Studio XE 2013\Getting Started\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: Dir (target): Key: ProgramFilesFolder    , Object: C:\Program Files (x86)\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: Dir (target): Key: INTEL    , Object: C:\Program Files (x86)\Intel\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: Dir (target): Key: INSTALLDIR    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: Dir (target): Key: ProgramFilesFolder.A6B9614E_3208_40D1_9317_66B6C7C34FC5    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: Dir (target): Key: PffIntel.A6B9614E_3208_40D1_9317_66B6C7C34FC5    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\Intel\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: Dir (target): Key: CommonFilesFolder    , Object: C:\Program Files (x86)\Common Files\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: Dir (target): Key: CmnIntel.A6B9614E_3208_40D1_9317_66B6C7C34FC5    , Object: C:\Program Files (x86)\Common Files\Intel\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: Dir (target): Key: CmnIntelHEBundle.A6B9614E_3208_40D1_9317_66B6C7C34FC5    , Object: C:\Program Files (x86)\Common Files\Intel\Parallel Studio XE 2013\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: Dir (target): Key: CmnIntel.6CE6DF50_ACB9_4BD7_8CFF_FD23CF90CE42    , Object: C:\Program Files (x86)\Common Files\Intel\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: Dir (target): Key: CmnIntelISM.6CE6DF50_ACB9_4BD7_8CFF_FD23CF90CE42    , Object: C:\Program Files (x86)\Common Files\Intel\Intel Software Manager\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: Dir (target): Key: include0    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\include\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: Dir (target): Key: legacy    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\include\legacy\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: Dir (target): Key: resource    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\resource\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: Dir (target): Key: sdk    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\sdk\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: Dir (target): Key: src    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\sdk\src\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: Dir (target): Key: ittnotify    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\sdk\src\ittnotify\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: Dir (target): Key: user_metrics    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\sdk\user_metrics\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: Dir (target): Key: lib32    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\lib32\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: Dir (target): Key: python    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\lib32\python\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: Dir (target): Key: reporter2    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\lib32\python\reporter2\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: Dir (target): Key: sqlite3    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\lib32\python\sqlite3\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: Dir (target): Key: test    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\lib32\python\sqlite3\test\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: Dir (target): Key: dvt6    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\lib32\python\dvt6\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: Dir (target): Key: pythonhelpers1    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\lib32\python\pythonhelpers1\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: Dir (target): Key: dicerhelpers10    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\lib32\python\dicerhelpers1\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: Dir (target): Key: dicer20    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\lib32\python\dicer2\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: Dir (target): Key: perfconfigs    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\lib32\python\perfconfigs\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: Dir (target): Key: bin32    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\bin32\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: Dir (target): Key: sepdrv0    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\bin32\sepdrv\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: Dir (target): Key: win70    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\bin32\sepdrv\win7\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: Dir (target): Key: wnet0    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\bin32\sepdrv\wnet\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: Dir (target): Key: runtime0    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\bin32\runtime\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: Dir (target): Key: config    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\config\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: Dir (target): Key: dicerengine20    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\config\dicerengine2\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: Dir (target): Key: manip    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\config\manip\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: Dir (target): Key: colorblind    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\config\manip\colorblind\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: Dir (target): Key: default    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\config\manip\default\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: Dir (target): Key: resolver    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\config\resolver\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: Dir (target): Key: dbinterface1    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\config\dbinterface1\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: Dir (target): Key: display    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\config\display\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: Dir (target): Key: target    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\config\target\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: Dir (target): Key: attach    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\config\target\attach\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: Dir (target): Key: system    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\config\target\system\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: Dir (target): Key: launch    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\config\target\launch\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: Dir (target): Key: report    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\config\report\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: Dir (target): Key: experimental.power0    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\config\report\experimental.power\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: Dir (target): Key: analysis_type    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\config\analysis_type\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: Dir (target): Key: collector    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\config\collector\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: Dir (target): Key: query_library    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\config\query_library\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: Dir (target): Key: viewpoint    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\config\viewpoint\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: Dir (target): Key: include    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\config\viewpoint\include\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:870]: Dir (target): Key: experimental.counters    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\config\viewpoint\experimental.counters\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:871]: Dir (target): Key: experimental.power    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\config\viewpoint\experimental.power\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:871]: Dir (target): Key: message    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\message\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:871]: Dir (target): Key: en3    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\message\en\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:871]: Dir (target): Key: tpssplug2    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\message\en\tpssplug2\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:871]: Dir (target): Key: perfrun1    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\message\en\perfrun1\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:871]: Dir (target): Key: dicerhelpers1    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\message\en\dicerhelpers1\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:871]: Dir (target): Key: manip0    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\message\en\manip\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:871]: Dir (target): Key: dicerengine2    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\message\en\dicerengine2\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:871]: Dir (target): Key: dpihelpers1    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\message\en\dpihelpers1\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:871]: Dir (target): Key: templates    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\message\en\templates\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:871]: Dir (target): Key: analysis_type0    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\message\en\analysis_type\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:871]: Dir (target): Key: viewpoint0    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\message\en\viewpoint\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:871]: Dir (target): Key: dicer2    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\message\en\dicer2\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:871]: Dir (target): Key: samples    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\samples\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:871]: Dir (target): Key: en2    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\samples\en\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:871]: Dir (target): Key: Fortran0    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\samples\en\Fortran\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:871]: Dir (target): Key: C_    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\samples\en\C#\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:871]: Dir (target): Key: C__2    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\samples\en\C++\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:871]: Dir (target): Key: documentation    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\documentation\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:871]: Dir (target): Key: msvhelp    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\documentation\msvhelp\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:871]: Dir (target): Key: en1    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\documentation\msvhelp\en\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:871]: Dir (target): Key: en0    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\documentation\en\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:871]: Dir (target): Key: welcomepage    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\documentation\en\welcomepage\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:871]: Dir (target): Key: get_started_files    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\documentation\en\welcomepage\get_started_files\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:871]: Dir (target): Key: images    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\documentation\en\welcomepage\get_started_files\images\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:871]: Dir (target): Key: tutorials    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\documentation\en\tutorials\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:871]: Dir (target): Key: find_hotspots    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\documentation\en\tutorials\find_hotspots\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:871]: Dir (target): Key: Fortran    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\documentation\en\tutorials\find_hotspots\Fortran\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:871]: Dir (target): Key: Resources0    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\documentation\en\tutorials\find_hotspots\Fortran\Resources\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:871]: Dir (target): Key: C__1    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\documentation\en\tutorials\find_hotspots\C++\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:871]: Dir (target): Key: Resources    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\documentation\en\tutorials\find_hotspots\C++\Resources\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:871]: Dir (target): Key: identify_hw_issues    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\documentation\en\tutorials\identify_hw_issues\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:871]: Dir (target): Key: C__0    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\documentation\en\tutorials\identify_hw_issues\C++\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:871]: Dir (target): Key: Resources1    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\documentation\en\tutorials\identify_hw_issues\C++\Resources\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:871]: Dir (target): Key: analyze_locks    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\documentation\en\tutorials\analyze_locks\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:871]: Dir (target): Key: C__    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\documentation\en\tutorials\analyze_locks\C++\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:871]: Dir (target): Key: Resources2    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\documentation\en\tutorials\analyze_locks\C++\Resources\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:871]: Dir (target): Key: instructions    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\documentation\en\instructions\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:871]: Dir (target): Key: help    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\documentation\en\help\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:871]: Dir (target): Key: vshelp    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\documentation\vshelp\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:871]: Dir (target): Key: en    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\documentation\vshelp\en\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:871]: Dir (target): Key: intel.perfhe.en    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\documentation\vshelp\en\intel.perfhe.en\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:871]: Dir (target): Key: _    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\_\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:871]: Dir (target): Key: bin320    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\_\bin32\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:871]: Dir (target): Key: bin640    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\_\bin64\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:871]: Dir (target): Key: lib64    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\lib64\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:871]: Dir (target): Key: bin64    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\bin64\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:871]: Dir (target): Key: sepdrv    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\bin64\sepdrv\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:871]: Dir (target): Key: win7    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\bin64\sepdrv\win7\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:871]: Dir (target): Key: wnet    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\bin64\sepdrv\wnet\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:871]: Dir (target): Key: runtime    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\bin64\runtime\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:871]: Dir (target): Key: BASEINSTALLDIR    , Object: C:\Program Files (x86)\Intel\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:871]: Dir (target): Key: LINK    , Object: C:\Program Files (x86)\Intel\VTune Amplifier XE\
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:871]: PROPERTY CHANGE: Adding INSTALLLEVEL property. Its value is '1'.
MSI(i) [13:54:55.002] | Action ended 13:54:54: CostFinalize. Return value 1.
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:904]: Doing action: InstallValidate
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:904]: Note: 1: 2205 2:  3: ActionText
MSI(i) [13:54:55.002] | Action 13:54:54: InstallValidate. Validating install
MSI(i) [13:54:55.002] | Action start 13:54:54: InstallValidate.
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:906]: Feature: CoreAppFiles64; Installed: Absent;   Request: Local;   Action: Local
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:906]: Feature: SEPFeature; Installed: Absent;   Request: Local;   Action: Local
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:906]: Feature: CoreAppFiles; Installed: Absent;   Request: Local;   Action: Local
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:906]: Component: CommonInstallRoot; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:906]: Component: symbolic_link; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:906]: Component: symbolic_link_target; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:906]: Component: ISMClientAnchor; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:906]: Component: FullPackageMarker; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:906]: Component: Dummy; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:906]: Component: ProductFamilyAnchor; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:906]: Component: ProductVersionAnchor; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:906]: Component: DirEnv; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:906]: Component: CompMsiMarker; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:906]: Component: CompLinks; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:906]: Component: CompLinksWin8; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:906]: Component: CoreAnchor; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_amplxe_tbbmalloc.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_amplxe_tbb.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_symsrv.yes; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_amplxe_dbghelp.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_amplxe_symsrv.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_Microsoft.VC90.CRT.manifest; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_msvcp90.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_msvcr90.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_amplxe_cpil_2.14.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_amplxe_libxml_2.7.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_amplxe_libxslt_1.1.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_ittnotify_sampling.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_libittnotify.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_VtuneApi32e.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_javaattach.jar; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_ittnotify_collector.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_amplxe_tpssmrte_javaprof_1.0.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_amplxe_samplingmrte_javaprof_1.0.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_dbghelp.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_vsdbg.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_pin.exe; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_pinvm.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_amplxe_boost_filesystem_1.47.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_amplxe_boost_filesystem3_1.47.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_amplxe_boost_date_time_1.47.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_amplxe_boost_regex_1.47.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_amplxe_boost_thread_1.47.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_amplxe_boost_iostreams_1.47.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_amplxe_boost_system_1.47.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_amplxe_gen_helpers_core_2.6.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_amplxe_gen_helpers_das_2.6.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_amplxe_gen_helpers_adn_2.6.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_amplxe_martini_osa_2.0.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_amplxe_martini_cie_2.0.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_amplxe_mrtehelpers_clrattach_2.1.exe; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_amplxe_sampling_strings_3.8.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.002] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_amplxe_sampling_logit_3.8.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_amplxe_sampling_utils_3.8.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_amplxe_sampling_rise_3.8.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_c_osi.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_amplxe_sampling_pise_3.8.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_amplxe_sampling_tbrw_3.8.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_abstract.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_amplxe_sampling_mrte_3.8.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_amplxe_sampling_user_api_3.8.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_sepdal.sys; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_sepdrv3_8.sys; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_sepdal.sys0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_sepdrv3_8.sys0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_vtss.sys; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_sep_modules.exe; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_tpsstool.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_amplxe_tpssmrte_clrprof_1.0.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_amplxe_samplingmrte_clrprof_1.0.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_tpssmrte_clrwrap_1.0.dll1; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_tpssmrte_clr35sp1wrap_1.0.dll1; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_tpssmrte_clr40wrap_1.0.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_jitprofiling.lib; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_libittnotify.lib; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_tpssmrte_clrwrap_1.0.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_tpssmrte_clr35sp1wrap_1.0.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:906]: Component: mrte_assembly64; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_tpssmrte_clrwrap_1.0.dll0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_tpssmrte_clr35sp1wrap_1.0.dll0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:906]: Component: mrte_assembly32; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_mrte_reg.msi; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_msvcrt_x64.msi; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_perfhe_namedurlindex.hxk; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_perfhe_f.hxk; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_perfhe.hxt; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_perfhe_k.hxk; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_perfhe.HxS; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_perfhe.hxa; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_perfhe.HxC; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_pmb_f.HxK0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_reference_olh.HxS; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_pmw_sp.HxS; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_pmm_f.HxK; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_reference_NamedUrlIndex.HxK; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_pmp_f.HxK0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_pmn_f.HxK0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_H2Reg_cmd.ini; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_reference_A.HxK; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_reference_F.HxK; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_pmb.HxS; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_pmn.HxS; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_pmbk.HxS; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_pmw_dp_f.HxK; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_pmw_dp.HxS; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_pmbk_f.HxK; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_pmm.HxS; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_reference_K.HxK; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_pmw_sp_f.HxK0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_reference.HxT; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_pmp.HxS; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_reference.HxS; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_reference.HxA; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_reference.HxC; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_perfhe.chm; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_perfhe_f.HxK0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_pmb_f.HxK; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_pmn_f.HxK; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_pmm.chm; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_pmp_f.HxK; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_pmp.chm; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_pmbk.chm; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_pmw_sp_f.HxK; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_pmm_f.HxK0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_pmb.chm; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_pmn.chm; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_pmw_dp.chm; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_pmbk_f.HxK0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_reference_olh.chm; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_pmw_dp_f.HxK0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_pmw_sp.chm; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:906]: Component: Comp_AVX_319433_013.pdf; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp__327364001EN.pdf; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_instruction_reference.xml; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp__253667.pdf; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp__253666.pdf; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_GUID_222FDA9F_6ECE_45B3_A9DC_7BBFA76CF50D_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_GUID_29BAC632_7B67_4308_BDC9_7CE931B79FBE_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_GUID_6B127988_FD4D_49E5_B6C2_054841D582E9_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_GUID_6DE40E1D_820A_4C31_97AB_ACCBEBDF17FB_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_GUID_DC6C10DF_EED1_45FE_BAA4_472F704804FB_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_GUID_D8DBA40B_558C_4899_B9B6_9068F1CAE124_low.jpg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_GUID_745C541A_9795_4F6F_A286_31A5E42DEB99_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_GUID_5749422A_B37A_4FC0_9980_4B891EB19B67_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_GUID_00E5AAB7_0A48_4D4A_BF25_7C064B195449.hhc.bak; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_GUID_A37E1B6B_F37F_4676_84F4_4943F1B1CB7E_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_GUID_15980D13_8C2C_4BEA_B3F4_6E3B3FB8B1F5_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_GUID_FE211AA7_ED9E_4206_AB72_FDA82CD423D8_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_GUID_20BF851A_580E_4371_AC42_FBC0D15593BE_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_GUID_02914B5D_1A7D_4B4B_8A24_9534BDA714E4_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_GUID_6243DC98_3E0C_4035_8DE5_98F33BE4DD48_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_dita.list; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_GUID_A4AF9F6D_C2F3_4CC2_BC62_4EF73CA76B7B_low.jpg0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_farinfo.ini; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_GUID_E632A67E_51CD_4676_B252_0F411DF5A068_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_GUID_B7F2766C_B929_4469_9431_7BB94D2018F6_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_GUID_099449C8_44EF_4A8C_AEA9_E1153BF6C2D8_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_GUID_6B050727_3556_42AC_A369_3E6095B9D583_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_treenodeplus.gif0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_langref_footer.html; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_ndash.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_Thumbs.db0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_tip.gif0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_note.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_intel_css_styles.css1; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_warning.jpg0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_bullet.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_warning.gif1; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_ssgid_scripts.js1; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_caution.gif0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_tip.jpg0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_mdash.gif1; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_NavScript.js1; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_caution.jpg0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_note.jpg1; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_GUID_582A3DAF_523B_42E5_AA51_689832BAC0E2.htm; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_GUID_96C7A16F_D7BF_4963_A9ED_9CB10C2CC574_low.jpg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_GUID_69C43A34_B0C5_48A6_8622_ED45A274FE43.htm0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_tree.css; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_GUID_2FF255B6_052C_4303_ACA5_1A150B783E0A_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_GUID_EE38AD95_A509_4506_9232_13367F5C2495.htm; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_GUID_00E5AAB7_0A48_4D4A_BF25_7C064B195449.hhk.bak; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_GUID_B49594F1_C7F8_4E96_B56C_2FA2E3C4F393_low.jpg1; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_GUID_8257EA78_2C6D_4E27_8C2C_604020F313ED.htm; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_perfhe.hhk0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_GUID_00E5AAB7_0A48_4D4A_BF25_7C064B195449.hhp; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_GUID_00E5AAB7_0A48_4D4A_BF25_7C064B195449.hhk; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_GUID_00E5AAB7_0A48_4D4A_BF25_7C064B195449.hhc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_GUID_D50FDB92_96AD_4D80_85F8_06E9650E5EF5_low.jpg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_GUID_FFE89AB1_40CF_416F_845F_D413C0737A4E_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_GUID_00E5AAB7_0A48_4D4A_BF25_7C064B195449_f.HxK; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_tree.js; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_delete_extra_files_for_final_release.bat; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_GUID_F26BAE99_B3EF_4141_917D_4D1E5C770A6A_low.jpg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_GUID_B06E5EBB_3CD1_477E_AAB2_1C5C5221EC8C_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_hh_toc.htm0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_GUID_32D9EE6D_C11E_40DB_BF5C_7EC6C62212F0_low.jpg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_GUID_0EDA1A3F_30A6_4035_80F2_A115DDE4953E_low.jpg0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_GUID_5A0AFC44_F34C_4AE0_A245_3CC0DED4945A_low.jpg0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_GUID_20B195C5_E286_4769_973B_4A2F86F3B448_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_NavScriptFarhelp_bat.FarRun; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_GUID_4247844E_FB32_4AA0_B2D9_4D40972AC2B3_low.jpg1; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_GUID_C65E00A6_6283_46D0_AE5E_99DBE68C9379_low.jpg0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_GUID_E75A46A6_20A2_4C2C_A9DB_486A36741064_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_GUID_A1306DB7_0558_4FC5_940C_0B019A8987FB_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_GUID_667008D9_1F25_4B94_9573_A1D855E7D9FC.htm0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_GUID_08AABA1E_7FDD_4ACF_8B4E_FA82F6AE7773_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_GUID_E7D56D64_CFB2_4E89_BD7A_6E946C5C495D_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_perfhe_f.HxK2; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_GUID_B2F2B2D9_F1E3_44F9_8919_50726722E1C3_low.jpg1; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_GUID_7AFDA3A0_486B_4130_B3FA_C02257DD0AA9_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_GUID_EC89F6F7_1D37_4D59_82B5_710853E15391_low.jpg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_GUID_95E3E82B_A470_4BA4_95C7_C9442A2938FF_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_GUID_7135B5E5_AE8D_4224_919A_3AE318B0BA60_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_GUID_970DDE2B_EC8F_4266_A7EC_5383FFEF3566_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_GUID_D9203FC0_7C95_40E0_A607_DD8C2FAC4A87_low.jpg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_perfhe.hhp; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_GUID_BCA972FA_3310_4BEA_AA86_1C30040C865B_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_GUID_ECE7B5D8_D281_4F4D_88F4_CF06675835C6_low.jpg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_perfhe.hhc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_GUID_CF8A1E58_DAA5_4671_A0C5_28ADF088A823_low.gif0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_delta.gif1; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_GUID_68FBBAA2_3D50_4327_93AA_0E7CCB5CD36A_low.gif0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_GUID_A766557E_C528_44AE_82BB_BBBA16D92BDA_low.jpg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_GUID_1539C8D4_389B_418F_ACE7_B7CEDE00FAF4_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_search.js0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_farhelp_bat_log.txt0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_GUID_79674B4D_96FE_443B_8C10_45DC8C577C9A_low.gif0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_GUID_45C754D4_76EA_4835_8FD8_EB1AA5767254_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_GUID_F5F7762C_7C7C_4493_A2C1_8321F6925178_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_GUID_BDA0454E_73C9_4195_9B69_4C57EEDA93B9_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_GUID_85949B52_3ABE_4B0D_8B4B_BCAF60C404F3_low.jpg0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_GUID_105FA066_A743_4D7F_B4AA_1A459B0EDC8F_low.gif1; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_GUID_14D61C3A_A2F4_43A4_B9B9_6C0F1A20F346.htm; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_GUID_01CC1A99_8CA9_428E_B406_EBE7A65143C7_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_delete_extra_files_during_beta.bat0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_hh_search.htm1; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_GUID_67E1BFB3_02BB_42DD_9F37_FC4E43AC7E64_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_GUID_7ECB4127_98ED_45FD_9A06_77127BFF9E03_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_dita.xml.properties; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_GUID_5BA24D82_9B9D_438B_B476_A5A50E83367E_low.jpg1; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_GUID_0DB63DE8_A7E4_4D30_B0CB_CBA67C2C97B2_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_GUID_FC1CA445_3400_447E_AD79_5A37D0D1D22B.htm; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_GUID_9B11B59F_FF06_4A24_A4E9_546C889E0E30.htm; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_treenodedot.gif0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_treenodeminus.gif0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_GUID_C3CB3FC0_37C8_49D9_9EF2_8BBBA81D23FC_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_GUID_00E5AAB7_0A48_4D4A_BF25_7C064B195449.ditamap_htmlhelpzip.log; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_GUID_00E5AAB7_0A48_4D4A_BF25_7C064B195449.hhp.bak; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_GUID_77F6D8AB_7B53_4D6A_A525_DE0678D2EA41_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_GUID_A41EFB53_22BA_4C1E_8F3F_EB18F05576FA_low.png; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_GUID_33D65372_E9A8_4E4C_BAAA_A3DAD8158E75_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_GUID_E440372F_3036_4EE8_95EB_62AC111D7521.htm; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_GUID_D97809EA_D0C0_4C92_8E0A_D7B2A0292113_low.jpg0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_GUID_2751A2D0_7CC6_4F13_89E4_B65B3F05B3E0_low.gif2; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_NavScript.js2; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_GUID_399AC448_BF89_49CF_8AA2_AEEE8F7DFB96_low.jpg0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_hh_goto.htm1; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_commonltr.css0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_GUID_3E61E05B_F315_404B_86CA_E1DE47E4E803_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_GUID_00E5AAB7_0A48_4D4A_BF25_7C064B195449.ditamap_farhtml.log; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:907]: Component: Comp_GUID_379CC698_B3D0_454F_B78C_DC5B4E22B37D_low.jpg1; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_GUID_1F1789E7_1A9E_4011_BFF3_3049B9E2A3EE_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_GUID_AD48636D_2FED_4665_BF24_EDA5C60A6ADF_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_GUID_47A23D99_AC7A_4B0C_AF79_876F283573DA_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.003] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_GUID_1990ADE7_BD64_40FD_802A_91C87579DA24_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_GUID_63078DB3_E611_4295_9068_E82AA17A809D.htm; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_GUID_A510FE74_B519_4A5B_8F35_C10AAF48B912_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_GUID_9C0EFE39_8B0A_47E8_92DA_698C5AF2316F.htm; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_GUID_FFA7F7D0_B380_4923_994B_52C02E616961_low.gif1; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_GUID_BA49DA5A_0828_482B_8E50_97A92B13D585_low.gif0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_GUID_661D9893_2B36_4397_9096_E822714B6987_low.gif1; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_GUID_A7D03818_E9AF_424D_B6F6_B3CDD47863BA_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_commonrtl.css0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_GUID_02125CD7_F858_4C84_B56F_FB8C89316580.htm; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_index.htm3; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_deltaend.gif2; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_GUID_59EDEE56_7657_472E_BB86_5A57FBBE4968.htm; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_GUID_FB99E6CF_E5AE_4C62_BC34_5330982D70A5_low.gif1; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_GUID_4BF5EBC1_3464_4064_A659_451198DF0176_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_GUID_BB3CEE89_C244_40CC_BE97_F9DE75185D81_low.gif0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_GUID_D403605D_8D88_47E8_8654_3DF782D9C645_low.jpg2; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_GUID_C2A283F4_0493_4B1E_BC73_F67390AE6700_low.gif2; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_GUID_852F1E0F_D987_49B4_99FE_8207ADE5A90E_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_GUID_E786659C_EB32_4AF5_9D86_A5F948610FFA.htm; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_GUID_6E86CF90_5E2D_4CEE_9C82_81A2B2B49417_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_GUID_6838B50B_C34A_431C_B472_5C112D6A1E51_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_GUID_BCE1DA0A_3ADC_404C_8BFD_1B3F8B67D64A_low.jpg2; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_searchdata.js2; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_GUID_AEB56342_BFCF_44A8_B2F5_893CD191B498_low.jpg1; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_GUID_092E2B62_7C81_410C_93F2_6690053138A2_low.jpg2; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_intel_css_styles.css6; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_GUID_DFA9CFC2_C540_46E0_B2BE_E88DCA3746BD_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_GUID_D77E4125_C797_4949_9418_AA630B67A72F.htm; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_search.js; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_GUID_1873EBEA_908B_4EFE_BCCD_CDC588A6265B.htm; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_intel_css_styles.css; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_GUID_18F8C6D3_635F_4EB5_BAD1_056C81B376F7_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_GUID_9AB632F6_C4A5_48B1_8152_AD4A397C206E_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_GUID_25FA8980_C556_472D_A105_B1BE23C33D5D_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_GUID_0EDA1A3F_30A6_4035_80F2_A115DDE4953E_low.jpg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_mdash.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_warning.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_Thumbs.db; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_tip.jpg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_caution.jpg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_tip.gif1; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_ssgid_scripts.js0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_note.gif1; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_warning.jpg1; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_note.jpg0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_NavScript.js0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_intel_css_styles.css5; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_bullet.gif2; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_caution.gif2; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_langref_footer.html2; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_ndash.gif2; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_treenodeplus.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_GUID_A6F2E84C_E438_4713_AE70_C87BD893D491_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_delete_extra_files_during_beta.bat; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_GUID_5E66DCAD_A9B0_4373_B90D_FC1D0FD1E7D2.htm; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_GUID_6FC48780_2172_4763_947F_59F5BAC37DD0.htm; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_GUID_96C7A16F_D7BF_4963_A9ED_9CB10C2CC574_low.jpg0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_GUID_4247844E_FB32_4AA0_B2D9_4D40972AC2B3_low.jpg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_GUID_20CA02A3_2074_4FF0_8EDC_EBCB2ED05D2E_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_GUID_D252800A_0917_41A4_A19E_4260C43540E9_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_GUID_2683FFAC_C2C2_4D41_B01D_9A5B0867B350.htm; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_GUID_85949B52_3ABE_4B0D_8B4B_BCAF60C404F3_low.jpg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_GUID_A9D4BE8C_4266_4F34_BA9C_00AFF01CE32B.htm; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_GUID_75F768B9_B36D_4B17_847A_CA6F71D40255_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_GUID_703EC099_0C5C_4505_83DC_BF1854BFED41.htm; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_NavScript.js; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_hh_goto.htm; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_GUID_745C541A_9795_4F6F_A286_31A5E42DEB99_low.gif0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_searchdata.js0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_GUID_CAD48E70_E817_4841_8D86_4DA82F5B276E_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_GUID_0C7C9098_EE62_464E_A3DA_505F467F7A8A_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_delta.gif0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_deltaend.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_GUID_2751A2D0_7CC6_4F13_89E4_B65B3F05B3E0_low.gif0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_GUID_C65E00A6_6283_46D0_AE5E_99DBE68C9379_low.jpg1; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_GUID_092E2B62_7C81_410C_93F2_6690053138A2_low.jpg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_GUID_A4AF9F6D_C2F3_4CC2_BC62_4EF73CA76B7B_low.jpg1; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_tree.js0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_GUID_5BA24D82_9B9D_438B_B476_A5A50E83367E_low.jpg0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_GUID_D50FDB92_96AD_4D80_85F8_06E9650E5EF5_low.jpg0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_GUID_2848515A_9ADE_421F_8A12_C9DC1E74F27A.ditamap_farhtml.log; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_GUID_B49594F1_C7F8_4E96_B56C_2FA2E3C4F393_low.jpg2; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_GUID_FA2F2896_3201_4C42_A038_9127E6CB0F8C_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_hh_toc.htm1; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_index.htm0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_GUID_A4E9A742_3CD6_4C63_B9B4_1B73799077F2_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_GUID_7AFDA3A0_486B_4130_B3FA_C02257DD0AA9_low.gif0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_GUID_FFA7F7D0_B380_4923_994B_52C02E616961_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_GUID_69C43A34_B0C5_48A6_8622_ED45A274FE43.htm2; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_GUID_105FA066_A743_4D7F_B4AA_1A459B0EDC8F_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_GUID_02914B5D_1A7D_4B4B_8A24_9534BDA714E4_low.gif1; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_treenodedot.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_GUID_BCE1DA0A_3ADC_404C_8BFD_1B3F8B67D64A_low.jpg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_GUID_667008D9_1F25_4B94_9573_A1D855E7D9FC.htm1; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_GUID_B7F2766C_B929_4469_9431_7BB94D2018F6_low.gif1; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_delete_extra_files_for_final_release.bat0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_GUID_FD488B3F_1486_4F87_9127_3F441FE3645D_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_GUID_83FD3461_0EF9_48D7_AC31_0A5641750A43_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_GUID_D9203FC0_7C95_40E0_A607_DD8C2FAC4A87_low.jpg1; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_GUID_79674B4D_96FE_443B_8C10_45DC8C577C9A_low.gif1; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_GUID_37C3F1D2_0546_4A21_B46B_9C4FF5DC30F4_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_farinfo.ini0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_GUID_D3A47376_A9B4_4CF6_86F1_EAC87D01D2A4_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_GUID_661D9893_2B36_4397_9096_E822714B6987_low.gif0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_GUID_08AABA1E_7FDD_4ACF_8B4E_FA82F6AE7773_low.gif1; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_NavScriptFarhelp_bat.FarRun2; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_GUID_9ABD646D_33D5_4470_9AB9_C9B5D769BAED_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_GUID_87108A1F_7EFA_4788_AF1E_25671365DD0F_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_GUID_02B52C62_0EA8_4B95_9756_E7611B450524_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_GUID_EC89F6F7_1D37_4D59_82B5_710853E15391_low.jpg1; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_GUID_9D64DB39_15AE_4B8D_A2E7_D4ED8C6DD42A.htm; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_tree.css1; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_GUID_379CC698_B3D0_454F_B78C_DC5B4E22B37D_low.jpg0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_GUID_B2F2B2D9_F1E3_44F9_8919_50726722E1C3_low.jpg2; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_hh_search.htm2; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_GUID_C2A283F4_0493_4B1E_BC73_F67390AE6700_low.gif0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_GUID_663034C4_7C73_4A6A_BFFA_A81413F18019.htm; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_GUID_32D9EE6D_C11E_40DB_BF5C_7EC6C62212F0_low.jpg1; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_GUID_5A0AFC44_F34C_4AE0_A245_3CC0DED4945A_low.jpg2; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_GUID_399AC448_BF89_49CF_8AA2_AEEE8F7DFB96_low.jpg2; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_GUID_D5D2D7B6_5246_4E30_BDAD_44A64358B218_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_GUID_D8DBA40B_558C_4899_B9B6_9068F1CAE124_low.jpg2; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_GUID_A766557E_C528_44AE_82BB_BBBA16D92BDA_low.jpg1; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_GUID_ECE7B5D8_D281_4F4D_88F4_CF06675835C6_low.jpg2; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:908]: Component: Comp_perfhe_f.HxK4; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_GUID_63B56C0F_6AFD_4E57_9B64_DC20F29BEDE4_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_GUID_F5B7CFD9_F73F_4FF5_837F_C1BDE6B0F024_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_GUID_98289BE0_D5A7_457A_9394_582D9A4BC3B0_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_GUID_53AE2D51_3318_4D2E_A746_8DDF537D917C.htm; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_GUID_3030D0BA_54D0_40F7_81D7_7BB41275E609_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_GUID_AEB56342_BFCF_44A8_B2F5_893CD191B498_low.jpg0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_GUID_D403605D_8D88_47E8_8654_3DF782D9C645_low.jpg1; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_GUID_07816522_040F_400B_9D8B_83B1EC6FD30E_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_farhelp_bat_log.txt1; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_perfhe.hhk2; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_GUID_70AC72E8_06B2_489A_8C23_A353711B04E9_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_perfhe.hhc2; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_perfhe.hhp2; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_GUID_7CE3E712_60CA_4116_9139_C22640D0DB52.htm; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_GUID_DC6C10DF_EED1_45FE_BAA4_472F704804FB_low.gif2; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_treenodeminus.gif2; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_GUID_2BEA8D3A_AF3A_46FE_8A4E_39F889F59C58.htm; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_GUID_2F50D0D0_0213_415F_978F_C7A45795A280_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_GUID_2DE245B0_2712_4C77_A337_73DEBD609942_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_warning.jpg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_intel_css_styles.css0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_warning.gif0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_bullet.gif0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_langref_footer.html1; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_mdash.gif0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_tip.gif2; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_Thumbs.db2; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_ndash.gif1; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_tip.jpg1; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_caution.gif1; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_note.gif2; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_caution.jpg2; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_note.jpg2; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_NavScript.js6; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_ssgid_scripts.js2; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_GUID_5BA24D82_9B9D_438B_B476_A5A50E83367E_low.jpg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_GUID_E65EAF99_9FEC_4FDA_A6FD_84ACD3F86E5D.htm; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_GUID_15068C95_6378_48B3_8351_0B433818806B_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_GUID_1D659123_13BE_4287_B2E5_55FDC352FA69_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_GUID_661D9893_2B36_4397_9096_E822714B6987_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_GUID_68FBBAA2_3D50_4327_93AA_0E7CCB5CD36A_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_GUID_F8F93F1C_43E4_44A8_9CAD_34E6EED8CFCD_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_GUID_4706E3CA_6DDE_4F20_941E_7F6D611312A7.htm; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_GUID_B2F2B2D9_F1E3_44F9_8919_50726722E1C3_low.jpg0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_GUID_83A4F285_B015_4B4B_A71C_CCADD6BC8470_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_GUID_046B0EC5_4092_41C2_B799_38E0A4DA0E2D_low.jpg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_GUID_2510CBE8_E9EA_4D4E_B22F_2BA498BEE8DA_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_hh_toc.htm; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_farhelp_bat_log.txt; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_GUID_74FC9A3F_9C89_485A_A0FD_766DC7808A6F_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_GUID_5A0AFC44_F34C_4AE0_A245_3CC0DED4945A_low.jpg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_GUID_4A038EF8_D456_4D2D_9895_5433085E863A_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_delta.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_GUID_02914B5D_1A7D_4B4B_8A24_9534BDA714E4_low.gif0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_GUID_08D3F75B_BCC1_480F_B656_939AB584C870_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_GUID_D97809EA_D0C0_4C92_8E0A_D7B2A0292113_low.jpg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_GUID_EE33387F_F561_4157_BC05_1D4D841249CF_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_GUID_B49594F1_C7F8_4E96_B56C_2FA2E3C4F393_low.jpg0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_perfhe_f.HxK1; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_GUID_69C43A34_B0C5_48A6_8622_ED45A274FE43.htm1; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_GUID_64DF01D6_D771_4980_985D_5E2F7DA425DC_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_GUID_ED550FD4_4A82_43C7_8CBB_289638105502.htm; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_GUID_57C5587D_CD08_4A47_AB0F_1DF5979DB293.htm; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_GUID_65CB3538_B65D_40DC_BA08_C6D670B12A89_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_GUID_F7A9608B_B057_4243_957B_38D0ED29508C_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_GUID_C5135754_54C1_4ABB_9EC9_101B6192B8C0_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_GUID_BB3CEE89_C244_40CC_BE97_F9DE75185D81_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_treenodeplus.gif1; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_GUID_EA01450B_7FE4_4A2C_81FD_060AB6EB5210_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_GUID_61315581_3BEC_462C_9528_4D8DAA250D55.htm; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_GUID_BA49DA5A_0828_482B_8E50_97A92B13D585_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_hh_search.htm; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_GUID_9AC809DE_A602_43ED_8B03_F6A0E68FB580_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_GUID_F377827F_CD34_41D0_A533_CD8F91264111_low.jpg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_GUID_6543D775_82EC_4B64_BCBC_5294825F5DBF.htm; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_GUID_EA1AC2F4_4F7F_4E5E_BF62_B342FA08CD3F_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_GUID_0EDA1A3F_30A6_4035_80F2_A115DDE4953E_low.jpg1; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_commonrtl.css; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.004] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_treenodeminus.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_GUID_532AC158_6141_45F1_81BF_2F3AA047D916_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_GUID_D1320A0F_E1E9_4A8A_BF53_32535A7368A0.htm; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_GUID_08AABA1E_7FDD_4ACF_8B4E_FA82F6AE7773_low.gif0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_GUID_EED2848B_A055_4D85_922B_388ADF02BF68.hhp; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_GUID_EED2848B_A055_4D85_922B_388ADF02BF68.hhk; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_GUID_EED2848B_A055_4D85_922B_388ADF02BF68.hhc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_GUID_EED2848B_A055_4D85_922B_388ADF02BF68.hhc.bak; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_GUID_695ADDE0_CFC3_41D5_A78B_434EA408D191_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_GUID_68B48DD3_E2E9_4CB2_B065_F067C00BD3A2_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_GUID_FB99E6CF_E5AE_4C62_BC34_5330982D70A5_low.gif0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_GUID_2925B396_A8DA_43B7_855A_576A3788B3C2_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_GUID_4247844E_FB32_4AA0_B2D9_4D40972AC2B3_low.jpg2; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_GUID_A4AF9F6D_C2F3_4CC2_BC62_4EF73CA76B7B_low.jpg2; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_GUID_96C7A16F_D7BF_4963_A9ED_9CB10C2CC574_low.jpg1; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_GUID_2FE02B7B_1B77_4EA6_A0B6_9F208AF2536F_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_search.js1; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_commonltr.css; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_GUID_D8DBA40B_558C_4899_B9B6_9068F1CAE124_low.jpg1; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_GUID_10EA24BF_1983_4508_B582_53109344C170_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_GUID_32D9EE6D_C11E_40DB_BF5C_7EC6C62212F0_low.jpg0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_GUID_7AFDA3A0_486B_4130_B3FA_C02257DD0AA9_low.gif1; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_GUID_2751A2D0_7CC6_4F13_89E4_B65B3F05B3E0_low.gif1; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_NavScriptFarhelp_bat.FarRun1; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_GUID_EF71EF8C_35FF_4E00_8A4A_875E4AADA62C_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_GUID_FAA6222F_9F58_44A1_A86B_40A80284ABFB_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_GUID_2F7FFE1A_98F2_4779_8688_E704B11EC9CA_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_treenodedot.gif1; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_GUID_1B5B7592_BE99_4105_A788_4DF3FB4C2E0C_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_GUID_379CC698_B3D0_454F_B78C_DC5B4E22B37D_low.jpg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_index.htm2; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_GUID_D21B4BA2_D151_40C8_BF1E_3A4C222F2B1F_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_GUID_9EDA29BB_D64D_4D1B_ABBF_C2805FDABE9C_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_perfhe.hhc1; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_perfhe.hhk1; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_GUID_105FA066_A743_4D7F_B4AA_1A459B0EDC8F_low.gif2; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_perfhe.hhp1; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_dita.list0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_GUID_BCE1DA0A_3ADC_404C_8BFD_1B3F8B67D64A_low.jpg0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_GUID_EC89F6F7_1D37_4D59_82B5_710853E15391_low.jpg0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_GUID_14047588_909C_41EB_9643_4BB168BEC1CD_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_GUID_D50FDB92_96AD_4D80_85F8_06E9650E5EF5_low.jpg1; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_GUID_ECE7B5D8_D281_4F4D_88F4_CF06675835C6_low.jpg0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_GUID_149D9490_B9DA_4E98_99F4_26A8E8868B37_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_GUID_D9203FC0_7C95_40E0_A607_DD8C2FAC4A87_low.jpg2; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_GUID_667008D9_1F25_4B94_9573_A1D855E7D9FC.htm2; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_GUID_41E8AB15_DFC5_4BF7_89CE_CB500C9528D6_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_GUID_FD1E4079_E7E6_4C35_AD07_B096D59F8F40_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_NavScript.js3; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_GUID_AEB56342_BFCF_44A8_B2F5_893CD191B498_low.jpg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_GUID_C0FFAF0B_0D4A_4251_A7AE_62AA0F30294C.htm; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_GUID_62063871_C8E4_4C7C_A7B1_9085B8E15684_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_GUID_EB2F995D_1158_4DCF_833C_B98239EB35EB_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:909]: Component: Comp_GUID_D403605D_8D88_47E8_8654_3DF782D9C645_low.jpg0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_GUID_F046A0B2_8517_40BA_B39C_B5186178FB95_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_intel_css_styles.css4; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_GUID_EED2848B_A055_4D85_922B_388ADF02BF68.ditamap_htmlhelpzip.log; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_GUID_3F6712EA_1D07_4393_B92D_A6A3131DF882_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_GUID_9176BE3F_1543_407E_A29B_463401A95A75_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_GUID_85949B52_3ABE_4B0D_8B4B_BCAF60C404F3_low.jpg2; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_GUID_399AC448_BF89_49CF_8AA2_AEEE8F7DFB96_low.jpg1; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_GUID_092E2B62_7C81_410C_93F2_6690053138A2_low.jpg1; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_deltaend.gif1; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_GUID_8DCE8321_E14C_4106_AA5B_443DD8ED634E.htm; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_GUID_EED2848B_A055_4D85_922B_388ADF02BF68.hhp.bak; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_farinfo.ini1; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_GUID_6E9638D0_B8B7_4E8F_B036_7E6E53F93763_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_GUID_A766557E_C528_44AE_82BB_BBBA16D92BDA_low.jpg2; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_GUID_B7F2766C_B929_4469_9431_7BB94D2018F6_low.gif2; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_GUID_096902F5_789D_436E_9729_4E78841382B4_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_GUID_EED2848B_A055_4D85_922B_388ADF02BF68.ditamap_farhtml.log; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_GUID_745C541A_9795_4F6F_A286_31A5E42DEB99_low.gif2; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_GUID_C2A283F4_0493_4B1E_BC73_F67390AE6700_low.gif1; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_GUID_5CB499F4_0E43_4C28_B929_8E9221DBED98_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_GUID_0052F069_B894_4E81_BC2F_CA23757183B0_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_GUID_7078FBE1_DFA5_4BB4_AF82_9C9E48177E9C_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_GUID_5749422A_B37A_4FC0_9980_4B891EB19B67_low.gif1; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_GUID_EED2848B_A055_4D85_922B_388ADF02BF68.hhk.bak; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_delete_extra_files_for_final_release.bat2; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_GUID_FFA7F7D0_B380_4923_994B_52C02E616961_low.gif2; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_GUID_DC6C10DF_EED1_45FE_BAA4_472F704804FB_low.gif1; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_GUID_6D18F537_F3FE_403C_A999_D725F60364B1_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_GUID_EE5BF17B_1E53_4F46_B8EB_E5727F594DB3_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_GUID_EED2848B_A055_4D85_922B_388ADF02BF68_f.HxK; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_GUID_E632A67E_51CD_4676_B252_0F411DF5A068_low.gif1; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_GUID_6772A602_BE58_4DEE_AEAE_DC2F07B7FEDB_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_tree.css2; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_GUID_8685D1D9_BBCE_4076_A0EA_A6A094428599.htm; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_tree.js2; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_GUID_79674B4D_96FE_443B_8C10_45DC8C577C9A_low.gif2; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_hh_goto.htm2; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_searchdata.js1; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_GUID_DC9667D5_EF5E_46BD_8A62_BA4EC9D3A60B_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_delete_extra_files_during_beta.bat2; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_GUID_C65E00A6_6283_46D0_AE5E_99DBE68C9379_low.jpg2; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_GUID_B05591A8_44E8_43FD_B1B1_3B5DE2B4D143_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_dita.xml.properties0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_GUID_77A32896_822E_423C_95B9_1BAE6E18C085.htm; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_GUID_1FE62AEF_923B_4A07_BC15_2B0EC83C4D04.htm; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_GUID_625EEBC0_3861_4973_AC46_2BBB0F836C0D_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_GUID_B49594F1_C7F8_4E96_B56C_2FA2E3C4F393_low.jpg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_GUID_212D8A6B_4228_44B2_8579_43014A7D61F1_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_GUID_A0885539_B860_4715_BCB6_F287DA98BF03_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_GUID_9FED167B_0BA1_4F0C_9D3A_0760B6AC4E41_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_GUID_3C9AAC61_6C7E_4AF5_B081_CBB93B4E3F96_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_GUID_B2F2B2D9_F1E3_44F9_8919_50726722E1C3_low.jpg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_GUID_07DF2795_B43D_46D8_B20F_91F62563BFAB_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_GUID_667008D9_1F25_4B94_9573_A1D855E7D9FC.htm; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_GUID_A4AF9F6D_C2F3_4CC2_BC62_4EF73CA76B7B_low.jpg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_GUID_79674B4D_96FE_443B_8C10_45DC8C577C9A_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_GUID_2BE47F1D_210C_4313_AC3C_755EE4E6EBB0_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_GUID_78CA8A65_B8F9_4490_A5E5_627FF1CA8E4B_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_tip.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_langref_footer.html0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_ssgid_scripts.js; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_note.gif0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_intel_css_styles.css2; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_caution.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_note.jpg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_warning.gif2; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_Thumbs.db1; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_ndash.gif0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_bullet.gif1; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_mdash.gif2; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_NavScript.js4; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_warning.jpg2; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_tip.jpg2; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_caution.jpg1; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_GUID_FB99E6CF_E5AE_4C62_BC34_5330982D70A5_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_GUID_0D0FCB08_5E2E_4D5E_9F69_B382A981DF60_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_GUID_6FD7C99B_BEFB_4184_B30A_AC35EB34DAF0.htm; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_GUID_5845CBF1_4EFB_438B_B2C6_352CA7E26251_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_GUID_69C43A34_B0C5_48A6_8622_ED45A274FE43.htm; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_GUID_C65E00A6_6283_46D0_AE5E_99DBE68C9379_low.jpg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_perfhe.hhk; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_GUID_4692FAD2_1D7A_40D8_99F8_78A2FB960694_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_GUID_E632A67E_51CD_4676_B252_0F411DF5A068_low.gif0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_GUID_B7F2766C_B929_4469_9431_7BB94D2018F6_low.gif0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_GUID_E70F5B85_0C23_48DB_94ED_FA59A4787F32_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_GUID_F44D6AB4_899A_48DC_9F0A_59E9BE98748F.htm; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_GUID_CF8A1E58_DAA5_4671_A0C5_28ADF088A823_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_GUID_6AF52DD1_55A3_499A_B30E_CF3CB02038C9_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_GUID_4497C70A_867B_4ECA_AC78_BDA3DAD2658C_low.jpg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_searchdata.js; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_GUID_85E53F13_EDF7_4CFD_A532_FE2B14D4986C_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_GUID_D231F74D_4A67_4C76_B9B9_C1B762496616.htm; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_GUID_5F8E77B5_E951_4E8D_BE1F_5E5E06A8F036_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_tree.css0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_GUID_2751A2D0_7CC6_4F13_89E4_B65B3F05B3E0_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_GUID_F1538017_4FBE_4DA3_B2CD_DEB04B10F71D_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_GUID_4247844E_FB32_4AA0_B2D9_4D40972AC2B3_low.jpg0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_GUID_9840ACD1_DDDE_455F_875A_37A916028E61_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_GUID_E9306A17_2C65_46CD_BE42_D8D94D0E336E.htm; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_GUID_399AC448_BF89_49CF_8AA2_AEEE8F7DFB96_low.jpg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_GUID_745C541A_9795_4F6F_A286_31A5E42DEB99_low.gif1; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_GUID_1112953F_C6C7_4278_A09E_D9CF366386DB_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_GUID_46380B64_F6EA_4B13_9DE8_EFFC41BE5C0B_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_deltaend.gif0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_GUID_93FA9D3E_A8A5_46B8_957D_ABBBA62D5625_low.jpg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_GUID_85A1D0A8_2F99_4E40_94C6_7B385A95853F_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_GUID_D8DBA40B_558C_4899_B9B6_9068F1CAE124_low.jpg0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_GUID_5A0AFC44_F34C_4AE0_A245_3CC0DED4945A_low.jpg1; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_GUID_742F5949_4A88_4170_9A20_425DD0CFB029.htm; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_hh_search.htm0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_GUID_5749422A_B37A_4FC0_9980_4B891EB19B67_low.gif0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.005] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_GUID_B245A744_74DE_484F_8F8B_F02E4797E4F8.htm; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_GUID_14570859_4183_4343_8FDE_A86EA692BA2B_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_GUID_092E2B62_7C81_410C_93F2_6690053138A2_low.jpg0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_perfhe.hhc0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_GUID_5CC0DF13_808D_43AD_A1C7_1690ECC4DC83.htm; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_GUID_10C90511_7C3C_401B_8467_B7B4B894FD2B_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_GUID_B0B309D2_B1F5_48A3_A623_5A5EE8418B70_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_NavScriptFarhelp_bat.FarRun0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_GUID_C2A283F4_0493_4B1E_BC73_F67390AE6700_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_delta.gif2; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_GUID_29E0EADE_D0EC_4C35_AECA_D93936C3C938.htm; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_GUID_4723F703_BADE_4EF2_841F_367ED7E9A322_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_GUID_D9203FC0_7C95_40E0_A607_DD8C2FAC4A87_low.jpg0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_GUID_105FA066_A743_4D7F_B4AA_1A459B0EDC8F_low.gif0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_GUID_4A9CB0E1_5211_4E55_B5EB_2F7FCCC587A7_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_intel_css_styles.css3; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_GUID_86EC8D37_20DF_4834_8B0E_A1539C56369B.htm; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_GUID_0AA879EE_948D_4B45_945E_4FD3C7EF779E_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_GUID_65530C48_A321_4C61_B8D7_9A7D4857F133_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_GUID_67E3D14B_CCE5_4BEC_9164_E1B3AB1ED5B9_low.jpg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:910]: Component: Comp_GUID_762B7E6A_21BB_4D43_8732_5DC7C4649308_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_GUID_A894E299_C7E2_4635_AD52_D98A09736EC8_low.jpg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_GUID_35EF0556_6BEE_41C7_ABBA_C008F1CF37CA_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_GUID_632287F8_67A2_4193_A82B_ABDF8230141E_low.jpg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_perfhe.hhp0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_GUID_AF2EBA99_3EFC_422A_AEBB_63919EB0030E_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_GUID_BED7B911_9D39_45D9_9367_313A2CB3E52B_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_GUID_2F57C095_01DE_42F4_8F97_32071A852A65_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_GUID_A766557E_C528_44AE_82BB_BBBA16D92BDA_low.jpg0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_GUID_85949B52_3ABE_4B0D_8B4B_BCAF60C404F3_low.jpg1; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_hh_goto.htm0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_GUID_851F4013_CD54_45BF_9047_C863A15CF6E2_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_GUID_31DC6898_D80F_433A_9389_32BD52D91F76_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_GUID_E5AA8F29_E660_410C_B68A_EDC9F01FF2FA_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_index.htm1; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_GUID_31A20E55_3123_4706_B320_131A8C7D4416.htm; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_GUID_7AFDA3A0_486B_4130_B3FA_C02257DD0AA9_low.gif2; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_GUID_10C09562_1DF1_43C2_9BD4_7DE82E93ED1C_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_GUID_4E0F6345_0DDA_4673_A244_B1FA09EA4621_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_GUID_FFA7F7D0_B380_4923_994B_52C02E616961_low.gif0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_tree.js1; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_GUID_A5C4B865_9FE6_4B8D_8017_6F7D0C797CE0.ditamap_farhtml.log; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_GUID_4D92412B_924C_4DD6_83A5_3365D46BD192_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_GUID_E6360B33_7073_4F39_B416_A937EC9CDE19_low.jpg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_GUID_CAD7F7D2_9498_4BE7_B532_E999936502A5_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_GUID_D403605D_8D88_47E8_8654_3DF782D9C645_low.jpg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_GUID_BCE1DA0A_3ADC_404C_8BFD_1B3F8B67D64A_low.jpg1; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_GUID_C3B0CEEA_BF4E_40D2_A0A2_FC44CC2FE142_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_GUID_10EA24BF_1983_4508_B582_53109344C170_low.gif0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_delete_extra_files_for_final_release.bat1; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_GUID_14241E67_AD91_440D_996D_95A116A590F4_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_delete_extra_files_during_beta.bat1; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_GUID_D97809EA_D0C0_4C92_8E0A_D7B2A0292113_low.jpg1; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_GUID_DA1A1419_2D2F_4716_9298_995FE7075BD6_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_GUID_D56343F9_2E2A_476D_A4A7_07BAD2C58D14.htm; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_perfhe_f.HxK3; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_GUID_BD79EE38_F6E2_4314_8A83_D55AAD25581A_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_GUID_96C7A16F_D7BF_4963_A9ED_9CB10C2CC574_low.jpg2; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_GUID_8DF87690_C9D0_464E_852B_C839266C97C7.htm; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_NavScript.js5; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_GUID_08AABA1E_7FDD_4ACF_8B4E_FA82F6AE7773_low.gif2; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_GUID_DC6C10DF_EED1_45FE_BAA4_472F704804FB_low.gif0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_GUID_849A01B7_A66C_4AE0_8050_9B361B44D192_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_GUID_94B47697_14BF_4560_99DF_DB65917F39C3_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_GUID_4F3A6FFE_1A72_4369_98B4_16C048656912_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_GUID_7D54EDB6_3C73_4457_9A7A_261C3B84A1EF_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_GUID_78C62327_78E4_436A_8F51_84137223D9B5_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_GUID_9D71AD3E_BCCE_41DA_BE6E_E1DA8673AE57_low.jpg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_GUID_A41EFB53_22BA_4C1E_8F3F_EB18F05576FA_low.png0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_GUID_EC89F6F7_1D37_4D59_82B5_710853E15391_low.jpg2; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_GUID_84F1DF41_A562_47ED_8407_DBAF5ABF0FE5_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_GUID_A79196FB_3D5A_45B6_B4AC_329A61B09D31_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_treenodeplus.gif2; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_GUID_10E76965_CBA4_43A9_B0F6_F438EA885E59.htm; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_GUID_97DA5C0B_0525_4917_B0BF_F4CB59D9DDC8_low.jpg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_GUID_ECE7B5D8_D281_4F4D_88F4_CF06675835C6_low.jpg1; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_GUID_4C1A118B_F15A_472A_9A39_D6657B484D62.htm; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_GUID_A9FD6107_90BA_4D4E_BB95_5167B3BEC4BD_low.jpg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_GUID_53964F5F_1E8B_4ACB_8D15_4878079C1FF9_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_GUID_032FF274_E9D2_4592_A731_7086F4C346DF_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_GUID_9E308975_E41D_4B2B_BC12_4BE63D942550_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_hh_toc.htm2; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_GUID_07FD9196_5812_4587_9DD0_1118FFADCD32_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_GUID_00266A69_9256_4CF5_BC51_D02DD956DDF1.htm; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_GUID_1EB22153_F0EF_4A29_9629_70B6FDAA897E.htm; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_GUID_5BA24D82_9B9D_438B_B476_A5A50E83367E_low.jpg2; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_GUID_0AEDFCF7_9B9A_4465_AA1D_8EAFA28FEE7C_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_farinfo.ini2; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_treenodeminus.gif1; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_GUID_8849AB21_3344_4BC5_BDF1_C03D1530E331_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_GUID_C733787D_776B_4CA9_9AC3_F38FC04DE5C6_low.jpg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_GUID_0EDA1A3F_30A6_4035_80F2_A115DDE4953E_low.jpg2; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_GUID_DFE22DB3_00C0_48F5_B382_9756665C18A0_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_GUID_91523C99_E189_4B7C_A23E_1B07F37B3DF4_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_GUID_6F7D686F_671E_4420_99DB_B79F1F0973AC_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_GUID_02914B5D_1A7D_4B4B_8A24_9534BDA714E4_low.gif2; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_treenodedot.gif2; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_GUID_EE33387F_F561_4157_BC05_1D4D841249CF_low.gif0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_farhelp_bat_log.txt2; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_search.js2; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_GUID_E1CF4EE8_7CCA_4F5B_B13E_F254C5ADEEFD_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_GUID_379CC698_B3D0_454F_B78C_DC5B4E22B37D_low.jpg2; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_GUID_1E747194_E559_4349_A580_E03D4570A867_low.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_index.htm; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_documentation_amplifier.htm; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_browser_not_found.htm; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_release_notes_amplifier_xe_windows.pdf; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_EULA.txt; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_EULA.rtf; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_ampl_big_picture_windows.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_ampl_toolbar_start.gif; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp__1.gif; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp__3.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_ampl_big_picture_windows.gif0; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_ampl_toolbar_start.gif0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp__1.gif0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_intel_logo.gif; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_ampl_icon.gif; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_psxe_group.jpg; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_ampl_start_menu.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp__2.gif; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_intel_logo.gif0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_ampl_icon.gif0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp__2.gif0; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_win8all_apps.gif; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp__3.gif0; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_get_started.html; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_get_started.html0; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_helpcontentsetup.msha; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_perfhe.cab; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_jitprofiling_vtune_amp_xe.zip; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_tachyon_vtune_amp_xe.zip; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_matrix_vtune_amp_xe.zip; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_parallel_nqueens_csharp.zip; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_serial_nqueens_csharp.zip; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_nqueens_fortran.zip; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_support.txt; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_cfgmgr2.xmc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_rdmgr2.xmc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_tpplug2.xmc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_core.xmc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_callstack.xmc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_pin.xmc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_perfcli.xmc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_reporter.xmc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_hardware_tuning_queries.xmc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_backward_compatibility_ql_messages.xmc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:911]: Component: Comp_query_library.xmc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_viewpoint.xmc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_analysis_type.xmc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_workflow.xmc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_collector.xmc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_target.xmc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_default.xmc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_mrtehelpers2.mrteenv.xmc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_mrtehelpers2.attach.xmc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_msngr.cmd.xmc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_file_finder.climgr.xmc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_cctrl2.climgr.xmc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_cctrl2.core.xmc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_cctrl2.at.xmc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_dpihelpers.xmc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_dicerresolver2.xmc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_climgr.xmc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_core.xmc0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_core.knobs.xmc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_colorblind.xmc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_default.xmc0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_dicerhelpers.xmc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_sep_msg_catalog.xmc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_tpss.collector.xmc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_perfrun1.etw.xmc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_perfrun1.power.xmc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_perfrun1.sep.xmc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_perfrun1.tpss.xmc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_perfrun1.itt.xmc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_perfrun1.vtsspp.xmc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_perfrun1.gpu.xmc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_perfrun1.launcher.xmc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_tpssplug.xmc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_qfagent.feedback.xmc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_ivbm.xmc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_snb_general_exploration.cfg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_tasks.cfg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp__1_pmu_samples.cfg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_hotspots_cpu_usage.cfg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_power_sleep.cfg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp__0_pmu_events.cfg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_power_sleep_extended.cfg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_power_frequency.cfg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_hotspots.cfg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_lightweight_hotspots.cfg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_snb_bandwidth.cfg0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_hotspots_thread_concurrency.cfg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_locksandwaits.cfg0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_hotspots_counters.cfg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_locksandwaits_counters.cfg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_atom_general_exploration.cfg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_wsmex_bandwidth.cfg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_hw_issues.cfg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_qpi_bandwidth.cfg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_stackpane.cfg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_filterbar.cfg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_timeline.xsl; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_summarypane.cfg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_frame_data_queries.cfg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_cpu_data_queries.cfg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_uncore_data_queries.cfg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_result_info_queries.cfg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_gen_metrics.cfg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_hardware_tuning_queries.cfg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_pmu_data_queries.cfg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_wait_data_queries.cfg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_task_data_queries.cfg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.006] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_uncore_metrics.cfg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_query_library.cfg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_pmu_metrics.cfg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_power_data_queries.cfg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_sched_data_queries.cfg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_counter_data_queries.cfg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_grouping_data_queries.cfg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_runsa.cfg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_runsa_knc.cfg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_runss.cfg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_core2_uop_flow.cfg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_concurrency.cfg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_cpu_frequency.cfg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_corei7_client_analysis.cfg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_snb_branch_analysis.cfg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_snb_access_contention.cfg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_snb_cycles_and_uops.cfg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_snb_bandwidth.cfg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_core2_bandwidth.cfg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_locksandwaits.cfg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_snb_loop_analysis.cfg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_corei7_cycles_uops.cfg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp__.workflow; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_core2_bandwidth_breakdown.cfg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_cpu_sleep_states.cfg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_snb_core_port_saturation.cfg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_core2_cycle_usage.cfg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_hotspots.cfg0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_corei7_memory_access.cfg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_snb_client.cfg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_core2_latency_analysis.cfg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_snb_general_exploration.cfg0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_knc_lightweight_hotspots.cfg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_wsmex_read_bandwidth.cfg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_snb_port_saturation.cfg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_wsmex_write_bandwidth.cfg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_corei7_frontend_investigation.cfg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_atom_general_exploration.cfg0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_lightweight_hotspots.cfg0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_snb_memory_access.cfg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_wait_time.tmpl; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_hw_events.tmpl; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_top_down.tmpl; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_sleep_extended_analysis.tmpl; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_summary.tmpl; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_gprof_cc.tmpl; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_frequency_analysis.tmpl; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_hotspots.tmpl; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_callstacks.tmpl; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_sleep_analysis.tmpl; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_launch.cfg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_system.cfg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_attach.cfg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_ui_color_definition.xml; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_sqlite_caches.cfg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_mrte.cfg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_tpss.cfg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_opencl.cfg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_ct.cfg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_default.cfg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_mpi.cfg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_tbb.cfg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_resolver.cfg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_concurrency.cfg0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_concurrency_deprecated.cfg0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_concurrency.cfg1; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_concurrency_deprecated.cfg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_finalization.cfg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_threshold_knob.rng; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_knobs.cfg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_finalization.rng; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_amplxe_tbbmalloc.dll0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_amplxe_tbb.dll0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_amplxe_userapihelpers_1.0.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_symsrv.yes0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_amplxe_symsrv.dll0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_amplxe_dbghelp.dll0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_Microsoft.VC90.CRT.manifest0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_msvcr90.dll0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_msvcp90.dll0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:912]: Component: Comp_amplxe_cpil_2.14.dll0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_amplxe_libxml_2.7.dll0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_amplxe_libxslt_1.1.dll0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_amplxe_msdia100.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_amplxe_cfgmgr_2.11.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_amplxe_clpt_3.4.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_amplxe_rdmgr_2.10.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_amplxe_dbiproviders_1.0.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_amplxe_dicer2_plugin_tp_2.2.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_ittnotify_sampling.dll0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_libittnotify.dll0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_VtuneApi.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_javaattach.jar0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_tpsstool.pdb; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_ittnotify_collector.dll0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_amplxe_tpssmrte_javaprof_1.0.dll0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_amplxe_samplingmrte_javaprof_1.0.dll0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_vsdbg.dll0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_pin.exe0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_pinvm.dll0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_dbghelp.dll0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_FNP_Act_Installer.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_amplxe_boost_filesystem_1.47.dll0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_amplxe_boost_filesystem3_1.47.dll0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_amplxe_boost_date_time_1.47.dll0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_amplxe_boost_regex_1.47.dll0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_amplxe_boost_thread_1.47.dll0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_amplxe_boost_iostreams_1.47.dll0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_amplxe_boost_python_shared_1.47.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_amplxe_boost_system_1.47.dll0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_amplxe_gen_helpers_core_2.6.dll0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_amplxe_gen_helpers_das_2.6.dll0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_amplxe_gen_helpers_adn_2.6.dll0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_amplxe_martini_osa_2.0.dll0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_amplxe_martini_cie_2.0.dll0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_amplxe_mrtehelpers_clrattach_2.1.exe0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_amplxe_mrtesym_jitreader_3.3.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_amplxe_mrtesym_clrsigparser_3.3.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_amplxe_msngr_cmd_2.7.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_amplxe_msngr_reader_2.7.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_amplxe_msngr_util_2.7.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_amplxe_python_core_2.5.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_amplxe_file_finder_core_2.13.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_amplxe_file_finder_symbol_file_resolver_2.13.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_amplxe_file_finder_binary_validators_2.13.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_amplxe_file_finder_symsrv_helper_2.13.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_amplxe_file_finder_climgr_2.13.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_amplxe_ism_core_3.18.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_amplxe_ism_demangler_3.18.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_amplxe_ism_cfa_3.18.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_amplxe_smip_core_3.3.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_amplxe_smip_mrtewrapper_3.3.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_amplxe_smip_ismwrapper_3.3.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_amplxe_smip_mic2_plugin_3.3.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_amplxe_smip_plugin_3.3.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_amplxe_cctrl_core_2.25.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_amplxe_cctrl_at_2.25.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_amplxe_cctrl_climgr_2.25.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_amplxe_dataproviderinterface_core_1.4.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_amplxe_dpihelpers_1.2.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_amplxe_dicer_2.5.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_dicer_transform_helper2.exe; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_amplxe_dicer_python_2_5.pyd; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_amplxe_dbinterface_core_1.11.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_amplxe_dbinterface_sqlite_1.11.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_amplxe_dbinterface_dicer_1.11.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_amplxe_dicerresolver_core_2.1.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_amplxe_dicerresolver_impl_2.1.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_amplxe_dicerengine_climgr_2.12.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_amplxe_dicerengine_core_2.12.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_amplxe_dicerengine_python_2_12.pyd; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_amplxe_dicerhelpers_data_provider_1.4.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_amplxe_dicerhelpers_python1.pyd; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_amplxe_timelinedataprovider_core_1.4.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_amplxe_pythonhelpers_genhelpers_1_7.pyd; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_amplxe_dvt_core_6.2.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_amplxe_dvt_python6.pyd; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_amplxe_featurestat_core_1.0.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_amplxe_sampling_strings_3.8.dll0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_amplxe_sampling_logit_3.8.dll0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_amplxe_sampling_utils_3.8.dll0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_amplxe_sampling_rise_3.8.dll0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_c_osi.dll0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_amplxe_sampling_pise_3.8.dll0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_amplxe_sampling_tbrw_3.8.dll0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_abstract.dll0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_amplxe_sampling_smrk_3.8.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_amplxe_sampling_sera_3.8.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_platform_picker.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_amplxe_sampling_pax_3.8.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_atom.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_atom_db.txt; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_core_db.txt; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_core.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_core2_db.txt; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_core2.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_core2p.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_corei7_db.txt; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_corei7.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_corei7wsp_db.txt; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_corei7wsp.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_corei7wdp_db.txt; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_corei7wdp.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_corei7b.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_corei7b_db.txt; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_snb.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_snb_db.txt; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_snbep.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_snbep_db.txt; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_pentiumm.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_pentiumm_db.txt; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_corei7_unc.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_corei7_unc_db.txt; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_corei7jf_unc.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_corei7jf_unc_db.txt; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_snbunc_cbo_db.txt; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_snbunc_cbo.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_snbunc_imc.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_snbunc_imc_db.txt; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_wsmexunc_imc_db.txt; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_wsmexunc_imc.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_wsmexunc_qpi_db.txt; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_wsmexunc_qpi.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_wsmexunc_wbox_db.txt; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_wsmexunc_wbox.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_ivybridge_db.txt; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_ivybridge.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_jktunc_imc.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_jktunc_imc_db.txt; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_jktunc_qpill_db.txt; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_jktunc_qpill.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_snb_power_db.txt; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_snb_power.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_amplxe_sampling_mrte_3.8.dll0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_amplxe_sampling_user_api_3.8.dll0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_amplxe_sampling_parser_3.8.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_sepdrv3_8.sys1; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_sepdal.sys2; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_sepdal.sys1; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:913]: Component: Comp_sepdrv3_8.sys2; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:914]: Component: Comp_vtss.sys0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:914]: Component: Comp_sep_modules.exe0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:914]: Component: Comp_amplxe_sepreg.exe; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:914]: Component: Comp_amplxe_tpss_rw_api_1.12.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:914]: Component: Comp_tpsstool.dll0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.007] | MSI (c) (B0:9C) [13:54:54:914]: Component: Comp_amplxe_stackwalk_image_1.2.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: Comp_amplxe_stackwalk_plugin_knc_1.2.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: Comp_amplxe_stackwalk_plugin_default_1.2.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: Comp_amplxe_stackwalk_factory_1.2.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: Comp_amplxe_tpssmrte_clrprof_1.0.dll0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: Comp_amplxe_samplingmrte_clrprof_1.0.dll0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: Comp__sqlite3.pyd; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: Comp_amplxe_runss.exe; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: Comp_amplxe_dicer2_plugin_tpss_2.6.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: Comp_amplxe_dicer2_plugin_sep_3.3.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: Comp_amplxe_qfagent_log_1.10.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: Comp_amplxe_qfagent_qfagent_1.10.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: Comp_amplxe_feedback.exe; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: Comp_amplxe_qfagent_minidump_1.10.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: Comp_amplxe_qfagent_assert_1.10.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: Comp_amplxe_cl.exe; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: Comp_amplxe_reporter_climgr_2.6.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: Comp_amplxe_reporter_core_2.6.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: Comp_amplxe_reporter_dicer_2.6.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: Comp_amplxe_reporter_python_2_6.pyd; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: Comp_amplxe_ivbm_lmapi_2.5.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: Comp_amplxe_ivbm_core_2.5_libFNP.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: Comp_amplxe_ivbm_core_2.5.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: Comp_amplxe_vsreg.exe; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: Comp_amplxe_mrtereg.exe; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: Comp_tpssmrte_clrwrap_1.0.dll2; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: Comp_tpssmrte_clr35sp1wrap_1.0.dll2; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: Comp_tpssmrte_clr40wrap_1.0.dll0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: Comp_amplxe_vars.bat; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: Comp_common.pyc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: Comp___init__.pyc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: Comp_sitelib.zip; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: Comp_grid_handler.pyc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: Comp___init__.pyc0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: Comp_queries.pyc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: Comp_util.pyc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: Comp_instance.pyc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: Comp_env.pyc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: Comp_tables.pyc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: Comp_qlibrary.pyc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: Comp___init__.pyc1; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: Comp_genhelpers.pyc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: Comp___init__.pyc2; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: Comp_provider.pyc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: Comp___init__.pyc3; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: Comp_transactions.pyc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: Comp_types.pyc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: Comp___init__.pyc4; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: Comp_userfunctions.pyc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: Comp_hooks.pyc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: Comp_regression.pyc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: Comp_dbapi.pyc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: Comp_factory.pyc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: Comp___init__.pyc5; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: Comp_dbapi2.pyc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: Comp_reporter.pyc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: Comp___init__.pyc6; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: Comp_wrapper.pyc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: Comp_output.pyc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: Comp_jitprofiling.lib0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: Comp_libittnotify.lib0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: Comp_user_metrics.zip; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: Comp_LICENSE.GPL; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: Comp_ittnotify_static.h; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: Comp_jitprofiling.c; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: Comp_ittnotify_config.h; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: Comp_ittnotify_types.h; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: Comp_disable_warnings.h; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: Comp_LICENSE.BSD; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: Comp_ittnotify_static.c; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: Comp_client.dat; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: Comp_qfagent1.dat; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: Comp_vs11_integration.msi; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: Comp_vs2008_integration.msi; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: Comp_vs2010_integration.msi; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: Comp_vs2005_integration.msi; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: Comp_msvcrt_x86.msi; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: Comp_ittnotify.h; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: Comp_libittnotify.h; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: Comp_llvm_jit_event_listener.hpp; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: Comp_ittnotify.h0; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: Comp_jitprofiling.h; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: ism.6CE6DF50_ACB9_4BD7_8CFF_FD23CF90CE42; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: ipsxevars.cmd.A6B9614E_3208_40D1_9317_66B6C7C34FC5; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: no_vs.A6B9614E_3208_40D1_9317_66B6C7C34FC5; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: ia32_vs2008.A6B9614E_3208_40D1_9317_66B6C7C34FC5; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: intel64_vs2008.A6B9614E_3208_40D1_9317_66B6C7C34FC5; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: ia32_vs2010.A6B9614E_3208_40D1_9317_66B6C7C34FC5; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: intel64_vs2010.A6B9614E_3208_40D1_9317_66B6C7C34FC5; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: ia32_vs2011.A6B9614E_3208_40D1_9317_66B6C7C34FC5; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: intel64_vs2011.A6B9614E_3208_40D1_9317_66B6C7C34FC5; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: __Comp_tpssmrte_clrwrap_1.0.dll65; Installed: Null;   Request: Local;   Action: Local;   Client State: Null
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: __Comp_tpssmrte_clr35sp1wrap_1.0.dll65; Installed: Null;   Request: Local;   Action: Local;   Client State: Null
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: __mrte_assembly6465; Installed: Null;   Request: Local;   Action: Local;   Client State: Null
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: __Comp_tpssmrte_clrwrap_1.0.dll065; Installed: Null;   Request: Local;   Action: Local;   Client State: Null
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: __Comp_tpssmrte_clr35sp1wrap_1.0.dll065; Installed: Null;   Request: Local;   Action: Local;   Client State: Null
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: __mrte_assembly3265; Installed: Null;   Request: Local;   Action: Local;   Client State: Null
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: __CompLinks65; Installed: Null;   Request: Local;   Action: Local;   Client State: Null
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: __CompLinks66; Installed: Null;   Request: Local;   Action: Local;   Client State: Null
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: __CompLinks67; Installed: Null;   Request: Local;   Action: Local;   Client State: Null
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: __CompLinks68; Installed: Null;   Request: Local;   Action: Local;   Client State: Null
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: __CompLinksWin865; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: __CompLinksWin866; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: __CompLinksWin867; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: __CompLinksWin868; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: __no_vs.A6B9614E_3208_40D1_9317_66B6C7C34FC565; Installed: Null;   Request: Local;   Action: Local;   Client State: Null
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: __ia32_vs2008.A6B9614E_3208_40D1_9317_66B6C7C34FC565; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: __ia32_vs2008.A6B9614E_3208_40D1_9317_66B6C7C34FC566; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: __intel64_vs2008.A6B9614E_3208_40D1_9317_66B6C7C34FC565; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: __intel64_vs2008.A6B9614E_3208_40D1_9317_66B6C7C34FC566; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: __ia32_vs2010.A6B9614E_3208_40D1_9317_66B6C7C34FC565; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: __ia32_vs2010.A6B9614E_3208_40D1_9317_66B6C7C34FC566; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: __intel64_vs2010.A6B9614E_3208_40D1_9317_66B6C7C34FC565; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: __intel64_vs2010.A6B9614E_3208_40D1_9317_66B6C7C34FC566; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: __ia32_vs2011.A6B9614E_3208_40D1_9317_66B6C7C34FC565; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: __ia32_vs2011.A6B9614E_3208_40D1_9317_66B6C7C34FC566; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: __intel64_vs2011.A6B9614E_3208_40D1_9317_66B6C7C34FC565; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: __intel64_vs2011.A6B9614E_3208_40D1_9317_66B6C7C34FC566; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: __CompLinks69; Installed: Null;   Request: Local;   Action: Local;   Client State: Null
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: __CompLinksWin869; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: __ism.6CE6DF50_ACB9_4BD7_8CFF_FD23CF90CE4265; Installed: Null;   Request: Local;   Action: Local;   Client State: Null
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: __no_vs.A6B9614E_3208_40D1_9317_66B6C7C34FC566; Installed: Null;   Request: Local;   Action: Local;   Client State: Null
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: __ia32_vs2008.A6B9614E_3208_40D1_9317_66B6C7C34FC567; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: __intel64_vs2008.A6B9614E_3208_40D1_9317_66B6C7C34FC567; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: __ia32_vs2010.A6B9614E_3208_40D1_9317_66B6C7C34FC567; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: __intel64_vs2010.A6B9614E_3208_40D1_9317_66B6C7C34FC567; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: __ia32_vs2011.A6B9614E_3208_40D1_9317_66B6C7C34FC567; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Component: __intel64_vs2011.A6B9614E_3208_40D1_9317_66B6C7C34FC567; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Note: 1: 2205 2:  3: BindImage
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Note: 1: 2205 2:  3: ProgId
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Note: 1: 2205 2:  3: PublishComponent
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Note: 1: 2205 2:  3: Extension
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:914]: Note: 1: 2205 2:  3: Font
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:915]: Note: 1: 2205 2:  3: Class
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:915]: Note: 1: 2205 2:  3: TypeLib
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:915]: Note: 1: 2205 2:  3: _RemoveFilePath
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:982]: PROPERTY CHANGE: Modifying CostingComplete property. Its current value is '0'. Its new value: '1'.
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:982]: Note: 1: 2205 2:  3: BindImage
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:982]: Note: 1: 2205 2:  3: ProgId
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:982]: Note: 1: 2205 2:  3: PublishComponent
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:982]: Note: 1: 2205 2:  3: Extension
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:982]: Note: 1: 2205 2:  3: Font
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:982]: Note: 1: 2205 2:  3: Class
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:982]: Note: 1: 2205 2:  3: TypeLib
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:982]: Note: 1: 2727 2:
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:997]: Note: 1: 2727 2:
MSI(i) [13:54:55.008] | Action ended 13:54:54: InstallValidate. Return value 1.
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:997]: Creating MSIHANDLE (19) of type 790541 for thread 3996
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:997]: Creating MSIHANDLE (20) of type 790540 for thread 3996
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:997]: Creating MSIHANDLE (21) of type 790531 for thread 3996
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:997]: Creating MSIHANDLE (22) of type 790540 for thread 3996
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:997]: Creating MSIHANDLE (23) of type 790531 for thread 3996
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:997]: Closing MSIHANDLE (23) of type 790531 for thread 3996
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:997]: Creating MSIHANDLE (24) of type 790540 for thread 3996
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:997]: Closing MSIHANDLE (24) of type 790540 for thread 3996
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:997]: Closing MSIHANDLE (22) of type 790540 for thread 3996
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:997]: Closing MSIHANDLE (21) of type 790531 for thread 3996
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:997]: Creating MSIHANDLE (25) of type 790531 for thread 3996
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:997]: Creating MSIHANDLE (26) of type 790540 for thread 3996
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:997]: Creating MSIHANDLE (27) of type 790540 for thread 3996
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:997]: Closing MSIHANDLE (27) of type 790540 for thread 3996
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:997]: Closing MSIHANDLE (26) of type 790540 for thread 3996
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:997]: Closing MSIHANDLE (25) of type 790531 for thread 3996
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:997]: Creating MSIHANDLE (28) of type 790531 for thread 3996
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:997]: Creating MSIHANDLE (29) of type 790540 for thread 3996
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:998]: Creating MSIHANDLE (30) of type 790540 for thread 3996
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:998]: Closing MSIHANDLE (30) of type 790540 for thread 3996
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:998]: Closing MSIHANDLE (29) of type 790540 for thread 3996
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:998]: Closing MSIHANDLE (28) of type 790531 for thread 3996
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:998]: Closing MSIHANDLE (20) of type 790540 for thread 3996
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:54:998]: Closing MSIHANDLE (19) of type 790541 for thread 3996
MSI(i) [13:54:55.008] | MSI (c) (B0:9C) [13:54:55:000]: Leaked MSIHANDLE (17) of type 790537 for thread 3996
MSI(i) [13:54:55.008] | === Verbose logging stopped: 4/8/2014  13:54:55 ===
PSET(i) [13:54:55.017] | (4225.1904): Dependency {ACD97E2A-090D-46ea-9983-6E44BCA28575} always show dialog
PSET(i) [13:54:55.018] | (4225.2963): MsiOpenPackageEx(C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\ps_he_gui\ps_he_gui.msi)
MSI(i) [13:54:55.084] | === Verbose logging started: 4/8/2014  13:54:55  Build type: SHIP UNICODE 5.00.7601.00  Calling process: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\setup.exe ===
MSI(i) [13:54:55.084] | MSI (c) (B0:9C) [13:54:55:019]: SOFTWARE RESTRICTION POLICY: Verifying package --> 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\ps_he_gui\ps_he_gui.msi' against software restriction policy
MSI(i) [13:54:55.084] | MSI (c) (B0:9C) [13:54:55:019]: SOFTWARE RESTRICTION POLICY: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\ps_he_gui\ps_he_gui.msi has a digital signature
MSI(i) [13:54:55.084] | MSI (c) (B0:9C) [13:54:55:063]: SOFTWARE RESTRICTION POLICY: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\ps_he_gui\ps_he_gui.msi is permitted to run at the 'unrestricted' authorization level.
MSI(i) [13:54:55.084] | MSI (c) (B0:9C) [13:54:55:064]: Cloaking enabled.
MSI(i) [13:54:55.084] | MSI (c) (B0:9C) [13:54:55:064]: Attempting to enable all disabled privileges before calling Install on Server
MSI(i) [13:54:55.084] | MSI (c) (B0:9C) [13:54:55:064]: End dialog not enabled
MSI(i) [13:54:55.084] | MSI (c) (B0:9C) [13:54:55:064]: Original package ==> C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\ps_he_gui\ps_he_gui.msi
MSI(i) [13:54:55.084] | MSI (c) (B0:9C) [13:54:55:064]: Package we're running from ==> C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\ps_he_gui\ps_he_gui.msi
MSI(i) [13:54:55.084] | MSI (c) (B0:9C) [13:54:55:066]: APPCOMPAT: Compatibility mode property overrides found.
MSI(i) [13:54:55.084] | MSI (c) (B0:9C) [13:54:55:066]: APPCOMPAT: looking for appcompat database entry with ProductCode '{21E9939C-DAEB-4ACB-9B5B-42A32EC12538}'.
MSI(i) [13:54:55.084] | MSI (c) (B0:9C) [13:54:55:066]: APPCOMPAT: no matching ProductCode found in database.
MSI(i) [13:54:55.084] | MSI (c) (B0:9C) [13:54:55:070]: MSCOREE not loaded loading copy from system32
MSI(i) [13:54:55.084] | MSI (c) (B0:9C) [13:54:55:074]: Machine policy value 'TransformsSecure' is 0
MSI(i) [13:54:55.084] | MSI (c) (B0:9C) [13:54:55:074]: User policy value 'TransformsAtSource' is 0
MSI(i) [13:54:55.084] | MSI (c) (B0:9C) [13:54:55:074]: Machine policy value 'DisablePatch' is 0
MSI(i) [13:54:55.084] | MSI (c) (B0:9C) [13:54:55:074]: Machine policy value 'AllowLockdownPatch' is 0
MSI(i) [13:54:55.084] | MSI (c) (B0:9C) [13:54:55:074]: Machine policy value 'DisableLUAPatching' is 0
MSI(i) [13:54:55.084] | MSI (c) (B0:9C) [13:54:55:074]: Machine policy value 'DisableFlyWeightPatching' is 0
MSI(i) [13:54:55.084] | MSI (c) (B0:9C) [13:54:55:074]: Enabling baseline caching for this transaction since all active patches are MSI 3.0 style MSPs or at least one MSI 3.0 minor update patch is active
MSI(i) [13:54:55.084] | MSI (c) (B0:9C) [13:54:55:075]: APPCOMPAT: looking for appcompat database entry with ProductCode '{21E9939C-DAEB-4ACB-9B5B-42A32EC12538}'.
MSI(i) [13:54:55.084] | MSI (c) (B0:9C) [13:54:55:075]: APPCOMPAT: no matching ProductCode found in database.
MSI(i) [13:54:55.084] | MSI (c) (B0:9C) [13:54:55:075]: Transforms are not secure.
MSI(i) [13:54:55.084] | MSI (c) (B0:9C) [13:54:55:075]: PROPERTY CHANGE: Adding MsiLogFileLocation property. Its value is 'C:\Users\PCCA-PM\AppData\Local\Temp\MSIED31.tmp'.
MSI(i) [13:54:55.084] | MSI (c) (B0:9C) [13:54:55:075]: No Command Line.
MSI(i) [13:54:55.084] | MSI (c) (B0:9C) [13:54:55:075]: PROPERTY CHANGE: Adding PackageCode property. Its value is '{DCD79D68-BBEE-4BFA-86C0-B9E2C4A6EB22}'.
MSI(i) [13:54:55.084] | MSI (c) (B0:9C) [13:54:55:075]: Product Code passed to Engine.Initialize:           '(none)'
MSI(i) [13:54:55.084] | MSI (c) (B0:9C) [13:54:55:075]: Product Code from property table before transforms: '{21E9939C-DAEB-4ACB-9B5B-42A32EC12538}'
MSI(i) [13:54:55.084] | MSI (c) (B0:9C) [13:54:55:075]: Product Code from property table after transforms:  '{21E9939C-DAEB-4ACB-9B5B-42A32EC12538}'
MSI(i) [13:54:55.084] | MSI (c) (B0:9C) [13:54:55:075]: Product not registered: beginning first-time install
MSI(i) [13:54:55.084] | MSI (c) (B0:9C) [13:54:55:075]: PROPERTY CHANGE: Adding ProductState property. Its value is '-1'.
MSI(i) [13:54:55.084] | MSI (c) (B0:9C) [13:54:55:075]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer 3: 2
MSI(i) [13:54:55.084] | MSI (c) (B0:9C) [13:54:55:075]: Entering CMsiConfigurationManager::SetLastUsedSource.
MSI(i) [13:54:55.084] | MSI (c) (B0:9C) [13:54:55:075]: User policy value 'SearchOrder' is 'nmu'
MSI(i) [13:54:55.084] | MSI (c) (B0:9C) [13:54:55:075]: Adding new sources is allowed.
MSI(i) [13:54:55.084] | MSI (c) (B0:9C) [13:54:55:075]: PROPERTY CHANGE: Adding PackagecodeChanging property. Its value is '1'.
MSI(i) [13:54:55.084] | MSI (c) (B0:9C) [13:54:55:075]: Package name extracted from package path: 'ps_he_gui.msi'
MSI(i) [13:54:55.084] | MSI (c) (B0:9C) [13:54:55:076]: Package to be registered: 'ps_he_gui.msi'
MSI(i) [13:54:55.084] | MSI (c) (B0:9C) [13:54:55:076]: Note: 1: 2262 2: AdminProperties 3: -2147287038
MSI(i) [13:54:55.084] | MSI (c) (B0:9C) [13:54:55:076]: Machine policy value 'DisableMsi' is 0
MSI(i) [13:54:55.084] | MSI (c) (B0:9C) [13:54:55:076]: Machine policy value 'AlwaysInstallElevated' is 0
MSI(i) [13:54:55.084] | MSI (c) (B0:9C) [13:54:55:076]: User policy value 'AlwaysInstallElevated' is 0
MSI(i) [13:54:55.084] | MSI (c) (B0:9C) [13:54:55:076]: Product installation will be elevated because user is admin and product is being installed per-machine.
MSI(i) [13:54:55.084] | MSI (c) (B0:9C) [13:54:55:076]: Running product '{21E9939C-DAEB-4ACB-9B5B-42A32EC12538}' with elevated privileges: Product is assigned.
MSI(i) [13:54:55.084] | MSI (c) (B0:9C) [13:54:55:076]: PROPERTY CHANGE: Adding MsiSystemRebootPending property. Its value is '1'.
MSI(i) [13:54:55.084] | MSI (c) (B0:9C) [13:54:55:076]: TRANSFORMS property is now:
MSI(i) [13:54:55.084] | MSI (c) (B0:9C) [13:54:55:076]: PROPERTY CHANGE: Adding VersionDatabase property. Its value is '200'.
MSI(i) [13:54:55.084] | MSI (c) (B0:9C) [13:54:55:077]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming
MSI(i) [13:54:55.084] | MSI (c) (B0:9C) [13:54:55:077]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Favorites
MSI(i) [13:54:55.084] | MSI (c) (B0:9C) [13:54:55:077]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Network Shortcuts
MSI(i) [13:54:55.084] | MSI (c) (B0:9C) [13:54:55:077]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Documents
MSI(i) [13:54:55.084] | MSI (c) (B0:9C) [13:54:55:077]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
MSI(i) [13:54:55.084] | MSI (c) (B0:9C) [13:54:55:077]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Recent
MSI(i) [13:54:55.084] | MSI (c) (B0:9C) [13:54:55:077]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\SendTo
MSI(i) [13:54:55.084] | MSI (c) (B0:9C) [13:54:55:077]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Templates
MSI(i) [13:54:55.084] | MSI (c) (B0:9C) [13:54:55:077]: SHELL32::SHGetFolderPath returned: C:\ProgramData
MSI(i) [13:54:55.084] | MSI (c) (B0:9C) [13:54:55:077]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Local
MSI(i) [13:54:55.084] | MSI (c) (B0:9C) [13:54:55:077]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Pictures
MSI(i) [13:54:55.084] | MSI (c) (B0:9C) [13:54:55:077]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI(i) [13:54:55.084] | MSI (c) (B0:9C) [13:54:55:077]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
MSI(i) [13:54:55.084] | MSI (c) (B0:9C) [13:54:55:077]: SHELL32::SHGetFolderPath returned: C:\Users\Public\Desktop
MSI(i) [13:54:55.084] | MSI (c) (B0:9C) [13:54:55:077]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI(i) [13:54:55.084] | MSI (c) (B0:9C) [13:54:55:077]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
MSI(i) [13:54:55.084] | MSI (c) (B0:9C) [13:54:55:077]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Desktop
MSI(i) [13:54:55.084] | MSI (c) (B0:9C) [13:54:55:077]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Templates
MSI(i) [13:54:55.084] | MSI (c) (B0:9C) [13:54:55:077]: SHELL32::SHGetFolderPath returned: C:\Windows\Fonts
MSI(i) [13:54:55.084] | MSI (c) (B0:9C) [13:54:55:077]: Note: 1: 2898 2: MS Sans Serif 3: MS Sans Serif 4: 0 5: 16
MSI(i) [13:54:55.084] | MSI (c) (B0:9C) [13:54:55:082]: MSI_LUA: Setting AdminUser property to 1 because this is the client or the user has already permitted elevation
MSI(i) [13:54:55.084] | MSI (c) (B0:9C) [13:54:55:082]: MSI_LUA: Setting MsiRunningElevated property to 1 because the install is already running elevated.
MSI(i) [13:54:55.084] | MSI (c) (B0:9C) [13:54:55:082]: PROPERTY CHANGE: Adding MsiRunningElevated property. Its value is '1'.
MSI(i) [13:54:55.084] | MSI (c) (B0:9C) [13:54:55:082]: PROPERTY CHANGE: Adding Privileged property. Its value is '1'.
MSI(i) [13:54:55.084] | MSI (c) (B0:9C) [13:54:55:083]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\MS Setup (ACME)\User Info 3: 2
MSI(i) [13:54:55.084] | MSI (c) (B0:9C) [13:54:55:083]: PROPERTY CHANGE: Adding USERNAME property. Its value is 'A Valued IT Customer'.
MSI(i) [13:54:55.084] | MSI (c) (B0:9C) [13:54:55:083]: PROPERTY CHANGE: Adding COMPANYNAME property. Its value is 'Intel Corporation'.
MSI(i) [13:54:55.084] | MSI (c) (B0:9C) [13:54:55:083]: PROPERTY CHANGE: Adding DATABASE property. Its value is 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\ps_he_gui\ps_he_gui.msi'.
MSI(i) [13:54:55.084] | MSI (c) (B0:9C) [13:54:55:083]: PROPERTY CHANGE: Adding OriginalDatabase property. Its value is 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\ps_he_gui\ps_he_gui.msi'.
MSI(i) [13:54:55.084] | MSI (c) (B0:9C) [13:54:55:083]: Machine policy value 'MsiDisableEmbeddedUI' is 0
MSI(i) [13:54:55.084] | MSI (c) (B0:9C) [13:54:55:083]: EEUI - Disabling MsiEmbeddedUI in quiet mode
MSI(i) [13:54:55.084] | === Logging started: 4/8/2014  13:54:55 ===
MSI(i) [13:54:55.084] | MSI (c) (B0:9C) [13:54:55:083]: Note: 1: 2205 2:  3: PatchPackage
MSI(i) [13:54:55.084] | MSI (c) (B0:9C) [13:54:55:083]: Machine policy value 'DisableRollback' is 0
MSI(i) [13:54:55.084] | MSI (c) (B0:9C) [13:54:55:083]: User policy value 'DisableRollback' is 0
MSI(i) [13:54:55.084] | MSI (c) (B0:9C) [13:54:55:083]: PROPERTY CHANGE: Adding UILevel property. Its value is '2'.
MSI(i) [13:54:55.084] | MSI (c) (B0:9C) [13:54:55:083]: Creating MSIHANDLE (31) of type 790537 for thread 3996
MSI(i) [13:54:55.084] | MSI (c) (B0:9C) [13:54:55:083]: MsiOpenPackageEx is returning 0
MSI(i) [13:54:55.084] | MSI (c) (B0:9C) [13:54:55:083]: Closing MSIHANDLE (31) of type 790537 for thread 3996
MSI(i) [13:54:55.084] | === Verbose logging stopped: 4/8/2014  13:54:55 ===
PSET(i) [13:54:55.091] | (4225.285): MsiOpenPackageEx(C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\ps_he_gui\ps_he_gui.msi)
MSI(i) [13:54:55.194] | === Verbose logging started: 4/8/2014  13:54:55  Build type: SHIP UNICODE 5.00.7601.00  Calling process: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\setup.exe ===
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:093]: SOFTWARE RESTRICTION POLICY: Verifying package --> 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\ps_he_gui\ps_he_gui.msi' against software restriction policy
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:093]: SOFTWARE RESTRICTION POLICY: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\ps_he_gui\ps_he_gui.msi has a digital signature
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:136]: SOFTWARE RESTRICTION POLICY: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\ps_he_gui\ps_he_gui.msi is permitted to run at the 'unrestricted' authorization level.
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:137]: Cloaking enabled.
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:137]: Attempting to enable all disabled privileges before calling Install on Server
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:137]: End dialog not enabled
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:137]: Original package ==> C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\ps_he_gui\ps_he_gui.msi
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:137]: Package we're running from ==> C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\ps_he_gui\ps_he_gui.msi
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:138]: Machine policy value 'DisableUserInstalls' is 0
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:139]: APPCOMPAT: Compatibility mode property overrides found.
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:139]: APPCOMPAT: looking for appcompat database entry with ProductCode '{21E9939C-DAEB-4ACB-9B5B-42A32EC12538}'.
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:139]: APPCOMPAT: no matching ProductCode found in database.
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:144]: MSCOREE not loaded loading copy from system32
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:147]: Machine policy value 'TransformsSecure' is 0
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:147]: User policy value 'TransformsAtSource' is 0
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:147]: Machine policy value 'DisablePatch' is 0
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:147]: Machine policy value 'AllowLockdownPatch' is 0
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:148]: Machine policy value 'DisableLUAPatching' is 0
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:148]: Machine policy value 'DisableFlyWeightPatching' is 0
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:148]: Enabling baseline caching for this transaction since all active patches are MSI 3.0 style MSPs or at least one MSI 3.0 minor update patch is active
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:148]: APPCOMPAT: looking for appcompat database entry with ProductCode '{21E9939C-DAEB-4ACB-9B5B-42A32EC12538}'.
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:148]: APPCOMPAT: no matching ProductCode found in database.
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:148]: Transforms are not secure.
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:148]: PROPERTY CHANGE: Adding MsiLogFileLocation property. Its value is 'C:\Users\PCCA-PM\AppData\Local\Temp\MSIED31.tmp'.
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:148]: No Command Line.
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:148]: PROPERTY CHANGE: Adding PackageCode property. Its value is '{DCD79D68-BBEE-4BFA-86C0-B9E2C4A6EB22}'.
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:148]: Product Code passed to Engine.Initialize:           '(none)'
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:148]: Product Code from property table before transforms: '{21E9939C-DAEB-4ACB-9B5B-42A32EC12538}'
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:148]: Product Code from property table after transforms:  '{21E9939C-DAEB-4ACB-9B5B-42A32EC12538}'
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:148]: Product not registered: beginning first-time install
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:148]: PROPERTY CHANGE: Adding ProductState property. Its value is '-1'.
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:148]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer 3: 2
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:148]: Entering CMsiConfigurationManager::SetLastUsedSource.
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:149]: User policy value 'SearchOrder' is 'nmu'
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:149]: Adding new sources is allowed.
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:149]: PROPERTY CHANGE: Adding PackagecodeChanging property. Its value is '1'.
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:149]: Package name extracted from package path: 'ps_he_gui.msi'
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:149]: Package to be registered: 'ps_he_gui.msi'
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:149]: Note: 1: 2262 2: AdminProperties 3: -2147287038
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:149]: Machine policy value 'DisableMsi' is 0
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:149]: Machine policy value 'AlwaysInstallElevated' is 0
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:149]: User policy value 'AlwaysInstallElevated' is 0
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:149]: Product installation will be elevated because user is admin and product is being installed per-machine.
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:149]: Running product '{21E9939C-DAEB-4ACB-9B5B-42A32EC12538}' with elevated privileges: Product is assigned.
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:149]: PROPERTY CHANGE: Adding MsiSystemRebootPending property. Its value is '1'.
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:149]: TRANSFORMS property is now:
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:149]: PROPERTY CHANGE: Adding VersionDatabase property. Its value is '200'.
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:150]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:150]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Favorites
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:150]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Network Shortcuts
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:150]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Documents
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:150]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:150]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Recent
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:150]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\SendTo
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:150]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Templates
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:150]: SHELL32::SHGetFolderPath returned: C:\ProgramData
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:150]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Local
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:150]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Pictures
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:150]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:150]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:150]: SHELL32::SHGetFolderPath returned: C:\Users\Public\Desktop
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:150]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:150]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:150]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Desktop
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:150]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Templates
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:150]: SHELL32::SHGetFolderPath returned: C:\Windows\Fonts
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:150]: Note: 1: 2898 2: MS Sans Serif 3: MS Sans Serif 4: 0 5: 16
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:155]: MSI_LUA: Setting AdminUser property to 1 because this is the client or the user has already permitted elevation
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:155]: MSI_LUA: Setting MsiRunningElevated property to 1 because the install is already running elevated.
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:155]: PROPERTY CHANGE: Adding MsiRunningElevated property. Its value is '1'.
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:155]: PROPERTY CHANGE: Adding Privileged property. Its value is '1'.
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:156]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\MS Setup (ACME)\User Info 3: 2
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:156]: PROPERTY CHANGE: Adding USERNAME property. Its value is 'A Valued IT Customer'.
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:156]: PROPERTY CHANGE: Adding COMPANYNAME property. Its value is 'Intel Corporation'.
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:156]: PROPERTY CHANGE: Adding DATABASE property. Its value is 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\ps_he_gui\ps_he_gui.msi'.
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:156]: PROPERTY CHANGE: Adding OriginalDatabase property. Its value is 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\ps_he_gui\ps_he_gui.msi'.
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:156]: Machine policy value 'MsiDisableEmbeddedUI' is 0
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:156]: EEUI - Disabling MsiEmbeddedUI in quiet mode
MSI(i) [13:54:55.194] | === Logging started: 4/8/2014  13:54:55 ===
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:156]: Note: 1: 2205 2:  3: PatchPackage
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:156]: Machine policy value 'DisableRollback' is 0
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:156]: User policy value 'DisableRollback' is 0
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:156]: PROPERTY CHANGE: Adding UILevel property. Its value is '2'.
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:156]: Creating MSIHANDLE (32) of type 790537 for thread 3996
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:156]: MsiOpenPackageEx is returning 0
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:156]: Creating MSIHANDLE (33) of type 790541 for thread 3996
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:156]: Closing MSIHANDLE (33) of type 790541 for thread 3996
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:156]: Doing action: AppSearch
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:156]: Note: 1: 2205 2:  3: ActionText
MSI(i) [13:54:55.194] | Action 13:54:55: AppSearch. Searching for installed applications
MSI(i) [13:54:55.194] | Action start 13:54:55: AppSearch.
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:158]: Note: 1: 2205 2:  3: AppSearch
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:158]: Note: 1: 2228 2:  3: AppSearch 4: SELECT `Property`, `Signature_` FROM `AppSearch`
MSI(i) [13:54:55.194] | Action ended 13:54:55: AppSearch. Return value 0.
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:158]: Doing action: CostInitialize
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:158]: Note: 1: 2205 2:  3: ActionText
MSI(i) [13:54:55.194] | Action 13:54:55: CostInitialize. Computing space requirements
MSI(i) [13:54:55.194] | Action start 13:54:55: CostInitialize.
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:159]: Machine policy value 'MaxPatchCacheSize' is 10
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:159]: Baseline: Sorting baselines for {21E9939C-DAEB-4ACB-9B5B-42A32EC12538}.
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:159]: Baseline: New baseline 13.1.0 from transaction.
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:159]: Baseline: Sorted order Native: Order 0.
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:159]: Baseline Data Table:
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:159]: ProductCode: {21E9939C-DAEB-4ACB-9B5B-42A32EC12538} Version: 13.1.0 Attributes: 0 PatchId: Native BaselineId: -2147483648 Order: 0
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:159]: Baseline File Table:
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:159]: PROPERTY CHANGE: Adding ROOTDRIVE property. Its value is 'C:\'.
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:159]: PROPERTY CHANGE: Adding CostingComplete property. Its value is '0'.
MSI(i) [13:54:55.194] | Action ended 13:54:55: CostInitialize. Return value 1.
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:160]: Doing action: FileCost
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:160]: Note: 1: 2205 2:  3: ActionText
MSI(i) [13:54:55.194] | Action 13:54:55: FileCost. Computing space requirements
MSI(i) [13:54:55.194] | Action start 13:54:55: FileCost.
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:161]: Note: 1: 2205 2:  3: MsiAssembly
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:161]: Note: 1: 2205 2:  3: Class
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:161]: Note: 1: 2205 2:  3: Extension
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:161]: Note: 1: 2205 2:  3: TypeLib
MSI(i) [13:54:55.194] | Action ended 13:54:55: FileCost. Return value 1.
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:161]: Doing action: CostFinalize
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:161]: Note: 1: 2205 2:  3: ActionText
MSI(i) [13:54:55.194] | Action 13:54:55: CostFinalize. Computing space requirements
MSI(i) [13:54:55.194] | Action start 13:54:55: CostFinalize.
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:162]: PROPERTY CHANGE: Adding OutOfDiskSpace property. Its value is '0'.
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:162]: PROPERTY CHANGE: Adding OutOfNoRbDiskSpace property. Its value is '0'.
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:162]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceAvailable property. Its value is '0'.
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:162]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRequired property. Its value is '0'.
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:162]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRemaining property. Its value is '0'.
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:162]: Note: 1: 2205 2:  3: Patch
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:163]: PROPERTY CHANGE: Adding TARGETDIR property. Its value is 'C:\'.
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:163]: PROPERTY CHANGE: Adding ProductMenuFolder property. Its value is 'C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Intel VTune Amplifier XE 2013\'.
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:163]: PROPERTY CHANGE: Adding HEMenuToolsFolder_1 property. Its value is 'C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Intel VTune Amplifier XE 2013\'.
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:163]: PROPERTY CHANGE: Adding HEMenuFolder property. Its value is 'C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Intel Parallel Studio XE 2013\'.
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:163]: PROPERTY CHANGE: Adding HEMenuToolsFolder property. Its value is 'C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Intel Parallel Studio XE 2013\'.
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:163]: PROPERTY CHANGE: Adding BASEINSTALLDIR property. Its value is 'C:\Program Files (x86)\Intel\'.
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:163]: PROPERTY CHANGE: Adding INSTALLDIR property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\'.
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:163]: PROPERTY CHANGE: Adding bin32 property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\bin32\'.
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:163]: PROPERTY CHANGE: Adding _1033 property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\bin32\1033\'.
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:163]: PROPERTY CHANGE: Adding config property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\config\'.
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:163]: PROPERTY CHANGE: Adding perffilterbar1 property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\config\perffilterbar1\'.
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:163]: PROPERTY CHANGE: Adding summarypane3 property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\config\summarypane3\'.
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:163]: PROPERTY CHANGE: Adding dialogs property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\config\dialogs\'.
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:163]: PROPERTY CHANGE: Adding action_state property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\config\action_state\'.
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:163]: PROPERTY CHANGE: Adding panehelpers2 property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\config\panehelpers2\'.
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:163]: PROPERTY CHANGE: Adding resource property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\resource\'.
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:163]: PROPERTY CHANGE: Adding message property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\message\'.
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:163]: PROPERTY CHANGE: Adding en property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\message\en\'.
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:163]: PROPERTY CHANGE: Adding perfclient1 property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\message\en\perfclient1\'.
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:163]: PROPERTY CHANGE: Adding gridpanes2 property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\message\en\gridpanes2\'.
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:163]: Target path resolution complete. Dumping Directory table...
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:163]: Note: target paths subject to change (via custom actions or browsing)
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:163]: Dir (target): Key: TARGETDIR    , Object: C:\
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:163]: Dir (target): Key: WindowsFolder    , Object: C:\Windows\
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:163]: Dir (target): Key: ProgramMenuFolder    , Object: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:163]: Dir (target): Key: ProductMenuFolder    , Object: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Intel VTune Amplifier XE 2013\
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:163]: Dir (target): Key: HEMenuToolsFolder_1    , Object: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Intel VTune Amplifier XE 2013\
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:163]: Dir (target): Key: HEMenuFolder    , Object: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Intel Parallel Studio XE 2013\
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:163]: Dir (target): Key: HEMenuToolsFolder    , Object: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Intel Parallel Studio XE 2013\
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:163]: Dir (target): Key: ProgramFilesFolder    , Object: C:\Program Files (x86)\
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:163]: Dir (target): Key: BASEINSTALLDIR    , Object: C:\Program Files (x86)\Intel\
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:163]: Dir (target): Key: INSTALLDIR    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:163]: Dir (target): Key: bin32    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\bin32\
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:163]: Dir (target): Key: _1033    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\bin32\1033\
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:163]: Dir (target): Key: config    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\config\
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:163]: Dir (target): Key: perffilterbar1    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\config\perffilterbar1\
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:163]: Dir (target): Key: summarypane3    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\config\summarypane3\
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:163]: Dir (target): Key: dialogs    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\config\dialogs\
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:163]: Dir (target): Key: action_state    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\config\action_state\
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:163]: Dir (target): Key: panehelpers2    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\config\panehelpers2\
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:163]: Dir (target): Key: resource    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\resource\
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:163]: Dir (target): Key: message    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\message\
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:163]: Dir (target): Key: en    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\message\en\
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:163]: Dir (target): Key: perfclient1    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\message\en\perfclient1\
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:163]: Dir (target): Key: gridpanes2    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\message\en\gridpanes2\
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:163]: PROPERTY CHANGE: Adding INSTALLLEVEL property. Its value is '1'.
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:163]: Note: 1: 2205 2:  3: MsiAssembly
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:163]: Note: 1: 2228 2:  3: MsiAssembly 4:  SELECT `MsiAssembly`.`Attributes`, `MsiAssembly`.`File_Application`, `MsiAssembly`.`File_Manifest`,  `Component`.`KeyPath` FROM `MsiAssembly`, `Component` WHERE  `MsiAssembly`.`Component_` = `Component`.`Component` AND `MsiAssembly`.`Component_` = ?
MSI(i) [13:54:55.194] | Action ended 13:54:55: CostFinalize. Return value 1.
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:167]: Doing action: InstallValidate
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:167]: Note: 1: 2205 2:  3: ActionText
MSI(i) [13:54:55.194] | Action 13:54:55: InstallValidate. Validating install
MSI(i) [13:54:55.194] | Action start 13:54:55: InstallValidate.
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:168]: Note: 1: 2205 2:  3: Dialog
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:168]: Feature: CoreAppFiles64; Installed: Absent;   Request: Local;   Action: Local
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:168]: Feature: CoreAppFiles; Installed: Absent;   Request: Local;   Action: Local
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:168]: Component: CommonInstallRoot; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:168]: Component: ProductFamilyAnchor; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:168]: Component: ProductVersionAnchor; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:168]: Component: CompMsiMarker; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:168]: Component: amplxe.file.assoc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:168]: Component: amplxeproj.file.assoc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:168]: Component: Comp_msngrgui.xmc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:168]: Component: Comp_stripchartpanes.xmc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:168]: Component: Comp_stripchartctrl.xmc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:168]: Component: Comp_viewer.xmc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:168]: Component: Comp_clienthelpers.core.xmc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:168]: Component: Comp_clienthelpers.msngr_gui.xmc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:168]: Component: Comp_clienthelpers.ff.xmc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:168]: Component: Comp_qfagent.fd.xmc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:168]: Component: Comp_panehelpers2_messages_task_scheduler.xmc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:168]: Component: Comp_panehelpers2_messages_common.xmc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:168]: Component: Comp_deeppane.xmc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:168]: Component: Comp_tabletreepane.xmc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:168]: Component: Comp_gridpane.xmc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:168]: Component: Comp_dvpane.xmc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:168]: Component: Comp_dialogs2.xmc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:168]: Component: Comp_summarypane3.xmc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:168]: Component: Comp_perffilterbar1.xmc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:168]: Component: Comp_ps_gui_plug.xmc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:168]: Component: Comp_commondlg.3.xmc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:168]: Component: Comp_abclient.core.xmc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:168]: Component: Comp_core.xmc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:168]: Component: Comp_collectdlg.3.xmc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:168]: Component: Comp_stripchartctrl.dat; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:168]: Component: Comp_viewer.dat; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:168]: Component: Comp_clienthelpers.dat; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:168]: Component: Comp_crashreport.dat; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:168]: Component: Comp_panehelpers2.dat; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:168]: Component: Comp_gridpanes2_deeppane.dat; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:168]: Component: Comp_gridpanes2_gridpane.dat; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:168]: Component: Comp_dialogs2.dat; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:168]: Component: Comp_summarypane3.dat; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:168]: Component: Comp_perffilterbar1.dat; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:168]: Component: Comp_ps_gui_plug.dat; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:168]: Component: Comp_commondlg3.dat; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:168]: Component: Comp_test.dat; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:168]: Component: Comp_abclient.core.dat; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:168]: Component: Comp_perfclient.dat; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:168]: Component: Comp_collectdlg3.dat; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:168]: Component: Comp_utils.pyc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:168]: Component: Comp_progress_bar.pyc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:168]: Component: Comp_list.pyc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:168]: Component: Comp_scrollbar.pyc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:168]: Component: Comp_push_button.pyc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:168]: Component: Comp_push_button.xml; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:168]: Component: Comp_list.xml; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:168]: Component: Comp_progress_bar.xml; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:168]: Component: Comp_scrollbar.xml; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:168]: Component: Comp_base_grid_pane.cfg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:168]: Component: Comp_summary_pane.xml; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:168]: Component: Comp_perffilterbar.xml; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:168]: Component: Comp_stripchartpanes.xml; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:168]: Component: Comp_tab_control.xml; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:168]: Component: Comp_ransa_gui.cfg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:168]: Component: Comp_chart_bar_image.xml; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:168]: Component: Comp_result_info.pyc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:168]: Component: Comp_concurrency_chart.xml; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:168]: Component: Comp_ratio_bar.xml; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:168]: Component: Comp_label_block.pyc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:168]: Component: Comp_info_table.pyc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:168]: Component: Comp_chart_mark.pyc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.194] | MSI (c) (B0:9C) [13:54:55:168]: Component: Comp_color_band.xml; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:168]: Component: Comp_chart.pyc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:168]: Component: Comp_chart_bar_image.pyc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:168]: Component: Comp_value_control.pyc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:168]: Component: Comp_chart_bar.pyc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:168]: Component: Comp_grid_column.xml; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:168]: Component: Comp_summary.pyc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:168]: Component: Comp_label_block.xml; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:168]: Component: Comp_ratio_bar.pyc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:168]: Component: Comp_chart_bar.xml; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:168]: Component: Comp_info_table.xml; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:168]: Component: Comp_info_table_row.xml; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:168]: Component: Comp_chart.xml; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:168]: Component: Comp_color_band.pyc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:168]: Component: Comp_xapgl_ext.rng; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:168]: Component: Comp_hyperlink.xml; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:168]: Component: Comp_result_info.xml; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:168]: Component: Comp_stack.xsl; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:168]: Component: Comp_stack_row.pyc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:168]: Component: Comp_summary.rng; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:168]: Component: Comp_hyperlink.pyc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:168]: Component: Comp_key_control.pyc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:169]: Component: Comp_summary.xml; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:169]: Component: Comp_info_table_recursive.pyc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:169]: Component: Comp_framerate_chart.xml; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:169]: Component: Comp_framerate_chart.pyc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:169]: Component: Comp_grid_column.pyc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:169]: Component: Comp_grid.pyc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:169]: Component: Comp_grid.xml; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:169]: Component: Comp_info_table_row.pyc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:169]: Component: Comp_key_control.xml; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:169]: Component: Comp_stack.pyc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:169]: Component: Comp_concurrency_chart.pyc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:169]: Component: Comp_stack_row.xml; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:169]: Component: Comp_stack.xml; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:169]: Component: Comp_info_table_recursive.xml; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:169]: Component: Comp_chart_mark.xml; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:169]: Component: Comp_slider.pyc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:169]: Component: Comp_slider.xml; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:169]: Component: Comp_value_control.xml; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:169]: Component: Comp_selector.pyc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:169]: Component: Comp_section.xml; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:169]: Component: Comp_knobs.xml; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:169]: Component: Comp_section.pyc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:169]: Component: Comp_section.xsl; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:169]: Component: Comp_selector.xml; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:169]: Component: Comp_knobs.pyc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:169]: Component: Comp_filterbar.xsl; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:169]: Component: Comp_filterbar.pyc; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:169]: Component: Comp_wxmsw28u_vc_amplxe_2.8.1208.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:169]: Component: Comp_wxmsw28u_stc_vc_amplxe_2.8.1208.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:169]: Component: Comp_amplxe_msngrgui_1.0.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:169]: Component: Comp_amplxe_idvc_base_7.2.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:169]: Component: Comp_amplxe_idvc_frw_7.2.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:169]: Component: Comp_amplxe_idvc_wx_7.2.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:169]: Component: Comp_amplxe_idvc_propgrid_2.4.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:169]: Component: Comp_amplxe_gui.exe; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:169]: Component: Comp_amplxe_clienthelpers_core_1.21.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:169]: Component: Comp_amplxe_clienthelpers_commondlghelpers_1.21.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:169]: Component: Comp_amplxe_clienthelpers_collectdlghelpers_1.21.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:169]: Component: Comp_crashreport.exe; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:169]: Component: Comp_amplxe_idvc_gridctl_core_8.2.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:169]: Component: Comp_amplxe_wx_helpers_core_1.14.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:169]: Component: Comp_amplxe_panehelpers_core_2.3.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:169]: Component: Comp_amplxe_gridpanes_core_2.3.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:169]: Component: Comp_amplxe_gridpanes_tabletreeview_2.3.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:169]: Component: Comp_amplxe_dialogs_core_2.1.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:169]: Component: Comp_amplxe_dialogs_sep_cd_addon_2.1.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:169]: Component: Comp_amplxe_summarypane_core_3.1.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:169]: Component: Comp_amplxe_perffilterbar_core_1.1.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:169]: Component: Comp_amplxe_stripchartpanes_panes_1.2.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:169]: Component: Comp_amplxe_stripchartctrl_shared_1.4.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:169]: Component: Comp_amplxe_gui_plug_1.3.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:169]: Component: Comp_amplxe_vspkg.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:169]: Component: Comp_amplxe_vspkgui.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:169]: Component: Comp_amplxe_commondlg_core_3.6.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:169]: Component: Comp_amplxe_abclient_1.13.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:169]: Component: Comp_amplxe_client_1.3.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:169]: Component: Comp_amplxe_client_stub_1.3.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:169]: Component: Comp_amplxe_configurator.exe; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:169]: Component: Comp_amplxe_collectdlg_core_3.12.dll; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:169]: Component: CompLinks; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:169]: Component: CompLinksWin8; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:169]: Component: __CompLinks65; Installed: Null;   Request: Local;   Action: Local;   Client State: Null
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:169]: Component: __CompLinksWin865; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:169]: Component: __amplxe.file.assoc65; Installed: Null;   Request: Local;   Action: Local;   Client State: Null
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:169]: Component: __amplxeproj.file.assoc65; Installed: Null;   Request: Local;   Action: Local;   Client State: Null
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:169]: Component: __CompLinks66; Installed: Null;   Request: Local;   Action: Local;   Client State: Null
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:169]: Component: __CompLinksWin866; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:169]: Note: 1: 2205 2:  3: BindImage
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:169]: Note: 1: 2205 2:  3: ProgId
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:169]: Note: 1: 2205 2:  3: PublishComponent
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:169]: Note: 1: 2205 2:  3: SelfReg
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:169]: Note: 1: 2205 2:  3: Extension
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:169]: Note: 1: 2205 2:  3: Font
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:169]: Note: 1: 2205 2:  3: Class
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:169]: Note: 1: 2205 2:  3: Icon
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:169]: Note: 1: 2205 2:  3: TypeLib
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:169]: Note: 1: 2205 2:  3: _RemoveFilePath
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:177]: PROPERTY CHANGE: Modifying CostingComplete property. Its current value is '0'. Its new value: '1'.
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:177]: Note: 1: 2205 2:  3: BindImage
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:177]: Note: 1: 2205 2:  3: ProgId
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:177]: Note: 1: 2205 2:  3: PublishComponent
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:177]: Note: 1: 2205 2:  3: SelfReg
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:177]: Note: 1: 2205 2:  3: Extension
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:177]: Note: 1: 2205 2:  3: Font
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:178]: Note: 1: 2205 2:  3: Class
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:178]: Note: 1: 2205 2:  3: Icon
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:178]: Note: 1: 2205 2:  3: TypeLib
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:178]: Note: 1: 2727 2:
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:192]: Note: 1: 2727 2:
MSI(i) [13:54:55.195] | Action ended 13:54:55: InstallValidate. Return value 1.
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:192]: Creating MSIHANDLE (34) of type 790541 for thread 3996
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:192]: Creating MSIHANDLE (35) of type 790540 for thread 3996
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:193]: Creating MSIHANDLE (36) of type 790531 for thread 3996
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:193]: Creating MSIHANDLE (37) of type 790540 for thread 3996
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:193]: Creating MSIHANDLE (38) of type 790531 for thread 3996
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:193]: Closing MSIHANDLE (38) of type 790531 for thread 3996
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:193]: Creating MSIHANDLE (39) of type 790540 for thread 3996
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:193]: Closing MSIHANDLE (39) of type 790540 for thread 3996
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:193]: Closing MSIHANDLE (37) of type 790540 for thread 3996
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:193]: Closing MSIHANDLE (36) of type 790531 for thread 3996
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:193]: Creating MSIHANDLE (40) of type 790531 for thread 3996
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:193]: Creating MSIHANDLE (41) of type 790540 for thread 3996
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:193]: Creating MSIHANDLE (42) of type 790540 for thread 3996
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:193]: Closing MSIHANDLE (42) of type 790540 for thread 3996
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:193]: Closing MSIHANDLE (41) of type 790540 for thread 3996
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:193]: Closing MSIHANDLE (40) of type 790531 for thread 3996
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:193]: Closing MSIHANDLE (35) of type 790540 for thread 3996
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:193]: Closing MSIHANDLE (34) of type 790541 for thread 3996
MSI(i) [13:54:55.195] | MSI (c) (B0:9C) [13:54:55:193]: Leaked MSIHANDLE (32) of type 790537 for thread 3996
MSI(i) [13:54:55.195] | === Verbose logging stopped: 4/8/2014  13:54:55 ===
PSET(i) [13:54:55.203] | (4225.1904): Dependency {ACD97E2A-090D-46ea-9983-6E44BCA28575} always show dialog
PSET(i) [13:54:55.204] | (4225.2963): MsiOpenPackageEx(C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\sep\sep.msi)
MSI(i) [13:54:55.239] | === Verbose logging started: 4/8/2014  13:54:55  Build type: SHIP UNICODE 5.00.7601.00  Calling process: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\setup.exe ===
MSI(i) [13:54:55.239] | MSI (c) (B0:9C) [13:54:55:205]: SOFTWARE RESTRICTION POLICY: Verifying package --> 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\sep\sep.msi' against software restriction policy
MSI(i) [13:54:55.239] | MSI (c) (B0:9C) [13:54:55:205]: SOFTWARE RESTRICTION POLICY: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\sep\sep.msi has a digital signature
MSI(i) [13:54:55.239] | MSI (c) (B0:9C) [13:54:55:219]: SOFTWARE RESTRICTION POLICY: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\sep\sep.msi is permitted to run at the 'unrestricted' authorization level.
MSI(i) [13:54:55.239] | MSI (c) (B0:9C) [13:54:55:220]: Cloaking enabled.
MSI(i) [13:54:55.239] | MSI (c) (B0:9C) [13:54:55:220]: Attempting to enable all disabled privileges before calling Install on Server
MSI(i) [13:54:55.239] | MSI (c) (B0:9C) [13:54:55:220]: End dialog not enabled
MSI(i) [13:54:55.239] | MSI (c) (B0:9C) [13:54:55:220]: Original package ==> C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\sep\sep.msi
MSI(i) [13:54:55.239] | MSI (c) (B0:9C) [13:54:55:220]: Package we're running from ==> C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\sep\sep.msi
MSI(i) [13:54:55.239] | MSI (c) (B0:9C) [13:54:55:221]: APPCOMPAT: Compatibility mode property overrides found.
MSI(i) [13:54:55.239] | MSI (c) (B0:9C) [13:54:55:222]: APPCOMPAT: looking for appcompat database entry with ProductCode '{F8081656-D251-4E20-80E8-1659BD636721}'.
MSI(i) [13:54:55.239] | MSI (c) (B0:9C) [13:54:55:222]: APPCOMPAT: no matching ProductCode found in database.
MSI(i) [13:54:55.239] | MSI (c) (B0:9C) [13:54:55:226]: MSCOREE not loaded loading copy from system32
MSI(i) [13:54:55.239] | MSI (c) (B0:9C) [13:54:55:230]: Machine policy value 'TransformsSecure' is 0
MSI(i) [13:54:55.239] | MSI (c) (B0:9C) [13:54:55:230]: User policy value 'TransformsAtSource' is 0
MSI(i) [13:54:55.239] | MSI (c) (B0:9C) [13:54:55:230]: Note: 1: 2262 2: File 3: -2147287038
MSI(i) [13:54:55.239] | MSI (c) (B0:9C) [13:54:55:230]: Note: 1: 2205 2:  3: MsiFileHash
MSI(i) [13:54:55.239] | MSI (c) (B0:9C) [13:54:55:230]: Machine policy value 'DisablePatch' is 0
MSI(i) [13:54:55.239] | MSI (c) (B0:9C) [13:54:55:230]: Machine policy value 'AllowLockdownPatch' is 0
MSI(i) [13:54:55.239] | MSI (c) (B0:9C) [13:54:55:230]: Machine policy value 'DisableLUAPatching' is 0
MSI(i) [13:54:55.239] | MSI (c) (B0:9C) [13:54:55:230]: Machine policy value 'DisableFlyWeightPatching' is 0
MSI(i) [13:54:55.239] | MSI (c) (B0:9C) [13:54:55:230]: Enabling baseline caching for this transaction since all active patches are MSI 3.0 style MSPs or at least one MSI 3.0 minor update patch is active
MSI(i) [13:54:55.239] | MSI (c) (B0:9C) [13:54:55:230]: APPCOMPAT: looking for appcompat database entry with ProductCode '{F8081656-D251-4E20-80E8-1659BD636721}'.
MSI(i) [13:54:55.239] | MSI (c) (B0:9C) [13:54:55:231]: APPCOMPAT: no matching ProductCode found in database.
MSI(i) [13:54:55.239] | MSI (c) (B0:9C) [13:54:55:231]: Transforms are not secure.
MSI(i) [13:54:55.239] | MSI (c) (B0:9C) [13:54:55:231]: PROPERTY CHANGE: Adding MsiLogFileLocation property. Its value is 'C:\Users\PCCA-PM\AppData\Local\Temp\MSIED31.tmp'.
MSI(i) [13:54:55.239] | MSI (c) (B0:9C) [13:54:55:231]: No Command Line.
MSI(i) [13:54:55.239] | MSI (c) (B0:9C) [13:54:55:231]: PROPERTY CHANGE: Adding PackageCode property. Its value is '{201DDC26-0CE0-477B-A268-2AC0FCF9CF3F}'.
MSI(i) [13:54:55.239] | MSI (c) (B0:9C) [13:54:55:231]: Product Code passed to Engine.Initialize:           '(none)'
MSI(i) [13:54:55.239] | MSI (c) (B0:9C) [13:54:55:231]: Product Code from property table before transforms: '{F8081656-D251-4E20-80E8-1659BD636721}'
MSI(i) [13:54:55.239] | MSI (c) (B0:9C) [13:54:55:231]: Product Code from property table after transforms:  '{F8081656-D251-4E20-80E8-1659BD636721}'
MSI(i) [13:54:55.239] | MSI (c) (B0:9C) [13:54:55:231]: Product not registered: beginning first-time install
MSI(i) [13:54:55.239] | MSI (c) (B0:9C) [13:54:55:231]: PROPERTY CHANGE: Adding ProductState property. Its value is '-1'.
MSI(i) [13:54:55.239] | MSI (c) (B0:9C) [13:54:55:231]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer 3: 2
MSI(i) [13:54:55.239] | MSI (c) (B0:9C) [13:54:55:231]: Entering CMsiConfigurationManager::SetLastUsedSource.
MSI(i) [13:54:55.239] | MSI (c) (B0:9C) [13:54:55:231]: User policy value 'SearchOrder' is 'nmu'
MSI(i) [13:54:55.239] | MSI (c) (B0:9C) [13:54:55:231]: Adding new sources is allowed.
MSI(i) [13:54:55.239] | MSI (c) (B0:9C) [13:54:55:231]: PROPERTY CHANGE: Adding PackagecodeChanging property. Its value is '1'.
MSI(i) [13:54:55.239] | MSI (c) (B0:9C) [13:54:55:231]: Package name extracted from package path: 'sep.msi'
MSI(i) [13:54:55.239] | MSI (c) (B0:9C) [13:54:55:231]: Package to be registered: 'sep.msi'
MSI(i) [13:54:55.239] | MSI (c) (B0:9C) [13:54:55:232]: Note: 1: 2262 2: AdminProperties 3: -2147287038
MSI(i) [13:54:55.239] | MSI (c) (B0:9C) [13:54:55:232]: Machine policy value 'DisableMsi' is 0
MSI(i) [13:54:55.239] | MSI (c) (B0:9C) [13:54:55:232]: Machine policy value 'AlwaysInstallElevated' is 0
MSI(i) [13:54:55.239] | MSI (c) (B0:9C) [13:54:55:232]: User policy value 'AlwaysInstallElevated' is 0
MSI(i) [13:54:55.239] | MSI (c) (B0:9C) [13:54:55:232]: Product installation will be elevated because user is admin and product is being installed per-machine.
MSI(i) [13:54:55.239] | MSI (c) (B0:9C) [13:54:55:232]: Running product '{F8081656-D251-4E20-80E8-1659BD636721}' with elevated privileges: Product is assigned.
MSI(i) [13:54:55.239] | MSI (c) (B0:9C) [13:54:55:232]: PROPERTY CHANGE: Adding MsiSystemRebootPending property. Its value is '1'.
MSI(i) [13:54:55.239] | MSI (c) (B0:9C) [13:54:55:232]: TRANSFORMS property is now:
MSI(i) [13:54:55.239] | MSI (c) (B0:9C) [13:54:55:232]: PROPERTY CHANGE: Adding VersionDatabase property. Its value is '200'.
MSI(i) [13:54:55.239] | MSI (c) (B0:9C) [13:54:55:232]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming
MSI(i) [13:54:55.239] | MSI (c) (B0:9C) [13:54:55:232]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Favorites
MSI(i) [13:54:55.239] | MSI (c) (B0:9C) [13:54:55:232]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Network Shortcuts
MSI(i) [13:54:55.239] | MSI (c) (B0:9C) [13:54:55:232]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Documents
MSI(i) [13:54:55.239] | MSI (c) (B0:9C) [13:54:55:232]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
MSI(i) [13:54:55.239] | MSI (c) (B0:9C) [13:54:55:232]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Recent
MSI(i) [13:54:55.239] | MSI (c) (B0:9C) [13:54:55:232]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\SendTo
MSI(i) [13:54:55.239] | MSI (c) (B0:9C) [13:54:55:232]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Templates
MSI(i) [13:54:55.239] | MSI (c) (B0:9C) [13:54:55:232]: SHELL32::SHGetFolderPath returned: C:\ProgramData
MSI(i) [13:54:55.239] | MSI (c) (B0:9C) [13:54:55:232]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Local
MSI(i) [13:54:55.239] | MSI (c) (B0:9C) [13:54:55:232]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Pictures
MSI(i) [13:54:55.239] | MSI (c) (B0:9C) [13:54:55:232]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI(i) [13:54:55.239] | MSI (c) (B0:9C) [13:54:55:232]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
MSI(i) [13:54:55.239] | MSI (c) (B0:9C) [13:54:55:232]: SHELL32::SHGetFolderPath returned: C:\Users\Public\Desktop
MSI(i) [13:54:55.239] | MSI (c) (B0:9C) [13:54:55:232]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI(i) [13:54:55.239] | MSI (c) (B0:9C) [13:54:55:232]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
MSI(i) [13:54:55.239] | MSI (c) (B0:9C) [13:54:55:232]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Desktop
MSI(i) [13:54:55.239] | MSI (c) (B0:9C) [13:54:55:233]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Templates
MSI(i) [13:54:55.239] | MSI (c) (B0:9C) [13:54:55:233]: SHELL32::SHGetFolderPath returned: C:\Windows\Fonts
MSI(i) [13:54:55.239] | MSI (c) (B0:9C) [13:54:55:233]: Note: 1: 2898 2: MS Sans Serif 3: MS Sans Serif 4: 0 5: 16
MSI(i) [13:54:55.239] | MSI (c) (B0:9C) [13:54:55:238]: MSI_LUA: Setting AdminUser property to 1 because this is the client or the user has already permitted elevation
MSI(i) [13:54:55.239] | MSI (c) (B0:9C) [13:54:55:238]: MSI_LUA: Setting MsiRunningElevated property to 1 because the install is already running elevated.
MSI(i) [13:54:55.239] | MSI (c) (B0:9C) [13:54:55:238]: PROPERTY CHANGE: Adding MsiRunningElevated property. Its value is '1'.
MSI(i) [13:54:55.239] | MSI (c) (B0:9C) [13:54:55:238]: PROPERTY CHANGE: Adding Privileged property. Its value is '1'.
MSI(i) [13:54:55.239] | MSI (c) (B0:9C) [13:54:55:238]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\MS Setup (ACME)\User Info 3: 2
MSI(i) [13:54:55.239] | MSI (c) (B0:9C) [13:54:55:238]: PROPERTY CHANGE: Adding USERNAME property. Its value is 'A Valued IT Customer'.
MSI(i) [13:54:55.239] | MSI (c) (B0:9C) [13:54:55:238]: PROPERTY CHANGE: Adding COMPANYNAME property. Its value is 'Intel Corporation'.
MSI(i) [13:54:55.239] | MSI (c) (B0:9C) [13:54:55:238]: PROPERTY CHANGE: Adding DATABASE property. Its value is 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\sep\sep.msi'.
MSI(i) [13:54:55.239] | MSI (c) (B0:9C) [13:54:55:238]: PROPERTY CHANGE: Adding OriginalDatabase property. Its value is 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\sep\sep.msi'.
MSI(i) [13:54:55.239] | MSI (c) (B0:9C) [13:54:55:238]: Machine policy value 'MsiDisableEmbeddedUI' is 0
MSI(i) [13:54:55.239] | MSI (c) (B0:9C) [13:54:55:238]: EEUI - Disabling MsiEmbeddedUI in quiet mode
MSI(i) [13:54:55.239] | === Logging started: 4/8/2014  13:54:55 ===
MSI(i) [13:54:55.239] | MSI (c) (B0:9C) [13:54:55:239]: Note: 1: 2205 2:  3: PatchPackage
MSI(i) [13:54:55.239] | MSI (c) (B0:9C) [13:54:55:239]: Machine policy value 'DisableRollback' is 0
MSI(i) [13:54:55.239] | MSI (c) (B0:9C) [13:54:55:239]: User policy value 'DisableRollback' is 0
MSI(i) [13:54:55.239] | MSI (c) (B0:9C) [13:54:55:239]: PROPERTY CHANGE: Adding UILevel property. Its value is '2'.
MSI(i) [13:54:55.239] | MSI (c) (B0:9C) [13:54:55:239]: Creating MSIHANDLE (43) of type 790537 for thread 3996
MSI(i) [13:54:55.239] | MSI (c) (B0:9C) [13:54:55:239]: MsiOpenPackageEx is returning 0
MSI(i) [13:54:55.239] | MSI (c) (B0:9C) [13:54:55:239]: Closing MSIHANDLE (43) of type 790537 for thread 3996
MSI(i) [13:54:55.239] | === Verbose logging stopped: 4/8/2014  13:54:55 ===
PSET(i) [13:54:55.247] | (4225.285): MsiOpenPackageEx(C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\sep\sep.msi)
MSI(i) [13:54:55.308] | === Verbose logging started: 4/8/2014  13:54:55  Build type: SHIP UNICODE 5.00.7601.00  Calling process: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\setup.exe ===
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:248]: SOFTWARE RESTRICTION POLICY: Verifying package --> 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\sep\sep.msi' against software restriction policy
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:248]: SOFTWARE RESTRICTION POLICY: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\sep\sep.msi has a digital signature
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:262]: SOFTWARE RESTRICTION POLICY: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\sep\sep.msi is permitted to run at the 'unrestricted' authorization level.
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:263]: Cloaking enabled.
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:263]: Attempting to enable all disabled privileges before calling Install on Server
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:263]: End dialog not enabled
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:263]: Original package ==> C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\sep\sep.msi
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:263]: Package we're running from ==> C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\sep\sep.msi
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:264]: Machine policy value 'DisableUserInstalls' is 0
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:265]: APPCOMPAT: Compatibility mode property overrides found.
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:265]: APPCOMPAT: looking for appcompat database entry with ProductCode '{F8081656-D251-4E20-80E8-1659BD636721}'.
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:265]: APPCOMPAT: no matching ProductCode found in database.
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:270]: MSCOREE not loaded loading copy from system32
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:274]: Machine policy value 'TransformsSecure' is 0
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:274]: User policy value 'TransformsAtSource' is 0
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:274]: Note: 1: 2262 2: File 3: -2147287038
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:274]: Note: 1: 2205 2:  3: MsiFileHash
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:274]: Machine policy value 'DisablePatch' is 0
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:275]: Machine policy value 'AllowLockdownPatch' is 0
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:275]: Machine policy value 'DisableLUAPatching' is 0
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:275]: Machine policy value 'DisableFlyWeightPatching' is 0
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:275]: Enabling baseline caching for this transaction since all active patches are MSI 3.0 style MSPs or at least one MSI 3.0 minor update patch is active
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:275]: APPCOMPAT: looking for appcompat database entry with ProductCode '{F8081656-D251-4E20-80E8-1659BD636721}'.
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:275]: APPCOMPAT: no matching ProductCode found in database.
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:275]: Transforms are not secure.
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:275]: PROPERTY CHANGE: Adding MsiLogFileLocation property. Its value is 'C:\Users\PCCA-PM\AppData\Local\Temp\MSIED31.tmp'.
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:275]: No Command Line.
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:275]: PROPERTY CHANGE: Adding PackageCode property. Its value is '{201DDC26-0CE0-477B-A268-2AC0FCF9CF3F}'.
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:275]: Product Code passed to Engine.Initialize:           '(none)'
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:275]: Product Code from property table before transforms: '{F8081656-D251-4E20-80E8-1659BD636721}'
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:275]: Product Code from property table after transforms:  '{F8081656-D251-4E20-80E8-1659BD636721}'
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:275]: Product not registered: beginning first-time install
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:275]: PROPERTY CHANGE: Adding ProductState property. Its value is '-1'.
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:275]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer 3: 2
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:276]: Entering CMsiConfigurationManager::SetLastUsedSource.
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:276]: User policy value 'SearchOrder' is 'nmu'
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:276]: Adding new sources is allowed.
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:276]: PROPERTY CHANGE: Adding PackagecodeChanging property. Its value is '1'.
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:276]: Package name extracted from package path: 'sep.msi'
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:276]: Package to be registered: 'sep.msi'
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:276]: Note: 1: 2262 2: AdminProperties 3: -2147287038
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:276]: Machine policy value 'DisableMsi' is 0
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:276]: Machine policy value 'AlwaysInstallElevated' is 0
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:276]: User policy value 'AlwaysInstallElevated' is 0
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:276]: Product installation will be elevated because user is admin and product is being installed per-machine.
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:276]: Running product '{F8081656-D251-4E20-80E8-1659BD636721}' with elevated privileges: Product is assigned.
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:277]: PROPERTY CHANGE: Adding MsiSystemRebootPending property. Its value is '1'.
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:277]: TRANSFORMS property is now:
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:277]: PROPERTY CHANGE: Adding VersionDatabase property. Its value is '200'.
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:277]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:277]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Favorites
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:277]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Network Shortcuts
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:277]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Documents
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:277]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:277]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Recent
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:277]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\SendTo
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:277]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Templates
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:277]: SHELL32::SHGetFolderPath returned: C:\ProgramData
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:277]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Local
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:277]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Pictures
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:277]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:277]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:277]: SHELL32::SHGetFolderPath returned: C:\Users\Public\Desktop
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:277]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:277]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:277]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Desktop
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:277]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Templates
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:277]: SHELL32::SHGetFolderPath returned: C:\Windows\Fonts
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:277]: Note: 1: 2898 2: MS Sans Serif 3: MS Sans Serif 4: 0 5: 16
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:283]: MSI_LUA: Setting AdminUser property to 1 because this is the client or the user has already permitted elevation
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:283]: MSI_LUA: Setting MsiRunningElevated property to 1 because the install is already running elevated.
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:283]: PROPERTY CHANGE: Adding MsiRunningElevated property. Its value is '1'.
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:283]: PROPERTY CHANGE: Adding Privileged property. Its value is '1'.
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:283]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\MS Setup (ACME)\User Info 3: 2
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:283]: PROPERTY CHANGE: Adding USERNAME property. Its value is 'A Valued IT Customer'.
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:283]: PROPERTY CHANGE: Adding COMPANYNAME property. Its value is 'Intel Corporation'.
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:283]: PROPERTY CHANGE: Adding DATABASE property. Its value is 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\sep\sep.msi'.
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:283]: PROPERTY CHANGE: Adding OriginalDatabase property. Its value is 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\sep\sep.msi'.
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:283]: Machine policy value 'MsiDisableEmbeddedUI' is 0
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:283]: EEUI - Disabling MsiEmbeddedUI in quiet mode
MSI(i) [13:54:55.308] | === Logging started: 4/8/2014  13:54:55 ===
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:283]: Note: 1: 2205 2:  3: PatchPackage
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:283]: Machine policy value 'DisableRollback' is 0
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:283]: User policy value 'DisableRollback' is 0
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:283]: PROPERTY CHANGE: Adding UILevel property. Its value is '2'.
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:284]: Creating MSIHANDLE (44) of type 790537 for thread 3996
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:284]: MsiOpenPackageEx is returning 0
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:284]: Creating MSIHANDLE (45) of type 790541 for thread 3996
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:284]: Closing MSIHANDLE (45) of type 790541 for thread 3996
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:284]: Doing action: AppSearch
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:284]: Note: 1: 2205 2:  3: ActionText
MSI(i) [13:54:55.308] | Action 13:54:55: AppSearch. Searching for installed applications
MSI(i) [13:54:55.308] | Action start 13:54:55: AppSearch.
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:285]: Note: 1: 2205 2:  3: AppSearch
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:285]: Note: 1: 2228 2:  3: AppSearch 4: SELECT `Property`, `Signature_` FROM `AppSearch`
MSI(i) [13:54:55.308] | Action ended 13:54:55: AppSearch. Return value 0.
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:285]: Doing action: CostInitialize
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:285]: Note: 1: 2205 2:  3: ActionText
MSI(i) [13:54:55.308] | Action 13:54:55: CostInitialize. Computing space requirements
MSI(i) [13:54:55.308] | Action start 13:54:55: CostInitialize.
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:287]: Machine policy value 'MaxPatchCacheSize' is 10
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:287]: Baseline: Sorting baselines for {F8081656-D251-4E20-80E8-1659BD636721}.
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:287]: Baseline: New baseline 13.1.0 from transaction.
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:287]: Baseline: Sorted order Native: Order 0.
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:287]: Baseline Data Table:
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:287]: ProductCode: {F8081656-D251-4E20-80E8-1659BD636721} Version: 13.1.0 Attributes: 0 PatchId: Native BaselineId: -2147483648 Order: 0
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:287]: Baseline File Table:
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:287]: PROPERTY CHANGE: Adding ROOTDRIVE property. Its value is 'C:\'.
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:287]: PROPERTY CHANGE: Adding CostingComplete property. Its value is '0'.
MSI(i) [13:54:55.308] | Action ended 13:54:55: CostInitialize. Return value 1.
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:288]: Doing action: FileCost
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:288]: Note: 1: 2205 2:  3: ActionText
MSI(i) [13:54:55.308] | Action 13:54:55: FileCost. Computing space requirements
MSI(i) [13:54:55.308] | Action start 13:54:55: FileCost.
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:289]: Note: 1: 2205 2:  3: MsiAssembly
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:289]: Note: 1: 2205 2:  3: Registry
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:289]: Note: 1: 2205 2:  3: Class
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:289]: Note: 1: 2205 2:  3: Extension
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:289]: Note: 1: 2205 2:  3: TypeLib
MSI(i) [13:54:55.308] | Action ended 13:54:55: FileCost. Return value 1.
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:289]: Doing action: CostFinalize
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:289]: Note: 1: 2205 2:  3: ActionText
MSI(i) [13:54:55.308] | Action 13:54:55: CostFinalize. Computing space requirements
MSI(i) [13:54:55.308] | Action start 13:54:55: CostFinalize.
MSI(i) [13:54:55.308] | MSI (c) (B0:9C) [13:54:55:290]: PROPERTY CHANGE: Adding OutOfDiskSpace property. Its value is '0'.
MSI(i) [13:54:55.309] | MSI (c) (B0:9C) [13:54:55:290]: PROPERTY CHANGE: Adding OutOfNoRbDiskSpace property. Its value is '0'.
MSI(i) [13:54:55.309] | MSI (c) (B0:9C) [13:54:55:290]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceAvailable property. Its value is '0'.
MSI(i) [13:54:55.309] | MSI (c) (B0:9C) [13:54:55:290]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRequired property. Its value is '0'.
MSI(i) [13:54:55.309] | MSI (c) (B0:9C) [13:54:55:290]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRemaining property. Its value is '0'.
MSI(i) [13:54:55.309] | MSI (c) (B0:9C) [13:54:55:290]: Note: 1: 2205 2:  3: Patch
MSI(i) [13:54:55.309] | MSI (c) (B0:9C) [13:54:55:290]: Note: 1: 2205 2:  3: Condition
MSI(i) [13:54:55.309] | MSI (c) (B0:9C) [13:54:55:291]: PROPERTY CHANGE: Adding TARGETDIR property. Its value is 'C:\'.
MSI(i) [13:54:55.309] | MSI (c) (B0:9C) [13:54:55:291]: PROPERTY CHANGE: Adding BASEINSTALLDIR property. Its value is 'C:\Program Files (x86)\Intel\'.
MSI(i) [13:54:55.309] | MSI (c) (B0:9C) [13:54:55:291]: PROPERTY CHANGE: Adding INSTALLDIR property. Its value is 'C:\Program Files (x86)\Intel\Amplifier XE 2013\'.
MSI(i) [13:54:55.309] | MSI (c) (B0:9C) [13:54:55:291]: Target path resolution complete. Dumping Directory table...
MSI(i) [13:54:55.309] | MSI (c) (B0:9C) [13:54:55:291]: Note: target paths subject to change (via custom actions or browsing)
MSI(i) [13:54:55.309] | MSI (c) (B0:9C) [13:54:55:291]: Dir (target): Key: TARGETDIR    , Object: C:\
MSI(i) [13:54:55.309] | MSI (c) (B0:9C) [13:54:55:291]: Dir (target): Key: ProgramFilesFolder    , Object: C:\Program Files (x86)\
MSI(i) [13:54:55.309] | MSI (c) (B0:9C) [13:54:55:291]: Dir (target): Key: BASEINSTALLDIR    , Object: C:\Program Files (x86)\Intel\
MSI(i) [13:54:55.309] | MSI (c) (B0:9C) [13:54:55:291]: Dir (target): Key: INSTALLDIR    , Object: C:\Program Files (x86)\Intel\Amplifier XE 2013\
MSI(i) [13:54:55.309] | MSI (c) (B0:9C) [13:54:55:291]: PROPERTY CHANGE: Adding INSTALLLEVEL property. Its value is '1'.
MSI(i) [13:54:55.309] | Action ended 13:54:55: CostFinalize. Return value 1.
MSI(i) [13:54:55.309] | MSI (c) (B0:9C) [13:54:55:291]: Doing action: InstallValidate
MSI(i) [13:54:55.309] | MSI (c) (B0:9C) [13:54:55:291]: Note: 1: 2205 2:  3: ActionText
MSI(i) [13:54:55.309] | Action 13:54:55: InstallValidate. Validating install
MSI(i) [13:54:55.309] | Action start 13:54:55: InstallValidate.
MSI(i) [13:54:55.309] | MSI (c) (B0:9C) [13:54:55:292]: Note: 1: 2205 2:  3: Dialog
MSI(i) [13:54:55.309] | MSI (c) (B0:9C) [13:54:55:292]: Feature: CoreAppFiles; Installed: Absent;   Request: Local;   Action: Local
MSI(i) [13:54:55.309] | MSI (c) (B0:9C) [13:54:55:292]: Component: CommonInstallRoot; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.309] | MSI (c) (B0:9C) [13:54:55:292]: Component: ProductFamilyAnchor; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.309] | MSI (c) (B0:9C) [13:54:55:292]: Component: ProductVersionAnchor; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.309] | MSI (c) (B0:9C) [13:54:55:292]: Note: 1: 2205 2:  3: Registry
MSI(i) [13:54:55.309] | MSI (c) (B0:9C) [13:54:55:292]: Note: 1: 2205 2:  3: BindImage
MSI(i) [13:54:55.309] | MSI (c) (B0:9C) [13:54:55:292]: Note: 1: 2205 2:  3: ProgId
MSI(i) [13:54:55.309] | MSI (c) (B0:9C) [13:54:55:292]: Note: 1: 2205 2:  3: PublishComponent
MSI(i) [13:54:55.309] | MSI (c) (B0:9C) [13:54:55:292]: Note: 1: 2205 2:  3: SelfReg
MSI(i) [13:54:55.309] | MSI (c) (B0:9C) [13:54:55:292]: Note: 1: 2205 2:  3: Extension
MSI(i) [13:54:55.309] | MSI (c) (B0:9C) [13:54:55:292]: Note: 1: 2205 2:  3: Font
MSI(i) [13:54:55.309] | MSI (c) (B0:9C) [13:54:55:292]: Note: 1: 2205 2:  3: Shortcut
MSI(i) [13:54:55.309] | MSI (c) (B0:9C) [13:54:55:292]: Note: 1: 2205 2:  3: Class
MSI(i) [13:54:55.309] | MSI (c) (B0:9C) [13:54:55:292]: Note: 1: 2205 2:  3: Icon
MSI(i) [13:54:55.309] | MSI (c) (B0:9C) [13:54:55:292]: Note: 1: 2205 2:  3: TypeLib
MSI(i) [13:54:55.309] | MSI (c) (B0:9C) [13:54:55:292]: Note: 1: 2205 2:  3: MsiAssembly
MSI(i) [13:54:55.309] | MSI (c) (B0:9C) [13:54:55:292]: Note: 1: 2228 2:  3: MsiAssembly 4:  SELECT `MsiAssembly`.`Attributes`, `MsiAssembly`.`File_Application`, `MsiAssembly`.`File_Manifest`,  `Component`.`KeyPath` FROM `MsiAssembly`, `Component` WHERE  `MsiAssembly`.`Component_` = `Component`.`Component` AND `MsiAssembly`.`Component_` = ?
MSI(i) [13:54:55.309] | MSI (c) (B0:9C) [13:54:55:292]: PROPERTY CHANGE: Modifying CostingComplete property. Its current value is '0'. Its new value: '1'.
MSI(i) [13:54:55.309] | MSI (c) (B0:9C) [13:54:55:293]: Note: 1: 2727 2:
MSI(i) [13:54:55.309] | MSI (c) (B0:9C) [13:54:55:307]: Note: 1: 2727 2:
MSI(i) [13:54:55.309] | Action ended 13:54:55: InstallValidate. Return value 1.
MSI(i) [13:54:55.309] | MSI (c) (B0:9C) [13:54:55:307]: Creating MSIHANDLE (46) of type 790541 for thread 3996
MSI(i) [13:54:55.309] | MSI (c) (B0:9C) [13:54:55:307]: Creating MSIHANDLE (47) of type 790540 for thread 3996
MSI(i) [13:54:55.309] | MSI (c) (B0:9C) [13:54:55:307]: Creating MSIHANDLE (48) of type 790531 for thread 3996
MSI(i) [13:54:55.309] | MSI (c) (B0:9C) [13:54:55:307]: Note: 1: 2205 2:  3: Condition
MSI(i) [13:54:55.309] | MSI (c) (B0:9C) [13:54:55:307]: Note: 1: 2228 2:  3: Condition 4: SELECT * FROM Condition WHERE Feature_ = 'CoreAppFiles'
MSI(i) [13:54:55.309] | MSI (c) (B0:9C) [13:54:55:308]: Creating MSIHANDLE (49) of type 790540 for thread 3996
MSI(i) [13:54:55.309] | MSI (c) (B0:9C) [13:54:55:308]: Closing MSIHANDLE (49) of type 790540 for thread 3996
MSI(i) [13:54:55.309] | MSI (c) (B0:9C) [13:54:55:308]: Closing MSIHANDLE (48) of type 790531 for thread 3996
MSI(i) [13:54:55.309] | MSI (c) (B0:9C) [13:54:55:308]: Closing MSIHANDLE (47) of type 790540 for thread 3996
MSI(i) [13:54:55.309] | MSI (c) (B0:9C) [13:54:55:308]: Closing MSIHANDLE (46) of type 790541 for thread 3996
MSI(i) [13:54:55.309] | MSI (c) (B0:9C) [13:54:55:308]: Leaked MSIHANDLE (44) of type 790537 for thread 3996
MSI(i) [13:54:55.309] | === Verbose logging stopped: 4/8/2014  13:54:55 ===
PSET(i) [13:54:55.317] | (4225.1904): Dependency {ACD97E2A-090D-46ea-9983-6E44BCA28575} always show dialog
PSET(i) [13:54:55.317] | (4225.1904): Dependency {8AA98789-C136-4adc-8269-86F3C222906F} always show dialog
PSET(i) [13:54:55.318] | (4225.2963): MsiOpenPackageEx(C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs11-integration.msi)
MSI(i) [13:54:55.357] | === Verbose logging started: 4/8/2014  13:54:55  Build type: SHIP UNICODE 5.00.7601.00  Calling process: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\setup.exe ===
MSI(i) [13:54:55.357] | MSI (c) (B0:9C) [13:54:55:319]: SOFTWARE RESTRICTION POLICY: Verifying package --> 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs11-integration.msi' against software restriction policy
MSI(i) [13:54:55.357] | MSI (c) (B0:9C) [13:54:55:319]: SOFTWARE RESTRICTION POLICY: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs11-integration.msi has a digital signature
MSI(i) [13:54:55.357] | MSI (c) (B0:9C) [13:54:55:335]: SOFTWARE RESTRICTION POLICY: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs11-integration.msi is permitted to run at the 'unrestricted' authorization level.
MSI(i) [13:54:55.357] | MSI (c) (B0:9C) [13:54:55:336]: Cloaking enabled.
MSI(i) [13:54:55.357] | MSI (c) (B0:9C) [13:54:55:336]: Attempting to enable all disabled privileges before calling Install on Server
MSI(i) [13:54:55.357] | MSI (c) (B0:9C) [13:54:55:336]: End dialog not enabled
MSI(i) [13:54:55.357] | MSI (c) (B0:9C) [13:54:55:337]: Original package ==> C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs11-integration.msi
MSI(i) [13:54:55.357] | MSI (c) (B0:9C) [13:54:55:337]: Package we're running from ==> C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs11-integration.msi
MSI(i) [13:54:55.357] | MSI (c) (B0:9C) [13:54:55:338]: APPCOMPAT: Compatibility mode property overrides found.
MSI(i) [13:54:55.357] | MSI (c) (B0:9C) [13:54:55:338]: APPCOMPAT: looking for appcompat database entry with ProductCode '{CB6E4A97-57E7-4D4D-BE5F-049DBD5380FB}'.
MSI(i) [13:54:55.357] | MSI (c) (B0:9C) [13:54:55:338]: APPCOMPAT: no matching ProductCode found in database.
MSI(i) [13:54:55.357] | MSI (c) (B0:9C) [13:54:55:343]: MSCOREE not loaded loading copy from system32
MSI(i) [13:54:55.357] | MSI (c) (B0:9C) [13:54:55:346]: Machine policy value 'TransformsSecure' is 0
MSI(i) [13:54:55.357] | MSI (c) (B0:9C) [13:54:55:346]: User policy value 'TransformsAtSource' is 0
MSI(i) [13:54:55.357] | MSI (c) (B0:9C) [13:54:55:347]: Machine policy value 'DisablePatch' is 0
MSI(i) [13:54:55.357] | MSI (c) (B0:9C) [13:54:55:347]: Machine policy value 'AllowLockdownPatch' is 0
MSI(i) [13:54:55.357] | MSI (c) (B0:9C) [13:54:55:347]: Machine policy value 'DisableLUAPatching' is 0
MSI(i) [13:54:55.357] | MSI (c) (B0:9C) [13:54:55:347]: Machine policy value 'DisableFlyWeightPatching' is 0
MSI(i) [13:54:55.357] | MSI (c) (B0:9C) [13:54:55:347]: Enabling baseline caching for this transaction since all active patches are MSI 3.0 style MSPs or at least one MSI 3.0 minor update patch is active
MSI(i) [13:54:55.357] | MSI (c) (B0:9C) [13:54:55:348]: APPCOMPAT: looking for appcompat database entry with ProductCode '{CB6E4A97-57E7-4D4D-BE5F-049DBD5380FB}'.
MSI(i) [13:54:55.357] | MSI (c) (B0:9C) [13:54:55:348]: APPCOMPAT: no matching ProductCode found in database.
MSI(i) [13:54:55.357] | MSI (c) (B0:9C) [13:54:55:348]: Transforms are not secure.
MSI(i) [13:54:55.357] | MSI (c) (B0:9C) [13:54:55:348]: PROPERTY CHANGE: Adding MsiLogFileLocation property. Its value is 'C:\Users\PCCA-PM\AppData\Local\Temp\MSIED31.tmp'.
MSI(i) [13:54:55.357] | MSI (c) (B0:9C) [13:54:55:348]: No Command Line.
MSI(i) [13:54:55.357] | MSI (c) (B0:9C) [13:54:55:348]: PROPERTY CHANGE: Adding PackageCode property. Its value is '{48FA2B8E-7BDC-4397-B438-CF8C749F1392}'.
MSI(i) [13:54:55.357] | MSI (c) (B0:9C) [13:54:55:348]: Product Code passed to Engine.Initialize:           '(none)'
MSI(i) [13:54:55.357] | MSI (c) (B0:9C) [13:54:55:348]: Product Code from property table before transforms: '{CB6E4A97-57E7-4D4D-BE5F-049DBD5380FB}'
MSI(i) [13:54:55.357] | MSI (c) (B0:9C) [13:54:55:348]: Product Code from property table after transforms:  '{CB6E4A97-57E7-4D4D-BE5F-049DBD5380FB}'
MSI(i) [13:54:55.357] | MSI (c) (B0:9C) [13:54:55:348]: Product not registered: beginning first-time install
MSI(i) [13:54:55.357] | MSI (c) (B0:9C) [13:54:55:348]: PROPERTY CHANGE: Adding ProductState property. Its value is '-1'.
MSI(i) [13:54:55.357] | MSI (c) (B0:9C) [13:54:55:348]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer 3: 2
MSI(i) [13:54:55.357] | MSI (c) (B0:9C) [13:54:55:348]: Entering CMsiConfigurationManager::SetLastUsedSource.
MSI(i) [13:54:55.357] | MSI (c) (B0:9C) [13:54:55:348]: User policy value 'SearchOrder' is 'nmu'
MSI(i) [13:54:55.357] | MSI (c) (B0:9C) [13:54:55:348]: Adding new sources is allowed.
MSI(i) [13:54:55.357] | MSI (c) (B0:9C) [13:54:55:348]: PROPERTY CHANGE: Adding PackagecodeChanging property. Its value is '1'.
MSI(i) [13:54:55.357] | MSI (c) (B0:9C) [13:54:55:348]: Package name extracted from package path: 'vs11-integration.msi'
MSI(i) [13:54:55.357] | MSI (c) (B0:9C) [13:54:55:348]: Package to be registered: 'vs11-integration.msi'
MSI(i) [13:54:55.357] | MSI (c) (B0:9C) [13:54:55:348]: Note: 1: 2205 2:  3: Error
MSI(i) [13:54:55.357] | MSI (c) (B0:9C) [13:54:55:349]: Note: 1: 2262 2: AdminProperties 3: -2147287038
MSI(i) [13:54:55.357] | MSI (c) (B0:9C) [13:54:55:349]: Machine policy value 'DisableMsi' is 0
MSI(i) [13:54:55.357] | MSI (c) (B0:9C) [13:54:55:349]: Machine policy value 'AlwaysInstallElevated' is 0
MSI(i) [13:54:55.357] | MSI (c) (B0:9C) [13:54:55:349]: User policy value 'AlwaysInstallElevated' is 0
MSI(i) [13:54:55.357] | MSI (c) (B0:9C) [13:54:55:349]: Product installation will be elevated because user is admin and product is being installed per-machine.
MSI(i) [13:54:55.357] | MSI (c) (B0:9C) [13:54:55:349]: Running product '{CB6E4A97-57E7-4D4D-BE5F-049DBD5380FB}' with elevated privileges: Product is assigned.
MSI(i) [13:54:55.357] | MSI (c) (B0:9C) [13:54:55:349]: PROPERTY CHANGE: Adding MsiSystemRebootPending property. Its value is '1'.
MSI(i) [13:54:55.357] | MSI (c) (B0:9C) [13:54:55:349]: TRANSFORMS property is now:
MSI(i) [13:54:55.357] | MSI (c) (B0:9C) [13:54:55:349]: PROPERTY CHANGE: Adding VersionDatabase property. Its value is '200'.
MSI(i) [13:54:55.357] | MSI (c) (B0:9C) [13:54:55:350]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming
MSI(i) [13:54:55.357] | MSI (c) (B0:9C) [13:54:55:350]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Favorites
MSI(i) [13:54:55.357] | MSI (c) (B0:9C) [13:54:55:350]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Network Shortcuts
MSI(i) [13:54:55.357] | MSI (c) (B0:9C) [13:54:55:350]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Documents
MSI(i) [13:54:55.357] | MSI (c) (B0:9C) [13:54:55:350]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
MSI(i) [13:54:55.357] | MSI (c) (B0:9C) [13:54:55:350]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Recent
MSI(i) [13:54:55.357] | MSI (c) (B0:9C) [13:54:55:350]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\SendTo
MSI(i) [13:54:55.357] | MSI (c) (B0:9C) [13:54:55:350]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Templates
MSI(i) [13:54:55.357] | MSI (c) (B0:9C) [13:54:55:350]: SHELL32::SHGetFolderPath returned: C:\ProgramData
MSI(i) [13:54:55.357] | MSI (c) (B0:9C) [13:54:55:350]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Local
MSI(i) [13:54:55.357] | MSI (c) (B0:9C) [13:54:55:350]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Pictures
MSI(i) [13:54:55.357] | MSI (c) (B0:9C) [13:54:55:350]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI(i) [13:54:55.357] | MSI (c) (B0:9C) [13:54:55:350]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
MSI(i) [13:54:55.357] | MSI (c) (B0:9C) [13:54:55:350]: SHELL32::SHGetFolderPath returned: C:\Users\Public\Desktop
MSI(i) [13:54:55.357] | MSI (c) (B0:9C) [13:54:55:350]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI(i) [13:54:55.357] | MSI (c) (B0:9C) [13:54:55:350]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
MSI(i) [13:54:55.357] | MSI (c) (B0:9C) [13:54:55:350]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Desktop
MSI(i) [13:54:55.357] | MSI (c) (B0:9C) [13:54:55:350]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Templates
MSI(i) [13:54:55.357] | MSI (c) (B0:9C) [13:54:55:350]: SHELL32::SHGetFolderPath returned: C:\Windows\Fonts
MSI(i) [13:54:55.357] | MSI (c) (B0:9C) [13:54:55:350]: Note: 1: 2898 2: MS Sans Serif 3: MS Sans Serif 4: 0 5: 16
MSI(i) [13:54:55.357] | MSI (c) (B0:9C) [13:54:55:355]: MSI_LUA: Setting AdminUser property to 1 because this is the client or the user has already permitted elevation
MSI(i) [13:54:55.357] | MSI (c) (B0:9C) [13:54:55:355]: MSI_LUA: Setting MsiRunningElevated property to 1 because the install is already running elevated.
MSI(i) [13:54:55.357] | MSI (c) (B0:9C) [13:54:55:355]: PROPERTY CHANGE: Adding MsiRunningElevated property. Its value is '1'.
MSI(i) [13:54:55.357] | MSI (c) (B0:9C) [13:54:55:355]: PROPERTY CHANGE: Adding Privileged property. Its value is '1'.
MSI(i) [13:54:55.357] | MSI (c) (B0:9C) [13:54:55:356]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\MS Setup (ACME)\User Info 3: 2
MSI(i) [13:54:55.357] | MSI (c) (B0:9C) [13:54:55:356]: PROPERTY CHANGE: Adding USERNAME property. Its value is 'A Valued IT Customer'.
MSI(i) [13:54:55.357] | MSI (c) (B0:9C) [13:54:55:356]: PROPERTY CHANGE: Adding COMPANYNAME property. Its value is 'Intel Corporation'.
MSI(i) [13:54:55.357] | MSI (c) (B0:9C) [13:54:55:356]: PROPERTY CHANGE: Adding DATABASE property. Its value is 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs11-integration.msi'.
MSI(i) [13:54:55.357] | MSI (c) (B0:9C) [13:54:55:356]: PROPERTY CHANGE: Adding OriginalDatabase property. Its value is 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs11-integration.msi'.
MSI(i) [13:54:55.357] | MSI (c) (B0:9C) [13:54:55:356]: Machine policy value 'MsiDisableEmbeddedUI' is 0
MSI(i) [13:54:55.357] | MSI (c) (B0:9C) [13:54:55:356]: EEUI - Disabling MsiEmbeddedUI in quiet mode
MSI(i) [13:54:55.357] | === Logging started: 4/8/2014  13:54:55 ===
MSI(i) [13:54:55.357] | MSI (c) (B0:9C) [13:54:55:356]: Note: 1: 2205 2:  3: PatchPackage
MSI(i) [13:54:55.357] | MSI (c) (B0:9C) [13:54:55:356]: Machine policy value 'DisableRollback' is 0
MSI(i) [13:54:55.357] | MSI (c) (B0:9C) [13:54:55:356]: User policy value 'DisableRollback' is 0
MSI(i) [13:54:55.357] | MSI (c) (B0:9C) [13:54:55:356]: PROPERTY CHANGE: Adding UILevel property. Its value is '2'.
MSI(i) [13:54:55.357] | MSI (c) (B0:9C) [13:54:55:356]: Creating MSIHANDLE (50) of type 790537 for thread 3996
MSI(i) [13:54:55.357] | MSI (c) (B0:9C) [13:54:55:356]: MsiOpenPackageEx is returning 0
MSI(i) [13:54:55.357] | MSI (c) (B0:9C) [13:54:55:356]: Closing MSIHANDLE (50) of type 790537 for thread 3996
MSI(i) [13:54:55.357] | === Verbose logging stopped: 4/8/2014  13:54:55 ===
PSET(i) [13:54:55.365] | (4225.285): MsiOpenPackageEx(C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs11-integration.msi)
MSI(i) [13:54:55.429] | === Verbose logging started: 4/8/2014  13:54:55  Build type: SHIP UNICODE 5.00.7601.00  Calling process: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\setup.exe ===
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:367]: SOFTWARE RESTRICTION POLICY: Verifying package --> 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs11-integration.msi' against software restriction policy
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:367]: SOFTWARE RESTRICTION POLICY: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs11-integration.msi has a digital signature
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:383]: SOFTWARE RESTRICTION POLICY: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs11-integration.msi is permitted to run at the 'unrestricted' authorization level.
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:383]: Cloaking enabled.
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:383]: Attempting to enable all disabled privileges before calling Install on Server
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:384]: End dialog not enabled
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:384]: Original package ==> C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs11-integration.msi
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:384]: Package we're running from ==> C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs11-integration.msi
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:384]: Machine policy value 'DisableUserInstalls' is 0
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:385]: APPCOMPAT: Compatibility mode property overrides found.
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:385]: APPCOMPAT: looking for appcompat database entry with ProductCode '{CB6E4A97-57E7-4D4D-BE5F-049DBD5380FB}'.
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:385]: APPCOMPAT: no matching ProductCode found in database.
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:390]: MSCOREE not loaded loading copy from system32
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:393]: Machine policy value 'TransformsSecure' is 0
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:393]: User policy value 'TransformsAtSource' is 0
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:394]: Machine policy value 'DisablePatch' is 0
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:394]: Machine policy value 'AllowLockdownPatch' is 0
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:394]: Machine policy value 'DisableLUAPatching' is 0
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:394]: Machine policy value 'DisableFlyWeightPatching' is 0
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:394]: Enabling baseline caching for this transaction since all active patches are MSI 3.0 style MSPs or at least one MSI 3.0 minor update patch is active
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:394]: APPCOMPAT: looking for appcompat database entry with ProductCode '{CB6E4A97-57E7-4D4D-BE5F-049DBD5380FB}'.
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:394]: APPCOMPAT: no matching ProductCode found in database.
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:394]: Transforms are not secure.
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:394]: PROPERTY CHANGE: Adding MsiLogFileLocation property. Its value is 'C:\Users\PCCA-PM\AppData\Local\Temp\MSIED31.tmp'.
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:394]: No Command Line.
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:394]: PROPERTY CHANGE: Adding PackageCode property. Its value is '{48FA2B8E-7BDC-4397-B438-CF8C749F1392}'.
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:394]: Product Code passed to Engine.Initialize:           '(none)'
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:394]: Product Code from property table before transforms: '{CB6E4A97-57E7-4D4D-BE5F-049DBD5380FB}'
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:394]: Product Code from property table after transforms:  '{CB6E4A97-57E7-4D4D-BE5F-049DBD5380FB}'
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:394]: Product not registered: beginning first-time install
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:394]: PROPERTY CHANGE: Adding ProductState property. Its value is '-1'.
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:395]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer 3: 2
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:395]: Entering CMsiConfigurationManager::SetLastUsedSource.
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:395]: User policy value 'SearchOrder' is 'nmu'
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:395]: Adding new sources is allowed.
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:395]: PROPERTY CHANGE: Adding PackagecodeChanging property. Its value is '1'.
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:395]: Package name extracted from package path: 'vs11-integration.msi'
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:395]: Package to be registered: 'vs11-integration.msi'
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:395]: Note: 1: 2205 2:  3: Error
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:395]: Note: 1: 2262 2: AdminProperties 3: -2147287038
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:395]: Machine policy value 'DisableMsi' is 0
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:395]: Machine policy value 'AlwaysInstallElevated' is 0
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:396]: User policy value 'AlwaysInstallElevated' is 0
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:396]: Product installation will be elevated because user is admin and product is being installed per-machine.
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:396]: Running product '{CB6E4A97-57E7-4D4D-BE5F-049DBD5380FB}' with elevated privileges: Product is assigned.
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:396]: PROPERTY CHANGE: Adding MsiSystemRebootPending property. Its value is '1'.
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:396]: TRANSFORMS property is now:
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:396]: PROPERTY CHANGE: Adding VersionDatabase property. Its value is '200'.
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:396]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:396]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Favorites
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:396]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Network Shortcuts
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:396]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Documents
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:396]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:396]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Recent
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:396]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\SendTo
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:396]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Templates
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:396]: SHELL32::SHGetFolderPath returned: C:\ProgramData
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:396]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Local
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:396]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Pictures
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:396]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:396]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:396]: SHELL32::SHGetFolderPath returned: C:\Users\Public\Desktop
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:396]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:396]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:396]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Desktop
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:396]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Templates
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:397]: SHELL32::SHGetFolderPath returned: C:\Windows\Fonts
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:397]: Note: 1: 2898 2: MS Sans Serif 3: MS Sans Serif 4: 0 5: 16
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:402]: MSI_LUA: Setting AdminUser property to 1 because this is the client or the user has already permitted elevation
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:402]: MSI_LUA: Setting MsiRunningElevated property to 1 because the install is already running elevated.
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:402]: PROPERTY CHANGE: Adding MsiRunningElevated property. Its value is '1'.
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:402]: PROPERTY CHANGE: Adding Privileged property. Its value is '1'.
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:402]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\MS Setup (ACME)\User Info 3: 2
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:402]: PROPERTY CHANGE: Adding USERNAME property. Its value is 'A Valued IT Customer'.
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:402]: PROPERTY CHANGE: Adding COMPANYNAME property. Its value is 'Intel Corporation'.
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:402]: PROPERTY CHANGE: Adding DATABASE property. Its value is 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs11-integration.msi'.
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:402]: PROPERTY CHANGE: Adding OriginalDatabase property. Its value is 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs11-integration.msi'.
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:402]: Machine policy value 'MsiDisableEmbeddedUI' is 0
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:402]: EEUI - Disabling MsiEmbeddedUI in quiet mode
MSI(i) [13:54:55.429] | === Logging started: 4/8/2014  13:54:55 ===
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:402]: Note: 1: 2205 2:  3: PatchPackage
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:402]: Machine policy value 'DisableRollback' is 0
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:402]: User policy value 'DisableRollback' is 0
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:402]: PROPERTY CHANGE: Adding UILevel property. Its value is '2'.
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:403]: Creating MSIHANDLE (51) of type 790537 for thread 3996
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:403]: MsiOpenPackageEx is returning 0
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:403]: Creating MSIHANDLE (52) of type 790541 for thread 3996
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:403]: Closing MSIHANDLE (52) of type 790541 for thread 3996
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:403]: Doing action: AppSearch
MSI(i) [13:54:55.429] | Action 13:54:55: AppSearch. Searching for installed applications
MSI(i) [13:54:55.429] | Action start 13:54:55: AppSearch.
MSI(i) [13:54:55.429] | AppSearch: Property: VS2011DIR.CB8456D7_A5A6_433A_9944_81F5DB2663E7, Signature: SIG_VS2011_DIR.CB8456D7_A5A6_433A_9944_81F5DB2663E7
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:404]: Note: 1: 2262 2: Signature 3: -2147287038
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:404]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE32\SOFTWARE\Microsoft\VisualStudio\11.0\Setup\VS 3: 2
MSI(i) [13:54:55.429] | AppSearch: Property: VS2010DIR.CB8456D7_A5A6_433A_9944_81F5DB2663E7, Signature: SIG_VS2010_DIR.CB8456D7_A5A6_433A_9944_81F5DB2663E7
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:405]: Note: 1: 2262 2: Signature 3: -2147287038
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:405]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE32\SOFTWARE\Microsoft\VisualStudio\10.0\Setup\VS 3: 2
MSI(i) [13:54:55.429] | AppSearch: Property: DEVENV_EXE_2008.C4A469D8_5FD7_462C_AAF9_27CC6BDF6210, Signature: RL_DevenvExe_2008.C4A469D8_5FD7_462C_AAF9_27CC6BDF6210
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:405]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE32\SOFTWARE\Microsoft\VisualStudio\9.0\Setup\VS 3: 2
MSI(i) [13:54:55.429] | AppSearch: Property: DEVENV_EXE_2010.C4A469D8_5FD7_462C_AAF9_27CC6BDF6210, Signature: RL_DevenvExe_2010.C4A469D8_5FD7_462C_AAF9_27CC6BDF6210
MSI(i) [13:54:55.429] | AppSearch: Property: DEVENV_EXE_2011.C4A469D8_5FD7_462C_AAF9_27CC6BDF6210, Signature: RL_DevenvExe_2011.C4A469D8_5FD7_462C_AAF9_27CC6BDF6210
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:405]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE32\SOFTWARE\Microsoft\VisualStudio\11.0\Setup\VS 3: 2
MSI(i) [13:54:55.429] | Action ended 13:54:55: AppSearch. Return value 1.
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:405]: Doing action: CostInitialize
MSI(i) [13:54:55.429] | Action 13:54:55: CostInitialize. Computing space requirements
MSI(i) [13:54:55.429] | Action start 13:54:55: CostInitialize.
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:406]: Machine policy value 'MaxPatchCacheSize' is 10
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:406]: Baseline: Sorting baselines for {CB6E4A97-57E7-4D4D-BE5F-049DBD5380FB}.
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:406]: Baseline: New baseline 13.1.5000 from transaction.
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:406]: Baseline: Sorted order Native: Order 0.
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:406]: Baseline Data Table:
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:406]: ProductCode: {CB6E4A97-57E7-4D4D-BE5F-049DBD5380FB} Version: 13.1.5000 Attributes: 0 PatchId: Native BaselineId: -2147483648 Order: 0
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:406]: Baseline File Table:
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:407]: PROPERTY CHANGE: Adding ROOTDRIVE property. Its value is 'C:\'.
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:407]: PROPERTY CHANGE: Adding CostingComplete property. Its value is '0'.
MSI(i) [13:54:55.429] | Action ended 13:54:55: CostInitialize. Return value 1.
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:407]: Doing action: FileCost
MSI(i) [13:54:55.429] | Action 13:54:55: FileCost. Computing space requirements
MSI(i) [13:54:55.429] | Action start 13:54:55: FileCost.
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:409]: Note: 1: 2205 2:  3: MsiAssembly
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:409]: Note: 1: 2205 2:  3: Class
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:409]: Note: 1: 2205 2:  3: Extension
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:409]: Note: 1: 2205 2:  3: TypeLib
MSI(i) [13:54:55.429] | Action ended 13:54:55: FileCost. Return value 1.
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:409]: Doing action: CostFinalize
MSI(i) [13:54:55.429] | Action 13:54:55: CostFinalize. Computing space requirements
MSI(i) [13:54:55.429] | Action start 13:54:55: CostFinalize.
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:410]: PROPERTY CHANGE: Adding OutOfDiskSpace property. Its value is '0'.
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:410]: PROPERTY CHANGE: Adding OutOfNoRbDiskSpace property. Its value is '0'.
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:410]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceAvailable property. Its value is '0'.
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:410]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRequired property. Its value is '0'.
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:410]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRemaining property. Its value is '0'.
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:410]: Note: 1: 2205 2:  3: Patch
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:410]: Note: 1: 2205 2:  3: Condition
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:410]: PROPERTY CHANGE: Adding TARGETDIR property. Its value is 'C:\'.
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:410]: PROPERTY CHANGE: Adding VS11_REMOTE_DEBUGGER_X64_DIR property. Its value is 'C:\'.
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:410]: PROPERTY CHANGE: Adding VS11_DEBUGER_DIR property. Its value is 'C:\'.
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:410]: PROPERTY CHANGE: Adding INSTALLDIR property. Its value is 'C:\'.
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:410]: PROPERTY CHANGE: Adding CommonFilesFolder.C4A469D8_5FD7_462C_AAF9_27CC6BDF6210 property. Its value is 'C:\'.
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:410]: PROPERTY CHANGE: Adding CmnIntel.C4A469D8_5FD7_462C_AAF9_27CC6BDF6210 property. Its value is 'C:\Intel\'.
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:410]: PROPERTY CHANGE: Adding CmnIntelHEBundle.C4A469D8_5FD7_462C_AAF9_27CC6BDF6210 property. Its value is 'C:\Intel\Parallel Studio XE 2013\'.
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:410]: PROPERTY CHANGE: Adding HEBundleMenuDir.C4A469D8_5FD7_462C_AAF9_27CC6BDF6210 property. Its value is 'C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Intel Parallel Studio XE 2013\'.
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:411]: PROPERTY CHANGE: Adding CommonFilesFolder.95C3848C_D156_4249_942C_7A8A0976584F property. Its value is 'C:\'.
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:411]: PROPERTY CHANGE: Adding CmnIntel.95C3848C_D156_4249_942C_7A8A0976584F property. Its value is 'C:\Intel\'.
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:411]: PROPERTY CHANGE: Adding CmnIntelHEBundle.95C3848C_D156_4249_942C_7A8A0976584F property. Its value is 'C:\Intel\Parallel Studio XE 2013\'.
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:411]: PROPERTY CHANGE: Adding VS2011DIR.CB8456D7_A5A6_433A_9944_81F5DB2663E7 property. Its value is 'C:\Program Files (x86)\VS2011DIR\'.
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:411]: PROPERTY CHANGE: Adding Common70.CB8456D7_A5A6_433A_9944_81F5DB2663E7 property. Its value is 'C:\Program Files (x86)\VS2011DIR\Common7\'.
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:411]: PROPERTY CHANGE: Adding IDE0.CB8456D7_A5A6_433A_9944_81F5DB2663E7 property. Its value is 'C:\Program Files (x86)\VS2011DIR\Common7\IDE\'.
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:411]: PROPERTY CHANGE: Adding Extensions0.CB8456D7_A5A6_433A_9944_81F5DB2663E7 property. Its value is 'C:\Program Files (x86)\VS2011DIR\Common7\IDE\Extensions\'.
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:411]: PROPERTY CHANGE: Adding Intel0.CB8456D7_A5A6_433A_9944_81F5DB2663E7 property. Its value is 'C:\Program Files (x86)\VS2011DIR\Common7\IDE\Extensions\Intel\'.
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:411]: PROPERTY CHANGE: Adding Intel.SoftwareManager0.CB8456D7_A5A6_433A_9944_81F5DB2663E7 property. Its value is 'C:\Program Files (x86)\VS2011DIR\Common7\IDE\Extensions\Intel\Intel.SoftwareManager\'.
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:411]: PROPERTY CHANGE: Adding ja1.CB8456D7_A5A6_433A_9944_81F5DB2663E7 property. Its value is 'C:\Program Files (x86)\VS2011DIR\Common7\IDE\Extensions\Intel\Intel.SoftwareManager\ja\'.
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:411]: Target path resolution complete. Dumping Directory table...
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:411]: Note: target paths subject to change (via custom actions or browsing)
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:411]: Dir (target): Key: TARGETDIR    , Object: C:\
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:411]: Dir (target): Key: WindowsFolder    , Object: C:\Windows\
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:411]: Dir (target): Key: VS11_REMOTE_DEBUGGER_X64_DIR    , Object: C:\
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:411]: Dir (target): Key: VS11_DEBUGER_DIR    , Object: C:\
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:411]: Dir (target): Key: CommonFilesFolder    , Object: C:\Program Files (x86)\Common Files\
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:411]: Dir (target): Key: INSTALLDIR    , Object: C:\
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:411]: Dir (target): Key: CommonFilesFolder.C4A469D8_5FD7_462C_AAF9_27CC6BDF6210    , Object: C:\
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:411]: Dir (target): Key: CmnIntel.C4A469D8_5FD7_462C_AAF9_27CC6BDF6210    , Object: C:\Intel\
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:411]: Dir (target): Key: CmnIntelHEBundle.C4A469D8_5FD7_462C_AAF9_27CC6BDF6210    , Object: C:\Intel\Parallel Studio XE 2013\
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:411]: Dir (target): Key: ProgramMenuFolder    , Object: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:411]: Dir (target): Key: HEBundleMenuDir.C4A469D8_5FD7_462C_AAF9_27CC6BDF6210    , Object: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Intel Parallel Studio XE 2013\
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:411]: Dir (target): Key: CommonFilesFolder.95C3848C_D156_4249_942C_7A8A0976584F    , Object: C:\
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:411]: Dir (target): Key: CmnIntel.95C3848C_D156_4249_942C_7A8A0976584F    , Object: C:\Intel\
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:411]: Dir (target): Key: CmnIntelHEBundle.95C3848C_D156_4249_942C_7A8A0976584F    , Object: C:\Intel\Parallel Studio XE 2013\
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:411]: Dir (target): Key: ProgramFilesFolder    , Object: C:\Program Files (x86)\
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:411]: Dir (target): Key: VS2011DIR.CB8456D7_A5A6_433A_9944_81F5DB2663E7    , Object: C:\Program Files (x86)\VS2011DIR\
MSI(i) [13:54:55.429] | MSI (c) (B0:9C) [13:54:55:411]: Dir (target): Key: Common70.CB8456D7_A5A6_433A_9944_81F5DB2663E7    , Object: C:\Program Files (x86)\VS2011DIR\Common7\
MSI(i) [13:54:55.430] | MSI (c) (B0:9C) [13:54:55:411]: Dir (target): Key: IDE0.CB8456D7_A5A6_433A_9944_81F5DB2663E7    , Object: C:\Program Files (x86)\VS2011DIR\Common7\IDE\
MSI(i) [13:54:55.430] | MSI (c) (B0:9C) [13:54:55:411]: Dir (target): Key: Extensions0.CB8456D7_A5A6_433A_9944_81F5DB2663E7    , Object: C:\Program Files (x86)\VS2011DIR\Common7\IDE\Extensions\
MSI(i) [13:54:55.430] | MSI (c) (B0:9C) [13:54:55:411]: Dir (target): Key: Intel0.CB8456D7_A5A6_433A_9944_81F5DB2663E7    , Object: C:\Program Files (x86)\VS2011DIR\Common7\IDE\Extensions\Intel\
MSI(i) [13:54:55.430] | MSI (c) (B0:9C) [13:54:55:411]: Dir (target): Key: Intel.SoftwareManager0.CB8456D7_A5A6_433A_9944_81F5DB2663E7    , Object: C:\Program Files (x86)\VS2011DIR\Common7\IDE\Extensions\Intel\Intel.SoftwareManager\
MSI(i) [13:54:55.430] | MSI (c) (B0:9C) [13:54:55:411]: Dir (target): Key: ja1.CB8456D7_A5A6_433A_9944_81F5DB2663E7    , Object: C:\Program Files (x86)\VS2011DIR\Common7\IDE\Extensions\Intel\Intel.SoftwareManager\ja\
MSI(i) [13:54:55.430] | MSI (c) (B0:9C) [13:54:55:411]: PROPERTY CHANGE: Adding INSTALLLEVEL property. Its value is '1'.
MSI(i) [13:54:55.430] | MSI (c) (B0:9C) [13:54:55:411]: Note: 1: 2205 2:  3: MsiAssembly
MSI(i) [13:54:55.430] | MSI (c) (B0:9C) [13:54:55:411]: Note: 1: 2228 2:  3: MsiAssembly 4:  SELECT `MsiAssembly`.`Attributes`, `MsiAssembly`.`File_Application`, `MsiAssembly`.`File_Manifest`,  `Component`.`KeyPath` FROM `MsiAssembly`, `Component` WHERE  `MsiAssembly`.`Component_` = `Component`.`Component` AND `MsiAssembly`.`Component_` = ?
MSI(i) [13:54:55.430] | Action ended 13:54:55: CostFinalize. Return value 1.
MSI(i) [13:54:55.430] | MSI (c) (B0:9C) [13:54:55:411]: Doing action: InstallValidate
MSI(i) [13:54:55.430] | Action 13:54:55: InstallValidate. Validating install
MSI(i) [13:54:55.430] | Action start 13:54:55: InstallValidate.
MSI(i) [13:54:55.430] | MSI (c) (B0:9C) [13:54:55:412]: Note: 1: 2205 2:  3: Dialog
MSI(i) [13:54:55.430] | MSI (c) (B0:9C) [13:54:55:412]: Feature: core; Installed: Absent;   Request: Local;   Action: Local
MSI(i) [13:54:55.430] | MSI (c) (B0:9C) [13:54:55:412]: Component: ProductFamilyAnchor; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.430] | MSI (c) (B0:9C) [13:54:55:412]: Component: ProductVersionAnchor; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.430] | MSI (c) (B0:9C) [13:54:55:412]: Component: CommonIntegrationAnchor; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.430] | MSI (c) (B0:9C) [13:54:55:412]: Component: VsIntegrationAnchor; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.430] | MSI (c) (B0:9C) [13:54:55:412]: Component: reg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.430] | MSI (c) (B0:9C) [13:54:55:412]: Component: VS11_F1_HELP_NAMESPACE; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.430] | MSI (c) (B0:9C) [13:54:55:412]: Component: VS11_F1_HELP_VENDOR; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.430] | MSI (c) (B0:9C) [13:54:55:412]: Component: Comp_Intel.SoftwareManager.dll1.CB8456D7_A5A6_433A_9944_81F5DB2663E7; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.430] | MSI (c) (B0:9C) [13:54:55:412]: Component: Comp_Intel.SoftwareManager.pkgdef0.CB8456D7_A5A6_433A_9944_81F5DB2663E7; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.430] | MSI (c) (B0:9C) [13:54:55:412]: Component: Comp_Intel.SoftwareManager.resources.dll1.CB8456D7_A5A6_433A_9944_81F5DB2663E7; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.430] | MSI (c) (B0:9C) [13:54:55:412]: Component: vs_run.exe.95C3848C_D156_4249_942C_7A8A0976584F; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.430] | MSI (c) (B0:9C) [13:54:55:412]: Component: VS2011.C4A469D8_5FD7_462C_AAF9_27CC6BDF6210; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.430] | MSI (c) (B0:9C) [13:54:55:412]: Component: VS2011_win8.C4A469D8_5FD7_462C_AAF9_27CC6BDF6210; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.430] | MSI (c) (B0:9C) [13:54:55:412]: Component: __reg65; Installed: Null;   Request: Local;   Action: Local;   Client State: Null
MSI(i) [13:54:55.430] | MSI (c) (B0:9C) [13:54:55:412]: Component: __VS11_F1_HELP_NAMESPACE65; Installed: Null;   Request: Local;   Action: Local;   Client State: Null
MSI(i) [13:54:55.430] | MSI (c) (B0:9C) [13:54:55:412]: Component: __VS11_F1_HELP_VENDOR65; Installed: Null;   Request: Local;   Action: Local;   Client State: Null
MSI(i) [13:54:55.430] | MSI (c) (B0:9C) [13:54:55:412]: Component: __VS2011.C4A469D8_5FD7_462C_AAF9_27CC6BDF621065; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.430] | MSI (c) (B0:9C) [13:54:55:413]: Component: __VS2011_win8.C4A469D8_5FD7_462C_AAF9_27CC6BDF621065; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.430] | MSI (c) (B0:9C) [13:54:55:413]: Note: 1: 2205 2:  3: BindImage
MSI(i) [13:54:55.430] | MSI (c) (B0:9C) [13:54:55:413]: Note: 1: 2205 2:  3: ProgId
MSI(i) [13:54:55.430] | MSI (c) (B0:9C) [13:54:55:413]: Note: 1: 2205 2:  3: PublishComponent
MSI(i) [13:54:55.430] | MSI (c) (B0:9C) [13:54:55:413]: Note: 1: 2205 2:  3: SelfReg
MSI(i) [13:54:55.430] | MSI (c) (B0:9C) [13:54:55:413]: Note: 1: 2205 2:  3: Extension
MSI(i) [13:54:55.430] | MSI (c) (B0:9C) [13:54:55:413]: Note: 1: 2205 2:  3: Font
MSI(i) [13:54:55.430] | MSI (c) (B0:9C) [13:54:55:413]: Note: 1: 2205 2:  3: Class
MSI(i) [13:54:55.430] | MSI (c) (B0:9C) [13:54:55:413]: Note: 1: 2205 2:  3: TypeLib
MSI(i) [13:54:55.430] | MSI (c) (B0:9C) [13:54:55:413]: Note: 1: 2205 2:  3: _RemoveFilePath
MSI(i) [13:54:55.430] | MSI (c) (B0:9C) [13:54:55:413]: PROPERTY CHANGE: Modifying CostingComplete property. Its current value is '0'. Its new value: '1'.
MSI(i) [13:54:55.430] | MSI (c) (B0:9C) [13:54:55:414]: Note: 1: 2727 2:
MSI(i) [13:54:55.430] | MSI (c) (B0:9C) [13:54:55:428]: Note: 1: 2727 2:
MSI(i) [13:54:55.430] | Action ended 13:54:55: InstallValidate. Return value 1.
MSI(i) [13:54:55.430] | MSI (c) (B0:9C) [13:54:55:428]: Creating MSIHANDLE (53) of type 790541 for thread 3996
MSI(i) [13:54:55.430] | MSI (c) (B0:9C) [13:54:55:428]: Creating MSIHANDLE (54) of type 790540 for thread 3996
MSI(i) [13:54:55.430] | MSI (c) (B0:9C) [13:54:55:428]: Creating MSIHANDLE (55) of type 790531 for thread 3996
MSI(i) [13:54:55.430] | MSI (c) (B0:9C) [13:54:55:428]: Note: 1: 2205 2:  3: Condition
MSI(i) [13:54:55.430] | MSI (c) (B0:9C) [13:54:55:428]: Note: 1: 2228 2:  3: Condition 4: SELECT * FROM Condition WHERE Feature_ = 'core'
MSI(i) [13:54:55.430] | MSI (c) (B0:9C) [13:54:55:428]: Creating MSIHANDLE (56) of type 790540 for thread 3996
MSI(i) [13:54:55.430] | MSI (c) (B0:9C) [13:54:55:428]: Closing MSIHANDLE (56) of type 790540 for thread 3996
MSI(i) [13:54:55.430] | MSI (c) (B0:9C) [13:54:55:428]: Closing MSIHANDLE (55) of type 790531 for thread 3996
MSI(i) [13:54:55.430] | MSI (c) (B0:9C) [13:54:55:428]: Closing MSIHANDLE (54) of type 790540 for thread 3996
MSI(i) [13:54:55.430] | MSI (c) (B0:9C) [13:54:55:428]: Closing MSIHANDLE (53) of type 790541 for thread 3996
MSI(i) [13:54:55.430] | MSI (c) (B0:9C) [13:54:55:428]: Leaked MSIHANDLE (51) of type 790537 for thread 3996
MSI(i) [13:54:55.430] | === Verbose logging stopped: 4/8/2014  13:54:55 ===
PSET(i) [13:54:55.438] | (4225.1904): Dependency {ACD97E2A-090D-46ea-9983-6E44BCA28575} always show dialog
PSET(i) [13:54:55.438] | (4225.1904): Dependency {E3BA8A13-2647-4c01-81D5-77E6D912D9D5} always show dialog
PSET(i) [13:54:55.438] | (4225.1904): Dependency {D52A1D2E-8D7A-4822-9421-3A92C64DB956} always show dialog
PSET(i) [13:54:55.439] | (4225.2963): MsiOpenPackageEx(C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs2008-integration.msi)
MSI(i) [13:54:55.478] | === Verbose logging started: 4/8/2014  13:54:55  Build type: SHIP UNICODE 5.00.7601.00  Calling process: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\setup.exe ===
MSI(i) [13:54:55.478] | MSI (c) (B0:9C) [13:54:55:440]: SOFTWARE RESTRICTION POLICY: Verifying package --> 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs2008-integration.msi' against software restriction policy
MSI(i) [13:54:55.478] | MSI (c) (B0:9C) [13:54:55:440]: SOFTWARE RESTRICTION POLICY: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs2008-integration.msi has a digital signature
MSI(i) [13:54:55.478] | MSI (c) (B0:9C) [13:54:55:458]: SOFTWARE RESTRICTION POLICY: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs2008-integration.msi is permitted to run at the 'unrestricted' authorization level.
MSI(i) [13:54:55.478] | MSI (c) (B0:9C) [13:54:55:459]: Cloaking enabled.
MSI(i) [13:54:55.478] | MSI (c) (B0:9C) [13:54:55:459]: Attempting to enable all disabled privileges before calling Install on Server
MSI(i) [13:54:55.478] | MSI (c) (B0:9C) [13:54:55:459]: End dialog not enabled
MSI(i) [13:54:55.478] | MSI (c) (B0:9C) [13:54:55:459]: Original package ==> C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs2008-integration.msi
MSI(i) [13:54:55.478] | MSI (c) (B0:9C) [13:54:55:459]: Package we're running from ==> C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs2008-integration.msi
MSI(i) [13:54:55.478] | MSI (c) (B0:9C) [13:54:55:460]: APPCOMPAT: Compatibility mode property overrides found.
MSI(i) [13:54:55.478] | MSI (c) (B0:9C) [13:54:55:461]: APPCOMPAT: looking for appcompat database entry with ProductCode '{EFD393B3-F9F9-43E5-9DEA-7ACA45B1E5B2}'.
MSI(i) [13:54:55.478] | MSI (c) (B0:9C) [13:54:55:461]: APPCOMPAT: no matching ProductCode found in database.
MSI(i) [13:54:55.478] | MSI (c) (B0:9C) [13:54:55:465]: MSCOREE not loaded loading copy from system32
MSI(i) [13:54:55.478] | MSI (c) (B0:9C) [13:54:55:469]: Machine policy value 'TransformsSecure' is 0
MSI(i) [13:54:55.478] | MSI (c) (B0:9C) [13:54:55:469]: User policy value 'TransformsAtSource' is 0
MSI(i) [13:54:55.478] | MSI (c) (B0:9C) [13:54:55:469]: Machine policy value 'DisablePatch' is 0
MSI(i) [13:54:55.478] | MSI (c) (B0:9C) [13:54:55:469]: Machine policy value 'AllowLockdownPatch' is 0
MSI(i) [13:54:55.478] | MSI (c) (B0:9C) [13:54:55:469]: Machine policy value 'DisableLUAPatching' is 0
MSI(i) [13:54:55.478] | MSI (c) (B0:9C) [13:54:55:469]: Machine policy value 'DisableFlyWeightPatching' is 0
MSI(i) [13:54:55.478] | MSI (c) (B0:9C) [13:54:55:469]: Enabling baseline caching for this transaction since all active patches are MSI 3.0 style MSPs or at least one MSI 3.0 minor update patch is active
MSI(i) [13:54:55.478] | MSI (c) (B0:9C) [13:54:55:469]: APPCOMPAT: looking for appcompat database entry with ProductCode '{EFD393B3-F9F9-43E5-9DEA-7ACA45B1E5B2}'.
MSI(i) [13:54:55.478] | MSI (c) (B0:9C) [13:54:55:469]: APPCOMPAT: no matching ProductCode found in database.
MSI(i) [13:54:55.478] | MSI (c) (B0:9C) [13:54:55:470]: Transforms are not secure.
MSI(i) [13:54:55.478] | MSI (c) (B0:9C) [13:54:55:470]: PROPERTY CHANGE: Adding MsiLogFileLocation property. Its value is 'C:\Users\PCCA-PM\AppData\Local\Temp\MSIED31.tmp'.
MSI(i) [13:54:55.478] | MSI (c) (B0:9C) [13:54:55:470]: No Command Line.
MSI(i) [13:54:55.478] | MSI (c) (B0:9C) [13:54:55:470]: PROPERTY CHANGE: Adding PackageCode property. Its value is '{27EA0C65-64CE-405E-A049-1F35608919DE}'.
MSI(i) [13:54:55.478] | MSI (c) (B0:9C) [13:54:55:470]: Product Code passed to Engine.Initialize:           '(none)'
MSI(i) [13:54:55.478] | MSI (c) (B0:9C) [13:54:55:470]: Product Code from property table before transforms: '{EFD393B3-F9F9-43E5-9DEA-7ACA45B1E5B2}'
MSI(i) [13:54:55.478] | MSI (c) (B0:9C) [13:54:55:470]: Product Code from property table after transforms:  '{EFD393B3-F9F9-43E5-9DEA-7ACA45B1E5B2}'
MSI(i) [13:54:55.478] | MSI (c) (B0:9C) [13:54:55:470]: Product not registered: beginning first-time install
MSI(i) [13:54:55.478] | MSI (c) (B0:9C) [13:54:55:470]: PROPERTY CHANGE: Adding ProductState property. Its value is '-1'.
MSI(i) [13:54:55.478] | MSI (c) (B0:9C) [13:54:55:470]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer 3: 2
MSI(i) [13:54:55.478] | MSI (c) (B0:9C) [13:54:55:470]: Entering CMsiConfigurationManager::SetLastUsedSource.
MSI(i) [13:54:55.478] | MSI (c) (B0:9C) [13:54:55:470]: User policy value 'SearchOrder' is 'nmu'
MSI(i) [13:54:55.478] | MSI (c) (B0:9C) [13:54:55:470]: Adding new sources is allowed.
MSI(i) [13:54:55.478] | MSI (c) (B0:9C) [13:54:55:470]: PROPERTY CHANGE: Adding PackagecodeChanging property. Its value is '1'.
MSI(i) [13:54:55.478] | MSI (c) (B0:9C) [13:54:55:470]: Package name extracted from package path: 'vs2008-integration.msi'
MSI(i) [13:54:55.478] | MSI (c) (B0:9C) [13:54:55:470]: Package to be registered: 'vs2008-integration.msi'
MSI(i) [13:54:55.478] | MSI (c) (B0:9C) [13:54:55:470]: Note: 1: 2205 2:  3: Error
MSI(i) [13:54:55.478] | MSI (c) (B0:9C) [13:54:55:471]: Note: 1: 2262 2: AdminProperties 3: -2147287038
MSI(i) [13:54:55.478] | MSI (c) (B0:9C) [13:54:55:471]: Machine policy value 'DisableMsi' is 0
MSI(i) [13:54:55.478] | MSI (c) (B0:9C) [13:54:55:471]: Machine policy value 'AlwaysInstallElevated' is 0
MSI(i) [13:54:55.478] | MSI (c) (B0:9C) [13:54:55:471]: User policy value 'AlwaysInstallElevated' is 0
MSI(i) [13:54:55.478] | MSI (c) (B0:9C) [13:54:55:471]: Product installation will be elevated because user is admin and product is being installed per-machine.
MSI(i) [13:54:55.478] | MSI (c) (B0:9C) [13:54:55:471]: Running product '{EFD393B3-F9F9-43E5-9DEA-7ACA45B1E5B2}' with elevated privileges: Product is assigned.
MSI(i) [13:54:55.478] | MSI (c) (B0:9C) [13:54:55:471]: PROPERTY CHANGE: Adding MsiSystemRebootPending property. Its value is '1'.
MSI(i) [13:54:55.478] | MSI (c) (B0:9C) [13:54:55:471]: TRANSFORMS property is now:
MSI(i) [13:54:55.478] | MSI (c) (B0:9C) [13:54:55:471]: PROPERTY CHANGE: Adding VersionDatabase property. Its value is '200'.
MSI(i) [13:54:55.478] | MSI (c) (B0:9C) [13:54:55:471]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming
MSI(i) [13:54:55.478] | MSI (c) (B0:9C) [13:54:55:471]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Favorites
MSI(i) [13:54:55.478] | MSI (c) (B0:9C) [13:54:55:471]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Network Shortcuts
MSI(i) [13:54:55.478] | MSI (c) (B0:9C) [13:54:55:471]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Documents
MSI(i) [13:54:55.478] | MSI (c) (B0:9C) [13:54:55:471]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
MSI(i) [13:54:55.478] | MSI (c) (B0:9C) [13:54:55:471]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Recent
MSI(i) [13:54:55.478] | MSI (c) (B0:9C) [13:54:55:471]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\SendTo
MSI(i) [13:54:55.478] | MSI (c) (B0:9C) [13:54:55:471]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Templates
MSI(i) [13:54:55.478] | MSI (c) (B0:9C) [13:54:55:471]: SHELL32::SHGetFolderPath returned: C:\ProgramData
MSI(i) [13:54:55.478] | MSI (c) (B0:9C) [13:54:55:471]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Local
MSI(i) [13:54:55.478] | MSI (c) (B0:9C) [13:54:55:471]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Pictures
MSI(i) [13:54:55.478] | MSI (c) (B0:9C) [13:54:55:471]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI(i) [13:54:55.478] | MSI (c) (B0:9C) [13:54:55:471]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
MSI(i) [13:54:55.478] | MSI (c) (B0:9C) [13:54:55:471]: SHELL32::SHGetFolderPath returned: C:\Users\Public\Desktop
MSI(i) [13:54:55.478] | MSI (c) (B0:9C) [13:54:55:471]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI(i) [13:54:55.478] | MSI (c) (B0:9C) [13:54:55:471]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
MSI(i) [13:54:55.478] | MSI (c) (B0:9C) [13:54:55:471]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Desktop
MSI(i) [13:54:55.478] | MSI (c) (B0:9C) [13:54:55:472]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Templates
MSI(i) [13:54:55.478] | MSI (c) (B0:9C) [13:54:55:472]: SHELL32::SHGetFolderPath returned: C:\Windows\Fonts
MSI(i) [13:54:55.478] | MSI (c) (B0:9C) [13:54:55:472]: Note: 1: 2898 2: MS Sans Serif 3: MS Sans Serif 4: 0 5: 16
MSI(i) [13:54:55.478] | MSI (c) (B0:9C) [13:54:55:477]: MSI_LUA: Setting AdminUser property to 1 because this is the client or the user has already permitted elevation
MSI(i) [13:54:55.478] | MSI (c) (B0:9C) [13:54:55:477]: MSI_LUA: Setting MsiRunningElevated property to 1 because the install is already running elevated.
MSI(i) [13:54:55.478] | MSI (c) (B0:9C) [13:54:55:477]: PROPERTY CHANGE: Adding MsiRunningElevated property. Its value is '1'.
MSI(i) [13:54:55.478] | MSI (c) (B0:9C) [13:54:55:477]: PROPERTY CHANGE: Adding Privileged property. Its value is '1'.
MSI(i) [13:54:55.478] | MSI (c) (B0:9C) [13:54:55:477]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\MS Setup (ACME)\User Info 3: 2
MSI(i) [13:54:55.478] | MSI (c) (B0:9C) [13:54:55:477]: PROPERTY CHANGE: Adding USERNAME property. Its value is 'A Valued IT Customer'.
MSI(i) [13:54:55.478] | MSI (c) (B0:9C) [13:54:55:477]: PROPERTY CHANGE: Adding COMPANYNAME property. Its value is 'Intel Corporation'.
MSI(i) [13:54:55.478] | MSI (c) (B0:9C) [13:54:55:477]: PROPERTY CHANGE: Adding DATABASE property. Its value is 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs2008-integration.msi'.
MSI(i) [13:54:55.478] | MSI (c) (B0:9C) [13:54:55:477]: PROPERTY CHANGE: Adding OriginalDatabase property. Its value is 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs2008-integration.msi'.
MSI(i) [13:54:55.478] | MSI (c) (B0:9C) [13:54:55:477]: Machine policy value 'MsiDisableEmbeddedUI' is 0
MSI(i) [13:54:55.478] | MSI (c) (B0:9C) [13:54:55:477]: EEUI - Disabling MsiEmbeddedUI in quiet mode
MSI(i) [13:54:55.478] | === Logging started: 4/8/2014  13:54:55 ===
MSI(i) [13:54:55.478] | MSI (c) (B0:9C) [13:54:55:478]: Note: 1: 2205 2:  3: PatchPackage
MSI(i) [13:54:55.478] | MSI (c) (B0:9C) [13:54:55:478]: Machine policy value 'DisableRollback' is 0
MSI(i) [13:54:55.478] | MSI (c) (B0:9C) [13:54:55:478]: User policy value 'DisableRollback' is 0
MSI(i) [13:54:55.478] | MSI (c) (B0:9C) [13:54:55:478]: PROPERTY CHANGE: Adding UILevel property. Its value is '2'.
MSI(i) [13:54:55.478] | MSI (c) (B0:9C) [13:54:55:478]: Creating MSIHANDLE (57) of type 790537 for thread 3996
MSI(i) [13:54:55.478] | MSI (c) (B0:9C) [13:54:55:478]: MsiOpenPackageEx is returning 0
MSI(i) [13:54:55.478] | MSI (c) (B0:9C) [13:54:55:478]: Closing MSIHANDLE (57) of type 790537 for thread 3996
MSI(i) [13:54:55.478] | === Verbose logging stopped: 4/8/2014  13:54:55 ===
PSET(i) [13:54:55.486] | (4225.285): MsiOpenPackageEx(C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs2008-integration.msi)
MSI(i) [13:54:55.552] | === Verbose logging started: 4/8/2014  13:54:55  Build type: SHIP UNICODE 5.00.7601.00  Calling process: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\setup.exe ===
MSI(i) [13:54:55.552] | MSI (c) (B0:9C) [13:54:55:487]: SOFTWARE RESTRICTION POLICY: Verifying package --> 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs2008-integration.msi' against software restriction policy
MSI(i) [13:54:55.552] | MSI (c) (B0:9C) [13:54:55:487]: SOFTWARE RESTRICTION POLICY: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs2008-integration.msi has a digital signature
MSI(i) [13:54:55.552] | MSI (c) (B0:9C) [13:54:55:504]: SOFTWARE RESTRICTION POLICY: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs2008-integration.msi is permitted to run at the 'unrestricted' authorization level.
MSI(i) [13:54:55.552] | MSI (c) (B0:9C) [13:54:55:505]: Cloaking enabled.
MSI(i) [13:54:55.552] | MSI (c) (B0:9C) [13:54:55:505]: Attempting to enable all disabled privileges before calling Install on Server
MSI(i) [13:54:55.552] | MSI (c) (B0:9C) [13:54:55:505]: End dialog not enabled
MSI(i) [13:54:55.552] | MSI (c) (B0:9C) [13:54:55:505]: Original package ==> C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs2008-integration.msi
MSI(i) [13:54:55.552] | MSI (c) (B0:9C) [13:54:55:505]: Package we're running from ==> C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs2008-integration.msi
MSI(i) [13:54:55.552] | MSI (c) (B0:9C) [13:54:55:506]: Machine policy value 'DisableUserInstalls' is 0
MSI(i) [13:54:55.552] | MSI (c) (B0:9C) [13:54:55:507]: APPCOMPAT: Compatibility mode property overrides found.
MSI(i) [13:54:55.552] | MSI (c) (B0:9C) [13:54:55:507]: APPCOMPAT: looking for appcompat database entry with ProductCode '{EFD393B3-F9F9-43E5-9DEA-7ACA45B1E5B2}'.
MSI(i) [13:54:55.552] | MSI (c) (B0:9C) [13:54:55:507]: APPCOMPAT: no matching ProductCode found in database.
MSI(i) [13:54:55.552] | MSI (c) (B0:9C) [13:54:55:512]: MSCOREE not loaded loading copy from system32
MSI(i) [13:54:55.552] | MSI (c) (B0:9C) [13:54:55:515]: Machine policy value 'TransformsSecure' is 0
MSI(i) [13:54:55.552] | MSI (c) (B0:9C) [13:54:55:515]: User policy value 'TransformsAtSource' is 0
MSI(i) [13:54:55.552] | MSI (c) (B0:9C) [13:54:55:515]: Machine policy value 'DisablePatch' is 0
MSI(i) [13:54:55.552] | MSI (c) (B0:9C) [13:54:55:515]: Machine policy value 'AllowLockdownPatch' is 0
MSI(i) [13:54:55.552] | MSI (c) (B0:9C) [13:54:55:515]: Machine policy value 'DisableLUAPatching' is 0
MSI(i) [13:54:55.552] | MSI (c) (B0:9C) [13:54:55:515]: Machine policy value 'DisableFlyWeightPatching' is 0
MSI(i) [13:54:55.552] | MSI (c) (B0:9C) [13:54:55:515]: Enabling baseline caching for this transaction since all active patches are MSI 3.0 style MSPs or at least one MSI 3.0 minor update patch is active
MSI(i) [13:54:55.552] | MSI (c) (B0:9C) [13:54:55:516]: APPCOMPAT: looking for appcompat database entry with ProductCode '{EFD393B3-F9F9-43E5-9DEA-7ACA45B1E5B2}'.
MSI(i) [13:54:55.552] | MSI (c) (B0:9C) [13:54:55:516]: APPCOMPAT: no matching ProductCode found in database.
MSI(i) [13:54:55.552] | MSI (c) (B0:9C) [13:54:55:516]: Transforms are not secure.
MSI(i) [13:54:55.552] | MSI (c) (B0:9C) [13:54:55:516]: PROPERTY CHANGE: Adding MsiLogFileLocation property. Its value is 'C:\Users\PCCA-PM\AppData\Local\Temp\MSIED31.tmp'.
MSI(i) [13:54:55.552] | MSI (c) (B0:9C) [13:54:55:516]: No Command Line.
MSI(i) [13:54:55.552] | MSI (c) (B0:9C) [13:54:55:516]: PROPERTY CHANGE: Adding PackageCode property. Its value is '{27EA0C65-64CE-405E-A049-1F35608919DE}'.
MSI(i) [13:54:55.552] | MSI (c) (B0:9C) [13:54:55:516]: Product Code passed to Engine.Initialize:           '(none)'
MSI(i) [13:54:55.552] | MSI (c) (B0:9C) [13:54:55:516]: Product Code from property table before transforms: '{EFD393B3-F9F9-43E5-9DEA-7ACA45B1E5B2}'
MSI(i) [13:54:55.552] | MSI (c) (B0:9C) [13:54:55:516]: Product Code from property table after transforms:  '{EFD393B3-F9F9-43E5-9DEA-7ACA45B1E5B2}'
MSI(i) [13:54:55.552] | MSI (c) (B0:9C) [13:54:55:516]: Product not registered: beginning first-time install
MSI(i) [13:54:55.552] | MSI (c) (B0:9C) [13:54:55:516]: PROPERTY CHANGE: Adding ProductState property. Its value is '-1'.
MSI(i) [13:54:55.552] | MSI (c) (B0:9C) [13:54:55:516]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer 3: 2
MSI(i) [13:54:55.552] | MSI (c) (B0:9C) [13:54:55:516]: Entering CMsiConfigurationManager::SetLastUsedSource.
MSI(i) [13:54:55.552] | MSI (c) (B0:9C) [13:54:55:516]: User policy value 'SearchOrder' is 'nmu'
MSI(i) [13:54:55.552] | MSI (c) (B0:9C) [13:54:55:516]: Adding new sources is allowed.
MSI(i) [13:54:55.552] | MSI (c) (B0:9C) [13:54:55:516]: PROPERTY CHANGE: Adding PackagecodeChanging property. Its value is '1'.
MSI(i) [13:54:55.552] | MSI (c) (B0:9C) [13:54:55:517]: Package name extracted from package path: 'vs2008-integration.msi'
MSI(i) [13:54:55.552] | MSI (c) (B0:9C) [13:54:55:517]: Package to be registered: 'vs2008-integration.msi'
MSI(i) [13:54:55.552] | MSI (c) (B0:9C) [13:54:55:517]: Note: 1: 2205 2:  3: Error
MSI(i) [13:54:55.552] | MSI (c) (B0:9C) [13:54:55:517]: Note: 1: 2262 2: AdminProperties 3: -2147287038
MSI(i) [13:54:55.552] | MSI (c) (B0:9C) [13:54:55:517]: Machine policy value 'DisableMsi' is 0
MSI(i) [13:54:55.552] | MSI (c) (B0:9C) [13:54:55:517]: Machine policy value 'AlwaysInstallElevated' is 0
MSI(i) [13:54:55.552] | MSI (c) (B0:9C) [13:54:55:517]: User policy value 'AlwaysInstallElevated' is 0
MSI(i) [13:54:55.552] | MSI (c) (B0:9C) [13:54:55:517]: Product installation will be elevated because user is admin and product is being installed per-machine.
MSI(i) [13:54:55.552] | MSI (c) (B0:9C) [13:54:55:517]: Running product '{EFD393B3-F9F9-43E5-9DEA-7ACA45B1E5B2}' with elevated privileges: Product is assigned.
MSI(i) [13:54:55.552] | MSI (c) (B0:9C) [13:54:55:518]: PROPERTY CHANGE: Adding MsiSystemRebootPending property. Its value is '1'.
MSI(i) [13:54:55.552] | MSI (c) (B0:9C) [13:54:55:518]: TRANSFORMS property is now:
MSI(i) [13:54:55.552] | MSI (c) (B0:9C) [13:54:55:518]: PROPERTY CHANGE: Adding VersionDatabase property. Its value is '200'.
MSI(i) [13:54:55.552] | MSI (c) (B0:9C) [13:54:55:518]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming
MSI(i) [13:54:55.552] | MSI (c) (B0:9C) [13:54:55:518]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Favorites
MSI(i) [13:54:55.552] | MSI (c) (B0:9C) [13:54:55:518]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Network Shortcuts
MSI(i) [13:54:55.552] | MSI (c) (B0:9C) [13:54:55:518]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Documents
MSI(i) [13:54:55.552] | MSI (c) (B0:9C) [13:54:55:518]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
MSI(i) [13:54:55.552] | MSI (c) (B0:9C) [13:54:55:518]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Recent
MSI(i) [13:54:55.552] | MSI (c) (B0:9C) [13:54:55:518]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\SendTo
MSI(i) [13:54:55.552] | MSI (c) (B0:9C) [13:54:55:518]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Templates
MSI(i) [13:54:55.552] | MSI (c) (B0:9C) [13:54:55:518]: SHELL32::SHGetFolderPath returned: C:\ProgramData
MSI(i) [13:54:55.552] | MSI (c) (B0:9C) [13:54:55:518]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Local
MSI(i) [13:54:55.552] | MSI (c) (B0:9C) [13:54:55:518]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Pictures
MSI(i) [13:54:55.552] | MSI (c) (B0:9C) [13:54:55:518]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:518]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:518]: SHELL32::SHGetFolderPath returned: C:\Users\Public\Desktop
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:518]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:518]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:518]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Desktop
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:518]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Templates
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:518]: SHELL32::SHGetFolderPath returned: C:\Windows\Fonts
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:518]: Note: 1: 2898 2: MS Sans Serif 3: MS Sans Serif 4: 0 5: 16
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:524]: MSI_LUA: Setting AdminUser property to 1 because this is the client or the user has already permitted elevation
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:524]: MSI_LUA: Setting MsiRunningElevated property to 1 because the install is already running elevated.
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:524]: PROPERTY CHANGE: Adding MsiRunningElevated property. Its value is '1'.
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:524]: PROPERTY CHANGE: Adding Privileged property. Its value is '1'.
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:524]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\MS Setup (ACME)\User Info 3: 2
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:524]: PROPERTY CHANGE: Adding USERNAME property. Its value is 'A Valued IT Customer'.
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:524]: PROPERTY CHANGE: Adding COMPANYNAME property. Its value is 'Intel Corporation'.
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:524]: PROPERTY CHANGE: Adding DATABASE property. Its value is 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs2008-integration.msi'.
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:524]: PROPERTY CHANGE: Adding OriginalDatabase property. Its value is 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs2008-integration.msi'.
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:524]: Machine policy value 'MsiDisableEmbeddedUI' is 0
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:524]: EEUI - Disabling MsiEmbeddedUI in quiet mode
MSI(i) [13:54:55.553] | === Logging started: 4/8/2014  13:54:55 ===
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:524]: Note: 1: 2205 2:  3: PatchPackage
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:524]: Machine policy value 'DisableRollback' is 0
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:524]: User policy value 'DisableRollback' is 0
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:524]: PROPERTY CHANGE: Adding UILevel property. Its value is '2'.
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:524]: Creating MSIHANDLE (58) of type 790537 for thread 3996
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:524]: MsiOpenPackageEx is returning 0
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:524]: Creating MSIHANDLE (59) of type 790541 for thread 3996
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:524]: Closing MSIHANDLE (59) of type 790541 for thread 3996
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:525]: Doing action: AppSearch
MSI(i) [13:54:55.553] | Action 13:54:55: AppSearch. Searching for installed applications
MSI(i) [13:54:55.553] | Action start 13:54:55: AppSearch.
MSI(i) [13:54:55.553] | AppSearch: Property: VS2010DIR.6229EDAD_EDEA_48D9_8C13_CA576A78F3DC, Signature: SIG_VS2010_DIR.6229EDAD_EDEA_48D9_8C13_CA576A78F3DC
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:526]: Note: 1: 2262 2: Signature 3: -2147287038
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:526]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE32\SOFTWARE\Microsoft\VisualStudio\10.0\Setup\VS 3: 2
MSI(i) [13:54:55.553] | AppSearch: Property: VS2011DIR.6229EDAD_EDEA_48D9_8C13_CA576A78F3DC, Signature: SIG_VS2011_DIR.6229EDAD_EDEA_48D9_8C13_CA576A78F3DC
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:527]: Note: 1: 2262 2: Signature 3: -2147287038
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:527]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE32\SOFTWARE\Microsoft\VisualStudio\11.0\Setup\VS 3: 2
MSI(i) [13:54:55.553] | AppSearch: Property: DEVENV_EXE_2008.FBB3A55A_D719_4787_AB98_1EBEE1E3CC63, Signature: RL_DevenvExe_2008.FBB3A55A_D719_4787_AB98_1EBEE1E3CC63
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:527]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE32\SOFTWARE\Microsoft\VisualStudio\9.0\Setup\VS 3: 2
MSI(i) [13:54:55.553] | AppSearch: Property: DEVENV_EXE_2010.FBB3A55A_D719_4787_AB98_1EBEE1E3CC63, Signature: RL_DevenvExe_2010.FBB3A55A_D719_4787_AB98_1EBEE1E3CC63
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:527]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE32\SOFTWARE\Microsoft\VisualStudio\10.0\Setup\VS 3: 2
MSI(i) [13:54:55.553] | AppSearch: Property: DEVENV_EXE_2011.FBB3A55A_D719_4787_AB98_1EBEE1E3CC63, Signature: RL_DevenvExe_2011.FBB3A55A_D719_4787_AB98_1EBEE1E3CC63
MSI(i) [13:54:55.553] | AppSearch: Property: FILTERS90_1033_DIR.5C3A34FA_BD75_49D3_AE1E_D9AB61E6DA6F, Signature: FILTERS90_1033.5C3A34FA_BD75_49D3_AE1E_D9AB61E6DA6F
MSI(i) [13:54:55.553] | AppSearch: Property: FILTERS90_1041_DIR.5C3A34FA_BD75_49D3_AE1E_D9AB61E6DA6F, Signature: FILTERS90_1041.5C3A34FA_BD75_49D3_AE1E_D9AB61E6DA6F
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:528]: Note: 1: 2262 2: Signature 3: -2147287038
MSI(i) [13:54:55.553] | AppSearch: Property: FILTERS90_1033_FOUND.5C3A34FA_BD75_49D3_AE1E_D9AB61E6DA6F, Signature: FILTERS90_1033.5C3A34FA_BD75_49D3_AE1E_D9AB61E6DA6F
MSI(i) [13:54:55.553] | AppSearch: Property: FILTERS90_1041_FOUND.5C3A34FA_BD75_49D3_AE1E_D9AB61E6DA6F, Signature: FILTERS90_1041.5C3A34FA_BD75_49D3_AE1E_D9AB61E6DA6F
MSI(i) [13:54:55.553] | Action ended 13:54:55: AppSearch. Return value 1.
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:528]: Doing action: CostInitialize
MSI(i) [13:54:55.553] | Action 13:54:55: CostInitialize. Computing space requirements
MSI(i) [13:54:55.553] | Action start 13:54:55: CostInitialize.
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:529]: Machine policy value 'MaxPatchCacheSize' is 10
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:529]: Baseline: Sorting baselines for {EFD393B3-F9F9-43E5-9DEA-7ACA45B1E5B2}.
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:529]: Baseline: New baseline 13.1.5000 from transaction.
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:529]: Baseline: Sorted order Native: Order 0.
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:529]: Baseline Data Table:
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:529]: ProductCode: {EFD393B3-F9F9-43E5-9DEA-7ACA45B1E5B2} Version: 13.1.5000 Attributes: 0 PatchId: Native BaselineId: -2147483648 Order: 0
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:529]: Baseline File Table:
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:530]: PROPERTY CHANGE: Adding ROOTDRIVE property. Its value is 'C:\'.
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:530]: PROPERTY CHANGE: Adding CostingComplete property. Its value is '0'.
MSI(i) [13:54:55.553] | Action ended 13:54:55: CostInitialize. Return value 1.
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:530]: Doing action: FileCost
MSI(i) [13:54:55.553] | Action 13:54:55: FileCost. Computing space requirements
MSI(i) [13:54:55.553] | Action start 13:54:55: FileCost.
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:531]: Note: 1: 2205 2:  3: MsiAssembly
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:531]: Note: 1: 2205 2:  3: Class
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:531]: Note: 1: 2205 2:  3: Extension
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:531]: Note: 1: 2205 2:  3: TypeLib
MSI(i) [13:54:55.553] | Action ended 13:54:55: FileCost. Return value 1.
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:532]: Doing action: CostFinalize
MSI(i) [13:54:55.553] | Action 13:54:55: CostFinalize. Computing space requirements
MSI(i) [13:54:55.553] | Action start 13:54:55: CostFinalize.
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:533]: PROPERTY CHANGE: Adding OutOfDiskSpace property. Its value is '0'.
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:533]: PROPERTY CHANGE: Adding OutOfNoRbDiskSpace property. Its value is '0'.
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:533]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceAvailable property. Its value is '0'.
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:533]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRequired property. Its value is '0'.
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:533]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRemaining property. Its value is '0'.
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:533]: Note: 1: 2205 2:  3: Patch
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:533]: Note: 1: 2205 2:  3: Condition
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:533]: PROPERTY CHANGE: Adding TARGETDIR property. Its value is 'C:\'.
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:533]: PROPERTY CHANGE: Adding VS11_REMOTE_DEBUGGER_X64_DIR property. Its value is 'C:\'.
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:533]: PROPERTY CHANGE: Adding VS11_DEBUGER_DIR property. Its value is 'C:\'.
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:533]: PROPERTY CHANGE: Adding FILTERS90_1041_DIR.5C3A34FA_BD75_49D3_AE1E_D9AB61E6DA6F property. Its value is 'C:\Program Files (x86)\Common Files\FILTERS90_1041_DIR\'.
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:533]: PROPERTY CHANGE: Adding FILTERS90_1033_DIR.5C3A34FA_BD75_49D3_AE1E_D9AB61E6DA6F property. Its value is 'C:\Program Files (x86)\Common Files\FILTERS90_1033_DIR\'.
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:533]: PROPERTY CHANGE: Adding CmnIntel.6229EDAD_EDEA_48D9_8C13_CA576A78F3DC property. Its value is 'C:\Program Files (x86)\Common Files\intel\'.
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:533]: PROPERTY CHANGE: Adding CmnIntelSharedFiles.6229EDAD_EDEA_48D9_8C13_CA576A78F3DC property. Its value is 'C:\Program Files (x86)\Common Files\intel\shared files\'.
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:533]: PROPERTY CHANGE: Adding CmnIntelSharedFilesVS.6229EDAD_EDEA_48D9_8C13_CA576A78F3DC property. Its value is 'C:\Program Files (x86)\Common Files\intel\shared files\VS Integration\'.
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:533]: PROPERTY CHANGE: Adding CmnIntelSharedFilesVSISM.6229EDAD_EDEA_48D9_8C13_CA576A78F3DC property. Its value is 'C:\Program Files (x86)\Common Files\intel\shared files\VS Integration\Intel Software Manager\'.
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:534]: PROPERTY CHANGE: Adding CmnIntelSharedFilesVSISMVS2008.6229EDAD_EDEA_48D9_8C13_CA576A78F3DC property. Its value is 'C:\Program Files (x86)\Common Files\intel\shared files\VS Integration\Intel Software Manager\VS2008\'.
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:534]: PROPERTY CHANGE: Adding ja.6229EDAD_EDEA_48D9_8C13_CA576A78F3DC property. Its value is 'C:\Program Files (x86)\Common Files\intel\shared files\VS Integration\Intel Software Manager\VS2008\ja\'.
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:534]: PROPERTY CHANGE: Adding INSTALLDIR property. Its value is 'C:\'.
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:534]: PROPERTY CHANGE: Adding CommonFilesFolder.FBB3A55A_D719_4787_AB98_1EBEE1E3CC63 property. Its value is 'C:\'.
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:534]: PROPERTY CHANGE: Adding CmnIntel.FBB3A55A_D719_4787_AB98_1EBEE1E3CC63 property. Its value is 'C:\Intel\'.
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:534]: PROPERTY CHANGE: Adding CmnIntelHEBundle.FBB3A55A_D719_4787_AB98_1EBEE1E3CC63 property. Its value is 'C:\Intel\Parallel Studio XE 2013\'.
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:534]: PROPERTY CHANGE: Adding HEBundleMenuDir.FBB3A55A_D719_4787_AB98_1EBEE1E3CC63 property. Its value is 'C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Intel Parallel Studio XE 2013\'.
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:534]: PROPERTY CHANGE: Adding CommonFilesFolder.95C3848C_D156_4249_942C_7A8A0976584F property. Its value is 'C:\'.
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:534]: PROPERTY CHANGE: Adding CmnIntel.95C3848C_D156_4249_942C_7A8A0976584F property. Its value is 'C:\Intel\'.
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:534]: PROPERTY CHANGE: Adding CmnIntelHEBundle.95C3848C_D156_4249_942C_7A8A0976584F property. Its value is 'C:\Intel\Parallel Studio XE 2013\'.
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:534]: Target path resolution complete. Dumping Directory table...
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:534]: Note: target paths subject to change (via custom actions or browsing)
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:534]: Dir (target): Key: TARGETDIR    , Object: C:\
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:534]: Dir (target): Key: WindowsFolder    , Object: C:\Windows\
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:534]: Dir (target): Key: VS11_REMOTE_DEBUGGER_X64_DIR    , Object: C:\
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:534]: Dir (target): Key: VS11_DEBUGER_DIR    , Object: C:\
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:534]: Dir (target): Key: CommonFilesFolder    , Object: C:\Program Files (x86)\Common Files\
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:534]: Dir (target): Key: FILTERS90_1041_DIR.5C3A34FA_BD75_49D3_AE1E_D9AB61E6DA6F    , Object: C:\Program Files (x86)\Common Files\FILTERS90_1041_DIR\
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:534]: Dir (target): Key: FILTERS90_1033_DIR.5C3A34FA_BD75_49D3_AE1E_D9AB61E6DA6F    , Object: C:\Program Files (x86)\Common Files\FILTERS90_1033_DIR\
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:534]: Dir (target): Key: CmnIntel.6229EDAD_EDEA_48D9_8C13_CA576A78F3DC    , Object: C:\Program Files (x86)\Common Files\intel\
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:534]: Dir (target): Key: CmnIntelSharedFiles.6229EDAD_EDEA_48D9_8C13_CA576A78F3DC    , Object: C:\Program Files (x86)\Common Files\intel\shared files\
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:534]: Dir (target): Key: CmnIntelSharedFilesVS.6229EDAD_EDEA_48D9_8C13_CA576A78F3DC    , Object: C:\Program Files (x86)\Common Files\intel\shared files\VS Integration\
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:534]: Dir (target): Key: CmnIntelSharedFilesVSISM.6229EDAD_EDEA_48D9_8C13_CA576A78F3DC    , Object: C:\Program Files (x86)\Common Files\intel\shared files\VS Integration\Intel Software Manager\
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:534]: Dir (target): Key: CmnIntelSharedFilesVSISMVS2008.6229EDAD_EDEA_48D9_8C13_CA576A78F3DC    , Object: C:\Program Files (x86)\Common Files\intel\shared files\VS Integration\Intel Software Manager\VS2008\
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:534]: Dir (target): Key: ja.6229EDAD_EDEA_48D9_8C13_CA576A78F3DC    , Object: C:\Program Files (x86)\Common Files\intel\shared files\VS Integration\Intel Software Manager\VS2008\ja\
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:534]: Dir (target): Key: INSTALLDIR    , Object: C:\
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:534]: Dir (target): Key: CommonFilesFolder.FBB3A55A_D719_4787_AB98_1EBEE1E3CC63    , Object: C:\
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:534]: Dir (target): Key: CmnIntel.FBB3A55A_D719_4787_AB98_1EBEE1E3CC63    , Object: C:\Intel\
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:534]: Dir (target): Key: CmnIntelHEBundle.FBB3A55A_D719_4787_AB98_1EBEE1E3CC63    , Object: C:\Intel\Parallel Studio XE 2013\
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:534]: Dir (target): Key: ProgramMenuFolder    , Object: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:534]: Dir (target): Key: HEBundleMenuDir.FBB3A55A_D719_4787_AB98_1EBEE1E3CC63    , Object: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Intel Parallel Studio XE 2013\
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:534]: Dir (target): Key: CommonFilesFolder.95C3848C_D156_4249_942C_7A8A0976584F    , Object: C:\
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:534]: Dir (target): Key: CmnIntel.95C3848C_D156_4249_942C_7A8A0976584F    , Object: C:\Intel\
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:534]: Dir (target): Key: CmnIntelHEBundle.95C3848C_D156_4249_942C_7A8A0976584F    , Object: C:\Intel\Parallel Studio XE 2013\
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:534]: Dir (target): Key: ProgramFilesFolder    , Object: C:\Program Files (x86)\
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:534]: Dir (target): Key: SystemFolder    , Object: C:\Windows\SysWOW64\
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:534]: PROPERTY CHANGE: Adding INSTALLLEVEL property. Its value is '1'.
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:534]: Note: 1: 2205 2:  3: MsiAssembly
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:534]: Note: 1: 2228 2:  3: MsiAssembly 4:  SELECT `MsiAssembly`.`Attributes`, `MsiAssembly`.`File_Application`, `MsiAssembly`.`File_Manifest`,  `Component`.`KeyPath` FROM `MsiAssembly`, `Component` WHERE  `MsiAssembly`.`Component_` = `Component`.`Component` AND `MsiAssembly`.`Component_` = ?
MSI(i) [13:54:55.553] | Action ended 13:54:55: CostFinalize. Return value 1.
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:534]: Doing action: InstallValidate
MSI(i) [13:54:55.553] | Action 13:54:55: InstallValidate. Validating install
MSI(i) [13:54:55.553] | Action start 13:54:55: InstallValidate.
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:535]: Note: 1: 2205 2:  3: Dialog
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:535]: Feature: core; Installed: Absent;   Request: Local;   Action: Local
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:535]: Component: ProductFamilyAnchor; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:535]: Component: ProductVersionAnchor; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:535]: Component: CommonIntegrationAnchor; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:535]: Component: VsIntegrationAnchor; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:535]: Component: reg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:535]: Component: Comp_Intel.SoftwareManager.dll.6229EDAD_EDEA_48D9_8C13_CA576A78F3DC; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:535]: Component: Comp_Intel.SoftwareManager.resources.dll.6229EDAD_EDEA_48D9_8C13_CA576A78F3DC; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:535]: Component: _reg_ism_2008.6229EDAD_EDEA_48D9_8C13_CA576A78F3DC; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:535]: Component: vs_run.exe.95C3848C_D156_4249_942C_7A8A0976584F; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:535]: Component: VS2008.FBB3A55A_D719_4787_AB98_1EBEE1E3CC63; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:535]: Component: VS2008_win8.FBB3A55A_D719_4787_AB98_1EBEE1E3CC63; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:535]: Component: CT90.5C3A34FA_BD75_49D3_AE1E_D9AB61E6DA6F; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:536]: Component: LT90.5C3A34FA_BD75_49D3_AE1E_D9AB61E6DA6F; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:536]: Component: TT90.5C3A34FA_BD75_49D3_AE1E_D9AB61E6DA6F; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:536]: Component: CT90_jp.5C3A34FA_BD75_49D3_AE1E_D9AB61E6DA6F; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:536]: Component: LT90_jp.5C3A34FA_BD75_49D3_AE1E_D9AB61E6DA6F; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:536]: Component: TT90_jp.5C3A34FA_BD75_49D3_AE1E_D9AB61E6DA6F; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:536]: Component: __reg65; Installed: Null;   Request: Local;   Action: Local;   Client State: Null
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:536]: Component: ___reg_ism_2008.6229EDAD_EDEA_48D9_8C13_CA576A78F3DC65; Installed: Null;   Request: Local;   Action: Local;   Client State: Null
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:536]: Component: __VS2008.FBB3A55A_D719_4787_AB98_1EBEE1E3CC6365; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:536]: Component: __VS2008_win8.FBB3A55A_D719_4787_AB98_1EBEE1E3CC6365; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:536]: Component: __CT90.5C3A34FA_BD75_49D3_AE1E_D9AB61E6DA6F65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:536]: Component: __LT90.5C3A34FA_BD75_49D3_AE1E_D9AB61E6DA6F65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:536]: Component: __TT90.5C3A34FA_BD75_49D3_AE1E_D9AB61E6DA6F65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:536]: Component: __CT90_jp.5C3A34FA_BD75_49D3_AE1E_D9AB61E6DA6F65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:536]: Component: __LT90_jp.5C3A34FA_BD75_49D3_AE1E_D9AB61E6DA6F65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:536]: Component: __TT90_jp.5C3A34FA_BD75_49D3_AE1E_D9AB61E6DA6F65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:536]: Note: 1: 2205 2:  3: BindImage
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:536]: Note: 1: 2205 2:  3: ProgId
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:536]: Note: 1: 2205 2:  3: PublishComponent
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:536]: Note: 1: 2205 2:  3: SelfReg
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:536]: Note: 1: 2205 2:  3: Extension
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:536]: Note: 1: 2205 2:  3: Font
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:536]: Note: 1: 2205 2:  3: Class
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:536]: Note: 1: 2205 2:  3: TypeLib
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:536]: Note: 1: 2205 2:  3: _RemoveFilePath
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:537]: PROPERTY CHANGE: Modifying CostingComplete property. Its current value is '0'. Its new value: '1'.
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:537]: Note: 1: 2205 2:  3: BindImage
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:537]: Note: 1: 2205 2:  3: ProgId
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:537]: Note: 1: 2205 2:  3: PublishComponent
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:537]: Note: 1: 2205 2:  3: SelfReg
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:537]: Note: 1: 2205 2:  3: Extension
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:537]: Note: 1: 2205 2:  3: Font
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:537]: Note: 1: 2205 2:  3: Class
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:537]: Note: 1: 2205 2:  3: TypeLib
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:537]: Note: 1: 2727 2:
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:552]: Note: 1: 2727 2:
MSI(i) [13:54:55.553] | Action ended 13:54:55: InstallValidate. Return value 1.
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:552]: Creating MSIHANDLE (60) of type 790541 for thread 3996
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:552]: Creating MSIHANDLE (61) of type 790540 for thread 3996
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:552]: Creating MSIHANDLE (62) of type 790531 for thread 3996
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:552]: Note: 1: 2205 2:  3: Condition
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:552]: Note: 1: 2228 2:  3: Condition 4: SELECT * FROM Condition WHERE Feature_ = 'core'
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:552]: Creating MSIHANDLE (63) of type 790540 for thread 3996
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:552]: Closing MSIHANDLE (63) of type 790540 for thread 3996
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:552]: Closing MSIHANDLE (62) of type 790531 for thread 3996
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:552]: Closing MSIHANDLE (61) of type 790540 for thread 3996
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:552]: Closing MSIHANDLE (60) of type 790541 for thread 3996
MSI(i) [13:54:55.553] | MSI (c) (B0:9C) [13:54:55:552]: Leaked MSIHANDLE (58) of type 790537 for thread 3996
MSI(i) [13:54:55.553] | === Verbose logging stopped: 4/8/2014  13:54:55 ===
PSET(i) [13:54:55.562] | (4225.1904): Dependency {ACD97E2A-090D-46ea-9983-6E44BCA28575} always show dialog
PSET(i) [13:54:55.562] | (4225.1904): Dependency {F3CE10E5-7F75-4356-A379-05F5D6B04FB6} always show dialog
PSET(i) [13:54:55.562] | (4225.1904): Dependency {D52A1D2E-8D7A-4822-9421-3A92C64DB956} always show dialog
PSET(i) [13:54:55.563] | (4225.2963): MsiOpenPackageEx(C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs2010-integration.msi)
MSI(i) [13:54:55.601] | === Verbose logging started: 4/8/2014  13:54:55  Build type: SHIP UNICODE 5.00.7601.00  Calling process: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\setup.exe ===
MSI(i) [13:54:55.601] | MSI (c) (B0:9C) [13:54:55:564]: SOFTWARE RESTRICTION POLICY: Verifying package --> 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs2010-integration.msi' against software restriction policy
MSI(i) [13:54:55.601] | MSI (c) (B0:9C) [13:54:55:564]: SOFTWARE RESTRICTION POLICY: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs2010-integration.msi has a digital signature
MSI(i) [13:54:55.601] | MSI (c) (B0:9C) [13:54:55:580]: SOFTWARE RESTRICTION POLICY: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs2010-integration.msi is permitted to run at the 'unrestricted' authorization level.
MSI(i) [13:54:55.601] | MSI (c) (B0:9C) [13:54:55:581]: Cloaking enabled.
MSI(i) [13:54:55.601] | MSI (c) (B0:9C) [13:54:55:581]: Attempting to enable all disabled privileges before calling Install on Server
MSI(i) [13:54:55.601] | MSI (c) (B0:9C) [13:54:55:581]: End dialog not enabled
MSI(i) [13:54:55.601] | MSI (c) (B0:9C) [13:54:55:581]: Original package ==> C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs2010-integration.msi
MSI(i) [13:54:55.601] | MSI (c) (B0:9C) [13:54:55:581]: Package we're running from ==> C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs2010-integration.msi
MSI(i) [13:54:55.601] | MSI (c) (B0:9C) [13:54:55:583]: APPCOMPAT: Compatibility mode property overrides found.
MSI(i) [13:54:55.601] | MSI (c) (B0:9C) [13:54:55:583]: APPCOMPAT: looking for appcompat database entry with ProductCode '{E16E559E-30A0-49BA-81F5-636CE693B4A1}'.
MSI(i) [13:54:55.601] | MSI (c) (B0:9C) [13:54:55:583]: APPCOMPAT: no matching ProductCode found in database.
MSI(i) [13:54:55.601] | MSI (c) (B0:9C) [13:54:55:587]: MSCOREE not loaded loading copy from system32
MSI(i) [13:54:55.601] | MSI (c) (B0:9C) [13:54:55:591]: Machine policy value 'TransformsSecure' is 0
MSI(i) [13:54:55.601] | MSI (c) (B0:9C) [13:54:55:591]: User policy value 'TransformsAtSource' is 0
MSI(i) [13:54:55.601] | MSI (c) (B0:9C) [13:54:55:591]: Machine policy value 'DisablePatch' is 0
MSI(i) [13:54:55.601] | MSI (c) (B0:9C) [13:54:55:591]: Machine policy value 'AllowLockdownPatch' is 0
MSI(i) [13:54:55.601] | MSI (c) (B0:9C) [13:54:55:591]: Machine policy value 'DisableLUAPatching' is 0
MSI(i) [13:54:55.601] | MSI (c) (B0:9C) [13:54:55:591]: Machine policy value 'DisableFlyWeightPatching' is 0
MSI(i) [13:54:55.601] | MSI (c) (B0:9C) [13:54:55:591]: Enabling baseline caching for this transaction since all active patches are MSI 3.0 style MSPs or at least one MSI 3.0 minor update patch is active
MSI(i) [13:54:55.601] | MSI (c) (B0:9C) [13:54:55:592]: APPCOMPAT: looking for appcompat database entry with ProductCode '{E16E559E-30A0-49BA-81F5-636CE693B4A1}'.
MSI(i) [13:54:55.601] | MSI (c) (B0:9C) [13:54:55:592]: APPCOMPAT: no matching ProductCode found in database.
MSI(i) [13:54:55.601] | MSI (c) (B0:9C) [13:54:55:592]: Transforms are not secure.
MSI(i) [13:54:55.601] | MSI (c) (B0:9C) [13:54:55:592]: PROPERTY CHANGE: Adding MsiLogFileLocation property. Its value is 'C:\Users\PCCA-PM\AppData\Local\Temp\MSIED31.tmp'.
MSI(i) [13:54:55.601] | MSI (c) (B0:9C) [13:54:55:592]: No Command Line.
MSI(i) [13:54:55.601] | MSI (c) (B0:9C) [13:54:55:592]: PROPERTY CHANGE: Adding PackageCode property. Its value is '{4E6E5693-7562-4ABD-B30F-309AC4849EEF}'.
MSI(i) [13:54:55.601] | MSI (c) (B0:9C) [13:54:55:592]: Product Code passed to Engine.Initialize:           '(none)'
MSI(i) [13:54:55.601] | MSI (c) (B0:9C) [13:54:55:592]: Product Code from property table before transforms: '{E16E559E-30A0-49BA-81F5-636CE693B4A1}'
MSI(i) [13:54:55.601] | MSI (c) (B0:9C) [13:54:55:592]: Product Code from property table after transforms:  '{E16E559E-30A0-49BA-81F5-636CE693B4A1}'
MSI(i) [13:54:55.601] | MSI (c) (B0:9C) [13:54:55:592]: Product not registered: beginning first-time install
MSI(i) [13:54:55.601] | MSI (c) (B0:9C) [13:54:55:592]: PROPERTY CHANGE: Adding ProductState property. Its value is '-1'.
MSI(i) [13:54:55.601] | MSI (c) (B0:9C) [13:54:55:592]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer 3: 2
MSI(i) [13:54:55.601] | MSI (c) (B0:9C) [13:54:55:592]: Entering CMsiConfigurationManager::SetLastUsedSource.
MSI(i) [13:54:55.601] | MSI (c) (B0:9C) [13:54:55:592]: User policy value 'SearchOrder' is 'nmu'
MSI(i) [13:54:55.601] | MSI (c) (B0:9C) [13:54:55:592]: Adding new sources is allowed.
MSI(i) [13:54:55.601] | MSI (c) (B0:9C) [13:54:55:592]: PROPERTY CHANGE: Adding PackagecodeChanging property. Its value is '1'.
MSI(i) [13:54:55.601] | MSI (c) (B0:9C) [13:54:55:592]: Package name extracted from package path: 'vs2010-integration.msi'
MSI(i) [13:54:55.601] | MSI (c) (B0:9C) [13:54:55:593]: Package to be registered: 'vs2010-integration.msi'
MSI(i) [13:54:55.601] | MSI (c) (B0:9C) [13:54:55:593]: Note: 1: 2205 2:  3: Error
MSI(i) [13:54:55.601] | MSI (c) (B0:9C) [13:54:55:593]: Note: 1: 2262 2: AdminProperties 3: -2147287038
MSI(i) [13:54:55.601] | MSI (c) (B0:9C) [13:54:55:593]: Machine policy value 'DisableMsi' is 0
MSI(i) [13:54:55.601] | MSI (c) (B0:9C) [13:54:55:593]: Machine policy value 'AlwaysInstallElevated' is 0
MSI(i) [13:54:55.601] | MSI (c) (B0:9C) [13:54:55:593]: User policy value 'AlwaysInstallElevated' is 0
MSI(i) [13:54:55.601] | MSI (c) (B0:9C) [13:54:55:593]: Product installation will be elevated because user is admin and product is being installed per-machine.
MSI(i) [13:54:55.601] | MSI (c) (B0:9C) [13:54:55:593]: Running product '{E16E559E-30A0-49BA-81F5-636CE693B4A1}' with elevated privileges: Product is assigned.
MSI(i) [13:54:55.601] | MSI (c) (B0:9C) [13:54:55:594]: PROPERTY CHANGE: Adding MsiSystemRebootPending property. Its value is '1'.
MSI(i) [13:54:55.601] | MSI (c) (B0:9C) [13:54:55:594]: TRANSFORMS property is now:
MSI(i) [13:54:55.601] | MSI (c) (B0:9C) [13:54:55:594]: PROPERTY CHANGE: Adding VersionDatabase property. Its value is '200'.
MSI(i) [13:54:55.601] | MSI (c) (B0:9C) [13:54:55:594]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming
MSI(i) [13:54:55.601] | MSI (c) (B0:9C) [13:54:55:594]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Favorites
MSI(i) [13:54:55.601] | MSI (c) (B0:9C) [13:54:55:594]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Network Shortcuts
MSI(i) [13:54:55.601] | MSI (c) (B0:9C) [13:54:55:594]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Documents
MSI(i) [13:54:55.601] | MSI (c) (B0:9C) [13:54:55:594]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
MSI(i) [13:54:55.601] | MSI (c) (B0:9C) [13:54:55:594]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Recent
MSI(i) [13:54:55.601] | MSI (c) (B0:9C) [13:54:55:594]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\SendTo
MSI(i) [13:54:55.601] | MSI (c) (B0:9C) [13:54:55:594]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Templates
MSI(i) [13:54:55.601] | MSI (c) (B0:9C) [13:54:55:594]: SHELL32::SHGetFolderPath returned: C:\ProgramData
MSI(i) [13:54:55.601] | MSI (c) (B0:9C) [13:54:55:594]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Local
MSI(i) [13:54:55.601] | MSI (c) (B0:9C) [13:54:55:594]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Pictures
MSI(i) [13:54:55.601] | MSI (c) (B0:9C) [13:54:55:594]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI(i) [13:54:55.601] | MSI (c) (B0:9C) [13:54:55:594]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
MSI(i) [13:54:55.601] | MSI (c) (B0:9C) [13:54:55:594]: SHELL32::SHGetFolderPath returned: C:\Users\Public\Desktop
MSI(i) [13:54:55.601] | MSI (c) (B0:9C) [13:54:55:594]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI(i) [13:54:55.601] | MSI (c) (B0:9C) [13:54:55:594]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
MSI(i) [13:54:55.601] | MSI (c) (B0:9C) [13:54:55:594]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Desktop
MSI(i) [13:54:55.601] | MSI (c) (B0:9C) [13:54:55:594]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Templates
MSI(i) [13:54:55.601] | MSI (c) (B0:9C) [13:54:55:594]: SHELL32::SHGetFolderPath returned: C:\Windows\Fonts
MSI(i) [13:54:55.601] | MSI (c) (B0:9C) [13:54:55:594]: Note: 1: 2898 2: MS Sans Serif 3: MS Sans Serif 4: 0 5: 16
MSI(i) [13:54:55.601] | MSI (c) (B0:9C) [13:54:55:600]: MSI_LUA: Setting AdminUser property to 1 because this is the client or the user has already permitted elevation
MSI(i) [13:54:55.601] | MSI (c) (B0:9C) [13:54:55:600]: MSI_LUA: Setting MsiRunningElevated property to 1 because the install is already running elevated.
MSI(i) [13:54:55.601] | MSI (c) (B0:9C) [13:54:55:600]: PROPERTY CHANGE: Adding MsiRunningElevated property. Its value is '1'.
MSI(i) [13:54:55.601] | MSI (c) (B0:9C) [13:54:55:600]: PROPERTY CHANGE: Adding Privileged property. Its value is '1'.
MSI(i) [13:54:55.601] | MSI (c) (B0:9C) [13:54:55:600]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\MS Setup (ACME)\User Info 3: 2
MSI(i) [13:54:55.601] | MSI (c) (B0:9C) [13:54:55:600]: PROPERTY CHANGE: Adding USERNAME property. Its value is 'A Valued IT Customer'.
MSI(i) [13:54:55.601] | MSI (c) (B0:9C) [13:54:55:600]: PROPERTY CHANGE: Adding COMPANYNAME property. Its value is 'Intel Corporation'.
MSI(i) [13:54:55.601] | MSI (c) (B0:9C) [13:54:55:600]: PROPERTY CHANGE: Adding DATABASE property. Its value is 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs2010-integration.msi'.
MSI(i) [13:54:55.601] | MSI (c) (B0:9C) [13:54:55:600]: PROPERTY CHANGE: Adding OriginalDatabase property. Its value is 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs2010-integration.msi'.
MSI(i) [13:54:55.601] | MSI (c) (B0:9C) [13:54:55:600]: Machine policy value 'MsiDisableEmbeddedUI' is 0
MSI(i) [13:54:55.601] | MSI (c) (B0:9C) [13:54:55:600]: EEUI - Disabling MsiEmbeddedUI in quiet mode
MSI(i) [13:54:55.601] | === Logging started: 4/8/2014  13:54:55 ===
MSI(i) [13:54:55.601] | MSI (c) (B0:9C) [13:54:55:600]: Note: 1: 2205 2:  3: PatchPackage
MSI(i) [13:54:55.601] | MSI (c) (B0:9C) [13:54:55:600]: Machine policy value 'DisableRollback' is 0
MSI(i) [13:54:55.601] | MSI (c) (B0:9C) [13:54:55:600]: User policy value 'DisableRollback' is 0
MSI(i) [13:54:55.601] | MSI (c) (B0:9C) [13:54:55:600]: PROPERTY CHANGE: Adding UILevel property. Its value is '2'.
MSI(i) [13:54:55.601] | MSI (c) (B0:9C) [13:54:55:600]: Creating MSIHANDLE (64) of type 790537 for thread 3996
MSI(i) [13:54:55.601] | MSI (c) (B0:9C) [13:54:55:600]: MsiOpenPackageEx is returning 0
MSI(i) [13:54:55.601] | MSI (c) (B0:9C) [13:54:55:600]: Closing MSIHANDLE (64) of type 790537 for thread 3996
MSI(i) [13:54:55.601] | === Verbose logging stopped: 4/8/2014  13:54:55 ===
PSET(i) [13:54:55.609] | (4225.285): MsiOpenPackageEx(C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs2010-integration.msi)
MSI(i) [13:54:55.673] | === Verbose logging started: 4/8/2014  13:54:55  Build type: SHIP UNICODE 5.00.7601.00  Calling process: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\setup.exe ===
MSI(i) [13:54:55.673] | MSI (c) (B0:9C) [13:54:55:610]: SOFTWARE RESTRICTION POLICY: Verifying package --> 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs2010-integration.msi' against software restriction policy
MSI(i) [13:54:55.673] | MSI (c) (B0:9C) [13:54:55:610]: SOFTWARE RESTRICTION POLICY: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs2010-integration.msi has a digital signature
MSI(i) [13:54:55.673] | MSI (c) (B0:9C) [13:54:55:626]: SOFTWARE RESTRICTION POLICY: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs2010-integration.msi is permitted to run at the 'unrestricted' authorization level.
MSI(i) [13:54:55.673] | MSI (c) (B0:9C) [13:54:55:627]: Cloaking enabled.
MSI(i) [13:54:55.673] | MSI (c) (B0:9C) [13:54:55:627]: Attempting to enable all disabled privileges before calling Install on Server
MSI(i) [13:54:55.673] | MSI (c) (B0:9C) [13:54:55:627]: End dialog not enabled
MSI(i) [13:54:55.673] | MSI (c) (B0:9C) [13:54:55:627]: Original package ==> C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs2010-integration.msi
MSI(i) [13:54:55.673] | MSI (c) (B0:9C) [13:54:55:627]: Package we're running from ==> C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs2010-integration.msi
MSI(i) [13:54:55.673] | MSI (c) (B0:9C) [13:54:55:628]: Machine policy value 'DisableUserInstalls' is 0
MSI(i) [13:54:55.673] | MSI (c) (B0:9C) [13:54:55:629]: APPCOMPAT: Compatibility mode property overrides found.
MSI(i) [13:54:55.673] | MSI (c) (B0:9C) [13:54:55:629]: APPCOMPAT: looking for appcompat database entry with ProductCode '{E16E559E-30A0-49BA-81F5-636CE693B4A1}'.
MSI(i) [13:54:55.673] | MSI (c) (B0:9C) [13:54:55:629]: APPCOMPAT: no matching ProductCode found in database.
MSI(i) [13:54:55.673] | MSI (c) (B0:9C) [13:54:55:633]: MSCOREE not loaded loading copy from system32
MSI(i) [13:54:55.673] | MSI (c) (B0:9C) [13:54:55:637]: Machine policy value 'TransformsSecure' is 0
MSI(i) [13:54:55.673] | MSI (c) (B0:9C) [13:54:55:637]: User policy value 'TransformsAtSource' is 0
MSI(i) [13:54:55.673] | MSI (c) (B0:9C) [13:54:55:637]: Machine policy value 'DisablePatch' is 0
MSI(i) [13:54:55.673] | MSI (c) (B0:9C) [13:54:55:637]: Machine policy value 'AllowLockdownPatch' is 0
MSI(i) [13:54:55.673] | MSI (c) (B0:9C) [13:54:55:637]: Machine policy value 'DisableLUAPatching' is 0
MSI(i) [13:54:55.673] | MSI (c) (B0:9C) [13:54:55:637]: Machine policy value 'DisableFlyWeightPatching' is 0
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:637]: Enabling baseline caching for this transaction since all active patches are MSI 3.0 style MSPs or at least one MSI 3.0 minor update patch is active
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:638]: APPCOMPAT: looking for appcompat database entry with ProductCode '{E16E559E-30A0-49BA-81F5-636CE693B4A1}'.
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:638]: APPCOMPAT: no matching ProductCode found in database.
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:638]: Transforms are not secure.
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:638]: PROPERTY CHANGE: Adding MsiLogFileLocation property. Its value is 'C:\Users\PCCA-PM\AppData\Local\Temp\MSIED31.tmp'.
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:638]: No Command Line.
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:638]: PROPERTY CHANGE: Adding PackageCode property. Its value is '{4E6E5693-7562-4ABD-B30F-309AC4849EEF}'.
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:638]: Product Code passed to Engine.Initialize:           '(none)'
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:638]: Product Code from property table before transforms: '{E16E559E-30A0-49BA-81F5-636CE693B4A1}'
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:638]: Product Code from property table after transforms:  '{E16E559E-30A0-49BA-81F5-636CE693B4A1}'
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:638]: Product not registered: beginning first-time install
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:638]: PROPERTY CHANGE: Adding ProductState property. Its value is '-1'.
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:638]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer 3: 2
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:638]: Entering CMsiConfigurationManager::SetLastUsedSource.
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:638]: User policy value 'SearchOrder' is 'nmu'
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:638]: Adding new sources is allowed.
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:638]: PROPERTY CHANGE: Adding PackagecodeChanging property. Its value is '1'.
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:638]: Package name extracted from package path: 'vs2010-integration.msi'
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:638]: Package to be registered: 'vs2010-integration.msi'
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:638]: Note: 1: 2205 2:  3: Error
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:639]: Note: 1: 2262 2: AdminProperties 3: -2147287038
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:639]: Machine policy value 'DisableMsi' is 0
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:639]: Machine policy value 'AlwaysInstallElevated' is 0
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:639]: User policy value 'AlwaysInstallElevated' is 0
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:639]: Product installation will be elevated because user is admin and product is being installed per-machine.
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:639]: Running product '{E16E559E-30A0-49BA-81F5-636CE693B4A1}' with elevated privileges: Product is assigned.
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:639]: PROPERTY CHANGE: Adding MsiSystemRebootPending property. Its value is '1'.
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:639]: TRANSFORMS property is now:
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:639]: PROPERTY CHANGE: Adding VersionDatabase property. Its value is '200'.
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:640]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:640]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Favorites
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:640]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Network Shortcuts
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:640]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Documents
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:640]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:640]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Recent
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:640]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\SendTo
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:640]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Templates
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:640]: SHELL32::SHGetFolderPath returned: C:\ProgramData
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:640]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Local
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:640]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Pictures
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:640]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:640]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:640]: SHELL32::SHGetFolderPath returned: C:\Users\Public\Desktop
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:640]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:640]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:640]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Desktop
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:640]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Templates
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:640]: SHELL32::SHGetFolderPath returned: C:\Windows\Fonts
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:640]: Note: 1: 2898 2: MS Sans Serif 3: MS Sans Serif 4: 0 5: 16
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:645]: MSI_LUA: Setting AdminUser property to 1 because this is the client or the user has already permitted elevation
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:645]: MSI_LUA: Setting MsiRunningElevated property to 1 because the install is already running elevated.
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:645]: PROPERTY CHANGE: Adding MsiRunningElevated property. Its value is '1'.
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:645]: PROPERTY CHANGE: Adding Privileged property. Its value is '1'.
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:646]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\MS Setup (ACME)\User Info 3: 2
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:646]: PROPERTY CHANGE: Adding USERNAME property. Its value is 'A Valued IT Customer'.
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:646]: PROPERTY CHANGE: Adding COMPANYNAME property. Its value is 'Intel Corporation'.
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:646]: PROPERTY CHANGE: Adding DATABASE property. Its value is 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs2010-integration.msi'.
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:646]: PROPERTY CHANGE: Adding OriginalDatabase property. Its value is 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs2010-integration.msi'.
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:646]: Machine policy value 'MsiDisableEmbeddedUI' is 0
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:646]: EEUI - Disabling MsiEmbeddedUI in quiet mode
MSI(i) [13:54:55.674] | === Logging started: 4/8/2014  13:54:55 ===
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:646]: Note: 1: 2205 2:  3: PatchPackage
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:646]: Machine policy value 'DisableRollback' is 0
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:646]: User policy value 'DisableRollback' is 0
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:646]: PROPERTY CHANGE: Adding UILevel property. Its value is '2'.
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:646]: Creating MSIHANDLE (65) of type 790537 for thread 3996
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:646]: MsiOpenPackageEx is returning 0
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:646]: Creating MSIHANDLE (66) of type 790541 for thread 3996
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:646]: Closing MSIHANDLE (66) of type 790541 for thread 3996
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:646]: Doing action: AppSearch
MSI(i) [13:54:55.674] | Action 13:54:55: AppSearch. Searching for installed applications
MSI(i) [13:54:55.674] | Action start 13:54:55: AppSearch.
MSI(i) [13:54:55.674] | AppSearch: Property: VS2010DIR.F7B87292_18A1_47AE_B415_0A3834A439C4, Signature: SIG_VS2010_DIR.F7B87292_18A1_47AE_B415_0A3834A439C4
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:648]: Note: 1: 2262 2: Signature 3: -2147287038
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:648]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE32\SOFTWARE\Microsoft\VisualStudio\10.0\Setup\VS 3: 2
MSI(i) [13:54:55.674] | AppSearch: Property: VS2011DIR.F7B87292_18A1_47AE_B415_0A3834A439C4, Signature: SIG_VS2011_DIR.F7B87292_18A1_47AE_B415_0A3834A439C4
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:648]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE32\SOFTWARE\Microsoft\VisualStudio\11.0\Setup\VS 3: 2
MSI(i) [13:54:55.674] | AppSearch: Property: DEVENV_EXE_2008.589D170B_7826_4DA4_9294_78FB5D852D57, Signature: RL_DevenvExe_2008.589D170B_7826_4DA4_9294_78FB5D852D57
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:648]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE32\SOFTWARE\Microsoft\VisualStudio\9.0\Setup\VS 3: 2
MSI(i) [13:54:55.674] | AppSearch: Property: DEVENV_EXE_2010.589D170B_7826_4DA4_9294_78FB5D852D57, Signature: RL_DevenvExe_2010.589D170B_7826_4DA4_9294_78FB5D852D57
MSI(i) [13:54:55.674] | AppSearch: Property: DEVENV_EXE_2011.589D170B_7826_4DA4_9294_78FB5D852D57, Signature: RL_DevenvExe_2011.589D170B_7826_4DA4_9294_78FB5D852D57
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:649]: Note: 1: 2262 2: Signature 3: -2147287038
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:649]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE32\SOFTWARE\Microsoft\VisualStudio\11.0\Setup\VS 3: 2
MSI(i) [13:54:55.674] | Action ended 13:54:55: AppSearch. Return value 1.
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:649]: Doing action: CostInitialize
MSI(i) [13:54:55.674] | Action 13:54:55: CostInitialize. Computing space requirements
MSI(i) [13:54:55.674] | Action start 13:54:55: CostInitialize.
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:650]: Machine policy value 'MaxPatchCacheSize' is 10
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:650]: Baseline: Sorting baselines for {E16E559E-30A0-49BA-81F5-636CE693B4A1}.
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:650]: Baseline: New baseline 13.1.5000 from transaction.
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:650]: Baseline: Sorted order Native: Order 0.
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:650]: Baseline Data Table:
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:650]: ProductCode: {E16E559E-30A0-49BA-81F5-636CE693B4A1} Version: 13.1.5000 Attributes: 0 PatchId: Native BaselineId: -2147483648 Order: 0
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:650]: Baseline File Table:
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:651]: PROPERTY CHANGE: Adding ROOTDRIVE property. Its value is 'C:\'.
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:651]: PROPERTY CHANGE: Adding CostingComplete property. Its value is '0'.
MSI(i) [13:54:55.674] | Action ended 13:54:55: CostInitialize. Return value 1.
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:651]: Doing action: FileCost
MSI(i) [13:54:55.674] | Action 13:54:55: FileCost. Computing space requirements
MSI(i) [13:54:55.674] | Action start 13:54:55: FileCost.
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:652]: Note: 1: 2205 2:  3: MsiAssembly
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:652]: Note: 1: 2205 2:  3: Class
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:652]: Note: 1: 2205 2:  3: Extension
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:652]: Note: 1: 2205 2:  3: TypeLib
MSI(i) [13:54:55.674] | Action ended 13:54:55: FileCost. Return value 1.
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:652]: Doing action: CostFinalize
MSI(i) [13:54:55.674] | Action 13:54:55: CostFinalize. Computing space requirements
MSI(i) [13:54:55.674] | Action start 13:54:55: CostFinalize.
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:653]: PROPERTY CHANGE: Adding OutOfDiskSpace property. Its value is '0'.
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:653]: PROPERTY CHANGE: Adding OutOfNoRbDiskSpace property. Its value is '0'.
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:653]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceAvailable property. Its value is '0'.
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:653]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRequired property. Its value is '0'.
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:653]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRemaining property. Its value is '0'.
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:653]: Note: 1: 2205 2:  3: Patch
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:653]: Note: 1: 2205 2:  3: Condition
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:654]: PROPERTY CHANGE: Adding TARGETDIR property. Its value is 'C:\'.
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:654]: PROPERTY CHANGE: Adding VS11_REMOTE_DEBUGGER_X64_DIR property. Its value is 'C:\'.
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:654]: PROPERTY CHANGE: Adding VS11_DEBUGER_DIR property. Its value is 'C:\'.
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:654]: PROPERTY CHANGE: Adding INSTALLDIR property. Its value is 'C:\'.
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:654]: PROPERTY CHANGE: Adding CommonFilesFolder.589D170B_7826_4DA4_9294_78FB5D852D57 property. Its value is 'C:\'.
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:654]: PROPERTY CHANGE: Adding CmnIntel.589D170B_7826_4DA4_9294_78FB5D852D57 property. Its value is 'C:\Intel\'.
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:654]: PROPERTY CHANGE: Adding CmnIntelHEBundle.589D170B_7826_4DA4_9294_78FB5D852D57 property. Its value is 'C:\Intel\Parallel Studio XE 2013\'.
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:654]: PROPERTY CHANGE: Adding HEBundleMenuDir.589D170B_7826_4DA4_9294_78FB5D852D57 property. Its value is 'C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Intel Parallel Studio XE 2013\'.
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:654]: PROPERTY CHANGE: Adding CommonFilesFolder.95C3848C_D156_4249_942C_7A8A0976584F property. Its value is 'C:\'.
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:654]: PROPERTY CHANGE: Adding CmnIntel.95C3848C_D156_4249_942C_7A8A0976584F property. Its value is 'C:\Intel\'.
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:654]: PROPERTY CHANGE: Adding CmnIntelHEBundle.95C3848C_D156_4249_942C_7A8A0976584F property. Its value is 'C:\Intel\Parallel Studio XE 2013\'.
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:654]: PROPERTY CHANGE: Adding VS2010DIR.F7B87292_18A1_47AE_B415_0A3834A439C4 property. Its value is 'C:\Program Files (x86)\VS2010DIR\'.
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:654]: PROPERTY CHANGE: Adding Common7.F7B87292_18A1_47AE_B415_0A3834A439C4 property. Its value is 'C:\Program Files (x86)\VS2010DIR\Common7\'.
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:654]: PROPERTY CHANGE: Adding IDE.F7B87292_18A1_47AE_B415_0A3834A439C4 property. Its value is 'C:\Program Files (x86)\VS2010DIR\Common7\IDE\'.
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:654]: PROPERTY CHANGE: Adding Extensions.F7B87292_18A1_47AE_B415_0A3834A439C4 property. Its value is 'C:\Program Files (x86)\VS2010DIR\Common7\IDE\Extensions\'.
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:654]: PROPERTY CHANGE: Adding Intel_.F7B87292_18A1_47AE_B415_0A3834A439C4 property. Its value is 'C:\Program Files (x86)\VS2010DIR\Common7\IDE\Extensions\Intel\'.
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:654]: PROPERTY CHANGE: Adding Intel.SoftwareManager.F7B87292_18A1_47AE_B415_0A3834A439C4 property. Its value is 'C:\Program Files (x86)\VS2010DIR\Common7\IDE\Extensions\Intel\Intel.SoftwareManager\'.
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:654]: PROPERTY CHANGE: Adding ja0.F7B87292_18A1_47AE_B415_0A3834A439C4 property. Its value is 'C:\Program Files (x86)\VS2010DIR\Common7\IDE\Extensions\Intel\Intel.SoftwareManager\ja\'.
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:654]: Target path resolution complete. Dumping Directory table...
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:654]: Note: target paths subject to change (via custom actions or browsing)
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:654]: Dir (target): Key: TARGETDIR    , Object: C:\
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:654]: Dir (target): Key: WindowsFolder    , Object: C:\Windows\
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:654]: Dir (target): Key: VS11_REMOTE_DEBUGGER_X64_DIR    , Object: C:\
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:654]: Dir (target): Key: VS11_DEBUGER_DIR    , Object: C:\
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:654]: Dir (target): Key: CommonFilesFolder    , Object: C:\Program Files (x86)\Common Files\
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:654]: Dir (target): Key: INSTALLDIR    , Object: C:\
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:654]: Dir (target): Key: CommonFilesFolder.589D170B_7826_4DA4_9294_78FB5D852D57    , Object: C:\
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:654]: Dir (target): Key: CmnIntel.589D170B_7826_4DA4_9294_78FB5D852D57    , Object: C:\Intel\
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:654]: Dir (target): Key: CmnIntelHEBundle.589D170B_7826_4DA4_9294_78FB5D852D57    , Object: C:\Intel\Parallel Studio XE 2013\
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:654]: Dir (target): Key: ProgramMenuFolder    , Object: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:654]: Dir (target): Key: HEBundleMenuDir.589D170B_7826_4DA4_9294_78FB5D852D57    , Object: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Intel Parallel Studio XE 2013\
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:654]: Dir (target): Key: CommonFilesFolder.95C3848C_D156_4249_942C_7A8A0976584F    , Object: C:\
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:654]: Dir (target): Key: CmnIntel.95C3848C_D156_4249_942C_7A8A0976584F    , Object: C:\Intel\
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:654]: Dir (target): Key: CmnIntelHEBundle.95C3848C_D156_4249_942C_7A8A0976584F    , Object: C:\Intel\Parallel Studio XE 2013\
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:654]: Dir (target): Key: ProgramFilesFolder    , Object: C:\Program Files (x86)\
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:654]: Dir (target): Key: VS2010DIR.F7B87292_18A1_47AE_B415_0A3834A439C4    , Object: C:\Program Files (x86)\VS2010DIR\
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:654]: Dir (target): Key: Common7.F7B87292_18A1_47AE_B415_0A3834A439C4    , Object: C:\Program Files (x86)\VS2010DIR\Common7\
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:654]: Dir (target): Key: IDE.F7B87292_18A1_47AE_B415_0A3834A439C4    , Object: C:\Program Files (x86)\VS2010DIR\Common7\IDE\
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:654]: Dir (target): Key: Extensions.F7B87292_18A1_47AE_B415_0A3834A439C4    , Object: C:\Program Files (x86)\VS2010DIR\Common7\IDE\Extensions\
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:654]: Dir (target): Key: Intel_.F7B87292_18A1_47AE_B415_0A3834A439C4    , Object: C:\Program Files (x86)\VS2010DIR\Common7\IDE\Extensions\Intel\
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:654]: Dir (target): Key: Intel.SoftwareManager.F7B87292_18A1_47AE_B415_0A3834A439C4    , Object: C:\Program Files (x86)\VS2010DIR\Common7\IDE\Extensions\Intel\Intel.SoftwareManager\
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:654]: Dir (target): Key: ja0.F7B87292_18A1_47AE_B415_0A3834A439C4    , Object: C:\Program Files (x86)\VS2010DIR\Common7\IDE\Extensions\Intel\Intel.SoftwareManager\ja\
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:654]: PROPERTY CHANGE: Adding INSTALLLEVEL property. Its value is '1'.
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:654]: Note: 1: 2205 2:  3: MsiAssembly
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:654]: Note: 1: 2228 2:  3: MsiAssembly 4:  SELECT `MsiAssembly`.`Attributes`, `MsiAssembly`.`File_Application`, `MsiAssembly`.`File_Manifest`,  `Component`.`KeyPath` FROM `MsiAssembly`, `Component` WHERE  `MsiAssembly`.`Component_` = `Component`.`Component` AND `MsiAssembly`.`Component_` = ?
MSI(i) [13:54:55.674] | Action ended 13:54:55: CostFinalize. Return value 1.
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:655]: Doing action: InstallValidate
MSI(i) [13:54:55.674] | Action 13:54:55: InstallValidate. Validating install
MSI(i) [13:54:55.674] | Action start 13:54:55: InstallValidate.
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:657]: Note: 1: 2205 2:  3: Dialog
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:657]: Feature: core; Installed: Absent;   Request: Local;   Action: Local
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:657]: Component: ProductFamilyAnchor; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:657]: Component: ProductVersionAnchor; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:657]: Component: CommonIntegrationAnchor; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:657]: Component: VsIntegrationAnchor; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:657]: Component: reg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:657]: Component: Comp_Intel.SoftwareManager.dll0.F7B87292_18A1_47AE_B415_0A3834A439C4; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:657]: Component: Comp_Intel.SoftwareManager.pkgdef.F7B87292_18A1_47AE_B415_0A3834A439C4; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:657]: Component: Comp_Intel.SoftwareManager.resources.dll0.F7B87292_18A1_47AE_B415_0A3834A439C4; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:657]: Component: vs_run.exe.95C3848C_D156_4249_942C_7A8A0976584F; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:657]: Component: VS2010.589D170B_7826_4DA4_9294_78FB5D852D57; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:657]: Component: VS2010_win8.589D170B_7826_4DA4_9294_78FB5D852D57; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:657]: Component: __reg65; Installed: Null;   Request: Local;   Action: Local;   Client State: Null
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:657]: Component: __VS2010.589D170B_7826_4DA4_9294_78FB5D852D5765; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:657]: Component: __VS2010_win8.589D170B_7826_4DA4_9294_78FB5D852D5765; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:657]: Note: 1: 2205 2:  3: BindImage
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:657]: Note: 1: 2205 2:  3: ProgId
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:657]: Note: 1: 2205 2:  3: PublishComponent
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:657]: Note: 1: 2205 2:  3: SelfReg
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:657]: Note: 1: 2205 2:  3: Extension
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:657]: Note: 1: 2205 2:  3: Font
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:657]: Note: 1: 2205 2:  3: Class
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:657]: Note: 1: 2205 2:  3: TypeLib
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:657]: Note: 1: 2205 2:  3: _RemoveFilePath
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:658]: PROPERTY CHANGE: Modifying CostingComplete property. Its current value is '0'. Its new value: '1'.
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:658]: Note: 1: 2205 2:  3: BindImage
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:658]: Note: 1: 2205 2:  3: ProgId
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:658]: Note: 1: 2205 2:  3: PublishComponent
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:658]: Note: 1: 2205 2:  3: SelfReg
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:658]: Note: 1: 2205 2:  3: Extension
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:658]: Note: 1: 2205 2:  3: Font
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:658]: Note: 1: 2205 2:  3: Class
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:658]: Note: 1: 2205 2:  3: TypeLib
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:658]: Note: 1: 2727 2:
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:673]: Note: 1: 2727 2:
MSI(i) [13:54:55.674] | Action ended 13:54:55: InstallValidate. Return value 1.
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:673]: Creating MSIHANDLE (67) of type 790541 for thread 3996
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:673]: Creating MSIHANDLE (68) of type 790540 for thread 3996
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:673]: Creating MSIHANDLE (69) of type 790531 for thread 3996
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:673]: Note: 1: 2205 2:  3: Condition
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:673]: Note: 1: 2228 2:  3: Condition 4: SELECT * FROM Condition WHERE Feature_ = 'core'
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:673]: Creating MSIHANDLE (70) of type 790540 for thread 3996
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:673]: Closing MSIHANDLE (70) of type 790540 for thread 3996
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:673]: Closing MSIHANDLE (69) of type 790531 for thread 3996
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:673]: Closing MSIHANDLE (68) of type 790540 for thread 3996
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:673]: Closing MSIHANDLE (67) of type 790541 for thread 3996
MSI(i) [13:54:55.674] | MSI (c) (B0:9C) [13:54:55:673]: Leaked MSIHANDLE (65) of type 790537 for thread 3996
MSI(i) [13:54:55.674] | === Verbose logging stopped: 4/8/2014  13:54:55 ===
PSET(i) [13:54:55.682] | (4225.1904): Dependency {ACD97E2A-090D-46ea-9983-6E44BCA28575} always show dialog
PSET(i) [13:54:55.682] | (4225.1904): Dependency {3AE471C7-8858-472a-8D7C-48B871B5EBDF} always show dialog
PSET(i) [13:54:55.682] | (4225.1904): Dependency {D52A1D2E-8D7A-4822-9421-3A92C64DB956} always show dialog
PSET(i) [13:54:55.683] | (4225.2963): MsiOpenPackageEx(C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\dim\distributed_install.msi)
MSI(i) [13:54:55.737] | === Verbose logging started: 4/8/2014  13:54:55  Build type: SHIP UNICODE 5.00.7601.00  Calling process: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\setup.exe ===
MSI(i) [13:54:55.737] | MSI (c) (B0:9C) [13:54:55:684]: SOFTWARE RESTRICTION POLICY: Verifying package --> 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\dim\distributed_install.msi' against software restriction policy
MSI(i) [13:54:55.737] | MSI (c) (B0:9C) [13:54:55:684]: SOFTWARE RESTRICTION POLICY: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\dim\distributed_install.msi has a digital signature
MSI(i) [13:54:55.737] | MSI (c) (B0:9C) [13:54:55:715]: SOFTWARE RESTRICTION POLICY: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\dim\distributed_install.msi is permitted to run at the 'unrestricted' authorization level.
MSI(i) [13:54:55.737] | MSI (c) (B0:9C) [13:54:55:716]: Cloaking enabled.
MSI(i) [13:54:55.737] | MSI (c) (B0:9C) [13:54:55:716]: Attempting to enable all disabled privileges before calling Install on Server
MSI(i) [13:54:55.737] | MSI (c) (B0:9C) [13:54:55:716]: End dialog not enabled
MSI(i) [13:54:55.737] | MSI (c) (B0:9C) [13:54:55:717]: Original package ==> C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\dim\distributed_install.msi
MSI(i) [13:54:55.737] | MSI (c) (B0:9C) [13:54:55:717]: Package we're running from ==> C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\dim\distributed_install.msi
MSI(i) [13:54:55.737] | MSI (c) (B0:9C) [13:54:55:717]: APPCOMPAT: Uninstall Flags override found.
MSI(i) [13:54:55.737] | MSI (c) (B0:9C) [13:54:55:718]: APPCOMPAT: Uninstall VersionNT override found.
MSI(i) [13:54:55.737] | MSI (c) (B0:9C) [13:54:55:718]: APPCOMPAT: Uninstall ServicePackLevel override found.
MSI(i) [13:54:55.737] | MSI (c) (B0:9C) [13:54:55:718]: APPCOMPAT: looking for appcompat database entry with ProductCode '{F885F6E6-0B5D-4925-877F-6A08BD25CEDE}'.
MSI(i) [13:54:55.737] | MSI (c) (B0:9C) [13:54:55:718]: APPCOMPAT: no matching ProductCode found in database.
MSI(i) [13:54:55.737] | MSI (c) (B0:9C) [13:54:55:723]: MSCOREE not loaded loading copy from system32
MSI(i) [13:54:55.737] | MSI (c) (B0:9C) [13:54:55:727]: Note: 1: 2262 2: File 3: -2147287038
MSI(i) [13:54:55.737] | MSI (c) (B0:9C) [13:54:55:727]: Note: 1: 2205 2:  3: MsiFileHash
MSI(i) [13:54:55.737] | MSI (c) (B0:9C) [13:54:55:727]: Machine policy value 'DisablePatch' is 0
MSI(i) [13:54:55.737] | MSI (c) (B0:9C) [13:54:55:727]: Machine policy value 'AllowLockdownPatch' is 0
MSI(i) [13:54:55.737] | MSI (c) (B0:9C) [13:54:55:727]: Machine policy value 'DisableLUAPatching' is 0
MSI(i) [13:54:55.737] | MSI (c) (B0:9C) [13:54:55:727]: Machine policy value 'DisableFlyWeightPatching' is 0
MSI(i) [13:54:55.737] | MSI (c) (B0:9C) [13:54:55:727]: Enabling baseline caching for this transaction since all active patches are MSI 3.0 style MSPs or at least one MSI 3.0 minor update patch is active
MSI(i) [13:54:55.737] | MSI (c) (B0:9C) [13:54:55:728]: APPCOMPAT: looking for appcompat database entry with ProductCode '{F885F6E6-0B5D-4925-877F-6A08BD25CEDE}'.
MSI(i) [13:54:55.737] | MSI (c) (B0:9C) [13:54:55:728]: APPCOMPAT: no matching ProductCode found in database.
MSI(i) [13:54:55.737] | MSI (c) (B0:9C) [13:54:55:728]: Transforms are not secure.
MSI(i) [13:54:55.737] | MSI (c) (B0:9C) [13:54:55:728]: PROPERTY CHANGE: Adding MsiLogFileLocation property. Its value is 'C:\Users\PCCA-PM\AppData\Local\Temp\MSIED31.tmp'.
MSI(i) [13:54:55.737] | MSI (c) (B0:9C) [13:54:55:728]: No Command Line.
MSI(i) [13:54:55.737] | MSI (c) (B0:9C) [13:54:55:728]: PROPERTY CHANGE: Adding PackageCode property. Its value is '{EFB1D39E-7DFF-42E4-B17F-388BAADE8B58}'.
MSI(i) [13:54:55.737] | MSI (c) (B0:9C) [13:54:55:728]: Product Code passed to Engine.Initialize:           '(none)'
MSI(i) [13:54:55.737] | MSI (c) (B0:9C) [13:54:55:728]: Product Code from property table before transforms: '{F885F6E6-0B5D-4925-877F-6A08BD25CEDE}'
MSI(i) [13:54:55.737] | MSI (c) (B0:9C) [13:54:55:728]: Product Code from property table after transforms:  '{F885F6E6-0B5D-4925-877F-6A08BD25CEDE}'
MSI(i) [13:54:55.737] | MSI (c) (B0:9C) [13:54:55:728]: Product registered: entering maintenance mode
MSI(i) [13:54:55.737] | MSI (c) (B0:9C) [13:54:55:728]: Determined that existing product (either this product or the product being upgraded with a patch) is installed per-machine.
MSI(i) [13:54:55.737] | MSI (c) (B0:9C) [13:54:55:728]: PROPERTY CHANGE: Adding ProductState property. Its value is '5'.
MSI(i) [13:54:55.737] | MSI (c) (B0:9C) [13:54:55:728]: PROPERTY CHANGE: Adding ProductToBeRegistered property. Its value is '1'.
MSI(i) [13:54:55.737] | MSI (c) (B0:9C) [13:54:55:728]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer 3: 2
MSI(i) [13:54:55.737] | MSI (c) (B0:9C) [13:54:55:728]: Entering CMsiConfigurationManager::SetLastUsedSource.
MSI(i) [13:54:55.737] | MSI (c) (B0:9C) [13:54:55:729]: Specifed source is already in a list.
MSI(i) [13:54:55.737] | MSI (c) (B0:9C) [13:54:55:729]: User policy value 'SearchOrder' is 'nmu'
MSI(i) [13:54:55.737] | MSI (c) (B0:9C) [13:54:55:729]: Machine policy value 'DisableBrowse' is 0
MSI(i) [13:54:55.737] | MSI (c) (B0:9C) [13:54:55:729]: Machine policy value 'AllowLockdownBrowse' is 0
MSI(i) [13:54:55.737] | MSI (c) (B0:9C) [13:54:55:729]: Adding new sources is allowed.
MSI(i) [13:54:55.737] | MSI (c) (B0:9C) [13:54:55:729]: Package name retrieved from configuration data: 'distributed_install.msi'
MSI(i) [13:54:55.737] | MSI (c) (B0:9C) [13:54:55:729]: Note: 1: 2205 2:  3: Error
MSI(i) [13:54:55.737] | MSI (c) (B0:9C) [13:54:55:729]: Note: 1: 2262 2: AdminProperties 3: -2147287038
MSI(i) [13:54:55.737] | MSI (c) (B0:9C) [13:54:55:729]: Machine policy value 'DisableMsi' is 0
MSI(i) [13:54:55.737] | MSI (c) (B0:9C) [13:54:55:729]: Machine policy value 'AlwaysInstallElevated' is 0
MSI(i) [13:54:55.737] | MSI (c) (B0:9C) [13:54:55:729]: User policy value 'AlwaysInstallElevated' is 0
MSI(i) [13:54:55.737] | MSI (c) (B0:9C) [13:54:55:729]: Product {F885F6E6-0B5D-4925-877F-6A08BD25CEDE} is admin assigned: LocalSystem owns the publish key.
MSI(i) [13:54:55.737] | MSI (c) (B0:9C) [13:54:55:729]: Product {F885F6E6-0B5D-4925-877F-6A08BD25CEDE} is managed.
MSI(i) [13:54:55.737] | MSI (c) (B0:9C) [13:54:55:729]: Running product '{F885F6E6-0B5D-4925-877F-6A08BD25CEDE}' with elevated privileges: Product is assigned.
MSI(i) [13:54:55.737] | MSI (c) (B0:9C) [13:54:55:730]: PROPERTY CHANGE: Adding MsiSystemRebootPending property. Its value is '1'.
MSI(i) [13:54:55.737] | MSI (c) (B0:9C) [13:54:55:730]: TRANSFORMS property is now:
MSI(i) [13:54:55.738] | MSI (c) (B0:9C) [13:54:55:730]: PROPERTY CHANGE: Adding PRODUCTLANGUAGE property. Its value is '1033'.
MSI(i) [13:54:55.738] | MSI (c) (B0:9C) [13:54:55:730]: PROPERTY CHANGE: Adding VersionDatabase property. Its value is '200'.
MSI(i) [13:54:55.738] | MSI (c) (B0:9C) [13:54:55:730]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming
MSI(i) [13:54:55.738] | MSI (c) (B0:9C) [13:54:55:730]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Favorites
MSI(i) [13:54:55.738] | MSI (c) (B0:9C) [13:54:55:730]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Network Shortcuts
MSI(i) [13:54:55.738] | MSI (c) (B0:9C) [13:54:55:730]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Documents
MSI(i) [13:54:55.738] | MSI (c) (B0:9C) [13:54:55:730]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
MSI(i) [13:54:55.738] | MSI (c) (B0:9C) [13:54:55:730]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Recent
MSI(i) [13:54:55.738] | MSI (c) (B0:9C) [13:54:55:730]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\SendTo
MSI(i) [13:54:55.738] | MSI (c) (B0:9C) [13:54:55:730]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Templates
MSI(i) [13:54:55.738] | MSI (c) (B0:9C) [13:54:55:730]: SHELL32::SHGetFolderPath returned: C:\ProgramData
MSI(i) [13:54:55.738] | MSI (c) (B0:9C) [13:54:55:730]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Local
MSI(i) [13:54:55.738] | MSI (c) (B0:9C) [13:54:55:730]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Pictures
MSI(i) [13:54:55.738] | MSI (c) (B0:9C) [13:54:55:730]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI(i) [13:54:55.738] | MSI (c) (B0:9C) [13:54:55:730]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
MSI(i) [13:54:55.738] | MSI (c) (B0:9C) [13:54:55:730]: SHELL32::SHGetFolderPath returned: C:\Users\Public\Desktop
MSI(i) [13:54:55.738] | MSI (c) (B0:9C) [13:54:55:730]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI(i) [13:54:55.738] | MSI (c) (B0:9C) [13:54:55:730]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
MSI(i) [13:54:55.738] | MSI (c) (B0:9C) [13:54:55:730]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Desktop
MSI(i) [13:54:55.738] | MSI (c) (B0:9C) [13:54:55:730]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Templates
MSI(i) [13:54:55.738] | MSI (c) (B0:9C) [13:54:55:730]: SHELL32::SHGetFolderPath returned: C:\Windows\Fonts
MSI(i) [13:54:55.738] | MSI (c) (B0:9C) [13:54:55:731]: Note: 1: 2898 2: MS Sans Serif 3: MS Sans Serif 4: 0 5: 16
MSI(i) [13:54:55.738] | MSI (c) (B0:9C) [13:54:55:736]: MSI_LUA: Setting AdminUser property to 1 because this is the client or the user has already permitted elevation
MSI(i) [13:54:55.738] | MSI (c) (B0:9C) [13:54:55:736]: MSI_LUA: Setting MsiRunningElevated property to 1 because the install is already running elevated.
MSI(i) [13:54:55.738] | MSI (c) (B0:9C) [13:54:55:736]: PROPERTY CHANGE: Adding MsiRunningElevated property. Its value is '1'.
MSI(i) [13:54:55.738] | MSI (c) (B0:9C) [13:54:55:736]: PROPERTY CHANGE: Adding Privileged property. Its value is '1'.
MSI(i) [13:54:55.738] | MSI (c) (B0:9C) [13:54:55:736]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\MS Setup (ACME)\User Info 3: 2
MSI(i) [13:54:55.738] | MSI (c) (B0:9C) [13:54:55:736]: PROPERTY CHANGE: Adding USERNAME property. Its value is 'A Valued IT Customer'.
MSI(i) [13:54:55.738] | MSI (c) (B0:9C) [13:54:55:736]: PROPERTY CHANGE: Adding COMPANYNAME property. Its value is 'Intel Corporation'.
MSI(i) [13:54:55.738] | MSI (c) (B0:9C) [13:54:55:736]: PROPERTY CHANGE: Adding Installed property. Its value is '00:00:00'.
MSI(i) [13:54:55.738] | MSI (c) (B0:9C) [13:54:55:736]: PROPERTY CHANGE: Adding DATABASE property. Its value is 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\dim\distributed_install.msi'.
MSI(i) [13:54:55.738] | MSI (c) (B0:9C) [13:54:55:736]: PROPERTY CHANGE: Adding OriginalDatabase property. Its value is 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\dim\distributed_install.msi'.
MSI(i) [13:54:55.738] | MSI (c) (B0:9C) [13:54:55:736]: Machine policy value 'MsiDisableEmbeddedUI' is 0
MSI(i) [13:54:55.738] | MSI (c) (B0:9C) [13:54:55:736]: EEUI - Disabling MsiEmbeddedUI in quiet mode
MSI(i) [13:54:55.738] | === Logging started: 4/8/2014  13:54:55 ===
MSI(i) [13:54:55.738] | MSI (c) (B0:9C) [13:54:55:737]: Note: 1: 2205 2:  3: PatchPackage
MSI(i) [13:54:55.738] | MSI (c) (B0:9C) [13:54:55:737]: Machine policy value 'DisableRollback' is 0
MSI(i) [13:54:55.738] | MSI (c) (B0:9C) [13:54:55:737]: User policy value 'DisableRollback' is 0
MSI(i) [13:54:55.738] | MSI (c) (B0:9C) [13:54:55:737]: PROPERTY CHANGE: Adding UILevel property. Its value is '2'.
MSI(i) [13:54:55.738] | MSI (c) (B0:9C) [13:54:55:737]: Creating MSIHANDLE (71) of type 790537 for thread 3996
MSI(i) [13:54:55.738] | MSI (c) (B0:9C) [13:54:55:737]: MsiOpenPackageEx is returning 0
MSI(i) [13:54:55.738] | MSI (c) (B0:9C) [13:54:55:737]: Closing MSIHANDLE (71) of type 790537 for thread 3996
MSI(i) [13:54:55.738] | === Verbose logging stopped: 4/8/2014  13:54:55 ===
PSET(i) [13:54:55.745] | (4225.285): MsiOpenPackageEx(C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\dim\distributed_install.msi)
MSI(i) [13:54:55.826] | === Verbose logging started: 4/8/2014  13:54:55  Build type: SHIP UNICODE 5.00.7601.00  Calling process: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\setup.exe ===
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:746]: SOFTWARE RESTRICTION POLICY: Verifying package --> 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\dim\distributed_install.msi' against software restriction policy
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:746]: SOFTWARE RESTRICTION POLICY: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\dim\distributed_install.msi has a digital signature
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:778]: SOFTWARE RESTRICTION POLICY: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\dim\distributed_install.msi is permitted to run at the 'unrestricted' authorization level.
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:779]: Cloaking enabled.
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:779]: Attempting to enable all disabled privileges before calling Install on Server
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:779]: End dialog not enabled
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:779]: Original package ==> C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\dim\distributed_install.msi
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:779]: Package we're running from ==> C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\dim\distributed_install.msi
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:779]: Machine policy value 'DisableUserInstalls' is 0
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:780]: APPCOMPAT: Uninstall Flags override found.
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:780]: APPCOMPAT: Uninstall VersionNT override found.
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:780]: APPCOMPAT: Uninstall ServicePackLevel override found.
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:780]: APPCOMPAT: looking for appcompat database entry with ProductCode '{F885F6E6-0B5D-4925-877F-6A08BD25CEDE}'.
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:780]: APPCOMPAT: no matching ProductCode found in database.
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:785]: MSCOREE not loaded loading copy from system32
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:789]: Note: 1: 2262 2: File 3: -2147287038
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:789]: Note: 1: 2205 2:  3: MsiFileHash
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:789]: Machine policy value 'DisablePatch' is 0
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:789]: Machine policy value 'AllowLockdownPatch' is 0
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:789]: Machine policy value 'DisableLUAPatching' is 0
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:789]: Machine policy value 'DisableFlyWeightPatching' is 0
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:789]: Enabling baseline caching for this transaction since all active patches are MSI 3.0 style MSPs or at least one MSI 3.0 minor update patch is active
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:789]: APPCOMPAT: looking for appcompat database entry with ProductCode '{F885F6E6-0B5D-4925-877F-6A08BD25CEDE}'.
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:789]: APPCOMPAT: no matching ProductCode found in database.
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:789]: Transforms are not secure.
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:789]: PROPERTY CHANGE: Adding MsiLogFileLocation property. Its value is 'C:\Users\PCCA-PM\AppData\Local\Temp\MSIED31.tmp'.
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:789]: No Command Line.
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:789]: PROPERTY CHANGE: Adding PackageCode property. Its value is '{EFB1D39E-7DFF-42E4-B17F-388BAADE8B58}'.
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:790]: Product Code passed to Engine.Initialize:           '(none)'
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:790]: Product Code from property table before transforms: '{F885F6E6-0B5D-4925-877F-6A08BD25CEDE}'
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:790]: Product Code from property table after transforms:  '{F885F6E6-0B5D-4925-877F-6A08BD25CEDE}'
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:790]: Product registered: entering maintenance mode
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:790]: Determined that existing product (either this product or the product being upgraded with a patch) is installed per-machine.
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:790]: PROPERTY CHANGE: Adding ProductState property. Its value is '5'.
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:790]: PROPERTY CHANGE: Adding ProductToBeRegistered property. Its value is '1'.
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:790]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer 3: 2
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:790]: Entering CMsiConfigurationManager::SetLastUsedSource.
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:790]: Specifed source is already in a list.
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:790]: User policy value 'SearchOrder' is 'nmu'
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:790]: Machine policy value 'DisableBrowse' is 0
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:790]: Machine policy value 'AllowLockdownBrowse' is 0
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:790]: Adding new sources is allowed.
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:790]: Package name retrieved from configuration data: 'distributed_install.msi'
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:791]: Note: 1: 2205 2:  3: Error
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:791]: Note: 1: 2262 2: AdminProperties 3: -2147287038
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:791]: Machine policy value 'DisableMsi' is 0
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:791]: Machine policy value 'AlwaysInstallElevated' is 0
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:791]: User policy value 'AlwaysInstallElevated' is 0
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:791]: Product {F885F6E6-0B5D-4925-877F-6A08BD25CEDE} is admin assigned: LocalSystem owns the publish key.
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:791]: Product {F885F6E6-0B5D-4925-877F-6A08BD25CEDE} is managed.
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:791]: Running product '{F885F6E6-0B5D-4925-877F-6A08BD25CEDE}' with elevated privileges: Product is assigned.
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:792]: PROPERTY CHANGE: Adding MsiSystemRebootPending property. Its value is '1'.
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:792]: TRANSFORMS property is now:
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:792]: PROPERTY CHANGE: Adding PRODUCTLANGUAGE property. Its value is '1033'.
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:792]: PROPERTY CHANGE: Adding VersionDatabase property. Its value is '200'.
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:792]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:792]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Favorites
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:792]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Network Shortcuts
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:792]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Documents
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:792]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:792]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Recent
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:792]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\SendTo
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:792]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Templates
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:792]: SHELL32::SHGetFolderPath returned: C:\ProgramData
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:792]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Local
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:792]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Pictures
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:792]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:792]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:792]: SHELL32::SHGetFolderPath returned: C:\Users\Public\Desktop
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:792]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:792]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:792]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Desktop
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:793]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Templates
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:793]: SHELL32::SHGetFolderPath returned: C:\Windows\Fonts
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:793]: Note: 1: 2898 2: MS Sans Serif 3: MS Sans Serif 4: 0 5: 16
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:800]: MSI_LUA: Setting AdminUser property to 1 because this is the client or the user has already permitted elevation
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:800]: MSI_LUA: Setting MsiRunningElevated property to 1 because the install is already running elevated.
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:800]: PROPERTY CHANGE: Adding MsiRunningElevated property. Its value is '1'.
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:800]: PROPERTY CHANGE: Adding Privileged property. Its value is '1'.
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:800]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\MS Setup (ACME)\User Info 3: 2
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:800]: PROPERTY CHANGE: Adding USERNAME property. Its value is 'A Valued IT Customer'.
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:800]: PROPERTY CHANGE: Adding COMPANYNAME property. Its value is 'Intel Corporation'.
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:800]: PROPERTY CHANGE: Adding Installed property. Its value is '00:00:00'.
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:800]: PROPERTY CHANGE: Adding DATABASE property. Its value is 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\dim\distributed_install.msi'.
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:800]: PROPERTY CHANGE: Adding OriginalDatabase property. Its value is 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\dim\distributed_install.msi'.
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:800]: Machine policy value 'MsiDisableEmbeddedUI' is 0
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:800]: EEUI - Disabling MsiEmbeddedUI in quiet mode
MSI(i) [13:54:55.826] | === Logging started: 4/8/2014  13:54:55 ===
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:800]: Note: 1: 2205 2:  3: PatchPackage
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:800]: Machine policy value 'DisableRollback' is 0
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:800]: User policy value 'DisableRollback' is 0
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:800]: PROPERTY CHANGE: Adding UILevel property. Its value is '2'.
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:801]: Creating MSIHANDLE (72) of type 790537 for thread 3996
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:801]: MsiOpenPackageEx is returning 0
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:801]: Creating MSIHANDLE (73) of type 790541 for thread 3996
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:801]: Closing MSIHANDLE (73) of type 790541 for thread 3996
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:801]: Doing action: AppSearch
MSI(i) [13:54:55.826] | Action 13:54:55: AppSearch. Searching for installed applications
MSI(i) [13:54:55.826] | Action start 13:54:55: AppSearch.
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:802]: Note: 1: 2205 2:  3: AppSearch
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:802]: Note: 1: 2228 2:  3: AppSearch 4: SELECT `Property`, `Signature_` FROM `AppSearch`
MSI(i) [13:54:55.826] | Action ended 13:54:55: AppSearch. Return value 0.
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:802]: Doing action: CostInitialize
MSI(i) [13:54:55.826] | Action 13:54:55: CostInitialize. Computing space requirements
MSI(i) [13:54:55.826] | Action start 13:54:55: CostInitialize.
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:803]: Machine policy value 'MaxPatchCacheSize' is 10
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:803]: Baseline: Sorting baselines for {F885F6E6-0B5D-4925-877F-6A08BD25CEDE}.
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:803]: Baseline: New baseline 1.0.0 from transaction.
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:803]: Baseline: Sorted order Native: Order 0.
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:803]: Baseline Data Table:
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:803]: ProductCode: {F885F6E6-0B5D-4925-877F-6A08BD25CEDE} Version: 1.0.0 Attributes: 0 PatchId: Native BaselineId: -2147483648 Order: 0
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:803]: Baseline File Table:
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:804]: PROPERTY CHANGE: Adding ROOTDRIVE property. Its value is 'C:\'.
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:804]: PROPERTY CHANGE: Adding CostingComplete property. Its value is '0'.
MSI(i) [13:54:55.826] | Action ended 13:54:55: CostInitialize. Return value 1.
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:804]: Doing action: FileCost
MSI(i) [13:54:55.826] | Action 13:54:55: FileCost. Computing space requirements
MSI(i) [13:54:55.826] | Action start 13:54:55: FileCost.
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:805]: Note: 1: 2205 2:  3: MsiAssembly
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:805]: Note: 1: 2205 2:  3: Registry
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:805]: Note: 1: 2205 2:  3: Class
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:805]: Note: 1: 2205 2:  3: Extension
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:805]: Note: 1: 2205 2:  3: TypeLib
MSI(i) [13:54:55.826] | Action ended 13:54:55: FileCost. Return value 1.
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:806]: Doing action: CostFinalize
MSI(i) [13:54:55.826] | Action 13:54:55: CostFinalize. Computing space requirements
MSI(i) [13:54:55.826] | Action start 13:54:55: CostFinalize.
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:807]: PROPERTY CHANGE: Adding OutOfDiskSpace property. Its value is '0'.
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:807]: PROPERTY CHANGE: Adding OutOfNoRbDiskSpace property. Its value is '0'.
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:807]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceAvailable property. Its value is '0'.
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:807]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRequired property. Its value is '0'.
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:807]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRemaining property. Its value is '0'.
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:807]: Note: 1: 2205 2:  3: MsiAssembly
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:807]: Note: 1: 2228 2:  3: MsiAssembly 4:  SELECT `MsiAssembly`.`Attributes`, `MsiAssembly`.`File_Application`, `MsiAssembly`.`File_Manifest`,  `Component`.`KeyPath` FROM `MsiAssembly`, `Component` WHERE  `MsiAssembly`.`Component_` = `Component`.`Component` AND `MsiAssembly`.`Component_` = ?
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:807]: PROPERTY CHANGE: Adding INSTALLDIR property. Its value is 'C:\Program Files (x86)\Intel\VTune Amplifier XE 2013'.
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:807]: PROPERTY CHANGE: Adding INTEL_LICENSE_FILE.68A24C09_F55E_4862_88B8_473B8FC6723A property. Its value is 'C:\Program Files (x86)\Common Files\Intel\Licenses'.
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:807]: Note: 1: 2205 2:  3: Patch
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:807]: Note: 1: 2205 2:  3: Condition
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:808]: PROPERTY CHANGE: Adding TARGETDIR property. Its value is 'C:\'.
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:808]: PROPERTY CHANGE: Adding INTEL property. Its value is 'C:\Program Files (x86)\Intel\'.
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:808]: PROPERTY CHANGE: Modifying INSTALLDIR property. Its current value is 'C:\Program Files (x86)\Intel\VTune Amplifier XE 2013'. Its new value: 'C:\Program Files (x86)\Intel\VTune Amplifier XE 2013\'.
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:808]: PROPERTY CHANGE: Adding CommonFilesFolder.68A24C09_F55E_4862_88B8_473B8FC6723A property. Its value is 'C:\Program Files (x86)\Intel\VTune Amplifier XE 2013\'.
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:808]: PROPERTY CHANGE: Adding INTEL.68A24C09_F55E_4862_88B8_473B8FC6723A property. Its value is 'C:\Program Files (x86)\Intel\VTune Amplifier XE 2013\Intel\'.
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:808]: PROPERTY CHANGE: Modifying INTEL_LICENSE_FILE.68A24C09_F55E_4862_88B8_473B8FC6723A property. Its current value is 'C:\Program Files (x86)\Common Files\Intel\Licenses'. Its new value: 'C:\Program Files (x86)\Common Files\Intel\Licenses\'.
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:808]: Target path resolution complete. Dumping Directory table...
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:808]: Note: target paths subject to change (via custom actions or browsing)
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:808]: Dir (target): Key: TARGETDIR    , Object: C:\
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:808]: Dir (target): Key: ProgramFilesFolder    , Object: C:\Program Files (x86)\
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:808]: Dir (target): Key: INTEL    , Object: C:\Program Files (x86)\Intel\
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:808]: Dir (target): Key: INSTALLDIR    , Object: C:\Program Files (x86)\Intel\VTune Amplifier XE 2013\
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:808]: Dir (target): Key: CommonFilesFolder.68A24C09_F55E_4862_88B8_473B8FC6723A    , Object: C:\Program Files (x86)\Intel\VTune Amplifier XE 2013\
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:808]: Dir (target): Key: INTEL.68A24C09_F55E_4862_88B8_473B8FC6723A    , Object: C:\Program Files (x86)\Intel\VTune Amplifier XE 2013\Intel\
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:808]: Dir (target): Key: INTEL_LICENSE_FILE.68A24C09_F55E_4862_88B8_473B8FC6723A    , Object: C:\Program Files (x86)\Common Files\Intel\Licenses\
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:808]: PROPERTY CHANGE: Adding INSTALLLEVEL property. Its value is '1'.
MSI(i) [13:54:55.826] | Action ended 13:54:55: CostFinalize. Return value 1.
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:808]: Doing action: InstallValidate
MSI(i) [13:54:55.826] | Action 13:54:55: InstallValidate. Validating install
MSI(i) [13:54:55.826] | Action start 13:54:55: InstallValidate.
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:809]: Feature: FlexLMCheck; Installed: Local;   Request: Null;   Action: Null
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:809]: Component: ProductFamilyAnchor; Installed: Local;   Request: Null;   Action: Local;   Client State: Absent
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:809]: Component: ProductVersionAnchor; Installed: Local;   Request: Null;   Action: Local;   Client State: Absent
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:809]: Component: CompMsiMarker; Installed: Local;   Request: Null;   Action: Local;   Client State: Absent
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:809]: Component: Intel_products; Installed: Local;   Request: Null;   Action: Local;   Client State: Absent
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:809]: Component: feature.68A24C09_F55E_4862_88B8_473B8FC6723A; Installed: Local;   Request: Null;   Action: Null;   Client State: Local
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:809]: Component: CopyLicenseStub.68A24C09_F55E_4862_88B8_473B8FC6723A; Installed: Local;   Request: Null;   Action: Local;   Client State: Absent
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:809]: Note: 1: 2205 2:  3: Registry
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:809]: Note: 1: 2205 2:  3: BindImage
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:809]: Note: 1: 2205 2:  3: ProgId
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:809]: Note: 1: 2205 2:  3: PublishComponent
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:809]: Note: 1: 2205 2:  3: SelfReg
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:809]: Note: 1: 2205 2:  3: Extension
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:809]: Note: 1: 2205 2:  3: Font
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:809]: Note: 1: 2205 2:  3: Shortcut
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:809]: Note: 1: 2205 2:  3: Class
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:809]: Note: 1: 2205 2:  3: Icon
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:809]: Note: 1: 2205 2:  3: TypeLib
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:809]: PROPERTY CHANGE: Modifying CostingComplete property. Its current value is '0'. Its new value: '1'.
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:810]: Note: 1: 2205 2:  3: PublishComponent
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:810]: Note: 1: 2205 2:  3: SelfReg
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:810]: Note: 1: 2205 2:  3: Extension
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:810]: Note: 1: 2205 2:  3: Font
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:810]: Note: 1: 2205 2:  3: Shortcut
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:810]: Note: 1: 2205 2:  3: Class
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:810]: Note: 1: 2205 2:  3: Icon
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:810]: Note: 1: 2205 2:  3: TypeLib
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:810]: Note: 1: 2727 2:
MSI(i) [13:54:55.826] | MSI (c) (B0:9C) [13:54:55:824]: Note: 1: 2727 2:
MSI(i) [13:54:55.826] | Action ended 13:54:55: InstallValidate. Return value 1.
MSI(i) [13:54:55.827] | MSI (c) (B0:9C) [13:54:55:824]: Creating MSIHANDLE (74) of type 790541 for thread 3996
MSI(i) [13:54:55.827] | MSI (c) (B0:9C) [13:54:55:824]: Creating MSIHANDLE (75) of type 790540 for thread 3996
MSI(i) [13:54:55.827] | MSI (c) (B0:9C) [13:54:55:824]: Creating MSIHANDLE (76) of type 790531 for thread 3996
MSI(i) [13:54:55.827] | MSI (c) (B0:9C) [13:54:55:825]: Note: 1: 2205 2:  3: Condition
MSI(i) [13:54:55.827] | MSI (c) (B0:9C) [13:54:55:825]: Note: 1: 2228 2:  3: Condition 4: SELECT * FROM Condition WHERE Feature_ = 'FlexLMCheck'
MSI(i) [13:54:55.827] | MSI (c) (B0:9C) [13:54:55:825]: Creating MSIHANDLE (77) of type 790540 for thread 3996
MSI(i) [13:54:55.827] | MSI (c) (B0:9C) [13:54:55:825]: Closing MSIHANDLE (77) of type 790540 for thread 3996
MSI(i) [13:54:55.827] | MSI (c) (B0:9C) [13:54:55:825]: Closing MSIHANDLE (76) of type 790531 for thread 3996
MSI(i) [13:54:55.827] | MSI (c) (B0:9C) [13:54:55:825]: Closing MSIHANDLE (75) of type 790540 for thread 3996
MSI(i) [13:54:55.827] | MSI (c) (B0:9C) [13:54:55:825]: Closing MSIHANDLE (74) of type 790541 for thread 3996
MSI(i) [13:54:55.827] | MSI (c) (B0:9C) [13:54:55:825]: Note: 1: 2727 2:
MSI(i) [13:54:55.827] | MSI (c) (B0:9C) [13:54:55:825]: Leaked MSIHANDLE (72) of type 790537 for thread 3996
MSI(i) [13:54:55.827] | === Verbose logging stopped: 4/8/2014  13:54:55 ===
PSET(i) [13:54:55.834] | (4225.1904): Dependency {97BC3C88-834C-11DE-B575-22C956D89593} always show dialog
PSET(i) [13:54:55.835] | (4225.2963): MsiOpenPackageEx(C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\msvcrt_x86.msi)
MSI(i) [13:54:55.879] | === Verbose logging started: 4/8/2014  13:54:55  Build type: SHIP UNICODE 5.00.7601.00  Calling process: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\setup.exe ===
MSI(i) [13:54:55.879] | MSI (c) (B0:9C) [13:54:55:836]: SOFTWARE RESTRICTION POLICY: Verifying package --> 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\msvcrt_x86.msi' against software restriction policy
MSI(i) [13:54:55.879] | MSI (c) (B0:9C) [13:54:55:836]: SOFTWARE RESTRICTION POLICY: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\msvcrt_x86.msi has a digital signature
MSI(i) [13:54:55.879] | MSI (c) (B0:9C) [13:54:55:857]: SOFTWARE RESTRICTION POLICY: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\msvcrt_x86.msi is permitted to run at the 'unrestricted' authorization level.
MSI(i) [13:54:55.879] | MSI (c) (B0:9C) [13:54:55:857]: Cloaking enabled.
MSI(i) [13:54:55.879] | MSI (c) (B0:9C) [13:54:55:857]: Attempting to enable all disabled privileges before calling Install on Server
MSI(i) [13:54:55.879] | MSI (c) (B0:9C) [13:54:55:857]: End dialog not enabled
MSI(i) [13:54:55.879] | MSI (c) (B0:9C) [13:54:55:858]: Original package ==> C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\msvcrt_x86.msi
MSI(i) [13:54:55.879] | MSI (c) (B0:9C) [13:54:55:858]: Package we're running from ==> C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\msvcrt_x86.msi
MSI(i) [13:54:55.879] | MSI (c) (B0:9C) [13:54:55:861]: APPCOMPAT: Compatibility mode property overrides found.
MSI(i) [13:54:55.879] | MSI (c) (B0:9C) [13:54:55:861]: APPCOMPAT: looking for appcompat database entry with ProductCode '{E36578FC-39EC-423E-BCE1-82D5E9C04BBC}'.
MSI(i) [13:54:55.879] | MSI (c) (B0:9C) [13:54:55:861]: APPCOMPAT: no matching ProductCode found in database.
MSI(i) [13:54:55.879] | MSI (c) (B0:9C) [13:54:55:865]: MSCOREE not loaded loading copy from system32
MSI(i) [13:54:55.879] | MSI (c) (B0:9C) [13:54:55:869]: Machine policy value 'TransformsSecure' is 0
MSI(i) [13:54:55.879] | MSI (c) (B0:9C) [13:54:55:869]: User policy value 'TransformsAtSource' is 0
MSI(i) [13:54:55.879] | MSI (c) (B0:9C) [13:54:55:869]: Machine policy value 'DisablePatch' is 0
MSI(i) [13:54:55.879] | MSI (c) (B0:9C) [13:54:55:869]: Machine policy value 'AllowLockdownPatch' is 0
MSI(i) [13:54:55.879] | MSI (c) (B0:9C) [13:54:55:869]: Machine policy value 'DisableLUAPatching' is 0
MSI(i) [13:54:55.879] | MSI (c) (B0:9C) [13:54:55:869]: Machine policy value 'DisableFlyWeightPatching' is 0
MSI(i) [13:54:55.879] | MSI (c) (B0:9C) [13:54:55:869]: Enabling baseline caching for this transaction since all active patches are MSI 3.0 style MSPs or at least one MSI 3.0 minor update patch is active
MSI(i) [13:54:55.879] | MSI (c) (B0:9C) [13:54:55:870]: APPCOMPAT: looking for appcompat database entry with ProductCode '{E36578FC-39EC-423E-BCE1-82D5E9C04BBC}'.
MSI(i) [13:54:55.879] | MSI (c) (B0:9C) [13:54:55:870]: APPCOMPAT: no matching ProductCode found in database.
MSI(i) [13:54:55.879] | MSI (c) (B0:9C) [13:54:55:870]: Transforms are not secure.
MSI(i) [13:54:55.879] | MSI (c) (B0:9C) [13:54:55:870]: PROPERTY CHANGE: Adding MsiLogFileLocation property. Its value is 'C:\Users\PCCA-PM\AppData\Local\Temp\MSIED31.tmp'.
MSI(i) [13:54:55.879] | MSI (c) (B0:9C) [13:54:55:870]: No Command Line.
MSI(i) [13:54:55.879] | MSI (c) (B0:9C) [13:54:55:870]: PROPERTY CHANGE: Adding PackageCode property. Its value is '{0400CFE6-8998-4683-9D11-5B2E6557D065}'.
MSI(i) [13:54:55.879] | MSI (c) (B0:9C) [13:54:55:870]: Product Code passed to Engine.Initialize:           '(none)'
MSI(i) [13:54:55.879] | MSI (c) (B0:9C) [13:54:55:870]: Product Code from property table before transforms: '{E36578FC-39EC-423E-BCE1-82D5E9C04BBC}'
MSI(i) [13:54:55.879] | MSI (c) (B0:9C) [13:54:55:870]: Product Code from property table after transforms:  '{E36578FC-39EC-423E-BCE1-82D5E9C04BBC}'
MSI(i) [13:54:55.879] | MSI (c) (B0:9C) [13:54:55:870]: Product not registered: beginning first-time install
MSI(i) [13:54:55.879] | MSI (c) (B0:9C) [13:54:55:870]: PROPERTY CHANGE: Adding ProductState property. Its value is '-1'.
MSI(i) [13:54:55.879] | MSI (c) (B0:9C) [13:54:55:870]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer 3: 2
MSI(i) [13:54:55.879] | MSI (c) (B0:9C) [13:54:55:870]: Entering CMsiConfigurationManager::SetLastUsedSource.
MSI(i) [13:54:55.879] | MSI (c) (B0:9C) [13:54:55:870]: User policy value 'SearchOrder' is 'nmu'
MSI(i) [13:54:55.879] | MSI (c) (B0:9C) [13:54:55:870]: Adding new sources is allowed.
MSI(i) [13:54:55.879] | MSI (c) (B0:9C) [13:54:55:870]: PROPERTY CHANGE: Adding PackagecodeChanging property. Its value is '1'.
MSI(i) [13:54:55.879] | MSI (c) (B0:9C) [13:54:55:870]: Package name extracted from package path: 'msvcrt_x86.msi'
MSI(i) [13:54:55.879] | MSI (c) (B0:9C) [13:54:55:871]: Package to be registered: 'msvcrt_x86.msi'
MSI(i) [13:54:55.879] | MSI (c) (B0:9C) [13:54:55:871]: Note: 1: 2262 2: AdminProperties 3: -2147287038
MSI(i) [13:54:55.879] | MSI (c) (B0:9C) [13:54:55:871]: Machine policy value 'DisableMsi' is 0
MSI(i) [13:54:55.879] | MSI (c) (B0:9C) [13:54:55:871]: Machine policy value 'AlwaysInstallElevated' is 0
MSI(i) [13:54:55.879] | MSI (c) (B0:9C) [13:54:55:871]: User policy value 'AlwaysInstallElevated' is 0
MSI(i) [13:54:55.879] | MSI (c) (B0:9C) [13:54:55:871]: Product installation will be elevated because user is admin and product is being installed per-machine.
MSI(i) [13:54:55.879] | MSI (c) (B0:9C) [13:54:55:871]: Running product '{E36578FC-39EC-423E-BCE1-82D5E9C04BBC}' with elevated privileges: Product is assigned.
MSI(i) [13:54:55.879] | MSI (c) (B0:9C) [13:54:55:871]: PROPERTY CHANGE: Adding MsiSystemRebootPending property. Its value is '1'.
MSI(i) [13:54:55.879] | MSI (c) (B0:9C) [13:54:55:871]: TRANSFORMS property is now:
MSI(i) [13:54:55.879] | MSI (c) (B0:9C) [13:54:55:871]: PROPERTY CHANGE: Adding VersionDatabase property. Its value is '200'.
MSI(i) [13:54:55.879] | MSI (c) (B0:9C) [13:54:55:872]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming
MSI(i) [13:54:55.879] | MSI (c) (B0:9C) [13:54:55:872]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Favorites
MSI(i) [13:54:55.879] | MSI (c) (B0:9C) [13:54:55:872]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Network Shortcuts
MSI(i) [13:54:55.879] | MSI (c) (B0:9C) [13:54:55:872]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Documents
MSI(i) [13:54:55.879] | MSI (c) (B0:9C) [13:54:55:872]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
MSI(i) [13:54:55.879] | MSI (c) (B0:9C) [13:54:55:872]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Recent
MSI(i) [13:54:55.879] | MSI (c) (B0:9C) [13:54:55:872]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\SendTo
MSI(i) [13:54:55.879] | MSI (c) (B0:9C) [13:54:55:872]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Templates
MSI(i) [13:54:55.879] | MSI (c) (B0:9C) [13:54:55:872]: SHELL32::SHGetFolderPath returned: C:\ProgramData
MSI(i) [13:54:55.879] | MSI (c) (B0:9C) [13:54:55:872]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Local
MSI(i) [13:54:55.879] | MSI (c) (B0:9C) [13:54:55:872]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Pictures
MSI(i) [13:54:55.879] | MSI (c) (B0:9C) [13:54:55:872]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI(i) [13:54:55.879] | MSI (c) (B0:9C) [13:54:55:872]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
MSI(i) [13:54:55.879] | MSI (c) (B0:9C) [13:54:55:872]: SHELL32::SHGetFolderPath returned: C:\Users\Public\Desktop
MSI(i) [13:54:55.879] | MSI (c) (B0:9C) [13:54:55:872]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI(i) [13:54:55.879] | MSI (c) (B0:9C) [13:54:55:872]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
MSI(i) [13:54:55.879] | MSI (c) (B0:9C) [13:54:55:872]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Desktop
MSI(i) [13:54:55.879] | MSI (c) (B0:9C) [13:54:55:872]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Templates
MSI(i) [13:54:55.879] | MSI (c) (B0:9C) [13:54:55:872]: SHELL32::SHGetFolderPath returned: C:\Windows\Fonts
MSI(i) [13:54:55.879] | MSI (c) (B0:9C) [13:54:55:873]: Note: 1: 2898 2: MS Sans Serif 3: MS Sans Serif 4: 0 5: 16
MSI(i) [13:54:55.879] | MSI (c) (B0:9C) [13:54:55:878]: MSI_LUA: Setting AdminUser property to 1 because this is the client or the user has already permitted elevation
MSI(i) [13:54:55.879] | MSI (c) (B0:9C) [13:54:55:878]: MSI_LUA: Setting MsiRunningElevated property to 1 because the install is already running elevated.
MSI(i) [13:54:55.879] | MSI (c) (B0:9C) [13:54:55:878]: PROPERTY CHANGE: Adding MsiRunningElevated property. Its value is '1'.
MSI(i) [13:54:55.879] | MSI (c) (B0:9C) [13:54:55:878]: PROPERTY CHANGE: Adding Privileged property. Its value is '1'.
MSI(i) [13:54:55.879] | MSI (c) (B0:9C) [13:54:55:878]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\MS Setup (ACME)\User Info 3: 2
MSI(i) [13:54:55.879] | MSI (c) (B0:9C) [13:54:55:878]: PROPERTY CHANGE: Adding USERNAME property. Its value is 'A Valued IT Customer'.
MSI(i) [13:54:55.879] | MSI (c) (B0:9C) [13:54:55:878]: PROPERTY CHANGE: Adding COMPANYNAME property. Its value is 'Intel Corporation'.
MSI(i) [13:54:55.879] | MSI (c) (B0:9C) [13:54:55:878]: PROPERTY CHANGE: Adding DATABASE property. Its value is 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\msvcrt_x86.msi'.
MSI(i) [13:54:55.879] | MSI (c) (B0:9C) [13:54:55:878]: PROPERTY CHANGE: Adding OriginalDatabase property. Its value is 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\msvcrt_x86.msi'.
MSI(i) [13:54:55.879] | MSI (c) (B0:9C) [13:54:55:878]: Machine policy value 'MsiDisableEmbeddedUI' is 0
MSI(i) [13:54:55.879] | MSI (c) (B0:9C) [13:54:55:878]: EEUI - Disabling MsiEmbeddedUI in quiet mode
MSI(i) [13:54:55.879] | === Logging started: 4/8/2014  13:54:55 ===
MSI(i) [13:54:55.879] | MSI (c) (B0:9C) [13:54:55:878]: Note: 1: 2205 2:  3: PatchPackage
MSI(i) [13:54:55.879] | MSI (c) (B0:9C) [13:54:55:878]: Machine policy value 'DisableRollback' is 0
MSI(i) [13:54:55.879] | MSI (c) (B0:9C) [13:54:55:878]: User policy value 'DisableRollback' is 0
MSI(i) [13:54:55.879] | MSI (c) (B0:9C) [13:54:55:878]: PROPERTY CHANGE: Adding UILevel property. Its value is '2'.
MSI(i) [13:54:55.879] | MSI (c) (B0:9C) [13:54:55:878]: Creating MSIHANDLE (78) of type 790537 for thread 3996
MSI(i) [13:54:55.879] | MSI (c) (B0:9C) [13:54:55:878]: MsiOpenPackageEx is returning 0
MSI(i) [13:54:55.879] | MSI (c) (B0:9C) [13:54:55:878]: Closing MSIHANDLE (78) of type 790537 for thread 3996
MSI(i) [13:54:55.879] | === Verbose logging stopped: 4/8/2014  13:54:55 ===
PSET(i) [13:54:55.887] | (4225.285): MsiOpenPackageEx(C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\msvcrt_x86.msi)
MSI(i) [13:54:55.965] | === Verbose logging started: 4/8/2014  13:54:55  Build type: SHIP UNICODE 5.00.7601.00  Calling process: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\setup.exe ===
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:888]: SOFTWARE RESTRICTION POLICY: Verifying package --> 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\msvcrt_x86.msi' against software restriction policy
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:888]: SOFTWARE RESTRICTION POLICY: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\msvcrt_x86.msi has a digital signature
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:909]: SOFTWARE RESTRICTION POLICY: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\msvcrt_x86.msi is permitted to run at the 'unrestricted' authorization level.
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:910]: Cloaking enabled.
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:910]: Attempting to enable all disabled privileges before calling Install on Server
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:910]: End dialog not enabled
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:910]: Original package ==> C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\msvcrt_x86.msi
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:910]: Package we're running from ==> C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\msvcrt_x86.msi
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:911]: Machine policy value 'DisableUserInstalls' is 0
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:912]: APPCOMPAT: Compatibility mode property overrides found.
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:912]: APPCOMPAT: looking for appcompat database entry with ProductCode '{E36578FC-39EC-423E-BCE1-82D5E9C04BBC}'.
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:912]: APPCOMPAT: no matching ProductCode found in database.
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:917]: MSCOREE not loaded loading copy from system32
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:920]: Machine policy value 'TransformsSecure' is 0
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:920]: User policy value 'TransformsAtSource' is 0
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:920]: Machine policy value 'DisablePatch' is 0
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:920]: Machine policy value 'AllowLockdownPatch' is 0
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:920]: Machine policy value 'DisableLUAPatching' is 0
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:921]: Machine policy value 'DisableFlyWeightPatching' is 0
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:921]: Enabling baseline caching for this transaction since all active patches are MSI 3.0 style MSPs or at least one MSI 3.0 minor update patch is active
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:921]: APPCOMPAT: looking for appcompat database entry with ProductCode '{E36578FC-39EC-423E-BCE1-82D5E9C04BBC}'.
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:921]: APPCOMPAT: no matching ProductCode found in database.
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:921]: Transforms are not secure.
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:921]: PROPERTY CHANGE: Adding MsiLogFileLocation property. Its value is 'C:\Users\PCCA-PM\AppData\Local\Temp\MSIED31.tmp'.
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:921]: No Command Line.
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:921]: PROPERTY CHANGE: Adding PackageCode property. Its value is '{0400CFE6-8998-4683-9D11-5B2E6557D065}'.
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:921]: Product Code passed to Engine.Initialize:           '(none)'
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:921]: Product Code from property table before transforms: '{E36578FC-39EC-423E-BCE1-82D5E9C04BBC}'
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:921]: Product Code from property table after transforms:  '{E36578FC-39EC-423E-BCE1-82D5E9C04BBC}'
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:921]: Product not registered: beginning first-time install
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:921]: PROPERTY CHANGE: Adding ProductState property. Its value is '-1'.
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:921]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer 3: 2
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:921]: Entering CMsiConfigurationManager::SetLastUsedSource.
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:921]: User policy value 'SearchOrder' is 'nmu'
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:921]: Adding new sources is allowed.
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:922]: PROPERTY CHANGE: Adding PackagecodeChanging property. Its value is '1'.
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:922]: Package name extracted from package path: 'msvcrt_x86.msi'
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:922]: Package to be registered: 'msvcrt_x86.msi'
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:922]: Note: 1: 2262 2: AdminProperties 3: -2147287038
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:922]: Machine policy value 'DisableMsi' is 0
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:922]: Machine policy value 'AlwaysInstallElevated' is 0
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:922]: User policy value 'AlwaysInstallElevated' is 0
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:922]: Product installation will be elevated because user is admin and product is being installed per-machine.
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:922]: Running product '{E36578FC-39EC-423E-BCE1-82D5E9C04BBC}' with elevated privileges: Product is assigned.
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:922]: PROPERTY CHANGE: Adding MsiSystemRebootPending property. Its value is '1'.
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:922]: TRANSFORMS property is now:
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:922]: PROPERTY CHANGE: Adding VersionDatabase property. Its value is '200'.
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:923]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:923]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Favorites
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:923]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Network Shortcuts
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:923]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Documents
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:923]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:923]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Recent
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:923]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\SendTo
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:923]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Templates
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:923]: SHELL32::SHGetFolderPath returned: C:\ProgramData
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:923]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Local
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:923]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Pictures
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:923]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:923]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:923]: SHELL32::SHGetFolderPath returned: C:\Users\Public\Desktop
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:923]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:923]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:923]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Desktop
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:923]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Templates
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:923]: SHELL32::SHGetFolderPath returned: C:\Windows\Fonts
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:923]: Note: 1: 2898 2: MS Sans Serif 3: MS Sans Serif 4: 0 5: 16
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:928]: MSI_LUA: Setting AdminUser property to 1 because this is the client or the user has already permitted elevation
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:928]: MSI_LUA: Setting MsiRunningElevated property to 1 because the install is already running elevated.
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:928]: PROPERTY CHANGE: Adding MsiRunningElevated property. Its value is '1'.
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:928]: PROPERTY CHANGE: Adding Privileged property. Its value is '1'.
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:929]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\MS Setup (ACME)\User Info 3: 2
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:929]: PROPERTY CHANGE: Adding USERNAME property. Its value is 'A Valued IT Customer'.
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:929]: PROPERTY CHANGE: Adding COMPANYNAME property. Its value is 'Intel Corporation'.
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:929]: PROPERTY CHANGE: Adding DATABASE property. Its value is 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\msvcrt_x86.msi'.
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:929]: PROPERTY CHANGE: Adding OriginalDatabase property. Its value is 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\msvcrt_x86.msi'.
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:929]: Machine policy value 'MsiDisableEmbeddedUI' is 0
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:929]: EEUI - Disabling MsiEmbeddedUI in quiet mode
MSI(i) [13:54:55.965] | === Logging started: 4/8/2014  13:54:55 ===
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:929]: Note: 1: 2205 2:  3: PatchPackage
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:929]: Machine policy value 'DisableRollback' is 0
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:929]: User policy value 'DisableRollback' is 0
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:929]: PROPERTY CHANGE: Adding UILevel property. Its value is '2'.
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:929]: Creating MSIHANDLE (79) of type 790537 for thread 3996
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:929]: MsiOpenPackageEx is returning 0
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:929]: Creating MSIHANDLE (80) of type 790541 for thread 3996
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:929]: Closing MSIHANDLE (80) of type 790541 for thread 3996
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:930]: Doing action: AppSearch
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:930]: Note: 1: 2205 2:  3: ActionText
MSI(i) [13:54:55.965] | Action 13:54:55: AppSearch. Searching for installed applications
MSI(i) [13:54:55.965] | Action start 13:54:55: AppSearch.
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:931]: Note: 1: 2205 2:  3: AppSearch
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:931]: Note: 1: 2228 2:  3: AppSearch 4: SELECT `Property`, `Signature_` FROM `AppSearch`
MSI(i) [13:54:55.965] | Action ended 13:54:55: AppSearch. Return value 0.
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:931]: Doing action: CostInitialize
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:931]: Note: 1: 2205 2:  3: ActionText
MSI(i) [13:54:55.965] | Action 13:54:55: CostInitialize. Computing space requirements
MSI(i) [13:54:55.965] | Action start 13:54:55: CostInitialize.
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:932]: Machine policy value 'MaxPatchCacheSize' is 10
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:932]: Baseline: Sorting baselines for {E36578FC-39EC-423E-BCE1-82D5E9C04BBC}.
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:932]: Baseline: New baseline 13.1.5000 from transaction.
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:932]: Baseline: Sorted order Native: Order 0.
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:932]: Baseline Data Table:
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:932]: ProductCode: {E36578FC-39EC-423E-BCE1-82D5E9C04BBC} Version: 13.1.5000 Attributes: 0 PatchId: Native BaselineId: -2147483648 Order: 0
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:932]: Baseline File Table:
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:933]: PROPERTY CHANGE: Adding ROOTDRIVE property. Its value is 'C:\'.
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:933]: PROPERTY CHANGE: Adding CostingComplete property. Its value is '0'.
MSI(i) [13:54:55.965] | Action ended 13:54:55: CostInitialize. Return value 1.
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:934]: Doing action: FileCost
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:934]: Note: 1: 2205 2:  3: ActionText
MSI(i) [13:54:55.965] | Action 13:54:55: FileCost. Computing space requirements
MSI(i) [13:54:55.965] | Action start 13:54:55: FileCost.
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:935]: Note: 1: 2205 2:  3: Class
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:935]: Note: 1: 2205 2:  3: Extension
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:935]: Note: 1: 2205 2:  3: TypeLib
MSI(i) [13:54:55.965] | Action ended 13:54:55: FileCost. Return value 1.
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:935]: Doing action: CostFinalize
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:935]: Note: 1: 2205 2:  3: ActionText
MSI(i) [13:54:55.965] | Action 13:54:55: CostFinalize. Computing space requirements
MSI(i) [13:54:55.965] | Action start 13:54:55: CostFinalize.
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:937]: PROPERTY CHANGE: Adding OutOfDiskSpace property. Its value is '0'.
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:937]: PROPERTY CHANGE: Adding OutOfNoRbDiskSpace property. Its value is '0'.
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:937]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceAvailable property. Its value is '0'.
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:937]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRequired property. Its value is '0'.
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:937]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRemaining property. Its value is '0'.
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:937]: Note: 1: 2205 2:  3: Patch
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:937]: Note: 1: 2205 2:  3: Condition
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:937]: PROPERTY CHANGE: Adding TARGETDIR property. Its value is 'C:\'.
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:937]: PROPERTY CHANGE: Adding INSTALLDIR property. Its value is 'C:\'.
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:937]: PROPERTY CHANGE: Adding WindowsFolder_x86_VC.DF495DFD_79F6_34DF_BB1E_E58DB5BDCF2C property. Its value is 'C:\Win\'.
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:937]: PROPERTY CHANGE: Adding SystemFolder_x86_VC.DF495DFD_79F6_34DF_BB1E_E58DB5BDCF2C property. Its value is 'C:\Win\System\'.
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:937]: PROPERTY CHANGE: Adding WindowsFolder.30729.6161.policy_9_0_Microsoft_VC90_CRT_x86.QFE.ED5CDF42_FC23_3F0F_80FC_C138299ADCC4 property. Its value is 'C:\Windows\'.
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:937]: PROPERTY CHANGE: Adding WinSxsDirectory.30729.6161.policy_9_0_Microsoft_VC90_CRT_x86.QFE.ED5CDF42_FC23_3F0F_80FC_C138299ADCC4 property. Its value is 'C:\Windows\winsxs\'.
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:937]: PROPERTY CHANGE: Adding WinSxsPolicies.30729.6161.policy_9_0_Microsoft_VC90_CRT_x86.QFE.ED5CDF42_FC23_3F0F_80FC_C138299ADCC4 property. Its value is 'C:\Windows\winsxs\Policies\'.
MSI(i) [13:54:55.965] | MSI (c) (B0:9C) [13:54:55:937]: PROPERTY CHANGE: Adding policydir.30729.6161.policy_9_0_Microsoft_VC90_CRT_x86.QFE.ED5CDF42_FC23_3F0F_80FC_C138299ADCC4 property. Its value is 'C:\Windows\winsxs\Policies\x86_policy.9.0.Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_x-ww_b7353f75\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:937]: PROPERTY CHANGE: Adding payload_ul.30729.6161.policy_9_0_Microsoft_VC90_CRT_x86.QFE.ED5CDF42_FC23_3F0F_80FC_C138299ADCC4 property. Its value is 'C:\Windows\winsxs\x86_policy.9.0.microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.6161_none_f480bfaef65491a5\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:937]: PROPERTY CHANGE: Adding WindowsFolder.30729.6161.Microsoft_VC90_CRT_x86.QFE.C8AE193F_7C6D_330A_93C7_EBBC23C30DBF property. Its value is 'C:\Windows\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:937]: PROPERTY CHANGE: Adding WinSxsDirectory.30729.6161.Microsoft_VC90_CRT_x86.QFE.C8AE193F_7C6D_330A_93C7_EBBC23C30DBF property. Its value is 'C:\Windows\winsxs\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:937]: PROPERTY CHANGE: Adding policydir_ul.30729.6161.Microsoft_VC90_CRT_x86.QFE.C8AE193F_7C6D_330A_93C7_EBBC23C30DBF property. Its value is 'C:\Windows\winsxs\x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_x-ww_1742743b\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:937]: PROPERTY CHANGE: Adding WinSxsPolicies.30729.6161.Microsoft_VC90_CRT_x86.QFE.C8AE193F_7C6D_330A_93C7_EBBC23C30DBF property. Its value is 'C:\Windows\winsxs\Policies\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:937]: PROPERTY CHANGE: Adding policydir.30729.6161.Microsoft_VC90_CRT_x86.QFE.C8AE193F_7C6D_330A_93C7_EBBC23C30DBF property. Its value is 'C:\Windows\winsxs\Policies\x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_x-ww_1742743b\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:937]: PROPERTY CHANGE: Adding WinSxsManifests.30729.6161.Microsoft_VC90_CRT_x86.QFE.C8AE193F_7C6D_330A_93C7_EBBC23C30DBF property. Its value is 'C:\Windows\winsxs\Manifests\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:937]: PROPERTY CHANGE: Adding payload.30729.6161.Microsoft_VC90_CRT_x86.QFE.C8AE193F_7C6D_330A_93C7_EBBC23C30DBF property. Its value is 'C:\Windows\winsxs\x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_9.0.30729.6161_x-ww_31a54e43\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:937]: PROPERTY CHANGE: Adding payload_ul.30729.6161.Microsoft_VC90_CRT_x86.QFE.C8AE193F_7C6D_330A_93C7_EBBC23C30DBF property. Its value is 'C:\Windows\winsxs\x86_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.6161_none_50934f2ebcb7eb57\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:938]: WIN64DUALFOLDERS: 'C:\Windows\SysWOW64\' will substitute 20 characters in 'C:\Windows\system32\' folder path. (mask argument = 0, the folder pair's iSwapAttrib member = 1).
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:938]: PROPERTY CHANGE: Adding SystemFolder.30729.6161.Microsoft_VC90_CRT_x86.QFE.C8AE193F_7C6D_330A_93C7_EBBC23C30DBF property. Its value is 'C:\Windows\SysWOW64\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:938]: PROPERTY CHANGE: Adding WindowsFolder.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:938]: PROPERTY CHANGE: Adding SystemFolder.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\SysWOW64\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:938]: PROPERTY CHANGE: Adding WinSxsDirectory.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:938]: PROPERTY CHANGE: Adding payload.8.0.50727.4053.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4053_x-ww_2a9a3690\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:938]: PROPERTY CHANGE: Adding payload.8.0.50727.4052.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4052_x-ww_2a9a368f\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:938]: PROPERTY CHANGE: Adding payload.8.0.50727.4045.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4045_x-ww_2a993653\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:938]: PROPERTY CHANGE: Adding payload.8.0.50727.4029.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4029_x-ww_2a9735d9\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:938]: PROPERTY CHANGE: Adding payload.8.0.50727.4028.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4028_x-ww_2a9735d8\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:938]: PROPERTY CHANGE: Adding payload.8.0.50727.4027.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4027_x-ww_2a9735d7\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:938]: PROPERTY CHANGE: Adding payload.8.0.50727.1833.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.1833_x-ww_a2f43fdd\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:938]: PROPERTY CHANGE: Adding payload.8.0.50727.3069.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.3069_x-ww_fc146616\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:938]: PROPERTY CHANGE: Adding payload.8.0.50727.3051.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.3051_x-ww_fc1365cf\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:938]: PROPERTY CHANGE: Adding payload.8.0.50727.3044.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.3044_x-ww_fc126593\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:938]: PROPERTY CHANGE: Adding payload.8.0.50727.238.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.238_x-ww_ac9cf5cb\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:938]: PROPERTY CHANGE: Adding payload.8.0.50727.193.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.193_x-ww_ac24e7bf\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:938]: PROPERTY CHANGE: Adding payload.8.0.50727.104.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.104_x-ww_ac1be589\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:938]: PROPERTY CHANGE: Adding payload.8.0.50727.103.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.103_x-ww_ac1be588\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:938]: PROPERTY CHANGE: Adding payload.8.0.50727.101.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.101_x-ww_ac1be586\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:938]: PROPERTY CHANGE: Adding payload.8.0.50727.100.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.100_x-ww_ac1be585\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:938]: PROPERTY CHANGE: Adding payload.8.0.50727.99.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.99_x-ww_51e92916\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:938]: PROPERTY CHANGE: Adding payload.8.0.50727.98.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.98_x-ww_51e92915\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:938]: PROPERTY CHANGE: Adding payload.8.0.50727.97.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.97_x-ww_51e92914\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:938]: PROPERTY CHANGE: Adding payload.8.0.50727.96.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.96_x-ww_51e92913\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:938]: PROPERTY CHANGE: Adding payload.8.0.50727.95.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.95_x-ww_51e92912\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:938]: PROPERTY CHANGE: Adding payload.8.0.50727.93.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.93_x-ww_51e92910\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:938]: PROPERTY CHANGE: Adding payload.8.0.50727.89.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.89_x-ww_51e828d7\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:938]: PROPERTY CHANGE: Adding payload.8.0.50727.94.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.94_x-ww_51e92911\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:938]: PROPERTY CHANGE: Adding policydir_ul.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4053_x-ww_2a9a3690\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:938]: PROPERTY CHANGE: Adding payload.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.42_x-ww_51e427d4\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:938]: PROPERTY CHANGE: Adding WinSxsManifests.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Manifests\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:938]: PROPERTY CHANGE: Adding WinSxsPolicies.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:938]: PROPERTY CHANGE: Adding policydir.8.0.50727.4053.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:938]: PROPERTY CHANGE: Adding policydir.8.0.50727.3069.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:938]: PROPERTY CHANGE: Adding policydir.8.0.50727.4027.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:938]: PROPERTY CHANGE: Adding policydir.8.0.50727.4045.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:938]: PROPERTY CHANGE: Adding policydir.8.0.50727.4029.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:938]: PROPERTY CHANGE: Adding policydir.8.0.50727.3051.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:938]: PROPERTY CHANGE: Adding policydir.8.0.50727.1833.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:938]: PROPERTY CHANGE: Adding policydir.8.0.50727.4052.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:938]: PROPERTY CHANGE: Adding policydir.8.0.50727.238.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:938]: PROPERTY CHANGE: Adding policydir.8.0.50727.3044.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:938]: PROPERTY CHANGE: Adding policydir.8.0.50727.4028.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:938]: PROPERTY CHANGE: Adding policydir.8.0.50727.97.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:938]: PROPERTY CHANGE: Adding policydir.8.0.50727.101.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:938]: PROPERTY CHANGE: Adding policydir.8.0.50727.99.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:938]: PROPERTY CHANGE: Adding policydir.8.0.50727.104.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:938]: PROPERTY CHANGE: Adding policydir.8.0.50727.98.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:938]: PROPERTY CHANGE: Adding policydir.8.0.50727.193.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:938]: PROPERTY CHANGE: Adding policydir.8.0.50727.93.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:938]: PROPERTY CHANGE: Adding policydir.8.0.50727.100.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:938]: PROPERTY CHANGE: Adding policydir.8.0.50727.95.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:938]: PROPERTY CHANGE: Adding policydir.8.0.50727.89.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:938]: PROPERTY CHANGE: Adding policydir.8.0.50727.94.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:938]: PROPERTY CHANGE: Adding policydir.8.0.50727.96.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:938]: PROPERTY CHANGE: Adding policydir.8.0.50727.103.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:938]: PROPERTY CHANGE: Adding policydir.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:938]: PROPERTY CHANGE: Adding payload_ul.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\x86_policy.8.0.microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.4053_none_516e2e610f48bda6\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:938]: PROPERTY CHANGE: Adding WindowsFolder.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:938]: PROPERTY CHANGE: Adding SystemFolder.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\SysWOW64\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:939]: PROPERTY CHANGE: Adding WinSxsDirectory.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:939]: PROPERTY CHANGE: Adding payload.8.0.50727.4053.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4053_x-ww_e6967989\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:939]: PROPERTY CHANGE: Adding payload.8.0.50727.4052.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4052_x-ww_e6967988\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:939]: PROPERTY CHANGE: Adding payload.8.0.50727.4045.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4045_x-ww_e695794c\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:939]: PROPERTY CHANGE: Adding payload.8.0.50727.4029.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4029_x-ww_e69378d2\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:939]: PROPERTY CHANGE: Adding payload.8.0.50727.4028.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4028_x-ww_e69378d1\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:939]: PROPERTY CHANGE: Adding payload.8.0.50727.4027.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4027_x-ww_e69378d0\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:939]: PROPERTY CHANGE: Adding payload.8.0.50727.1833.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.1833_x-ww_5ef082d6\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:939]: PROPERTY CHANGE: Adding payload.8.0.50727.3069.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.3069_x-ww_b810a90f\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:939]: PROPERTY CHANGE: Adding payload.8.0.50727.3051.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.3051_x-ww_b80fa8c8\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:939]: PROPERTY CHANGE: Adding payload.8.0.50727.3044.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.3044_x-ww_b80ea88c\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:939]: PROPERTY CHANGE: Adding payload.8.0.50727.238.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.238_x-ww_689938c4\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:939]: PROPERTY CHANGE: Adding payload.8.0.50727.193.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.193_x-ww_68212ab8\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:939]: PROPERTY CHANGE: Adding payload.8.0.50727.104.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.104_x-ww_68182882\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:939]: PROPERTY CHANGE: Adding payload.8.0.50727.103.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.103_x-ww_68182881\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:939]: PROPERTY CHANGE: Adding payload.8.0.50727.101.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.101_x-ww_6818287f\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:939]: PROPERTY CHANGE: Adding payload.8.0.50727.100.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.100_x-ww_6818287e\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:939]: PROPERTY CHANGE: Adding payload.8.0.50727.99.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.99_x-ww_0de56c0f\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:939]: PROPERTY CHANGE: Adding payload.8.0.50727.98.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.98_x-ww_0de56c0e\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:939]: PROPERTY CHANGE: Adding payload.8.0.50727.97.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.97_x-ww_0de56c0d\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:939]: PROPERTY CHANGE: Adding payload.8.0.50727.96.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.96_x-ww_0de56c0c\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:939]: PROPERTY CHANGE: Adding payload.8.0.50727.95.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.95_x-ww_0de56c0b\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:939]: PROPERTY CHANGE: Adding payload.8.0.50727.93.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.93_x-ww_0de56c09\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:939]: PROPERTY CHANGE: Adding payload.8.0.50727.94.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.94_x-ww_0de56c0a\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:939]: PROPERTY CHANGE: Adding payload.8.0.50727.89.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.89_x-ww_0de46bd0\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:939]: PROPERTY CHANGE: Adding policydir_ul.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4053_x-ww_e6967989\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:939]: PROPERTY CHANGE: Adding WinSxsPolicies.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:939]: PROPERTY CHANGE: Adding policydir.8.0.50727.4052.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:939]: PROPERTY CHANGE: Adding policydir.8.0.50727.4045.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:939]: PROPERTY CHANGE: Adding policydir.8.0.50727.4053.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:939]: PROPERTY CHANGE: Adding policydir.8.0.50727.1833.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:939]: PROPERTY CHANGE: Adding policydir.8.0.50727.4028.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:939]: PROPERTY CHANGE: Adding policydir.8.0.50727.238.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:939]: PROPERTY CHANGE: Adding policydir.8.0.50727.3051.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:939]: PROPERTY CHANGE: Adding policydir.8.0.50727.3069.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:939]: PROPERTY CHANGE: Adding policydir.8.0.50727.104.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:939]: PROPERTY CHANGE: Adding policydir.8.0.50727.101.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:939]: PROPERTY CHANGE: Adding policydir.8.0.50727.193.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:939]: PROPERTY CHANGE: Adding policydir.8.0.50727.3044.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:939]: PROPERTY CHANGE: Adding policydir.8.0.50727.99.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:939]: PROPERTY CHANGE: Adding policydir.8.0.50727.98.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:939]: PROPERTY CHANGE: Adding policydir.8.0.50727.4027.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:939]: PROPERTY CHANGE: Adding policydir.8.0.50727.97.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:939]: PROPERTY CHANGE: Adding policydir.8.0.50727.103.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:939]: PROPERTY CHANGE: Adding policydir.8.0.50727.95.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:939]: PROPERTY CHANGE: Adding policydir.8.0.50727.96.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:939]: PROPERTY CHANGE: Adding policydir.8.0.50727.93.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:939]: PROPERTY CHANGE: Adding policydir.8.0.50727.100.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:939]: PROPERTY CHANGE: Adding policydir.8.0.50727.4029.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:939]: PROPERTY CHANGE: Adding policydir.8.0.50727.94.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:939]: PROPERTY CHANGE: Adding policydir.8.0.50727.89.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:939]: PROPERTY CHANGE: Adding policydir.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:939]: PROPERTY CHANGE: Adding WinSxsManifests.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Manifests\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:939]: PROPERTY CHANGE: Adding payload.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.42_x-ww_0de06acd\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:939]: PROPERTY CHANGE: Adding payload_ul.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\x86_microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.4053_none_d08d7da0442a985d\'.
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:939]: Target path resolution complete. Dumping Directory table...
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:939]: Note: target paths subject to change (via custom actions or browsing)
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:939]: Dir (target): Key: TARGETDIR    , Object: C:\
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:939]: Dir (target): Key: WindowsFolder    , Object: C:\Windows\
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:939]: Dir (target): Key: INSTALLDIR    , Object: C:\
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:939]: Dir (target): Key: WindowsFolder_x86_VC.DF495DFD_79F6_34DF_BB1E_E58DB5BDCF2C    , Object: C:\Win\
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:939]: Dir (target): Key: SystemFolder_x86_VC.DF495DFD_79F6_34DF_BB1E_E58DB5BDCF2C    , Object: C:\Win\System\
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:939]: Dir (target): Key: WindowsFolder.30729.6161.policy_9_0_Microsoft_VC90_CRT_x86.QFE.ED5CDF42_FC23_3F0F_80FC_C138299ADCC4    , Object: C:\Windows\
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:939]: Dir (target): Key: WinSxsDirectory.30729.6161.policy_9_0_Microsoft_VC90_CRT_x86.QFE.ED5CDF42_FC23_3F0F_80FC_C138299ADCC4    , Object: C:\Windows\winsxs\
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:939]: Dir (target): Key: WinSxsPolicies.30729.6161.policy_9_0_Microsoft_VC90_CRT_x86.QFE.ED5CDF42_FC23_3F0F_80FC_C138299ADCC4    , Object: C:\Windows\winsxs\Policies\
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:939]: Dir (target): Key: policydir.30729.6161.policy_9_0_Microsoft_VC90_CRT_x86.QFE.ED5CDF42_FC23_3F0F_80FC_C138299ADCC4    , Object: C:\Windows\winsxs\Policies\x86_policy.9.0.Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_x-ww_b7353f75\
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:939]: Dir (target): Key: payload_ul.30729.6161.policy_9_0_Microsoft_VC90_CRT_x86.QFE.ED5CDF42_FC23_3F0F_80FC_C138299ADCC4    , Object: C:\Windows\winsxs\x86_policy.9.0.microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.6161_none_f480bfaef65491a5\
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:939]: Dir (target): Key: WindowsFolder.30729.6161.Microsoft_VC90_CRT_x86.QFE.C8AE193F_7C6D_330A_93C7_EBBC23C30DBF    , Object: C:\Windows\
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:939]: Dir (target): Key: WinSxsDirectory.30729.6161.Microsoft_VC90_CRT_x86.QFE.C8AE193F_7C6D_330A_93C7_EBBC23C30DBF    , Object: C:\Windows\winsxs\
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:939]: Dir (target): Key: policydir_ul.30729.6161.Microsoft_VC90_CRT_x86.QFE.C8AE193F_7C6D_330A_93C7_EBBC23C30DBF    , Object: C:\Windows\winsxs\x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_x-ww_1742743b\
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:939]: Dir (target): Key: WinSxsPolicies.30729.6161.Microsoft_VC90_CRT_x86.QFE.C8AE193F_7C6D_330A_93C7_EBBC23C30DBF    , Object: C:\Windows\winsxs\Policies\
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:939]: Dir (target): Key: policydir.30729.6161.Microsoft_VC90_CRT_x86.QFE.C8AE193F_7C6D_330A_93C7_EBBC23C30DBF    , Object: C:\Windows\winsxs\Policies\x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_x-ww_1742743b\
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:939]: Dir (target): Key: WinSxsManifests.30729.6161.Microsoft_VC90_CRT_x86.QFE.C8AE193F_7C6D_330A_93C7_EBBC23C30DBF    , Object: C:\Windows\winsxs\Manifests\
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:939]: Dir (target): Key: payload.30729.6161.Microsoft_VC90_CRT_x86.QFE.C8AE193F_7C6D_330A_93C7_EBBC23C30DBF    , Object: C:\Windows\winsxs\x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_9.0.30729.6161_x-ww_31a54e43\
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:939]: Dir (target): Key: payload_ul.30729.6161.Microsoft_VC90_CRT_x86.QFE.C8AE193F_7C6D_330A_93C7_EBBC23C30DBF    , Object: C:\Windows\winsxs\x86_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.6161_none_50934f2ebcb7eb57\
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:939]: Dir (target): Key: SystemFolder.30729.6161.Microsoft_VC90_CRT_x86.QFE.C8AE193F_7C6D_330A_93C7_EBBC23C30DBF    , Object: C:\Windows\SysWOW64\
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:939]: Dir (target): Key: WindowsFolder.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E    , Object: C:\Windows\
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:939]: Dir (target): Key: SystemFolder.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E    , Object: C:\Windows\SysWOW64\
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:939]: Dir (target): Key: WinSxsDirectory.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:939]: Dir (target): Key: payload.8.0.50727.4053.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4053_x-ww_2a9a3690\
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:939]: Dir (target): Key: payload.8.0.50727.4052.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4052_x-ww_2a9a368f\
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:939]: Dir (target): Key: payload.8.0.50727.4045.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4045_x-ww_2a993653\
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:939]: Dir (target): Key: payload.8.0.50727.4029.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4029_x-ww_2a9735d9\
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: payload.8.0.50727.4028.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4028_x-ww_2a9735d8\
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: payload.8.0.50727.4027.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4027_x-ww_2a9735d7\
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: payload.8.0.50727.1833.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.1833_x-ww_a2f43fdd\
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: payload.8.0.50727.3069.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.3069_x-ww_fc146616\
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: payload.8.0.50727.3051.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.3051_x-ww_fc1365cf\
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: payload.8.0.50727.3044.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.3044_x-ww_fc126593\
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: payload.8.0.50727.238.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.238_x-ww_ac9cf5cb\
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: payload.8.0.50727.193.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.193_x-ww_ac24e7bf\
MSI(i) [13:54:55.966] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: payload.8.0.50727.104.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.104_x-ww_ac1be589\
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: payload.8.0.50727.103.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.103_x-ww_ac1be588\
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: payload.8.0.50727.101.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.101_x-ww_ac1be586\
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: payload.8.0.50727.100.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.100_x-ww_ac1be585\
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: payload.8.0.50727.99.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.99_x-ww_51e92916\
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: payload.8.0.50727.98.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.98_x-ww_51e92915\
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: payload.8.0.50727.97.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.97_x-ww_51e92914\
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: payload.8.0.50727.96.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.96_x-ww_51e92913\
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: payload.8.0.50727.95.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.95_x-ww_51e92912\
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: payload.8.0.50727.93.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.93_x-ww_51e92910\
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: payload.8.0.50727.89.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.89_x-ww_51e828d7\
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: payload.8.0.50727.94.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.94_x-ww_51e92911\
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: policydir_ul.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4053_x-ww_2a9a3690\
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: payload.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.42_x-ww_51e427d4\
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: WinSxsManifests.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Manifests\
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: WinSxsPolicies.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: policydir.8.0.50727.4053.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: policydir.8.0.50727.3069.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: policydir.8.0.50727.4027.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: policydir.8.0.50727.4045.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: policydir.8.0.50727.4029.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: policydir.8.0.50727.3051.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: policydir.8.0.50727.1833.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: policydir.8.0.50727.4052.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: policydir.8.0.50727.238.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: policydir.8.0.50727.3044.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: policydir.8.0.50727.4028.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: policydir.8.0.50727.97.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: policydir.8.0.50727.101.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: policydir.8.0.50727.99.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: policydir.8.0.50727.104.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: policydir.8.0.50727.98.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: policydir.8.0.50727.193.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: policydir.8.0.50727.93.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: policydir.8.0.50727.100.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: policydir.8.0.50727.95.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: policydir.8.0.50727.89.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: policydir.8.0.50727.94.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: policydir.8.0.50727.96.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: policydir.8.0.50727.103.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: policydir.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: payload_ul.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\x86_policy.8.0.microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.4053_none_516e2e610f48bda6\
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: WindowsFolder.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E    , Object: C:\Windows\
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: SystemFolder.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E    , Object: C:\Windows\SysWOW64\
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: WinSxsDirectory.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: payload.8.0.50727.4053.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4053_x-ww_e6967989\
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: payload.8.0.50727.4052.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4052_x-ww_e6967988\
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: payload.8.0.50727.4045.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4045_x-ww_e695794c\
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: payload.8.0.50727.4029.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4029_x-ww_e69378d2\
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: payload.8.0.50727.4028.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4028_x-ww_e69378d1\
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: payload.8.0.50727.4027.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4027_x-ww_e69378d0\
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: payload.8.0.50727.1833.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.1833_x-ww_5ef082d6\
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: payload.8.0.50727.3069.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.3069_x-ww_b810a90f\
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: payload.8.0.50727.3051.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.3051_x-ww_b80fa8c8\
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: payload.8.0.50727.3044.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.3044_x-ww_b80ea88c\
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: payload.8.0.50727.238.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.238_x-ww_689938c4\
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: payload.8.0.50727.193.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.193_x-ww_68212ab8\
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: payload.8.0.50727.104.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.104_x-ww_68182882\
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: payload.8.0.50727.103.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.103_x-ww_68182881\
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: payload.8.0.50727.101.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.101_x-ww_6818287f\
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: payload.8.0.50727.100.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.100_x-ww_6818287e\
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: payload.8.0.50727.99.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.99_x-ww_0de56c0f\
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: payload.8.0.50727.98.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.98_x-ww_0de56c0e\
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: payload.8.0.50727.97.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.97_x-ww_0de56c0d\
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: payload.8.0.50727.96.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.96_x-ww_0de56c0c\
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: payload.8.0.50727.95.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.95_x-ww_0de56c0b\
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: payload.8.0.50727.93.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.93_x-ww_0de56c09\
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: payload.8.0.50727.94.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.94_x-ww_0de56c0a\
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: payload.8.0.50727.89.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.89_x-ww_0de46bd0\
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: policydir_ul.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4053_x-ww_e6967989\
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: WinSxsPolicies.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: policydir.8.0.50727.4052.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: policydir.8.0.50727.4045.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: policydir.8.0.50727.4053.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: policydir.8.0.50727.1833.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: policydir.8.0.50727.4028.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: policydir.8.0.50727.238.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: policydir.8.0.50727.3051.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: policydir.8.0.50727.3069.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: policydir.8.0.50727.104.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: policydir.8.0.50727.101.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: policydir.8.0.50727.193.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: policydir.8.0.50727.3044.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: policydir.8.0.50727.99.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: policydir.8.0.50727.98.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: policydir.8.0.50727.4027.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: policydir.8.0.50727.97.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: policydir.8.0.50727.103.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: policydir.8.0.50727.95.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: policydir.8.0.50727.96.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: policydir.8.0.50727.93.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: policydir.8.0.50727.100.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: policydir.8.0.50727.4029.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: policydir.8.0.50727.94.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: policydir.8.0.50727.89.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: policydir.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: WinSxsManifests.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Manifests\
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: payload.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.42_x-ww_0de06acd\
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:940]: Dir (target): Key: payload_ul.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\x86_microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.4053_none_d08d7da0442a985d\
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:940]: PROPERTY CHANGE: Adding INSTALLLEVEL property. Its value is '1'.
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:942]: skipping installation of assembly component: {B4606FC1-ADD6-3F4C-B9A7-BEA4CE07951E} since the assembly already exists
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:942]: skipping installation of assembly component: {4C3A7A77-BFE9-309A-B576-33618A5B1A67} since the assembly already exists
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:943]: skipping installation of assembly component: {63E949F6-03BC-5C40-A01F-C8B3B9A1E18E} since the assembly already exists
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:944]: skipping installation of assembly component: {98CB24AD-52FB-DB5F-A01F-C8B3B9A1E18E} since the assembly already exists
MSI(i) [13:54:55.967] | Action ended 13:54:55: CostFinalize. Return value 1.
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:944]: Doing action: InstallValidate
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:944]: Note: 1: 2205 2:  3: ActionText
MSI(i) [13:54:55.967] | Action 13:54:55: InstallValidate. Validating install
MSI(i) [13:54:55.967] | Action start 13:54:55: InstallValidate.
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:945]: Feature: Core; Installed: Absent;   Request: Local;   Action: Local
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:945]: Feature: MS_Runtime_8_0; Installed: Absent;   Request: Local;   Action: Local
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:945]: Feature: MS_Runtime_9_0; Installed: Absent;   Request: Local;   Action: Local
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:945]: Feature: MS_Runtime_10_0; Installed: Absent;   Request: Local;   Action: Local
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:945]: Component: ProductFamilyAnchor; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:945]: Component: ProductVersionAnchor; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:945]: Component: RuntimeAnchor; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:945]: Component: downlevel_payload.8.0.50727.4053.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:945]: Component: uplevel.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:945]: Component: downlevel_manifest.8.0.50727.4053.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:945]: Component: nosxs.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:945]: Component: downlevel_payload.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:945]: Component: downlevel_manifest.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:945]: Component: downlevel_manifest.8.0.50727.89.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:945]: Component: downlevel_payload.8.0.50727.89.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:945]: Component: downlevel_manifest.8.0.50727.94.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:945]: Component: downlevel_manifest.8.0.50727.93.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:945]: Component: downlevel_manifest.8.0.50727.95.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:945]: Component: downlevel_payload.8.0.50727.93.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:945]: Component: downlevel_payload.8.0.50727.94.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:945]: Component: downlevel_manifest.8.0.50727.96.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:945]: Component: downlevel_payload.8.0.50727.95.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:945]: Component: downlevel_manifest.8.0.50727.97.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:945]: Component: downlevel_manifest.8.0.50727.98.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:945]: Component: downlevel_payload.8.0.50727.96.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:945]: Component: downlevel_manifest.8.0.50727.100.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:945]: Component: downlevel_payload.8.0.50727.97.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:945]: Component: downlevel_manifest.8.0.50727.99.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:945]: Component: downlevel_payload.8.0.50727.98.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:945]: Component: downlevel_payload.8.0.50727.99.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:945]: Component: downlevel_manifest.8.0.50727.101.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:945]: Component: downlevel_manifest.8.0.50727.103.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:945]: Component: downlevel_payload.8.0.50727.100.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:945]: Component: downlevel_payload.8.0.50727.101.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:945]: Component: downlevel_manifest.8.0.50727.104.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:945]: Component: downlevel_manifest.8.0.50727.193.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:945]: Component: downlevel_payload.8.0.50727.103.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:945]: Component: downlevel_payload.8.0.50727.104.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:945]: Component: downlevel_payload.8.0.50727.193.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:945]: Component: downlevel_manifest.8.0.50727.238.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:945]: Component: downlevel_payload.8.0.50727.238.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:945]: Component: downlevel_manifest.8.0.50727.3044.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:945]: Component: downlevel_manifest.8.0.50727.3051.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:945]: Component: downlevel_manifest.8.0.50727.3069.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:945]: Component: downlevel_payload.8.0.50727.3044.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:945]: Component: downlevel_payload.8.0.50727.3051.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:945]: Component: downlevel_manifest.8.0.50727.1833.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:945]: Component: downlevel_manifest.8.0.50727.4027.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:945]: Component: downlevel_payload.8.0.50727.3069.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:945]: Component: downlevel_payload.8.0.50727.1833.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:945]: Component: downlevel_manifest.8.0.50727.4028.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:945]: Component: downlevel_manifest.8.0.50727.4029.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:946]: Component: downlevel_payload.8.0.50727.4027.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:946]: Component: downlevel_manifest.8.0.50727.4045.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:946]: Component: downlevel_payload.8.0.50727.4028.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:946]: Component: downlevel_payload.8.0.50727.4029.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:946]: Component: downlevel_manifest.8.0.50727.4052.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:946]: Component: downlevel_payload.8.0.50727.4045.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:946]: Component: downlevel_payload.8.0.50727.4052.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:946]: Component: uplevel.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:946]: Component: downlevel_manifest.8.0.50727.4053.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:946]: Component: downlevel_manifest.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:946]: Component: downlevel_manifest.8.0.50727.89.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:946]: Component: downlevel_manifest.8.0.50727.93.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:946]: Component: downlevel_manifest.8.0.50727.94.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:946]: Component: downlevel_manifest.8.0.50727.95.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:946]: Component: downlevel_manifest.8.0.50727.96.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:946]: Component: downlevel_manifest.8.0.50727.97.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:946]: Component: downlevel_manifest.8.0.50727.98.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:946]: Component: downlevel_manifest.8.0.50727.99.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:946]: Component: downlevel_manifest.8.0.50727.100.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:946]: Component: downlevel_manifest.8.0.50727.101.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:946]: Component: downlevel_manifest.8.0.50727.103.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:946]: Component: downlevel_manifest.8.0.50727.104.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:946]: Component: downlevel_manifest.8.0.50727.238.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:946]: Component: downlevel_manifest.8.0.50727.193.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.967] | MSI (c) (B0:9C) [13:54:55:946]: Component: downlevel_manifest.8.0.50727.3044.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:946]: Component: downlevel_manifest.8.0.50727.3051.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:946]: Component: downlevel_manifest.8.0.50727.3069.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:946]: Component: downlevel_manifest.8.0.50727.1833.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:946]: Component: downlevel_manifest.8.0.50727.4027.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:946]: Component: downlevel_manifest.8.0.50727.4028.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:946]: Component: downlevel_manifest.8.0.50727.4029.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:946]: Component: downlevel_manifest.8.0.50727.4045.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:946]: Component: downlevel_manifest.8.0.50727.4052.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:946]: Component: uplevel.30729.6161.Microsoft_VC90_CRT_x86.QFE.C8AE193F_7C6D_330A_93C7_EBBC23C30DBF; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:946]: Component: nosxs.30729.6161.Microsoft_VC90_CRT_x86.QFE.C8AE193F_7C6D_330A_93C7_EBBC23C30DBF; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:946]: Component: downlevel_payload.30729.6161.Microsoft_VC90_CRT_x86.QFE.C8AE193F_7C6D_330A_93C7_EBBC23C30DBF; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:946]: Component: downlevel_manifest.30729.6161.Microsoft_VC90_CRT_x86.QFE.C8AE193F_7C6D_330A_93C7_EBBC23C30DBF; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:946]: Component: uplevel.30729.6161.policy_9_0_Microsoft_VC90_CRT_x86.QFE.ED5CDF42_FC23_3F0F_80FC_C138299ADCC4; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:946]: Component: downlevel_manifest.30729.6161.policy_9_0_Microsoft_VC90_CRT_x86.QFE.ED5CDF42_FC23_3F0F_80FC_C138299ADCC4; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:946]: Component: C_CENTRAL_msvcr100_x86.DF495DFD_79F6_34DF_BB1E_E58DB5BDCF2C; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:946]: Component: C_CENTRAL_msvcp100_x86.DF495DFD_79F6_34DF_BB1E_E58DB5BDCF2C; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:946]: Component: __uplevel.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:946]: Component: __uplevel.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:946]: Component: __uplevel.30729.6161.Microsoft_VC90_CRT_x86.QFE.C8AE193F_7C6D_330A_93C7_EBBC23C30DBF65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:946]: Component: __uplevel.30729.6161.policy_9_0_Microsoft_VC90_CRT_x86.QFE.ED5CDF42_FC23_3F0F_80FC_C138299ADCC465; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:946]: Component: __downlevel_payload.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:946]: Component: __nosxs.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:946]: Component: __downlevel_manifest.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:946]: Component: __downlevel_manifest.8.0.50727.89.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:946]: Component: __downlevel_payload.8.0.50727.89.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:946]: Component: __downlevel_manifest.8.0.50727.94.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:946]: Component: __downlevel_manifest.8.0.50727.93.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:946]: Component: __downlevel_payload.8.0.50727.93.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:946]: Component: __downlevel_payload.8.0.50727.94.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:946]: Component: __downlevel_manifest.8.0.50727.95.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:946]: Component: __downlevel_manifest.8.0.50727.96.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:946]: Component: __downlevel_payload.8.0.50727.95.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:946]: Component: __downlevel_manifest.8.0.50727.97.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:946]: Component: __downlevel_payload.8.0.50727.96.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:946]: Component: __downlevel_manifest.8.0.50727.98.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:946]: Component: __downlevel_payload.8.0.50727.97.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:946]: Component: __downlevel_manifest.8.0.50727.99.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:946]: Component: __downlevel_payload.8.0.50727.98.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:946]: Component: __downlevel_manifest.8.0.50727.100.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:946]: Component: __downlevel_payload.8.0.50727.99.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:946]: Component: __downlevel_manifest.8.0.50727.101.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:946]: Component: __downlevel_payload.8.0.50727.100.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:946]: Component: __downlevel_manifest.8.0.50727.103.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:946]: Component: __downlevel_payload.8.0.50727.101.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:946]: Component: __downlevel_manifest.8.0.50727.104.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:946]: Component: __downlevel_payload.8.0.50727.103.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:946]: Component: __downlevel_manifest.8.0.50727.193.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:946]: Component: __downlevel_payload.8.0.50727.104.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:946]: Component: __downlevel_payload.8.0.50727.193.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:946]: Component: __downlevel_manifest.8.0.50727.238.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:946]: Component: __downlevel_manifest.8.0.50727.3044.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:946]: Component: __downlevel_payload.8.0.50727.238.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:946]: Component: __downlevel_manifest.8.0.50727.3051.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:946]: Component: __downlevel_payload.8.0.50727.3044.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:946]: Component: __downlevel_manifest.8.0.50727.3069.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:946]: Component: __downlevel_payload.8.0.50727.3051.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:946]: Component: __downlevel_manifest.8.0.50727.1833.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:946]: Component: __downlevel_payload.8.0.50727.3069.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:946]: Component: __downlevel_manifest.8.0.50727.4027.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:946]: Component: __downlevel_payload.8.0.50727.1833.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:946]: Component: __downlevel_manifest.8.0.50727.4028.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:946]: Component: __downlevel_payload.8.0.50727.4027.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:946]: Component: __downlevel_manifest.8.0.50727.4029.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:946]: Component: __downlevel_payload.8.0.50727.4028.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:946]: Component: __downlevel_manifest.8.0.50727.4045.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:946]: Component: __downlevel_payload.8.0.50727.4029.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:946]: Component: __downlevel_manifest.8.0.50727.4052.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:946]: Component: __downlevel_payload.8.0.50727.4045.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:946]: Component: __downlevel_manifest.8.0.50727.4053.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:946]: Component: __downlevel_payload.8.0.50727.4052.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:946]: Component: __downlevel_payload.8.0.50727.4053.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:946]: Component: __downlevel_manifest.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:946]: Component: __downlevel_manifest.8.0.50727.89.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:946]: Component: __downlevel_manifest.8.0.50727.94.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:946]: Component: __downlevel_manifest.8.0.50727.93.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:946]: Component: __downlevel_manifest.8.0.50727.95.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:946]: Component: __downlevel_manifest.8.0.50727.96.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:946]: Component: __downlevel_manifest.8.0.50727.97.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:946]: Component: __downlevel_manifest.8.0.50727.98.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:946]: Component: __downlevel_manifest.8.0.50727.99.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:946]: Component: __downlevel_manifest.8.0.50727.100.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:946]: Component: __downlevel_manifest.8.0.50727.101.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:946]: Component: __downlevel_manifest.8.0.50727.103.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:946]: Component: __downlevel_manifest.8.0.50727.238.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:946]: Component: __downlevel_manifest.8.0.50727.104.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:946]: Component: __downlevel_manifest.8.0.50727.193.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:946]: Component: __downlevel_manifest.8.0.50727.3044.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:947]: Component: __downlevel_manifest.8.0.50727.3051.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:947]: Component: __downlevel_manifest.8.0.50727.3069.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:947]: Component: __downlevel_manifest.8.0.50727.1833.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:947]: Component: __downlevel_manifest.8.0.50727.4027.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:947]: Component: __downlevel_manifest.8.0.50727.4028.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:947]: Component: __downlevel_manifest.8.0.50727.4029.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:947]: Component: __downlevel_manifest.8.0.50727.4045.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:947]: Component: __downlevel_manifest.8.0.50727.4052.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:947]: Component: __downlevel_manifest.8.0.50727.4053.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:947]: Component: __nosxs.30729.6161.Microsoft_VC90_CRT_x86.QFE.C8AE193F_7C6D_330A_93C7_EBBC23C30DBF65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:947]: Component: __downlevel_payload.30729.6161.Microsoft_VC90_CRT_x86.QFE.C8AE193F_7C6D_330A_93C7_EBBC23C30DBF65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:947]: Component: __downlevel_manifest.30729.6161.Microsoft_VC90_CRT_x86.QFE.C8AE193F_7C6D_330A_93C7_EBBC23C30DBF65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:947]: Component: __downlevel_manifest.30729.6161.policy_9_0_Microsoft_VC90_CRT_x86.QFE.ED5CDF42_FC23_3F0F_80FC_C138299ADCC465; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:947]: Note: 1: 2205 2:  3: BindImage
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:947]: Note: 1: 2205 2:  3: ProgId
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:947]: Note: 1: 2205 2:  3: PublishComponent
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:947]: Note: 1: 2205 2:  3: SelfReg
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:947]: Note: 1: 2205 2:  3: Extension
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:947]: Note: 1: 2205 2:  3: Font
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:947]: Note: 1: 2205 2:  3: Shortcut
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:947]: Note: 1: 2205 2:  3: Class
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:947]: Note: 1: 2205 2:  3: Icon
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:947]: Note: 1: 2205 2:  3: TypeLib
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:948]: Note: 1: 2205 2:  3: _RemoveFilePath
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:948]: PROPERTY CHANGE: Modifying CostingComplete property. Its current value is '0'. Its new value: '1'.
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:948]: Note: 1: 2205 2:  3: BindImage
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:948]: Note: 1: 2205 2:  3: ProgId
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:948]: Note: 1: 2205 2:  3: PublishComponent
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:948]: Note: 1: 2205 2:  3: SelfReg
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:948]: Note: 1: 2205 2:  3: Extension
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:948]: Note: 1: 2205 2:  3: Font
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:948]: Note: 1: 2205 2:  3: Shortcut
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:948]: Note: 1: 2205 2:  3: Class
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:948]: Note: 1: 2205 2:  3: Icon
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:948]: Note: 1: 2205 2:  3: TypeLib
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:949]: Note: 1: 2727 2:
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:963]: Note: 1: 2727 2:
MSI(i) [13:54:55.968] | Action ended 13:54:55: InstallValidate. Return value 1.
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:963]: Creating MSIHANDLE (81) of type 790541 for thread 3996
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:964]: Creating MSIHANDLE (82) of type 790540 for thread 3996
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:964]: Creating MSIHANDLE (83) of type 790531 for thread 3996
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:964]: Note: 1: 2205 2:  3: Condition
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:964]: Note: 1: 2228 2:  3: Condition 4: SELECT * FROM Condition WHERE Feature_ = 'Core'
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:964]: Creating MSIHANDLE (84) of type 790540 for thread 3996
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:964]: Closing MSIHANDLE (84) of type 790540 for thread 3996
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:964]: Closing MSIHANDLE (83) of type 790531 for thread 3996
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:964]: Creating MSIHANDLE (85) of type 790531 for thread 3996
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:964]: Note: 1: 2228 2:  3: Condition 4: SELECT * FROM Condition WHERE Feature_ = 'MS_Runtime_8_0'
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:964]: Creating MSIHANDLE (86) of type 790540 for thread 3996
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:964]: Closing MSIHANDLE (86) of type 790540 for thread 3996
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:964]: Closing MSIHANDLE (85) of type 790531 for thread 3996
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:964]: Creating MSIHANDLE (87) of type 790531 for thread 3996
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:964]: Note: 1: 2228 2:  3: Condition 4: SELECT * FROM Condition WHERE Feature_ = 'MS_Runtime_9_0'
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:964]: Creating MSIHANDLE (88) of type 790540 for thread 3996
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:964]: Closing MSIHANDLE (88) of type 790540 for thread 3996
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:964]: Closing MSIHANDLE (87) of type 790531 for thread 3996
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:964]: Creating MSIHANDLE (89) of type 790531 for thread 3996
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:964]: Note: 1: 2228 2:  3: Condition 4: SELECT * FROM Condition WHERE Feature_ = 'MS_Runtime_10_0'
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:964]: Creating MSIHANDLE (90) of type 790540 for thread 3996
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:964]: Closing MSIHANDLE (90) of type 790540 for thread 3996
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:964]: Closing MSIHANDLE (89) of type 790531 for thread 3996
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:964]: Closing MSIHANDLE (82) of type 790540 for thread 3996
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:964]: Closing MSIHANDLE (81) of type 790541 for thread 3996
MSI(i) [13:54:55.968] | MSI (c) (B0:9C) [13:54:55:964]: Leaked MSIHANDLE (79) of type 790537 for thread 3996
MSI(i) [13:54:55.968] | === Verbose logging stopped: 4/8/2014  13:54:55 ===
PSET(i) [13:54:55.978] | (4225.1904): Dependency {ACD97E2A-090D-46ea-9983-6E44BCA28575} always show dialog
PSET(i) [13:54:55.979] | (4225.2963): MsiOpenPackageEx(C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\msvcrt_x64.msi)
MSI(i) [13:54:56.018] | === Verbose logging started: 4/8/2014  13:54:55  Build type: SHIP UNICODE 5.00.7601.00  Calling process: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\setup.exe ===
MSI(i) [13:54:56.018] | MSI (c) (B0:9C) [13:54:55:980]: SOFTWARE RESTRICTION POLICY: Verifying package --> 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\msvcrt_x64.msi' against software restriction policy
MSI(i) [13:54:56.018] | MSI (c) (B0:9C) [13:54:55:980]: SOFTWARE RESTRICTION POLICY: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\msvcrt_x64.msi has a digital signature
MSI(i) [13:54:56.018] | MSI (c) (B0:9C) [13:54:56:001]: SOFTWARE RESTRICTION POLICY: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\msvcrt_x64.msi is permitted to run at the 'unrestricted' authorization level.
MSI(i) [13:54:56.018] | MSI (c) (B0:9C) [13:54:56:002]: Cloaking enabled.
MSI(i) [13:54:56.018] | MSI (c) (B0:9C) [13:54:56:002]: Attempting to enable all disabled privileges before calling Install on Server
MSI(i) [13:54:56.018] | MSI (c) (B0:9C) [13:54:56:002]: End dialog not enabled
MSI(i) [13:54:56.018] | MSI (c) (B0:9C) [13:54:56:002]: Original package ==> C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\msvcrt_x64.msi
MSI(i) [13:54:56.018] | MSI (c) (B0:9C) [13:54:56:002]: Package we're running from ==> C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\msvcrt_x64.msi
MSI(i) [13:54:56.018] | MSI (c) (B0:9C) [13:54:56:004]: APPCOMPAT: Compatibility mode property overrides found.
MSI(i) [13:54:56.018] | MSI (c) (B0:9C) [13:54:56:004]: APPCOMPAT: looking for appcompat database entry with ProductCode '{40DB5A21-4602-4D7D-B049-0B24691B93AD}'.
MSI(i) [13:54:56.018] | MSI (c) (B0:9C) [13:54:56:004]: APPCOMPAT: no matching ProductCode found in database.
MSI(i) [13:54:56.018] | MSI (c) (B0:9C) [13:54:56:007]: MSCOREE not loaded loading copy from system32
MSI(i) [13:54:56.018] | MSI (c) (B0:9C) [13:54:56:011]: Machine policy value 'TransformsSecure' is 0
MSI(i) [13:54:56.018] | MSI (c) (B0:9C) [13:54:56:011]: User policy value 'TransformsAtSource' is 0
MSI(i) [13:54:56.018] | MSI (c) (B0:9C) [13:54:56:011]: Machine policy value 'DisablePatch' is 0
MSI(i) [13:54:56.018] | MSI (c) (B0:9C) [13:54:56:011]: Machine policy value 'AllowLockdownPatch' is 0
MSI(i) [13:54:56.018] | MSI (c) (B0:9C) [13:54:56:011]: Machine policy value 'DisableLUAPatching' is 0
MSI(i) [13:54:56.018] | MSI (c) (B0:9C) [13:54:56:011]: Machine policy value 'DisableFlyWeightPatching' is 0
MSI(i) [13:54:56.018] | MSI (c) (B0:9C) [13:54:56:012]: Enabling baseline caching for this transaction since all active patches are MSI 3.0 style MSPs or at least one MSI 3.0 minor update patch is active
MSI(i) [13:54:56.018] | MSI (c) (B0:9C) [13:54:56:012]: APPCOMPAT: looking for appcompat database entry with ProductCode '{40DB5A21-4602-4D7D-B049-0B24691B93AD}'.
MSI(i) [13:54:56.018] | MSI (c) (B0:9C) [13:54:56:012]: APPCOMPAT: no matching ProductCode found in database.
MSI(i) [13:54:56.018] | MSI (c) (B0:9C) [13:54:56:012]: Transforms are not secure.
MSI(i) [13:54:56.018] | MSI (c) (B0:9C) [13:54:56:012]: PROPERTY CHANGE: Adding MsiLogFileLocation property. Its value is 'C:\Users\PCCA-PM\AppData\Local\Temp\MSIED31.tmp'.
MSI(i) [13:54:56.018] | MSI (c) (B0:9C) [13:54:56:012]: No Command Line.
MSI(i) [13:54:56.018] | MSI (c) (B0:9C) [13:54:56:012]: PROPERTY CHANGE: Adding PackageCode property. Its value is '{F7F0A864-C985-4C06-8FDB-B44B81272B5D}'.
MSI(i) [13:54:56.018] | MSI (c) (B0:9C) [13:54:56:012]: Product Code passed to Engine.Initialize:           '(none)'
MSI(i) [13:54:56.018] | MSI (c) (B0:9C) [13:54:56:012]: Product Code from property table before transforms: '{40DB5A21-4602-4D7D-B049-0B24691B93AD}'
MSI(i) [13:54:56.018] | MSI (c) (B0:9C) [13:54:56:012]: Product Code from property table after transforms:  '{40DB5A21-4602-4D7D-B049-0B24691B93AD}'
MSI(i) [13:54:56.018] | MSI (c) (B0:9C) [13:54:56:012]: Product not registered: beginning first-time install
MSI(i) [13:54:56.018] | MSI (c) (B0:9C) [13:54:56:012]: PROPERTY CHANGE: Adding ProductState property. Its value is '-1'.
MSI(i) [13:54:56.018] | MSI (c) (B0:9C) [13:54:56:012]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer 3: 2
MSI(i) [13:54:56.018] | MSI (c) (B0:9C) [13:54:56:012]: Entering CMsiConfigurationManager::SetLastUsedSource.
MSI(i) [13:54:56.018] | MSI (c) (B0:9C) [13:54:56:012]: User policy value 'SearchOrder' is 'nmu'
MSI(i) [13:54:56.018] | MSI (c) (B0:9C) [13:54:56:012]: Adding new sources is allowed.
MSI(i) [13:54:56.018] | MSI (c) (B0:9C) [13:54:56:012]: PROPERTY CHANGE: Adding PackagecodeChanging property. Its value is '1'.
MSI(i) [13:54:56.018] | MSI (c) (B0:9C) [13:54:56:012]: Package name extracted from package path: 'msvcrt_x64.msi'
MSI(i) [13:54:56.018] | MSI (c) (B0:9C) [13:54:56:013]: Package to be registered: 'msvcrt_x64.msi'
MSI(i) [13:54:56.018] | MSI (c) (B0:9C) [13:54:56:013]: Note: 1: 2262 2: AdminProperties 3: -2147287038
MSI(i) [13:54:56.018] | MSI (c) (B0:9C) [13:54:56:013]: Machine policy value 'DisableMsi' is 0
MSI(i) [13:54:56.018] | MSI (c) (B0:9C) [13:54:56:013]: Machine policy value 'AlwaysInstallElevated' is 0
MSI(i) [13:54:56.018] | MSI (c) (B0:9C) [13:54:56:013]: User policy value 'AlwaysInstallElevated' is 0
MSI(i) [13:54:56.018] | MSI (c) (B0:9C) [13:54:56:013]: Product installation will be elevated because user is admin and product is being installed per-machine.
MSI(i) [13:54:56.018] | MSI (c) (B0:9C) [13:54:56:013]: Running product '{40DB5A21-4602-4D7D-B049-0B24691B93AD}' with elevated privileges: Product is assigned.
MSI(i) [13:54:56.018] | MSI (c) (B0:9C) [13:54:56:013]: PROPERTY CHANGE: Adding MsiSystemRebootPending property. Its value is '1'.
MSI(i) [13:54:56.018] | MSI (c) (B0:9C) [13:54:56:013]: TRANSFORMS property is now:
MSI(i) [13:54:56.018] | MSI (c) (B0:9C) [13:54:56:013]: PROPERTY CHANGE: Adding VersionDatabase property. Its value is '200'.
MSI(i) [13:54:56.018] | MSI (c) (B0:9C) [13:54:56:014]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming
MSI(i) [13:54:56.018] | MSI (c) (B0:9C) [13:54:56:014]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Favorites
MSI(i) [13:54:56.018] | MSI (c) (B0:9C) [13:54:56:014]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Network Shortcuts
MSI(i) [13:54:56.018] | MSI (c) (B0:9C) [13:54:56:014]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Documents
MSI(i) [13:54:56.018] | MSI (c) (B0:9C) [13:54:56:014]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
MSI(i) [13:54:56.018] | MSI (c) (B0:9C) [13:54:56:014]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Recent
MSI(i) [13:54:56.018] | MSI (c) (B0:9C) [13:54:56:014]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\SendTo
MSI(i) [13:54:56.018] | MSI (c) (B0:9C) [13:54:56:014]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Templates
MSI(i) [13:54:56.018] | MSI (c) (B0:9C) [13:54:56:014]: SHELL32::SHGetFolderPath returned: C:\ProgramData
MSI(i) [13:54:56.018] | MSI (c) (B0:9C) [13:54:56:014]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Local
MSI(i) [13:54:56.018] | MSI (c) (B0:9C) [13:54:56:014]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Pictures
MSI(i) [13:54:56.018] | MSI (c) (B0:9C) [13:54:56:014]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI(i) [13:54:56.018] | MSI (c) (B0:9C) [13:54:56:014]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
MSI(i) [13:54:56.018] | MSI (c) (B0:9C) [13:54:56:014]: SHELL32::SHGetFolderPath returned: C:\Users\Public\Desktop
MSI(i) [13:54:56.018] | MSI (c) (B0:9C) [13:54:56:014]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI(i) [13:54:56.018] | MSI (c) (B0:9C) [13:54:56:014]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
MSI(i) [13:54:56.018] | MSI (c) (B0:9C) [13:54:56:014]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Desktop
MSI(i) [13:54:56.018] | MSI (c) (B0:9C) [13:54:56:014]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Templates
MSI(i) [13:54:56.018] | MSI (c) (B0:9C) [13:54:56:014]: SHELL32::SHGetFolderPath returned: C:\Windows\Fonts
MSI(i) [13:54:56.018] | MSI (c) (B0:9C) [13:54:56:014]: Note: 1: 2898 2: MS Sans Serif 3: MS Sans Serif 4: 0 5: 16
MSI(i) [13:54:56.018] | MSI (c) (B0:9C) [13:54:56:017]: MSI_LUA: Setting AdminUser property to 1 because this is the client or the user has already permitted elevation
MSI(i) [13:54:56.018] | MSI (c) (B0:9C) [13:54:56:017]: MSI_LUA: Setting MsiRunningElevated property to 1 because the install is already running elevated.
MSI(i) [13:54:56.018] | MSI (c) (B0:9C) [13:54:56:017]: PROPERTY CHANGE: Adding MsiRunningElevated property. Its value is '1'.
MSI(i) [13:54:56.018] | MSI (c) (B0:9C) [13:54:56:017]: PROPERTY CHANGE: Adding Privileged property. Its value is '1'.
MSI(i) [13:54:56.018] | MSI (c) (B0:9C) [13:54:56:017]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\MS Setup (ACME)\User Info 3: 2
MSI(i) [13:54:56.018] | MSI (c) (B0:9C) [13:54:56:017]: PROPERTY CHANGE: Adding USERNAME property. Its value is 'A Valued IT Customer'.
MSI(i) [13:54:56.018] | MSI (c) (B0:9C) [13:54:56:017]: PROPERTY CHANGE: Adding COMPANYNAME property. Its value is 'Intel Corporation'.
MSI(i) [13:54:56.018] | MSI (c) (B0:9C) [13:54:56:017]: PROPERTY CHANGE: Adding DATABASE property. Its value is 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\msvcrt_x64.msi'.
MSI(i) [13:54:56.018] | MSI (c) (B0:9C) [13:54:56:017]: PROPERTY CHANGE: Adding OriginalDatabase property. Its value is 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\msvcrt_x64.msi'.
MSI(i) [13:54:56.018] | MSI (c) (B0:9C) [13:54:56:017]: Machine policy value 'MsiDisableEmbeddedUI' is 0
MSI(i) [13:54:56.018] | MSI (c) (B0:9C) [13:54:56:017]: EEUI - Disabling MsiEmbeddedUI in quiet mode
MSI(i) [13:54:56.018] | === Logging started: 4/8/2014  13:54:56 ===
MSI(i) [13:54:56.018] | MSI (c) (B0:9C) [13:54:56:017]: Note: 1: 2205 2:  3: PatchPackage
MSI(i) [13:54:56.018] | MSI (c) (B0:9C) [13:54:56:017]: Machine policy value 'DisableRollback' is 0
MSI(i) [13:54:56.018] | MSI (c) (B0:9C) [13:54:56:017]: User policy value 'DisableRollback' is 0
MSI(i) [13:54:56.018] | MSI (c) (B0:9C) [13:54:56:017]: PROPERTY CHANGE: Adding UILevel property. Its value is '2'.
MSI(i) [13:54:56.018] | MSI (c) (B0:9C) [13:54:56:017]: Creating MSIHANDLE (91) of type 790537 for thread 3996
MSI(i) [13:54:56.018] | MSI (c) (B0:9C) [13:54:56:017]: MsiOpenPackageEx is returning 0
MSI(i) [13:54:56.018] | MSI (c) (B0:9C) [13:54:56:017]: Closing MSIHANDLE (91) of type 790537 for thread 3996
MSI(i) [13:54:56.018] | === Verbose logging stopped: 4/8/2014  13:54:56 ===
PSET(i) [13:54:56.027] | (4225.285): MsiOpenPackageEx(C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\msvcrt_x64.msi)
MSI(i) [13:54:56.099] | === Verbose logging started: 4/8/2014  13:54:56  Build type: SHIP UNICODE 5.00.7601.00  Calling process: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\setup.exe ===
MSI(i) [13:54:56.099] | MSI (c) (B0:9C) [13:54:56:028]: SOFTWARE RESTRICTION POLICY: Verifying package --> 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\msvcrt_x64.msi' against software restriction policy
MSI(i) [13:54:56.099] | MSI (c) (B0:9C) [13:54:56:028]: SOFTWARE RESTRICTION POLICY: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\msvcrt_x64.msi has a digital signature
MSI(i) [13:54:56.099] | MSI (c) (B0:9C) [13:54:56:049]: SOFTWARE RESTRICTION POLICY: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\msvcrt_x64.msi is permitted to run at the 'unrestricted' authorization level.
MSI(i) [13:54:56.099] | MSI (c) (B0:9C) [13:54:56:050]: Cloaking enabled.
MSI(i) [13:54:56.099] | MSI (c) (B0:9C) [13:54:56:050]: Attempting to enable all disabled privileges before calling Install on Server
MSI(i) [13:54:56.099] | MSI (c) (B0:9C) [13:54:56:050]: End dialog not enabled
MSI(i) [13:54:56.099] | MSI (c) (B0:9C) [13:54:56:050]: Original package ==> C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\msvcrt_x64.msi
MSI(i) [13:54:56.099] | MSI (c) (B0:9C) [13:54:56:050]: Package we're running from ==> C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\msvcrt_x64.msi
MSI(i) [13:54:56.099] | MSI (c) (B0:9C) [13:54:56:051]: Machine policy value 'DisableUserInstalls' is 0
MSI(i) [13:54:56.099] | MSI (c) (B0:9C) [13:54:56:052]: APPCOMPAT: Compatibility mode property overrides found.
MSI(i) [13:54:56.099] | MSI (c) (B0:9C) [13:54:56:052]: APPCOMPAT: looking for appcompat database entry with ProductCode '{40DB5A21-4602-4D7D-B049-0B24691B93AD}'.
MSI(i) [13:54:56.099] | MSI (c) (B0:9C) [13:54:56:052]: APPCOMPAT: no matching ProductCode found in database.
MSI(i) [13:54:56.099] | MSI (c) (B0:9C) [13:54:56:054]: MSCOREE not loaded loading copy from system32
MSI(i) [13:54:56.099] | MSI (c) (B0:9C) [13:54:56:057]: Machine policy value 'TransformsSecure' is 0
MSI(i) [13:54:56.099] | MSI (c) (B0:9C) [13:54:56:057]: User policy value 'TransformsAtSource' is 0
MSI(i) [13:54:56.099] | MSI (c) (B0:9C) [13:54:56:058]: Machine policy value 'DisablePatch' is 0
MSI(i) [13:54:56.099] | MSI (c) (B0:9C) [13:54:56:058]: Machine policy value 'AllowLockdownPatch' is 0
MSI(i) [13:54:56.099] | MSI (c) (B0:9C) [13:54:56:058]: Machine policy value 'DisableLUAPatching' is 0
MSI(i) [13:54:56.099] | MSI (c) (B0:9C) [13:54:56:058]: Machine policy value 'DisableFlyWeightPatching' is 0
MSI(i) [13:54:56.099] | MSI (c) (B0:9C) [13:54:56:058]: Enabling baseline caching for this transaction since all active patches are MSI 3.0 style MSPs or at least one MSI 3.0 minor update patch is active
MSI(i) [13:54:56.099] | MSI (c) (B0:9C) [13:54:56:058]: APPCOMPAT: looking for appcompat database entry with ProductCode '{40DB5A21-4602-4D7D-B049-0B24691B93AD}'.
MSI(i) [13:54:56.099] | MSI (c) (B0:9C) [13:54:56:058]: APPCOMPAT: no matching ProductCode found in database.
MSI(i) [13:54:56.099] | MSI (c) (B0:9C) [13:54:56:058]: Transforms are not secure.
MSI(i) [13:54:56.099] | MSI (c) (B0:9C) [13:54:56:058]: PROPERTY CHANGE: Adding MsiLogFileLocation property. Its value is 'C:\Users\PCCA-PM\AppData\Local\Temp\MSIED31.tmp'.
MSI(i) [13:54:56.099] | MSI (c) (B0:9C) [13:54:56:058]: No Command Line.
MSI(i) [13:54:56.099] | MSI (c) (B0:9C) [13:54:56:058]: PROPERTY CHANGE: Adding PackageCode property. Its value is '{F7F0A864-C985-4C06-8FDB-B44B81272B5D}'.
MSI(i) [13:54:56.099] | MSI (c) (B0:9C) [13:54:56:058]: Product Code passed to Engine.Initialize:           '(none)'
MSI(i) [13:54:56.099] | MSI (c) (B0:9C) [13:54:56:058]: Product Code from property table before transforms: '{40DB5A21-4602-4D7D-B049-0B24691B93AD}'
MSI(i) [13:54:56.099] | MSI (c) (B0:9C) [13:54:56:058]: Product Code from property table after transforms:  '{40DB5A21-4602-4D7D-B049-0B24691B93AD}'
MSI(i) [13:54:56.099] | MSI (c) (B0:9C) [13:54:56:058]: Product not registered: beginning first-time install
MSI(i) [13:54:56.099] | MSI (c) (B0:9C) [13:54:56:058]: PROPERTY CHANGE: Adding ProductState property. Its value is '-1'.
MSI(i) [13:54:56.099] | MSI (c) (B0:9C) [13:54:56:059]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer 3: 2
MSI(i) [13:54:56.099] | MSI (c) (B0:9C) [13:54:56:059]: Entering CMsiConfigurationManager::SetLastUsedSource.
MSI(i) [13:54:56.099] | MSI (c) (B0:9C) [13:54:56:059]: User policy value 'SearchOrder' is 'nmu'
MSI(i) [13:54:56.099] | MSI (c) (B0:9C) [13:54:56:059]: Adding new sources is allowed.
MSI(i) [13:54:56.099] | MSI (c) (B0:9C) [13:54:56:059]: PROPERTY CHANGE: Adding PackagecodeChanging property. Its value is '1'.
MSI(i) [13:54:56.099] | MSI (c) (B0:9C) [13:54:56:059]: Package name extracted from package path: 'msvcrt_x64.msi'
MSI(i) [13:54:56.099] | MSI (c) (B0:9C) [13:54:56:059]: Package to be registered: 'msvcrt_x64.msi'
MSI(i) [13:54:56.099] | MSI (c) (B0:9C) [13:54:56:059]: Note: 1: 2262 2: AdminProperties 3: -2147287038
MSI(i) [13:54:56.099] | MSI (c) (B0:9C) [13:54:56:059]: Machine policy value 'DisableMsi' is 0
MSI(i) [13:54:56.099] | MSI (c) (B0:9C) [13:54:56:059]: Machine policy value 'AlwaysInstallElevated' is 0
MSI(i) [13:54:56.099] | MSI (c) (B0:9C) [13:54:56:059]: User policy value 'AlwaysInstallElevated' is 0
MSI(i) [13:54:56.099] | MSI (c) (B0:9C) [13:54:56:059]: Product installation will be elevated because user is admin and product is being installed per-machine.
MSI(i) [13:54:56.099] | MSI (c) (B0:9C) [13:54:56:059]: Running product '{40DB5A21-4602-4D7D-B049-0B24691B93AD}' with elevated privileges: Product is assigned.
MSI(i) [13:54:56.099] | MSI (c) (B0:9C) [13:54:56:060]: PROPERTY CHANGE: Adding MsiSystemRebootPending property. Its value is '1'.
MSI(i) [13:54:56.099] | MSI (c) (B0:9C) [13:54:56:060]: TRANSFORMS property is now:
MSI(i) [13:54:56.099] | MSI (c) (B0:9C) [13:54:56:060]: PROPERTY CHANGE: Adding VersionDatabase property. Its value is '200'.
MSI(i) [13:54:56.099] | MSI (c) (B0:9C) [13:54:56:060]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming
MSI(i) [13:54:56.099] | MSI (c) (B0:9C) [13:54:56:060]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Favorites
MSI(i) [13:54:56.099] | MSI (c) (B0:9C) [13:54:56:060]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Network Shortcuts
MSI(i) [13:54:56.099] | MSI (c) (B0:9C) [13:54:56:060]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Documents
MSI(i) [13:54:56.099] | MSI (c) (B0:9C) [13:54:56:060]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
MSI(i) [13:54:56.099] | MSI (c) (B0:9C) [13:54:56:060]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Recent
MSI(i) [13:54:56.099] | MSI (c) (B0:9C) [13:54:56:060]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\SendTo
MSI(i) [13:54:56.099] | MSI (c) (B0:9C) [13:54:56:060]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Templates
MSI(i) [13:54:56.099] | MSI (c) (B0:9C) [13:54:56:060]: SHELL32::SHGetFolderPath returned: C:\ProgramData
MSI(i) [13:54:56.099] | MSI (c) (B0:9C) [13:54:56:060]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Local
MSI(i) [13:54:56.099] | MSI (c) (B0:9C) [13:54:56:060]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Pictures
MSI(i) [13:54:56.099] | MSI (c) (B0:9C) [13:54:56:060]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI(i) [13:54:56.099] | MSI (c) (B0:9C) [13:54:56:060]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
MSI(i) [13:54:56.099] | MSI (c) (B0:9C) [13:54:56:060]: SHELL32::SHGetFolderPath returned: C:\Users\Public\Desktop
MSI(i) [13:54:56.099] | MSI (c) (B0:9C) [13:54:56:060]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI(i) [13:54:56.099] | MSI (c) (B0:9C) [13:54:56:060]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
MSI(i) [13:54:56.099] | MSI (c) (B0:9C) [13:54:56:060]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Desktop
MSI(i) [13:54:56.099] | MSI (c) (B0:9C) [13:54:56:060]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Templates
MSI(i) [13:54:56.099] | MSI (c) (B0:9C) [13:54:56:061]: SHELL32::SHGetFolderPath returned: C:\Windows\Fonts
MSI(i) [13:54:56.099] | MSI (c) (B0:9C) [13:54:56:061]: Note: 1: 2898 2: MS Sans Serif 3: MS Sans Serif 4: 0 5: 16
MSI(i) [13:54:56.099] | MSI (c) (B0:9C) [13:54:56:063]: MSI_LUA: Setting AdminUser property to 1 because this is the client or the user has already permitted elevation
MSI(i) [13:54:56.099] | MSI (c) (B0:9C) [13:54:56:063]: MSI_LUA: Setting MsiRunningElevated property to 1 because the install is already running elevated.
MSI(i) [13:54:56.099] | MSI (c) (B0:9C) [13:54:56:063]: PROPERTY CHANGE: Adding MsiRunningElevated property. Its value is '1'.
MSI(i) [13:54:56.099] | MSI (c) (B0:9C) [13:54:56:063]: PROPERTY CHANGE: Adding Privileged property. Its value is '1'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:063]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\MS Setup (ACME)\User Info 3: 2
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:063]: PROPERTY CHANGE: Adding USERNAME property. Its value is 'A Valued IT Customer'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:063]: PROPERTY CHANGE: Adding COMPANYNAME property. Its value is 'Intel Corporation'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:063]: PROPERTY CHANGE: Adding DATABASE property. Its value is 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\msvcrt_x64.msi'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:063]: PROPERTY CHANGE: Adding OriginalDatabase property. Its value is 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\msvcrt_x64.msi'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:063]: Machine policy value 'MsiDisableEmbeddedUI' is 0
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:063]: EEUI - Disabling MsiEmbeddedUI in quiet mode
MSI(i) [13:54:56.100] | === Logging started: 4/8/2014  13:54:56 ===
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:063]: Note: 1: 2205 2:  3: PatchPackage
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:064]: Machine policy value 'DisableRollback' is 0
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:064]: User policy value 'DisableRollback' is 0
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:064]: PROPERTY CHANGE: Adding UILevel property. Its value is '2'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:064]: Creating MSIHANDLE (92) of type 790537 for thread 3996
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:064]: MsiOpenPackageEx is returning 0
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:064]: Creating MSIHANDLE (93) of type 790541 for thread 3996
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:064]: Closing MSIHANDLE (93) of type 790541 for thread 3996
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:064]: Doing action: AppSearch
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:064]: Note: 1: 2205 2:  3: ActionText
MSI(i) [13:54:56.100] | Action 13:54:56: AppSearch. Searching for installed applications
MSI(i) [13:54:56.100] | Action start 13:54:56: AppSearch.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:065]: Note: 1: 2205 2:  3: AppSearch
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:065]: Note: 1: 2228 2:  3: AppSearch 4: SELECT `Property`, `Signature_` FROM `AppSearch`
MSI(i) [13:54:56.100] | Action ended 13:54:56: AppSearch. Return value 0.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:065]: Doing action: CostInitialize
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:065]: Note: 1: 2205 2:  3: ActionText
MSI(i) [13:54:56.100] | Action 13:54:56: CostInitialize. Computing space requirements
MSI(i) [13:54:56.100] | Action start 13:54:56: CostInitialize.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:067]: Machine policy value 'MaxPatchCacheSize' is 10
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:067]: Baseline: Sorting baselines for {40DB5A21-4602-4D7D-B049-0B24691B93AD}.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:067]: Baseline: New baseline 13.1.5000 from transaction.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:067]: Baseline: Sorted order Native: Order 0.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:067]: Baseline Data Table:
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:067]: ProductCode: {40DB5A21-4602-4D7D-B049-0B24691B93AD} Version: 13.1.5000 Attributes: 0 PatchId: Native BaselineId: -2147483648 Order: 0
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:067]: Baseline File Table:
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:067]: PROPERTY CHANGE: Adding ROOTDRIVE property. Its value is 'C:\'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:068]: PROPERTY CHANGE: Adding CostingComplete property. Its value is '0'.
MSI(i) [13:54:56.100] | Action ended 13:54:56: CostInitialize. Return value 1.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:068]: Doing action: FileCost
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:068]: Note: 1: 2205 2:  3: ActionText
MSI(i) [13:54:56.100] | Action 13:54:56: FileCost. Computing space requirements
MSI(i) [13:54:56.100] | Action start 13:54:56: FileCost.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:070]: Note: 1: 2205 2:  3: Class
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:070]: Note: 1: 2205 2:  3: Extension
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:070]: Note: 1: 2205 2:  3: TypeLib
MSI(i) [13:54:56.100] | Action ended 13:54:56: FileCost. Return value 1.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:070]: Doing action: CostFinalize
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:070]: Note: 1: 2205 2:  3: ActionText
MSI(i) [13:54:56.100] | Action 13:54:56: CostFinalize. Computing space requirements
MSI(i) [13:54:56.100] | Action start 13:54:56: CostFinalize.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:071]: PROPERTY CHANGE: Adding OutOfDiskSpace property. Its value is '0'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:071]: PROPERTY CHANGE: Adding OutOfNoRbDiskSpace property. Its value is '0'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:071]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceAvailable property. Its value is '0'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:071]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRequired property. Its value is '0'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:071]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRemaining property. Its value is '0'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:072]: Note: 1: 2205 2:  3: Patch
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:072]: Note: 1: 2205 2:  3: Condition
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:072]: PROPERTY CHANGE: Adding TARGETDIR property. Its value is 'C:\'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:072]: PROPERTY CHANGE: Adding INSTALLDIR property. Its value is 'C:\'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:072]: PROPERTY CHANGE: Adding WindowsFolder_amd64_VC.1C11561A_11CB_36A7_8A47_D7A042055FA7 property. Its value is 'C:\Win\'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:072]: PROPERTY CHANGE: Adding System64Folder_amd64_VC.1C11561A_11CB_36A7_8A47_D7A042055FA7 property. Its value is 'C:\Win\System64\'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:072]: PROPERTY CHANGE: Adding WindowsFolder.30729.6161.policy_9_0_Microsoft_VC90_CRT_x64.QFE.2B64E0BC_8AED_3A12_9FC4_E6C247309FFF property. Its value is 'C:\Windows\'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:072]: PROPERTY CHANGE: Adding WinSxsDirectory.30729.6161.policy_9_0_Microsoft_VC90_CRT_x64.QFE.2B64E0BC_8AED_3A12_9FC4_E6C247309FFF property. Its value is 'C:\Windows\winsxs\'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:072]: PROPERTY CHANGE: Adding WinSxsPolicies.30729.6161.policy_9_0_Microsoft_VC90_CRT_x64.QFE.2B64E0BC_8AED_3A12_9FC4_E6C247309FFF property. Its value is 'C:\Windows\winsxs\Policies\'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:072]: PROPERTY CHANGE: Adding policydir.30729.6161.policy_9_0_Microsoft_VC90_CRT_x64.QFE.2B64E0BC_8AED_3A12_9FC4_E6C247309FFF property. Its value is 'C:\Windows\winsxs\Policies\amd64_policy.9.0.Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_x-ww_16f3e195\'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:072]: PROPERTY CHANGE: Adding payload_ul.30729.6161.policy_9_0_Microsoft_VC90_CRT_x64.QFE.2B64E0BC_8AED_3A12_9FC4_E6C247309FFF property. Its value is 'C:\Windows\winsxs\amd64_policy.9.0.microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.6161_none_acd388d7e1d8689f\'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:072]: PROPERTY CHANGE: Adding WindowsFolder.30729.6161.Microsoft_VC90_CRT_x64.QFE.D11988A5_400E_3D5F_834D_62102379E659 property. Its value is 'C:\Windows\'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:072]: PROPERTY CHANGE: Adding WinSxsDirectory.30729.6161.Microsoft_VC90_CRT_x64.QFE.D11988A5_400E_3D5F_834D_62102379E659 property. Its value is 'C:\Windows\winsxs\'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:072]: PROPERTY CHANGE: Adding policydir_ul.30729.6161.Microsoft_VC90_CRT_x64.QFE.D11988A5_400E_3D5F_834D_62102379E659 property. Its value is 'C:\Windows\winsxs\amd64_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_x-ww_7701165b\'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:072]: PROPERTY CHANGE: Adding WinSxsPolicies.30729.6161.Microsoft_VC90_CRT_x64.QFE.D11988A5_400E_3D5F_834D_62102379E659 property. Its value is 'C:\Windows\winsxs\Policies\'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:072]: PROPERTY CHANGE: Adding policydir.30729.6161.Microsoft_VC90_CRT_x64.QFE.D11988A5_400E_3D5F_834D_62102379E659 property. Its value is 'C:\Windows\winsxs\Policies\amd64_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_x-ww_7701165b\'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:072]: PROPERTY CHANGE: Adding WinSxsManifests.30729.6161.Microsoft_VC90_CRT_x64.QFE.D11988A5_400E_3D5F_834D_62102379E659 property. Its value is 'C:\Windows\winsxs\Manifests\'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:072]: PROPERTY CHANGE: Adding payload.30729.6161.Microsoft_VC90_CRT_x64.QFE.D11988A5_400E_3D5F_834D_62102379E659 property. Its value is 'C:\Windows\winsxs\amd64_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_9.0.30729.6161_x-ww_63af3423\'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:072]: PROPERTY CHANGE: Adding payload_ul.30729.6161.Microsoft_VC90_CRT_x64.QFE.D11988A5_400E_3D5F_834D_62102379E659 property. Its value is 'C:\Windows\winsxs\amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.6161_none_08e61857a83bc251\'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:072]: PROPERTY CHANGE: Adding WindowsFolder.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:072]: PROPERTY CHANGE: Adding SystemFolder.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\system32\'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:072]: PROPERTY CHANGE: Adding WinSxsDirectory.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:072]: PROPERTY CHANGE: Adding payload.8.0.50727.4053.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4053_x-ww_5ca41c70\'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:072]: PROPERTY CHANGE: Adding payload.8.0.50727.4052.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4052_x-ww_5ca41c6f\'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:072]: PROPERTY CHANGE: Adding payload.8.0.50727.4045.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4045_x-ww_5ca31c33\'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:072]: PROPERTY CHANGE: Adding payload.8.0.50727.4029.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4029_x-ww_5ca11bb9\'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:072]: PROPERTY CHANGE: Adding payload.8.0.50727.4028.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4028_x-ww_5ca11bb8\'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:072]: PROPERTY CHANGE: Adding payload.8.0.50727.4027.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4027_x-ww_5ca11bb7\'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:072]: PROPERTY CHANGE: Adding payload.8.0.50727.1833.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.1833_x-ww_d4fe25bd\'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:072]: PROPERTY CHANGE: Adding payload.8.0.50727.3069.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.3069_x-ww_2e1e4bf6\'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:072]: PROPERTY CHANGE: Adding payload.8.0.50727.3051.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.3051_x-ww_2e1d4baf\'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:072]: PROPERTY CHANGE: Adding payload.8.0.50727.3044.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.3044_x-ww_2e1c4b73\'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:073]: PROPERTY CHANGE: Adding payload.8.0.50727.238.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.238_x-ww_dea6dbab\'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:073]: PROPERTY CHANGE: Adding payload.8.0.50727.193.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.193_x-ww_de2ecd9f\'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:073]: PROPERTY CHANGE: Adding payload.8.0.50727.104.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.104_x-ww_de25cb69\'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:073]: PROPERTY CHANGE: Adding payload.8.0.50727.103.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.103_x-ww_de25cb68\'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:073]: PROPERTY CHANGE: Adding payload.8.0.50727.101.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.101_x-ww_de25cb66\'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:073]: PROPERTY CHANGE: Adding payload.8.0.50727.100.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.100_x-ww_de25cb65\'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:073]: PROPERTY CHANGE: Adding payload.8.0.50727.99.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.99_x-ww_83f30ef6\'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:073]: PROPERTY CHANGE: Adding payload.8.0.50727.98.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.98_x-ww_83f30ef5\'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:073]: PROPERTY CHANGE: Adding payload.8.0.50727.97.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.97_x-ww_83f30ef4\'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:073]: PROPERTY CHANGE: Adding payload.8.0.50727.96.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.96_x-ww_83f30ef3\'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:073]: PROPERTY CHANGE: Adding payload.8.0.50727.95.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.95_x-ww_83f30ef2\'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:073]: PROPERTY CHANGE: Adding payload.8.0.50727.93.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.93_x-ww_83f30ef0\'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:073]: PROPERTY CHANGE: Adding payload.8.0.50727.89.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.89_x-ww_83f20eb7\'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:073]: PROPERTY CHANGE: Adding payload.8.0.50727.94.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.94_x-ww_83f30ef1\'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:073]: PROPERTY CHANGE: Adding policydir_ul.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4053_x-ww_5ca41c70\'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:073]: PROPERTY CHANGE: Adding payload.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.42_x-ww_83ee0db4\'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:073]: PROPERTY CHANGE: Adding WinSxsManifests.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Manifests\'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:073]: PROPERTY CHANGE: Adding WinSxsPolicies.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:073]: PROPERTY CHANGE: Adding policydir.8.0.50727.4053.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_d780e993\'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:073]: PROPERTY CHANGE: Adding policydir.8.0.50727.3069.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_d780e993\'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:073]: PROPERTY CHANGE: Adding policydir.8.0.50727.4027.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_d780e993\'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:073]: PROPERTY CHANGE: Adding policydir.8.0.50727.4045.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_d780e993\'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:073]: PROPERTY CHANGE: Adding policydir.8.0.50727.4029.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_d780e993\'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:073]: PROPERTY CHANGE: Adding policydir.8.0.50727.3051.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_d780e993\'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:073]: PROPERTY CHANGE: Adding policydir.8.0.50727.1833.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_d780e993\'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:073]: PROPERTY CHANGE: Adding policydir.8.0.50727.4052.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_d780e993\'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:073]: PROPERTY CHANGE: Adding policydir.8.0.50727.238.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_d780e993\'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:073]: PROPERTY CHANGE: Adding policydir.8.0.50727.3044.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_d780e993\'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:073]: PROPERTY CHANGE: Adding policydir.8.0.50727.4028.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_d780e993\'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:073]: PROPERTY CHANGE: Adding policydir.8.0.50727.97.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_d780e993\'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:073]: PROPERTY CHANGE: Adding policydir.8.0.50727.101.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_d780e993\'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:073]: PROPERTY CHANGE: Adding policydir.8.0.50727.99.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_d780e993\'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:073]: PROPERTY CHANGE: Adding policydir.8.0.50727.104.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_d780e993\'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:073]: PROPERTY CHANGE: Adding policydir.8.0.50727.98.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_d780e993\'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:073]: PROPERTY CHANGE: Adding policydir.8.0.50727.193.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_d780e993\'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:073]: PROPERTY CHANGE: Adding policydir.8.0.50727.93.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_d780e993\'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:073]: PROPERTY CHANGE: Adding policydir.8.0.50727.100.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_d780e993\'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:073]: PROPERTY CHANGE: Adding policydir.8.0.50727.95.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_d780e993\'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:073]: PROPERTY CHANGE: Adding policydir.8.0.50727.89.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_d780e993\'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:073]: PROPERTY CHANGE: Adding policydir.8.0.50727.94.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_d780e993\'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:073]: PROPERTY CHANGE: Adding policydir.8.0.50727.96.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_d780e993\'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:073]: PROPERTY CHANGE: Adding policydir.8.0.50727.103.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_d780e993\'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:073]: PROPERTY CHANGE: Adding policydir.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_d780e993\'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:073]: PROPERTY CHANGE: Adding payload_ul.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\amd64_policy.8.0.microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.4053_none_09c0f789facc94a0\'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:073]: PROPERTY CHANGE: Adding WindowsFolder.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:073]: PROPERTY CHANGE: Adding SystemFolder.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\system32\'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:073]: PROPERTY CHANGE: Adding WinSxsDirectory.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:073]: PROPERTY CHANGE: Adding payload.8.0.50727.4053.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4053_x-ww_18a05f69\'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:073]: PROPERTY CHANGE: Adding payload.8.0.50727.4052.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4052_x-ww_18a05f68\'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:073]: PROPERTY CHANGE: Adding payload.8.0.50727.4045.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4045_x-ww_189f5f2c\'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:073]: PROPERTY CHANGE: Adding payload.8.0.50727.4029.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4029_x-ww_189d5eb2\'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:073]: PROPERTY CHANGE: Adding payload.8.0.50727.4028.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4028_x-ww_189d5eb1\'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:073]: PROPERTY CHANGE: Adding payload.8.0.50727.4027.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4027_x-ww_189d5eb0\'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:073]: PROPERTY CHANGE: Adding payload.8.0.50727.1833.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.1833_x-ww_90fa68b6\'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:073]: PROPERTY CHANGE: Adding payload.8.0.50727.3069.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.3069_x-ww_ea1a8eef\'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:073]: PROPERTY CHANGE: Adding payload.8.0.50727.3051.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.3051_x-ww_ea198ea8\'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:073]: PROPERTY CHANGE: Adding payload.8.0.50727.3044.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.3044_x-ww_ea188e6c\'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:073]: PROPERTY CHANGE: Adding payload.8.0.50727.193.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.193_x-ww_9a2b1098\'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:073]: PROPERTY CHANGE: Adding payload.8.0.50727.238.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.238_x-ww_9aa31ea4\'.
MSI(i) [13:54:56.100] | MSI (c) (B0:9C) [13:54:56:073]: PROPERTY CHANGE: Adding payload.8.0.50727.104.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.104_x-ww_9a220e62\'.
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:073]: PROPERTY CHANGE: Adding payload.8.0.50727.103.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.103_x-ww_9a220e61\'.
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:073]: PROPERTY CHANGE: Adding payload.8.0.50727.101.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.101_x-ww_9a220e5f\'.
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:073]: PROPERTY CHANGE: Adding payload.8.0.50727.100.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.100_x-ww_9a220e5e\'.
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:073]: PROPERTY CHANGE: Adding payload.8.0.50727.99.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.99_x-ww_3fef51ef\'.
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:073]: PROPERTY CHANGE: Adding payload.8.0.50727.98.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.98_x-ww_3fef51ee\'.
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:073]: PROPERTY CHANGE: Adding payload.8.0.50727.97.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.97_x-ww_3fef51ed\'.
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: PROPERTY CHANGE: Adding payload.8.0.50727.96.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.96_x-ww_3fef51ec\'.
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: PROPERTY CHANGE: Adding payload.8.0.50727.94.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.94_x-ww_3fef51ea\'.
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: PROPERTY CHANGE: Adding payload.8.0.50727.95.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.95_x-ww_3fef51eb\'.
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: PROPERTY CHANGE: Adding payload.8.0.50727.93.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.93_x-ww_3fef51e9\'.
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: PROPERTY CHANGE: Adding payload.8.0.50727.89.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.89_x-ww_3fee51b0\'.
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: PROPERTY CHANGE: Adding policydir_ul.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4053_x-ww_18a05f69\'.
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: PROPERTY CHANGE: Adding WinSxsManifests.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Manifests\'.
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: PROPERTY CHANGE: Adding payload.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.42_x-ww_3fea50ad\'.
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: PROPERTY CHANGE: Adding payload_ul.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\amd64_microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.4053_none_88e046c92fae6f57\'.
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: PROPERTY CHANGE: Adding WinSxsPolicies.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\'.
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: PROPERTY CHANGE: Adding policydir.8.0.50727.4053.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_a3e7585a\'.
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: PROPERTY CHANGE: Adding policydir.8.0.50727.4052.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_a3e7585a\'.
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: PROPERTY CHANGE: Adding policydir.8.0.50727.4045.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_a3e7585a\'.
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: PROPERTY CHANGE: Adding policydir.8.0.50727.4028.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_a3e7585a\'.
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: PROPERTY CHANGE: Adding policydir.8.0.50727.4027.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_a3e7585a\'.
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: PROPERTY CHANGE: Adding policydir.8.0.50727.1833.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_a3e7585a\'.
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: PROPERTY CHANGE: Adding policydir.8.0.50727.4029.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_a3e7585a\'.
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: PROPERTY CHANGE: Adding policydir.8.0.50727.3051.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_a3e7585a\'.
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: PROPERTY CHANGE: Adding policydir.8.0.50727.3069.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_a3e7585a\'.
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: PROPERTY CHANGE: Adding policydir.8.0.50727.3044.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_a3e7585a\'.
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: PROPERTY CHANGE: Adding policydir.8.0.50727.193.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_a3e7585a\'.
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: PROPERTY CHANGE: Adding policydir.8.0.50727.238.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_a3e7585a\'.
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: PROPERTY CHANGE: Adding policydir.8.0.50727.104.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_a3e7585a\'.
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: PROPERTY CHANGE: Adding policydir.8.0.50727.103.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_a3e7585a\'.
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: PROPERTY CHANGE: Adding policydir.8.0.50727.100.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_a3e7585a\'.
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: PROPERTY CHANGE: Adding policydir.8.0.50727.99.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_a3e7585a\'.
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: PROPERTY CHANGE: Adding policydir.8.0.50727.101.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_a3e7585a\'.
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: PROPERTY CHANGE: Adding policydir.8.0.50727.89.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_a3e7585a\'.
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: PROPERTY CHANGE: Adding policydir.8.0.50727.98.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_a3e7585a\'.
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: PROPERTY CHANGE: Adding policydir.8.0.50727.96.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_a3e7585a\'.
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: PROPERTY CHANGE: Adding policydir.8.0.50727.97.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_a3e7585a\'.
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: PROPERTY CHANGE: Adding policydir.8.0.50727.94.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_a3e7585a\'.
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: PROPERTY CHANGE: Adding policydir.8.0.50727.95.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_a3e7585a\'.
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: PROPERTY CHANGE: Adding policydir.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_a3e7585a\'.
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: PROPERTY CHANGE: Adding policydir.8.0.50727.93.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_a3e7585a\'.
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: Target path resolution complete. Dumping Directory table...
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: Note: target paths subject to change (via custom actions or browsing)
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: Dir (target): Key: TARGETDIR    , Object: C:\
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: Dir (target): Key: WindowsFolder    , Object: C:\Windows\
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: Dir (target): Key: INSTALLDIR    , Object: C:\
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: Dir (target): Key: WindowsFolder_amd64_VC.1C11561A_11CB_36A7_8A47_D7A042055FA7    , Object: C:\Win\
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: Dir (target): Key: System64Folder_amd64_VC.1C11561A_11CB_36A7_8A47_D7A042055FA7    , Object: C:\Win\System64\
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: Dir (target): Key: WindowsFolder.30729.6161.policy_9_0_Microsoft_VC90_CRT_x64.QFE.2B64E0BC_8AED_3A12_9FC4_E6C247309FFF    , Object: C:\Windows\
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: Dir (target): Key: WinSxsDirectory.30729.6161.policy_9_0_Microsoft_VC90_CRT_x64.QFE.2B64E0BC_8AED_3A12_9FC4_E6C247309FFF    , Object: C:\Windows\winsxs\
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: Dir (target): Key: WinSxsPolicies.30729.6161.policy_9_0_Microsoft_VC90_CRT_x64.QFE.2B64E0BC_8AED_3A12_9FC4_E6C247309FFF    , Object: C:\Windows\winsxs\Policies\
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: Dir (target): Key: policydir.30729.6161.policy_9_0_Microsoft_VC90_CRT_x64.QFE.2B64E0BC_8AED_3A12_9FC4_E6C247309FFF    , Object: C:\Windows\winsxs\Policies\amd64_policy.9.0.Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_x-ww_16f3e195\
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: Dir (target): Key: payload_ul.30729.6161.policy_9_0_Microsoft_VC90_CRT_x64.QFE.2B64E0BC_8AED_3A12_9FC4_E6C247309FFF    , Object: C:\Windows\winsxs\amd64_policy.9.0.microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.6161_none_acd388d7e1d8689f\
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: Dir (target): Key: WindowsFolder.30729.6161.Microsoft_VC90_CRT_x64.QFE.D11988A5_400E_3D5F_834D_62102379E659    , Object: C:\Windows\
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: Dir (target): Key: WinSxsDirectory.30729.6161.Microsoft_VC90_CRT_x64.QFE.D11988A5_400E_3D5F_834D_62102379E659    , Object: C:\Windows\winsxs\
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: Dir (target): Key: policydir_ul.30729.6161.Microsoft_VC90_CRT_x64.QFE.D11988A5_400E_3D5F_834D_62102379E659    , Object: C:\Windows\winsxs\amd64_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_x-ww_7701165b\
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: Dir (target): Key: WinSxsPolicies.30729.6161.Microsoft_VC90_CRT_x64.QFE.D11988A5_400E_3D5F_834D_62102379E659    , Object: C:\Windows\winsxs\Policies\
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: Dir (target): Key: policydir.30729.6161.Microsoft_VC90_CRT_x64.QFE.D11988A5_400E_3D5F_834D_62102379E659    , Object: C:\Windows\winsxs\Policies\amd64_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_x-ww_7701165b\
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: Dir (target): Key: WinSxsManifests.30729.6161.Microsoft_VC90_CRT_x64.QFE.D11988A5_400E_3D5F_834D_62102379E659    , Object: C:\Windows\winsxs\Manifests\
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: Dir (target): Key: payload.30729.6161.Microsoft_VC90_CRT_x64.QFE.D11988A5_400E_3D5F_834D_62102379E659    , Object: C:\Windows\winsxs\amd64_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_9.0.30729.6161_x-ww_63af3423\
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: Dir (target): Key: payload_ul.30729.6161.Microsoft_VC90_CRT_x64.QFE.D11988A5_400E_3D5F_834D_62102379E659    , Object: C:\Windows\winsxs\amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.6161_none_08e61857a83bc251\
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: Dir (target): Key: WindowsFolder.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E    , Object: C:\Windows\
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: Dir (target): Key: SystemFolder.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E    , Object: C:\Windows\system32\
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: Dir (target): Key: WinSxsDirectory.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: Dir (target): Key: payload.8.0.50727.4053.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4053_x-ww_5ca41c70\
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: Dir (target): Key: payload.8.0.50727.4052.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4052_x-ww_5ca41c6f\
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: Dir (target): Key: payload.8.0.50727.4045.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4045_x-ww_5ca31c33\
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: Dir (target): Key: payload.8.0.50727.4029.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4029_x-ww_5ca11bb9\
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: Dir (target): Key: payload.8.0.50727.4028.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4028_x-ww_5ca11bb8\
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: Dir (target): Key: payload.8.0.50727.4027.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4027_x-ww_5ca11bb7\
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: Dir (target): Key: payload.8.0.50727.1833.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.1833_x-ww_d4fe25bd\
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: Dir (target): Key: payload.8.0.50727.3069.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.3069_x-ww_2e1e4bf6\
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: Dir (target): Key: payload.8.0.50727.3051.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.3051_x-ww_2e1d4baf\
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: Dir (target): Key: payload.8.0.50727.3044.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.3044_x-ww_2e1c4b73\
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: Dir (target): Key: payload.8.0.50727.238.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.238_x-ww_dea6dbab\
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: Dir (target): Key: payload.8.0.50727.193.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.193_x-ww_de2ecd9f\
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: Dir (target): Key: payload.8.0.50727.104.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.104_x-ww_de25cb69\
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: Dir (target): Key: payload.8.0.50727.103.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.103_x-ww_de25cb68\
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: Dir (target): Key: payload.8.0.50727.101.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.101_x-ww_de25cb66\
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: Dir (target): Key: payload.8.0.50727.100.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.100_x-ww_de25cb65\
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: Dir (target): Key: payload.8.0.50727.99.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.99_x-ww_83f30ef6\
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: Dir (target): Key: payload.8.0.50727.98.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.98_x-ww_83f30ef5\
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: Dir (target): Key: payload.8.0.50727.97.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.97_x-ww_83f30ef4\
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: Dir (target): Key: payload.8.0.50727.96.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.96_x-ww_83f30ef3\
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: Dir (target): Key: payload.8.0.50727.95.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.95_x-ww_83f30ef2\
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: Dir (target): Key: payload.8.0.50727.93.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.93_x-ww_83f30ef0\
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: Dir (target): Key: payload.8.0.50727.89.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.89_x-ww_83f20eb7\
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: Dir (target): Key: payload.8.0.50727.94.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.94_x-ww_83f30ef1\
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: Dir (target): Key: policydir_ul.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4053_x-ww_5ca41c70\
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: Dir (target): Key: payload.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.42_x-ww_83ee0db4\
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: Dir (target): Key: WinSxsManifests.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Manifests\
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: Dir (target): Key: WinSxsPolicies.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: Dir (target): Key: policydir.8.0.50727.4053.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_d780e993\
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: Dir (target): Key: policydir.8.0.50727.3069.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_d780e993\
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: Dir (target): Key: policydir.8.0.50727.4027.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_d780e993\
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: Dir (target): Key: policydir.8.0.50727.4045.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_d780e993\
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: Dir (target): Key: policydir.8.0.50727.4029.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_d780e993\
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: Dir (target): Key: policydir.8.0.50727.3051.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_d780e993\
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: Dir (target): Key: policydir.8.0.50727.1833.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_d780e993\
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: Dir (target): Key: policydir.8.0.50727.4052.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_d780e993\
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: Dir (target): Key: policydir.8.0.50727.238.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_d780e993\
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: Dir (target): Key: policydir.8.0.50727.3044.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_d780e993\
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: Dir (target): Key: policydir.8.0.50727.4028.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_d780e993\
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: Dir (target): Key: policydir.8.0.50727.97.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_d780e993\
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: Dir (target): Key: policydir.8.0.50727.101.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_d780e993\
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: Dir (target): Key: policydir.8.0.50727.99.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_d780e993\
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: Dir (target): Key: policydir.8.0.50727.104.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_d780e993\
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: Dir (target): Key: policydir.8.0.50727.98.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_d780e993\
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: Dir (target): Key: policydir.8.0.50727.193.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_d780e993\
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: Dir (target): Key: policydir.8.0.50727.93.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_d780e993\
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: Dir (target): Key: policydir.8.0.50727.100.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_d780e993\
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: Dir (target): Key: policydir.8.0.50727.95.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_d780e993\
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: Dir (target): Key: policydir.8.0.50727.89.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_d780e993\
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: Dir (target): Key: policydir.8.0.50727.94.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_d780e993\
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: Dir (target): Key: policydir.8.0.50727.96.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_d780e993\
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:074]: Dir (target): Key: policydir.8.0.50727.103.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_d780e993\
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:075]: Dir (target): Key: policydir.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\amd64_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_d780e993\
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:075]: Dir (target): Key: payload_ul.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\amd64_policy.8.0.microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.4053_none_09c0f789facc94a0\
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:075]: Dir (target): Key: WindowsFolder.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E    , Object: C:\Windows\
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:075]: Dir (target): Key: SystemFolder.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E    , Object: C:\Windows\system32\
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:075]: Dir (target): Key: WinSxsDirectory.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:075]: Dir (target): Key: payload.8.0.50727.4053.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4053_x-ww_18a05f69\
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:075]: Dir (target): Key: payload.8.0.50727.4052.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4052_x-ww_18a05f68\
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:075]: Dir (target): Key: payload.8.0.50727.4045.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4045_x-ww_189f5f2c\
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:075]: Dir (target): Key: payload.8.0.50727.4029.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4029_x-ww_189d5eb2\
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:075]: Dir (target): Key: payload.8.0.50727.4028.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4028_x-ww_189d5eb1\
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:075]: Dir (target): Key: payload.8.0.50727.4027.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4027_x-ww_189d5eb0\
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:075]: Dir (target): Key: payload.8.0.50727.1833.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.1833_x-ww_90fa68b6\
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:075]: Dir (target): Key: payload.8.0.50727.3069.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.3069_x-ww_ea1a8eef\
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:075]: Dir (target): Key: payload.8.0.50727.3051.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.3051_x-ww_ea198ea8\
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:075]: Dir (target): Key: payload.8.0.50727.3044.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.3044_x-ww_ea188e6c\
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:075]: Dir (target): Key: payload.8.0.50727.193.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.193_x-ww_9a2b1098\
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:075]: Dir (target): Key: payload.8.0.50727.238.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.238_x-ww_9aa31ea4\
MSI(i) [13:54:56.102] | MSI (c) (B0:9C) [13:54:56:075]: Dir (target): Key: payload.8.0.50727.104.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.104_x-ww_9a220e62\
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:075]: Dir (target): Key: payload.8.0.50727.103.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.103_x-ww_9a220e61\
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:075]: Dir (target): Key: payload.8.0.50727.101.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.101_x-ww_9a220e5f\
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:075]: Dir (target): Key: payload.8.0.50727.100.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.100_x-ww_9a220e5e\
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:075]: Dir (target): Key: payload.8.0.50727.99.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.99_x-ww_3fef51ef\
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:075]: Dir (target): Key: payload.8.0.50727.98.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.98_x-ww_3fef51ee\
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:075]: Dir (target): Key: payload.8.0.50727.97.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.97_x-ww_3fef51ed\
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:075]: Dir (target): Key: payload.8.0.50727.96.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.96_x-ww_3fef51ec\
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:075]: Dir (target): Key: payload.8.0.50727.94.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.94_x-ww_3fef51ea\
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:075]: Dir (target): Key: payload.8.0.50727.95.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.95_x-ww_3fef51eb\
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:075]: Dir (target): Key: payload.8.0.50727.93.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.93_x-ww_3fef51e9\
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:075]: Dir (target): Key: payload.8.0.50727.89.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.89_x-ww_3fee51b0\
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:075]: Dir (target): Key: policydir_ul.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4053_x-ww_18a05f69\
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:075]: Dir (target): Key: WinSxsManifests.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Manifests\
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:075]: Dir (target): Key: payload.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.42_x-ww_3fea50ad\
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:075]: Dir (target): Key: payload_ul.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\amd64_microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.4053_none_88e046c92fae6f57\
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:075]: Dir (target): Key: WinSxsPolicies.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:075]: Dir (target): Key: policydir.8.0.50727.4053.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_a3e7585a\
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:075]: Dir (target): Key: policydir.8.0.50727.4052.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_a3e7585a\
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:075]: Dir (target): Key: policydir.8.0.50727.4045.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_a3e7585a\
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:075]: Dir (target): Key: policydir.8.0.50727.4028.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_a3e7585a\
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:075]: Dir (target): Key: policydir.8.0.50727.4027.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_a3e7585a\
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:075]: Dir (target): Key: policydir.8.0.50727.1833.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_a3e7585a\
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:075]: Dir (target): Key: policydir.8.0.50727.4029.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_a3e7585a\
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:075]: Dir (target): Key: policydir.8.0.50727.3051.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_a3e7585a\
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:075]: Dir (target): Key: policydir.8.0.50727.3069.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_a3e7585a\
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:075]: Dir (target): Key: policydir.8.0.50727.3044.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_a3e7585a\
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:075]: Dir (target): Key: policydir.8.0.50727.193.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_a3e7585a\
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:075]: Dir (target): Key: policydir.8.0.50727.238.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_a3e7585a\
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:075]: Dir (target): Key: policydir.8.0.50727.104.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_a3e7585a\
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:075]: Dir (target): Key: policydir.8.0.50727.103.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_a3e7585a\
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:075]: Dir (target): Key: policydir.8.0.50727.100.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_a3e7585a\
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:075]: Dir (target): Key: policydir.8.0.50727.99.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_a3e7585a\
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:075]: Dir (target): Key: policydir.8.0.50727.101.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_a3e7585a\
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:075]: Dir (target): Key: policydir.8.0.50727.89.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_a3e7585a\
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:075]: Dir (target): Key: policydir.8.0.50727.98.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_a3e7585a\
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:075]: Dir (target): Key: policydir.8.0.50727.96.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_a3e7585a\
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:075]: Dir (target): Key: policydir.8.0.50727.97.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_a3e7585a\
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:075]: Dir (target): Key: policydir.8.0.50727.94.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_a3e7585a\
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:075]: Dir (target): Key: policydir.8.0.50727.95.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_a3e7585a\
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:075]: Dir (target): Key: policydir.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_a3e7585a\
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:075]: Dir (target): Key: policydir.8.0.50727.93.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E    , Object: C:\Windows\winsxs\Policies\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_a3e7585a\
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:075]: PROPERTY CHANGE: Adding INSTALLLEVEL property. Its value is '1'.
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:076]: skipping installation of assembly component: {1D6945E7-7EB3-31AA-9B66-AB012EDBB7D6} since the assembly already exists
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:076]: skipping installation of assembly component: {22D75DAD-658C-3109-91F7-4CB1A0729109} since the assembly already exists
MSI(i) [13:54:56.103] | Action ended 13:54:56: CostFinalize. Return value 1.
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:077]: Doing action: InstallValidate
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:077]: Note: 1: 2205 2:  3: ActionText
MSI(i) [13:54:56.103] | Action 13:54:56: InstallValidate. Validating install
MSI(i) [13:54:56.103] | Action start 13:54:56: InstallValidate.
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:078]: Feature: Core; Installed: Absent;   Request: Local;   Action: Local
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:078]: Feature: MS_Runtime_8_0; Installed: Absent;   Request: Local;   Action: Local
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:078]: Feature: MS_Runtime_9_0; Installed: Absent;   Request: Local;   Action: Local
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:078]: Feature: MS_Runtime_10_0; Installed: Absent;   Request: Local;   Action: Local
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:078]: Component: ProductFamilyAnchor; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: ProductVersionAnchor; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: RuntimeAnchor; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: uplevel.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: downlevel_payload.8.0.50727.4053.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: downlevel_manifest.8.0.50727.4053.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: downlevel_payload.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: downlevel_manifest.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: downlevel_manifest.8.0.50727.89.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: downlevel_manifest.8.0.50727.93.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: downlevel_manifest.8.0.50727.95.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: downlevel_payload.8.0.50727.89.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: downlevel_manifest.8.0.50727.94.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: downlevel_payload.8.0.50727.93.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: downlevel_payload.8.0.50727.95.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: downlevel_payload.8.0.50727.94.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: downlevel_manifest.8.0.50727.97.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: downlevel_manifest.8.0.50727.96.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: downlevel_manifest.8.0.50727.98.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: downlevel_payload.8.0.50727.96.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: downlevel_manifest.8.0.50727.99.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: downlevel_payload.8.0.50727.97.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: downlevel_manifest.8.0.50727.100.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: downlevel_payload.8.0.50727.98.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: downlevel_manifest.8.0.50727.101.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: downlevel_payload.8.0.50727.99.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: downlevel_manifest.8.0.50727.238.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: downlevel_manifest.8.0.50727.103.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: downlevel_payload.8.0.50727.100.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: downlevel_manifest.8.0.50727.104.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: downlevel_payload.8.0.50727.101.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: downlevel_payload.8.0.50727.103.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: downlevel_manifest.8.0.50727.193.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: downlevel_payload.8.0.50727.104.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: downlevel_payload.8.0.50727.238.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: downlevel_payload.8.0.50727.193.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: downlevel_manifest.8.0.50727.3044.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: downlevel_manifest.8.0.50727.3051.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: downlevel_manifest.8.0.50727.3069.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: downlevel_payload.8.0.50727.3044.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: downlevel_manifest.8.0.50727.1833.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: downlevel_payload.8.0.50727.3051.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: downlevel_manifest.8.0.50727.4027.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: downlevel_payload.8.0.50727.3069.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: downlevel_manifest.8.0.50727.4028.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: downlevel_payload.8.0.50727.1833.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: downlevel_manifest.8.0.50727.4029.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: downlevel_payload.8.0.50727.4027.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: downlevel_manifest.8.0.50727.4045.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: downlevel_payload.8.0.50727.4028.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: downlevel_manifest.8.0.50727.4052.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: downlevel_payload.8.0.50727.4029.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: downlevel_payload.8.0.50727.4045.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: downlevel_payload.8.0.50727.4052.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: uplevel.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: downlevel_manifest.8.0.50727.4053.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: downlevel_manifest.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: downlevel_manifest.8.0.50727.89.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: downlevel_manifest.8.0.50727.93.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: downlevel_manifest.8.0.50727.94.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: downlevel_manifest.8.0.50727.95.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: downlevel_manifest.8.0.50727.96.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: downlevel_manifest.8.0.50727.97.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: downlevel_manifest.8.0.50727.98.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: downlevel_manifest.8.0.50727.99.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: downlevel_manifest.8.0.50727.100.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: downlevel_manifest.8.0.50727.101.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: downlevel_manifest.8.0.50727.103.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: downlevel_manifest.8.0.50727.104.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: downlevel_manifest.8.0.50727.238.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: downlevel_manifest.8.0.50727.193.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: downlevel_manifest.8.0.50727.3044.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: downlevel_manifest.8.0.50727.3051.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: downlevel_manifest.8.0.50727.3069.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: downlevel_manifest.8.0.50727.1833.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: downlevel_manifest.8.0.50727.4027.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: downlevel_manifest.8.0.50727.4028.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: downlevel_manifest.8.0.50727.4029.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: downlevel_manifest.8.0.50727.4045.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: downlevel_manifest.8.0.50727.4052.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: uplevel.30729.6161.Microsoft_VC90_CRT_x64.QFE.D11988A5_400E_3D5F_834D_62102379E659; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: downlevel_payload.30729.6161.Microsoft_VC90_CRT_x64.QFE.D11988A5_400E_3D5F_834D_62102379E659; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: downlevel_manifest.30729.6161.Microsoft_VC90_CRT_x64.QFE.D11988A5_400E_3D5F_834D_62102379E659; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: uplevel.30729.6161.policy_9_0_Microsoft_VC90_CRT_x64.QFE.2B64E0BC_8AED_3A12_9FC4_E6C247309FFF; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: downlevel_manifest.30729.6161.policy_9_0_Microsoft_VC90_CRT_x64.QFE.2B64E0BC_8AED_3A12_9FC4_E6C247309FFF; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: C_CENTRAL_msvcr100_x64.1C11561A_11CB_36A7_8A47_D7A042055FA7; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: C_CENTRAL_msvcp100_x64.1C11561A_11CB_36A7_8A47_D7A042055FA7; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: __uplevel.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Local;   Client State: Null
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: __uplevel.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Local;   Client State: Null
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: __uplevel.30729.6161.Microsoft_VC90_CRT_x64.QFE.D11988A5_400E_3D5F_834D_62102379E65965; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: __uplevel.30729.6161.policy_9_0_Microsoft_VC90_CRT_x64.QFE.2B64E0BC_8AED_3A12_9FC4_E6C247309FFF65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: __downlevel_payload.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: __downlevel_manifest.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: __downlevel_manifest.8.0.50727.95.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: __downlevel_manifest.8.0.50727.89.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: __downlevel_manifest.8.0.50727.93.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: __downlevel_payload.8.0.50727.89.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: __downlevel_payload.8.0.50727.93.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: __downlevel_manifest.8.0.50727.94.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: __downlevel_payload.8.0.50727.95.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: __downlevel_payload.8.0.50727.94.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: __downlevel_manifest.8.0.50727.96.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: __downlevel_payload.8.0.50727.96.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: __downlevel_manifest.8.0.50727.97.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: __downlevel_payload.8.0.50727.97.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: __downlevel_manifest.8.0.50727.98.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: __downlevel_payload.8.0.50727.98.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: __downlevel_manifest.8.0.50727.99.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: __downlevel_payload.8.0.50727.99.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: __downlevel_manifest.8.0.50727.100.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: __downlevel_payload.8.0.50727.100.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: __downlevel_manifest.8.0.50727.101.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: __downlevel_payload.8.0.50727.101.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: __downlevel_manifest.8.0.50727.103.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: __downlevel_manifest.8.0.50727.238.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: __downlevel_payload.8.0.50727.103.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: __downlevel_manifest.8.0.50727.104.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:079]: Component: __downlevel_payload.8.0.50727.104.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:080]: Component: __downlevel_manifest.8.0.50727.193.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:080]: Component: __downlevel_payload.8.0.50727.193.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:080]: Component: __downlevel_payload.8.0.50727.238.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:080]: Component: __downlevel_manifest.8.0.50727.3044.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:080]: Component: __downlevel_payload.8.0.50727.3044.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:080]: Component: __downlevel_manifest.8.0.50727.3051.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:080]: Component: __downlevel_payload.8.0.50727.3051.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:080]: Component: __downlevel_manifest.8.0.50727.3069.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:080]: Component: __downlevel_payload.8.0.50727.3069.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:080]: Component: __downlevel_manifest.8.0.50727.1833.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:080]: Component: __downlevel_payload.8.0.50727.1833.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:080]: Component: __downlevel_manifest.8.0.50727.4027.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:080]: Component: __downlevel_payload.8.0.50727.4027.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:080]: Component: __downlevel_manifest.8.0.50727.4028.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:080]: Component: __downlevel_payload.8.0.50727.4028.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:080]: Component: __downlevel_manifest.8.0.50727.4029.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:080]: Component: __downlevel_payload.8.0.50727.4029.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:080]: Component: __downlevel_manifest.8.0.50727.4045.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:080]: Component: __downlevel_payload.8.0.50727.4045.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:080]: Component: __downlevel_manifest.8.0.50727.4052.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:080]: Component: __downlevel_payload.8.0.50727.4052.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:080]: Component: __downlevel_manifest.8.0.50727.4053.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:080]: Component: __downlevel_payload.8.0.50727.4053.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:080]: Component: __downlevel_manifest.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:080]: Component: __downlevel_manifest.8.0.50727.89.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:080]: Component: __downlevel_manifest.8.0.50727.94.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:56.103] | MSI (c) (B0:9C) [13:54:56:080]: Component: __downlevel_manifest.8.0.50727.93.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:56.104] | MSI (c) (B0:9C) [13:54:56:080]: Component: __downlevel_manifest.8.0.50727.95.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:56.104] | MSI (c) (B0:9C) [13:54:56:080]: Component: __downlevel_manifest.8.0.50727.96.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:56.104] | MSI (c) (B0:9C) [13:54:56:080]: Component: __downlevel_manifest.8.0.50727.97.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:56.104] | MSI (c) (B0:9C) [13:54:56:080]: Component: __downlevel_manifest.8.0.50727.98.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:56.104] | MSI (c) (B0:9C) [13:54:56:080]: Component: __downlevel_manifest.8.0.50727.99.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:56.104] | MSI (c) (B0:9C) [13:54:56:080]: Component: __downlevel_manifest.8.0.50727.100.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:56.104] | MSI (c) (B0:9C) [13:54:56:080]: Component: __downlevel_manifest.8.0.50727.101.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:56.104] | MSI (c) (B0:9C) [13:54:56:080]: Component: __downlevel_manifest.8.0.50727.103.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:56.104] | MSI (c) (B0:9C) [13:54:56:080]: Component: __downlevel_manifest.8.0.50727.238.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:56.104] | MSI (c) (B0:9C) [13:54:56:080]: Component: __downlevel_manifest.8.0.50727.104.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:56.104] | MSI (c) (B0:9C) [13:54:56:080]: Component: __downlevel_manifest.8.0.50727.193.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:56.104] | MSI (c) (B0:9C) [13:54:56:080]: Component: __downlevel_manifest.8.0.50727.3044.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:56.104] | MSI (c) (B0:9C) [13:54:56:080]: Component: __downlevel_manifest.8.0.50727.3051.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:56.104] | MSI (c) (B0:9C) [13:54:56:080]: Component: __downlevel_manifest.8.0.50727.3069.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:56.104] | MSI (c) (B0:9C) [13:54:56:080]: Component: __downlevel_manifest.8.0.50727.1833.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:56.104] | MSI (c) (B0:9C) [13:54:56:080]: Component: __downlevel_manifest.8.0.50727.4027.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:56.104] | MSI (c) (B0:9C) [13:54:56:080]: Component: __downlevel_manifest.8.0.50727.4028.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:56.104] | MSI (c) (B0:9C) [13:54:56:080]: Component: __downlevel_manifest.8.0.50727.4029.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:56.104] | MSI (c) (B0:9C) [13:54:56:080]: Component: __downlevel_manifest.8.0.50727.4045.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:56.104] | MSI (c) (B0:9C) [13:54:56:080]: Component: __downlevel_manifest.8.0.50727.4052.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:56.104] | MSI (c) (B0:9C) [13:54:56:080]: Component: __downlevel_manifest.8.0.50727.4053.4F6D20F0_CCE5_1492_FF1F_C8B3B9A1E18E65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:56.104] | MSI (c) (B0:9C) [13:54:56:080]: Component: __downlevel_payload.30729.6161.Microsoft_VC90_CRT_x64.QFE.D11988A5_400E_3D5F_834D_62102379E65965; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:56.104] | MSI (c) (B0:9C) [13:54:56:080]: Component: __downlevel_manifest.30729.6161.Microsoft_VC90_CRT_x64.QFE.D11988A5_400E_3D5F_834D_62102379E65965; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:56.104] | MSI (c) (B0:9C) [13:54:56:080]: Component: __downlevel_manifest.30729.6161.policy_9_0_Microsoft_VC90_CRT_x64.QFE.2B64E0BC_8AED_3A12_9FC4_E6C247309FFF65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:56.104] | MSI (c) (B0:9C) [13:54:56:080]: Note: 1: 2205 2:  3: BindImage
MSI(i) [13:54:56.104] | MSI (c) (B0:9C) [13:54:56:080]: Note: 1: 2205 2:  3: ProgId
MSI(i) [13:54:56.104] | MSI (c) (B0:9C) [13:54:56:080]: Note: 1: 2205 2:  3: PublishComponent
MSI(i) [13:54:56.104] | MSI (c) (B0:9C) [13:54:56:080]: Note: 1: 2205 2:  3: SelfReg
MSI(i) [13:54:56.104] | MSI (c) (B0:9C) [13:54:56:080]: Note: 1: 2205 2:  3: Extension
MSI(i) [13:54:56.104] | MSI (c) (B0:9C) [13:54:56:080]: Note: 1: 2205 2:  3: Font
MSI(i) [13:54:56.104] | MSI (c) (B0:9C) [13:54:56:080]: Note: 1: 2205 2:  3: Shortcut
MSI(i) [13:54:56.104] | MSI (c) (B0:9C) [13:54:56:080]: Note: 1: 2205 2:  3: Class
MSI(i) [13:54:56.104] | MSI (c) (B0:9C) [13:54:56:080]: Note: 1: 2205 2:  3: Icon
MSI(i) [13:54:56.104] | MSI (c) (B0:9C) [13:54:56:080]: Note: 1: 2205 2:  3: TypeLib
MSI(i) [13:54:56.104] | MSI (c) (B0:9C) [13:54:56:081]: Note: 1: 2205 2:  3: _RemoveFilePath
MSI(i) [13:54:56.104] | MSI (c) (B0:9C) [13:54:56:082]: PROPERTY CHANGE: Modifying CostingComplete property. Its current value is '0'. Its new value: '1'.
MSI(i) [13:54:56.104] | MSI (c) (B0:9C) [13:54:56:082]: Note: 1: 2205 2:  3: BindImage
MSI(i) [13:54:56.104] | MSI (c) (B0:9C) [13:54:56:082]: Note: 1: 2205 2:  3: ProgId
MSI(i) [13:54:56.104] | MSI (c) (B0:9C) [13:54:56:082]: Note: 1: 2205 2:  3: PublishComponent
MSI(i) [13:54:56.104] | MSI (c) (B0:9C) [13:54:56:082]: Note: 1: 2205 2:  3: SelfReg
MSI(i) [13:54:56.104] | MSI (c) (B0:9C) [13:54:56:082]: Note: 1: 2205 2:  3: Extension
MSI(i) [13:54:56.104] | MSI (c) (B0:9C) [13:54:56:082]: Note: 1: 2205 2:  3: Font
MSI(i) [13:54:56.104] | MSI (c) (B0:9C) [13:54:56:082]: Note: 1: 2205 2:  3: Shortcut
MSI(i) [13:54:56.104] | MSI (c) (B0:9C) [13:54:56:082]: Note: 1: 2205 2:  3: Class
MSI(i) [13:54:56.104] | MSI (c) (B0:9C) [13:54:56:082]: Note: 1: 2205 2:  3: Icon
MSI(i) [13:54:56.104] | MSI (c) (B0:9C) [13:54:56:082]: Note: 1: 2205 2:  3: TypeLib
MSI(i) [13:54:56.104] | MSI (c) (B0:9C) [13:54:56:083]: Note: 1: 2727 2:
MSI(i) [13:54:56.104] | MSI (c) (B0:9C) [13:54:56:097]: Note: 1: 2727 2:
MSI(i) [13:54:56.104] | Action ended 13:54:56: InstallValidate. Return value 1.
MSI(i) [13:54:56.104] | MSI (c) (B0:9C) [13:54:56:098]: Creating MSIHANDLE (94) of type 790541 for thread 3996
MSI(i) [13:54:56.104] | MSI (c) (B0:9C) [13:54:56:098]: Creating MSIHANDLE (95) of type 790540 for thread 3996
MSI(i) [13:54:56.104] | MSI (c) (B0:9C) [13:54:56:098]: Creating MSIHANDLE (96) of type 790531 for thread 3996
MSI(i) [13:54:56.104] | MSI (c) (B0:9C) [13:54:56:098]: Note: 1: 2205 2:  3: Condition
MSI(i) [13:54:56.104] | MSI (c) (B0:9C) [13:54:56:098]: Note: 1: 2228 2:  3: Condition 4: SELECT * FROM Condition WHERE Feature_ = 'Core'
MSI(i) [13:54:56.104] | MSI (c) (B0:9C) [13:54:56:098]: Creating MSIHANDLE (97) of type 790540 for thread 3996
MSI(i) [13:54:56.104] | MSI (c) (B0:9C) [13:54:56:098]: Closing MSIHANDLE (97) of type 790540 for thread 3996
MSI(i) [13:54:56.104] | MSI (c) (B0:9C) [13:54:56:098]: Closing MSIHANDLE (96) of type 790531 for thread 3996
MSI(i) [13:54:56.104] | MSI (c) (B0:9C) [13:54:56:098]: Creating MSIHANDLE (98) of type 790531 for thread 3996
MSI(i) [13:54:56.104] | MSI (c) (B0:9C) [13:54:56:098]: Note: 1: 2228 2:  3: Condition 4: SELECT * FROM Condition WHERE Feature_ = 'MS_Runtime_8_0'
MSI(i) [13:54:56.104] | MSI (c) (B0:9C) [13:54:56:098]: Creating MSIHANDLE (99) of type 790540 for thread 3996
MSI(i) [13:54:56.104] | MSI (c) (B0:9C) [13:54:56:098]: Closing MSIHANDLE (99) of type 790540 for thread 3996
MSI(i) [13:54:56.104] | MSI (c) (B0:9C) [13:54:56:098]: Closing MSIHANDLE (98) of type 790531 for thread 3996
MSI(i) [13:54:56.104] | MSI (c) (B0:9C) [13:54:56:098]: Creating MSIHANDLE (100) of type 790531 for thread 3996
MSI(i) [13:54:56.104] | MSI (c) (B0:9C) [13:54:56:098]: Note: 1: 2228 2:  3: Condition 4: SELECT * FROM Condition WHERE Feature_ = 'MS_Runtime_9_0'
MSI(i) [13:54:56.104] | MSI (c) (B0:9C) [13:54:56:098]: Creating MSIHANDLE (101) of type 790540 for thread 3996
MSI(i) [13:54:56.104] | MSI (c) (B0:9C) [13:54:56:098]: Closing MSIHANDLE (101) of type 790540 for thread 3996
MSI(i) [13:54:56.104] | MSI (c) (B0:9C) [13:54:56:098]: Closing MSIHANDLE (100) of type 790531 for thread 3996
MSI(i) [13:54:56.104] | MSI (c) (B0:9C) [13:54:56:098]: Creating MSIHANDLE (102) of type 790531 for thread 3996
MSI(i) [13:54:56.104] | MSI (c) (B0:9C) [13:54:56:098]: Note: 1: 2228 2:  3: Condition 4: SELECT * FROM Condition WHERE Feature_ = 'MS_Runtime_10_0'
MSI(i) [13:54:56.104] | MSI (c) (B0:9C) [13:54:56:098]: Creating MSIHANDLE (103) of type 790540 for thread 3996
MSI(i) [13:54:56.104] | MSI (c) (B0:9C) [13:54:56:098]: Closing MSIHANDLE (103) of type 790540 for thread 3996
MSI(i) [13:54:56.104] | MSI (c) (B0:9C) [13:54:56:098]: Closing MSIHANDLE (102) of type 790531 for thread 3996
MSI(i) [13:54:56.104] | MSI (c) (B0:9C) [13:54:56:098]: Closing MSIHANDLE (95) of type 790540 for thread 3996
MSI(i) [13:54:56.104] | MSI (c) (B0:9C) [13:54:56:098]: Closing MSIHANDLE (94) of type 790541 for thread 3996
MSI(i) [13:54:56.104] | MSI (c) (B0:9C) [13:54:56:098]: Leaked MSIHANDLE (92) of type 790537 for thread 3996
MSI(i) [13:54:56.104] | === Verbose logging stopped: 4/8/2014  13:54:56 ===
PSET(i) [13:54:56.109] | (4225.1904): Dependency {ACD97E2A-090D-46ea-9983-6E44BCA28575} always show dialog
PSET(i) [13:54:56.110] | (4225.2963): MsiOpenPackageEx(C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\ism\ism.msi)
MSI(i) [13:54:56.165] | === Verbose logging started: 4/8/2014  13:54:56  Build type: SHIP UNICODE 5.00.7601.00  Calling process: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\setup.exe ===
MSI(i) [13:54:56.165] | MSI (c) (B0:9C) [13:54:56:111]: SOFTWARE RESTRICTION POLICY: Verifying package --> 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\ism\ism.msi' against software restriction policy
MSI(i) [13:54:56.165] | MSI (c) (B0:9C) [13:54:56:111]: SOFTWARE RESTRICTION POLICY: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\ism\ism.msi has a digital signature
MSI(i) [13:54:56.165] | MSI (c) (B0:9C) [13:54:56:147]: SOFTWARE RESTRICTION POLICY: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\ism\ism.msi is permitted to run at the 'unrestricted' authorization level.
MSI(i) [13:54:56.165] | MSI (c) (B0:9C) [13:54:56:148]: Cloaking enabled.
MSI(i) [13:54:56.165] | MSI (c) (B0:9C) [13:54:56:148]: Attempting to enable all disabled privileges before calling Install on Server
MSI(i) [13:54:56.165] | MSI (c) (B0:9C) [13:54:56:148]: End dialog not enabled
MSI(i) [13:54:56.165] | MSI (c) (B0:9C) [13:54:56:149]: Original package ==> C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\ism\ism.msi
MSI(i) [13:54:56.165] | MSI (c) (B0:9C) [13:54:56:149]: Package we're running from ==> C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\ism\ism.msi
MSI(i) [13:54:56.165] | MSI (c) (B0:9C) [13:54:56:152]: APPCOMPAT: Compatibility mode property overrides found.
MSI(i) [13:54:56.165] | MSI (c) (B0:9C) [13:54:56:152]: APPCOMPAT: looking for appcompat database entry with ProductCode '{6FA7345E-370F-42E7-8F48-825476CA34D1}'.
MSI(i) [13:54:56.165] | MSI (c) (B0:9C) [13:54:56:152]: APPCOMPAT: no matching ProductCode found in database.
MSI(i) [13:54:56.165] | MSI (c) (B0:9C) [13:54:56:154]: MSCOREE not loaded loading copy from system32
MSI(i) [13:54:56.165] | MSI (c) (B0:9C) [13:54:56:158]: Machine policy value 'TransformsSecure' is 0
MSI(i) [13:54:56.165] | MSI (c) (B0:9C) [13:54:56:158]: User policy value 'TransformsAtSource' is 0
MSI(i) [13:54:56.165] | MSI (c) (B0:9C) [13:54:56:158]: Machine policy value 'DisablePatch' is 0
MSI(i) [13:54:56.165] | MSI (c) (B0:9C) [13:54:56:158]: Machine policy value 'AllowLockdownPatch' is 0
MSI(i) [13:54:56.165] | MSI (c) (B0:9C) [13:54:56:158]: Machine policy value 'DisableLUAPatching' is 0
MSI(i) [13:54:56.165] | MSI (c) (B0:9C) [13:54:56:158]: Machine policy value 'DisableFlyWeightPatching' is 0
MSI(i) [13:54:56.165] | MSI (c) (B0:9C) [13:54:56:158]: Enabling baseline caching for this transaction since all active patches are MSI 3.0 style MSPs or at least one MSI 3.0 minor update patch is active
MSI(i) [13:54:56.165] | MSI (c) (B0:9C) [13:54:56:158]: APPCOMPAT: looking for appcompat database entry with ProductCode '{6FA7345E-370F-42E7-8F48-825476CA34D1}'.
MSI(i) [13:54:56.165] | MSI (c) (B0:9C) [13:54:56:158]: APPCOMPAT: no matching ProductCode found in database.
MSI(i) [13:54:56.165] | MSI (c) (B0:9C) [13:54:56:159]: Transforms are not secure.
MSI(i) [13:54:56.165] | MSI (c) (B0:9C) [13:54:56:159]: PROPERTY CHANGE: Adding MsiLogFileLocation property. Its value is 'C:\Users\PCCA-PM\AppData\Local\Temp\MSIED31.tmp'.
MSI(i) [13:54:56.165] | MSI (c) (B0:9C) [13:54:56:159]: No Command Line.
MSI(i) [13:54:56.165] | MSI (c) (B0:9C) [13:54:56:159]: PROPERTY CHANGE: Adding PackageCode property. Its value is '{7D4891AC-125C-4FA5-A8AC-6077DBDB1809}'.
MSI(i) [13:54:56.165] | MSI (c) (B0:9C) [13:54:56:159]: Product Code passed to Engine.Initialize:           '(none)'
MSI(i) [13:54:56.165] | MSI (c) (B0:9C) [13:54:56:159]: Product Code from property table before transforms: '{6FA7345E-370F-42E7-8F48-825476CA34D1}'
MSI(i) [13:54:56.165] | MSI (c) (B0:9C) [13:54:56:159]: Product Code from property table after transforms:  '{6FA7345E-370F-42E7-8F48-825476CA34D1}'
MSI(i) [13:54:56.165] | MSI (c) (B0:9C) [13:54:56:159]: Product not registered: beginning first-time install
MSI(i) [13:54:56.165] | MSI (c) (B0:9C) [13:54:56:159]: PROPERTY CHANGE: Adding ProductState property. Its value is '-1'.
MSI(i) [13:54:56.165] | MSI (c) (B0:9C) [13:54:56:159]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer 3: 2
MSI(i) [13:54:56.165] | MSI (c) (B0:9C) [13:54:56:159]: Entering CMsiConfigurationManager::SetLastUsedSource.
MSI(i) [13:54:56.165] | MSI (c) (B0:9C) [13:54:56:159]: User policy value 'SearchOrder' is 'nmu'
MSI(i) [13:54:56.165] | MSI (c) (B0:9C) [13:54:56:159]: Adding new sources is allowed.
MSI(i) [13:54:56.165] | MSI (c) (B0:9C) [13:54:56:159]: PROPERTY CHANGE: Adding PackagecodeChanging property. Its value is '1'.
MSI(i) [13:54:56.165] | MSI (c) (B0:9C) [13:54:56:159]: Package name extracted from package path: 'ism.msi'
MSI(i) [13:54:56.165] | MSI (c) (B0:9C) [13:54:56:159]: Package to be registered: 'ism.msi'
MSI(i) [13:54:56.165] | MSI (c) (B0:9C) [13:54:56:159]: Note: 1: 2205 2:  3: Error
MSI(i) [13:54:56.165] | MSI (c) (B0:9C) [13:54:56:160]: Note: 1: 2262 2: AdminProperties 3: -2147287038
MSI(i) [13:54:56.165] | MSI (c) (B0:9C) [13:54:56:160]: Machine policy value 'DisableMsi' is 0
MSI(i) [13:54:56.165] | MSI (c) (B0:9C) [13:54:56:160]: Machine policy value 'AlwaysInstallElevated' is 0
MSI(i) [13:54:56.165] | MSI (c) (B0:9C) [13:54:56:160]: User policy value 'AlwaysInstallElevated' is 0
MSI(i) [13:54:56.165] | MSI (c) (B0:9C) [13:54:56:160]: Product installation will be elevated because user is admin and product is being installed per-machine.
MSI(i) [13:54:56.165] | MSI (c) (B0:9C) [13:54:56:160]: Running product '{6FA7345E-370F-42E7-8F48-825476CA34D1}' with elevated privileges: Product is assigned.
MSI(i) [13:54:56.165] | MSI (c) (B0:9C) [13:54:56:160]: PROPERTY CHANGE: Adding MsiSystemRebootPending property. Its value is '1'.
MSI(i) [13:54:56.165] | MSI (c) (B0:9C) [13:54:56:160]: TRANSFORMS property is now:
MSI(i) [13:54:56.165] | MSI (c) (B0:9C) [13:54:56:160]: PROPERTY CHANGE: Adding VersionDatabase property. Its value is '200'.
MSI(i) [13:54:56.165] | MSI (c) (B0:9C) [13:54:56:160]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming
MSI(i) [13:54:56.165] | MSI (c) (B0:9C) [13:54:56:160]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Favorites
MSI(i) [13:54:56.165] | MSI (c) (B0:9C) [13:54:56:160]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Network Shortcuts
MSI(i) [13:54:56.165] | MSI (c) (B0:9C) [13:54:56:160]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Documents
MSI(i) [13:54:56.165] | MSI (c) (B0:9C) [13:54:56:160]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
MSI(i) [13:54:56.165] | MSI (c) (B0:9C) [13:54:56:160]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Recent
MSI(i) [13:54:56.165] | MSI (c) (B0:9C) [13:54:56:160]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\SendTo
MSI(i) [13:54:56.165] | MSI (c) (B0:9C) [13:54:56:160]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Templates
MSI(i) [13:54:56.165] | MSI (c) (B0:9C) [13:54:56:160]: SHELL32::SHGetFolderPath returned: C:\ProgramData
MSI(i) [13:54:56.165] | MSI (c) (B0:9C) [13:54:56:160]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Local
MSI(i) [13:54:56.165] | MSI (c) (B0:9C) [13:54:56:160]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Pictures
MSI(i) [13:54:56.165] | MSI (c) (B0:9C) [13:54:56:161]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI(i) [13:54:56.165] | MSI (c) (B0:9C) [13:54:56:161]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
MSI(i) [13:54:56.165] | MSI (c) (B0:9C) [13:54:56:161]: SHELL32::SHGetFolderPath returned: C:\Users\Public\Desktop
MSI(i) [13:54:56.165] | MSI (c) (B0:9C) [13:54:56:161]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI(i) [13:54:56.165] | MSI (c) (B0:9C) [13:54:56:161]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
MSI(i) [13:54:56.165] | MSI (c) (B0:9C) [13:54:56:161]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Desktop
MSI(i) [13:54:56.165] | MSI (c) (B0:9C) [13:54:56:161]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Templates
MSI(i) [13:54:56.165] | MSI (c) (B0:9C) [13:54:56:161]: SHELL32::SHGetFolderPath returned: C:\Windows\Fonts
MSI(i) [13:54:56.165] | MSI (c) (B0:9C) [13:54:56:161]: Note: 1: 2898 2: MS Sans Serif 3: MS Sans Serif 4: 0 5: 16
MSI(i) [13:54:56.165] | MSI (c) (B0:9C) [13:54:56:163]: MSI_LUA: Setting AdminUser property to 1 because this is the client or the user has already permitted elevation
MSI(i) [13:54:56.165] | MSI (c) (B0:9C) [13:54:56:163]: MSI_LUA: Setting MsiRunningElevated property to 1 because the install is already running elevated.
MSI(i) [13:54:56.165] | MSI (c) (B0:9C) [13:54:56:163]: PROPERTY CHANGE: Adding MsiRunningElevated property. Its value is '1'.
MSI(i) [13:54:56.165] | MSI (c) (B0:9C) [13:54:56:163]: PROPERTY CHANGE: Adding Privileged property. Its value is '1'.
MSI(i) [13:54:56.165] | MSI (c) (B0:9C) [13:54:56:164]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\MS Setup (ACME)\User Info 3: 2
MSI(i) [13:54:56.165] | MSI (c) (B0:9C) [13:54:56:164]: PROPERTY CHANGE: Adding USERNAME property. Its value is 'A Valued IT Customer'.
MSI(i) [13:54:56.165] | MSI (c) (B0:9C) [13:54:56:164]: PROPERTY CHANGE: Adding COMPANYNAME property. Its value is 'Intel Corporation'.
MSI(i) [13:54:56.165] | MSI (c) (B0:9C) [13:54:56:164]: PROPERTY CHANGE: Adding DATABASE property. Its value is 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\ism\ism.msi'.
MSI(i) [13:54:56.165] | MSI (c) (B0:9C) [13:54:56:164]: PROPERTY CHANGE: Adding OriginalDatabase property. Its value is 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\ism\ism.msi'.
MSI(i) [13:54:56.165] | MSI (c) (B0:9C) [13:54:56:164]: Machine policy value 'MsiDisableEmbeddedUI' is 0
MSI(i) [13:54:56.165] | MSI (c) (B0:9C) [13:54:56:164]: EEUI - Disabling MsiEmbeddedUI in quiet mode
MSI(i) [13:54:56.165] | === Logging started: 4/8/2014  13:54:56 ===
MSI(i) [13:54:56.165] | MSI (c) (B0:9C) [13:54:56:164]: Note: 1: 2205 2:  3: PatchPackage
MSI(i) [13:54:56.165] | MSI (c) (B0:9C) [13:54:56:164]: Machine policy value 'DisableRollback' is 0
MSI(i) [13:54:56.165] | MSI (c) (B0:9C) [13:54:56:164]: User policy value 'DisableRollback' is 0
MSI(i) [13:54:56.165] | MSI (c) (B0:9C) [13:54:56:164]: PROPERTY CHANGE: Adding UILevel property. Its value is '2'.
MSI(i) [13:54:56.165] | MSI (c) (B0:9C) [13:54:56:164]: Creating MSIHANDLE (104) of type 790537 for thread 3996
MSI(i) [13:54:56.165] | MSI (c) (B0:9C) [13:54:56:164]: MsiOpenPackageEx is returning 0
MSI(i) [13:54:56.165] | MSI (c) (B0:9C) [13:54:56:164]: Closing MSIHANDLE (104) of type 790537 for thread 3996
MSI(i) [13:54:56.165] | === Verbose logging stopped: 4/8/2014  13:54:56 ===
PSET(i) [13:54:56.173] | (4225.285): MsiOpenPackageEx(C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\ism\ism.msi)
MSI(i) [13:54:56.272] | === Verbose logging started: 4/8/2014  13:54:56  Build type: SHIP UNICODE 5.00.7601.00  Calling process: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\setup.exe ===
MSI(i) [13:54:56.272] | MSI (c) (B0:9C) [13:54:56:175]: SOFTWARE RESTRICTION POLICY: Verifying package --> 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\ism\ism.msi' against software restriction policy
MSI(i) [13:54:56.272] | MSI (c) (B0:9C) [13:54:56:175]: SOFTWARE RESTRICTION POLICY: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\ism\ism.msi has a digital signature
MSI(i) [13:54:56.272] | MSI (c) (B0:9C) [13:54:56:210]: SOFTWARE RESTRICTION POLICY: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\ism\ism.msi is permitted to run at the 'unrestricted' authorization level.
MSI(i) [13:54:56.272] | MSI (c) (B0:9C) [13:54:56:211]: Cloaking enabled.
MSI(i) [13:54:56.272] | MSI (c) (B0:9C) [13:54:56:211]: Attempting to enable all disabled privileges before calling Install on Server
MSI(i) [13:54:56.272] | MSI (c) (B0:9C) [13:54:56:211]: End dialog not enabled
MSI(i) [13:54:56.272] | MSI (c) (B0:9C) [13:54:56:212]: Original package ==> C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\ism\ism.msi
MSI(i) [13:54:56.272] | MSI (c) (B0:9C) [13:54:56:212]: Package we're running from ==> C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\ism\ism.msi
MSI(i) [13:54:56.272] | MSI (c) (B0:9C) [13:54:56:214]: Machine policy value 'DisableUserInstalls' is 0
MSI(i) [13:54:56.272] | MSI (c) (B0:9C) [13:54:56:215]: APPCOMPAT: Compatibility mode property overrides found.
MSI(i) [13:54:56.272] | MSI (c) (B0:9C) [13:54:56:215]: APPCOMPAT: looking for appcompat database entry with ProductCode '{6FA7345E-370F-42E7-8F48-825476CA34D1}'.
MSI(i) [13:54:56.272] | MSI (c) (B0:9C) [13:54:56:215]: APPCOMPAT: no matching ProductCode found in database.
MSI(i) [13:54:56.272] | MSI (c) (B0:9C) [13:54:56:217]: MSCOREE not loaded loading copy from system32
MSI(i) [13:54:56.272] | MSI (c) (B0:9C) [13:54:56:220]: Machine policy value 'TransformsSecure' is 0
MSI(i) [13:54:56.272] | MSI (c) (B0:9C) [13:54:56:220]: User policy value 'TransformsAtSource' is 0
MSI(i) [13:54:56.272] | MSI (c) (B0:9C) [13:54:56:221]: Machine policy value 'DisablePatch' is 0
MSI(i) [13:54:56.272] | MSI (c) (B0:9C) [13:54:56:221]: Machine policy value 'AllowLockdownPatch' is 0
MSI(i) [13:54:56.272] | MSI (c) (B0:9C) [13:54:56:221]: Machine policy value 'DisableLUAPatching' is 0
MSI(i) [13:54:56.272] | MSI (c) (B0:9C) [13:54:56:221]: Machine policy value 'DisableFlyWeightPatching' is 0
MSI(i) [13:54:56.272] | MSI (c) (B0:9C) [13:54:56:221]: Enabling baseline caching for this transaction since all active patches are MSI 3.0 style MSPs or at least one MSI 3.0 minor update patch is active
MSI(i) [13:54:56.272] | MSI (c) (B0:9C) [13:54:56:221]: APPCOMPAT: looking for appcompat database entry with ProductCode '{6FA7345E-370F-42E7-8F48-825476CA34D1}'.
MSI(i) [13:54:56.272] | MSI (c) (B0:9C) [13:54:56:221]: APPCOMPAT: no matching ProductCode found in database.
MSI(i) [13:54:56.272] | MSI (c) (B0:9C) [13:54:56:221]: Transforms are not secure.
MSI(i) [13:54:56.272] | MSI (c) (B0:9C) [13:54:56:221]: PROPERTY CHANGE: Adding MsiLogFileLocation property. Its value is 'C:\Users\PCCA-PM\AppData\Local\Temp\MSIED31.tmp'.
MSI(i) [13:54:56.272] | MSI (c) (B0:9C) [13:54:56:221]: No Command Line.
MSI(i) [13:54:56.272] | MSI (c) (B0:9C) [13:54:56:221]: PROPERTY CHANGE: Adding PackageCode property. Its value is '{7D4891AC-125C-4FA5-A8AC-6077DBDB1809}'.
MSI(i) [13:54:56.272] | MSI (c) (B0:9C) [13:54:56:221]: Product Code passed to Engine.Initialize:           '(none)'
MSI(i) [13:54:56.272] | MSI (c) (B0:9C) [13:54:56:221]: Product Code from property table before transforms: '{6FA7345E-370F-42E7-8F48-825476CA34D1}'
MSI(i) [13:54:56.272] | MSI (c) (B0:9C) [13:54:56:221]: Product Code from property table after transforms:  '{6FA7345E-370F-42E7-8F48-825476CA34D1}'
MSI(i) [13:54:56.272] | MSI (c) (B0:9C) [13:54:56:221]: Product not registered: beginning first-time install
MSI(i) [13:54:56.272] | MSI (c) (B0:9C) [13:54:56:221]: PROPERTY CHANGE: Adding ProductState property. Its value is '-1'.
MSI(i) [13:54:56.272] | MSI (c) (B0:9C) [13:54:56:222]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer 3: 2
MSI(i) [13:54:56.272] | MSI (c) (B0:9C) [13:54:56:222]: Entering CMsiConfigurationManager::SetLastUsedSource.
MSI(i) [13:54:56.272] | MSI (c) (B0:9C) [13:54:56:222]: User policy value 'SearchOrder' is 'nmu'
MSI(i) [13:54:56.272] | MSI (c) (B0:9C) [13:54:56:222]: Adding new sources is allowed.
MSI(i) [13:54:56.272] | MSI (c) (B0:9C) [13:54:56:222]: PROPERTY CHANGE: Adding PackagecodeChanging property. Its value is '1'.
MSI(i) [13:54:56.272] | MSI (c) (B0:9C) [13:54:56:222]: Package name extracted from package path: 'ism.msi'
MSI(i) [13:54:56.272] | MSI (c) (B0:9C) [13:54:56:222]: Package to be registered: 'ism.msi'
MSI(i) [13:54:56.272] | MSI (c) (B0:9C) [13:54:56:222]: Note: 1: 2205 2:  3: Error
MSI(i) [13:54:56.272] | MSI (c) (B0:9C) [13:54:56:222]: Note: 1: 2262 2: AdminProperties 3: -2147287038
MSI(i) [13:54:56.272] | MSI (c) (B0:9C) [13:54:56:222]: Machine policy value 'DisableMsi' is 0
MSI(i) [13:54:56.272] | MSI (c) (B0:9C) [13:54:56:222]: Machine policy value 'AlwaysInstallElevated' is 0
MSI(i) [13:54:56.272] | MSI (c) (B0:9C) [13:54:56:223]: User policy value 'AlwaysInstallElevated' is 0
MSI(i) [13:54:56.272] | MSI (c) (B0:9C) [13:54:56:223]: Product installation will be elevated because user is admin and product is being installed per-machine.
MSI(i) [13:54:56.272] | MSI (c) (B0:9C) [13:54:56:223]: Running product '{6FA7345E-370F-42E7-8F48-825476CA34D1}' with elevated privileges: Product is assigned.
MSI(i) [13:54:56.272] | MSI (c) (B0:9C) [13:54:56:223]: PROPERTY CHANGE: Adding MsiSystemRebootPending property. Its value is '1'.
MSI(i) [13:54:56.272] | MSI (c) (B0:9C) [13:54:56:223]: TRANSFORMS property is now:
MSI(i) [13:54:56.272] | MSI (c) (B0:9C) [13:54:56:223]: PROPERTY CHANGE: Adding VersionDatabase property. Its value is '200'.
MSI(i) [13:54:56.272] | MSI (c) (B0:9C) [13:54:56:223]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming
MSI(i) [13:54:56.272] | MSI (c) (B0:9C) [13:54:56:223]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Favorites
MSI(i) [13:54:56.272] | MSI (c) (B0:9C) [13:54:56:223]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Network Shortcuts
MSI(i) [13:54:56.272] | MSI (c) (B0:9C) [13:54:56:223]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Documents
MSI(i) [13:54:56.272] | MSI (c) (B0:9C) [13:54:56:223]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
MSI(i) [13:54:56.272] | MSI (c) (B0:9C) [13:54:56:223]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Recent
MSI(i) [13:54:56.272] | MSI (c) (B0:9C) [13:54:56:223]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\SendTo
MSI(i) [13:54:56.272] | MSI (c) (B0:9C) [13:54:56:223]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Templates
MSI(i) [13:54:56.272] | MSI (c) (B0:9C) [13:54:56:223]: SHELL32::SHGetFolderPath returned: C:\ProgramData
MSI(i) [13:54:56.272] | MSI (c) (B0:9C) [13:54:56:223]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Local
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:223]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Pictures
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:223]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:223]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:223]: SHELL32::SHGetFolderPath returned: C:\Users\Public\Desktop
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:223]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:223]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:223]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Desktop
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:223]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Templates
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:224]: SHELL32::SHGetFolderPath returned: C:\Windows\Fonts
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:224]: Note: 1: 2898 2: MS Sans Serif 3: MS Sans Serif 4: 0 5: 16
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:226]: MSI_LUA: Setting AdminUser property to 1 because this is the client or the user has already permitted elevation
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:226]: MSI_LUA: Setting MsiRunningElevated property to 1 because the install is already running elevated.
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:226]: PROPERTY CHANGE: Adding MsiRunningElevated property. Its value is '1'.
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:226]: PROPERTY CHANGE: Adding Privileged property. Its value is '1'.
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:226]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\MS Setup (ACME)\User Info 3: 2
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:226]: PROPERTY CHANGE: Adding USERNAME property. Its value is 'A Valued IT Customer'.
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:226]: PROPERTY CHANGE: Adding COMPANYNAME property. Its value is 'Intel Corporation'.
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:226]: PROPERTY CHANGE: Adding DATABASE property. Its value is 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\ism\ism.msi'.
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:226]: PROPERTY CHANGE: Adding OriginalDatabase property. Its value is 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\ism\ism.msi'.
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:226]: Machine policy value 'MsiDisableEmbeddedUI' is 0
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:227]: EEUI - Disabling MsiEmbeddedUI in quiet mode
MSI(i) [13:54:56.273] | === Logging started: 4/8/2014  13:54:56 ===
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:227]: Note: 1: 2205 2:  3: PatchPackage
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:227]: Machine policy value 'DisableRollback' is 0
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:227]: User policy value 'DisableRollback' is 0
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:227]: PROPERTY CHANGE: Adding UILevel property. Its value is '2'.
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:227]: Creating MSIHANDLE (105) of type 790537 for thread 3996
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:227]: MsiOpenPackageEx is returning 0
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:227]: Creating MSIHANDLE (106) of type 790541 for thread 3996
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:227]: Closing MSIHANDLE (106) of type 790541 for thread 3996
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:227]: Doing action: AppSearch
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:227]: Note: 1: 2205 2:  3: ActionText
MSI(i) [13:54:56.273] | Action 13:54:56: AppSearch. Searching for installed applications
MSI(i) [13:54:56.273] | Action start 13:54:56: AppSearch.
MSI(i) [13:54:56.273] | AppSearch: Property: IE5FOUND.9FC896E6_8DD6_4BFD_A02C_189B1B87F512, Signature: sigShdocvw.9FC896E6_8DD6_4BFD_A02C_189B1B87F512
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:233]: PROPERTY CHANGE: Adding IE5FOUND.9FC896E6_8DD6_4BFD_A02C_189B1B87F512 property. Its value is 'C:\Windows\SysWOW64\shdocvw.dll'.
MSI(i) [13:54:56.273] | AppSearch: Property: IE5FOUND.C4D4FE07_FC74_47DD_9A30_533F27F843F1, Signature: sigShdocvw.C4D4FE07_FC74_47DD_9A30_533F27F843F1
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:238]: PROPERTY CHANGE: Adding IE5FOUND.C4D4FE07_FC74_47DD_9A30_533F27F843F1 property. Its value is 'C:\Windows\SysWOW64\shdocvw.dll'.
MSI(i) [13:54:56.273] | Action ended 13:54:56: AppSearch. Return value 1.
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:238]: Doing action: CostInitialize
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:238]: Note: 1: 2205 2:  3: ActionText
MSI(i) [13:54:56.273] | Action 13:54:56: CostInitialize. Computing space requirements
MSI(i) [13:54:56.273] | Action start 13:54:56: CostInitialize.
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:239]: Machine policy value 'MaxPatchCacheSize' is 10
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:239]: Baseline: Sorting baselines for {6FA7345E-370F-42E7-8F48-825476CA34D1}.
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:239]: Baseline: New baseline 1.0.35 from transaction.
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:239]: Baseline: Sorted order Native: Order 0.
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:239]: Baseline Data Table:
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:239]: ProductCode: {6FA7345E-370F-42E7-8F48-825476CA34D1} Version: 1.0.35 Attributes: 0 PatchId: Native BaselineId: -2147483648 Order: 0
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:239]: Baseline File Table:
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:240]: PROPERTY CHANGE: Adding ROOTDRIVE property. Its value is 'C:\'.
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:240]: PROPERTY CHANGE: Adding CostingComplete property. Its value is '0'.
MSI(i) [13:54:56.273] | Action ended 13:54:56: CostInitialize. Return value 1.
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:240]: Doing action: FileCost
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:240]: Note: 1: 2205 2:  3: ActionText
MSI(i) [13:54:56.273] | Action 13:54:56: FileCost. Computing space requirements
MSI(i) [13:54:56.273] | Action start 13:54:56: FileCost.
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:242]: Note: 1: 2205 2:  3: MsiAssembly
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:243]: Note: 1: 2262 2: Class 3: -2147287038
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:243]: Note: 1: 2262 2: Extension 3: -2147287038
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:243]: Note: 1: 2205 2:  3: TypeLib
MSI(i) [13:54:56.273] | Action ended 13:54:56: FileCost. Return value 1.
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:243]: Doing action: CostFinalize
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:243]: Note: 1: 2205 2:  3: ActionText
MSI(i) [13:54:56.273] | Action 13:54:56: CostFinalize. Computing space requirements
MSI(i) [13:54:56.273] | Action start 13:54:56: CostFinalize.
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:244]: PROPERTY CHANGE: Adding OutOfDiskSpace property. Its value is '0'.
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:244]: PROPERTY CHANGE: Adding OutOfNoRbDiskSpace property. Its value is '0'.
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:244]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceAvailable property. Its value is '0'.
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:244]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRequired property. Its value is '0'.
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:244]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRemaining property. Its value is '0'.
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:244]: Note: 1: 2205 2:  3: Patch
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:244]: Note: 1: 2205 2:  3: Condition
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:245]: PROPERTY CHANGE: Adding TARGETDIR property. Its value is 'C:\'.
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:245]: PROPERTY CHANGE: Adding FLEXNET.C4D4FE07_FC74_47DD_9A30_533F27F843F1 property. Its value is 'C:\ProgramData\FLEXnet\'.
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:245]: PROPERTY CHANGE: Adding CONNECT.C4D4FE07_FC74_47DD_9A30_533F27F843F1 property. Its value is 'C:\ProgramData\FLEXnet\Connect\'.
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:245]: PROPERTY CHANGE: Adding FNCBINDIR.C4D4FE07_FC74_47DD_9A30_533F27F843F1 property. Its value is 'C:\ProgramData\FLEXnet\Connect\11\'.
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:245]: PROPERTY CHANGE: Adding UI.C4D4FE07_FC74_47DD_9A30_533F27F843F1 property. Its value is 'C:\ProgramData\FLEXnet\Connect\11\ui\'.
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:245]: PROPERTY CHANGE: Adding LANG.C4D4FE07_FC74_47DD_9A30_533F27F843F1 property. Its value is 'C:\ProgramData\FLEXnet\Connect\11\ui\lang\'.
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:245]: PROPERTY CHANGE: Adding IMAGES.C4D4FE07_FC74_47DD_9A30_533F27F843F1 property. Its value is 'C:\ProgramData\FLEXnet\Connect\11\ui\images\'.
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:245]: PROPERTY CHANGE: Adding MACROVISION.9FC896E6_8DD6_4BFD_A02C_189B1B87F512 property. Its value is 'C:\ProgramData\Macrovision\'.
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:245]: PROPERTY CHANGE: Adding FLEXNET_CONNECT.9FC896E6_8DD6_4BFD_A02C_189B1B87F512 property. Its value is 'C:\ProgramData\Macrovision\FLEXnet Connect\'.
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:245]: PROPERTY CHANGE: Adding FNC61DIR.9FC896E6_8DD6_4BFD_A02C_189B1B87F512 property. Its value is 'C:\ProgramData\Macrovision\FLEXnet Connect\6\'.
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:245]: PROPERTY CHANGE: Adding FNC11DIR.9FC896E6_8DD6_4BFD_A02C_189B1B87F512 property. Its value is 'C:\ProgramData\Macrovision\FLEXnet Connect\11\'.
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:245]: PROPERTY CHANGE: Adding FLEXNET.9FC896E6_8DD6_4BFD_A02C_189B1B87F512 property. Its value is 'C:\ProgramData\FLEXnet\'.
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:245]: PROPERTY CHANGE: Adding CONNECT.9FC896E6_8DD6_4BFD_A02C_189B1B87F512 property. Its value is 'C:\ProgramData\FLEXnet\Connect\'.
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:245]: PROPERTY CHANGE: Adding FNCBINDIR.9FC896E6_8DD6_4BFD_A02C_189B1B87F512 property. Its value is 'C:\ProgramData\FLEXnet\Connect\11\'.
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:245]: PROPERTY CHANGE: Adding INSTALLSHIELD.9FC896E6_8DD6_4BFD_A02C_189B1B87F512 property. Its value is 'C:\Program Files (x86)\Common Files\InstallShield\'.
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:245]: PROPERTY CHANGE: Adding UPDATESERVICE.9FC896E6_8DD6_4BFD_A02C_189B1B87F512 property. Its value is 'C:\Program Files (x86)\Common Files\InstallShield\UpdateService\'.
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:245]: PROPERTY CHANGE: Adding INTEL property. Its value is 'C:\Program Files (x86)\Common Files\Intel\'.
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:245]: PROPERTY CHANGE: Adding PRODUCT property. Its value is 'C:\Program Files (x86)\Common Files\Intel\Intel Software Manager\'.
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:245]: PROPERTY CHANGE: Adding ISMintel64 property. Its value is 'C:\Program Files (x86)\Common Files\Intel\Intel Software Manager\intel64\'.
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:245]: Target path resolution complete. Dumping Directory table...
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:245]: Note: target paths subject to change (via custom actions or browsing)
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:245]: Dir (target): Key: TARGETDIR    , Object: C:\
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:245]: Dir (target): Key: WindowsFolder    , Object: C:\Windows\
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:245]: Dir (target): Key: StartMenuFolder    , Object: C:\ProgramData\Microsoft\Windows\Start Menu\
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:245]: Dir (target): Key: CommonAppDataFolder    , Object: C:\ProgramData\
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:245]: Dir (target): Key: FLEXNET.C4D4FE07_FC74_47DD_9A30_533F27F843F1    , Object: C:\ProgramData\FLEXnet\
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:245]: Dir (target): Key: CONNECT.C4D4FE07_FC74_47DD_9A30_533F27F843F1    , Object: C:\ProgramData\FLEXnet\Connect\
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:245]: Dir (target): Key: FNCBINDIR.C4D4FE07_FC74_47DD_9A30_533F27F843F1    , Object: C:\ProgramData\FLEXnet\Connect\11\
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:245]: Dir (target): Key: UI.C4D4FE07_FC74_47DD_9A30_533F27F843F1    , Object: C:\ProgramData\FLEXnet\Connect\11\ui\
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:245]: Dir (target): Key: LANG.C4D4FE07_FC74_47DD_9A30_533F27F843F1    , Object: C:\ProgramData\FLEXnet\Connect\11\ui\lang\
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:245]: Dir (target): Key: IMAGES.C4D4FE07_FC74_47DD_9A30_533F27F843F1    , Object: C:\ProgramData\FLEXnet\Connect\11\ui\images\
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:245]: Dir (target): Key: MACROVISION.9FC896E6_8DD6_4BFD_A02C_189B1B87F512    , Object: C:\ProgramData\Macrovision\
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:245]: Dir (target): Key: FLEXNET_CONNECT.9FC896E6_8DD6_4BFD_A02C_189B1B87F512    , Object: C:\ProgramData\Macrovision\FLEXnet Connect\
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:245]: Dir (target): Key: FNC61DIR.9FC896E6_8DD6_4BFD_A02C_189B1B87F512    , Object: C:\ProgramData\Macrovision\FLEXnet Connect\6\
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:245]: Dir (target): Key: FNC11DIR.9FC896E6_8DD6_4BFD_A02C_189B1B87F512    , Object: C:\ProgramData\Macrovision\FLEXnet Connect\11\
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:245]: Dir (target): Key: FLEXNET.9FC896E6_8DD6_4BFD_A02C_189B1B87F512    , Object: C:\ProgramData\FLEXnet\
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:245]: Dir (target): Key: CONNECT.9FC896E6_8DD6_4BFD_A02C_189B1B87F512    , Object: C:\ProgramData\FLEXnet\Connect\
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:245]: Dir (target): Key: FNCBINDIR.9FC896E6_8DD6_4BFD_A02C_189B1B87F512    , Object: C:\ProgramData\FLEXnet\Connect\11\
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:245]: Dir (target): Key: CommonFilesFolder    , Object: C:\Program Files (x86)\Common Files\
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:245]: Dir (target): Key: INSTALLSHIELD.9FC896E6_8DD6_4BFD_A02C_189B1B87F512    , Object: C:\Program Files (x86)\Common Files\InstallShield\
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:245]: Dir (target): Key: UPDATESERVICE.9FC896E6_8DD6_4BFD_A02C_189B1B87F512    , Object: C:\Program Files (x86)\Common Files\InstallShield\UpdateService\
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:245]: Dir (target): Key: INTEL    , Object: C:\Program Files (x86)\Common Files\Intel\
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:245]: Dir (target): Key: PRODUCT    , Object: C:\Program Files (x86)\Common Files\Intel\Intel Software Manager\
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:245]: Dir (target): Key: ISMintel64    , Object: C:\Program Files (x86)\Common Files\Intel\Intel Software Manager\intel64\
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:245]: Note: 1: 2205 2:  3: MsiAssembly
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:245]: Note: 1: 2228 2:  3: MsiAssembly 4:  SELECT `MsiAssembly`.`Attributes`, `MsiAssembly`.`File_Application`, `MsiAssembly`.`File_Manifest`,  `Component`.`KeyPath` FROM `MsiAssembly`, `Component` WHERE  `MsiAssembly`.`Component_` = `Component`.`Component` AND `MsiAssembly`.`Component_` = ?
MSI(i) [13:54:56.273] | Action ended 13:54:56: CostFinalize. Return value 1.
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:246]: Doing action: InstallValidate
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:246]: Note: 1: 2205 2:  3: ActionText
MSI(i) [13:54:56.273] | Action 13:54:56: InstallValidate. Validating install
MSI(i) [13:54:56.273] | Action start 13:54:56: InstallValidate.
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:248]: Note: 1: 2205 2:  3: Dialog
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:248]: Feature: ISM; Installed: Absent;   Request: Local;   Action: Local
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:248]: Component: Instance; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:248]: Component: ISM_detector; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:248]: Component: RegistryData; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:248]: Component: C1; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:248]: Component: C2; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:248]: Component: C3; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:248]: Component: C4; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:248]: Component: C5; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:248]: Component: C6; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:248]: Component: C7; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:248]: Component: C8; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:248]: Component: C9; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:248]: Component: C10; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:248]: Component: C11; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:248]: Component: C12; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:248]: Component: C13; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:248]: Component: C14; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:248]: Component: C15; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:248]: Component: C16; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:248]: Component: C17; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:248]: Component: C18; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:248]: Component: C19; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:248]: Component: C20; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:248]: Component: C21; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:248]: Component: C31; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:248]: Component: C32; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:248]: Component: C22; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:248]: Component: C23; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:248]: Component: C24; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:248]: Component: C25; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:248]: Component: C26; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:248]: Component: C27; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:248]: Component: C28; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:248]: Component: C29; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:248]: Component: C30; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:248]: Component: ISDM.exe.9FC896E6_8DD6_4BFD_A02C_189B1B87F512; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:248]: Component: _isusres.dll.9FC896E6_8DD6_4BFD_A02C_189B1B87F512; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:248]: Component: agent.exe.9FC896E6_8DD6_4BFD_A02C_189B1B87F512; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:248]: Component: agent1101.exe.9FC896E6_8DD6_4BFD_A02C_189B1B87F512; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:248]: Component: agent600.exe.9FC896E6_8DD6_4BFD_A02C_189B1B87F512; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:248]: Component: agent610.exe.9FC896E6_8DD6_4BFD_A02C_189B1B87F512; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:248]: Component: dwusplay.dll.9FC896E6_8DD6_4BFD_A02C_189B1B87F512; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:248]: Component: dwusplay.exe.9FC896E6_8DD6_4BFD_A02C_189B1B87F512; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:248]: Component: fncproducts.9FC896E6_8DD6_4BFD_A02C_189B1B87F512; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:248]: Component: issch.exe.9FC896E6_8DD6_4BFD_A02C_189B1B87F512; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:248]: Component: isusweb.dll_deprecated.9FC896E6_8DD6_4BFD_A02C_189B1B87F512; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:248]: Component: FNCInstallComponent_deprecated.9FC896E6_8DD6_4BFD_A02C_189B1B87F512; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:248]: Component: ISDM.exe_RegistryData.9FC896E6_8DD6_4BFD_A02C_189B1B87F512; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:248]: Component: agent.exe_RegistryData.9FC896E6_8DD6_4BFD_A02C_189B1B87F512; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:248]: Component: agent1101.exe_RegistryData.9FC896E6_8DD6_4BFD_A02C_189B1B87F512; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:248]: Component: agent600.exe_RegistryData.9FC896E6_8DD6_4BFD_A02C_189B1B87F512; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:248]: Component: agent610.exe_RegistryData.9FC896E6_8DD6_4BFD_A02C_189B1B87F512; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:248]: Component: dwusplay.exe_RegistryData.9FC896E6_8DD6_4BFD_A02C_189B1B87F512; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:248]: Component: isusweb.dll_RegistryData_deprecated.9FC896E6_8DD6_4BFD_A02C_189B1B87F512; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:248]: Component: ISUSPM.exe.C4D4FE07_FC74_47DD_9A30_533F27F843F1; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:248]: Component: _ispmres.dll.C4D4FE07_FC74_47DD_9A30_533F27F843F1; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:248]: Component: Images.C4D4FE07_FC74_47DD_9A30_533F27F843F1; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:248]: Component: Pages.C4D4FE07_FC74_47DD_9A30_533F27F843F1; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:248]: Component: Strings.C4D4FE07_FC74_47DD_9A30_533F27F843F1; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:248]: Component: FNCInstallComponent.C4D4FE07_FC74_47DD_9A30_533F27F843F1; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:248]: Component: FNCSetBootstrap.C4D4FE07_FC74_47DD_9A30_533F27F843F1; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:248]: Component: ISUSPM.exe_RegistryData.C4D4FE07_FC74_47DD_9A30_533F27F843F1; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:248]: Component: __agent1101.exe.9FC896E6_8DD6_4BFD_A02C_189B1B87F51265; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:248]: Component: __agent610.exe.9FC896E6_8DD6_4BFD_A02C_189B1B87F51265; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:248]: Component: __ISUSPM.exe.C4D4FE07_FC74_47DD_9A30_533F27F843F165; Installed: Null;   Request: Local;   Action: Local;   Client State: Null
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:248]: Component: __RegistryData65; Installed: Null;   Request: Local;   Action: Local;   Client State: Null
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:248]: Component: __agent610.exe.9FC896E6_8DD6_4BFD_A02C_189B1B87F51266; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:248]: Component: __agent1101.exe.9FC896E6_8DD6_4BFD_A02C_189B1B87F51266; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:248]: Component: __agent.exe.9FC896E6_8DD6_4BFD_A02C_189B1B87F51265; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:248]: Component: __ISDM.exe.9FC896E6_8DD6_4BFD_A02C_189B1B87F51265; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:248]: Component: __agent600.exe.9FC896E6_8DD6_4BFD_A02C_189B1B87F51265; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:248]: Component: __dwusplay.exe.9FC896E6_8DD6_4BFD_A02C_189B1B87F51265; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:248]: Component: __FNCSetBootstrap.C4D4FE07_FC74_47DD_9A30_533F27F843F165; Installed: Null;   Request: Local;   Action: Local;   Client State: Null
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:248]: Component: __ISUSPM.exe_RegistryData.C4D4FE07_FC74_47DD_9A30_533F27F843F165; Installed: Null;   Request: Local;   Action: Local;   Client State: Null
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:248]: Note: 1: 2205 2:  3: BindImage
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:248]: Note: 1: 2205 2:  3: PublishComponent
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:248]: Note: 1: 2205 2:  3: SelfReg
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:248]: Note: 1: 2262 2: Extension 3: -2147287038
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:248]: Note: 1: 2205 2:  3: Font
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:248]: Note: 1: 2262 2: Class 3: -2147287038
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:248]: Note: 1: 2205 2:  3: TypeLib
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:249]: Note: 1: 2205 2:  3: _RemoveFilePath
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:253]: Note: 1: 2262 2: Class 3: -2147287038
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:253]: Note: 1: 2262 2: Extension 3: -2147287038
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:254]: Note: 1: 2262 2: Class 3: -2147287038
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:254]: Note: 1: 2262 2: Extension 3: -2147287038
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:254]: PROPERTY CHANGE: Modifying CostingComplete property. Its current value is '0'. Its new value: '1'.
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:254]: Note: 1: 2205 2:  3: BindImage
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:254]: Note: 1: 2205 2:  3: PublishComponent
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:254]: Note: 1: 2205 2:  3: SelfReg
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:254]: Note: 1: 2205 2:  3: Font
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:254]: Note: 1: 2205 2:  3: TypeLib
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:254]: Note: 1: 2727 2:
MSI(i) [13:54:56.273] | MSI (c) (B0:9C) [13:54:56:271]: Note: 1: 2727 2:
MSI(i) [13:54:56.273] | Action ended 13:54:56: InstallValidate. Return value 1.
MSI(i) [13:54:56.276] | MSI (c) (B0:9C) [13:54:56:271]: Creating MSIHANDLE (107) of type 790541 for thread 3996
MSI(i) [13:54:56.276] | MSI (c) (B0:9C) [13:54:56:271]: Creating MSIHANDLE (108) of type 790540 for thread 3996
MSI(i) [13:54:56.276] | MSI (c) (B0:9C) [13:54:56:271]: Creating MSIHANDLE (109) of type 790531 for thread 3996
MSI(i) [13:54:56.276] | MSI (c) (B0:9C) [13:54:56:271]: Note: 1: 2205 2:  3: Condition
MSI(i) [13:54:56.276] | MSI (c) (B0:9C) [13:54:56:271]: Note: 1: 2228 2:  3: Condition 4: SELECT * FROM Condition WHERE Feature_ = 'ISM'
MSI(i) [13:54:56.276] | MSI (c) (B0:9C) [13:54:56:271]: Creating MSIHANDLE (110) of type 790540 for thread 3996
MSI(i) [13:54:56.276] | MSI (c) (B0:9C) [13:54:56:271]: Closing MSIHANDLE (110) of type 790540 for thread 3996
MSI(i) [13:54:56.276] | MSI (c) (B0:9C) [13:54:56:271]: Closing MSIHANDLE (109) of type 790531 for thread 3996
MSI(i) [13:54:56.276] | MSI (c) (B0:9C) [13:54:56:271]: Closing MSIHANDLE (108) of type 790540 for thread 3996
MSI(i) [13:54:56.276] | MSI (c) (B0:9C) [13:54:56:271]: Closing MSIHANDLE (107) of type 790541 for thread 3996
MSI(i) [13:54:56.276] | MSI (c) (B0:9C) [13:54:56:271]: Leaked MSIHANDLE (105) of type 790537 for thread 3996
MSI(i) [13:54:56.276] | === Verbose logging stopped: 4/8/2014  13:54:56 ===
PSET(i) [13:54:56.284] | (3073.783): MsiOpenPackageEx(C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\indicator\indicator.msi)
MSI(i) [13:54:56.312] | === Verbose logging started: 4/8/2014  13:54:56  Build type: SHIP UNICODE 5.00.7601.00  Calling process: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\setup.exe ===
MSI(i) [13:54:56.312] | MSI (c) (B0:9C) [13:54:56:285]: SOFTWARE RESTRICTION POLICY: Verifying package --> 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\indicator\indicator.msi' against software restriction policy
MSI(i) [13:54:56.312] | MSI (c) (B0:9C) [13:54:56:285]: SOFTWARE RESTRICTION POLICY: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\indicator\indicator.msi has a digital signature
MSI(i) [13:54:56.312] | MSI (c) (B0:9C) [13:54:56:298]: SOFTWARE RESTRICTION POLICY: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\indicator\indicator.msi is permitted to run at the 'unrestricted' authorization level.
MSI(i) [13:54:56.312] | MSI (c) (B0:9C) [13:54:56:299]: Cloaking enabled.
MSI(i) [13:54:56.312] | MSI (c) (B0:9C) [13:54:56:299]: Attempting to enable all disabled privileges before calling Install on Server
MSI(i) [13:54:56.312] | MSI (c) (B0:9C) [13:54:56:299]: End dialog not enabled
MSI(i) [13:54:56.312] | MSI (c) (B0:9C) [13:54:56:299]: Original package ==> C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\indicator\indicator.msi
MSI(i) [13:54:56.312] | MSI (c) (B0:9C) [13:54:56:299]: Package we're running from ==> C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\indicator\indicator.msi
MSI(i) [13:54:56.312] | MSI (c) (B0:9C) [13:54:56:300]: APPCOMPAT: Compatibility mode property overrides found.
MSI(i) [13:54:56.312] | MSI (c) (B0:9C) [13:54:56:300]: APPCOMPAT: looking for appcompat database entry with ProductCode '{0C13F8EE-A432-495D-8F77-EDB3F3778D2D}'.
MSI(i) [13:54:56.312] | MSI (c) (B0:9C) [13:54:56:300]: APPCOMPAT: no matching ProductCode found in database.
MSI(i) [13:54:56.312] | MSI (c) (B0:9C) [13:54:56:302]: MSCOREE not loaded loading copy from system32
MSI(i) [13:54:56.312] | MSI (c) (B0:9C) [13:54:56:305]: Machine policy value 'TransformsSecure' is 0
MSI(i) [13:54:56.312] | MSI (c) (B0:9C) [13:54:56:305]: User policy value 'TransformsAtSource' is 0
MSI(i) [13:54:56.312] | MSI (c) (B0:9C) [13:54:56:305]: Note: 1: 2262 2: File 3: -2147287038
MSI(i) [13:54:56.312] | MSI (c) (B0:9C) [13:54:56:306]: Note: 1: 2205 2:  3: MsiFileHash
MSI(i) [13:54:56.312] | MSI (c) (B0:9C) [13:54:56:306]: Machine policy value 'DisablePatch' is 0
MSI(i) [13:54:56.312] | MSI (c) (B0:9C) [13:54:56:306]: Machine policy value 'AllowLockdownPatch' is 0
MSI(i) [13:54:56.312] | MSI (c) (B0:9C) [13:54:56:306]: Machine policy value 'DisableLUAPatching' is 0
MSI(i) [13:54:56.312] | MSI (c) (B0:9C) [13:54:56:306]: Machine policy value 'DisableFlyWeightPatching' is 0
MSI(i) [13:54:56.312] | MSI (c) (B0:9C) [13:54:56:306]: Enabling baseline caching for this transaction since all active patches are MSI 3.0 style MSPs or at least one MSI 3.0 minor update patch is active
MSI(i) [13:54:56.312] | MSI (c) (B0:9C) [13:54:56:306]: APPCOMPAT: looking for appcompat database entry with ProductCode '{0C13F8EE-A432-495D-8F77-EDB3F3778D2D}'.
MSI(i) [13:54:56.312] | MSI (c) (B0:9C) [13:54:56:306]: APPCOMPAT: no matching ProductCode found in database.
MSI(i) [13:54:56.312] | MSI (c) (B0:9C) [13:54:56:306]: Transforms are not secure.
MSI(i) [13:54:56.312] | MSI (c) (B0:9C) [13:54:56:306]: PROPERTY CHANGE: Adding MsiLogFileLocation property. Its value is 'C:\Users\PCCA-PM\AppData\Local\Temp\MSIED31.tmp'.
MSI(i) [13:54:56.312] | MSI (c) (B0:9C) [13:54:56:306]: No Command Line.
MSI(i) [13:54:56.312] | MSI (c) (B0:9C) [13:54:56:306]: PROPERTY CHANGE: Adding PackageCode property. Its value is '{F7333571-5276-4BF4-A6E2-695FDAC1CD7F}'.
MSI(i) [13:54:56.312] | MSI (c) (B0:9C) [13:54:56:306]: Product Code passed to Engine.Initialize:           '(none)'
MSI(i) [13:54:56.312] | MSI (c) (B0:9C) [13:54:56:306]: Product Code from property table before transforms: '{0C13F8EE-A432-495D-8F77-EDB3F3778D2D}'
MSI(i) [13:54:56.312] | MSI (c) (B0:9C) [13:54:56:306]: Product Code from property table after transforms:  '{0C13F8EE-A432-495D-8F77-EDB3F3778D2D}'
MSI(i) [13:54:56.312] | MSI (c) (B0:9C) [13:54:56:306]: Product not registered: beginning first-time install
MSI(i) [13:54:56.312] | MSI (c) (B0:9C) [13:54:56:306]: PROPERTY CHANGE: Adding ProductState property. Its value is '-1'.
MSI(i) [13:54:56.312] | MSI (c) (B0:9C) [13:54:56:307]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer 3: 2
MSI(i) [13:54:56.312] | MSI (c) (B0:9C) [13:54:56:307]: Entering CMsiConfigurationManager::SetLastUsedSource.
MSI(i) [13:54:56.312] | MSI (c) (B0:9C) [13:54:56:307]: User policy value 'SearchOrder' is 'nmu'
MSI(i) [13:54:56.312] | MSI (c) (B0:9C) [13:54:56:307]: Adding new sources is allowed.
MSI(i) [13:54:56.312] | MSI (c) (B0:9C) [13:54:56:307]: PROPERTY CHANGE: Adding PackagecodeChanging property. Its value is '1'.
MSI(i) [13:54:56.312] | MSI (c) (B0:9C) [13:54:56:307]: Package name extracted from package path: 'indicator.msi'
MSI(i) [13:54:56.312] | MSI (c) (B0:9C) [13:54:56:307]: Package to be registered: 'indicator.msi'
MSI(i) [13:54:56.312] | MSI (c) (B0:9C) [13:54:56:307]: Note: 1: 2205 2:  3: Error
MSI(i) [13:54:56.312] | MSI (c) (B0:9C) [13:54:56:307]: Note: 1: 2262 2: AdminProperties 3: -2147287038
MSI(i) [13:54:56.312] | MSI (c) (B0:9C) [13:54:56:307]: Machine policy value 'DisableMsi' is 0
MSI(i) [13:54:56.312] | MSI (c) (B0:9C) [13:54:56:308]: Machine policy value 'AlwaysInstallElevated' is 0
MSI(i) [13:54:56.312] | MSI (c) (B0:9C) [13:54:56:308]: User policy value 'AlwaysInstallElevated' is 0
MSI(i) [13:54:56.312] | MSI (c) (B0:9C) [13:54:56:308]: Product installation will be elevated because user is admin and product is being installed per-machine.
MSI(i) [13:54:56.312] | MSI (c) (B0:9C) [13:54:56:308]: Running product '{0C13F8EE-A432-495D-8F77-EDB3F3778D2D}' with elevated privileges: Product is assigned.
MSI(i) [13:54:56.312] | MSI (c) (B0:9C) [13:54:56:308]: PROPERTY CHANGE: Adding MsiSystemRebootPending property. Its value is '1'.
MSI(i) [13:54:56.312] | MSI (c) (B0:9C) [13:54:56:308]: TRANSFORMS property is now:
MSI(i) [13:54:56.312] | MSI (c) (B0:9C) [13:54:56:308]: PROPERTY CHANGE: Adding VersionDatabase property. Its value is '200'.
MSI(i) [13:54:56.312] | MSI (c) (B0:9C) [13:54:56:308]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming
MSI(i) [13:54:56.312] | MSI (c) (B0:9C) [13:54:56:308]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Favorites
MSI(i) [13:54:56.312] | MSI (c) (B0:9C) [13:54:56:308]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Network Shortcuts
MSI(i) [13:54:56.312] | MSI (c) (B0:9C) [13:54:56:308]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Documents
MSI(i) [13:54:56.312] | MSI (c) (B0:9C) [13:54:56:308]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
MSI(i) [13:54:56.312] | MSI (c) (B0:9C) [13:54:56:308]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Recent
MSI(i) [13:54:56.312] | MSI (c) (B0:9C) [13:54:56:308]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\SendTo
MSI(i) [13:54:56.312] | MSI (c) (B0:9C) [13:54:56:308]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Templates
MSI(i) [13:54:56.312] | MSI (c) (B0:9C) [13:54:56:308]: SHELL32::SHGetFolderPath returned: C:\ProgramData
MSI(i) [13:54:56.312] | MSI (c) (B0:9C) [13:54:56:308]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Local
MSI(i) [13:54:56.312] | MSI (c) (B0:9C) [13:54:56:308]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Pictures
MSI(i) [13:54:56.312] | MSI (c) (B0:9C) [13:54:56:308]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI(i) [13:54:56.312] | MSI (c) (B0:9C) [13:54:56:308]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
MSI(i) [13:54:56.312] | MSI (c) (B0:9C) [13:54:56:308]: SHELL32::SHGetFolderPath returned: C:\Users\Public\Desktop
MSI(i) [13:54:56.312] | MSI (c) (B0:9C) [13:54:56:308]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI(i) [13:54:56.312] | MSI (c) (B0:9C) [13:54:56:308]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
MSI(i) [13:54:56.312] | MSI (c) (B0:9C) [13:54:56:308]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Desktop
MSI(i) [13:54:56.312] | MSI (c) (B0:9C) [13:54:56:308]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Templates
MSI(i) [13:54:56.312] | MSI (c) (B0:9C) [13:54:56:309]: SHELL32::SHGetFolderPath returned: C:\Windows\Fonts
MSI(i) [13:54:56.312] | MSI (c) (B0:9C) [13:54:56:309]: Note: 1: 2898 2: MS Sans Serif 3: MS Sans Serif 4: 0 5: 16
MSI(i) [13:54:56.312] | MSI (c) (B0:9C) [13:54:56:311]: MSI_LUA: Setting AdminUser property to 1 because this is the client or the user has already permitted elevation
MSI(i) [13:54:56.312] | MSI (c) (B0:9C) [13:54:56:311]: MSI_LUA: Setting MsiRunningElevated property to 1 because the install is already running elevated.
MSI(i) [13:54:56.312] | MSI (c) (B0:9C) [13:54:56:311]: PROPERTY CHANGE: Adding MsiRunningElevated property. Its value is '1'.
MSI(i) [13:54:56.312] | MSI (c) (B0:9C) [13:54:56:311]: PROPERTY CHANGE: Adding Privileged property. Its value is '1'.
MSI(i) [13:54:56.312] | MSI (c) (B0:9C) [13:54:56:311]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\MS Setup (ACME)\User Info 3: 2
MSI(i) [13:54:56.312] | MSI (c) (B0:9C) [13:54:56:311]: PROPERTY CHANGE: Adding USERNAME property. Its value is 'A Valued IT Customer'.
MSI(i) [13:54:56.312] | MSI (c) (B0:9C) [13:54:56:311]: PROPERTY CHANGE: Adding COMPANYNAME property. Its value is 'Intel Corporation'.
MSI(i) [13:54:56.312] | MSI (c) (B0:9C) [13:54:56:311]: PROPERTY CHANGE: Adding DATABASE property. Its value is 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\indicator\indicator.msi'.
MSI(i) [13:54:56.312] | MSI (c) (B0:9C) [13:54:56:311]: PROPERTY CHANGE: Adding OriginalDatabase property. Its value is 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\indicator\indicator.msi'.
MSI(i) [13:54:56.312] | MSI (c) (B0:9C) [13:54:56:311]: Machine policy value 'MsiDisableEmbeddedUI' is 0
MSI(i) [13:54:56.312] | MSI (c) (B0:9C) [13:54:56:311]: EEUI - Disabling MsiEmbeddedUI in quiet mode
MSI(i) [13:54:56.312] | === Logging started: 4/8/2014  13:54:56 ===
MSI(i) [13:54:56.312] | MSI (c) (B0:9C) [13:54:56:312]: Note: 1: 2205 2:  3: PatchPackage
MSI(i) [13:54:56.312] | MSI (c) (B0:9C) [13:54:56:312]: Machine policy value 'DisableRollback' is 0
MSI(i) [13:54:56.312] | MSI (c) (B0:9C) [13:54:56:312]: User policy value 'DisableRollback' is 0
MSI(i) [13:54:56.312] | MSI (c) (B0:9C) [13:54:56:312]: PROPERTY CHANGE: Adding UILevel property. Its value is '2'.
MSI(i) [13:54:56.312] | MSI (c) (B0:9C) [13:54:56:312]: Creating MSIHANDLE (111) of type 790537 for thread 3996
MSI(i) [13:54:56.312] | MSI (c) (B0:9C) [13:54:56:312]: MsiOpenPackageEx is returning 0
MSI(i) [13:54:56.312] | MSI (c) (B0:9C) [13:54:56:312]: Closing MSIHANDLE (111) of type 790537 for thread 3996
MSI(i) [13:54:56.312] | === Verbose logging stopped: 4/8/2014  13:54:56 ===
PSET(i) [13:54:56.352] | (9217.15): CPropPageMissingMSVC: {F3232000-E3BA-4B32-B7FF-89331B1E128C};{62276707-4674-4240-8AC6-85E461494AFE};{7DEBE3CB-C7DD-4443-B417-E79C3B1B3B9B};{86737A33-1483-48c1-BF02-EF3C4F4CA597}
PSET(i) [13:54:56.352] | (9409.32): CPropPageMissingMSDevTools: {161F1373-21CB-485b-B57E-56A4E175AA1E}
PSET(i) [13:54:56.352] | (9809.18): CPropPageChooseMSDEVTool: {C005E000-DE40-7001-0000-000000000000}
PSET(i) [13:54:56.352] | (1489.18): CPropPageChooseMSDEVToolEM: {C5501D4E-96D7-4219-A4B7-1502F641B88E}
PSET(i) [13:54:56.352] | (6689.19): CPropPageSetEnvVars: {5E700000-E9400-4A85-0000-000000000000}
PSET(i) [13:54:56.352] | (3073.783): MsiOpenPackageEx(C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\indicator\indicator.msi)
MSI(i) [13:54:56.380] | === Verbose logging started: 4/8/2014  13:54:56  Build type: SHIP UNICODE 5.00.7601.00  Calling process: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\setup.exe ===
MSI(i) [13:54:56.380] | MSI (c) (B0:9C) [13:54:56:353]: SOFTWARE RESTRICTION POLICY: Verifying package --> 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\indicator\indicator.msi' against software restriction policy
MSI(i) [13:54:56.380] | MSI (c) (B0:9C) [13:54:56:353]: SOFTWARE RESTRICTION POLICY: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\indicator\indicator.msi has a digital signature
MSI(i) [13:54:56.380] | MSI (c) (B0:9C) [13:54:56:366]: SOFTWARE RESTRICTION POLICY: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\indicator\indicator.msi is permitted to run at the 'unrestricted' authorization level.
MSI(i) [13:54:56.380] | MSI (c) (B0:9C) [13:54:56:367]: Cloaking enabled.
MSI(i) [13:54:56.380] | MSI (c) (B0:9C) [13:54:56:367]: Attempting to enable all disabled privileges before calling Install on Server
MSI(i) [13:54:56.380] | MSI (c) (B0:9C) [13:54:56:367]: End dialog not enabled
MSI(i) [13:54:56.380] | MSI (c) (B0:9C) [13:54:56:367]: Original package ==> C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\indicator\indicator.msi
MSI(i) [13:54:56.380] | MSI (c) (B0:9C) [13:54:56:367]: Package we're running from ==> C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\indicator\indicator.msi
MSI(i) [13:54:56.380] | MSI (c) (B0:9C) [13:54:56:368]: APPCOMPAT: Compatibility mode property overrides found.
MSI(i) [13:54:56.380] | MSI (c) (B0:9C) [13:54:56:368]: APPCOMPAT: looking for appcompat database entry with ProductCode '{0C13F8EE-A432-495D-8F77-EDB3F3778D2D}'.
MSI(i) [13:54:56.380] | MSI (c) (B0:9C) [13:54:56:368]: APPCOMPAT: no matching ProductCode found in database.
MSI(i) [13:54:56.380] | MSI (c) (B0:9C) [13:54:56:370]: MSCOREE not loaded loading copy from system32
MSI(i) [13:54:56.380] | MSI (c) (B0:9C) [13:54:56:374]: Machine policy value 'TransformsSecure' is 0
MSI(i) [13:54:56.380] | MSI (c) (B0:9C) [13:54:56:374]: User policy value 'TransformsAtSource' is 0
MSI(i) [13:54:56.380] | MSI (c) (B0:9C) [13:54:56:374]: Note: 1: 2262 2: File 3: -2147287038
MSI(i) [13:54:56.380] | MSI (c) (B0:9C) [13:54:56:374]: Note: 1: 2205 2:  3: MsiFileHash
MSI(i) [13:54:56.380] | MSI (c) (B0:9C) [13:54:56:374]: Machine policy value 'DisablePatch' is 0
MSI(i) [13:54:56.380] | MSI (c) (B0:9C) [13:54:56:374]: Machine policy value 'AllowLockdownPatch' is 0
MSI(i) [13:54:56.380] | MSI (c) (B0:9C) [13:54:56:374]: Machine policy value 'DisableLUAPatching' is 0
MSI(i) [13:54:56.380] | MSI (c) (B0:9C) [13:54:56:374]: Machine policy value 'DisableFlyWeightPatching' is 0
MSI(i) [13:54:56.380] | MSI (c) (B0:9C) [13:54:56:374]: Enabling baseline caching for this transaction since all active patches are MSI 3.0 style MSPs or at least one MSI 3.0 minor update patch is active
MSI(i) [13:54:56.380] | MSI (c) (B0:9C) [13:54:56:374]: APPCOMPAT: looking for appcompat database entry with ProductCode '{0C13F8EE-A432-495D-8F77-EDB3F3778D2D}'.
MSI(i) [13:54:56.380] | MSI (c) (B0:9C) [13:54:56:374]: APPCOMPAT: no matching ProductCode found in database.
MSI(i) [13:54:56.380] | MSI (c) (B0:9C) [13:54:56:374]: Transforms are not secure.
MSI(i) [13:54:56.380] | MSI (c) (B0:9C) [13:54:56:374]: PROPERTY CHANGE: Adding MsiLogFileLocation property. Its value is 'C:\Users\PCCA-PM\AppData\Local\Temp\MSIED31.tmp'.
MSI(i) [13:54:56.380] | MSI (c) (B0:9C) [13:54:56:374]: No Command Line.
MSI(i) [13:54:56.380] | MSI (c) (B0:9C) [13:54:56:374]: PROPERTY CHANGE: Adding PackageCode property. Its value is '{F7333571-5276-4BF4-A6E2-695FDAC1CD7F}'.
MSI(i) [13:54:56.380] | MSI (c) (B0:9C) [13:54:56:374]: Product Code passed to Engine.Initialize:           '(none)'
MSI(i) [13:54:56.380] | MSI (c) (B0:9C) [13:54:56:374]: Product Code from property table before transforms: '{0C13F8EE-A432-495D-8F77-EDB3F3778D2D}'
MSI(i) [13:54:56.380] | MSI (c) (B0:9C) [13:54:56:374]: Product Code from property table after transforms:  '{0C13F8EE-A432-495D-8F77-EDB3F3778D2D}'
MSI(i) [13:54:56.380] | MSI (c) (B0:9C) [13:54:56:374]: Product not registered: beginning first-time install
MSI(i) [13:54:56.380] | MSI (c) (B0:9C) [13:54:56:375]: PROPERTY CHANGE: Adding ProductState property. Its value is '-1'.
MSI(i) [13:54:56.380] | MSI (c) (B0:9C) [13:54:56:375]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer 3: 2
MSI(i) [13:54:56.380] | MSI (c) (B0:9C) [13:54:56:375]: Entering CMsiConfigurationManager::SetLastUsedSource.
MSI(i) [13:54:56.380] | MSI (c) (B0:9C) [13:54:56:375]: User policy value 'SearchOrder' is 'nmu'
MSI(i) [13:54:56.380] | MSI (c) (B0:9C) [13:54:56:375]: Adding new sources is allowed.
MSI(i) [13:54:56.380] | MSI (c) (B0:9C) [13:54:56:375]: PROPERTY CHANGE: Adding PackagecodeChanging property. Its value is '1'.
MSI(i) [13:54:56.380] | MSI (c) (B0:9C) [13:54:56:375]: Package name extracted from package path: 'indicator.msi'
MSI(i) [13:54:56.380] | MSI (c) (B0:9C) [13:54:56:375]: Package to be registered: 'indicator.msi'
MSI(i) [13:54:56.380] | MSI (c) (B0:9C) [13:54:56:375]: Note: 1: 2205 2:  3: Error
MSI(i) [13:54:56.380] | MSI (c) (B0:9C) [13:54:56:376]: Note: 1: 2262 2: AdminProperties 3: -2147287038
MSI(i) [13:54:56.380] | MSI (c) (B0:9C) [13:54:56:376]: Machine policy value 'DisableMsi' is 0
MSI(i) [13:54:56.380] | MSI (c) (B0:9C) [13:54:56:376]: Machine policy value 'AlwaysInstallElevated' is 0
MSI(i) [13:54:56.380] | MSI (c) (B0:9C) [13:54:56:376]: User policy value 'AlwaysInstallElevated' is 0
MSI(i) [13:54:56.380] | MSI (c) (B0:9C) [13:54:56:376]: Product installation will be elevated because user is admin and product is being installed per-machine.
MSI(i) [13:54:56.380] | MSI (c) (B0:9C) [13:54:56:376]: Running product '{0C13F8EE-A432-495D-8F77-EDB3F3778D2D}' with elevated privileges: Product is assigned.
MSI(i) [13:54:56.380] | MSI (c) (B0:9C) [13:54:56:376]: PROPERTY CHANGE: Adding MsiSystemRebootPending property. Its value is '1'.
MSI(i) [13:54:56.380] | MSI (c) (B0:9C) [13:54:56:376]: TRANSFORMS property is now:
MSI(i) [13:54:56.380] | MSI (c) (B0:9C) [13:54:56:376]: PROPERTY CHANGE: Adding VersionDatabase property. Its value is '200'.
MSI(i) [13:54:56.380] | MSI (c) (B0:9C) [13:54:56:376]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming
MSI(i) [13:54:56.380] | MSI (c) (B0:9C) [13:54:56:376]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Favorites
MSI(i) [13:54:56.380] | MSI (c) (B0:9C) [13:54:56:376]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Network Shortcuts
MSI(i) [13:54:56.380] | MSI (c) (B0:9C) [13:54:56:376]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Documents
MSI(i) [13:54:56.380] | MSI (c) (B0:9C) [13:54:56:376]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
MSI(i) [13:54:56.380] | MSI (c) (B0:9C) [13:54:56:376]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Recent
MSI(i) [13:54:56.380] | MSI (c) (B0:9C) [13:54:56:376]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\SendTo
MSI(i) [13:54:56.380] | MSI (c) (B0:9C) [13:54:56:376]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Templates
MSI(i) [13:54:56.380] | MSI (c) (B0:9C) [13:54:56:376]: SHELL32::SHGetFolderPath returned: C:\ProgramData
MSI(i) [13:54:56.380] | MSI (c) (B0:9C) [13:54:56:376]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Local
MSI(i) [13:54:56.380] | MSI (c) (B0:9C) [13:54:56:376]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Pictures
MSI(i) [13:54:56.380] | MSI (c) (B0:9C) [13:54:56:376]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI(i) [13:54:56.380] | MSI (c) (B0:9C) [13:54:56:376]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
MSI(i) [13:54:56.380] | MSI (c) (B0:9C) [13:54:56:376]: SHELL32::SHGetFolderPath returned: C:\Users\Public\Desktop
MSI(i) [13:54:56.380] | MSI (c) (B0:9C) [13:54:56:376]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI(i) [13:54:56.380] | MSI (c) (B0:9C) [13:54:56:376]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
MSI(i) [13:54:56.381] | MSI (c) (B0:9C) [13:54:56:376]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Start Menu\Programs
MSI(i) [13:54:56.381] | MSI (c) (B0:9C) [13:54:56:376]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Desktop
MSI(i) [13:54:56.381] | MSI (c) (B0:9C) [13:54:56:377]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Templates
MSI(i) [13:54:56.381] | MSI (c) (B0:9C) [13:54:56:377]: SHELL32::SHGetFolderPath returned: C:\Windows\Fonts
MSI(i) [13:54:56.381] | MSI (c) (B0:9C) [13:54:56:377]: Note: 1: 2898 2: MS Sans Serif 3: MS Sans Serif 4: 0 5: 16
MSI(i) [13:54:56.381] | MSI (c) (B0:9C) [13:54:56:379]: MSI_LUA: Setting AdminUser property to 1 because this is the client or the user has already permitted elevation
MSI(i) [13:54:56.381] | MSI (c) (B0:9C) [13:54:56:379]: MSI_LUA: Setting MsiRunningElevated property to 1 because the install is already running elevated.
MSI(i) [13:54:56.381] | MSI (c) (B0:9C) [13:54:56:379]: PROPERTY CHANGE: Adding MsiRunningElevated property. Its value is '1'.
MSI(i) [13:54:56.381] | MSI (c) (B0:9C) [13:54:56:379]: PROPERTY CHANGE: Adding Privileged property. Its value is '1'.
MSI(i) [13:54:56.381] | MSI (c) (B0:9C) [13:54:56:379]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\MS Setup (ACME)\User Info 3: 2
MSI(i) [13:54:56.381] | MSI (c) (B0:9C) [13:54:56:380]: PROPERTY CHANGE: Adding USERNAME property. Its value is 'A Valued IT Customer'.
MSI(i) [13:54:56.381] | MSI (c) (B0:9C) [13:54:56:380]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\MS Setup (ACME)\User Info 3: 2
MSI(i) [13:54:56.381] | MSI (c) (B0:9C) [13:54:56:380]: PROPERTY CHANGE: Adding COMPANYNAME property. Its value is 'Intel Corporation'.
MSI(i) [13:54:56.381] | MSI (c) (B0:9C) [13:54:56:380]: PROPERTY CHANGE: Adding DATABASE property. Its value is 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\indicator\indicator.msi'.
MSI(i) [13:54:56.381] | MSI (c) (B0:9C) [13:54:56:380]: PROPERTY CHANGE: Adding OriginalDatabase property. Its value is 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\indicator\indicator.msi'.
MSI(i) [13:54:56.381] | MSI (c) (B0:9C) [13:54:56:380]: Machine policy value 'MsiDisableEmbeddedUI' is 0
MSI(i) [13:54:56.381] | MSI (c) (B0:9C) [13:54:56:380]: EEUI - Disabling MsiEmbeddedUI in quiet mode
MSI(i) [13:54:56.381] | === Logging started: 4/8/2014  13:54:56 ===
MSI(i) [13:54:56.381] | MSI (c) (B0:9C) [13:54:56:380]: Note: 1: 2205 2:  3: PatchPackage
MSI(i) [13:54:56.381] | MSI (c) (B0:9C) [13:54:56:380]: Machine policy value 'DisableRollback' is 0
MSI(i) [13:54:56.381] | MSI (c) (B0:9C) [13:54:56:380]: User policy value 'DisableRollback' is 0
MSI(i) [13:54:56.381] | MSI (c) (B0:9C) [13:54:56:380]: PROPERTY CHANGE: Adding UILevel property. Its value is '2'.
MSI(i) [13:54:56.381] | MSI (c) (B0:9C) [13:54:56:380]: Creating MSIHANDLE (112) of type 790537 for thread 3996
MSI(i) [13:54:56.381] | MSI (c) (B0:9C) [13:54:56:380]: MsiOpenPackageEx is returning 0
MSI(i) [13:54:56.381] | MSI (c) (B0:9C) [13:54:56:380]: Closing MSIHANDLE (112) of type 790537 for thread 3996
MSI(i) [13:54:56.381] | === Verbose logging stopped: 4/8/2014  13:54:56 ===
ISSA(i) [13:54:56.948] | (2289.1456): issaapi_cpp::set_media_id: Media ID is BL5
ISSA(i) [13:54:56.948] | (2289.1507): issaapi_cpp::add_feature: feature PerfAnl| (PerfAnlMID), path Installs
ISSA(i) [13:54:56.949] | (5729.2526): LicenseHandler::GetIntelLicenseFileEnvVar(): pzLicFileDirs - C:\Program Files (x86)\Common Files\Intel\Licenses
ISSA(i) [13:54:56.949] | (5729.2401): lzBaseDir and stuff: C:\Program Files (x86)\Common Files\Intel\Licenses\*.lic
ISSA(i) [13:54:56.949] | (5729.297): LicenseHandler::validateSerialNumber()::
ISSA(e) [13:54:56.949] | (5729.300): LicenseHandler::validateSerialNumber: serial number  is of a wrong length! Expected 13 characters!
ISSA(i) [13:54:56.950] | (5729.1690): LicenseHandler::getLicenseFileDir() - CommonFilesDir C:\Program Files (x86)\Common Files
ISSA(i) [13:54:56.950] | (5729.1719): LicenseHandler::getLicenseFileDir() - C:\Program Files (x86)\Common Files\Intel\Licenses
ISSA(i) [13:54:56.950] | (5729.2565): LicenseHandler::GetChkLicCode()C:\Program Files (x86)\Common Files\Intel\Licenses\w_MRKCWVF4.lic
ISSA(i) [13:54:56.950] | (5729.2596): LicenseHandler::GetChkLicCode() - File size : 758
ISSA(i) [13:54:56.950] | (5729.2606): LicenseHandler::GetChkLicCode() - Bytes read : 758
ISSA(i) [13:54:56.950] | (5729.139): LicenseHandler::ChklicIsOk: "C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\fli\chklics.exe" -d
ISSA(i) [13:54:57.547] | (5729.142): "C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\fli\chklics.exe" -d stdout is 20120811
ISSA(i) [13:54:57.547] | (5729.147): "C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\fli\chklics.exe" -d status is 0
ISSA(i) [13:54:57.547] | (5729.2689): LicenseHandler::GetChkLicCode(): "C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\fli\chklics.exe" -a -f"PerfAnl" -f"PerfAnlW" -p"i86_n" -p"ia64_n"  -c"C:\Program Files (x86)\Common Files\Intel\Licenses\w_MRKCWVF4.lic"
ISSA(i) [13:54:57.760] | (5729.2697): LicenseHandler::GetChkLicCode(): "C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\fli\chklics.exe" -a -f"PerfAnl" -f"PerfAnlW" -p"i86_n" -p"ia64_n"  -c"C:\Program Files (x86)\Common Files\Intel\Licenses\w_MRKCWVF4.lic"
ISSA(i) [13:54:57.760] | (5729.2721): LicenseHandler::GetChkLicCode(): 10
ISSA(i) [13:54:57.760] | (5729.2565): LicenseHandler::GetChkLicCode()C:\Program Files (x86)\Common Files\Intel\Licenses\w_MRKCWVF4.lic
ISSA(i) [13:54:57.760] | (5729.2596): LicenseHandler::GetChkLicCode() - File size : 758
ISSA(i) [13:54:57.760] | (5729.2606): LicenseHandler::GetChkLicCode() - Bytes read : 758
ISSA(i) [13:54:57.760] | (5729.2721): LicenseHandler::GetChkLicCode(): 0
ISSA(i) [13:54:57.760] | (5729.2565): LicenseHandler::GetChkLicCode()TS
ISSA(i) [13:54:57.760] | (5729.2689): LicenseHandler::GetChkLicCode(): "C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\fli\chklics.exe" -a -f"PerfAnlMID" -f"PerfAnlMIDW" -p"i86_n" -p"ia64_n"  -c"TS"
ISSA(i) [13:54:58.048] | (5729.2697): LicenseHandler::GetChkLicCode(): "C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\fli\chklics.exe" -a -f"PerfAnlMID" -f"PerfAnlMIDW" -p"i86_n" -p"ia64_n"  -c"TS"
ISSA(i) [13:54:58.048] | (5729.2721): LicenseHandler::GetChkLicCode(): 0
PSET(i) [13:54:58.048] | (3073.783): MsiOpenPackageEx(C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\indicator\indicator.msi)
MSI(i) [13:54:58.078] | === Verbose logging started: 4/8/2014  13:54:58  Build type: SHIP UNICODE 5.00.7601.00  Calling process: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\setup.exe ===
MSI(i) [13:54:58.078] | MSI (c) (B0:9C) [13:54:58:049]: SOFTWARE RESTRICTION POLICY: Verifying package --> 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\indicator\indicator.msi' against software restriction policy
MSI(i) [13:54:58.078] | MSI (c) (B0:9C) [13:54:58:049]: SOFTWARE RESTRICTION POLICY: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\indicator\indicator.msi has a digital signature
MSI(i) [13:54:58.078] | MSI (c) (B0:9C) [13:54:58:064]: SOFTWARE RESTRICTION POLICY: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\indicator\indicator.msi is permitted to run at the 'unrestricted' authorization level.
MSI(i) [13:54:58.078] | MSI (c) (B0:9C) [13:54:58:065]: Cloaking enabled.
MSI(i) [13:54:58.078] | MSI (c) (B0:9C) [13:54:58:065]: Attempting to enable all disabled privileges before calling Install on Server
MSI(i) [13:54:58.078] | MSI (c) (B0:9C) [13:54:58:065]: End dialog not enabled
MSI(i) [13:54:58.078] | MSI (c) (B0:9C) [13:54:58:065]: Original package ==> C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\indicator\indicator.msi
MSI(i) [13:54:58.078] | MSI (c) (B0:9C) [13:54:58:065]: Package we're running from ==> C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\indicator\indicator.msi
MSI(i) [13:54:58.078] | MSI (c) (B0:9C) [13:54:58:066]: APPCOMPAT: Compatibility mode property overrides found.
MSI(i) [13:54:58.078] | MSI (c) (B0:9C) [13:54:58:066]: APPCOMPAT: looking for appcompat database entry with ProductCode '{0C13F8EE-A432-495D-8F77-EDB3F3778D2D}'.
MSI(i) [13:54:58.078] | MSI (c) (B0:9C) [13:54:58:066]: APPCOMPAT: no matching ProductCode found in database.
MSI(i) [13:54:58.078] | MSI (c) (B0:9C) [13:54:58:068]: MSCOREE not loaded loading copy from system32
MSI(i) [13:54:58.078] | MSI (c) (B0:9C) [13:54:58:071]: Machine policy value 'TransformsSecure' is 0
MSI(i) [13:54:58.078] | MSI (c) (B0:9C) [13:54:58:071]: User policy value 'TransformsAtSource' is 0
MSI(i) [13:54:58.078] | MSI (c) (B0:9C) [13:54:58:072]: Note: 1: 2262 2: File 3: -2147287038
MSI(i) [13:54:58.078] | MSI (c) (B0:9C) [13:54:58:072]: Note: 1: 2205 2:  3: MsiFileHash
MSI(i) [13:54:58.078] | MSI (c) (B0:9C) [13:54:58:072]: Machine policy value 'DisablePatch' is 0
MSI(i) [13:54:58.078] | MSI (c) (B0:9C) [13:54:58:072]: Machine policy value 'AllowLockdownPatch' is 0
MSI(i) [13:54:58.078] | MSI (c) (B0:9C) [13:54:58:072]: Machine policy value 'DisableLUAPatching' is 0
MSI(i) [13:54:58.078] | MSI (c) (B0:9C) [13:54:58:072]: Machine policy value 'DisableFlyWeightPatching' is 0
MSI(i) [13:54:58.078] | MSI (c) (B0:9C) [13:54:58:072]: Enabling baseline caching for this transaction since all active patches are MSI 3.0 style MSPs or at least one MSI 3.0 minor update patch is active
MSI(i) [13:54:58.078] | MSI (c) (B0:9C) [13:54:58:072]: APPCOMPAT: looking for appcompat database entry with ProductCode '{0C13F8EE-A432-495D-8F77-EDB3F3778D2D}'.
MSI(i) [13:54:58.078] | MSI (c) (B0:9C) [13:54:58:072]: APPCOMPAT: no matching ProductCode found in database.
MSI(i) [13:54:58.078] | MSI (c) (B0:9C) [13:54:58:072]: Transforms are not secure.
MSI(i) [13:54:58.078] | MSI (c) (B0:9C) [13:54:58:072]: PROPERTY CHANGE: Adding MsiLogFileLocation property. Its value is 'C:\Users\PCCA-PM\AppData\Local\Temp\MSIED31.tmp'.
MSI(i) [13:54:58.078] | MSI (c) (B0:9C) [13:54:58:072]: No Command Line.
MSI(i) [13:54:58.078] | MSI (c) (B0:9C) [13:54:58:072]: PROPERTY CHANGE: Adding PackageCode property. Its value is '{F7333571-5276-4BF4-A6E2-695FDAC1CD7F}'.
MSI(i) [13:54:58.078] | MSI (c) (B0:9C) [13:54:58:072]: Product Code passed to Engine.Initialize:           '(none)'
MSI(i) [13:54:58.078] | MSI (c) (B0:9C) [13:54:58:072]: Product Code from property table before transforms: '{0C13F8EE-A432-495D-8F77-EDB3F3778D2D}'
MSI(i) [13:54:58.078] | MSI (c) (B0:9C) [13:54:58:072]: Product Code from property table after transforms:  '{0C13F8EE-A432-495D-8F77-EDB3F3778D2D}'
MSI(i) [13:54:58.078] | MSI (c) (B0:9C) [13:54:58:072]: Product not registered: beginning first-time install
MSI(i) [13:54:58.078] | MSI (c) (B0:9C) [13:54:58:072]: PROPERTY CHANGE: Adding ProductState property. Its value is '-1'.
MSI(i) [13:54:58.078] | MSI (c) (B0:9C) [13:54:58:073]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer 3: 2
MSI(i) [13:54:58.078] | MSI (c) (B0:9C) [13:54:58:073]: Entering CMsiConfigurationManager::SetLastUsedSource.
MSI(i) [13:54:58.078] | MSI (c) (B0:9C) [13:54:58:073]: User policy value 'SearchOrder' is 'nmu'
MSI(i) [13:54:58.078] | MSI (c) (B0:9C) [13:54:58:073]: Adding new sources is allowed.
MSI(i) [13:54:58.078] | MSI (c) (B0:9C) [13:54:58:073]: PROPERTY CHANGE: Adding PackagecodeChanging property. Its value is '1'.
MSI(i) [13:54:58.078] | MSI (c) (B0:9C) [13:54:58:073]: Package name extracted from package path: 'indicator.msi'
MSI(i) [13:54:58.078] | MSI (c) (B0:9C) [13:54:58:073]: Package to be registered: 'indicator.msi'
MSI(i) [13:54:58.078] | MSI (c) (B0:9C) [13:54:58:073]: Note: 1: 2205 2:  3: Error
MSI(i) [13:54:58.078] | MSI (c) (B0:9C) [13:54:58:074]: Note: 1: 2262 2: AdminProperties 3: -2147287038
MSI(i) [13:54:58.078] | MSI (c) (B0:9C) [13:54:58:074]: Machine policy value 'DisableMsi' is 0
MSI(i) [13:54:58.078] | MSI (c) (B0:9C) [13:54:58:074]: Machine policy value 'AlwaysInstallElevated' is 0
MSI(i) [13:54:58.078] | MSI (c) (B0:9C) [13:54:58:074]: User policy value 'AlwaysInstallElevated' is 0
MSI(i) [13:54:58.078] | MSI (c) (B0:9C) [13:54:58:074]: Product installation will be elevated because user is admin and product is being installed per-machine.
MSI(i) [13:54:58.078] | MSI (c) (B0:9C) [13:54:58:074]: Running product '{0C13F8EE-A432-495D-8F77-EDB3F3778D2D}' with elevated privileges: Product is assigned.
MSI(i) [13:54:58.078] | MSI (c) (B0:9C) [13:54:58:074]: PROPERTY CHANGE: Adding MsiSystemRebootPending property. Its value is '1'.
MSI(i) [13:54:58.078] | MSI (c) (B0:9C) [13:54:58:074]: TRANSFORMS property is now:
MSI(i) [13:54:58.078] | MSI (c) (B0:9C) [13:54:58:074]: PROPERTY CHANGE: Adding VersionDatabase property. Its value is '200'.
MSI(i) [13:54:58.078] | MSI (c) (B0:9C) [13:54:58:074]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming
MSI(i) [13:54:58.078] | MSI (c) (B0:9C) [13:54:58:074]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Favorites
MSI(i) [13:54:58.078] | MSI (c) (B0:9C) [13:54:58:074]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Network Shortcuts
MSI(i) [13:54:58.078] | MSI (c) (B0:9C) [13:54:58:074]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Documents
MSI(i) [13:54:58.078] | MSI (c) (B0:9C) [13:54:58:074]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
MSI(i) [13:54:58.078] | MSI (c) (B0:9C) [13:54:58:074]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Recent
MSI(i) [13:54:58.078] | MSI (c) (B0:9C) [13:54:58:074]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\SendTo
MSI(i) [13:54:58.078] | MSI (c) (B0:9C) [13:54:58:074]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Templates
MSI(i) [13:54:58.078] | MSI (c) (B0:9C) [13:54:58:074]: SHELL32::SHGetFolderPath returned: C:\ProgramData
MSI(i) [13:54:58.078] | MSI (c) (B0:9C) [13:54:58:074]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Local
MSI(i) [13:54:58.078] | MSI (c) (B0:9C) [13:54:58:074]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Pictures
MSI(i) [13:54:58.078] | MSI (c) (B0:9C) [13:54:58:074]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI(i) [13:54:58.078] | MSI (c) (B0:9C) [13:54:58:074]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
MSI(i) [13:54:58.078] | MSI (c) (B0:9C) [13:54:58:074]: SHELL32::SHGetFolderPath returned: C:\Users\Public\Desktop
MSI(i) [13:54:58.078] | MSI (c) (B0:9C) [13:54:58:074]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI(i) [13:54:58.078] | MSI (c) (B0:9C) [13:54:58:074]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
MSI(i) [13:54:58.079] | MSI (c) (B0:9C) [13:54:58:074]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Start Menu\Programs
MSI(i) [13:54:58.079] | MSI (c) (B0:9C) [13:54:58:074]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Desktop
MSI(i) [13:54:58.079] | MSI (c) (B0:9C) [13:54:58:075]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Templates
MSI(i) [13:54:58.079] | MSI (c) (B0:9C) [13:54:58:075]: SHELL32::SHGetFolderPath returned: C:\Windows\Fonts
MSI(i) [13:54:58.079] | MSI (c) (B0:9C) [13:54:58:075]: Note: 1: 2898 2: MS Sans Serif 3: MS Sans Serif 4: 0 5: 16
MSI(i) [13:54:58.079] | MSI (c) (B0:9C) [13:54:58:077]: MSI_LUA: Setting AdminUser property to 1 because this is the client or the user has already permitted elevation
MSI(i) [13:54:58.079] | MSI (c) (B0:9C) [13:54:58:077]: MSI_LUA: Setting MsiRunningElevated property to 1 because the install is already running elevated.
MSI(i) [13:54:58.079] | MSI (c) (B0:9C) [13:54:58:077]: PROPERTY CHANGE: Adding MsiRunningElevated property. Its value is '1'.
MSI(i) [13:54:58.079] | MSI (c) (B0:9C) [13:54:58:077]: PROPERTY CHANGE: Adding Privileged property. Its value is '1'.
MSI(i) [13:54:58.079] | MSI (c) (B0:9C) [13:54:58:077]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\MS Setup (ACME)\User Info 3: 2
MSI(i) [13:54:58.079] | MSI (c) (B0:9C) [13:54:58:077]: PROPERTY CHANGE: Adding USERNAME property. Its value is 'A Valued IT Customer'.
MSI(i) [13:54:58.079] | MSI (c) (B0:9C) [13:54:58:077]: PROPERTY CHANGE: Adding COMPANYNAME property. Its value is 'Intel Corporation'.
MSI(i) [13:54:58.079] | MSI (c) (B0:9C) [13:54:58:077]: PROPERTY CHANGE: Adding DATABASE property. Its value is 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\indicator\indicator.msi'.
MSI(i) [13:54:58.079] | MSI (c) (B0:9C) [13:54:58:077]: PROPERTY CHANGE: Adding OriginalDatabase property. Its value is 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\indicator\indicator.msi'.
MSI(i) [13:54:58.079] | MSI (c) (B0:9C) [13:54:58:077]: Machine policy value 'MsiDisableEmbeddedUI' is 0
MSI(i) [13:54:58.079] | MSI (c) (B0:9C) [13:54:58:078]: EEUI - Disabling MsiEmbeddedUI in quiet mode
MSI(i) [13:54:58.079] | === Logging started: 4/8/2014  13:54:58 ===
MSI(i) [13:54:58.079] | MSI (c) (B0:9C) [13:54:58:078]: Note: 1: 2205 2:  3: PatchPackage
MSI(i) [13:54:58.079] | MSI (c) (B0:9C) [13:54:58:078]: Machine policy value 'DisableRollback' is 0
MSI(i) [13:54:58.079] | MSI (c) (B0:9C) [13:54:58:078]: User policy value 'DisableRollback' is 0
MSI(i) [13:54:58.079] | MSI (c) (B0:9C) [13:54:58:078]: PROPERTY CHANGE: Adding UILevel property. Its value is '2'.
MSI(i) [13:54:58.079] | MSI (c) (B0:9C) [13:54:58:078]: Creating MSIHANDLE (113) of type 790537 for thread 3996
MSI(i) [13:54:58.079] | MSI (c) (B0:9C) [13:54:58:078]: MsiOpenPackageEx is returning 0
MSI(i) [13:54:58.079] | MSI (c) (B0:9C) [13:54:58:078]: Closing MSIHANDLE (113) of type 790537 for thread 3996
MSI(i) [13:54:58.079] | === Verbose logging stopped: 4/8/2014  13:54:58 ===
PSET(i) [13:55:05.983] | (673.430): InitPlugins(true)
PSET(i) [13:55:05.984] | (673.167): ResetNeedforCheckFlags
PSET(i) [13:55:05.984] | (4225.1157): msi package: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\Setup\setup.msi
PSET(i) [13:55:05.984] | (4225.1158): LicIsValid: 1     InstallOnCurrentArch: 1     Installed State: -1     Pending Action: 3
PSET(i) [13:55:05.984] | (673.178): UpdateNeedforCheck {ACD97E2A-090D-46ea-9983-6E44BCA28575}: Need
UNK(i) [13:55:06.001] |
Plugin psetlogger is initialized.
UNK(i) [13:55:06.001] | pset::abstract_context(context == pset::ContextInfo(eInstallMode == INSTALL_MODE_TYPICAL, iLog == ptr(0x1563f74), lLocaleID == size_t("1033"), sCurrentArchitecture == String("Intel64"), sLicenseFiles == String(""), sVSPackageNumber == String(""), sPathToLocaleFileFolder == String("C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\1033\"), sSerialNumber == String("")))
UNK(i) [13:55:06.001] | pset::abstract_context() return: deps::Context(mode == INSTALL, silent == bool(false), upfront == bool(false), full == bool(false), locale == int("0"))
UNK(i) [13:55:06.001] | Main(id == {ACD97E2A-090D-46ea-9983-6E44BCA28575}, severity == 0, message == ptr(0x16f068))
UNK(i) [13:55:06.001] | Main(): Check dependencies
UNK(i) [13:55:06.001] | Main(): exit with severity == DependencyCode(0), message == String("")
PSET(i) [13:55:06.001] | (673.118): Check Dependency for {ACD97E2A-090D-46ea-9983-6E44BCA28575}: 0
PSET(i) [13:55:06.001] | (4225.1157): msi package: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\indicator\indicator.msi
PSET(i) [13:55:06.001] | (4225.1158): LicIsValid: 1     InstallOnCurrentArch: 1     Installed State: -1     Pending Action: 3
UNK(i) [13:55:06.002] |
UNK(i) [13:55:06.002] | pset::abstract_context(context == pset::ContextInfo(eInstallMode == INSTALL_MODE_TYPICAL, iLog == ptr(0x1563f74), lLocaleID == size_t("1033"), sCurrentArchitecture == String("Intel64"), sLicenseFiles == String(""), sVSPackageNumber == String(""), sPathToLocaleFileFolder == String("C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\1033\"), sSerialNumber == String("")))
UNK(i) [13:55:06.002] | pset::abstract_context() return: deps::Context(mode == INSTALL, silent == bool(false), upfront == bool(false), full == bool(false), locale == int("0"))
UNK(i) [13:55:06.002] | Main(id == {ACD97E2A-090D-46ea-9983-6E44BCA28575}, severity == 0, message == ptr(0x16f068))
UNK(i) [13:55:06.002] | Main(): Check dependencies
UNK(i) [13:55:06.002] | Main(): exit with severity == DependencyCode(0), message == String("")
PSET(i) [13:55:06.002] | (673.118): Check Dependency for {ACD97E2A-090D-46ea-9983-6E44BCA28575}: 0
PSET(i) [13:55:06.002] | (4225.1157): msi package: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\ps_he_cli\ps_he_cli.msi
PSET(i) [13:55:06.002] | (4225.1158): LicIsValid: 1     InstallOnCurrentArch: 1     Installed State: -1     Pending Action: 3
PSET(i) [13:55:06.002] | (673.178): UpdateNeedforCheck {ACD97E2A-090D-46ea-9983-6E44BCA28575}: Need
PSET(i) [13:55:06.002] | (4225.1157): msi package: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\ps_he_gui\ps_he_gui.msi
UNK(i) [13:55:06.003] | Main(id == {ACD97E2A-090D-46ea-9983-6E44BCA28575}, severity == 0, message == ptr(0x16f068))
UNK(i) [13:55:06.003] | Main(): Check dependencies
UNK(i) [13:55:06.003] | Main(): exit with severity == DependencyCode(0), message == String("")
PSET(i) [13:55:06.003] | (673.118): Check Dependency for {ACD97E2A-090D-46ea-9983-6E44BCA28575}: 0
PSET(i) [13:55:06.003] | (4225.1157): msi package: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\sep\sep.msi
PSET(i) [13:55:06.003] | (4225.1158): LicIsValid: 1     InstallOnCurrentArch: 1     Installed State: -1     Pending Action: 3
PSET(i) [13:55:06.003] | (673.178): UpdateNeedforCheck {ACD97E2A-090D-46ea-9983-6E44BCA28575}: Need
PSET(i) [13:55:06.003] | (673.178): UpdateNeedforCheck {8AA98789-C136-4adc-8269-86F3C222906F}: Need
UNK(i) [13:55:06.003] | pset::abstract_context(context == pset::ContextInfo(eInstallMode == INSTALL_MODE_TYPICAL, iLog == ptr(0x1563f74), lLocaleID == size_t("1033"), sCurrentArchitecture == String("Intel64"), sLicenseFiles == String(""), sVSPackageNumber == String(""), sPathToLocaleFileFolder == String("C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\1033\"), sSerialNumber == String("")))
UNK(i) [13:55:06.003] | pset::abstract_context() return: deps::Context(mode == INSTALL, silent == bool(false), upfront == bool(false), full == bool(false), locale == int("0"))
UNK(i) [13:55:06.003] | Main(id == {8AA98789-C136-4adc-8269-86F3C222906F}, severity == 0, message == ptr(0x16f068))
UNK(i) [13:55:06.003] | Platform::Platform()
UNK(i) [13:55:06.003] |     getting system informtaion...
UNK(i) [13:55:06.003] |     Detect if this is WOW64 process...
UNK(i) [13:55:06.003] |     kernel32.dll has function IsWow64Process() so this is 64-bit system.
UNK(i) [13:55:06.003] |     call IsWow64Process().
UNK(i) [13:55:06.003] |     result == TRUE
UNK(i) [13:55:06.003] |     get address for GetNativeSystemInfo()
UNK(i) [13:55:06.003] |     function found. Use it instead of GetSystemInfo().
UNK(i) [13:55:06.003] |     call API to get system information.
UNK(i) [13:55:06.003] |     detect CPU arcitecture
UNK(i) [13:55:06.003] |     cpu Arch == INTEL64
UNK(i) [13:55:06.003] |     detect if SSE2 (cpu feature PF_XMMI64_INSTRUCTIONS_AVAILABLE) present
UNK(i) [13:55:06.003] |     result == bool(true)
UNK(i) [13:55:06.003] |     detect CPU is Genuine Intel.
UNK(i) [13:55:06.003] |     Call SEP_CPU_Check. CPU Sampling capability is bool(true)
UNK(i) [13:55:06.003] |     Detecting OS version
UNK(i) [13:55:06.003] |     OS version == OSVer(os_major == 6, os_minor == 1, sp_major == 1, sp_minor == 0)
UNK(i) [13:55:06.003] |     OS type == workstation
UNK(i) [13:55:06.003] |     Detecting OS name reading HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion:ProductName
UNK(i) [13:55:06.004] |     OS name from registry == Windows 7 Enterprise
UNK(i) [13:55:06.004] |     appending version, new name == Windows 7 Enterprise Service Pack 1
UNK(i) [13:55:06.004] |     remove trade marks from OS name
UNK(i) [13:55:06.004] |     new name == Windows* 7 Enterprise Service Pack 1
UNK(i) [13:55:06.004] |     make _os_name ready to print
UNK(i) [13:55:06.004] |     detect if user has admin rights
UNK(i) [13:55:06.004] |     succeed to open 'HKEY_LOCAL_MACHINE\SOFTWARE' in KEY_WRITE mode => user has admin rights
UNK(i) [13:55:06.004] |     return;
UNK(i) [13:55:06.004] | Main(): exit with severity == DependencyCode(0), message == String("")
PSET(i) [13:55:06.004] | (673.118): Check Dependency for {8AA98789-C136-4adc-8269-86F3C222906F}: 0
PSET(i) [13:55:06.004] | (4225.1157): msi package: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs11-integration.msi
PSET(i) [13:55:06.004] | (4225.1158): LicIsValid: 1     InstallOnCurrentArch: 1     Installed State: -1     Pending Action: 3
PSET(i) [13:55:06.004] | (673.178): UpdateNeedforCheck {ACD97E2A-090D-46ea-9983-6E44BCA28575}: Need
PSET(i) [13:55:06.004] | (673.178): UpdateNeedforCheck {E3BA8A13-2647-4c01-81D5-77E6D912D9D5}: Need
PSET(i) [13:55:06.004] | (673.178): UpdateNeedforCheck {D52A1D2E-8D7A-4822-9421-3A92C64DB956}: Need
UNK(i) [13:55:06.004] | pset::abstract_context(context == pset::ContextInfo(eInstallMode == INSTALL_MODE_TYPICAL, iLog == ptr(0x1563f74), lLocaleID == size_t("1033"), sCurrentArchitecture == String("Intel64"), sLicenseFiles == String(""), sVSPackageNumber == String(""), sPathToLocaleFileFolder == String("C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\1033\"), sSerialNumber == String("")))
UNK(i) [13:55:06.004] | pset::abstract_context() return: deps::Context(mode == INSTALL, silent == bool(false), upfront == bool(false), full == bool(false), locale == int("0"))
UNK(i) [13:55:06.004] | Main(id == {ACD97E2A-090D-46ea-9983-6E44BCA28575}, severity == 0, message == ptr(0x16f068))
UNK(i) [13:55:06.004] | Main(): Check dependencies
PSET(i) [13:55:06.004] | (673.118): Check Dependency for {ACD97E2A-090D-46ea-9983-6E44BCA28575}: 0
UNK(i) [13:55:06.005] | Main(id == {D52A1D2E-8D7A-4822-9421-3A92C64DB956}, severity == 0, message == ptr(0x16f068))
UNK(i) [13:55:06.005] | Main(): Check if need to show VS Integration dialog
UNK(i) [13:55:06.005] | Main(): Enable dialog
UNK(i) [13:55:06.005] | Main(): exit with severity == MISSING_DEPENDENCY_NO_SUMMARY, message == String("")
PSET(i) [13:55:06.005] | (673.118): Check Dependency for {D52A1D2E-8D7A-4822-9421-3A92C64DB956}: 12032
UNK(i) [13:55:06.005] | pset::abstract_context(context == pset::ContextInfo(eInstallMode == INSTALL_MODE_TYPICAL, iLog == ptr(0x1563f74), lLocaleID == size_t("1033"), sCurrentArchitecture == String("Intel64"), sLicenseFiles == String(""), sVSPackageNumber == String(""), sPathToLocaleFileFolder == String("C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\1033\"), sSerialNumber == String("")))
UNK(i) [13:55:06.005] | pset::abstract_context() return: deps::Context(mode == INSTALL, silent == bool(false), upfront == bool(false), full == bool(false), locale == int("0"))
UNK(i) [13:55:06.005] | Main(id == {E3BA8A13-2647-4c01-81D5-77E6D912D9D5}, severity == 0, message == ptr(0x16f068))
UNK(i) [13:55:06.005] | Main(): disable VS 11
UNK(i) [13:55:06.005] | Main(): exit with severity == MISSING_DEPENDENCY_COMPONENT_DISABLED, message == String("")
PSET(i) [13:55:06.005] | (673.118): Check Dependency for {E3BA8A13-2647-4c01-81D5-77E6D912D9D5}: 12021
UNK(i) [13:55:06.006] | Main(id == {8AA98789-C136-4adc-8269-86F3C222906F}, severity == 0, message == ptr(0x16f068))
UNK(i) [13:55:06.006] | Main(): exit with severity == DependencyCode(0), message == String("")
PSET(i) [13:55:06.006] | (673.118): Check Dependency for {8AA98789-C136-4adc-8269-86F3C222906F}: 0
PSET(i) [13:55:06.006] | (4225.1224): Disabled C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs11-integration.msi
PSET(i) [13:55:06.006] | (4225.285): MsiOpenPackageEx(C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs11-integration.msi)
PSET(i) [13:55:06.074] | (6497.173): Feature=core PendingAction=5, Action=3
PSET(i) [13:55:06.074] | (6497.176): Call MsiSetFeatureState(core)
MSI(i) [13:55:06.074] | === Verbose logging started: 4/8/2014  13:55:06  Build type: SHIP UNICODE 5.00.7601.00  Calling process: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\setup.exe ===
MSI(i) [13:55:06.074] | MSI (c) (B0:9C) [13:55:06:008]: SOFTWARE RESTRICTION POLICY: Verifying package --> 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs11-integration.msi' against software restriction policy
MSI(i) [13:55:06.074] | MSI (c) (B0:9C) [13:55:06:008]: SOFTWARE RESTRICTION POLICY: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs11-integration.msi has a digital signature
MSI(i) [13:55:06.074] | MSI (c) (B0:9C) [13:55:06:030]: SOFTWARE RESTRICTION POLICY: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs11-integration.msi is permitted to run at the 'unrestricted' authorization level.
MSI(i) [13:55:06.074] | MSI (c) (B0:9C) [13:55:06:031]: Cloaking enabled.
MSI(i) [13:55:06.074] | MSI (c) (B0:9C) [13:55:06:031]: Attempting to enable all disabled privileges before calling Install on Server
MSI(i) [13:55:06.074] | MSI (c) (B0:9C) [13:55:06:032]: End dialog not enabled
MSI(i) [13:55:06.074] | MSI (c) (B0:9C) [13:55:06:032]: Original package ==> C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs11-integration.msi
MSI(i) [13:55:06.074] | MSI (c) (B0:9C) [13:55:06:032]: Package we're running from ==> C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs11-integration.msi
MSI(i) [13:55:06.074] | MSI (c) (B0:9C) [13:55:06:033]: APPCOMPAT: Compatibility mode property overrides found.
MSI(i) [13:55:06.074] | MSI (c) (B0:9C) [13:55:06:034]: APPCOMPAT: looking for appcompat database entry with ProductCode '{CB6E4A97-57E7-4D4D-BE5F-049DBD5380FB}'.
MSI(i) [13:55:06.074] | MSI (c) (B0:9C) [13:55:06:034]: APPCOMPAT: no matching ProductCode found in database.
MSI(i) [13:55:06.074] | MSI (c) (B0:9C) [13:55:06:035]: MSCOREE not loaded loading copy from system32
MSI(i) [13:55:06.074] | MSI (c) (B0:9C) [13:55:06:039]: Machine policy value 'TransformsSecure' is 0
MSI(i) [13:55:06.074] | MSI (c) (B0:9C) [13:55:06:039]: User policy value 'TransformsAtSource' is 0
MSI(i) [13:55:06.074] | MSI (c) (B0:9C) [13:55:06:039]: Machine policy value 'DisablePatch' is 0
MSI(i) [13:55:06.074] | MSI (c) (B0:9C) [13:55:06:039]: Machine policy value 'AllowLockdownPatch' is 0
MSI(i) [13:55:06.074] | MSI (c) (B0:9C) [13:55:06:039]: Machine policy value 'DisableLUAPatching' is 0
MSI(i) [13:55:06.074] | MSI (c) (B0:9C) [13:55:06:039]: Machine policy value 'DisableFlyWeightPatching' is 0
MSI(i) [13:55:06.074] | MSI (c) (B0:9C) [13:55:06:039]: Enabling baseline caching for this transaction since all active patches are MSI 3.0 style MSPs or at least one MSI 3.0 minor update patch is active
MSI(i) [13:55:06.074] | MSI (c) (B0:9C) [13:55:06:041]: APPCOMPAT: looking for appcompat database entry with ProductCode '{CB6E4A97-57E7-4D4D-BE5F-049DBD5380FB}'.
MSI(i) [13:55:06.074] | MSI (c) (B0:9C) [13:55:06:041]: APPCOMPAT: no matching ProductCode found in database.
MSI(i) [13:55:06.074] | MSI (c) (B0:9C) [13:55:06:041]: Transforms are not secure.
MSI(i) [13:55:06.074] | MSI (c) (B0:9C) [13:55:06:041]: PROPERTY CHANGE: Adding MsiLogFileLocation property. Its value is 'C:\Users\PCCA-PM\AppData\Local\Temp\MSIED31.tmp'.
MSI(i) [13:55:06.074] | MSI (c) (B0:9C) [13:55:06:041]: No Command Line.
MSI(i) [13:55:06.074] | MSI (c) (B0:9C) [13:55:06:041]: PROPERTY CHANGE: Adding PackageCode property. Its value is '{48FA2B8E-7BDC-4397-B438-CF8C749F1392}'.
MSI(i) [13:55:06.074] | MSI (c) (B0:9C) [13:55:06:041]: Product Code passed to Engine.Initialize:           '(none)'
MSI(i) [13:55:06.074] | MSI (c) (B0:9C) [13:55:06:041]: Product Code from property table before transforms: '{CB6E4A97-57E7-4D4D-BE5F-049DBD5380FB}'
MSI(i) [13:55:06.074] | MSI (c) (B0:9C) [13:55:06:041]: Product Code from property table after transforms:  '{CB6E4A97-57E7-4D4D-BE5F-049DBD5380FB}'
MSI(i) [13:55:06.074] | MSI (c) (B0:9C) [13:55:06:041]: Product not registered: beginning first-time install
MSI(i) [13:55:06.074] | MSI (c) (B0:9C) [13:55:06:041]: PROPERTY CHANGE: Adding ProductState property. Its value is '-1'.
MSI(i) [13:55:06.074] | MSI (c) (B0:9C) [13:55:06:041]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer 3: 2
MSI(i) [13:55:06.074] | MSI (c) (B0:9C) [13:55:06:041]: Entering CMsiConfigurationManager::SetLastUsedSource.
MSI(i) [13:55:06.074] | MSI (c) (B0:9C) [13:55:06:041]: User policy value 'SearchOrder' is 'nmu'
MSI(i) [13:55:06.074] | MSI (c) (B0:9C) [13:55:06:041]: Adding new sources is allowed.
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:041]: PROPERTY CHANGE: Adding PackagecodeChanging property. Its value is '1'.
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:041]: Package name extracted from package path: 'vs11-integration.msi'
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:042]: Package to be registered: 'vs11-integration.msi'
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:042]: Note: 1: 2205 2:  3: Error
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:042]: Note: 1: 2262 2: AdminProperties 3: -2147287038
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:042]: Machine policy value 'DisableMsi' is 0
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:042]: Machine policy value 'AlwaysInstallElevated' is 0
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:042]: User policy value 'AlwaysInstallElevated' is 0
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:042]: Product installation will be elevated because user is admin and product is being installed per-machine.
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:042]: Running product '{CB6E4A97-57E7-4D4D-BE5F-049DBD5380FB}' with elevated privileges: Product is assigned.
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:043]: PROPERTY CHANGE: Adding MsiSystemRebootPending property. Its value is '1'.
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:043]: TRANSFORMS property is now:
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:043]: PROPERTY CHANGE: Adding VersionDatabase property. Its value is '200'.
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:043]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:043]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Favorites
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:043]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Network Shortcuts
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:043]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Documents
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:043]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:043]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Recent
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:043]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\SendTo
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:043]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Templates
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:043]: SHELL32::SHGetFolderPath returned: C:\ProgramData
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:043]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Local
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:043]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Pictures
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:043]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:043]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:043]: SHELL32::SHGetFolderPath returned: C:\Users\Public\Desktop
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:043]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:043]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:043]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Desktop
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:043]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Templates
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:043]: SHELL32::SHGetFolderPath returned: C:\Windows\Fonts
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:044]: Note: 1: 2898 2: MS Sans Serif 3: MS Sans Serif 4: 0 5: 16
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:046]: MSI_LUA: Setting AdminUser property to 1 because this is the client or the user has already permitted elevation
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:046]: MSI_LUA: Setting MsiRunningElevated property to 1 because the install is already running elevated.
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:046]: PROPERTY CHANGE: Adding MsiRunningElevated property. Its value is '1'.
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:046]: PROPERTY CHANGE: Adding Privileged property. Its value is '1'.
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:046]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\MS Setup (ACME)\User Info 3: 2
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:046]: PROPERTY CHANGE: Adding USERNAME property. Its value is 'A Valued IT Customer'.
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:046]: PROPERTY CHANGE: Adding COMPANYNAME property. Its value is 'Intel Corporation'.
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:046]: PROPERTY CHANGE: Adding DATABASE property. Its value is 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs11-integration.msi'.
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:046]: PROPERTY CHANGE: Adding OriginalDatabase property. Its value is 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs11-integration.msi'.
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:046]: Machine policy value 'MsiDisableEmbeddedUI' is 0
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:046]: EEUI - Disabling MsiEmbeddedUI in quiet mode
MSI(i) [13:55:06.075] | === Logging started: 4/8/2014  13:55:06 ===
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:047]: Note: 1: 2205 2:  3: PatchPackage
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:047]: Machine policy value 'DisableRollback' is 0
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:047]: User policy value 'DisableRollback' is 0
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:047]: PROPERTY CHANGE: Adding UILevel property. Its value is '2'.
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:047]: Creating MSIHANDLE (114) of type 790537 for thread 3996
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:047]: MsiOpenPackageEx is returning 0
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:047]: Creating MSIHANDLE (115) of type 790541 for thread 3996
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:047]: Closing MSIHANDLE (115) of type 790541 for thread 3996
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:047]: Doing action: AppSearch
MSI(i) [13:55:06.075] | Action 13:55:06: AppSearch. Searching for installed applications
MSI(i) [13:55:06.075] | Action start 13:55:06: AppSearch.
MSI(i) [13:55:06.075] | AppSearch: Property: VS2011DIR.CB8456D7_A5A6_433A_9944_81F5DB2663E7, Signature: SIG_VS2011_DIR.CB8456D7_A5A6_433A_9944_81F5DB2663E7
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:049]: Note: 1: 2262 2: Signature 3: -2147287038
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:049]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE32\SOFTWARE\Microsoft\VisualStudio\11.0\Setup\VS 3: 2
MSI(i) [13:55:06.075] | AppSearch: Property: VS2010DIR.CB8456D7_A5A6_433A_9944_81F5DB2663E7, Signature: SIG_VS2010_DIR.CB8456D7_A5A6_433A_9944_81F5DB2663E7
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:049]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE32\SOFTWARE\Microsoft\VisualStudio\10.0\Setup\VS 3: 2
MSI(i) [13:55:06.075] | AppSearch: Property: DEVENV_EXE_2008.C4A469D8_5FD7_462C_AAF9_27CC6BDF6210, Signature: RL_DevenvExe_2008.C4A469D8_5FD7_462C_AAF9_27CC6BDF6210
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:049]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE32\SOFTWARE\Microsoft\VisualStudio\9.0\Setup\VS 3: 2
MSI(i) [13:55:06.075] | AppSearch: Property: DEVENV_EXE_2010.C4A469D8_5FD7_462C_AAF9_27CC6BDF6210, Signature: RL_DevenvExe_2010.C4A469D8_5FD7_462C_AAF9_27CC6BDF6210
MSI(i) [13:55:06.075] | AppSearch: Property: DEVENV_EXE_2011.C4A469D8_5FD7_462C_AAF9_27CC6BDF6210, Signature: RL_DevenvExe_2011.C4A469D8_5FD7_462C_AAF9_27CC6BDF6210
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:050]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE32\SOFTWARE\Microsoft\VisualStudio\11.0\Setup\VS 3: 2
MSI(i) [13:55:06.075] | Action ended 13:55:06: AppSearch. Return value 1.
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:050]: Doing action: CostInitialize
MSI(i) [13:55:06.075] | Action 13:55:06: CostInitialize. Computing space requirements
MSI(i) [13:55:06.075] | Action start 13:55:06: CostInitialize.
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:051]: Machine policy value 'MaxPatchCacheSize' is 10
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:051]: Baseline: Sorting baselines for {CB6E4A97-57E7-4D4D-BE5F-049DBD5380FB}.
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:051]: Baseline: New baseline 13.1.5000 from transaction.
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:051]: Baseline: Sorted order Native: Order 0.
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:051]: Baseline Data Table:
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:051]: ProductCode: {CB6E4A97-57E7-4D4D-BE5F-049DBD5380FB} Version: 13.1.5000 Attributes: 0 PatchId: Native BaselineId: -2147483648 Order: 0
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:051]: Baseline File Table:
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:052]: PROPERTY CHANGE: Adding ROOTDRIVE property. Its value is 'C:\'.
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:052]: PROPERTY CHANGE: Adding CostingComplete property. Its value is '0'.
MSI(i) [13:55:06.075] | Action ended 13:55:06: CostInitialize. Return value 1.
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:052]: Doing action: FileCost
MSI(i) [13:55:06.075] | Action 13:55:06: FileCost. Computing space requirements
MSI(i) [13:55:06.075] | Action start 13:55:06: FileCost.
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:053]: Note: 1: 2205 2:  3: MsiAssembly
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:053]: Note: 1: 2205 2:  3: Class
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:053]: Note: 1: 2205 2:  3: Extension
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:053]: Note: 1: 2205 2:  3: TypeLib
MSI(i) [13:55:06.075] | Action ended 13:55:06: FileCost. Return value 1.
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:053]: Doing action: CostFinalize
MSI(i) [13:55:06.075] | Action 13:55:06: CostFinalize. Computing space requirements
MSI(i) [13:55:06.075] | Action start 13:55:06: CostFinalize.
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:055]: PROPERTY CHANGE: Adding OutOfDiskSpace property. Its value is '0'.
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:055]: PROPERTY CHANGE: Adding OutOfNoRbDiskSpace property. Its value is '0'.
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:055]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceAvailable property. Its value is '0'.
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:055]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRequired property. Its value is '0'.
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:055]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRemaining property. Its value is '0'.
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:055]: Note: 1: 2205 2:  3: Patch
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:055]: Note: 1: 2205 2:  3: Condition
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:055]: PROPERTY CHANGE: Adding TARGETDIR property. Its value is 'C:\'.
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:055]: PROPERTY CHANGE: Adding VS11_REMOTE_DEBUGGER_X64_DIR property. Its value is 'C:\'.
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:055]: PROPERTY CHANGE: Adding VS11_DEBUGER_DIR property. Its value is 'C:\'.
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:055]: PROPERTY CHANGE: Adding INSTALLDIR property. Its value is 'C:\'.
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:055]: PROPERTY CHANGE: Adding CommonFilesFolder.C4A469D8_5FD7_462C_AAF9_27CC6BDF6210 property. Its value is 'C:\'.
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:055]: PROPERTY CHANGE: Adding CmnIntel.C4A469D8_5FD7_462C_AAF9_27CC6BDF6210 property. Its value is 'C:\Intel\'.
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:055]: PROPERTY CHANGE: Adding CmnIntelHEBundle.C4A469D8_5FD7_462C_AAF9_27CC6BDF6210 property. Its value is 'C:\Intel\Parallel Studio XE 2013\'.
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:055]: PROPERTY CHANGE: Adding HEBundleMenuDir.C4A469D8_5FD7_462C_AAF9_27CC6BDF6210 property. Its value is 'C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Intel Parallel Studio XE 2013\'.
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:055]: PROPERTY CHANGE: Adding CommonFilesFolder.95C3848C_D156_4249_942C_7A8A0976584F property. Its value is 'C:\'.
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:055]: PROPERTY CHANGE: Adding CmnIntel.95C3848C_D156_4249_942C_7A8A0976584F property. Its value is 'C:\Intel\'.
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:055]: PROPERTY CHANGE: Adding CmnIntelHEBundle.95C3848C_D156_4249_942C_7A8A0976584F property. Its value is 'C:\Intel\Parallel Studio XE 2013\'.
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:055]: PROPERTY CHANGE: Adding VS2011DIR.CB8456D7_A5A6_433A_9944_81F5DB2663E7 property. Its value is 'C:\Program Files (x86)\VS2011DIR\'.
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:055]: PROPERTY CHANGE: Adding Common70.CB8456D7_A5A6_433A_9944_81F5DB2663E7 property. Its value is 'C:\Program Files (x86)\VS2011DIR\Common7\'.
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:055]: PROPERTY CHANGE: Adding IDE0.CB8456D7_A5A6_433A_9944_81F5DB2663E7 property. Its value is 'C:\Program Files (x86)\VS2011DIR\Common7\IDE\'.
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:055]: PROPERTY CHANGE: Adding Extensions0.CB8456D7_A5A6_433A_9944_81F5DB2663E7 property. Its value is 'C:\Program Files (x86)\VS2011DIR\Common7\IDE\Extensions\'.
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:055]: PROPERTY CHANGE: Adding Intel0.CB8456D7_A5A6_433A_9944_81F5DB2663E7 property. Its value is 'C:\Program Files (x86)\VS2011DIR\Common7\IDE\Extensions\Intel\'.
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:055]: PROPERTY CHANGE: Adding Intel.SoftwareManager0.CB8456D7_A5A6_433A_9944_81F5DB2663E7 property. Its value is 'C:\Program Files (x86)\VS2011DIR\Common7\IDE\Extensions\Intel\Intel.SoftwareManager\'.
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:055]: PROPERTY CHANGE: Adding ja1.CB8456D7_A5A6_433A_9944_81F5DB2663E7 property. Its value is 'C:\Program Files (x86)\VS2011DIR\Common7\IDE\Extensions\Intel\Intel.SoftwareManager\ja\'.
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:055]: Target path resolution complete. Dumping Directory table...
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:055]: Note: target paths subject to change (via custom actions or browsing)
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:055]: Dir (target): Key: TARGETDIR    , Object: C:\
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:055]: Dir (target): Key: WindowsFolder    , Object: C:\Windows\
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:055]: Dir (target): Key: VS11_REMOTE_DEBUGGER_X64_DIR    , Object: C:\
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:055]: Dir (target): Key: VS11_DEBUGER_DIR    , Object: C:\
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:055]: Dir (target): Key: CommonFilesFolder    , Object: C:\Program Files (x86)\Common Files\
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:055]: Dir (target): Key: INSTALLDIR    , Object: C:\
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:055]: Dir (target): Key: CommonFilesFolder.C4A469D8_5FD7_462C_AAF9_27CC6BDF6210    , Object: C:\
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:055]: Dir (target): Key: CmnIntel.C4A469D8_5FD7_462C_AAF9_27CC6BDF6210    , Object: C:\Intel\
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:055]: Dir (target): Key: CmnIntelHEBundle.C4A469D8_5FD7_462C_AAF9_27CC6BDF6210    , Object: C:\Intel\Parallel Studio XE 2013\
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:055]: Dir (target): Key: ProgramMenuFolder    , Object: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:055]: Dir (target): Key: HEBundleMenuDir.C4A469D8_5FD7_462C_AAF9_27CC6BDF6210    , Object: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Intel Parallel Studio XE 2013\
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:055]: Dir (target): Key: CommonFilesFolder.95C3848C_D156_4249_942C_7A8A0976584F    , Object: C:\
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:055]: Dir (target): Key: CmnIntel.95C3848C_D156_4249_942C_7A8A0976584F    , Object: C:\Intel\
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:055]: Dir (target): Key: CmnIntelHEBundle.95C3848C_D156_4249_942C_7A8A0976584F    , Object: C:\Intel\Parallel Studio XE 2013\
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:055]: Dir (target): Key: ProgramFilesFolder    , Object: C:\Program Files (x86)\
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:055]: Dir (target): Key: VS2011DIR.CB8456D7_A5A6_433A_9944_81F5DB2663E7    , Object: C:\Program Files (x86)\VS2011DIR\
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:055]: Dir (target): Key: Common70.CB8456D7_A5A6_433A_9944_81F5DB2663E7    , Object: C:\Program Files (x86)\VS2011DIR\Common7\
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:055]: Dir (target): Key: IDE0.CB8456D7_A5A6_433A_9944_81F5DB2663E7    , Object: C:\Program Files (x86)\VS2011DIR\Common7\IDE\
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:055]: Dir (target): Key: Extensions0.CB8456D7_A5A6_433A_9944_81F5DB2663E7    , Object: C:\Program Files (x86)\VS2011DIR\Common7\IDE\Extensions\
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:055]: Dir (target): Key: Intel0.CB8456D7_A5A6_433A_9944_81F5DB2663E7    , Object: C:\Program Files (x86)\VS2011DIR\Common7\IDE\Extensions\Intel\
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:055]: Dir (target): Key: Intel.SoftwareManager0.CB8456D7_A5A6_433A_9944_81F5DB2663E7    , Object: C:\Program Files (x86)\VS2011DIR\Common7\IDE\Extensions\Intel\Intel.SoftwareManager\
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:055]: Dir (target): Key: ja1.CB8456D7_A5A6_433A_9944_81F5DB2663E7    , Object: C:\Program Files (x86)\VS2011DIR\Common7\IDE\Extensions\Intel\Intel.SoftwareManager\ja\
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:056]: PROPERTY CHANGE: Adding INSTALLLEVEL property. Its value is '1'.
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:056]: Note: 1: 2205 2:  3: MsiAssembly
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:056]: Note: 1: 2228 2:  3: MsiAssembly 4:  SELECT `MsiAssembly`.`Attributes`, `MsiAssembly`.`File_Application`, `MsiAssembly`.`File_Manifest`,  `Component`.`KeyPath` FROM `MsiAssembly`, `Component` WHERE  `MsiAssembly`.`Component_` = `Component`.`Component` AND `MsiAssembly`.`Component_` = ?
MSI(i) [13:55:06.075] | Action ended 13:55:06: CostFinalize. Return value 1.
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:056]: Doing action: InstallValidate
MSI(i) [13:55:06.075] | Action 13:55:06: InstallValidate. Validating install
MSI(i) [13:55:06.075] | Action start 13:55:06: InstallValidate.
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:057]: Note: 1: 2205 2:  3: Dialog
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:057]: Feature: core; Installed: Absent;   Request: Local;   Action: Local
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:057]: Component: ProductFamilyAnchor; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:057]: Component: ProductVersionAnchor; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:057]: Component: CommonIntegrationAnchor; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:057]: Component: VsIntegrationAnchor; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:057]: Component: reg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:057]: Component: VS11_F1_HELP_NAMESPACE; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:057]: Component: VS11_F1_HELP_VENDOR; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:057]: Component: Comp_Intel.SoftwareManager.dll1.CB8456D7_A5A6_433A_9944_81F5DB2663E7; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:057]: Component: Comp_Intel.SoftwareManager.pkgdef0.CB8456D7_A5A6_433A_9944_81F5DB2663E7; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:057]: Component: Comp_Intel.SoftwareManager.resources.dll1.CB8456D7_A5A6_433A_9944_81F5DB2663E7; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:057]: Component: vs_run.exe.95C3848C_D156_4249_942C_7A8A0976584F; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:057]: Component: VS2011.C4A469D8_5FD7_462C_AAF9_27CC6BDF6210; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:057]: Component: VS2011_win8.C4A469D8_5FD7_462C_AAF9_27CC6BDF6210; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:057]: Component: __reg65; Installed: Null;   Request: Local;   Action: Local;   Client State: Null
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:057]: Component: __VS11_F1_HELP_NAMESPACE65; Installed: Null;   Request: Local;   Action: Local;   Client State: Null
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:057]: Component: __VS11_F1_HELP_VENDOR65; Installed: Null;   Request: Local;   Action: Local;   Client State: Null
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:057]: Component: __VS2011.C4A469D8_5FD7_462C_AAF9_27CC6BDF621065; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:057]: Component: __VS2011_win8.C4A469D8_5FD7_462C_AAF9_27CC6BDF621065; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:057]: Note: 1: 2205 2:  3: BindImage
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:057]: Note: 1: 2205 2:  3: ProgId
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:057]: Note: 1: 2205 2:  3: PublishComponent
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:057]: Note: 1: 2205 2:  3: SelfReg
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:057]: Note: 1: 2205 2:  3: Extension
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:057]: Note: 1: 2205 2:  3: Font
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:057]: Note: 1: 2205 2:  3: Class
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:057]: Note: 1: 2205 2:  3: TypeLib
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:058]: Note: 1: 2205 2:  3: _RemoveFilePath
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:058]: PROPERTY CHANGE: Modifying CostingComplete property. Its current value is '0'. Its new value: '1'.
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:058]: Note: 1: 2205 2:  3: BindImage
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:058]: Note: 1: 2205 2:  3: ProgId
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:058]: Note: 1: 2205 2:  3: PublishComponent
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:058]: Note: 1: 2205 2:  3: SelfReg
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:058]: Note: 1: 2205 2:  3: Extension
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:058]: Note: 1: 2205 2:  3: Font
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:058]: Note: 1: 2205 2:  3: Class
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:058]: Note: 1: 2205 2:  3: TypeLib
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:059]: Note: 1: 2727 2:
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:073]: Note: 1: 2727 2:
MSI(i) [13:55:06.075] | Action ended 13:55:06: InstallValidate. Return value 1.
MSI(i) [13:55:06.075] | MSI (c) (B0:9C) [13:55:06:074]: Closing MSIHANDLE (114) of type 790537 for thread 3996
MSI(i) [13:55:06.075] | === Verbose logging stopped: 4/8/2014  13:55:06 ===
PSET(i) [13:55:06.082] | (4225.285): MsiOpenPackageEx(C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs11-integration.msi)
PSET(i) [13:55:06.140] | (6497.173): Feature=core PendingAction=-1, Action=3
MSI(i) [13:55:06.140] | === Verbose logging started: 4/8/2014  13:55:06  Build type: SHIP UNICODE 5.00.7601.00  Calling process: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\setup.exe ===
MSI(i) [13:55:06.140] | MSI (c) (B0:9C) [13:55:06:084]: SOFTWARE RESTRICTION POLICY: Verifying package --> 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs11-integration.msi' against software restriction policy
MSI(i) [13:55:06.140] | MSI (c) (B0:9C) [13:55:06:084]: SOFTWARE RESTRICTION POLICY: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs11-integration.msi has a digital signature
MSI(i) [13:55:06.140] | MSI (c) (B0:9C) [13:55:06:100]: SOFTWARE RESTRICTION POLICY: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs11-integration.msi is permitted to run at the 'unrestricted' authorization level.
MSI(i) [13:55:06.140] | MSI (c) (B0:9C) [13:55:06:101]: Cloaking enabled.
MSI(i) [13:55:06.140] | MSI (c) (B0:9C) [13:55:06:101]: Attempting to enable all disabled privileges before calling Install on Server
MSI(i) [13:55:06.140] | MSI (c) (B0:9C) [13:55:06:101]: End dialog not enabled
MSI(i) [13:55:06.140] | MSI (c) (B0:9C) [13:55:06:101]: Original package ==> C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs11-integration.msi
MSI(i) [13:55:06.140] | MSI (c) (B0:9C) [13:55:06:101]: Package we're running from ==> C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs11-integration.msi
MSI(i) [13:55:06.140] | MSI (c) (B0:9C) [13:55:06:102]: Machine policy value 'DisableUserInstalls' is 0
MSI(i) [13:55:06.140] | MSI (c) (B0:9C) [13:55:06:102]: APPCOMPAT: Compatibility mode property overrides found.
MSI(i) [13:55:06.140] | MSI (c) (B0:9C) [13:55:06:103]: APPCOMPAT: looking for appcompat database entry with ProductCode '{CB6E4A97-57E7-4D4D-BE5F-049DBD5380FB}'.
MSI(i) [13:55:06.140] | MSI (c) (B0:9C) [13:55:06:103]: APPCOMPAT: no matching ProductCode found in database.
MSI(i) [13:55:06.140] | MSI (c) (B0:9C) [13:55:06:104]: MSCOREE not loaded loading copy from system32
MSI(i) [13:55:06.140] | MSI (c) (B0:9C) [13:55:06:108]: Machine policy value 'TransformsSecure' is 0
MSI(i) [13:55:06.140] | MSI (c) (B0:9C) [13:55:06:108]: User policy value 'TransformsAtSource' is 0
MSI(i) [13:55:06.140] | MSI (c) (B0:9C) [13:55:06:108]: Machine policy value 'DisablePatch' is 0
MSI(i) [13:55:06.140] | MSI (c) (B0:9C) [13:55:06:108]: Machine policy value 'AllowLockdownPatch' is 0
MSI(i) [13:55:06.140] | MSI (c) (B0:9C) [13:55:06:108]: Machine policy value 'DisableLUAPatching' is 0
MSI(i) [13:55:06.140] | MSI (c) (B0:9C) [13:55:06:108]: Machine policy value 'DisableFlyWeightPatching' is 0
MSI(i) [13:55:06.140] | MSI (c) (B0:9C) [13:55:06:108]: Enabling baseline caching for this transaction since all active patches are MSI 3.0 style MSPs or at least one MSI 3.0 minor update patch is active
MSI(i) [13:55:06.140] | MSI (c) (B0:9C) [13:55:06:109]: APPCOMPAT: looking for appcompat database entry with ProductCode '{CB6E4A97-57E7-4D4D-BE5F-049DBD5380FB}'.
MSI(i) [13:55:06.140] | MSI (c) (B0:9C) [13:55:06:109]: APPCOMPAT: no matching ProductCode found in database.
MSI(i) [13:55:06.140] | MSI (c) (B0:9C) [13:55:06:109]: Transforms are not secure.
MSI(i) [13:55:06.140] | MSI (c) (B0:9C) [13:55:06:109]: PROPERTY CHANGE: Adding MsiLogFileLocation property. Its value is 'C:\Users\PCCA-PM\AppData\Local\Temp\MSIED31.tmp'.
MSI(i) [13:55:06.140] | MSI (c) (B0:9C) [13:55:06:109]: No Command Line.
MSI(i) [13:55:06.140] | MSI (c) (B0:9C) [13:55:06:109]: PROPERTY CHANGE: Adding PackageCode property. Its value is '{48FA2B8E-7BDC-4397-B438-CF8C749F1392}'.
MSI(i) [13:55:06.140] | MSI (c) (B0:9C) [13:55:06:109]: Product Code passed to Engine.Initialize:           '(none)'
MSI(i) [13:55:06.140] | MSI (c) (B0:9C) [13:55:06:109]: Product Code from property table before transforms: '{CB6E4A97-57E7-4D4D-BE5F-049DBD5380FB}'
MSI(i) [13:55:06.140] | MSI (c) (B0:9C) [13:55:06:109]: Product Code from property table after transforms:  '{CB6E4A97-57E7-4D4D-BE5F-049DBD5380FB}'
MSI(i) [13:55:06.140] | MSI (c) (B0:9C) [13:55:06:109]: Product not registered: beginning first-time install
MSI(i) [13:55:06.140] | MSI (c) (B0:9C) [13:55:06:109]: PROPERTY CHANGE: Adding ProductState property. Its value is '-1'.
MSI(i) [13:55:06.140] | MSI (c) (B0:9C) [13:55:06:109]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer 3: 2
MSI(i) [13:55:06.140] | MSI (c) (B0:9C) [13:55:06:109]: Entering CMsiConfigurationManager::SetLastUsedSource.
MSI(i) [13:55:06.140] | MSI (c) (B0:9C) [13:55:06:109]: User policy value 'SearchOrder' is 'nmu'
MSI(i) [13:55:06.140] | MSI (c) (B0:9C) [13:55:06:109]: Adding new sources is allowed.
MSI(i) [13:55:06.140] | MSI (c) (B0:9C) [13:55:06:109]: PROPERTY CHANGE: Adding PackagecodeChanging property. Its value is '1'.
MSI(i) [13:55:06.140] | MSI (c) (B0:9C) [13:55:06:109]: Package name extracted from package path: 'vs11-integration.msi'
MSI(i) [13:55:06.140] | MSI (c) (B0:9C) [13:55:06:109]: Package to be registered: 'vs11-integration.msi'
MSI(i) [13:55:06.140] | MSI (c) (B0:9C) [13:55:06:109]: Note: 1: 2205 2:  3: Error
MSI(i) [13:55:06.140] | MSI (c) (B0:9C) [13:55:06:110]: Note: 1: 2262 2: AdminProperties 3: -2147287038
MSI(i) [13:55:06.140] | MSI (c) (B0:9C) [13:55:06:110]: Machine policy value 'DisableMsi' is 0
MSI(i) [13:55:06.140] | MSI (c) (B0:9C) [13:55:06:110]: Machine policy value 'AlwaysInstallElevated' is 0
MSI(i) [13:55:06.140] | MSI (c) (B0:9C) [13:55:06:110]: User policy value 'AlwaysInstallElevated' is 0
MSI(i) [13:55:06.140] | MSI (c) (B0:9C) [13:55:06:110]: Product installation will be elevated because user is admin and product is being installed per-machine.
MSI(i) [13:55:06.140] | MSI (c) (B0:9C) [13:55:06:110]: Running product '{CB6E4A97-57E7-4D4D-BE5F-049DBD5380FB}' with elevated privileges: Product is assigned.
MSI(i) [13:55:06.140] | MSI (c) (B0:9C) [13:55:06:110]: PROPERTY CHANGE: Adding MsiSystemRebootPending property. Its value is '1'.
MSI(i) [13:55:06.140] | MSI (c) (B0:9C) [13:55:06:110]: TRANSFORMS property is now:
MSI(i) [13:55:06.140] | MSI (c) (B0:9C) [13:55:06:110]: PROPERTY CHANGE: Adding VersionDatabase property. Its value is '200'.
MSI(i) [13:55:06.140] | MSI (c) (B0:9C) [13:55:06:110]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming
MSI(i) [13:55:06.140] | MSI (c) (B0:9C) [13:55:06:111]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Favorites
MSI(i) [13:55:06.140] | MSI (c) (B0:9C) [13:55:06:111]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Network Shortcuts
MSI(i) [13:55:06.140] | MSI (c) (B0:9C) [13:55:06:111]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Documents
MSI(i) [13:55:06.140] | MSI (c) (B0:9C) [13:55:06:111]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
MSI(i) [13:55:06.140] | MSI (c) (B0:9C) [13:55:06:111]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Recent
MSI(i) [13:55:06.140] | MSI (c) (B0:9C) [13:55:06:111]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\SendTo
MSI(i) [13:55:06.140] | MSI (c) (B0:9C) [13:55:06:111]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Templates
MSI(i) [13:55:06.140] | MSI (c) (B0:9C) [13:55:06:111]: SHELL32::SHGetFolderPath returned: C:\ProgramData
MSI(i) [13:55:06.140] | MSI (c) (B0:9C) [13:55:06:111]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Local
MSI(i) [13:55:06.140] | MSI (c) (B0:9C) [13:55:06:111]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Pictures
MSI(i) [13:55:06.140] | MSI (c) (B0:9C) [13:55:06:111]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI(i) [13:55:06.140] | MSI (c) (B0:9C) [13:55:06:111]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
MSI(i) [13:55:06.140] | MSI (c) (B0:9C) [13:55:06:111]: SHELL32::SHGetFolderPath returned: C:\Users\Public\Desktop
MSI(i) [13:55:06.140] | MSI (c) (B0:9C) [13:55:06:111]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI(i) [13:55:06.140] | MSI (c) (B0:9C) [13:55:06:111]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
MSI(i) [13:55:06.140] | MSI (c) (B0:9C) [13:55:06:111]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Desktop
MSI(i) [13:55:06.140] | MSI (c) (B0:9C) [13:55:06:111]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Templates
MSI(i) [13:55:06.140] | MSI (c) (B0:9C) [13:55:06:111]: SHELL32::SHGetFolderPath returned: C:\Windows\Fonts
MSI(i) [13:55:06.140] | MSI (c) (B0:9C) [13:55:06:111]: Note: 1: 2898 2: MS Sans Serif 3: MS Sans Serif 4: 0 5: 16
MSI(i) [13:55:06.140] | MSI (c) (B0:9C) [13:55:06:113]: MSI_LUA: Setting AdminUser property to 1 because this is the client or the user has already permitted elevation
MSI(i) [13:55:06.140] | MSI (c) (B0:9C) [13:55:06:113]: MSI_LUA: Setting MsiRunningElevated property to 1 because the install is already running elevated.
MSI(i) [13:55:06.140] | MSI (c) (B0:9C) [13:55:06:113]: PROPERTY CHANGE: Adding MsiRunningElevated property. Its value is '1'.
MSI(i) [13:55:06.140] | MSI (c) (B0:9C) [13:55:06:113]: PROPERTY CHANGE: Adding Privileged property. Its value is '1'.
MSI(i) [13:55:06.140] | MSI (c) (B0:9C) [13:55:06:114]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\MS Setup (ACME)\User Info 3: 2
MSI(i) [13:55:06.140] | MSI (c) (B0:9C) [13:55:06:114]: PROPERTY CHANGE: Adding USERNAME property. Its value is 'A Valued IT Customer'.
MSI(i) [13:55:06.140] | MSI (c) (B0:9C) [13:55:06:114]: PROPERTY CHANGE: Adding COMPANYNAME property. Its value is 'Intel Corporation'.
MSI(i) [13:55:06.140] | MSI (c) (B0:9C) [13:55:06:114]: PROPERTY CHANGE: Adding DATABASE property. Its value is 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs11-integration.msi'.
MSI(i) [13:55:06.140] | MSI (c) (B0:9C) [13:55:06:114]: PROPERTY CHANGE: Adding OriginalDatabase property. Its value is 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs11-integration.msi'.
MSI(i) [13:55:06.140] | MSI (c) (B0:9C) [13:55:06:114]: Machine policy value 'MsiDisableEmbeddedUI' is 0
MSI(i) [13:55:06.140] | MSI (c) (B0:9C) [13:55:06:114]: EEUI - Disabling MsiEmbeddedUI in quiet mode
MSI(i) [13:55:06.140] | === Logging started: 4/8/2014  13:55:06 ===
MSI(i) [13:55:06.140] | MSI (c) (B0:9C) [13:55:06:114]: Note: 1: 2205 2:  3: PatchPackage
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:114]: Machine policy value 'DisableRollback' is 0
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:114]: User policy value 'DisableRollback' is 0
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:114]: PROPERTY CHANGE: Adding UILevel property. Its value is '2'.
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:114]: Creating MSIHANDLE (116) of type 790537 for thread 3996
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:114]: MsiOpenPackageEx is returning 0
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:114]: Creating MSIHANDLE (117) of type 790541 for thread 3996
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:114]: Closing MSIHANDLE (117) of type 790541 for thread 3996
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:114]: Doing action: AppSearch
MSI(i) [13:55:06.141] | Action 13:55:06: AppSearch. Searching for installed applications
MSI(i) [13:55:06.141] | Action start 13:55:06: AppSearch.
MSI(i) [13:55:06.141] | AppSearch: Property: VS2011DIR.CB8456D7_A5A6_433A_9944_81F5DB2663E7, Signature: SIG_VS2011_DIR.CB8456D7_A5A6_433A_9944_81F5DB2663E7
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:116]: Note: 1: 2262 2: Signature 3: -2147287038
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:116]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE32\SOFTWARE\Microsoft\VisualStudio\11.0\Setup\VS 3: 2
MSI(i) [13:55:06.141] | AppSearch: Property: VS2010DIR.CB8456D7_A5A6_433A_9944_81F5DB2663E7, Signature: SIG_VS2010_DIR.CB8456D7_A5A6_433A_9944_81F5DB2663E7
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:116]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE32\SOFTWARE\Microsoft\VisualStudio\10.0\Setup\VS 3: 2
MSI(i) [13:55:06.141] | AppSearch: Property: DEVENV_EXE_2008.C4A469D8_5FD7_462C_AAF9_27CC6BDF6210, Signature: RL_DevenvExe_2008.C4A469D8_5FD7_462C_AAF9_27CC6BDF6210
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:116]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE32\SOFTWARE\Microsoft\VisualStudio\9.0\Setup\VS 3: 2
MSI(i) [13:55:06.141] | AppSearch: Property: DEVENV_EXE_2010.C4A469D8_5FD7_462C_AAF9_27CC6BDF6210, Signature: RL_DevenvExe_2010.C4A469D8_5FD7_462C_AAF9_27CC6BDF6210
MSI(i) [13:55:06.141] | AppSearch: Property: DEVENV_EXE_2011.C4A469D8_5FD7_462C_AAF9_27CC6BDF6210, Signature: RL_DevenvExe_2011.C4A469D8_5FD7_462C_AAF9_27CC6BDF6210
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:117]: Note: 1: 2262 2: Signature 3: -2147287038
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:117]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE32\SOFTWARE\Microsoft\VisualStudio\11.0\Setup\VS 3: 2
MSI(i) [13:55:06.141] | Action ended 13:55:06: AppSearch. Return value 1.
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:117]: Doing action: CostInitialize
MSI(i) [13:55:06.141] | Action 13:55:06: CostInitialize. Computing space requirements
MSI(i) [13:55:06.141] | Action start 13:55:06: CostInitialize.
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:118]: Machine policy value 'MaxPatchCacheSize' is 10
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:118]: Baseline: Sorting baselines for {CB6E4A97-57E7-4D4D-BE5F-049DBD5380FB}.
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:118]: Baseline: New baseline 13.1.5000 from transaction.
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:118]: Baseline: Sorted order Native: Order 0.
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:118]: Baseline Data Table:
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:118]: ProductCode: {CB6E4A97-57E7-4D4D-BE5F-049DBD5380FB} Version: 13.1.5000 Attributes: 0 PatchId: Native BaselineId: -2147483648 Order: 0
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:118]: Baseline File Table:
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:119]: PROPERTY CHANGE: Adding ROOTDRIVE property. Its value is 'C:\'.
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:119]: PROPERTY CHANGE: Adding CostingComplete property. Its value is '0'.
MSI(i) [13:55:06.141] | Action ended 13:55:06: CostInitialize. Return value 1.
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:119]: Doing action: FileCost
MSI(i) [13:55:06.141] | Action 13:55:06: FileCost. Computing space requirements
MSI(i) [13:55:06.141] | Action start 13:55:06: FileCost.
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:120]: Note: 1: 2205 2:  3: MsiAssembly
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:120]: Note: 1: 2205 2:  3: Class
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:120]: Note: 1: 2205 2:  3: Extension
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:120]: Note: 1: 2205 2:  3: TypeLib
MSI(i) [13:55:06.141] | Action ended 13:55:06: FileCost. Return value 1.
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:120]: Doing action: CostFinalize
MSI(i) [13:55:06.141] | Action 13:55:06: CostFinalize. Computing space requirements
MSI(i) [13:55:06.141] | Action start 13:55:06: CostFinalize.
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:121]: PROPERTY CHANGE: Adding OutOfDiskSpace property. Its value is '0'.
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:121]: PROPERTY CHANGE: Adding OutOfNoRbDiskSpace property. Its value is '0'.
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:121]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceAvailable property. Its value is '0'.
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:121]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRequired property. Its value is '0'.
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:121]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRemaining property. Its value is '0'.
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:121]: Note: 1: 2205 2:  3: Patch
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:121]: Note: 1: 2205 2:  3: Condition
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:122]: PROPERTY CHANGE: Adding TARGETDIR property. Its value is 'C:\'.
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:122]: PROPERTY CHANGE: Adding VS11_REMOTE_DEBUGGER_X64_DIR property. Its value is 'C:\'.
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:122]: PROPERTY CHANGE: Adding VS11_DEBUGER_DIR property. Its value is 'C:\'.
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:122]: PROPERTY CHANGE: Adding INSTALLDIR property. Its value is 'C:\'.
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:122]: PROPERTY CHANGE: Adding CommonFilesFolder.C4A469D8_5FD7_462C_AAF9_27CC6BDF6210 property. Its value is 'C:\'.
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:122]: PROPERTY CHANGE: Adding CmnIntel.C4A469D8_5FD7_462C_AAF9_27CC6BDF6210 property. Its value is 'C:\Intel\'.
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:122]: PROPERTY CHANGE: Adding CmnIntelHEBundle.C4A469D8_5FD7_462C_AAF9_27CC6BDF6210 property. Its value is 'C:\Intel\Parallel Studio XE 2013\'.
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:122]: PROPERTY CHANGE: Adding HEBundleMenuDir.C4A469D8_5FD7_462C_AAF9_27CC6BDF6210 property. Its value is 'C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Intel Parallel Studio XE 2013\'.
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:122]: PROPERTY CHANGE: Adding CommonFilesFolder.95C3848C_D156_4249_942C_7A8A0976584F property. Its value is 'C:\'.
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:122]: PROPERTY CHANGE: Adding CmnIntel.95C3848C_D156_4249_942C_7A8A0976584F property. Its value is 'C:\Intel\'.
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:122]: PROPERTY CHANGE: Adding CmnIntelHEBundle.95C3848C_D156_4249_942C_7A8A0976584F property. Its value is 'C:\Intel\Parallel Studio XE 2013\'.
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:122]: PROPERTY CHANGE: Adding VS2011DIR.CB8456D7_A5A6_433A_9944_81F5DB2663E7 property. Its value is 'C:\Program Files (x86)\VS2011DIR\'.
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:122]: PROPERTY CHANGE: Adding Common70.CB8456D7_A5A6_433A_9944_81F5DB2663E7 property. Its value is 'C:\Program Files (x86)\VS2011DIR\Common7\'.
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:122]: PROPERTY CHANGE: Adding IDE0.CB8456D7_A5A6_433A_9944_81F5DB2663E7 property. Its value is 'C:\Program Files (x86)\VS2011DIR\Common7\IDE\'.
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:122]: PROPERTY CHANGE: Adding Extensions0.CB8456D7_A5A6_433A_9944_81F5DB2663E7 property. Its value is 'C:\Program Files (x86)\VS2011DIR\Common7\IDE\Extensions\'.
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:122]: PROPERTY CHANGE: Adding Intel0.CB8456D7_A5A6_433A_9944_81F5DB2663E7 property. Its value is 'C:\Program Files (x86)\VS2011DIR\Common7\IDE\Extensions\Intel\'.
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:122]: PROPERTY CHANGE: Adding Intel.SoftwareManager0.CB8456D7_A5A6_433A_9944_81F5DB2663E7 property. Its value is 'C:\Program Files (x86)\VS2011DIR\Common7\IDE\Extensions\Intel\Intel.SoftwareManager\'.
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:122]: PROPERTY CHANGE: Adding ja1.CB8456D7_A5A6_433A_9944_81F5DB2663E7 property. Its value is 'C:\Program Files (x86)\VS2011DIR\Common7\IDE\Extensions\Intel\Intel.SoftwareManager\ja\'.
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:122]: Target path resolution complete. Dumping Directory table...
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:122]: Note: target paths subject to change (via custom actions or browsing)
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:122]: Dir (target): Key: TARGETDIR    , Object: C:\
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:122]: Dir (target): Key: WindowsFolder    , Object: C:\Windows\
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:122]: Dir (target): Key: VS11_REMOTE_DEBUGGER_X64_DIR    , Object: C:\
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:122]: Dir (target): Key: VS11_DEBUGER_DIR    , Object: C:\
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:122]: Dir (target): Key: CommonFilesFolder    , Object: C:\Program Files (x86)\Common Files\
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:122]: Dir (target): Key: INSTALLDIR    , Object: C:\
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:122]: Dir (target): Key: CommonFilesFolder.C4A469D8_5FD7_462C_AAF9_27CC6BDF6210    , Object: C:\
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:122]: Dir (target): Key: CmnIntel.C4A469D8_5FD7_462C_AAF9_27CC6BDF6210    , Object: C:\Intel\
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:122]: Dir (target): Key: CmnIntelHEBundle.C4A469D8_5FD7_462C_AAF9_27CC6BDF6210    , Object: C:\Intel\Parallel Studio XE 2013\
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:122]: Dir (target): Key: ProgramMenuFolder    , Object: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:122]: Dir (target): Key: HEBundleMenuDir.C4A469D8_5FD7_462C_AAF9_27CC6BDF6210    , Object: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Intel Parallel Studio XE 2013\
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:122]: Dir (target): Key: CommonFilesFolder.95C3848C_D156_4249_942C_7A8A0976584F    , Object: C:\
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:122]: Dir (target): Key: CmnIntel.95C3848C_D156_4249_942C_7A8A0976584F    , Object: C:\Intel\
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:122]: Dir (target): Key: CmnIntelHEBundle.95C3848C_D156_4249_942C_7A8A0976584F    , Object: C:\Intel\Parallel Studio XE 2013\
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:122]: Dir (target): Key: ProgramFilesFolder    , Object: C:\Program Files (x86)\
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:122]: Dir (target): Key: VS2011DIR.CB8456D7_A5A6_433A_9944_81F5DB2663E7    , Object: C:\Program Files (x86)\VS2011DIR\
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:122]: Dir (target): Key: Common70.CB8456D7_A5A6_433A_9944_81F5DB2663E7    , Object: C:\Program Files (x86)\VS2011DIR\Common7\
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:122]: Dir (target): Key: IDE0.CB8456D7_A5A6_433A_9944_81F5DB2663E7    , Object: C:\Program Files (x86)\VS2011DIR\Common7\IDE\
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:122]: Dir (target): Key: Extensions0.CB8456D7_A5A6_433A_9944_81F5DB2663E7    , Object: C:\Program Files (x86)\VS2011DIR\Common7\IDE\Extensions\
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:122]: Dir (target): Key: Intel0.CB8456D7_A5A6_433A_9944_81F5DB2663E7    , Object: C:\Program Files (x86)\VS2011DIR\Common7\IDE\Extensions\Intel\
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:122]: Dir (target): Key: Intel.SoftwareManager0.CB8456D7_A5A6_433A_9944_81F5DB2663E7    , Object: C:\Program Files (x86)\VS2011DIR\Common7\IDE\Extensions\Intel\Intel.SoftwareManager\
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:122]: Dir (target): Key: ja1.CB8456D7_A5A6_433A_9944_81F5DB2663E7    , Object: C:\Program Files (x86)\VS2011DIR\Common7\IDE\Extensions\Intel\Intel.SoftwareManager\ja\
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:122]: PROPERTY CHANGE: Adding INSTALLLEVEL property. Its value is '1'.
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:122]: Note: 1: 2205 2:  3: MsiAssembly
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:122]: Note: 1: 2228 2:  3: MsiAssembly 4:  SELECT `MsiAssembly`.`Attributes`, `MsiAssembly`.`File_Application`, `MsiAssembly`.`File_Manifest`,  `Component`.`KeyPath` FROM `MsiAssembly`, `Component` WHERE  `MsiAssembly`.`Component_` = `Component`.`Component` AND `MsiAssembly`.`Component_` = ?
MSI(i) [13:55:06.141] | Action ended 13:55:06: CostFinalize. Return value 1.
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:123]: Doing action: InstallValidate
MSI(i) [13:55:06.141] | Action 13:55:06: InstallValidate. Validating install
MSI(i) [13:55:06.141] | Action start 13:55:06: InstallValidate.
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:124]: Note: 1: 2205 2:  3: Dialog
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:124]: Feature: core; Installed: Absent;   Request: Local;   Action: Local
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:124]: Component: ProductFamilyAnchor; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:124]: Component: ProductVersionAnchor; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:124]: Component: CommonIntegrationAnchor; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:124]: Component: VsIntegrationAnchor; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:124]: Component: reg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:124]: Component: VS11_F1_HELP_NAMESPACE; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:124]: Component: VS11_F1_HELP_VENDOR; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:124]: Component: Comp_Intel.SoftwareManager.dll1.CB8456D7_A5A6_433A_9944_81F5DB2663E7; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:124]: Component: Comp_Intel.SoftwareManager.pkgdef0.CB8456D7_A5A6_433A_9944_81F5DB2663E7; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:124]: Component: Comp_Intel.SoftwareManager.resources.dll1.CB8456D7_A5A6_433A_9944_81F5DB2663E7; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:124]: Component: vs_run.exe.95C3848C_D156_4249_942C_7A8A0976584F; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:124]: Component: VS2011.C4A469D8_5FD7_462C_AAF9_27CC6BDF6210; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:124]: Component: VS2011_win8.C4A469D8_5FD7_462C_AAF9_27CC6BDF6210; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:124]: Component: __reg65; Installed: Null;   Request: Local;   Action: Local;   Client State: Null
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:124]: Component: __VS11_F1_HELP_NAMESPACE65; Installed: Null;   Request: Local;   Action: Local;   Client State: Null
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:124]: Component: __VS11_F1_HELP_VENDOR65; Installed: Null;   Request: Local;   Action: Local;   Client State: Null
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:124]: Component: __VS2011.C4A469D8_5FD7_462C_AAF9_27CC6BDF621065; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:124]: Component: __VS2011_win8.C4A469D8_5FD7_462C_AAF9_27CC6BDF621065; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:124]: Note: 1: 2205 2:  3: BindImage
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:124]: Note: 1: 2205 2:  3: ProgId
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:124]: Note: 1: 2205 2:  3: PublishComponent
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:124]: Note: 1: 2205 2:  3: SelfReg
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:124]: Note: 1: 2205 2:  3: Extension
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:124]: Note: 1: 2205 2:  3: Font
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:124]: Note: 1: 2205 2:  3: Class
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:124]: Note: 1: 2205 2:  3: TypeLib
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:124]: Note: 1: 2205 2:  3: _RemoveFilePath
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:125]: PROPERTY CHANGE: Modifying CostingComplete property. Its current value is '0'. Its new value: '1'.
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:125]: Note: 1: 2205 2:  3: BindImage
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:125]: Note: 1: 2205 2:  3: ProgId
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:125]: Note: 1: 2205 2:  3: PublishComponent
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:125]: Note: 1: 2205 2:  3: SelfReg
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:125]: Note: 1: 2205 2:  3: Extension
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:125]: Note: 1: 2205 2:  3: Font
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:125]: Note: 1: 2205 2:  3: Class
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:125]: Note: 1: 2205 2:  3: TypeLib
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:125]: Note: 1: 2727 2:
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:140]: Note: 1: 2727 2:
MSI(i) [13:55:06.141] | Action ended 13:55:06: InstallValidate. Return value 1.
MSI(i) [13:55:06.141] | MSI (c) (B0:9C) [13:55:06:140]: Closing MSIHANDLE (116) of type 790537 for thread 3996
MSI(i) [13:55:06.141] | === Verbose logging stopped: 4/8/2014  13:55:06 ===
PSET(i) [13:55:06.149] | (4225.1157): msi package: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs2008-integration.msi
PSET(i) [13:55:06.149] | (4225.1158): LicIsValid: 1     InstallOnCurrentArch: 1     Installed State: -1     Pending Action: 3
PSET(i) [13:55:06.149] | (673.178): UpdateNeedforCheck {ACD97E2A-090D-46ea-9983-6E44BCA28575}: Need
PSET(i) [13:55:06.149] | (673.178): UpdateNeedforCheck {F3CE10E5-7F75-4356-A379-05F5D6B04FB6}: Need
PSET(i) [13:55:06.149] | (673.178): UpdateNeedforCheck {D52A1D2E-8D7A-4822-9421-3A92C64DB956}: Need
UNK(i) [13:55:06.149] |
Plugin psetlogger is initialized.
UNK(i) [13:55:06.149] | pset::abstract_context(context == pset::ContextInfo(eInstallMode == INSTALL_MODE_TYPICAL, iLog == ptr(0x1563f74), lLocaleID == size_t("1033"), sCurrentArchitecture == String("Intel64"), sLicenseFiles == String(""), sVSPackageNumber == String(""), sPathToLocaleFileFolder == String("C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\1033\"), sSerialNumber == String("")))
UNK(i) [13:55:06.149] | pset::abstract_context() return: deps::Context(mode == INSTALL, silent == bool(false), upfront == bool(false), full == bool(false), locale == int("0"))
UNK(i) [13:55:06.149] | Main(id == {ACD97E2A-090D-46ea-9983-6E44BCA28575}, severity == 0, message == ptr(0x16f068))
UNK(i) [13:55:06.149] | Main(): Check dependencies
UNK(i) [13:55:06.149] | Main(): exit with severity == DependencyCode(0), message == String("")
PSET(i) [13:55:06.149] | (673.118): Check Dependency for {ACD97E2A-090D-46ea-9983-6E44BCA28575}: 0
UNK(i) [13:55:06.150] | Main(id == {D52A1D2E-8D7A-4822-9421-3A92C64DB956}, severity == 0, message == ptr(0x16f068))
UNK(i) [13:55:06.150] | Main(): Check if need to show VS Integration dialog
UNK(i) [13:55:06.150] | Main(): Enable dialog
UNK(i) [13:55:06.150] | Main(): exit with severity == MISSING_DEPENDENCY_NO_SUMMARY, message == String("")
PSET(i) [13:55:06.150] | (673.118): Check Dependency for {D52A1D2E-8D7A-4822-9421-3A92C64DB956}: 12032
UNK(i) [13:55:06.150] | pset::abstract_context(context == pset::ContextInfo(eInstallMode == INSTALL_MODE_TYPICAL, iLog == ptr(0x1563f74), lLocaleID == size_t("1033"), sCurrentArchitecture == String("Intel64"), sLicenseFiles == String(""), sVSPackageNumber == String(""), sPathToLocaleFileFolder == String("C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\1033\"), sSerialNumber == String("")))
UNK(i) [13:55:06.150] | pset::abstract_context() return: deps::Context(mode == INSTALL, silent == bool(false), upfront == bool(false), full == bool(false), locale == int("0"))
UNK(i) [13:55:06.150] | Main(id == {E3BA8A13-2647-4c01-81D5-77E6D912D9D5}, severity == 0, message == ptr(0x16f068))
UNK(i) [13:55:06.150] | Main(): disable VS 11
UNK(i) [13:55:06.150] | Main(): exit with severity == MISSING_DEPENDENCY_COMPONENT_DISABLED, message == String("")
PSET(i) [13:55:06.150] | (673.118): Check Dependency for {E3BA8A13-2647-4c01-81D5-77E6D912D9D5}: 12021
UNK(i) [13:55:06.150] | Main(id == {F3CE10E5-7F75-4356-A379-05F5D6B04FB6}, severity == 0, message == ptr(0x16f068))
UNK(i) [13:55:06.150] | Main(): disable VS2008
PSET(i) [13:55:06.150] | (673.118): Check Dependency for {F3CE10E5-7F75-4356-A379-05F5D6B04FB6}: 12021
UNK(i) [13:55:06.150] | Main(id == {8AA98789-C136-4adc-8269-86F3C222906F}, severity == 0, message == ptr(0x16f068))
UNK(i) [13:55:06.150] | Main(): exit with severity == DependencyCode(0), message == String("")
PSET(i) [13:55:06.150] | (673.118): Check Dependency for {8AA98789-C136-4adc-8269-86F3C222906F}: 0
PSET(i) [13:55:06.150] | (4225.1224): Disabled C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs2008-integration.msi
PSET(i) [13:55:06.150] | (4225.285): MsiOpenPackageEx(C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs2008-integration.msi)
PSET(i) [13:55:06.209] | (6497.173): Feature=core PendingAction=5, Action=3
PSET(i) [13:55:06.209] | (6497.176): Call MsiSetFeatureState(core)
MSI(i) [13:55:06.210] | === Verbose logging started: 4/8/2014  13:55:06  Build type: SHIP UNICODE 5.00.7601.00  Calling process: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\setup.exe ===
MSI(i) [13:55:06.210] | MSI (c) (B0:9C) [13:55:06:152]: SOFTWARE RESTRICTION POLICY: Verifying package --> 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs2008-integration.msi' against software restriction policy
MSI(i) [13:55:06.210] | MSI (c) (B0:9C) [13:55:06:152]: SOFTWARE RESTRICTION POLICY: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs2008-integration.msi has a digital signature
MSI(i) [13:55:06.210] | MSI (c) (B0:9C) [13:55:06:169]: SOFTWARE RESTRICTION POLICY: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs2008-integration.msi is permitted to run at the 'unrestricted' authorization level.
MSI(i) [13:55:06.210] | MSI (c) (B0:9C) [13:55:06:169]: Cloaking enabled.
MSI(i) [13:55:06.210] | MSI (c) (B0:9C) [13:55:06:169]: Attempting to enable all disabled privileges before calling Install on Server
MSI(i) [13:55:06.210] | MSI (c) (B0:9C) [13:55:06:170]: End dialog not enabled
MSI(i) [13:55:06.210] | MSI (c) (B0:9C) [13:55:06:170]: Original package ==> C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs2008-integration.msi
MSI(i) [13:55:06.210] | MSI (c) (B0:9C) [13:55:06:170]: Package we're running from ==> C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs2008-integration.msi
MSI(i) [13:55:06.210] | MSI (c) (B0:9C) [13:55:06:170]: Machine policy value 'DisableUserInstalls' is 0
MSI(i) [13:55:06.210] | MSI (c) (B0:9C) [13:55:06:171]: APPCOMPAT: Compatibility mode property overrides found.
MSI(i) [13:55:06.210] | MSI (c) (B0:9C) [13:55:06:171]: APPCOMPAT: looking for appcompat database entry with ProductCode '{EFD393B3-F9F9-43E5-9DEA-7ACA45B1E5B2}'.
MSI(i) [13:55:06.210] | MSI (c) (B0:9C) [13:55:06:171]: APPCOMPAT: no matching ProductCode found in database.
MSI(i) [13:55:06.210] | MSI (c) (B0:9C) [13:55:06:173]: MSCOREE not loaded loading copy from system32
MSI(i) [13:55:06.210] | MSI (c) (B0:9C) [13:55:06:177]: Machine policy value 'TransformsSecure' is 0
MSI(i) [13:55:06.210] | MSI (c) (B0:9C) [13:55:06:177]: User policy value 'TransformsAtSource' is 0
MSI(i) [13:55:06.210] | MSI (c) (B0:9C) [13:55:06:177]: Machine policy value 'DisablePatch' is 0
MSI(i) [13:55:06.210] | MSI (c) (B0:9C) [13:55:06:177]: Machine policy value 'AllowLockdownPatch' is 0
MSI(i) [13:55:06.210] | MSI (c) (B0:9C) [13:55:06:177]: Machine policy value 'DisableLUAPatching' is 0
MSI(i) [13:55:06.210] | MSI (c) (B0:9C) [13:55:06:177]: Machine policy value 'DisableFlyWeightPatching' is 0
MSI(i) [13:55:06.210] | MSI (c) (B0:9C) [13:55:06:177]: Enabling baseline caching for this transaction since all active patches are MSI 3.0 style MSPs or at least one MSI 3.0 minor update patch is active
MSI(i) [13:55:06.210] | MSI (c) (B0:9C) [13:55:06:177]: APPCOMPAT: looking for appcompat database entry with ProductCode '{EFD393B3-F9F9-43E5-9DEA-7ACA45B1E5B2}'.
MSI(i) [13:55:06.210] | MSI (c) (B0:9C) [13:55:06:177]: APPCOMPAT: no matching ProductCode found in database.
MSI(i) [13:55:06.210] | MSI (c) (B0:9C) [13:55:06:177]: Transforms are not secure.
MSI(i) [13:55:06.210] | MSI (c) (B0:9C) [13:55:06:177]: PROPERTY CHANGE: Adding MsiLogFileLocation property. Its value is 'C:\Users\PCCA-PM\AppData\Local\Temp\MSIED31.tmp'.
MSI(i) [13:55:06.210] | MSI (c) (B0:9C) [13:55:06:177]: No Command Line.
MSI(i) [13:55:06.210] | MSI (c) (B0:9C) [13:55:06:177]: PROPERTY CHANGE: Adding PackageCode property. Its value is '{27EA0C65-64CE-405E-A049-1F35608919DE}'.
MSI(i) [13:55:06.210] | MSI (c) (B0:9C) [13:55:06:177]: Product Code passed to Engine.Initialize:           '(none)'
MSI(i) [13:55:06.210] | MSI (c) (B0:9C) [13:55:06:177]: Product Code from property table before transforms: '{EFD393B3-F9F9-43E5-9DEA-7ACA45B1E5B2}'
MSI(i) [13:55:06.210] | MSI (c) (B0:9C) [13:55:06:177]: Product Code from property table after transforms:  '{EFD393B3-F9F9-43E5-9DEA-7ACA45B1E5B2}'
MSI(i) [13:55:06.210] | MSI (c) (B0:9C) [13:55:06:177]: Product not registered: beginning first-time install
MSI(i) [13:55:06.210] | MSI (c) (B0:9C) [13:55:06:178]: PROPERTY CHANGE: Adding ProductState property. Its value is '-1'.
MSI(i) [13:55:06.210] | MSI (c) (B0:9C) [13:55:06:178]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer 3: 2
MSI(i) [13:55:06.210] | MSI (c) (B0:9C) [13:55:06:178]: Entering CMsiConfigurationManager::SetLastUsedSource.
MSI(i) [13:55:06.210] | MSI (c) (B0:9C) [13:55:06:178]: User policy value 'SearchOrder' is 'nmu'
MSI(i) [13:55:06.210] | MSI (c) (B0:9C) [13:55:06:178]: Adding new sources is allowed.
MSI(i) [13:55:06.210] | MSI (c) (B0:9C) [13:55:06:178]: PROPERTY CHANGE: Adding PackagecodeChanging property. Its value is '1'.
MSI(i) [13:55:06.210] | MSI (c) (B0:9C) [13:55:06:178]: Package name extracted from package path: 'vs2008-integration.msi'
MSI(i) [13:55:06.210] | MSI (c) (B0:9C) [13:55:06:178]: Package to be registered: 'vs2008-integration.msi'
MSI(i) [13:55:06.210] | MSI (c) (B0:9C) [13:55:06:178]: Note: 1: 2205 2:  3: Error
MSI(i) [13:55:06.210] | MSI (c) (B0:9C) [13:55:06:178]: Note: 1: 2262 2: AdminProperties 3: -2147287038
MSI(i) [13:55:06.210] | MSI (c) (B0:9C) [13:55:06:178]: Machine policy value 'DisableMsi' is 0
MSI(i) [13:55:06.210] | MSI (c) (B0:9C) [13:55:06:179]: Machine policy value 'AlwaysInstallElevated' is 0
MSI(i) [13:55:06.210] | MSI (c) (B0:9C) [13:55:06:179]: User policy value 'AlwaysInstallElevated' is 0
MSI(i) [13:55:06.210] | MSI (c) (B0:9C) [13:55:06:179]: Product installation will be elevated because user is admin and product is being installed per-machine.
MSI(i) [13:55:06.210] | MSI (c) (B0:9C) [13:55:06:179]: Running product '{EFD393B3-F9F9-43E5-9DEA-7ACA45B1E5B2}' with elevated privileges: Product is assigned.
MSI(i) [13:55:06.210] | MSI (c) (B0:9C) [13:55:06:179]: PROPERTY CHANGE: Adding MsiSystemRebootPending property. Its value is '1'.
MSI(i) [13:55:06.210] | MSI (c) (B0:9C) [13:55:06:179]: TRANSFORMS property is now:
MSI(i) [13:55:06.210] | MSI (c) (B0:9C) [13:55:06:179]: PROPERTY CHANGE: Adding VersionDatabase property. Its value is '200'.
MSI(i) [13:55:06.210] | MSI (c) (B0:9C) [13:55:06:179]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming
MSI(i) [13:55:06.210] | MSI (c) (B0:9C) [13:55:06:179]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Favorites
MSI(i) [13:55:06.210] | MSI (c) (B0:9C) [13:55:06:179]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Network Shortcuts
MSI(i) [13:55:06.210] | MSI (c) (B0:9C) [13:55:06:179]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Documents
MSI(i) [13:55:06.210] | MSI (c) (B0:9C) [13:55:06:179]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
MSI(i) [13:55:06.210] | MSI (c) (B0:9C) [13:55:06:179]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Recent
MSI(i) [13:55:06.210] | MSI (c) (B0:9C) [13:55:06:179]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\SendTo
MSI(i) [13:55:06.210] | MSI (c) (B0:9C) [13:55:06:179]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Templates
MSI(i) [13:55:06.210] | MSI (c) (B0:9C) [13:55:06:179]: SHELL32::SHGetFolderPath returned: C:\ProgramData
MSI(i) [13:55:06.210] | MSI (c) (B0:9C) [13:55:06:179]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Local
MSI(i) [13:55:06.210] | MSI (c) (B0:9C) [13:55:06:179]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Pictures
MSI(i) [13:55:06.210] | MSI (c) (B0:9C) [13:55:06:179]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI(i) [13:55:06.210] | MSI (c) (B0:9C) [13:55:06:179]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
MSI(i) [13:55:06.210] | MSI (c) (B0:9C) [13:55:06:179]: SHELL32::SHGetFolderPath returned: C:\Users\Public\Desktop
MSI(i) [13:55:06.210] | MSI (c) (B0:9C) [13:55:06:179]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI(i) [13:55:06.210] | MSI (c) (B0:9C) [13:55:06:179]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
MSI(i) [13:55:06.210] | MSI (c) (B0:9C) [13:55:06:179]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Desktop
MSI(i) [13:55:06.210] | MSI (c) (B0:9C) [13:55:06:179]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Templates
MSI(i) [13:55:06.210] | MSI (c) (B0:9C) [13:55:06:179]: SHELL32::SHGetFolderPath returned: C:\Windows\Fonts
MSI(i) [13:55:06.210] | MSI (c) (B0:9C) [13:55:06:180]: Note: 1: 2898 2: MS Sans Serif 3: MS Sans Serif 4: 0 5: 16
MSI(i) [13:55:06.210] | MSI (c) (B0:9C) [13:55:06:182]: MSI_LUA: Setting AdminUser property to 1 because this is the client or the user has already permitted elevation
MSI(i) [13:55:06.210] | MSI (c) (B0:9C) [13:55:06:182]: MSI_LUA: Setting MsiRunningElevated property to 1 because the install is already running elevated.
MSI(i) [13:55:06.210] | MSI (c) (B0:9C) [13:55:06:182]: PROPERTY CHANGE: Adding MsiRunningElevated property. Its value is '1'.
MSI(i) [13:55:06.210] | MSI (c) (B0:9C) [13:55:06:182]: PROPERTY CHANGE: Adding Privileged property. Its value is '1'.
MSI(i) [13:55:06.210] | MSI (c) (B0:9C) [13:55:06:182]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\MS Setup (ACME)\User Info 3: 2
MSI(i) [13:55:06.210] | MSI (c) (B0:9C) [13:55:06:182]: PROPERTY CHANGE: Adding USERNAME property. Its value is 'A Valued IT Customer'.
MSI(i) [13:55:06.210] | MSI (c) (B0:9C) [13:55:06:182]: PROPERTY CHANGE: Adding COMPANYNAME property. Its value is 'Intel Corporation'.
MSI(i) [13:55:06.210] | MSI (c) (B0:9C) [13:55:06:182]: PROPERTY CHANGE: Adding DATABASE property. Its value is 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs2008-integration.msi'.
MSI(i) [13:55:06.210] | MSI (c) (B0:9C) [13:55:06:182]: PROPERTY CHANGE: Adding OriginalDatabase property. Its value is 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs2008-integration.msi'.
MSI(i) [13:55:06.210] | MSI (c) (B0:9C) [13:55:06:182]: Machine policy value 'MsiDisableEmbeddedUI' is 0
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:182]: EEUI - Disabling MsiEmbeddedUI in quiet mode
MSI(i) [13:55:06.211] | === Logging started: 4/8/2014  13:55:06 ===
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:183]: Note: 1: 2205 2:  3: PatchPackage
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:183]: Machine policy value 'DisableRollback' is 0
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:183]: User policy value 'DisableRollback' is 0
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:183]: PROPERTY CHANGE: Adding UILevel property. Its value is '2'.
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:183]: Creating MSIHANDLE (118) of type 790537 for thread 3996
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:183]: MsiOpenPackageEx is returning 0
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:183]: Creating MSIHANDLE (119) of type 790541 for thread 3996
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:183]: Closing MSIHANDLE (119) of type 790541 for thread 3996
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:183]: Doing action: AppSearch
MSI(i) [13:55:06.211] | Action 13:55:06: AppSearch. Searching for installed applications
MSI(i) [13:55:06.211] | Action start 13:55:06: AppSearch.
MSI(i) [13:55:06.211] | AppSearch: Property: VS2010DIR.6229EDAD_EDEA_48D9_8C13_CA576A78F3DC, Signature: SIG_VS2010_DIR.6229EDAD_EDEA_48D9_8C13_CA576A78F3DC
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:185]: Note: 1: 2262 2: Signature 3: -2147287038
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:185]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE32\SOFTWARE\Microsoft\VisualStudio\10.0\Setup\VS 3: 2
MSI(i) [13:55:06.211] | AppSearch: Property: VS2011DIR.6229EDAD_EDEA_48D9_8C13_CA576A78F3DC, Signature: SIG_VS2011_DIR.6229EDAD_EDEA_48D9_8C13_CA576A78F3DC
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:185]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE32\SOFTWARE\Microsoft\VisualStudio\11.0\Setup\VS 3: 2
MSI(i) [13:55:06.211] | AppSearch: Property: DEVENV_EXE_2008.FBB3A55A_D719_4787_AB98_1EBEE1E3CC63, Signature: RL_DevenvExe_2008.FBB3A55A_D719_4787_AB98_1EBEE1E3CC63
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:185]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE32\SOFTWARE\Microsoft\VisualStudio\9.0\Setup\VS 3: 2
MSI(i) [13:55:06.211] | AppSearch: Property: DEVENV_EXE_2010.FBB3A55A_D719_4787_AB98_1EBEE1E3CC63, Signature: RL_DevenvExe_2010.FBB3A55A_D719_4787_AB98_1EBEE1E3CC63
MSI(i) [13:55:06.211] | AppSearch: Property: DEVENV_EXE_2011.FBB3A55A_D719_4787_AB98_1EBEE1E3CC63, Signature: RL_DevenvExe_2011.FBB3A55A_D719_4787_AB98_1EBEE1E3CC63
MSI(i) [13:55:06.211] | AppSearch: Property: FILTERS90_1033_DIR.5C3A34FA_BD75_49D3_AE1E_D9AB61E6DA6F, Signature: FILTERS90_1033.5C3A34FA_BD75_49D3_AE1E_D9AB61E6DA6F
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:186]: Note: 1: 2262 2: Signature 3: -2147287038
MSI(i) [13:55:06.211] | AppSearch: Property: FILTERS90_1041_DIR.5C3A34FA_BD75_49D3_AE1E_D9AB61E6DA6F, Signature: FILTERS90_1041.5C3A34FA_BD75_49D3_AE1E_D9AB61E6DA6F
MSI(i) [13:55:06.211] | AppSearch: Property: FILTERS90_1033_FOUND.5C3A34FA_BD75_49D3_AE1E_D9AB61E6DA6F, Signature: FILTERS90_1033.5C3A34FA_BD75_49D3_AE1E_D9AB61E6DA6F
MSI(i) [13:55:06.211] | AppSearch: Property: FILTERS90_1041_FOUND.5C3A34FA_BD75_49D3_AE1E_D9AB61E6DA6F, Signature: FILTERS90_1041.5C3A34FA_BD75_49D3_AE1E_D9AB61E6DA6F
MSI(i) [13:55:06.211] | Action ended 13:55:06: AppSearch. Return value 1.
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:186]: Doing action: CostInitialize
MSI(i) [13:55:06.211] | Action 13:55:06: CostInitialize. Computing space requirements
MSI(i) [13:55:06.211] | Action start 13:55:06: CostInitialize.
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:187]: Machine policy value 'MaxPatchCacheSize' is 10
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:187]: Baseline: Sorting baselines for {EFD393B3-F9F9-43E5-9DEA-7ACA45B1E5B2}.
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:187]: Baseline: New baseline 13.1.5000 from transaction.
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:187]: Baseline: Sorted order Native: Order 0.
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:187]: Baseline Data Table:
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:187]: ProductCode: {EFD393B3-F9F9-43E5-9DEA-7ACA45B1E5B2} Version: 13.1.5000 Attributes: 0 PatchId: Native BaselineId: -2147483648 Order: 0
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:187]: Baseline File Table:
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:188]: PROPERTY CHANGE: Adding ROOTDRIVE property. Its value is 'C:\'.
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:188]: PROPERTY CHANGE: Adding CostingComplete property. Its value is '0'.
MSI(i) [13:55:06.211] | Action ended 13:55:06: CostInitialize. Return value 1.
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:188]: Doing action: FileCost
MSI(i) [13:55:06.211] | Action 13:55:06: FileCost. Computing space requirements
MSI(i) [13:55:06.211] | Action start 13:55:06: FileCost.
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:189]: Note: 1: 2205 2:  3: MsiAssembly
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:190]: Note: 1: 2205 2:  3: Class
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:190]: Note: 1: 2205 2:  3: Extension
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:190]: Note: 1: 2205 2:  3: TypeLib
MSI(i) [13:55:06.211] | Action ended 13:55:06: FileCost. Return value 1.
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:190]: Doing action: CostFinalize
MSI(i) [13:55:06.211] | Action 13:55:06: CostFinalize. Computing space requirements
MSI(i) [13:55:06.211] | Action start 13:55:06: CostFinalize.
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:191]: PROPERTY CHANGE: Adding OutOfDiskSpace property. Its value is '0'.
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:191]: PROPERTY CHANGE: Adding OutOfNoRbDiskSpace property. Its value is '0'.
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:191]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceAvailable property. Its value is '0'.
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:191]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRequired property. Its value is '0'.
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:191]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRemaining property. Its value is '0'.
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:191]: Note: 1: 2205 2:  3: Patch
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:191]: Note: 1: 2205 2:  3: Condition
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:191]: PROPERTY CHANGE: Adding TARGETDIR property. Its value is 'C:\'.
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:191]: PROPERTY CHANGE: Adding VS11_REMOTE_DEBUGGER_X64_DIR property. Its value is 'C:\'.
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:191]: PROPERTY CHANGE: Adding VS11_DEBUGER_DIR property. Its value is 'C:\'.
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:191]: PROPERTY CHANGE: Adding FILTERS90_1041_DIR.5C3A34FA_BD75_49D3_AE1E_D9AB61E6DA6F property. Its value is 'C:\Program Files (x86)\Common Files\FILTERS90_1041_DIR\'.
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:191]: PROPERTY CHANGE: Adding FILTERS90_1033_DIR.5C3A34FA_BD75_49D3_AE1E_D9AB61E6DA6F property. Its value is 'C:\Program Files (x86)\Common Files\FILTERS90_1033_DIR\'.
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:191]: PROPERTY CHANGE: Adding CmnIntel.6229EDAD_EDEA_48D9_8C13_CA576A78F3DC property. Its value is 'C:\Program Files (x86)\Common Files\intel\'.
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:191]: PROPERTY CHANGE: Adding CmnIntelSharedFiles.6229EDAD_EDEA_48D9_8C13_CA576A78F3DC property. Its value is 'C:\Program Files (x86)\Common Files\intel\shared files\'.
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:191]: PROPERTY CHANGE: Adding CmnIntelSharedFilesVS.6229EDAD_EDEA_48D9_8C13_CA576A78F3DC property. Its value is 'C:\Program Files (x86)\Common Files\intel\shared files\VS Integration\'.
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:191]: PROPERTY CHANGE: Adding CmnIntelSharedFilesVSISM.6229EDAD_EDEA_48D9_8C13_CA576A78F3DC property. Its value is 'C:\Program Files (x86)\Common Files\intel\shared files\VS Integration\Intel Software Manager\'.
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:191]: PROPERTY CHANGE: Adding CmnIntelSharedFilesVSISMVS2008.6229EDAD_EDEA_48D9_8C13_CA576A78F3DC property. Its value is 'C:\Program Files (x86)\Common Files\intel\shared files\VS Integration\Intel Software Manager\VS2008\'.
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:191]: PROPERTY CHANGE: Adding ja.6229EDAD_EDEA_48D9_8C13_CA576A78F3DC property. Its value is 'C:\Program Files (x86)\Common Files\intel\shared files\VS Integration\Intel Software Manager\VS2008\ja\'.
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:191]: PROPERTY CHANGE: Adding INSTALLDIR property. Its value is 'C:\'.
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:191]: PROPERTY CHANGE: Adding CommonFilesFolder.FBB3A55A_D719_4787_AB98_1EBEE1E3CC63 property. Its value is 'C:\'.
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:191]: PROPERTY CHANGE: Adding CmnIntel.FBB3A55A_D719_4787_AB98_1EBEE1E3CC63 property. Its value is 'C:\Intel\'.
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:191]: PROPERTY CHANGE: Adding CmnIntelHEBundle.FBB3A55A_D719_4787_AB98_1EBEE1E3CC63 property. Its value is 'C:\Intel\Parallel Studio XE 2013\'.
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:191]: PROPERTY CHANGE: Adding HEBundleMenuDir.FBB3A55A_D719_4787_AB98_1EBEE1E3CC63 property. Its value is 'C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Intel Parallel Studio XE 2013\'.
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:191]: PROPERTY CHANGE: Adding CommonFilesFolder.95C3848C_D156_4249_942C_7A8A0976584F property. Its value is 'C:\'.
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:191]: PROPERTY CHANGE: Adding CmnIntel.95C3848C_D156_4249_942C_7A8A0976584F property. Its value is 'C:\Intel\'.
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:191]: PROPERTY CHANGE: Adding CmnIntelHEBundle.95C3848C_D156_4249_942C_7A8A0976584F property. Its value is 'C:\Intel\Parallel Studio XE 2013\'.
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:191]: Target path resolution complete. Dumping Directory table...
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:191]: Note: target paths subject to change (via custom actions or browsing)
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:191]: Dir (target): Key: TARGETDIR    , Object: C:\
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:191]: Dir (target): Key: WindowsFolder    , Object: C:\Windows\
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:191]: Dir (target): Key: VS11_REMOTE_DEBUGGER_X64_DIR    , Object: C:\
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:191]: Dir (target): Key: VS11_DEBUGER_DIR    , Object: C:\
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:191]: Dir (target): Key: CommonFilesFolder    , Object: C:\Program Files (x86)\Common Files\
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:191]: Dir (target): Key: FILTERS90_1041_DIR.5C3A34FA_BD75_49D3_AE1E_D9AB61E6DA6F    , Object: C:\Program Files (x86)\Common Files\FILTERS90_1041_DIR\
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:191]: Dir (target): Key: FILTERS90_1033_DIR.5C3A34FA_BD75_49D3_AE1E_D9AB61E6DA6F    , Object: C:\Program Files (x86)\Common Files\FILTERS90_1033_DIR\
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:191]: Dir (target): Key: CmnIntel.6229EDAD_EDEA_48D9_8C13_CA576A78F3DC    , Object: C:\Program Files (x86)\Common Files\intel\
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:191]: Dir (target): Key: CmnIntelSharedFiles.6229EDAD_EDEA_48D9_8C13_CA576A78F3DC    , Object: C:\Program Files (x86)\Common Files\intel\shared files\
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:191]: Dir (target): Key: CmnIntelSharedFilesVS.6229EDAD_EDEA_48D9_8C13_CA576A78F3DC    , Object: C:\Program Files (x86)\Common Files\intel\shared files\VS Integration\
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:191]: Dir (target): Key: CmnIntelSharedFilesVSISM.6229EDAD_EDEA_48D9_8C13_CA576A78F3DC    , Object: C:\Program Files (x86)\Common Files\intel\shared files\VS Integration\Intel Software Manager\
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:192]: Dir (target): Key: CmnIntelSharedFilesVSISMVS2008.6229EDAD_EDEA_48D9_8C13_CA576A78F3DC    , Object: C:\Program Files (x86)\Common Files\intel\shared files\VS Integration\Intel Software Manager\VS2008\
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:192]: Dir (target): Key: ja.6229EDAD_EDEA_48D9_8C13_CA576A78F3DC    , Object: C:\Program Files (x86)\Common Files\intel\shared files\VS Integration\Intel Software Manager\VS2008\ja\
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:192]: Dir (target): Key: INSTALLDIR    , Object: C:\
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:192]: Dir (target): Key: CommonFilesFolder.FBB3A55A_D719_4787_AB98_1EBEE1E3CC63    , Object: C:\
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:192]: Dir (target): Key: CmnIntel.FBB3A55A_D719_4787_AB98_1EBEE1E3CC63    , Object: C:\Intel\
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:192]: Dir (target): Key: CmnIntelHEBundle.FBB3A55A_D719_4787_AB98_1EBEE1E3CC63    , Object: C:\Intel\Parallel Studio XE 2013\
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:192]: Dir (target): Key: ProgramMenuFolder    , Object: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:192]: Dir (target): Key: HEBundleMenuDir.FBB3A55A_D719_4787_AB98_1EBEE1E3CC63    , Object: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Intel Parallel Studio XE 2013\
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:192]: Dir (target): Key: CommonFilesFolder.95C3848C_D156_4249_942C_7A8A0976584F    , Object: C:\
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:192]: Dir (target): Key: CmnIntel.95C3848C_D156_4249_942C_7A8A0976584F    , Object: C:\Intel\
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:192]: Dir (target): Key: CmnIntelHEBundle.95C3848C_D156_4249_942C_7A8A0976584F    , Object: C:\Intel\Parallel Studio XE 2013\
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:192]: Dir (target): Key: ProgramFilesFolder    , Object: C:\Program Files (x86)\
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:192]: Dir (target): Key: SystemFolder    , Object: C:\Windows\SysWOW64\
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:192]: PROPERTY CHANGE: Adding INSTALLLEVEL property. Its value is '1'.
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:192]: Note: 1: 2205 2:  3: MsiAssembly
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:192]: Note: 1: 2228 2:  3: MsiAssembly 4:  SELECT `MsiAssembly`.`Attributes`, `MsiAssembly`.`File_Application`, `MsiAssembly`.`File_Manifest`,  `Component`.`KeyPath` FROM `MsiAssembly`, `Component` WHERE  `MsiAssembly`.`Component_` = `Component`.`Component` AND `MsiAssembly`.`Component_` = ?
MSI(i) [13:55:06.211] | Action ended 13:55:06: CostFinalize. Return value 1.
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:192]: Doing action: InstallValidate
MSI(i) [13:55:06.211] | Action 13:55:06: InstallValidate. Validating install
MSI(i) [13:55:06.211] | Action start 13:55:06: InstallValidate.
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:193]: Note: 1: 2205 2:  3: Dialog
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:193]: Feature: core; Installed: Absent;   Request: Local;   Action: Local
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:193]: Component: ProductFamilyAnchor; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:193]: Component: ProductVersionAnchor; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:193]: Component: CommonIntegrationAnchor; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:193]: Component: VsIntegrationAnchor; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:193]: Component: reg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:193]: Component: Comp_Intel.SoftwareManager.dll.6229EDAD_EDEA_48D9_8C13_CA576A78F3DC; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:193]: Component: Comp_Intel.SoftwareManager.resources.dll.6229EDAD_EDEA_48D9_8C13_CA576A78F3DC; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:193]: Component: _reg_ism_2008.6229EDAD_EDEA_48D9_8C13_CA576A78F3DC; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:193]: Component: vs_run.exe.95C3848C_D156_4249_942C_7A8A0976584F; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:193]: Component: VS2008.FBB3A55A_D719_4787_AB98_1EBEE1E3CC63; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:193]: Component: VS2008_win8.FBB3A55A_D719_4787_AB98_1EBEE1E3CC63; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:193]: Component: CT90.5C3A34FA_BD75_49D3_AE1E_D9AB61E6DA6F; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:193]: Component: LT90.5C3A34FA_BD75_49D3_AE1E_D9AB61E6DA6F; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:193]: Component: TT90.5C3A34FA_BD75_49D3_AE1E_D9AB61E6DA6F; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:193]: Component: CT90_jp.5C3A34FA_BD75_49D3_AE1E_D9AB61E6DA6F; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:193]: Component: LT90_jp.5C3A34FA_BD75_49D3_AE1E_D9AB61E6DA6F; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:193]: Component: TT90_jp.5C3A34FA_BD75_49D3_AE1E_D9AB61E6DA6F; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:193]: Component: __reg65; Installed: Null;   Request: Local;   Action: Local;   Client State: Null
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:193]: Component: ___reg_ism_2008.6229EDAD_EDEA_48D9_8C13_CA576A78F3DC65; Installed: Null;   Request: Local;   Action: Local;   Client State: Null
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:193]: Component: __VS2008.FBB3A55A_D719_4787_AB98_1EBEE1E3CC6365; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:193]: Component: __VS2008_win8.FBB3A55A_D719_4787_AB98_1EBEE1E3CC6365; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:193]: Component: __CT90.5C3A34FA_BD75_49D3_AE1E_D9AB61E6DA6F65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:193]: Component: __LT90.5C3A34FA_BD75_49D3_AE1E_D9AB61E6DA6F65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:193]: Component: __TT90.5C3A34FA_BD75_49D3_AE1E_D9AB61E6DA6F65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:193]: Component: __CT90_jp.5C3A34FA_BD75_49D3_AE1E_D9AB61E6DA6F65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:193]: Component: __LT90_jp.5C3A34FA_BD75_49D3_AE1E_D9AB61E6DA6F65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:193]: Component: __TT90_jp.5C3A34FA_BD75_49D3_AE1E_D9AB61E6DA6F65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:193]: Note: 1: 2205 2:  3: BindImage
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:193]: Note: 1: 2205 2:  3: ProgId
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:193]: Note: 1: 2205 2:  3: PublishComponent
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:193]: Note: 1: 2205 2:  3: SelfReg
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:193]: Note: 1: 2205 2:  3: Extension
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:193]: Note: 1: 2205 2:  3: Font
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:193]: Note: 1: 2205 2:  3: Class
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:193]: Note: 1: 2205 2:  3: TypeLib
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:194]: Note: 1: 2205 2:  3: _RemoveFilePath
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:194]: PROPERTY CHANGE: Modifying CostingComplete property. Its current value is '0'. Its new value: '1'.
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:194]: Note: 1: 2205 2:  3: BindImage
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:194]: Note: 1: 2205 2:  3: ProgId
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:194]: Note: 1: 2205 2:  3: PublishComponent
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:194]: Note: 1: 2205 2:  3: SelfReg
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:194]: Note: 1: 2205 2:  3: Extension
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:194]: Note: 1: 2205 2:  3: Font
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:194]: Note: 1: 2205 2:  3: Class
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:194]: Note: 1: 2205 2:  3: TypeLib
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:195]: Note: 1: 2727 2:
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:209]: Note: 1: 2727 2:
MSI(i) [13:55:06.211] | Action ended 13:55:06: InstallValidate. Return value 1.
MSI(i) [13:55:06.211] | MSI (c) (B0:9C) [13:55:06:209]: Closing MSIHANDLE (118) of type 790537 for thread 3996
MSI(i) [13:55:06.211] | === Verbose logging stopped: 4/8/2014  13:55:06 ===
PSET(i) [13:55:06.218] | (4225.285): MsiOpenPackageEx(C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs2008-integration.msi)
PSET(i) [13:55:06.280] | (6497.173): Feature=core PendingAction=-1, Action=3
MSI(i) [13:55:06.280] | === Verbose logging started: 4/8/2014  13:55:06  Build type: SHIP UNICODE 5.00.7601.00  Calling process: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\setup.exe ===
MSI(i) [13:55:06.280] | MSI (c) (B0:9C) [13:55:06:219]: SOFTWARE RESTRICTION POLICY: Verifying package --> 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs2008-integration.msi' against software restriction policy
MSI(i) [13:55:06.280] | MSI (c) (B0:9C) [13:55:06:219]: SOFTWARE RESTRICTION POLICY: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs2008-integration.msi has a digital signature
MSI(i) [13:55:06.280] | MSI (c) (B0:9C) [13:55:06:237]: SOFTWARE RESTRICTION POLICY: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs2008-integration.msi is permitted to run at the 'unrestricted' authorization level.
MSI(i) [13:55:06.280] | MSI (c) (B0:9C) [13:55:06:238]: Cloaking enabled.
MSI(i) [13:55:06.280] | MSI (c) (B0:9C) [13:55:06:238]: Attempting to enable all disabled privileges before calling Install on Server
MSI(i) [13:55:06.280] | MSI (c) (B0:9C) [13:55:06:238]: End dialog not enabled
MSI(i) [13:55:06.280] | MSI (c) (B0:9C) [13:55:06:238]: Original package ==> C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs2008-integration.msi
MSI(i) [13:55:06.280] | MSI (c) (B0:9C) [13:55:06:238]: Package we're running from ==> C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs2008-integration.msi
MSI(i) [13:55:06.280] | MSI (c) (B0:9C) [13:55:06:239]: Machine policy value 'DisableUserInstalls' is 0
MSI(i) [13:55:06.280] | MSI (c) (B0:9C) [13:55:06:239]: APPCOMPAT: Compatibility mode property overrides found.
MSI(i) [13:55:06.280] | MSI (c) (B0:9C) [13:55:06:240]: APPCOMPAT: looking for appcompat database entry with ProductCode '{EFD393B3-F9F9-43E5-9DEA-7ACA45B1E5B2}'.
MSI(i) [13:55:06.280] | MSI (c) (B0:9C) [13:55:06:240]: APPCOMPAT: no matching ProductCode found in database.
MSI(i) [13:55:06.280] | MSI (c) (B0:9C) [13:55:06:241]: MSCOREE not loaded loading copy from system32
MSI(i) [13:55:06.280] | MSI (c) (B0:9C) [13:55:06:245]: Machine policy value 'TransformsSecure' is 0
MSI(i) [13:55:06.280] | MSI (c) (B0:9C) [13:55:06:245]: User policy value 'TransformsAtSource' is 0
MSI(i) [13:55:06.280] | MSI (c) (B0:9C) [13:55:06:245]: Machine policy value 'DisablePatch' is 0
MSI(i) [13:55:06.280] | MSI (c) (B0:9C) [13:55:06:245]: Machine policy value 'AllowLockdownPatch' is 0
MSI(i) [13:55:06.280] | MSI (c) (B0:9C) [13:55:06:245]: Machine policy value 'DisableLUAPatching' is 0
MSI(i) [13:55:06.280] | MSI (c) (B0:9C) [13:55:06:245]: Machine policy value 'DisableFlyWeightPatching' is 0
MSI(i) [13:55:06.280] | MSI (c) (B0:9C) [13:55:06:245]: Enabling baseline caching for this transaction since all active patches are MSI 3.0 style MSPs or at least one MSI 3.0 minor update patch is active
MSI(i) [13:55:06.280] | MSI (c) (B0:9C) [13:55:06:246]: APPCOMPAT: looking for appcompat database entry with ProductCode '{EFD393B3-F9F9-43E5-9DEA-7ACA45B1E5B2}'.
MSI(i) [13:55:06.280] | MSI (c) (B0:9C) [13:55:06:246]: APPCOMPAT: no matching ProductCode found in database.
MSI(i) [13:55:06.280] | MSI (c) (B0:9C) [13:55:06:246]: Transforms are not secure.
MSI(i) [13:55:06.280] | MSI (c) (B0:9C) [13:55:06:246]: PROPERTY CHANGE: Adding MsiLogFileLocation property. Its value is 'C:\Users\PCCA-PM\AppData\Local\Temp\MSIED31.tmp'.
MSI(i) [13:55:06.280] | MSI (c) (B0:9C) [13:55:06:246]: No Command Line.
MSI(i) [13:55:06.280] | MSI (c) (B0:9C) [13:55:06:246]: PROPERTY CHANGE: Adding PackageCode property. Its value is '{27EA0C65-64CE-405E-A049-1F35608919DE}'.
MSI(i) [13:55:06.280] | MSI (c) (B0:9C) [13:55:06:246]: Product Code passed to Engine.Initialize:           '(none)'
MSI(i) [13:55:06.280] | MSI (c) (B0:9C) [13:55:06:246]: Product Code from property table before transforms: '{EFD393B3-F9F9-43E5-9DEA-7ACA45B1E5B2}'
MSI(i) [13:55:06.280] | MSI (c) (B0:9C) [13:55:06:246]: Product Code from property table after transforms:  '{EFD393B3-F9F9-43E5-9DEA-7ACA45B1E5B2}'
MSI(i) [13:55:06.280] | MSI (c) (B0:9C) [13:55:06:246]: Product not registered: beginning first-time install
MSI(i) [13:55:06.280] | MSI (c) (B0:9C) [13:55:06:246]: PROPERTY CHANGE: Adding ProductState property. Its value is '-1'.
MSI(i) [13:55:06.280] | MSI (c) (B0:9C) [13:55:06:246]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer 3: 2
MSI(i) [13:55:06.280] | MSI (c) (B0:9C) [13:55:06:246]: Entering CMsiConfigurationManager::SetLastUsedSource.
MSI(i) [13:55:06.280] | MSI (c) (B0:9C) [13:55:06:246]: User policy value 'SearchOrder' is 'nmu'
MSI(i) [13:55:06.280] | MSI (c) (B0:9C) [13:55:06:246]: Adding new sources is allowed.
MSI(i) [13:55:06.280] | MSI (c) (B0:9C) [13:55:06:246]: PROPERTY CHANGE: Adding PackagecodeChanging property. Its value is '1'.
MSI(i) [13:55:06.280] | MSI (c) (B0:9C) [13:55:06:246]: Package name extracted from package path: 'vs2008-integration.msi'
MSI(i) [13:55:06.280] | MSI (c) (B0:9C) [13:55:06:246]: Package to be registered: 'vs2008-integration.msi'
MSI(i) [13:55:06.280] | MSI (c) (B0:9C) [13:55:06:246]: Note: 1: 2205 2:  3: Error
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:247]: Note: 1: 2262 2: AdminProperties 3: -2147287038
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:247]: Machine policy value 'DisableMsi' is 0
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:247]: Machine policy value 'AlwaysInstallElevated' is 0
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:247]: User policy value 'AlwaysInstallElevated' is 0
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:247]: Product installation will be elevated because user is admin and product is being installed per-machine.
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:247]: Running product '{EFD393B3-F9F9-43E5-9DEA-7ACA45B1E5B2}' with elevated privileges: Product is assigned.
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:247]: PROPERTY CHANGE: Adding MsiSystemRebootPending property. Its value is '1'.
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:247]: TRANSFORMS property is now:
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:247]: PROPERTY CHANGE: Adding VersionDatabase property. Its value is '200'.
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:248]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:248]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Favorites
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:248]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Network Shortcuts
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:248]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Documents
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:248]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:248]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Recent
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:248]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\SendTo
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:248]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Templates
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:248]: SHELL32::SHGetFolderPath returned: C:\ProgramData
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:248]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Local
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:248]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Pictures
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:248]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:248]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:248]: SHELL32::SHGetFolderPath returned: C:\Users\Public\Desktop
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:248]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:248]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:248]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Desktop
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:248]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Templates
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:248]: SHELL32::SHGetFolderPath returned: C:\Windows\Fonts
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:248]: Note: 1: 2898 2: MS Sans Serif 3: MS Sans Serif 4: 0 5: 16
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:251]: MSI_LUA: Setting AdminUser property to 1 because this is the client or the user has already permitted elevation
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:251]: MSI_LUA: Setting MsiRunningElevated property to 1 because the install is already running elevated.
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:251]: PROPERTY CHANGE: Adding MsiRunningElevated property. Its value is '1'.
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:251]: PROPERTY CHANGE: Adding Privileged property. Its value is '1'.
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:251]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\MS Setup (ACME)\User Info 3: 2
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:251]: PROPERTY CHANGE: Adding USERNAME property. Its value is 'A Valued IT Customer'.
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:251]: PROPERTY CHANGE: Adding COMPANYNAME property. Its value is 'Intel Corporation'.
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:251]: PROPERTY CHANGE: Adding DATABASE property. Its value is 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs2008-integration.msi'.
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:251]: PROPERTY CHANGE: Adding OriginalDatabase property. Its value is 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs2008-integration.msi'.
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:251]: Machine policy value 'MsiDisableEmbeddedUI' is 0
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:251]: EEUI - Disabling MsiEmbeddedUI in quiet mode
MSI(i) [13:55:06.281] | === Logging started: 4/8/2014  13:55:06 ===
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:251]: Note: 1: 2205 2:  3: PatchPackage
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:251]: Machine policy value 'DisableRollback' is 0
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:251]: User policy value 'DisableRollback' is 0
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:251]: PROPERTY CHANGE: Adding UILevel property. Its value is '2'.
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:251]: Creating MSIHANDLE (120) of type 790537 for thread 3996
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:251]: MsiOpenPackageEx is returning 0
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:251]: Creating MSIHANDLE (121) of type 790541 for thread 3996
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:251]: Closing MSIHANDLE (121) of type 790541 for thread 3996
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:252]: Doing action: AppSearch
MSI(i) [13:55:06.281] | Action 13:55:06: AppSearch. Searching for installed applications
MSI(i) [13:55:06.281] | Action start 13:55:06: AppSearch.
MSI(i) [13:55:06.281] | AppSearch: Property: VS2010DIR.6229EDAD_EDEA_48D9_8C13_CA576A78F3DC, Signature: SIG_VS2010_DIR.6229EDAD_EDEA_48D9_8C13_CA576A78F3DC
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:253]: Note: 1: 2262 2: Signature 3: -2147287038
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:253]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE32\SOFTWARE\Microsoft\VisualStudio\10.0\Setup\VS 3: 2
MSI(i) [13:55:06.281] | AppSearch: Property: VS2011DIR.6229EDAD_EDEA_48D9_8C13_CA576A78F3DC, Signature: SIG_VS2011_DIR.6229EDAD_EDEA_48D9_8C13_CA576A78F3DC
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:254]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE32\SOFTWARE\Microsoft\VisualStudio\11.0\Setup\VS 3: 2
MSI(i) [13:55:06.281] | AppSearch: Property: DEVENV_EXE_2008.FBB3A55A_D719_4787_AB98_1EBEE1E3CC63, Signature: RL_DevenvExe_2008.FBB3A55A_D719_4787_AB98_1EBEE1E3CC63
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:254]: Note: 1: 2262 2: Signature 3: -2147287038
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:254]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE32\SOFTWARE\Microsoft\VisualStudio\9.0\Setup\VS 3: 2
MSI(i) [13:55:06.281] | AppSearch: Property: DEVENV_EXE_2010.FBB3A55A_D719_4787_AB98_1EBEE1E3CC63, Signature: RL_DevenvExe_2010.FBB3A55A_D719_4787_AB98_1EBEE1E3CC63
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:254]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE32\SOFTWARE\Microsoft\VisualStudio\10.0\Setup\VS 3: 2
MSI(i) [13:55:06.281] | AppSearch: Property: DEVENV_EXE_2011.FBB3A55A_D719_4787_AB98_1EBEE1E3CC63, Signature: RL_DevenvExe_2011.FBB3A55A_D719_4787_AB98_1EBEE1E3CC63
MSI(i) [13:55:06.281] | AppSearch: Property: FILTERS90_1033_DIR.5C3A34FA_BD75_49D3_AE1E_D9AB61E6DA6F, Signature: FILTERS90_1033.5C3A34FA_BD75_49D3_AE1E_D9AB61E6DA6F
MSI(i) [13:55:06.281] | AppSearch: Property: FILTERS90_1041_DIR.5C3A34FA_BD75_49D3_AE1E_D9AB61E6DA6F, Signature: FILTERS90_1041.5C3A34FA_BD75_49D3_AE1E_D9AB61E6DA6F
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:255]: Note: 1: 2262 2: Signature 3: -2147287038
MSI(i) [13:55:06.281] | AppSearch: Property: FILTERS90_1033_FOUND.5C3A34FA_BD75_49D3_AE1E_D9AB61E6DA6F, Signature: FILTERS90_1033.5C3A34FA_BD75_49D3_AE1E_D9AB61E6DA6F
MSI(i) [13:55:06.281] | AppSearch: Property: FILTERS90_1041_FOUND.5C3A34FA_BD75_49D3_AE1E_D9AB61E6DA6F, Signature: FILTERS90_1041.5C3A34FA_BD75_49D3_AE1E_D9AB61E6DA6F
MSI(i) [13:55:06.281] | Action ended 13:55:06: AppSearch. Return value 1.
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:255]: Doing action: CostInitialize
MSI(i) [13:55:06.281] | Action 13:55:06: CostInitialize. Computing space requirements
MSI(i) [13:55:06.281] | Action start 13:55:06: CostInitialize.
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:256]: Machine policy value 'MaxPatchCacheSize' is 10
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:256]: Baseline: Sorting baselines for {EFD393B3-F9F9-43E5-9DEA-7ACA45B1E5B2}.
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:256]: Baseline: New baseline 13.1.5000 from transaction.
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:256]: Baseline: Sorted order Native: Order 0.
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:256]: Baseline Data Table:
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:256]: ProductCode: {EFD393B3-F9F9-43E5-9DEA-7ACA45B1E5B2} Version: 13.1.5000 Attributes: 0 PatchId: Native BaselineId: -2147483648 Order: 0
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:256]: Baseline File Table:
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:257]: PROPERTY CHANGE: Adding ROOTDRIVE property. Its value is 'C:\'.
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:257]: PROPERTY CHANGE: Adding CostingComplete property. Its value is '0'.
MSI(i) [13:55:06.281] | Action ended 13:55:06: CostInitialize. Return value 1.
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:257]: Doing action: FileCost
MSI(i) [13:55:06.281] | Action 13:55:06: FileCost. Computing space requirements
MSI(i) [13:55:06.281] | Action start 13:55:06: FileCost.
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:259]: Note: 1: 2205 2:  3: MsiAssembly
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:259]: Note: 1: 2205 2:  3: Class
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:259]: Note: 1: 2205 2:  3: Extension
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:259]: Note: 1: 2205 2:  3: TypeLib
MSI(i) [13:55:06.281] | Action ended 13:55:06: FileCost. Return value 1.
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:259]: Doing action: CostFinalize
MSI(i) [13:55:06.281] | Action 13:55:06: CostFinalize. Computing space requirements
MSI(i) [13:55:06.281] | Action start 13:55:06: CostFinalize.
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:260]: PROPERTY CHANGE: Adding OutOfDiskSpace property. Its value is '0'.
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:260]: PROPERTY CHANGE: Adding OutOfNoRbDiskSpace property. Its value is '0'.
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:260]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceAvailable property. Its value is '0'.
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:260]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRequired property. Its value is '0'.
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:260]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRemaining property. Its value is '0'.
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:260]: Note: 1: 2205 2:  3: Patch
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:260]: Note: 1: 2205 2:  3: Condition
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:260]: PROPERTY CHANGE: Adding TARGETDIR property. Its value is 'C:\'.
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:260]: PROPERTY CHANGE: Adding VS11_REMOTE_DEBUGGER_X64_DIR property. Its value is 'C:\'.
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:260]: PROPERTY CHANGE: Adding VS11_DEBUGER_DIR property. Its value is 'C:\'.
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:260]: PROPERTY CHANGE: Adding FILTERS90_1041_DIR.5C3A34FA_BD75_49D3_AE1E_D9AB61E6DA6F property. Its value is 'C:\Program Files (x86)\Common Files\FILTERS90_1041_DIR\'.
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:260]: PROPERTY CHANGE: Adding FILTERS90_1033_DIR.5C3A34FA_BD75_49D3_AE1E_D9AB61E6DA6F property. Its value is 'C:\Program Files (x86)\Common Files\FILTERS90_1033_DIR\'.
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:261]: PROPERTY CHANGE: Adding CmnIntel.6229EDAD_EDEA_48D9_8C13_CA576A78F3DC property. Its value is 'C:\Program Files (x86)\Common Files\intel\'.
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:261]: PROPERTY CHANGE: Adding CmnIntelSharedFiles.6229EDAD_EDEA_48D9_8C13_CA576A78F3DC property. Its value is 'C:\Program Files (x86)\Common Files\intel\shared files\'.
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:261]: PROPERTY CHANGE: Adding CmnIntelSharedFilesVS.6229EDAD_EDEA_48D9_8C13_CA576A78F3DC property. Its value is 'C:\Program Files (x86)\Common Files\intel\shared files\VS Integration\'.
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:261]: PROPERTY CHANGE: Adding CmnIntelSharedFilesVSISM.6229EDAD_EDEA_48D9_8C13_CA576A78F3DC property. Its value is 'C:\Program Files (x86)\Common Files\intel\shared files\VS Integration\Intel Software Manager\'.
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:261]: PROPERTY CHANGE: Adding CmnIntelSharedFilesVSISMVS2008.6229EDAD_EDEA_48D9_8C13_CA576A78F3DC property. Its value is 'C:\Program Files (x86)\Common Files\intel\shared files\VS Integration\Intel Software Manager\VS2008\'.
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:261]: PROPERTY CHANGE: Adding ja.6229EDAD_EDEA_48D9_8C13_CA576A78F3DC property. Its value is 'C:\Program Files (x86)\Common Files\intel\shared files\VS Integration\Intel Software Manager\VS2008\ja\'.
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:261]: PROPERTY CHANGE: Adding INSTALLDIR property. Its value is 'C:\'.
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:261]: PROPERTY CHANGE: Adding CommonFilesFolder.FBB3A55A_D719_4787_AB98_1EBEE1E3CC63 property. Its value is 'C:\'.
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:261]: PROPERTY CHANGE: Adding CmnIntel.FBB3A55A_D719_4787_AB98_1EBEE1E3CC63 property. Its value is 'C:\Intel\'.
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:261]: PROPERTY CHANGE: Adding CmnIntelHEBundle.FBB3A55A_D719_4787_AB98_1EBEE1E3CC63 property. Its value is 'C:\Intel\Parallel Studio XE 2013\'.
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:261]: PROPERTY CHANGE: Adding HEBundleMenuDir.FBB3A55A_D719_4787_AB98_1EBEE1E3CC63 property. Its value is 'C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Intel Parallel Studio XE 2013\'.
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:261]: PROPERTY CHANGE: Adding CommonFilesFolder.95C3848C_D156_4249_942C_7A8A0976584F property. Its value is 'C:\'.
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:261]: PROPERTY CHANGE: Adding CmnIntel.95C3848C_D156_4249_942C_7A8A0976584F property. Its value is 'C:\Intel\'.
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:261]: PROPERTY CHANGE: Adding CmnIntelHEBundle.95C3848C_D156_4249_942C_7A8A0976584F property. Its value is 'C:\Intel\Parallel Studio XE 2013\'.
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:261]: Target path resolution complete. Dumping Directory table...
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:261]: Note: target paths subject to change (via custom actions or browsing)
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:261]: Dir (target): Key: TARGETDIR    , Object: C:\
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:261]: Dir (target): Key: WindowsFolder    , Object: C:\Windows\
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:261]: Dir (target): Key: VS11_REMOTE_DEBUGGER_X64_DIR    , Object: C:\
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:261]: Dir (target): Key: VS11_DEBUGER_DIR    , Object: C:\
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:261]: Dir (target): Key: CommonFilesFolder    , Object: C:\Program Files (x86)\Common Files\
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:261]: Dir (target): Key: FILTERS90_1041_DIR.5C3A34FA_BD75_49D3_AE1E_D9AB61E6DA6F    , Object: C:\Program Files (x86)\Common Files\FILTERS90_1041_DIR\
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:261]: Dir (target): Key: FILTERS90_1033_DIR.5C3A34FA_BD75_49D3_AE1E_D9AB61E6DA6F    , Object: C:\Program Files (x86)\Common Files\FILTERS90_1033_DIR\
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:261]: Dir (target): Key: CmnIntel.6229EDAD_EDEA_48D9_8C13_CA576A78F3DC    , Object: C:\Program Files (x86)\Common Files\intel\
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:261]: Dir (target): Key: CmnIntelSharedFiles.6229EDAD_EDEA_48D9_8C13_CA576A78F3DC    , Object: C:\Program Files (x86)\Common Files\intel\shared files\
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:261]: Dir (target): Key: CmnIntelSharedFilesVS.6229EDAD_EDEA_48D9_8C13_CA576A78F3DC    , Object: C:\Program Files (x86)\Common Files\intel\shared files\VS Integration\
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:261]: Dir (target): Key: CmnIntelSharedFilesVSISM.6229EDAD_EDEA_48D9_8C13_CA576A78F3DC    , Object: C:\Program Files (x86)\Common Files\intel\shared files\VS Integration\Intel Software Manager\
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:261]: Dir (target): Key: CmnIntelSharedFilesVSISMVS2008.6229EDAD_EDEA_48D9_8C13_CA576A78F3DC    , Object: C:\Program Files (x86)\Common Files\intel\shared files\VS Integration\Intel Software Manager\VS2008\
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:261]: Dir (target): Key: ja.6229EDAD_EDEA_48D9_8C13_CA576A78F3DC    , Object: C:\Program Files (x86)\Common Files\intel\shared files\VS Integration\Intel Software Manager\VS2008\ja\
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:261]: Dir (target): Key: INSTALLDIR    , Object: C:\
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:261]: Dir (target): Key: CommonFilesFolder.FBB3A55A_D719_4787_AB98_1EBEE1E3CC63    , Object: C:\
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:261]: Dir (target): Key: CmnIntel.FBB3A55A_D719_4787_AB98_1EBEE1E3CC63    , Object: C:\Intel\
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:261]: Dir (target): Key: CmnIntelHEBundle.FBB3A55A_D719_4787_AB98_1EBEE1E3CC63    , Object: C:\Intel\Parallel Studio XE 2013\
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:261]: Dir (target): Key: ProgramMenuFolder    , Object: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:261]: Dir (target): Key: HEBundleMenuDir.FBB3A55A_D719_4787_AB98_1EBEE1E3CC63    , Object: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Intel Parallel Studio XE 2013\
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:261]: Dir (target): Key: CommonFilesFolder.95C3848C_D156_4249_942C_7A8A0976584F    , Object: C:\
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:261]: Dir (target): Key: CmnIntel.95C3848C_D156_4249_942C_7A8A0976584F    , Object: C:\Intel\
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:261]: Dir (target): Key: CmnIntelHEBundle.95C3848C_D156_4249_942C_7A8A0976584F    , Object: C:\Intel\Parallel Studio XE 2013\
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:261]: Dir (target): Key: ProgramFilesFolder    , Object: C:\Program Files (x86)\
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:261]: Dir (target): Key: SystemFolder    , Object: C:\Windows\SysWOW64\
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:261]: PROPERTY CHANGE: Adding INSTALLLEVEL property. Its value is '1'.
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:261]: Note: 1: 2205 2:  3: MsiAssembly
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:261]: Note: 1: 2228 2:  3: MsiAssembly 4:  SELECT `MsiAssembly`.`Attributes`, `MsiAssembly`.`File_Application`, `MsiAssembly`.`File_Manifest`,  `Component`.`KeyPath` FROM `MsiAssembly`, `Component` WHERE  `MsiAssembly`.`Component_` = `Component`.`Component` AND `MsiAssembly`.`Component_` = ?
MSI(i) [13:55:06.281] | Action ended 13:55:06: CostFinalize. Return value 1.
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:261]: Doing action: InstallValidate
MSI(i) [13:55:06.281] | Action 13:55:06: InstallValidate. Validating install
MSI(i) [13:55:06.281] | Action start 13:55:06: InstallValidate.
MSI(i) [13:55:06.281] | MSI (c) (B0:9C) [13:55:06:262]: Note: 1: 2205 2:  3: Dialog
MSI(i) [13:55:06.283] | MSI (c) (B0:9C) [13:55:06:262]: Feature: core; Installed: Absent;   Request: Local;   Action: Local
MSI(i) [13:55:06.283] | MSI (c) (B0:9C) [13:55:06:263]: Component: ProductFamilyAnchor; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:55:06.283] | MSI (c) (B0:9C) [13:55:06:263]: Component: ProductVersionAnchor; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:55:06.283] | MSI (c) (B0:9C) [13:55:06:263]: Component: CommonIntegrationAnchor; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:55:06.283] | MSI (c) (B0:9C) [13:55:06:263]: Component: VsIntegrationAnchor; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:55:06.283] | MSI (c) (B0:9C) [13:55:06:263]: Component: reg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:55:06.283] | MSI (c) (B0:9C) [13:55:06:263]: Component: Comp_Intel.SoftwareManager.dll.6229EDAD_EDEA_48D9_8C13_CA576A78F3DC; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:55:06.283] | MSI (c) (B0:9C) [13:55:06:263]: Component: Comp_Intel.SoftwareManager.resources.dll.6229EDAD_EDEA_48D9_8C13_CA576A78F3DC; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:55:06.283] | MSI (c) (B0:9C) [13:55:06:263]: Component: _reg_ism_2008.6229EDAD_EDEA_48D9_8C13_CA576A78F3DC; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:55:06.283] | MSI (c) (B0:9C) [13:55:06:263]: Component: vs_run.exe.95C3848C_D156_4249_942C_7A8A0976584F; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:55:06.283] | MSI (c) (B0:9C) [13:55:06:263]: Component: VS2008.FBB3A55A_D719_4787_AB98_1EBEE1E3CC63; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:55:06.283] | MSI (c) (B0:9C) [13:55:06:263]: Component: VS2008_win8.FBB3A55A_D719_4787_AB98_1EBEE1E3CC63; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:55:06.283] | MSI (c) (B0:9C) [13:55:06:263]: Component: CT90.5C3A34FA_BD75_49D3_AE1E_D9AB61E6DA6F; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:55:06.283] | MSI (c) (B0:9C) [13:55:06:263]: Component: LT90.5C3A34FA_BD75_49D3_AE1E_D9AB61E6DA6F; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:55:06.283] | MSI (c) (B0:9C) [13:55:06:263]: Component: TT90.5C3A34FA_BD75_49D3_AE1E_D9AB61E6DA6F; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:55:06.283] | MSI (c) (B0:9C) [13:55:06:263]: Component: CT90_jp.5C3A34FA_BD75_49D3_AE1E_D9AB61E6DA6F; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:55:06.283] | MSI (c) (B0:9C) [13:55:06:263]: Component: LT90_jp.5C3A34FA_BD75_49D3_AE1E_D9AB61E6DA6F; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:55:06.283] | MSI (c) (B0:9C) [13:55:06:263]: Component: TT90_jp.5C3A34FA_BD75_49D3_AE1E_D9AB61E6DA6F; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:55:06.283] | MSI (c) (B0:9C) [13:55:06:263]: Component: __reg65; Installed: Null;   Request: Local;   Action: Local;   Client State: Null
MSI(i) [13:55:06.283] | MSI (c) (B0:9C) [13:55:06:263]: Component: ___reg_ism_2008.6229EDAD_EDEA_48D9_8C13_CA576A78F3DC65; Installed: Null;   Request: Local;   Action: Local;   Client State: Null
MSI(i) [13:55:06.283] | MSI (c) (B0:9C) [13:55:06:263]: Component: __VS2008.FBB3A55A_D719_4787_AB98_1EBEE1E3CC6365; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:55:06.283] | MSI (c) (B0:9C) [13:55:06:263]: Component: __VS2008_win8.FBB3A55A_D719_4787_AB98_1EBEE1E3CC6365; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:55:06.283] | MSI (c) (B0:9C) [13:55:06:263]: Component: __CT90.5C3A34FA_BD75_49D3_AE1E_D9AB61E6DA6F65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:55:06.283] | MSI (c) (B0:9C) [13:55:06:263]: Component: __LT90.5C3A34FA_BD75_49D3_AE1E_D9AB61E6DA6F65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:55:06.283] | MSI (c) (B0:9C) [13:55:06:263]: Component: __TT90.5C3A34FA_BD75_49D3_AE1E_D9AB61E6DA6F65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:55:06.283] | MSI (c) (B0:9C) [13:55:06:263]: Component: __CT90_jp.5C3A34FA_BD75_49D3_AE1E_D9AB61E6DA6F65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:55:06.283] | MSI (c) (B0:9C) [13:55:06:263]: Component: __LT90_jp.5C3A34FA_BD75_49D3_AE1E_D9AB61E6DA6F65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:55:06.283] | MSI (c) (B0:9C) [13:55:06:263]: Component: __TT90_jp.5C3A34FA_BD75_49D3_AE1E_D9AB61E6DA6F65; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:55:06.283] | MSI (c) (B0:9C) [13:55:06:263]: Note: 1: 2205 2:  3: BindImage
MSI(i) [13:55:06.283] | MSI (c) (B0:9C) [13:55:06:263]: Note: 1: 2205 2:  3: ProgId
MSI(i) [13:55:06.283] | MSI (c) (B0:9C) [13:55:06:263]: Note: 1: 2205 2:  3: PublishComponent
MSI(i) [13:55:06.283] | MSI (c) (B0:9C) [13:55:06:263]: Note: 1: 2205 2:  3: SelfReg
MSI(i) [13:55:06.283] | MSI (c) (B0:9C) [13:55:06:263]: Note: 1: 2205 2:  3: Extension
MSI(i) [13:55:06.283] | MSI (c) (B0:9C) [13:55:06:263]: Note: 1: 2205 2:  3: Font
MSI(i) [13:55:06.283] | MSI (c) (B0:9C) [13:55:06:263]: Note: 1: 2205 2:  3: Class
MSI(i) [13:55:06.283] | MSI (c) (B0:9C) [13:55:06:263]: Note: 1: 2205 2:  3: TypeLib
MSI(i) [13:55:06.283] | MSI (c) (B0:9C) [13:55:06:263]: Note: 1: 2205 2:  3: _RemoveFilePath
MSI(i) [13:55:06.283] | MSI (c) (B0:9C) [13:55:06:264]: PROPERTY CHANGE: Modifying CostingComplete property. Its current value is '0'. Its new value: '1'.
MSI(i) [13:55:06.283] | MSI (c) (B0:9C) [13:55:06:264]: Note: 1: 2205 2:  3: BindImage
MSI(i) [13:55:06.283] | MSI (c) (B0:9C) [13:55:06:264]: Note: 1: 2205 2:  3: ProgId
MSI(i) [13:55:06.283] | MSI (c) (B0:9C) [13:55:06:264]: Note: 1: 2205 2:  3: PublishComponent
MSI(i) [13:55:06.283] | MSI (c) (B0:9C) [13:55:06:264]: Note: 1: 2205 2:  3: SelfReg
MSI(i) [13:55:06.283] | MSI (c) (B0:9C) [13:55:06:264]: Note: 1: 2205 2:  3: Extension
MSI(i) [13:55:06.283] | MSI (c) (B0:9C) [13:55:06:264]: Note: 1: 2205 2:  3: Font
MSI(i) [13:55:06.283] | MSI (c) (B0:9C) [13:55:06:264]: Note: 1: 2205 2:  3: Class
MSI(i) [13:55:06.283] | MSI (c) (B0:9C) [13:55:06:264]: Note: 1: 2205 2:  3: TypeLib
MSI(i) [13:55:06.283] | MSI (c) (B0:9C) [13:55:06:264]: Note: 1: 2727 2:
MSI(i) [13:55:06.283] | MSI (c) (B0:9C) [13:55:06:280]: Note: 1: 2727 2:
MSI(i) [13:55:06.283] | Action ended 13:55:06: InstallValidate. Return value 1.
MSI(i) [13:55:06.283] | MSI (c) (B0:9C) [13:55:06:280]: Closing MSIHANDLE (120) of type 790537 for thread 3996
MSI(i) [13:55:06.283] | === Verbose logging stopped: 4/8/2014  13:55:06 ===
PSET(i) [13:55:06.289] | (4225.1157): msi package: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs2010-integration.msi
PSET(i) [13:55:06.289] | (4225.1158): LicIsValid: 1     InstallOnCurrentArch: 1     Installed State: -1     Pending Action: 3
PSET(i) [13:55:06.289] | (673.178): UpdateNeedforCheck {ACD97E2A-090D-46ea-9983-6E44BCA28575}: Need
PSET(i) [13:55:06.289] | (673.178): UpdateNeedforCheck {3AE471C7-8858-472a-8D7C-48B871B5EBDF}: Need
PSET(i) [13:55:06.289] | (673.178): UpdateNeedforCheck {D52A1D2E-8D7A-4822-9421-3A92C64DB956}: Need
UNK(i) [13:55:06.289] |
Plugin psetlogger is initialized.
UNK(i) [13:55:06.289] | pset::abstract_context(context == pset::ContextInfo(eInstallMode == INSTALL_MODE_TYPICAL, iLog == ptr(0x1563f74), lLocaleID == size_t("1033"), sCurrentArchitecture == String("Intel64"), sLicenseFiles == String(""), sVSPackageNumber == String(""), sPathToLocaleFileFolder == String("C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\1033\"), sSerialNumber == String("")))
UNK(i) [13:55:06.289] | pset::abstract_context() return: deps::Context(mode == INSTALL, silent == bool(false), upfront == bool(false), full == bool(false), locale == int("0"))
UNK(i) [13:55:06.289] | Main(id == {ACD97E2A-090D-46ea-9983-6E44BCA28575}, severity == 0, message == ptr(0x16f068))
UNK(i) [13:55:06.289] | Main(): Check dependencies
UNK(i) [13:55:06.289] | Main(): exit with severity == DependencyCode(0), message == String("")
PSET(i) [13:55:06.289] | (673.118): Check Dependency for {ACD97E2A-090D-46ea-9983-6E44BCA28575}: 0
UNK(i) [13:55:06.290] |
UNK(i) [13:55:06.290] | pset::abstract_context(context == pset::ContextInfo(eInstallMode == INSTALL_MODE_TYPICAL, iLog == ptr(0x1563f74), lLocaleID == size_t("1033"), sCurrentArchitecture == String("Intel64"), sLicenseFiles == String(""), sVSPackageNumber == String(""), sPathToLocaleFileFolder == String("C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\1033\"), sSerialNumber == String("")))
UNK(i) [13:55:06.290] | pset::abstract_context() return: deps::Context(mode == INSTALL, silent == bool(false), upfront == bool(false), full == bool(false), locale == int("0"))
UNK(i) [13:55:06.290] | Main(id == {D52A1D2E-8D7A-4822-9421-3A92C64DB956}, severity == 0, message == ptr(0x16f068))
UNK(i) [13:55:06.290] | Main(): Check if need to show VS Integration dialog
UNK(i) [13:55:06.290] | Main(): Enable dialog
UNK(i) [13:55:06.290] | Main(): exit with severity == MISSING_DEPENDENCY_NO_SUMMARY, message == String("")
PSET(i) [13:55:06.290] | (673.118): Check Dependency for {D52A1D2E-8D7A-4822-9421-3A92C64DB956}: 12032
UNK(i) [13:55:06.290] | Main(id == {E3BA8A13-2647-4c01-81D5-77E6D912D9D5}, severity == 0, message == ptr(0x16f068))
UNK(i) [13:55:06.290] | Main(): disable VS 11
UNK(i) [13:55:06.290] | Main(): exit with severity == MISSING_DEPENDENCY_COMPONENT_DISABLED, message == String("")
PSET(i) [13:55:06.290] | (673.118): Check Dependency for {E3BA8A13-2647-4c01-81D5-77E6D912D9D5}: 12021
UNK(i) [13:55:06.290] | Main(id == {F3CE10E5-7F75-4356-A379-05F5D6B04FB6}, severity == 0, message == ptr(0x16f068))
UNK(i) [13:55:06.290] | Main(): disable VS2008
PSET(i) [13:55:06.290] | (673.118): Check Dependency for {F3CE10E5-7F75-4356-A379-05F5D6B04FB6}: 12021
UNK(i) [13:55:06.290] | Main(id == {3AE471C7-8858-472a-8D7C-48B871B5EBDF}, severity == 0, message == ptr(0x16f068))
UNK(i) [13:55:06.290] | Main(): disable VS2010
PSET(i) [13:55:06.290] | (673.118): Check Dependency for {3AE471C7-8858-472a-8D7C-48B871B5EBDF}: 12021
UNK(i) [13:55:06.291] | Main(id == {8AA98789-C136-4adc-8269-86F3C222906F}, severity == 0, message == ptr(0x16f068))
UNK(i) [13:55:06.291] | Main(): exit with severity == DependencyCode(0), message == String("")
PSET(i) [13:55:06.291] | (673.118): Check Dependency for {8AA98789-C136-4adc-8269-86F3C222906F}: 0
PSET(i) [13:55:06.291] | (4225.1224): Disabled C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs2010-integration.msi
PSET(i) [13:55:06.291] | (4225.285): MsiOpenPackageEx(C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs2010-integration.msi)
PSET(i) [13:55:06.346] | (6497.173): Feature=core PendingAction=5, Action=3
PSET(i) [13:55:06.346] | (6497.176): Call MsiSetFeatureState(core)
MSI(i) [13:55:06.347] | === Verbose logging started: 4/8/2014  13:55:06  Build type: SHIP UNICODE 5.00.7601.00  Calling process: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\setup.exe ===
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:292]: SOFTWARE RESTRICTION POLICY: Verifying package --> 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs2010-integration.msi' against software restriction policy
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:292]: SOFTWARE RESTRICTION POLICY: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs2010-integration.msi has a digital signature
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:308]: SOFTWARE RESTRICTION POLICY: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs2010-integration.msi is permitted to run at the 'unrestricted' authorization level.
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:308]: Cloaking enabled.
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:308]: Attempting to enable all disabled privileges before calling Install on Server
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:308]: End dialog not enabled
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:309]: Original package ==> C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs2010-integration.msi
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:309]: Package we're running from ==> C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs2010-integration.msi
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:309]: Machine policy value 'DisableUserInstalls' is 0
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:310]: APPCOMPAT: Compatibility mode property overrides found.
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:310]: APPCOMPAT: looking for appcompat database entry with ProductCode '{E16E559E-30A0-49BA-81F5-636CE693B4A1}'.
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:310]: APPCOMPAT: no matching ProductCode found in database.
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:312]: MSCOREE not loaded loading copy from system32
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:315]: Machine policy value 'TransformsSecure' is 0
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:315]: User policy value 'TransformsAtSource' is 0
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:316]: Machine policy value 'DisablePatch' is 0
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:316]: Machine policy value 'AllowLockdownPatch' is 0
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:316]: Machine policy value 'DisableLUAPatching' is 0
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:316]: Machine policy value 'DisableFlyWeightPatching' is 0
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:316]: Enabling baseline caching for this transaction since all active patches are MSI 3.0 style MSPs or at least one MSI 3.0 minor update patch is active
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:316]: APPCOMPAT: looking for appcompat database entry with ProductCode '{E16E559E-30A0-49BA-81F5-636CE693B4A1}'.
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:316]: APPCOMPAT: no matching ProductCode found in database.
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:316]: Transforms are not secure.
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:316]: PROPERTY CHANGE: Adding MsiLogFileLocation property. Its value is 'C:\Users\PCCA-PM\AppData\Local\Temp\MSIED31.tmp'.
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:316]: No Command Line.
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:316]: PROPERTY CHANGE: Adding PackageCode property. Its value is '{4E6E5693-7562-4ABD-B30F-309AC4849EEF}'.
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:316]: Product Code passed to Engine.Initialize:           '(none)'
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:316]: Product Code from property table before transforms: '{E16E559E-30A0-49BA-81F5-636CE693B4A1}'
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:316]: Product Code from property table after transforms:  '{E16E559E-30A0-49BA-81F5-636CE693B4A1}'
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:316]: Product not registered: beginning first-time install
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:316]: PROPERTY CHANGE: Adding ProductState property. Its value is '-1'.
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:317]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer 3: 2
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:317]: Entering CMsiConfigurationManager::SetLastUsedSource.
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:317]: User policy value 'SearchOrder' is 'nmu'
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:317]: Adding new sources is allowed.
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:317]: PROPERTY CHANGE: Adding PackagecodeChanging property. Its value is '1'.
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:317]: Package name extracted from package path: 'vs2010-integration.msi'
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:317]: Package to be registered: 'vs2010-integration.msi'
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:317]: Note: 1: 2205 2:  3: Error
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:317]: Note: 1: 2262 2: AdminProperties 3: -2147287038
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:317]: Machine policy value 'DisableMsi' is 0
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:317]: Machine policy value 'AlwaysInstallElevated' is 0
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:317]: User policy value 'AlwaysInstallElevated' is 0
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:318]: Product installation will be elevated because user is admin and product is being installed per-machine.
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:318]: Running product '{E16E559E-30A0-49BA-81F5-636CE693B4A1}' with elevated privileges: Product is assigned.
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:318]: PROPERTY CHANGE: Adding MsiSystemRebootPending property. Its value is '1'.
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:318]: TRANSFORMS property is now:
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:318]: PROPERTY CHANGE: Adding VersionDatabase property. Its value is '200'.
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:318]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:318]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Favorites
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:318]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Network Shortcuts
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:318]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Documents
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:318]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:318]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Recent
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:318]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\SendTo
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:318]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Templates
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:318]: SHELL32::SHGetFolderPath returned: C:\ProgramData
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:318]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Local
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:318]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Pictures
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:318]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:318]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:318]: SHELL32::SHGetFolderPath returned: C:\Users\Public\Desktop
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:318]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:318]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:318]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Desktop
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:318]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Templates
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:318]: SHELL32::SHGetFolderPath returned: C:\Windows\Fonts
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:319]: Note: 1: 2898 2: MS Sans Serif 3: MS Sans Serif 4: 0 5: 16
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:321]: MSI_LUA: Setting AdminUser property to 1 because this is the client or the user has already permitted elevation
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:321]: MSI_LUA: Setting MsiRunningElevated property to 1 because the install is already running elevated.
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:321]: PROPERTY CHANGE: Adding MsiRunningElevated property. Its value is '1'.
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:321]: PROPERTY CHANGE: Adding Privileged property. Its value is '1'.
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:321]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\MS Setup (ACME)\User Info 3: 2
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:321]: PROPERTY CHANGE: Adding USERNAME property. Its value is 'A Valued IT Customer'.
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:321]: PROPERTY CHANGE: Adding COMPANYNAME property. Its value is 'Intel Corporation'.
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:321]: PROPERTY CHANGE: Adding DATABASE property. Its value is 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs2010-integration.msi'.
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:321]: PROPERTY CHANGE: Adding OriginalDatabase property. Its value is 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs2010-integration.msi'.
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:321]: Machine policy value 'MsiDisableEmbeddedUI' is 0
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:321]: EEUI - Disabling MsiEmbeddedUI in quiet mode
MSI(i) [13:55:06.347] | === Logging started: 4/8/2014  13:55:06 ===
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:321]: Note: 1: 2205 2:  3: PatchPackage
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:321]: Machine policy value 'DisableRollback' is 0
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:321]: User policy value 'DisableRollback' is 0
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:321]: PROPERTY CHANGE: Adding UILevel property. Its value is '2'.
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:322]: Creating MSIHANDLE (122) of type 790537 for thread 3996
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:322]: MsiOpenPackageEx is returning 0
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:322]: Creating MSIHANDLE (123) of type 790541 for thread 3996
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:322]: Closing MSIHANDLE (123) of type 790541 for thread 3996
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:322]: Doing action: AppSearch
MSI(i) [13:55:06.347] | Action 13:55:06: AppSearch. Searching for installed applications
MSI(i) [13:55:06.347] | Action start 13:55:06: AppSearch.
MSI(i) [13:55:06.347] | AppSearch: Property: VS2010DIR.F7B87292_18A1_47AE_B415_0A3834A439C4, Signature: SIG_VS2010_DIR.F7B87292_18A1_47AE_B415_0A3834A439C4
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:323]: Note: 1: 2262 2: Signature 3: -2147287038
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:323]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE32\SOFTWARE\Microsoft\VisualStudio\10.0\Setup\VS 3: 2
MSI(i) [13:55:06.347] | AppSearch: Property: VS2011DIR.F7B87292_18A1_47AE_B415_0A3834A439C4, Signature: SIG_VS2011_DIR.F7B87292_18A1_47AE_B415_0A3834A439C4
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:324]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE32\SOFTWARE\Microsoft\VisualStudio\11.0\Setup\VS 3: 2
MSI(i) [13:55:06.347] | AppSearch: Property: DEVENV_EXE_2008.589D170B_7826_4DA4_9294_78FB5D852D57, Signature: RL_DevenvExe_2008.589D170B_7826_4DA4_9294_78FB5D852D57
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:324]: Note: 1: 2262 2: Signature 3: -2147287038
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:324]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE32\SOFTWARE\Microsoft\VisualStudio\9.0\Setup\VS 3: 2
MSI(i) [13:55:06.347] | AppSearch: Property: DEVENV_EXE_2010.589D170B_7826_4DA4_9294_78FB5D852D57, Signature: RL_DevenvExe_2010.589D170B_7826_4DA4_9294_78FB5D852D57
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:324]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE32\SOFTWARE\Microsoft\VisualStudio\10.0\Setup\VS 3: 2
MSI(i) [13:55:06.347] | AppSearch: Property: DEVENV_EXE_2011.589D170B_7826_4DA4_9294_78FB5D852D57, Signature: RL_DevenvExe_2011.589D170B_7826_4DA4_9294_78FB5D852D57
MSI(i) [13:55:06.347] | Action ended 13:55:06: AppSearch. Return value 1.
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:324]: Doing action: CostInitialize
MSI(i) [13:55:06.347] | Action 13:55:06: CostInitialize. Computing space requirements
MSI(i) [13:55:06.347] | Action start 13:55:06: CostInitialize.
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:325]: Machine policy value 'MaxPatchCacheSize' is 10
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:325]: Baseline: Sorting baselines for {E16E559E-30A0-49BA-81F5-636CE693B4A1}.
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:325]: Baseline: New baseline 13.1.5000 from transaction.
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:325]: Baseline: Sorted order Native: Order 0.
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:325]: Baseline Data Table:
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:325]: ProductCode: {E16E559E-30A0-49BA-81F5-636CE693B4A1} Version: 13.1.5000 Attributes: 0 PatchId: Native BaselineId: -2147483648 Order: 0
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:325]: Baseline File Table:
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:326]: PROPERTY CHANGE: Adding ROOTDRIVE property. Its value is 'C:\'.
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:326]: PROPERTY CHANGE: Adding CostingComplete property. Its value is '0'.
MSI(i) [13:55:06.347] | Action ended 13:55:06: CostInitialize. Return value 1.
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:326]: Doing action: FileCost
MSI(i) [13:55:06.347] | Action 13:55:06: FileCost. Computing space requirements
MSI(i) [13:55:06.347] | Action start 13:55:06: FileCost.
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:327]: Note: 1: 2205 2:  3: MsiAssembly
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:327]: Note: 1: 2205 2:  3: Class
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:327]: Note: 1: 2205 2:  3: Extension
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:327]: Note: 1: 2205 2:  3: TypeLib
MSI(i) [13:55:06.347] | Action ended 13:55:06: FileCost. Return value 1.
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:327]: Doing action: CostFinalize
MSI(i) [13:55:06.347] | Action 13:55:06: CostFinalize. Computing space requirements
MSI(i) [13:55:06.347] | Action start 13:55:06: CostFinalize.
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:328]: PROPERTY CHANGE: Adding OutOfDiskSpace property. Its value is '0'.
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:328]: PROPERTY CHANGE: Adding OutOfNoRbDiskSpace property. Its value is '0'.
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:328]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceAvailable property. Its value is '0'.
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:328]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRequired property. Its value is '0'.
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:328]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRemaining property. Its value is '0'.
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:328]: Note: 1: 2205 2:  3: Patch
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:328]: Note: 1: 2205 2:  3: Condition
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:329]: PROPERTY CHANGE: Adding TARGETDIR property. Its value is 'C:\'.
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:329]: PROPERTY CHANGE: Adding VS11_REMOTE_DEBUGGER_X64_DIR property. Its value is 'C:\'.
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:329]: PROPERTY CHANGE: Adding VS11_DEBUGER_DIR property. Its value is 'C:\'.
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:329]: PROPERTY CHANGE: Adding INSTALLDIR property. Its value is 'C:\'.
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:329]: PROPERTY CHANGE: Adding CommonFilesFolder.589D170B_7826_4DA4_9294_78FB5D852D57 property. Its value is 'C:\'.
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:329]: PROPERTY CHANGE: Adding CmnIntel.589D170B_7826_4DA4_9294_78FB5D852D57 property. Its value is 'C:\Intel\'.
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:329]: PROPERTY CHANGE: Adding CmnIntelHEBundle.589D170B_7826_4DA4_9294_78FB5D852D57 property. Its value is 'C:\Intel\Parallel Studio XE 2013\'.
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:329]: PROPERTY CHANGE: Adding HEBundleMenuDir.589D170B_7826_4DA4_9294_78FB5D852D57 property. Its value is 'C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Intel Parallel Studio XE 2013\'.
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:329]: PROPERTY CHANGE: Adding CommonFilesFolder.95C3848C_D156_4249_942C_7A8A0976584F property. Its value is 'C:\'.
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:329]: PROPERTY CHANGE: Adding CmnIntel.95C3848C_D156_4249_942C_7A8A0976584F property. Its value is 'C:\Intel\'.
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:329]: PROPERTY CHANGE: Adding CmnIntelHEBundle.95C3848C_D156_4249_942C_7A8A0976584F property. Its value is 'C:\Intel\Parallel Studio XE 2013\'.
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:329]: PROPERTY CHANGE: Adding VS2010DIR.F7B87292_18A1_47AE_B415_0A3834A439C4 property. Its value is 'C:\Program Files (x86)\VS2010DIR\'.
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:329]: PROPERTY CHANGE: Adding Common7.F7B87292_18A1_47AE_B415_0A3834A439C4 property. Its value is 'C:\Program Files (x86)\VS2010DIR\Common7\'.
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:329]: PROPERTY CHANGE: Adding IDE.F7B87292_18A1_47AE_B415_0A3834A439C4 property. Its value is 'C:\Program Files (x86)\VS2010DIR\Common7\IDE\'.
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:329]: PROPERTY CHANGE: Adding Extensions.F7B87292_18A1_47AE_B415_0A3834A439C4 property. Its value is 'C:\Program Files (x86)\VS2010DIR\Common7\IDE\Extensions\'.
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:329]: PROPERTY CHANGE: Adding Intel_.F7B87292_18A1_47AE_B415_0A3834A439C4 property. Its value is 'C:\Program Files (x86)\VS2010DIR\Common7\IDE\Extensions\Intel\'.
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:329]: PROPERTY CHANGE: Adding Intel.SoftwareManager.F7B87292_18A1_47AE_B415_0A3834A439C4 property. Its value is 'C:\Program Files (x86)\VS2010DIR\Common7\IDE\Extensions\Intel\Intel.SoftwareManager\'.
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:329]: PROPERTY CHANGE: Adding ja0.F7B87292_18A1_47AE_B415_0A3834A439C4 property. Its value is 'C:\Program Files (x86)\VS2010DIR\Common7\IDE\Extensions\Intel\Intel.SoftwareManager\ja\'.
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:329]: Target path resolution complete. Dumping Directory table...
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:329]: Note: target paths subject to change (via custom actions or browsing)
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:329]: Dir (target): Key: TARGETDIR    , Object: C:\
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:329]: Dir (target): Key: WindowsFolder    , Object: C:\Windows\
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:329]: Dir (target): Key: VS11_REMOTE_DEBUGGER_X64_DIR    , Object: C:\
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:329]: Dir (target): Key: VS11_DEBUGER_DIR    , Object: C:\
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:329]: Dir (target): Key: CommonFilesFolder    , Object: C:\Program Files (x86)\Common Files\
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:329]: Dir (target): Key: INSTALLDIR    , Object: C:\
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:329]: Dir (target): Key: CommonFilesFolder.589D170B_7826_4DA4_9294_78FB5D852D57    , Object: C:\
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:329]: Dir (target): Key: CmnIntel.589D170B_7826_4DA4_9294_78FB5D852D57    , Object: C:\Intel\
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:329]: Dir (target): Key: CmnIntelHEBundle.589D170B_7826_4DA4_9294_78FB5D852D57    , Object: C:\Intel\Parallel Studio XE 2013\
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:329]: Dir (target): Key: ProgramMenuFolder    , Object: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:329]: Dir (target): Key: HEBundleMenuDir.589D170B_7826_4DA4_9294_78FB5D852D57    , Object: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Intel Parallel Studio XE 2013\
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:329]: Dir (target): Key: CommonFilesFolder.95C3848C_D156_4249_942C_7A8A0976584F    , Object: C:\
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:329]: Dir (target): Key: CmnIntel.95C3848C_D156_4249_942C_7A8A0976584F    , Object: C:\Intel\
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:329]: Dir (target): Key: CmnIntelHEBundle.95C3848C_D156_4249_942C_7A8A0976584F    , Object: C:\Intel\Parallel Studio XE 2013\
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:329]: Dir (target): Key: ProgramFilesFolder    , Object: C:\Program Files (x86)\
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:329]: Dir (target): Key: VS2010DIR.F7B87292_18A1_47AE_B415_0A3834A439C4    , Object: C:\Program Files (x86)\VS2010DIR\
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:329]: Dir (target): Key: Common7.F7B87292_18A1_47AE_B415_0A3834A439C4    , Object: C:\Program Files (x86)\VS2010DIR\Common7\
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:329]: Dir (target): Key: IDE.F7B87292_18A1_47AE_B415_0A3834A439C4    , Object: C:\Program Files (x86)\VS2010DIR\Common7\IDE\
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:329]: Dir (target): Key: Extensions.F7B87292_18A1_47AE_B415_0A3834A439C4    , Object: C:\Program Files (x86)\VS2010DIR\Common7\IDE\Extensions\
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:329]: Dir (target): Key: Intel_.F7B87292_18A1_47AE_B415_0A3834A439C4    , Object: C:\Program Files (x86)\VS2010DIR\Common7\IDE\Extensions\Intel\
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:329]: Dir (target): Key: Intel.SoftwareManager.F7B87292_18A1_47AE_B415_0A3834A439C4    , Object: C:\Program Files (x86)\VS2010DIR\Common7\IDE\Extensions\Intel\Intel.SoftwareManager\
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:329]: Dir (target): Key: ja0.F7B87292_18A1_47AE_B415_0A3834A439C4    , Object: C:\Program Files (x86)\VS2010DIR\Common7\IDE\Extensions\Intel\Intel.SoftwareManager\ja\
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:329]: PROPERTY CHANGE: Adding INSTALLLEVEL property. Its value is '1'.
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:329]: Note: 1: 2205 2:  3: MsiAssembly
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:329]: Note: 1: 2228 2:  3: MsiAssembly 4:  SELECT `MsiAssembly`.`Attributes`, `MsiAssembly`.`File_Application`, `MsiAssembly`.`File_Manifest`,  `Component`.`KeyPath` FROM `MsiAssembly`, `Component` WHERE  `MsiAssembly`.`Component_` = `Component`.`Component` AND `MsiAssembly`.`Component_` = ?
MSI(i) [13:55:06.347] | Action ended 13:55:06: CostFinalize. Return value 1.
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:330]: Doing action: InstallValidate
MSI(i) [13:55:06.347] | Action 13:55:06: InstallValidate. Validating install
MSI(i) [13:55:06.347] | Action start 13:55:06: InstallValidate.
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:331]: Note: 1: 2205 2:  3: Dialog
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:331]: Feature: core; Installed: Absent;   Request: Local;   Action: Local
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:331]: Component: ProductFamilyAnchor; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:331]: Component: ProductVersionAnchor; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:331]: Component: CommonIntegrationAnchor; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:331]: Component: VsIntegrationAnchor; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:331]: Component: reg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:331]: Component: Comp_Intel.SoftwareManager.dll0.F7B87292_18A1_47AE_B415_0A3834A439C4; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:331]: Component: Comp_Intel.SoftwareManager.pkgdef.F7B87292_18A1_47AE_B415_0A3834A439C4; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:331]: Component: Comp_Intel.SoftwareManager.resources.dll0.F7B87292_18A1_47AE_B415_0A3834A439C4; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:331]: Component: vs_run.exe.95C3848C_D156_4249_942C_7A8A0976584F; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:331]: Component: VS2010.589D170B_7826_4DA4_9294_78FB5D852D57; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:331]: Component: VS2010_win8.589D170B_7826_4DA4_9294_78FB5D852D57; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:331]: Component: __reg65; Installed: Null;   Request: Local;   Action: Local;   Client State: Null
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:331]: Component: __VS2010.589D170B_7826_4DA4_9294_78FB5D852D5765; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:331]: Component: __VS2010_win8.589D170B_7826_4DA4_9294_78FB5D852D5765; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:331]: Note: 1: 2205 2:  3: BindImage
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:331]: Note: 1: 2205 2:  3: ProgId
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:331]: Note: 1: 2205 2:  3: PublishComponent
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:331]: Note: 1: 2205 2:  3: SelfReg
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:331]: Note: 1: 2205 2:  3: Extension
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:331]: Note: 1: 2205 2:  3: Font
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:331]: Note: 1: 2205 2:  3: Class
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:331]: Note: 1: 2205 2:  3: TypeLib
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:331]: Note: 1: 2205 2:  3: _RemoveFilePath
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:331]: PROPERTY CHANGE: Modifying CostingComplete property. Its current value is '0'. Its new value: '1'.
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:332]: Note: 1: 2205 2:  3: BindImage
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:332]: Note: 1: 2205 2:  3: ProgId
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:332]: Note: 1: 2205 2:  3: PublishComponent
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:332]: Note: 1: 2205 2:  3: SelfReg
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:332]: Note: 1: 2205 2:  3: Extension
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:332]: Note: 1: 2205 2:  3: Font
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:332]: Note: 1: 2205 2:  3: Class
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:332]: Note: 1: 2205 2:  3: TypeLib
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:332]: Note: 1: 2727 2:
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:346]: Note: 1: 2727 2:
MSI(i) [13:55:06.347] | Action ended 13:55:06: InstallValidate. Return value 1.
MSI(i) [13:55:06.347] | MSI (c) (B0:9C) [13:55:06:346]: Closing MSIHANDLE (122) of type 790537 for thread 3996
MSI(i) [13:55:06.347] | === Verbose logging stopped: 4/8/2014  13:55:06 ===
PSET(i) [13:55:06.356] | (4225.285): MsiOpenPackageEx(C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs2010-integration.msi)
PSET(i) [13:55:06.414] | (6497.173): Feature=core PendingAction=-1, Action=3
MSI(i) [13:55:06.414] | === Verbose logging started: 4/8/2014  13:55:06  Build type: SHIP UNICODE 5.00.7601.00  Calling process: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\setup.exe ===
MSI(i) [13:55:06.414] | MSI (c) (B0:9C) [13:55:06:357]: SOFTWARE RESTRICTION POLICY: Verifying package --> 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs2010-integration.msi' against software restriction policy
MSI(i) [13:55:06.414] | MSI (c) (B0:9C) [13:55:06:357]: SOFTWARE RESTRICTION POLICY: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs2010-integration.msi has a digital signature
MSI(i) [13:55:06.414] | MSI (c) (B0:9C) [13:55:06:373]: SOFTWARE RESTRICTION POLICY: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs2010-integration.msi is permitted to run at the 'unrestricted' authorization level.
MSI(i) [13:55:06.414] | MSI (c) (B0:9C) [13:55:06:374]: Cloaking enabled.
MSI(i) [13:55:06.414] | MSI (c) (B0:9C) [13:55:06:374]: Attempting to enable all disabled privileges before calling Install on Server
MSI(i) [13:55:06.414] | MSI (c) (B0:9C) [13:55:06:374]: End dialog not enabled
MSI(i) [13:55:06.414] | MSI (c) (B0:9C) [13:55:06:375]: Original package ==> C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs2010-integration.msi
MSI(i) [13:55:06.414] | MSI (c) (B0:9C) [13:55:06:375]: Package we're running from ==> C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs2010-integration.msi
MSI(i) [13:55:06.414] | MSI (c) (B0:9C) [13:55:06:375]: Machine policy value 'DisableUserInstalls' is 0
MSI(i) [13:55:06.414] | MSI (c) (B0:9C) [13:55:06:376]: APPCOMPAT: Compatibility mode property overrides found.
MSI(i) [13:55:06.414] | MSI (c) (B0:9C) [13:55:06:376]: APPCOMPAT: looking for appcompat database entry with ProductCode '{E16E559E-30A0-49BA-81F5-636CE693B4A1}'.
MSI(i) [13:55:06.414] | MSI (c) (B0:9C) [13:55:06:376]: APPCOMPAT: no matching ProductCode found in database.
MSI(i) [13:55:06.414] | MSI (c) (B0:9C) [13:55:06:378]: MSCOREE not loaded loading copy from system32
MSI(i) [13:55:06.414] | MSI (c) (B0:9C) [13:55:06:381]: Machine policy value 'TransformsSecure' is 0
MSI(i) [13:55:06.414] | MSI (c) (B0:9C) [13:55:06:381]: User policy value 'TransformsAtSource' is 0
MSI(i) [13:55:06.414] | MSI (c) (B0:9C) [13:55:06:382]: Machine policy value 'DisablePatch' is 0
MSI(i) [13:55:06.414] | MSI (c) (B0:9C) [13:55:06:382]: Machine policy value 'AllowLockdownPatch' is 0
MSI(i) [13:55:06.414] | MSI (c) (B0:9C) [13:55:06:382]: Machine policy value 'DisableLUAPatching' is 0
MSI(i) [13:55:06.414] | MSI (c) (B0:9C) [13:55:06:382]: Machine policy value 'DisableFlyWeightPatching' is 0
MSI(i) [13:55:06.414] | MSI (c) (B0:9C) [13:55:06:382]: Enabling baseline caching for this transaction since all active patches are MSI 3.0 style MSPs or at least one MSI 3.0 minor update patch is active
MSI(i) [13:55:06.414] | MSI (c) (B0:9C) [13:55:06:382]: APPCOMPAT: looking for appcompat database entry with ProductCode '{E16E559E-30A0-49BA-81F5-636CE693B4A1}'.
MSI(i) [13:55:06.414] | MSI (c) (B0:9C) [13:55:06:382]: APPCOMPAT: no matching ProductCode found in database.
MSI(i) [13:55:06.414] | MSI (c) (B0:9C) [13:55:06:382]: Transforms are not secure.
MSI(i) [13:55:06.414] | MSI (c) (B0:9C) [13:55:06:382]: PROPERTY CHANGE: Adding MsiLogFileLocation property. Its value is 'C:\Users\PCCA-PM\AppData\Local\Temp\MSIED31.tmp'.
MSI(i) [13:55:06.414] | MSI (c) (B0:9C) [13:55:06:382]: No Command Line.
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:382]: PROPERTY CHANGE: Adding PackageCode property. Its value is '{4E6E5693-7562-4ABD-B30F-309AC4849EEF}'.
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:382]: Product Code passed to Engine.Initialize:           '(none)'
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:382]: Product Code from property table before transforms: '{E16E559E-30A0-49BA-81F5-636CE693B4A1}'
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:382]: Product Code from property table after transforms:  '{E16E559E-30A0-49BA-81F5-636CE693B4A1}'
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:382]: Product not registered: beginning first-time install
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:382]: PROPERTY CHANGE: Adding ProductState property. Its value is '-1'.
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:383]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer 3: 2
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:383]: Entering CMsiConfigurationManager::SetLastUsedSource.
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:383]: User policy value 'SearchOrder' is 'nmu'
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:383]: Adding new sources is allowed.
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:383]: PROPERTY CHANGE: Adding PackagecodeChanging property. Its value is '1'.
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:383]: Package name extracted from package path: 'vs2010-integration.msi'
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:383]: Package to be registered: 'vs2010-integration.msi'
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:383]: Note: 1: 2205 2:  3: Error
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:384]: Note: 1: 2262 2: AdminProperties 3: -2147287038
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:384]: Machine policy value 'DisableMsi' is 0
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:384]: Machine policy value 'AlwaysInstallElevated' is 0
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:384]: User policy value 'AlwaysInstallElevated' is 0
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:384]: Product installation will be elevated because user is admin and product is being installed per-machine.
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:384]: Running product '{E16E559E-30A0-49BA-81F5-636CE693B4A1}' with elevated privileges: Product is assigned.
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:384]: PROPERTY CHANGE: Adding MsiSystemRebootPending property. Its value is '1'.
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:384]: TRANSFORMS property is now:
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:384]: PROPERTY CHANGE: Adding VersionDatabase property. Its value is '200'.
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:384]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:384]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Favorites
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:384]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Network Shortcuts
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:384]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Documents
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:384]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:384]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Recent
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:384]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\SendTo
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:384]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Templates
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:384]: SHELL32::SHGetFolderPath returned: C:\ProgramData
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:384]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Local
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:384]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Pictures
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:384]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:384]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:384]: SHELL32::SHGetFolderPath returned: C:\Users\Public\Desktop
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:384]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:384]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:384]: SHELL32::SHGetFolderPath returned: C:\Users\PCCA-PM\Desktop
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:384]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Templates
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:385]: SHELL32::SHGetFolderPath returned: C:\Windows\Fonts
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:385]: Note: 1: 2898 2: MS Sans Serif 3: MS Sans Serif 4: 0 5: 16
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:387]: MSI_LUA: Setting AdminUser property to 1 because this is the client or the user has already permitted elevation
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:387]: MSI_LUA: Setting MsiRunningElevated property to 1 because the install is already running elevated.
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:387]: PROPERTY CHANGE: Adding MsiRunningElevated property. Its value is '1'.
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:387]: PROPERTY CHANGE: Adding Privileged property. Its value is '1'.
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:387]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\MS Setup (ACME)\User Info 3: 2
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:387]: PROPERTY CHANGE: Adding USERNAME property. Its value is 'A Valued IT Customer'.
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:387]: PROPERTY CHANGE: Adding COMPANYNAME property. Its value is 'Intel Corporation'.
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:387]: PROPERTY CHANGE: Adding DATABASE property. Its value is 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs2010-integration.msi'.
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:387]: PROPERTY CHANGE: Adding OriginalDatabase property. Its value is 'C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs2010-integration.msi'.
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:388]: Machine policy value 'MsiDisableEmbeddedUI' is 0
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:388]: EEUI - Disabling MsiEmbeddedUI in quiet mode
MSI(i) [13:55:06.415] | === Logging started: 4/8/2014  13:55:06 ===
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:388]: Note: 1: 2205 2:  3: PatchPackage
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:388]: Machine policy value 'DisableRollback' is 0
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:388]: User policy value 'DisableRollback' is 0
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:388]: PROPERTY CHANGE: Adding UILevel property. Its value is '2'.
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:388]: Creating MSIHANDLE (124) of type 790537 for thread 3996
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:388]: MsiOpenPackageEx is returning 0
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:388]: Creating MSIHANDLE (125) of type 790541 for thread 3996
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:388]: Closing MSIHANDLE (125) of type 790541 for thread 3996
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:388]: Doing action: AppSearch
MSI(i) [13:55:06.415] | Action 13:55:06: AppSearch. Searching for installed applications
MSI(i) [13:55:06.415] | Action start 13:55:06: AppSearch.
MSI(i) [13:55:06.415] | AppSearch: Property: VS2010DIR.F7B87292_18A1_47AE_B415_0A3834A439C4, Signature: SIG_VS2010_DIR.F7B87292_18A1_47AE_B415_0A3834A439C4
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:390]: Note: 1: 2262 2: Signature 3: -2147287038
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:390]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE32\SOFTWARE\Microsoft\VisualStudio\10.0\Setup\VS 3: 2
MSI(i) [13:55:06.415] | AppSearch: Property: VS2011DIR.F7B87292_18A1_47AE_B415_0A3834A439C4, Signature: SIG_VS2011_DIR.F7B87292_18A1_47AE_B415_0A3834A439C4
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:390]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE32\SOFTWARE\Microsoft\VisualStudio\11.0\Setup\VS 3: 2
MSI(i) [13:55:06.415] | AppSearch: Property: DEVENV_EXE_2008.589D170B_7826_4DA4_9294_78FB5D852D57, Signature: RL_DevenvExe_2008.589D170B_7826_4DA4_9294_78FB5D852D57
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:390]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE32\SOFTWARE\Microsoft\VisualStudio\9.0\Setup\VS 3: 2
MSI(i) [13:55:06.415] | AppSearch: Property: DEVENV_EXE_2010.589D170B_7826_4DA4_9294_78FB5D852D57, Signature: RL_DevenvExe_2010.589D170B_7826_4DA4_9294_78FB5D852D57
MSI(i) [13:55:06.415] | AppSearch: Property: DEVENV_EXE_2011.589D170B_7826_4DA4_9294_78FB5D852D57, Signature: RL_DevenvExe_2011.589D170B_7826_4DA4_9294_78FB5D852D57
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:391]: Note: 1: 2262 2: Signature 3: -2147287038
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:391]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE32\SOFTWARE\Microsoft\VisualStudio\11.0\Setup\VS 3: 2
MSI(i) [13:55:06.415] | Action ended 13:55:06: AppSearch. Return value 1.
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:391]: Doing action: CostInitialize
MSI(i) [13:55:06.415] | Action 13:55:06: CostInitialize. Computing space requirements
MSI(i) [13:55:06.415] | Action start 13:55:06: CostInitialize.
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:392]: Machine policy value 'MaxPatchCacheSize' is 10
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:392]: Baseline: Sorting baselines for {E16E559E-30A0-49BA-81F5-636CE693B4A1}.
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:392]: Baseline: New baseline 13.1.5000 from transaction.
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:392]: Baseline: Sorted order Native: Order 0.
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:392]: Baseline Data Table:
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:392]: ProductCode: {E16E559E-30A0-49BA-81F5-636CE693B4A1} Version: 13.1.5000 Attributes: 0 PatchId: Native BaselineId: -2147483648 Order: 0
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:392]: Baseline File Table:
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:393]: PROPERTY CHANGE: Adding ROOTDRIVE property. Its value is 'C:\'.
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:393]: PROPERTY CHANGE: Adding CostingComplete property. Its value is '0'.
MSI(i) [13:55:06.415] | Action ended 13:55:06: CostInitialize. Return value 1.
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:393]: Doing action: FileCost
MSI(i) [13:55:06.415] | Action 13:55:06: FileCost. Computing space requirements
MSI(i) [13:55:06.415] | Action start 13:55:06: FileCost.
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:394]: Note: 1: 2205 2:  3: MsiAssembly
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:394]: Note: 1: 2205 2:  3: Class
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:394]: Note: 1: 2205 2:  3: Extension
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:394]: Note: 1: 2205 2:  3: TypeLib
MSI(i) [13:55:06.415] | Action ended 13:55:06: FileCost. Return value 1.
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:394]: Doing action: CostFinalize
MSI(i) [13:55:06.415] | Action 13:55:06: CostFinalize. Computing space requirements
MSI(i) [13:55:06.415] | Action start 13:55:06: CostFinalize.
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:396]: PROPERTY CHANGE: Adding OutOfDiskSpace property. Its value is '0'.
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:396]: PROPERTY CHANGE: Adding OutOfNoRbDiskSpace property. Its value is '0'.
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:396]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceAvailable property. Its value is '0'.
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:396]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRequired property. Its value is '0'.
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:396]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRemaining property. Its value is '0'.
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:396]: Note: 1: 2205 2:  3: Patch
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:396]: Note: 1: 2205 2:  3: Condition
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:396]: PROPERTY CHANGE: Adding TARGETDIR property. Its value is 'C:\'.
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:396]: PROPERTY CHANGE: Adding VS11_REMOTE_DEBUGGER_X64_DIR property. Its value is 'C:\'.
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:396]: PROPERTY CHANGE: Adding VS11_DEBUGER_DIR property. Its value is 'C:\'.
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:396]: PROPERTY CHANGE: Adding INSTALLDIR property. Its value is 'C:\'.
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:396]: PROPERTY CHANGE: Adding CommonFilesFolder.589D170B_7826_4DA4_9294_78FB5D852D57 property. Its value is 'C:\'.
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:396]: PROPERTY CHANGE: Adding CmnIntel.589D170B_7826_4DA4_9294_78FB5D852D57 property. Its value is 'C:\Intel\'.
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:396]: PROPERTY CHANGE: Adding CmnIntelHEBundle.589D170B_7826_4DA4_9294_78FB5D852D57 property. Its value is 'C:\Intel\Parallel Studio XE 2013\'.
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:396]: PROPERTY CHANGE: Adding HEBundleMenuDir.589D170B_7826_4DA4_9294_78FB5D852D57 property. Its value is 'C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Intel Parallel Studio XE 2013\'.
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:396]: PROPERTY CHANGE: Adding CommonFilesFolder.95C3848C_D156_4249_942C_7A8A0976584F property. Its value is 'C:\'.
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:396]: PROPERTY CHANGE: Adding CmnIntel.95C3848C_D156_4249_942C_7A8A0976584F property. Its value is 'C:\Intel\'.
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:396]: PROPERTY CHANGE: Adding CmnIntelHEBundle.95C3848C_D156_4249_942C_7A8A0976584F property. Its value is 'C:\Intel\Parallel Studio XE 2013\'.
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:396]: PROPERTY CHANGE: Adding VS2010DIR.F7B87292_18A1_47AE_B415_0A3834A439C4 property. Its value is 'C:\Program Files (x86)\VS2010DIR\'.
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:396]: PROPERTY CHANGE: Adding Common7.F7B87292_18A1_47AE_B415_0A3834A439C4 property. Its value is 'C:\Program Files (x86)\VS2010DIR\Common7\'.
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:396]: PROPERTY CHANGE: Adding IDE.F7B87292_18A1_47AE_B415_0A3834A439C4 property. Its value is 'C:\Program Files (x86)\VS2010DIR\Common7\IDE\'.
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:396]: PROPERTY CHANGE: Adding Extensions.F7B87292_18A1_47AE_B415_0A3834A439C4 property. Its value is 'C:\Program Files (x86)\VS2010DIR\Common7\IDE\Extensions\'.
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:396]: PROPERTY CHANGE: Adding Intel_.F7B87292_18A1_47AE_B415_0A3834A439C4 property. Its value is 'C:\Program Files (x86)\VS2010DIR\Common7\IDE\Extensions\Intel\'.
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:396]: PROPERTY CHANGE: Adding Intel.SoftwareManager.F7B87292_18A1_47AE_B415_0A3834A439C4 property. Its value is 'C:\Program Files (x86)\VS2010DIR\Common7\IDE\Extensions\Intel\Intel.SoftwareManager\'.
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:396]: PROPERTY CHANGE: Adding ja0.F7B87292_18A1_47AE_B415_0A3834A439C4 property. Its value is 'C:\Program Files (x86)\VS2010DIR\Common7\IDE\Extensions\Intel\Intel.SoftwareManager\ja\'.
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:396]: Target path resolution complete. Dumping Directory table...
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:396]: Note: target paths subject to change (via custom actions or browsing)
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:396]: Dir (target): Key: TARGETDIR    , Object: C:\
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:396]: Dir (target): Key: WindowsFolder    , Object: C:\Windows\
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:396]: Dir (target): Key: VS11_REMOTE_DEBUGGER_X64_DIR    , Object: C:\
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:396]: Dir (target): Key: VS11_DEBUGER_DIR    , Object: C:\
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:396]: Dir (target): Key: CommonFilesFolder    , Object: C:\Program Files (x86)\Common Files\
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:396]: Dir (target): Key: INSTALLDIR    , Object: C:\
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:396]: Dir (target): Key: CommonFilesFolder.589D170B_7826_4DA4_9294_78FB5D852D57    , Object: C:\
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:396]: Dir (target): Key: CmnIntel.589D170B_7826_4DA4_9294_78FB5D852D57    , Object: C:\Intel\
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:396]: Dir (target): Key: CmnIntelHEBundle.589D170B_7826_4DA4_9294_78FB5D852D57    , Object: C:\Intel\Parallel Studio XE 2013\
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:396]: Dir (target): Key: ProgramMenuFolder    , Object: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:396]: Dir (target): Key: HEBundleMenuDir.589D170B_7826_4DA4_9294_78FB5D852D57    , Object: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Intel Parallel Studio XE 2013\
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:396]: Dir (target): Key: CommonFilesFolder.95C3848C_D156_4249_942C_7A8A0976584F    , Object: C:\
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:396]: Dir (target): Key: CmnIntel.95C3848C_D156_4249_942C_7A8A0976584F    , Object: C:\Intel\
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:396]: Dir (target): Key: CmnIntelHEBundle.95C3848C_D156_4249_942C_7A8A0976584F    , Object: C:\Intel\Parallel Studio XE 2013\
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:396]: Dir (target): Key: ProgramFilesFolder    , Object: C:\Program Files (x86)\
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:396]: Dir (target): Key: VS2010DIR.F7B87292_18A1_47AE_B415_0A3834A439C4    , Object: C:\Program Files (x86)\VS2010DIR\
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:396]: Dir (target): Key: Common7.F7B87292_18A1_47AE_B415_0A3834A439C4    , Object: C:\Program Files (x86)\VS2010DIR\Common7\
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:396]: Dir (target): Key: IDE.F7B87292_18A1_47AE_B415_0A3834A439C4    , Object: C:\Program Files (x86)\VS2010DIR\Common7\IDE\
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:396]: Dir (target): Key: Extensions.F7B87292_18A1_47AE_B415_0A3834A439C4    , Object: C:\Program Files (x86)\VS2010DIR\Common7\IDE\Extensions\
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:396]: Dir (target): Key: Intel_.F7B87292_18A1_47AE_B415_0A3834A439C4    , Object: C:\Program Files (x86)\VS2010DIR\Common7\IDE\Extensions\Intel\
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:396]: Dir (target): Key: Intel.SoftwareManager.F7B87292_18A1_47AE_B415_0A3834A439C4    , Object: C:\Program Files (x86)\VS2010DIR\Common7\IDE\Extensions\Intel\Intel.SoftwareManager\
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:396]: Dir (target): Key: ja0.F7B87292_18A1_47AE_B415_0A3834A439C4    , Object: C:\Program Files (x86)\VS2010DIR\Common7\IDE\Extensions\Intel\Intel.SoftwareManager\ja\
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:396]: PROPERTY CHANGE: Adding INSTALLLEVEL property. Its value is '1'.
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:396]: Note: 1: 2205 2:  3: MsiAssembly
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:396]: Note: 1: 2228 2:  3: MsiAssembly 4:  SELECT `MsiAssembly`.`Attributes`, `MsiAssembly`.`File_Application`, `MsiAssembly`.`File_Manifest`,  `Component`.`KeyPath` FROM `MsiAssembly`, `Component` WHERE  `MsiAssembly`.`Component_` = `Component`.`Component` AND `MsiAssembly`.`Component_` = ?
MSI(i) [13:55:06.415] | Action ended 13:55:06: CostFinalize. Return value 1.
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:397]: Doing action: InstallValidate
MSI(i) [13:55:06.415] | Action 13:55:06: InstallValidate. Validating install
MSI(i) [13:55:06.415] | Action start 13:55:06: InstallValidate.
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:398]: Note: 1: 2205 2:  3: Dialog
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:398]: Feature: core; Installed: Absent;   Request: Local;   Action: Local
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:398]: Component: ProductFamilyAnchor; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:398]: Component: ProductVersionAnchor; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:398]: Component: CommonIntegrationAnchor; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:398]: Component: VsIntegrationAnchor; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:398]: Component: reg; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:398]: Component: Comp_Intel.SoftwareManager.dll0.F7B87292_18A1_47AE_B415_0A3834A439C4; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:398]: Component: Comp_Intel.SoftwareManager.pkgdef.F7B87292_18A1_47AE_B415_0A3834A439C4; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:398]: Component: Comp_Intel.SoftwareManager.resources.dll0.F7B87292_18A1_47AE_B415_0A3834A439C4; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:398]: Component: vs_run.exe.95C3848C_D156_4249_942C_7A8A0976584F; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:398]: Component: VS2010.589D170B_7826_4DA4_9294_78FB5D852D57; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:398]: Component: VS2010_win8.589D170B_7826_4DA4_9294_78FB5D852D57; Installed: Absent;   Request: Local;   Action: Null;   Client State: Unknown
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:398]: Component: __reg65; Installed: Null;   Request: Local;   Action: Local;   Client State: Null
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:398]: Component: __VS2010.589D170B_7826_4DA4_9294_78FB5D852D5765; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:398]: Component: __VS2010_win8.589D170B_7826_4DA4_9294_78FB5D852D5765; Installed: Null;   Request: Local;   Action: Null;   Client State: Null
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:398]: Note: 1: 2205 2:  3: BindImage
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:398]: Note: 1: 2205 2:  3: ProgId
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:398]: Note: 1: 2205 2:  3: PublishComponent
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:398]: Note: 1: 2205 2:  3: SelfReg
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:398]: Note: 1: 2205 2:  3: Extension
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:398]: Note: 1: 2205 2:  3: Font
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:398]: Note: 1: 2205 2:  3: Class
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:398]: Note: 1: 2205 2:  3: TypeLib
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:399]: Note: 1: 2205 2:  3: _RemoveFilePath
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:399]: PROPERTY CHANGE: Modifying CostingComplete property. Its current value is '0'. Its new value: '1'.
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:399]: Note: 1: 2205 2:  3: BindImage
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:399]: Note: 1: 2205 2:  3: ProgId
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:399]: Note: 1: 2205 2:  3: PublishComponent
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:399]: Note: 1: 2205 2:  3: SelfReg
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:399]: Note: 1: 2205 2:  3: Extension
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:399]: Note: 1: 2205 2:  3: Font
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:399]: Note: 1: 2205 2:  3: Class
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:399]: Note: 1: 2205 2:  3: TypeLib
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:399]: Note: 1: 2727 2:
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:414]: Note: 1: 2727 2:
MSI(i) [13:55:06.415] | Action ended 13:55:06: InstallValidate. Return value 1.
MSI(i) [13:55:06.415] | MSI (c) (B0:9C) [13:55:06:414]: Closing MSIHANDLE (124) of type 790537 for thread 3996
MSI(i) [13:55:06.415] | === Verbose logging stopped: 4/8/2014  13:55:06 ===
PSET(i) [13:55:06.423] | (4225.1157): msi package: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\dim\distributed_install.msi
PSET(i) [13:55:06.423] | (4225.1158): LicIsValid: 1     InstallOnCurrentArch: 1     Installed State: 5     Pending Action: 3
PSET(i) [13:55:06.423] | (673.178): UpdateNeedforCheck {97BC3C88-834C-11DE-B575-22C956D89593}: Need
UNK(i) [13:55:06.423] |
Plugin psetlogger is initialized.
UNK(i) [13:55:06.423] | pset::abstract_context(context == pset::ContextInfo(eInstallMode == INSTALL_MODE_TYPICAL, iLog == ptr(0x1563f74), lLocaleID == size_t("1033"), sCurrentArchitecture == String("Intel64"), sLicenseFiles == String(""), sVSPackageNumber == String(""), sPathToLocaleFileFolder == String("C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\1033\"), sSerialNumber == String("")))
UNK(i) [13:55:06.423] | pset::abstract_context() return: deps::Context(mode == INSTALL, silent == bool(false), upfront == bool(false), full == bool(false), locale == int("0"))
UNK(i) [13:55:06.423] | Main(id == {ACD97E2A-090D-46ea-9983-6E44BCA28575}, severity == 0, message == ptr(0x16f068))
UNK(i) [13:55:06.423] | Main(): Check dependencies
UNK(i) [13:55:06.423] | Main(): exit with severity == DependencyCode(0), message == String("")
PSET(i) [13:55:06.423] | (673.118): Check Dependency for {ACD97E2A-090D-46ea-9983-6E44BCA28575}: 0
UNK(i) [13:55:06.424] | pset::abstract_context(context == pset::ContextInfo(eInstallMode == INSTALL_MODE_TYPICAL, iLog == ptr(0x1563f74), lLocaleID == size_t("1033"), sCurrentArchitecture == String("Intel64"), sLicenseFiles == String(""), sVSPackageNumber == String(""), sPathToLocaleFileFolder == String("C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\1033\"), sSerialNumber == String("")))
UNK(i) [13:55:06.424] | pset::abstract_context() return: deps::Context(mode == INSTALL, silent == bool(false), upfront == bool(false), full == bool(false), locale == int("0"))
UNK(i) [13:55:06.424] | Main(id == {D52A1D2E-8D7A-4822-9421-3A92C64DB956}, severity == 0, message == ptr(0x16f068))
UNK(i) [13:55:06.424] | Main(): Check if need to show VS Integration dialog
UNK(i) [13:55:06.424] | Main(): Enable dialog
UNK(i) [13:55:06.424] | Main(): exit with severity == MISSING_DEPENDENCY_NO_SUMMARY, message == String("")
PSET(i) [13:55:06.424] | (673.118): Check Dependency for {D52A1D2E-8D7A-4822-9421-3A92C64DB956}: 12032
UNK(i) [13:55:06.424] | Main(id == {E3BA8A13-2647-4c01-81D5-77E6D912D9D5}, severity == 0, message == ptr(0x16f068))
UNK(i) [13:55:06.424] | Main(): disable VS 11
UNK(i) [13:55:06.424] | Main(): exit with severity == MISSING_DEPENDENCY_COMPONENT_DISABLED, message == String("")
PSET(i) [13:55:06.424] | (673.118): Check Dependency for {E3BA8A13-2647-4c01-81D5-77E6D912D9D5}: 12021
UNK(i) [13:55:06.424] | Main(id == {F3CE10E5-7F75-4356-A379-05F5D6B04FB6}, severity == 0, message == ptr(0x16f068))
UNK(i) [13:55:06.424] | Main(): disable VS2008
PSET(i) [13:55:06.424] | (673.118): Check Dependency for {F3CE10E5-7F75-4356-A379-05F5D6B04FB6}: 12021
UNK(i) [13:55:06.424] | Main(id == {3AE471C7-8858-472a-8D7C-48B871B5EBDF}, severity == 0, message == ptr(0x16f068))
UNK(i) [13:55:06.424] | Main(): disable VS2010
PSET(i) [13:55:06.424] | (673.118): Check Dependency for {3AE471C7-8858-472a-8D7C-48B871B5EBDF}: 12021
UNK(i) [13:55:06.424] | Main(id == {8AA98789-C136-4adc-8269-86F3C222906F}, severity == 0, message == ptr(0x16f068))
UNK(i) [13:55:06.424] | Main(): exit with severity == DependencyCode(0), message == String("")
PSET(i) [13:55:06.424] | (673.118): Check Dependency for {8AA98789-C136-4adc-8269-86F3C222906F}: 0
PSET(i) [13:55:06.428] | (673.118): Check Dependency for {97BC3C88-834C-11DE-B575-22C956D89593}: 0
PSET(i) [13:55:06.428] | (4225.1157): msi package: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\msvcrt_x86.msi
PSET(i) [13:55:06.428] | (4225.1158): LicIsValid: 1     InstallOnCurrentArch: 1     Installed State: -1     Pending Action: 3
PSET(i) [13:55:06.428] | (673.178): UpdateNeedforCheck {ACD97E2A-090D-46ea-9983-6E44BCA28575}: Need
UNK(i) [13:55:06.428] |
UNK(i) [13:55:06.428] | pset::abstract_context(context == pset::ContextInfo(eInstallMode == INSTALL_MODE_TYPICAL, iLog == ptr(0x1563f74), lLocaleID == size_t("1033"), sCurrentArchitecture == String("Intel64"), sLicenseFiles == String(""), sVSPackageNumber == String(""), sPathToLocaleFileFolder == String("C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\1033\"), sSerialNumber == String("")))
UNK(i) [13:55:06.428] | pset::abstract_context() return: deps::Context(mode == INSTALL, silent == bool(false), upfront == bool(false), full == bool(false), locale == int("0"))
UNK(i) [13:55:06.428] | Main(id == {ACD97E2A-090D-46ea-9983-6E44BCA28575}, severity == 0, message == ptr(0x16f068))
UNK(i) [13:55:06.428] | Main(): Check dependencies
UNK(i) [13:55:06.428] | Main(): exit with severity == DependencyCode(0), message == String("")
PSET(i) [13:55:06.428] | (673.118): Check Dependency for {ACD97E2A-090D-46ea-9983-6E44BCA28575}: 0
UNK(i) [13:55:06.428] | Main(id == {D52A1D2E-8D7A-4822-9421-3A92C64DB956}, severity == 0, message == ptr(0x16f068))
UNK(i) [13:55:06.428] | Main(): Check if need to show VS Integration dialog
UNK(i) [13:55:06.428] | Main(): Enable dialog
UNK(i) [13:55:06.428] | Main(): exit with severity == MISSING_DEPENDENCY_NO_SUMMARY, message == String("")
PSET(i) [13:55:06.428] | (673.118): Check Dependency for {D52A1D2E-8D7A-4822-9421-3A92C64DB956}: 12032
UNK(i) [13:55:06.428] | Main(id == {E3BA8A13-2647-4c01-81D5-77E6D912D9D5}, severity == 0, message == ptr(0x16f068))
UNK(i) [13:55:06.429] | Main(): disable VS 11
UNK(i) [13:55:06.429] | Main(): exit with severity == MISSING_DEPENDENCY_COMPONENT_DISABLED, message == String("")
PSET(i) [13:55:06.429] | (673.118): Check Dependency for {E3BA8A13-2647-4c01-81D5-77E6D912D9D5}: 12021
UNK(i) [13:55:06.429] | pset::abstract_context(context == pset::ContextInfo(eInstallMode == INSTALL_MODE_TYPICAL, iLog == ptr(0x1563f74), lLocaleID == size_t("1033"), sCurrentArchitecture == String("Intel64"), sLicenseFiles == String(""), sVSPackageNumber == String(""), sPathToLocaleFileFolder == String("C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\1033\"), sSerialNumber == String("")))
UNK(i) [13:55:06.429] | pset::abstract_context() return: deps::Context(mode == INSTALL, silent == bool(false), upfront == bool(false), full == bool(false), locale == int("0"))
UNK(i) [13:55:06.429] | Main(id == {F3CE10E5-7F75-4356-A379-05F5D6B04FB6}, severity == 0, message == ptr(0x16f068))
UNK(i) [13:55:06.429] | Main(): disable VS2008
PSET(i) [13:55:06.429] | (673.118): Check Dependency for {F3CE10E5-7F75-4356-A379-05F5D6B04FB6}: 12021
UNK(i) [13:55:06.429] | Main(id == {3AE471C7-8858-472a-8D7C-48B871B5EBDF}, severity == 0, message == ptr(0x16f068))
UNK(i) [13:55:06.429] | Main(): disable VS2010
PSET(i) [13:55:06.429] | (673.118): Check Dependency for {3AE471C7-8858-472a-8D7C-48B871B5EBDF}: 12021
UNK(i) [13:55:06.429] | Main(id == {8AA98789-C136-4adc-8269-86F3C222906F}, severity == 0, message == ptr(0x16f068))
UNK(i) [13:55:06.429] | Main(): exit with severity == DependencyCode(0), message == String("")
PSET(i) [13:55:06.429] | (673.118): Check Dependency for {8AA98789-C136-4adc-8269-86F3C222906F}: 0
PSET(i) [13:55:06.430] | (673.118): Check Dependency for {97BC3C88-834C-11DE-B575-22C956D89593}: 0
PSET(i) [13:55:06.430] | (4225.1157): msi package: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\msvcrt_x64.msi
PSET(i) [13:55:06.430] | (4225.1158): LicIsValid: 1     InstallOnCurrentArch: 1     Installed State: -1     Pending Action: 3
PSET(i) [13:55:06.430] | (673.178): UpdateNeedforCheck {ACD97E2A-090D-46ea-9983-6E44BCA28575}: Need
UNK(i) [13:55:06.430] |
UNK(i) [13:55:06.430] | pset::abstract_context(context == pset::ContextInfo(eInstallMode == INSTALL_MODE_TYPICAL, iLog == ptr(0x1563f74), lLocaleID == size_t("1033"), sCurrentArchitecture == String("Intel64"), sLicenseFiles == String(""), sVSPackageNumber == String(""), sPathToLocaleFileFolder == String("C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\1033\"), sSerialNumber == String("")))
UNK(i) [13:55:06.430] | pset::abstract_context() return: deps::Context(mode == INSTALL, silent == bool(false), upfront == bool(false), full == bool(false), locale == int("0"))
UNK(i) [13:55:06.430] | Main(id == {ACD97E2A-090D-46ea-9983-6E44BCA28575}, severity == 0, message == ptr(0x16f068))
UNK(i) [13:55:06.430] | Main(): Check dependencies
UNK(i) [13:55:06.430] | Main(): exit with severity == DependencyCode(0), message == String("")
PSET(i) [13:55:06.430] | (673.118): Check Dependency for {ACD97E2A-090D-46ea-9983-6E44BCA28575}: 0
UNK(i) [13:55:06.430] | Main(id == {D52A1D2E-8D7A-4822-9421-3A92C64DB956}, severity == 0, message == ptr(0x16f068))
UNK(i) [13:55:06.430] | Main(): Check if need to show VS Integration dialog
UNK(i) [13:55:06.430] | Main(): Enable dialog
UNK(i) [13:55:06.430] | Main(): exit with severity == MISSING_DEPENDENCY_NO_SUMMARY, message == String("")
PSET(i) [13:55:06.430] | (673.118): Check Dependency for {D52A1D2E-8D7A-4822-9421-3A92C64DB956}: 12032
UNK(i) [13:55:06.430] | Main(id == {E3BA8A13-2647-4c01-81D5-77E6D912D9D5}, severity == 0, message == ptr(0x16f068))
UNK(i) [13:55:06.430] | Main(): disable VS 11
UNK(i) [13:55:06.430] | Main(): exit with severity == MISSING_DEPENDENCY_COMPONENT_DISABLED, message == String("")
PSET(i) [13:55:06.430] | (673.118): Check Dependency for {E3BA8A13-2647-4c01-81D5-77E6D912D9D5}: 12021
UNK(i) [13:55:06.430] | Main(id == {F3CE10E5-7F75-4356-A379-05F5D6B04FB6}, severity == 0, message == ptr(0x16f068))
UNK(i) [13:55:06.430] | Main(): disable VS2008
PSET(i) [13:55:06.430] | (673.118): Check Dependency for {F3CE10E5-7F75-4356-A379-05F5D6B04FB6}: 12021
UNK(i) [13:55:06.430] | Main(id == {3AE471C7-8858-472a-8D7C-48B871B5EBDF}, severity == 0, message == ptr(0x16f068))
UNK(i) [13:55:06.431] | Main(): disable VS2010
UNK(i) [13:55:06.431] | Main(): exit with severity == MISSING_DEPENDENCY_COMPONENT_DISABLED, message == String("")
PSET(i) [13:55:06.431] | (673.118): Check Dependency for {3AE471C7-8858-472a-8D7C-48B871B5EBDF}: 12021
UNK(i) [13:55:06.431] | pset::abstract_context(context == pset::ContextInfo(eInstallMode == INSTALL_MODE_TYPICAL, iLog == ptr(0x1563f74), lLocaleID == size_t("1033"), sCurrentArchitecture == String("Intel64"), sLicenseFiles == String(""), sVSPackageNumber == String(""), sPathToLocaleFileFolder == String("C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\1033\"), sSerialNumber == String("")))
UNK(i) [13:55:06.431] | pset::abstract_context() return: deps::Context(mode == INSTALL, silent == bool(false), upfront == bool(false), full == bool(false), locale == int("0"))
UNK(i) [13:55:06.431] | Main(id == {8AA98789-C136-4adc-8269-86F3C222906F}, severity == 0, message == ptr(0x16f068))
UNK(i) [13:55:06.431] | Main(): exit with severity == DependencyCode(0), message == String("")
PSET(i) [13:55:06.431] | (673.118): Check Dependency for {8AA98789-C136-4adc-8269-86F3C222906F}: 0
PSET(i) [13:55:06.431] | (673.118): Check Dependency for {97BC3C88-834C-11DE-B575-22C956D89593}: 0
PSET(i) [13:55:06.431] | (4225.1157): msi package: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\ism\ism.msi
PSET(i) [13:55:06.431] | (4225.1158): LicIsValid: 1     InstallOnCurrentArch: 1     Installed State: -1     Pending Action: 3
UNK(i) [13:55:06.431] | Main(id == {ACD97E2A-090D-46ea-9983-6E44BCA28575}, severity == 0, message == ptr(0x16f068))
UNK(i) [13:55:06.431] | Main(): Check dependencies
PSET(i) [13:55:06.431] | (673.118): Check Dependency for {ACD97E2A-090D-46ea-9983-6E44BCA28575}: 0
UNK(i) [13:55:06.431] | Main(id == {D52A1D2E-8D7A-4822-9421-3A92C64DB956}, severity == 0, message == ptr(0x16f068))
UNK(i) [13:55:06.431] | Main(): Check if need to show VS Integration dialog
UNK(i) [13:55:06.431] | Main(): Enable dialog
UNK(i) [13:55:06.431] | Main(): exit with severity == MISSING_DEPENDENCY_NO_SUMMARY, message == String("")
PSET(i) [13:55:06.431] | (673.118): Check Dependency for {D52A1D2E-8D7A-4822-9421-3A92C64DB956}: 12032
UNK(i) [13:55:06.432] | pset::abstract_context() return: deps::Context(mode == INSTALL, silent == bool(false), upfront == bool(false), full == bool(false), locale == int("0"))
UNK(i) [13:55:06.432] | Main(id == {E3BA8A13-2647-4c01-81D5-77E6D912D9D5}, severity == 0, message == ptr(0x16f068))
UNK(i) [13:55:06.432] | Main(): disable VS 11
UNK(i) [13:55:06.432] | Main(): exit with severity == MISSING_DEPENDENCY_COMPONENT_DISABLED, message == String("")
PSET(i) [13:55:06.432] | (673.118): Check Dependency for {E3BA8A13-2647-4c01-81D5-77E6D912D9D5}: 12021
UNK(i) [13:55:06.432] | pset::abstract_context(context == pset::ContextInfo(eInstallMode == INSTALL_MODE_TYPICAL, iLog == ptr(0x1563f74), lLocaleID == size_t("1033"), sCurrentArchitecture == String("Intel64"), sLicenseFiles == String(""), sVSPackageNumber == String(""), sPathToLocaleFileFolder == String("C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\1033\"), sSerialNumber == String("")))
UNK(i) [13:55:06.432] | Main(id == {F3CE10E5-7F75-4356-A379-05F5D6B04FB6}, severity == 0, message == ptr(0x16f068))
UNK(i) [13:55:06.432] | Main(): disable VS2008
PSET(i) [13:55:06.432] | (673.118): Check Dependency for {F3CE10E5-7F75-4356-A379-05F5D6B04FB6}: 12021
UNK(i) [13:55:06.432] | Main(id == {3AE471C7-8858-472a-8D7C-48B871B5EBDF}, severity == 0, message == ptr(0x16f068))
UNK(i) [13:55:06.432] | Main(): disable VS2010
PSET(i) [13:55:06.432] | (673.118): Check Dependency for {3AE471C7-8858-472a-8D7C-48B871B5EBDF}: 12021
UNK(i) [13:55:06.432] | Main(id == {8AA98789-C136-4adc-8269-86F3C222906F}, severity == 0, message == ptr(0x16f068))
UNK(i) [13:55:06.432] | Main(): exit with severity == DependencyCode(0), message == String("")
PSET(i) [13:55:06.432] | (673.118): Check Dependency for {8AA98789-C136-4adc-8269-86F3C222906F}: 0
PSET(i) [13:55:06.433] | (673.118): Check Dependency for {97BC3C88-834C-11DE-B575-22C956D89593}: 0
PSET(i) [13:55:06.433] | (4225.1157): msi package:
PSET(i) [13:55:06.433] | (4225.1158): LicIsValid: 1     InstallOnCurrentArch: 1     Installed State: -1     Pending Action: -7
UNK(i) [13:55:06.433] |
UNK(i) [13:55:06.433] | pset::abstract_context(context == pset::ContextInfo(eInstallMode == INSTALL_MODE_TYPICAL, iLog == ptr(0x1563f74), lLocaleID == size_t("1033"), sCurrentArchitecture == String("Intel64"), sLicenseFiles == String(""), sVSPackageNumber == String(""), sPathToLocaleFileFolder == String("C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\1033\"), sSerialNumber == String("")))
UNK(i) [13:55:06.433] | pset::abstract_context() return: deps::Context(mode == INSTALL, silent == bool(false), upfront == bool(false), full == bool(false), locale == int("0"))
UNK(i) [13:55:06.433] | Main(id == {ACD97E2A-090D-46ea-9983-6E44BCA28575}, severity == 0, message == ptr(0x16f068))
UNK(i) [13:55:06.433] | Main(): Check dependencies
UNK(i) [13:55:06.433] | Main(): exit with severity == DependencyCode(0), message == String("")
PSET(i) [13:55:06.433] | (673.118): Check Dependency for {ACD97E2A-090D-46ea-9983-6E44BCA28575}: 0
UNK(i) [13:55:06.433] | Main(id == {D52A1D2E-8D7A-4822-9421-3A92C64DB956}, severity == 0, message == ptr(0x16f068))
UNK(i) [13:55:06.433] | Main(): Check if need to show VS Integration dialog
UNK(i) [13:55:06.433] | Main(): Enable dialog
UNK(i) [13:55:06.433] | Main(): exit with severity == MISSING_DEPENDENCY_NO_SUMMARY, message == String("")
PSET(i) [13:55:06.433] | (673.118): Check Dependency for {D52A1D2E-8D7A-4822-9421-3A92C64DB956}: 12032
UNK(i) [13:55:06.433] | Main(id == {E3BA8A13-2647-4c01-81D5-77E6D912D9D5}, severity == 0, message == ptr(0x16f068))
UNK(i) [13:55:06.433] | Main(): disable VS 11
UNK(i) [13:55:06.433] | Main(): exit with severity == MISSING_DEPENDENCY_COMPONENT_DISABLED, message == String("")
PSET(i) [13:55:06.433] | (673.118): Check Dependency for {E3BA8A13-2647-4c01-81D5-77E6D912D9D5}: 12021
UNK(i) [13:55:06.433] | Main(id == {F3CE10E5-7F75-4356-A379-05F5D6B04FB6}, severity == 0, message == ptr(0x16f068))
UNK(i) [13:55:06.433] | Main(): disable VS2008
PSET(i) [13:55:06.433] | (673.118): Check Dependency for {F3CE10E5-7F75-4356-A379-05F5D6B04FB6}: 12021
UNK(i) [13:55:06.434] | pset::abstract_context() return: deps::Context(mode == INSTALL, silent == bool(false), upfront == bool(false), full == bool(false), locale == int("0"))
UNK(i) [13:55:06.434] | Main(id == {3AE471C7-8858-472a-8D7C-48B871B5EBDF}, severity == 0, message == ptr(0x16f068))
UNK(i) [13:55:06.434] | Main(): disable VS2010
UNK(i) [13:55:06.434] | Main(): exit with severity == MISSING_DEPENDENCY_COMPONENT_DISABLED, message == String("")
PSET(i) [13:55:06.434] | (673.118): Check Dependency for {3AE471C7-8858-472a-8D7C-48B871B5EBDF}: 12021
UNK(i) [13:55:06.434] | pset::abstract_context(context == pset::ContextInfo(eInstallMode == INSTALL_MODE_TYPICAL, iLog == ptr(0x1563f74), lLocaleID == size_t("1033"), sCurrentArchitecture == String("Intel64"), sLicenseFiles == String(""), sVSPackageNumber == String(""), sPathToLocaleFileFolder == String("C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\1033\"), sSerialNumber == String("")))
UNK(i) [13:55:06.434] | Main(id == {8AA98789-C136-4adc-8269-86F3C222906F}, severity == 0, message == ptr(0x16f068))
UNK(i) [13:55:06.434] | Main(): exit with severity == DependencyCode(0), message == String("")
PSET(i) [13:55:06.434] | (673.118): Check Dependency for {8AA98789-C136-4adc-8269-86F3C222906F}: 0
PSET(i) [13:55:06.434] | (673.118): Check Dependency for {97BC3C88-834C-11DE-B575-22C956D89593}: 0
UNK(i) [13:55:06.437] |
UNK(i) [13:55:06.437] | pset::abstract_context(context == pset::ContextInfo(eInstallMode == INSTALL_MODE_NONE, iLog == ptr(0x1563f74), lLocaleID == size_t("1033"), sCurrentArchitecture == String("Intel64"), sLicenseFiles == String(""), sVSPackageNumber == String(""), sPathToLocaleFileFolder == String("C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\1033\"), sSerialNumber == String("")))
UNK(i) [13:55:06.437] | pset::abstract_context() return: deps::Context(mode == INSTALL, silent == bool(false), upfront == bool(true), full == bool(false), locale == int("0"))
UNK(i) [13:55:06.437] | Main(id == {ACD97E2A-090D-46ea-9983-6E44BCA28575}, severity == 0, message == ptr(0x16eed0))
UNK(i) [13:55:06.437] | Main(): Check dependencies
UNK(i) [13:55:06.438] | Check::execute(...)
UNK(i) [13:55:06.438] |     Checking compatibility...
UNK(i) [13:55:06.438] |     call platform::check_cpu()
UNK(i) [13:55:06.438] | platform::check_cpu()
UNK(i) [13:55:06.438] |     call get_cpu_arch()
UNK(i) [13:55:06.438] |     arch == INTEL64
UNK(i) [13:55:06.438] |     check for SSE2
UNK(i) [13:55:06.438] |     CPU is Genuine Intel.
UNK(i) [13:55:06.438] |     return TESTED_CPU.
UNK(i) [13:55:06.438] |   result == TESTED_CPU
UNK(i) [13:55:06.438] |     nothing to report
UNK(i) [13:55:06.438] |     call platform::check_os()
UNK(i) [13:55:06.438] | platform::check_os()
UNK(i) [13:55:06.438] |     ver = get_os_ver()
UNK(i) [13:55:06.438] |     ver == 6.1.1.0
UNK(i) [13:55:06.438] |     OS supported. Check if it is tested.
UNK(i) [13:55:06.438] |     OS is tested => return TESTED.
UNK(i) [13:55:06.438] |     result == TESTED_OS
UNK(i) [13:55:06.438] |     call platform::check_user()
UNK(i) [13:55:06.438] | platfrom::check_user()
UNK(i) [13:55:06.438] |     res = has_admin_rights()
UNK(i) [13:55:06.438] |     res == true
UNK(i) [13:55:06.438] |     return true
UNK(i) [13:55:06.438] |     result == true
UNK(i) [13:55:06.438] |     Non of dependencies failed => exit
UNK(i) [13:55:06.438] | Executing CheckAppStopped
UNK(i) [13:55:06.438] |     products by version anchor == String("{F885F6E6-0B5D-4925-877F-6A08BD25CEDE}")
UNK(i) [13:55:06.438] |     products by core anchor == String("")
UNK(i) [13:55:06.438] |     intersection == String("")
UNK(i) [13:55:06.438] | Main(): exit with severity == DependencyCode(0), message == String("")
PSET(i) [13:55:06.438] | (673.118): Check Dependency for {ACD97E2A-090D-46ea-9983-6E44BCA28575}: 0
UNK(i) [13:55:06.438] | pset::abstract_context(context == pset::ContextInfo(eInstallMode == INSTALL_MODE_NONE, iLog == ptr(0x1563f74), lLocaleID == size_t("1033"), sCurrentArchitecture == String("Intel64"), sLicenseFiles == String(""), sVSPackageNumber == String(""), sPathToLocaleFileFolder == String("C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\1033\"), sSerialNumber == String("")))
UNK(i) [13:55:06.438] | pset::abstract_context() return: deps::Context(mode == INSTALL, silent == bool(false), upfront == bool(true), full == bool(false), locale == int("0"))
UNK(i) [13:55:06.438] | Main(id == {D52A1D2E-8D7A-4822-9421-3A92C64DB956}, severity == 0, message == ptr(0x16eed0))
UNK(i) [13:55:06.438] | Main(): Check if need to show VS Integration dialog
UNK(i) [13:55:06.438] | Main(): Enable dialog
UNK(i) [13:55:06.438] | Main(): exit with severity == MISSING_DEPENDENCY_NO_SUMMARY, message == String("")
PSET(i) [13:55:06.439] | (673.118): Check Dependency for {D52A1D2E-8D7A-4822-9421-3A92C64DB956}: 12032
UNK(i) [13:55:06.439] |
UNK(i) [13:55:06.439] | pset::abstract_context(context == pset::ContextInfo(eInstallMode == INSTALL_MODE_NONE, iLog == ptr(0x1563f74), lLocaleID == size_t("1033"), sCurrentArchitecture == String("Intel64"), sLicenseFiles == String(""), sVSPackageNumber == String(""), sPathToLocaleFileFolder == String("C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\1033\"), sSerialNumber == String("")))
UNK(i) [13:55:06.439] | pset::abstract_context() return: deps::Context(mode == INSTALL, silent == bool(false), upfront == bool(true), full == bool(false), locale == int("0"))
UNK(i) [13:55:06.439] | Main(id == {E3BA8A13-2647-4c01-81D5-77E6D912D9D5}, severity == 0, message == ptr(0x16eed0))
UNK(i) [13:55:06.439] | Main(): disable VS 11
UNK(i) [13:55:06.439] | Main(): exit with severity == MISSING_DEPENDENCY_COMPONENT_DISABLED, message == String("")
PSET(i) [13:55:06.439] | (673.118): Check Dependency for {E3BA8A13-2647-4c01-81D5-77E6D912D9D5}: 12021
UNK(i) [13:55:06.439] | Main(id == {F3CE10E5-7F75-4356-A379-05F5D6B04FB6}, severity == 0, message == ptr(0x16eed0))
UNK(i) [13:55:06.439] | Main(): disable VS2008
PSET(i) [13:55:06.439] | (673.118): Check Dependency for {F3CE10E5-7F75-4356-A379-05F5D6B04FB6}: 12021
UNK(i) [13:55:06.439] | Main(id == {3AE471C7-8858-472a-8D7C-48B871B5EBDF}, severity == 0, message == ptr(0x16eed0))
UNK(i) [13:55:06.439] | Main(): disable VS2010
PSET(i) [13:55:06.439] | (673.118): Check Dependency for {3AE471C7-8858-472a-8D7C-48B871B5EBDF}: 12021
UNK(i) [13:55:06.439] | Main(id == {8AA98789-C136-4adc-8269-86F3C222906F}, severity == 0, message == ptr(0x16eed0))
UNK(i) [13:55:06.439] | Main(): exit with severity == DependencyCode(0), message == String("")
PSET(i) [13:55:06.439] | (673.118): Check Dependency for {8AA98789-C136-4adc-8269-86F3C222906F}: 0
PSET(i) [13:55:06.440] | (673.118): Check Dependency for {97BC3C88-834C-11DE-B575-22C956D89593}: 0
UNK(i) [13:55:06.441] |
UNK(i) [13:55:06.441] | pset::abstract_context(context == pset::ContextInfo(eInstallMode == INSTALL_MODE_NONE, iLog == ptr(0x1563f74), lLocaleID == size_t("1033"), sCurrentArchitecture == String("Intel64"), sLicenseFiles == String(""), sVSPackageNumber == String(""), sPathToLocaleFileFolder == String("C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\1033\"), sSerialNumber == String("")))
UNK(i) [13:55:06.441] | pset::abstract_context() return: deps::Context(mode == INSTALL, silent == bool(false), upfront == bool(true), full == bool(false), locale == int("0"))
UNK(i) [13:55:06.442] | Main(id == {ACD97E2A-090D-46ea-9983-6E44BCA28575}, severity == 0, message == ptr(0x16f5c8))
UNK(i) [13:55:06.442] | Main(): Check dependencies
UNK(i) [13:55:06.442] | Check::execute(...)
UNK(i) [13:55:06.442] |     Checking compatibility...
UNK(i) [13:55:06.442] |     call platform::check_cpu()
UNK(i) [13:55:06.442] | platform::check_cpu()
UNK(i) [13:55:06.442] |     call get_cpu_arch()
UNK(i) [13:55:06.442] |     arch == INTEL64
UNK(i) [13:55:06.442] |     check for SSE2
UNK(i) [13:55:06.442] |     CPU is Genuine Intel.
UNK(i) [13:55:06.442] |     return TESTED_CPU.
UNK(i) [13:55:06.442] |   result == TESTED_CPU
UNK(i) [13:55:06.442] |     nothing to report
UNK(i) [13:55:06.442] |     call platform::check_os()
UNK(i) [13:55:06.442] | platform::check_os()
UNK(i) [13:55:06.442] |     ver = get_os_ver()
UNK(i) [13:55:06.442] |     ver == 6.1.1.0
UNK(i) [13:55:06.442] |     OS supported. Check if it is tested.
UNK(i) [13:55:06.442] |     OS is tested => return TESTED.
UNK(i) [13:55:06.442] |     result == TESTED_OS
UNK(i) [13:55:06.442] |     call platform::check_user()
UNK(i) [13:55:06.442] | platfrom::check_user()
UNK(i) [13:55:06.442] |     res = has_admin_rights()
UNK(i) [13:55:06.442] |     res == true
UNK(i) [13:55:06.442] |     return true
UNK(i) [13:55:06.442] |     result == true
UNK(i) [13:55:06.442] |     Non of dependencies failed => exit
UNK(i) [13:55:06.442] | Executing CheckAppStopped
UNK(i) [13:55:06.442] |     products by version anchor == String("{F885F6E6-0B5D-4925-877F-6A08BD25CEDE}")
UNK(i) [13:55:06.442] |     products by core anchor == String("")
UNK(i) [13:55:06.442] |     intersection == String("")
UNK(i) [13:55:06.442] | Main(): exit with severity == DependencyCode(0), message == String("")
PSET(i) [13:55:06.442] | (673.118): Check Dependency for {ACD97E2A-090D-46ea-9983-6E44BCA28575}: 0
UNK(i) [13:55:06.442] | pset::abstract_context(context == pset::ContextInfo(eInstallMode == INSTALL_MODE_NONE, iLog == ptr(0x1563f74), lLocaleID == size_t("1033"), sCurrentArchitecture == String("Intel64"), sLicenseFiles == String(""), sVSPackageNumber == String(""), sPathToLocaleFileFolder == String("C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\1033\"), sSerialNumber == String("")))
UNK(i) [13:55:06.442] | pset::abstract_context() return: deps::Context(mode == INSTALL, silent == bool(false), upfront == bool(true), full == bool(false), locale == int("0"))
UNK(i) [13:55:06.443] | Main(id == {D52A1D2E-8D7A-4822-9421-3A92C64DB956}, severity == 0, message == ptr(0x16f5c8))
UNK(i) [13:55:06.443] | Main(): Check if need to show VS Integration dialog
UNK(i) [13:55:06.443] | Main(): Enable dialog
UNK(i) [13:55:06.443] | Main(): exit with severity == MISSING_DEPENDENCY_NO_SUMMARY, message == String("")
PSET(i) [13:55:06.443] | (673.118): Check Dependency for {D52A1D2E-8D7A-4822-9421-3A92C64DB956}: 12032
UNK(i) [13:55:06.443] | pset::abstract_context(context == pset::ContextInfo(eInstallMode == INSTALL_MODE_NONE, iLog == ptr(0x1563f74), lLocaleID == size_t("1033"), sCurrentArchitecture == String("Intel64"), sLicenseFiles == String(""), sVSPackageNumber == String(""), sPathToLocaleFileFolder == String("C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\1033\"), sSerialNumber == String("")))
UNK(i) [13:55:06.443] | pset::abstract_context() return: deps::Context(mode == INSTALL, silent == bool(false), upfront == bool(true), full == bool(false), locale == int("0"))
UNK(i) [13:55:06.443] | Main(id == {E3BA8A13-2647-4c01-81D5-77E6D912D9D5}, severity == 0, message == ptr(0x16f5c8))
UNK(i) [13:55:06.443] | Main(): disable VS 11
UNK(i) [13:55:06.443] | Main(): exit with severity == MISSING_DEPENDENCY_COMPONENT_DISABLED, message == String("")
PSET(i) [13:55:06.443] | (673.118): Check Dependency for {E3BA8A13-2647-4c01-81D5-77E6D912D9D5}: 12021
UNK(i) [13:55:06.443] | Main(id == {F3CE10E5-7F75-4356-A379-05F5D6B04FB6}, severity == 0, message == ptr(0x16f5c8))
UNK(i) [13:55:06.443] | Main(): disable VS2008
PSET(i) [13:55:06.443] | (673.118): Check Dependency for {F3CE10E5-7F75-4356-A379-05F5D6B04FB6}: 12021
UNK(i) [13:55:06.443] | Main(id == {3AE471C7-8858-472a-8D7C-48B871B5EBDF}, severity == 0, message == ptr(0x16f5c8))
UNK(i) [13:55:06.443] | Main(): disable VS2010
PSET(i) [13:55:06.443] | (673.118): Check Dependency for {3AE471C7-8858-472a-8D7C-48B871B5EBDF}: 12021
UNK(i) [13:55:06.443] | Main(id == {8AA98789-C136-4adc-8269-86F3C222906F}, severity == 0, message == ptr(0x16f5c8))
UNK(i) [13:55:06.443] | Main(): exit with severity == DependencyCode(0), message == String("")
PSET(i) [13:55:06.443] | (673.118): Check Dependency for {8AA98789-C136-4adc-8269-86F3C222906F}: 0
PSET(i) [13:55:06.444] | (673.118): Check Dependency for {97BC3C88-834C-11DE-B575-22C956D89593}: 0
ISSA(e) [13:55:13.281] | (9697.228): issa::Parser::error: factor: syntax error
ISSA(i) [13:55:13.281] | (5729.297): LicenseHandler::validateSerialNumber():TBL5-MRKCWVF4:TBL5-MRKCWVF4
ISSA(i) [13:55:13.286] | (5265.1045): RegCenterAdapter: hmac_hash(): calculated
ISSA(i) [13:55:14.636] | (5729.1547): LicenseHandler::installLicenseFromRegCenter() - 758:10240
ISSA(i) [13:55:14.636] | (5729.1690): LicenseHandler::getLicenseFileDir() - CommonFilesDir C:\Program Files (x86)\Common Files
ISSA(i) [13:55:14.637] | (5729.1719): LicenseHandler::getLicenseFileDir() - C:\Program Files (x86)\Common Files\Intel\Licenses
ISSA(i) [13:55:14.645] | (5729.1690): LicenseHandler::getLicenseFileDir() - CommonFilesDir C:\Program Files (x86)\Common Files
ISSA(i) [13:55:14.646] | (5729.1719): LicenseHandler::getLicenseFileDir() - C:\Program Files (x86)\Common Files\Intel\Licenses
ISSA(i) [13:55:14.648] | (5729.297): LicenseHandler::validateSerialNumber()::
ISSA(e) [13:55:14.648] | (5729.300): LicenseHandler::validateSerialNumber: serial number  is of a wrong length! Expected 13 characters!
ISSA(i) [13:55:14.648] | (5729.1690): LicenseHandler::getLicenseFileDir() - CommonFilesDir C:\Program Files (x86)\Common Files
ISSA(i) [13:55:14.648] | (5729.1719): LicenseHandler::getLicenseFileDir() - C:\Program Files (x86)\Common Files\Intel\Licenses
ISSA(i) [13:55:14.649] | (5729.2565): LicenseHandler::GetChkLicCode()C:\Program Files (x86)\Common Files\Intel\Licenses\w_MRKCWVF4.lic
ISSA(i) [13:55:14.649] | (5729.2596): LicenseHandler::GetChkLicCode() - File size : 758
ISSA(i) [13:55:14.649] | (5729.2606): LicenseHandler::GetChkLicCode() - Bytes read : 758
ISSA(i) [13:55:14.649] | (5729.2721): LicenseHandler::GetChkLicCode(): 10
ISSA(i) [13:55:14.649] | (5729.2721): LicenseHandler::GetChkLicCode(): 0
PSET(i) [13:55:24.351] | (4225.285): MsiOpenPackageEx(C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\Setup\setup.msi)
PSET(i) [13:55:24.471] | (6497.173): Feature=CoreAppFiles PendingAction=3, Action=3
PSET(i) [13:55:24.471] | (6497.176): Call MsiSetFeatureState(CoreAppFiles)
PSET(i) [13:55:24.476] | (4225.285): MsiOpenPackageEx(C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\indicator\indicator.msi)
PSET(i) [13:55:24.528] | (6497.173): Feature=CoreAppFiles PendingAction=3, Action=3
PSET(i) [13:55:24.528] | (6497.176): Call MsiSetFeatureState(CoreAppFiles)
PSET(i) [13:55:24.530] | (4225.285): MsiOpenPackageEx(C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\ps_he_cli\ps_he_cli.msi)
PSET(i) [13:55:24.711] | (6497.173): Feature=CoreAppFiles64 PendingAction=3, Action=3
PSET(i) [13:55:24.711] | (6497.176): Call MsiSetFeatureState(CoreAppFiles64)
PSET(i) [13:55:24.714] | (6497.173): Feature=SEPFeature PendingAction=3, Action=3
PSET(i) [13:55:24.714] | (6497.176): Call MsiSetFeatureState(SEPFeature)
PSET(i) [13:55:24.715] | (6497.173): Feature=CoreAppFiles PendingAction=3, Action=3
PSET(i) [13:55:24.715] | (6497.176): Call MsiSetFeatureState(CoreAppFiles)
PSET(i) [13:55:24.752] | (4225.285): MsiOpenPackageEx(C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\ps_he_gui\ps_he_gui.msi)
PSET(i) [13:55:24.849] | (6497.173): Feature=CoreAppFiles64 PendingAction=3, Action=3
PSET(i) [13:55:24.849] | (6497.176): Call MsiSetFeatureState(CoreAppFiles64)
PSET(i) [13:55:24.850] | (6497.173): Feature=CoreAppFiles PendingAction=3, Action=3
PSET(i) [13:55:24.850] | (6497.176): Call MsiSetFeatureState(CoreAppFiles)
PSET(i) [13:55:24.855] | (4225.285): MsiOpenPackageEx(C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\sep\sep.msi)
PSET(i) [13:55:24.909] | (6497.173): Feature=CoreAppFiles PendingAction=3, Action=3
PSET(i) [13:55:24.909] | (6497.176): Call MsiSetFeatureState(CoreAppFiles)
PSET(i) [13:55:24.911] | (4225.285): MsiOpenPackageEx(C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\dim\distributed_install.msi)
PSET(i) [13:55:24.983] | (6497.173): Feature=FlexLMCheck PendingAction=3, Action=3
PSET(i) [13:55:24.983] | (6497.176): Call MsiSetFeatureState(FlexLMCheck)
PSET(i) [13:55:24.985] | (4225.285): MsiOpenPackageEx(C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\msvcrt_x86.msi)
PSET(i) [13:55:25.055] | (6497.173): Feature=Core PendingAction=3, Action=3
PSET(i) [13:55:25.055] | (6497.176): Call MsiSetFeatureState(Core)
PSET(i) [13:55:25.055] | (6497.173): Feature=MS_Runtime_8_0 PendingAction=3, Action=3
PSET(i) [13:55:25.055] | (6497.176): Call MsiSetFeatureState(MS_Runtime_8_0)
PSET(i) [13:55:25.056] | (6497.173): Feature=MS_Runtime_9_0 PendingAction=3, Action=3
PSET(i) [13:55:25.056] | (6497.176): Call MsiSetFeatureState(MS_Runtime_9_0)
PSET(i) [13:55:25.057] | (6497.173): Feature=MS_Runtime_10_0 PendingAction=3, Action=3
PSET(i) [13:55:25.057] | (6497.176): Call MsiSetFeatureState(MS_Runtime_10_0)
PSET(i) [13:55:25.060] | (4225.285): MsiOpenPackageEx(C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\msvcrt_x64.msi)
PSET(i) [13:55:25.130] | (6497.173): Feature=Core PendingAction=3, Action=3
PSET(i) [13:55:25.130] | (6497.176): Call MsiSetFeatureState(Core)
PSET(i) [13:55:25.130] | (6497.173): Feature=MS_Runtime_8_0 PendingAction=3, Action=3
PSET(i) [13:55:25.130] | (6497.176): Call MsiSetFeatureState(MS_Runtime_8_0)
PSET(i) [13:55:25.131] | (6497.173): Feature=MS_Runtime_9_0 PendingAction=3, Action=3
PSET(i) [13:55:25.131] | (6497.176): Call MsiSetFeatureState(MS_Runtime_9_0)
PSET(i) [13:55:25.132] | (6497.173): Feature=MS_Runtime_10_0 PendingAction=3, Action=3
PSET(i) [13:55:25.132] | (6497.176): Call MsiSetFeatureState(MS_Runtime_10_0)
PSET(i) [13:55:25.135] | (4225.285): MsiOpenPackageEx(C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\ism\ism.msi)
PSET(i) [13:55:25.231] | (6497.173): Feature=ISM PendingAction=3, Action=3
PSET(i) [13:55:25.231] | (6497.176): Call MsiSetFeatureState(ISM)
PSET(i) [13:55:25.235] | (673.167): ResetNeedforCheckFlags
PSET(i) [13:55:25.235] | (4225.1157): msi package: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\Setup\setup.msi
PSET(i) [13:55:25.235] | (4225.1158): LicIsValid: 1     InstallOnCurrentArch: 1     Installed State: -1     Pending Action: 3
PSET(i) [13:55:25.235] | (673.178): UpdateNeedforCheck {ACD97E2A-090D-46ea-9983-6E44BCA28575}: Need
UNK(i) [13:55:25.235] |
UNK(i) [13:55:25.235] | pset::abstract_context(context == pset::ContextInfo(eInstallMode == INSTALL_MODE_COMPLETE, iLog == ptr(0x1563f74), lLocaleID == size_t("1033"), sCurrentArchitecture == String("Intel64"), sLicenseFiles == String(""), sVSPackageNumber == String(""), sPathToLocaleFileFolder == String("C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\1033\"), sSerialNumber == String("")))
UNK(i) [13:55:25.235] | pset::abstract_context() return: deps::Context(mode == INSTALL, silent == bool(false), upfront == bool(false), full == bool(true), locale == int("0"))
UNK(i) [13:55:25.235] | Main(id == {ACD97E2A-090D-46ea-9983-6E44BCA28575}, severity == 0, message == ptr(0x16ec0c))
UNK(i) [13:55:25.235] | Main(): Check dependencies
UNK(i) [13:55:25.235] | Main(): exit with severity == DependencyCode(0), message == String("")
PSET(i) [13:55:25.235] | (673.118): Check Dependency for {ACD97E2A-090D-46ea-9983-6E44BCA28575}: 0
UNK(i) [13:55:25.235] | Main(id == {D52A1D2E-8D7A-4822-9421-3A92C64DB956}, severity == 0, message == ptr(0x16ec0c))
UNK(i) [13:55:25.235] | Main(): Check if need to show VS Integration dialog
PSET(i) [13:55:25.235] | (673.118): Check Dependency for {D52A1D2E-8D7A-4822-9421-3A92C64DB956}: 0
UNK(i) [13:55:25.235] | Main(id == {E3BA8A13-2647-4c01-81D5-77E6D912D9D5}, severity == 0, message == ptr(0x16ec0c))
UNK(i) [13:55:25.235] | Main(): disable VS 11
UNK(i) [13:55:25.235] | Main(): exit with severity == MISSING_DEPENDENCY_COMPONENT_DISABLED, message == String("")
PSET(i) [13:55:25.235] | (673.118): Check Dependency for {E3BA8A13-2647-4c01-81D5-77E6D912D9D5}: 12021
UNK(i) [13:55:25.235] | Main(id == {F3CE10E5-7F75-4356-A379-05F5D6B04FB6}, severity == 0, message == ptr(0x16ec0c))
UNK(i) [13:55:25.235] | Main(): disable VS2008
PSET(i) [13:55:25.235] | (673.118): Check Dependency for {F3CE10E5-7F75-4356-A379-05F5D6B04FB6}: 12021
UNK(i) [13:55:25.235] | Main(id == {3AE471C7-8858-472a-8D7C-48B871B5EBDF}, severity == 0, message == ptr(0x16ec0c))
UNK(i) [13:55:25.236] | Main(): disable VS2010
UNK(i) [13:55:25.236] | Main(): exit with severity == MISSING_DEPENDENCY_COMPONENT_DISABLED, message == String("")
PSET(i) [13:55:25.236] | (673.118): Check Dependency for {3AE471C7-8858-472a-8D7C-48B871B5EBDF}: 12021
UNK(i) [13:55:25.236] | pset::abstract_context(context == pset::ContextInfo(eInstallMode == INSTALL_MODE_COMPLETE, iLog == ptr(0x1563f74), lLocaleID == size_t("1033"), sCurrentArchitecture == String("Intel64"), sLicenseFiles == String(""), sVSPackageNumber == String(""), sPathToLocaleFileFolder == String("C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\1033\"), sSerialNumber == String("")))
UNK(i) [13:55:25.236] | pset::abstract_context() return: deps::Context(mode == INSTALL, silent == bool(false), upfront == bool(false), full == bool(true), locale == int("0"))
UNK(i) [13:55:25.236] | Main(id == {8AA98789-C136-4adc-8269-86F3C222906F}, severity == 0, message == ptr(0x16ec0c))
UNK(i) [13:55:25.236] | Main(): exit with severity == DependencyCode(0), message == String("")
PSET(i) [13:55:25.236] | (673.118): Check Dependency for {8AA98789-C136-4adc-8269-86F3C222906F}: 0
PSET(i) [13:55:25.236] | (673.118): Check Dependency for {97BC3C88-834C-11DE-B575-22C956D89593}: 0
PSET(i) [13:55:25.236] | (4225.1157): msi package: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\indicator\indicator.msi
PSET(i) [13:55:25.236] | (4225.1158): LicIsValid: 1     InstallOnCurrentArch: 1     Installed State: -1     Pending Action: 3
UNK(i) [13:55:25.236] | Main(id == {ACD97E2A-090D-46ea-9983-6E44BCA28575}, severity == 0, message == ptr(0x16ec0c))
UNK(i) [13:55:25.236] | Main(): Check dependencies
PSET(i) [13:55:25.236] | (673.118): Check Dependency for {ACD97E2A-090D-46ea-9983-6E44BCA28575}: 0
UNK(i) [13:55:25.236] | Main(id == {D52A1D2E-8D7A-4822-9421-3A92C64DB956}, severity == 0, message == ptr(0x16ec0c))
UNK(i) [13:55:25.236] | Main(): Check if need to show VS Integration dialog
PSET(i) [13:55:25.236] | (673.118): Check Dependency for {D52A1D2E-8D7A-4822-9421-3A92C64DB956}: 0
UNK(i) [13:55:25.237] |
UNK(i) [13:55:25.237] | pset::abstract_context(context == pset::ContextInfo(eInstallMode == INSTALL_MODE_COMPLETE, iLog == ptr(0x1563f74), lLocaleID == size_t("1033"), sCurrentArchitecture == String("Intel64"), sLicenseFiles == String(""), sVSPackageNumber == String(""), sPathToLocaleFileFolder == String("C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\1033\"), sSerialNumber == String("")))
UNK(i) [13:55:25.237] | pset::abstract_context() return: deps::Context(mode == INSTALL, silent == bool(false), upfront == bool(false), full == bool(true), locale == int("0"))
UNK(i) [13:55:25.237] | Main(id == {E3BA8A13-2647-4c01-81D5-77E6D912D9D5}, severity == 0, message == ptr(0x16ec0c))
UNK(i) [13:55:25.237] | Main(): disable VS 11
UNK(i) [13:55:25.237] | Main(): exit with severity == MISSING_DEPENDENCY_COMPONENT_DISABLED, message == String("")
PSET(i) [13:55:25.237] | (673.118): Check Dependency for {E3BA8A13-2647-4c01-81D5-77E6D912D9D5}: 12021
UNK(i) [13:55:25.237] | Main(id == {F3CE10E5-7F75-4356-A379-05F5D6B04FB6}, severity == 0, message == ptr(0x16ec0c))
UNK(i) [13:55:25.237] | Main(): disable VS2008
PSET(i) [13:55:25.237] | (673.118): Check Dependency for {F3CE10E5-7F75-4356-A379-05F5D6B04FB6}: 12021
UNK(i) [13:55:25.237] | Main(id == {3AE471C7-8858-472a-8D7C-48B871B5EBDF}, severity == 0, message == ptr(0x16ec0c))
UNK(i) [13:55:25.237] | Main(): disable VS2010
PSET(i) [13:55:25.237] | (673.118): Check Dependency for {3AE471C7-8858-472a-8D7C-48B871B5EBDF}: 12021
UNK(i) [13:55:25.237] | Main(id == {8AA98789-C136-4adc-8269-86F3C222906F}, severity == 0, message == ptr(0x16ec0c))
UNK(i) [13:55:25.237] | Main(): exit with severity == DependencyCode(0), message == String("")
PSET(i) [13:55:25.237] | (673.118): Check Dependency for {8AA98789-C136-4adc-8269-86F3C222906F}: 0
PSET(i) [13:55:25.238] | (673.118): Check Dependency for {97BC3C88-834C-11DE-B575-22C956D89593}: 0
PSET(i) [13:55:25.238] | (4225.1157): msi package: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\ps_he_cli\ps_he_cli.msi
PSET(i) [13:55:25.238] | (4225.1158): LicIsValid: 1     InstallOnCurrentArch: 1     Installed State: -1     Pending Action: 3
PSET(i) [13:55:25.238] | (673.178): UpdateNeedforCheck {ACD97E2A-090D-46ea-9983-6E44BCA28575}: Need
UNK(i) [13:55:25.238] |
UNK(i) [13:55:25.238] | pset::abstract_context(context == pset::ContextInfo(eInstallMode == INSTALL_MODE_COMPLETE, iLog == ptr(0x1563f74), lLocaleID == size_t("1033"), sCurrentArchitecture == String("Intel64"), sLicenseFiles == String(""), sVSPackageNumber == String(""), sPathToLocaleFileFolder == String("C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\1033\"), sSerialNumber == String("")))
UNK(i) [13:55:25.238] | pset::abstract_context() return: deps::Context(mode == INSTALL, silent == bool(false), upfront == bool(false), full == bool(true), locale == int("0"))
UNK(i) [13:55:25.238] | Main(id == {ACD97E2A-090D-46ea-9983-6E44BCA28575}, severity == 0, message == ptr(0x16ec0c))
UNK(i) [13:55:25.238] | Main(): Check dependencies
UNK(i) [13:55:25.238] | Main(): exit with severity == DependencyCode(0), message == String("")
PSET(i) [13:55:25.238] | (673.118): Check Dependency for {ACD97E2A-090D-46ea-9983-6E44BCA28575}: 0
UNK(i) [13:55:25.238] | Main(id == {D52A1D2E-8D7A-4822-9421-3A92C64DB956}, severity == 0, message == ptr(0x16ec0c))
UNK(i) [13:55:25.238] | Main(): Check if need to show VS Integration dialog
PSET(i) [13:55:25.238] | (673.118): Check Dependency for {D52A1D2E-8D7A-4822-9421-3A92C64DB956}: 0
UNK(i) [13:55:25.238] | Main(id == {E3BA8A13-2647-4c01-81D5-77E6D912D9D5}, severity == 0, message == ptr(0x16ec0c))
UNK(i) [13:55:25.238] | Main(): disable VS 11
UNK(i) [13:55:25.238] | Main(): exit with severity == MISSING_DEPENDENCY_COMPONENT_DISABLED, message == String("")
PSET(i) [13:55:25.238] | (673.118): Check Dependency for {E3BA8A13-2647-4c01-81D5-77E6D912D9D5}: 12021
UNK(i) [13:55:25.238] | Main(id == {F3CE10E5-7F75-4356-A379-05F5D6B04FB6}, severity == 0, message == ptr(0x16ec0c))
UNK(i) [13:55:25.238] | Main(): disable VS2008
PSET(i) [13:55:25.238] | (673.118): Check Dependency for {F3CE10E5-7F75-4356-A379-05F5D6B04FB6}: 12021
UNK(i) [13:55:25.238] | Main(id == {3AE471C7-8858-472a-8D7C-48B871B5EBDF}, severity == 0, message == ptr(0x16ec0c))
UNK(i) [13:55:25.239] | Main(): disable VS2010
UNK(i) [13:55:25.239] | Main(): exit with severity == MISSING_DEPENDENCY_COMPONENT_DISABLED, message == String("")
PSET(i) [13:55:25.239] | (673.118): Check Dependency for {3AE471C7-8858-472a-8D7C-48B871B5EBDF}: 12021
UNK(i) [13:55:25.239] | pset::abstract_context(context == pset::ContextInfo(eInstallMode == INSTALL_MODE_COMPLETE, iLog == ptr(0x1563f74), lLocaleID == size_t("1033"), sCurrentArchitecture == String("Intel64"), sLicenseFiles == String(""), sVSPackageNumber == String(""), sPathToLocaleFileFolder == String("C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\1033\"), sSerialNumber == String("")))
UNK(i) [13:55:25.239] | pset::abstract_context() return: deps::Context(mode == INSTALL, silent == bool(false), upfront == bool(false), full == bool(true), locale == int("0"))
UNK(i) [13:55:25.239] | Main(id == {8AA98789-C136-4adc-8269-86F3C222906F}, severity == 0, message == ptr(0x16ec0c))
UNK(i) [13:55:25.239] | Main(): exit with severity == DependencyCode(0), message == String("")
PSET(i) [13:55:25.239] | (673.118): Check Dependency for {8AA98789-C136-4adc-8269-86F3C222906F}: 0
PSET(i) [13:55:25.239] | (673.118): Check Dependency for {97BC3C88-834C-11DE-B575-22C956D89593}: 0
PSET(i) [13:55:25.239] | (4225.1157): msi package: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\ps_he_gui\ps_he_gui.msi
PSET(i) [13:55:25.239] | (4225.1158): LicIsValid: 1     InstallOnCurrentArch: 1     Installed State: -1     Pending Action: 3
PSET(i) [13:55:25.239] | (673.178): UpdateNeedforCheck {ACD97E2A-090D-46ea-9983-6E44BCA28575}: Need
UNK(i) [13:55:25.239] | Main(id == {ACD97E2A-090D-46ea-9983-6E44BCA28575}, severity == 0, message == ptr(0x16ec0c))
UNK(i) [13:55:25.239] | Main(): Check dependencies
PSET(i) [13:55:25.239] | (673.118): Check Dependency for {ACD97E2A-090D-46ea-9983-6E44BCA28575}: 0
UNK(i) [13:55:25.239] | Main(id == {D52A1D2E-8D7A-4822-9421-3A92C64DB956}, severity == 0, message == ptr(0x16ec0c))
UNK(i) [13:55:25.239] | Main(): Check if need to show VS Integration dialog
PSET(i) [13:55:25.239] | (673.118): Check Dependency for {D52A1D2E-8D7A-4822-9421-3A92C64DB956}: 0
UNK(i) [13:55:25.240] | Main(id == {E3BA8A13-2647-4c01-81D5-77E6D912D9D5}, severity == 0, message == ptr(0x16ec0c))
UNK(i) [13:55:25.240] | Main(): disable VS 11
UNK(i) [13:55:25.240] | Main(): exit with severity == MISSING_DEPENDENCY_COMPONENT_DISABLED, message == String("")
PSET(i) [13:55:25.240] | (673.118): Check Dependency for {E3BA8A13-2647-4c01-81D5-77E6D912D9D5}: 12021
UNK(i) [13:55:25.240] | pset::abstract_context(context == pset::ContextInfo(eInstallMode == INSTALL_MODE_COMPLETE, iLog == ptr(0x1563f74), lLocaleID == size_t("1033"), sCurrentArchitecture == String("Intel64"), sLicenseFiles == String(""), sVSPackageNumber == String(""), sPathToLocaleFileFolder == String("C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\1033\"), sSerialNumber == String("")))
UNK(i) [13:55:25.240] | pset::abstract_context() return: deps::Context(mode == INSTALL, silent == bool(false), upfront == bool(false), full == bool(true), locale == int("0"))
UNK(i) [13:55:25.240] | Main(id == {F3CE10E5-7F75-4356-A379-05F5D6B04FB6}, severity == 0, message == ptr(0x16ec0c))
UNK(i) [13:55:25.240] | Main(): disable VS2008
PSET(i) [13:55:25.240] | (673.118): Check Dependency for {F3CE10E5-7F75-4356-A379-05F5D6B04FB6}: 12021
UNK(i) [13:55:25.240] | Main(id == {3AE471C7-8858-472a-8D7C-48B871B5EBDF}, severity == 0, message == ptr(0x16ec0c))
UNK(i) [13:55:25.240] | Main(): disable VS2010
PSET(i) [13:55:25.240] | (673.118): Check Dependency for {3AE471C7-8858-472a-8D7C-48B871B5EBDF}: 12021
UNK(i) [13:55:25.240] | Main(id == {8AA98789-C136-4adc-8269-86F3C222906F}, severity == 0, message == ptr(0x16ec0c))
UNK(i) [13:55:25.240] | Main(): exit with severity == DependencyCode(0), message == String("")
PSET(i) [13:55:25.240] | (673.118): Check Dependency for {8AA98789-C136-4adc-8269-86F3C222906F}: 0
PSET(i) [13:55:25.241] | (673.118): Check Dependency for {97BC3C88-834C-11DE-B575-22C956D89593}: 0
PSET(i) [13:55:25.241] | (4225.1157): msi package: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\sep\sep.msi
PSET(i) [13:55:25.241] | (4225.1158): LicIsValid: 1     InstallOnCurrentArch: 1     Installed State: -1     Pending Action: 3
PSET(i) [13:55:25.241] | (673.178): UpdateNeedforCheck {ACD97E2A-090D-46ea-9983-6E44BCA28575}: Need
PSET(i) [13:55:25.241] | (673.178): UpdateNeedforCheck {8AA98789-C136-4adc-8269-86F3C222906F}: Need
UNK(i) [13:55:25.241] |
UNK(i) [13:55:25.241] | pset::abstract_context(context == pset::ContextInfo(eInstallMode == INSTALL_MODE_COMPLETE, iLog == ptr(0x1563f74), lLocaleID == size_t("1033"), sCurrentArchitecture == String("Intel64"), sLicenseFiles == String(""), sVSPackageNumber == String(""), sPathToLocaleFileFolder == String("C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\1033\"), sSerialNumber == String("")))
UNK(i) [13:55:25.241] | pset::abstract_context() return: deps::Context(mode == INSTALL, silent == bool(false), upfront == bool(false), full == bool(true), locale == int("0"))
UNK(i) [13:55:25.241] | Main(id == {ACD97E2A-090D-46ea-9983-6E44BCA28575}, severity == 0, message == ptr(0x16ec0c))
UNK(i) [13:55:25.241] | Main(): Check dependencies
UNK(i) [13:55:25.241] | Main(): exit with severity == DependencyCode(0), message == String("")
PSET(i) [13:55:25.241] | (673.118): Check Dependency for {ACD97E2A-090D-46ea-9983-6E44BCA28575}: 0
UNK(i) [13:55:25.241] | Main(id == {D52A1D2E-8D7A-4822-9421-3A92C64DB956}, severity == 0, message == ptr(0x16ec0c))
UNK(i) [13:55:25.241] | Main(): Check if need to show VS Integration dialog
PSET(i) [13:55:25.241] | (673.118): Check Dependency for {D52A1D2E-8D7A-4822-9421-3A92C64DB956}: 0
UNK(i) [13:55:25.241] | Main(id == {E3BA8A13-2647-4c01-81D5-77E6D912D9D5}, severity == 0, message == ptr(0x16ec0c))
UNK(i) [13:55:25.241] | Main(): disable VS 11
UNK(i) [13:55:25.241] | Main(): exit with severity == MISSING_DEPENDENCY_COMPONENT_DISABLED, message == String("")
PSET(i) [13:55:25.241] | (673.118): Check Dependency for {E3BA8A13-2647-4c01-81D5-77E6D912D9D5}: 12021
UNK(i) [13:55:25.241] | Main(id == {F3CE10E5-7F75-4356-A379-05F5D6B04FB6}, severity == 0, message == ptr(0x16ec0c))
UNK(i) [13:55:25.241] | Main(): disable VS2008
PSET(i) [13:55:25.241] | (673.118): Check Dependency for {F3CE10E5-7F75-4356-A379-05F5D6B04FB6}: 12021
UNK(i) [13:55:25.241] | Main(id == {3AE471C7-8858-472a-8D7C-48B871B5EBDF}, severity == 0, message == ptr(0x16ec0c))
UNK(i) [13:55:25.241] | Main(): disable VS2010
PSET(i) [13:55:25.241] | (673.118): Check Dependency for {3AE471C7-8858-472a-8D7C-48B871B5EBDF}: 12021
UNK(i) [13:55:25.242] | pset::abstract_context(context == pset::ContextInfo(eInstallMode == INSTALL_MODE_COMPLETE, iLog == ptr(0x1563f74), lLocaleID == size_t("1033"), sCurrentArchitecture == String("Intel64"), sLicenseFiles == String(""), sVSPackageNumber == String(""), sPathToLocaleFileFolder == String("C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\1033\"), sSerialNumber == String("")))
UNK(i) [13:55:25.242] | pset::abstract_context() return: deps::Context(mode == INSTALL, silent == bool(false), upfront == bool(false), full == bool(true), locale == int("0"))
UNK(i) [13:55:25.242] | Main(id == {8AA98789-C136-4adc-8269-86F3C222906F}, severity == 0, message == ptr(0x16ec0c))
UNK(i) [13:55:25.242] | Main(): exit with severity == DependencyCode(0), message == String("")
PSET(i) [13:55:25.242] | (673.118): Check Dependency for {8AA98789-C136-4adc-8269-86F3C222906F}: 0
PSET(i) [13:55:25.242] | (673.118): Check Dependency for {97BC3C88-834C-11DE-B575-22C956D89593}: 0
PSET(i) [13:55:25.242] | (4225.1157): msi package: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs11-integration.msi
PSET(i) [13:55:25.242] | (4225.1158): LicIsValid: 1     InstallOnCurrentArch: 1     Installed State: -1     Pending Action: 3
PSET(i) [13:55:25.242] | (673.178): UpdateNeedforCheck {ACD97E2A-090D-46ea-9983-6E44BCA28575}: Not Need
PSET(i) [13:55:25.242] | (673.178): UpdateNeedforCheck {E3BA8A13-2647-4c01-81D5-77E6D912D9D5}: Not Need
PSET(i) [13:55:25.242] | (673.178): UpdateNeedforCheck {D52A1D2E-8D7A-4822-9421-3A92C64DB956}: Not Need
UNK(i) [13:55:25.242] | Main(id == {ACD97E2A-090D-46ea-9983-6E44BCA28575}, severity == 0, message == ptr(0x16ec0c))
UNK(i) [13:55:25.242] | Main(): Check dependencies
PSET(i) [13:55:25.242] | (673.118): Check Dependency for {ACD97E2A-090D-46ea-9983-6E44BCA28575}: 0
UNK(i) [13:55:25.242] | Main(id == {D52A1D2E-8D7A-4822-9421-3A92C64DB956}, severity == 0, message == ptr(0x16ec0c))
UNK(i) [13:55:25.242] | Main(): Check if need to show VS Integration dialog
PSET(i) [13:55:25.242] | (673.118): Check Dependency for {D52A1D2E-8D7A-4822-9421-3A92C64DB956}: 0
UNK(i) [13:55:25.242] | Main(id == {E3BA8A13-2647-4c01-81D5-77E6D912D9D5}, severity == 0, message == ptr(0x16ec0c))
UNK(i) [13:55:25.243] | Main(): disable VS 11
UNK(i) [13:55:25.243] | Main(): exit with severity == MISSING_DEPENDENCY_COMPONENT_DISABLED, message == String("")
PSET(i) [13:55:25.243] | (673.118): Check Dependency for {E3BA8A13-2647-4c01-81D5-77E6D912D9D5}: 12021
UNK(i) [13:55:25.243] | pset::abstract_context(context == pset::ContextInfo(eInstallMode == INSTALL_MODE_COMPLETE, iLog == ptr(0x1563f74), lLocaleID == size_t("1033"), sCurrentArchitecture == String("Intel64"), sLicenseFiles == String(""), sVSPackageNumber == String(""), sPathToLocaleFileFolder == String("C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\1033\"), sSerialNumber == String("")))
UNK(i) [13:55:25.243] | pset::abstract_context() return: deps::Context(mode == INSTALL, silent == bool(false), upfront == bool(false), full == bool(true), locale == int("0"))
UNK(i) [13:55:25.243] | Main(id == {F3CE10E5-7F75-4356-A379-05F5D6B04FB6}, severity == 0, message == ptr(0x16ec0c))
UNK(i) [13:55:25.243] | Main(): disable VS2008
PSET(i) [13:55:25.243] | (673.118): Check Dependency for {F3CE10E5-7F75-4356-A379-05F5D6B04FB6}: 12021
UNK(i) [13:55:25.243] | Main(id == {3AE471C7-8858-472a-8D7C-48B871B5EBDF}, severity == 0, message == ptr(0x16ec0c))
UNK(i) [13:55:25.243] | Main(): disable VS2010
PSET(i) [13:55:25.243] | (673.118): Check Dependency for {3AE471C7-8858-472a-8D7C-48B871B5EBDF}: 12021
UNK(i) [13:55:25.243] | Main(id == {8AA98789-C136-4adc-8269-86F3C222906F}, severity == 0, message == ptr(0x16ec0c))
UNK(i) [13:55:25.243] | Main(): exit with severity == DependencyCode(0), message == String("")
PSET(i) [13:55:25.243] | (673.118): Check Dependency for {8AA98789-C136-4adc-8269-86F3C222906F}: 0
PSET(i) [13:55:25.244] | (673.118): Check Dependency for {97BC3C88-834C-11DE-B575-22C956D89593}: 0
PSET(i) [13:55:25.244] | (4225.1224): Disabled C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs11-integration.msi
PSET(i) [13:55:25.244] | (4225.285): MsiOpenPackageEx(C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs11-integration.msi)
PSET(i) [13:55:25.303] | (6497.173): Feature=core PendingAction=5, Action=3
PSET(i) [13:55:25.303] | (6497.176): Call MsiSetFeatureState(core)
PSET(i) [13:55:25.305] | (4225.285): MsiOpenPackageEx(C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs11-integration.msi)
PSET(i) [13:55:25.363] | (6497.173): Feature=core PendingAction=-1, Action=3
PSET(i) [13:55:25.365] | (4225.1157): msi package: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs2008-integration.msi
PSET(i) [13:55:25.365] | (4225.1158): LicIsValid: 1     InstallOnCurrentArch: 1     Installed State: -1     Pending Action: 3
PSET(i) [13:55:25.365] | (673.178): UpdateNeedforCheck {ACD97E2A-090D-46ea-9983-6E44BCA28575}: Not Need
PSET(i) [13:55:25.365] | (673.178): UpdateNeedforCheck {F3CE10E5-7F75-4356-A379-05F5D6B04FB6}: Not Need
PSET(i) [13:55:25.365] | (673.178): UpdateNeedforCheck {D52A1D2E-8D7A-4822-9421-3A92C64DB956}: Not Need
UNK(i) [13:55:25.365] |
UNK(i) [13:55:25.365] | pset::abstract_context(context == pset::ContextInfo(eInstallMode == INSTALL_MODE_COMPLETE, iLog == ptr(0x1563f74), lLocaleID == size_t("1033"), sCurrentArchitecture == String("Intel64"), sLicenseFiles == String(""), sVSPackageNumber == String(""), sPathToLocaleFileFolder == String("C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\1033\"), sSerialNumber == String("")))
UNK(i) [13:55:25.365] | pset::abstract_context() return: deps::Context(mode == INSTALL, silent == bool(false), upfront == bool(false), full == bool(true), locale == int("0"))
UNK(i) [13:55:25.365] | Main(id == {ACD97E2A-090D-46ea-9983-6E44BCA28575}, severity == 0, message == ptr(0x16ec0c))
UNK(i) [13:55:25.365] | Main(): Check dependencies
UNK(i) [13:55:25.365] | Main(): exit with severity == DependencyCode(0), message == String("")
PSET(i) [13:55:25.365] | (673.118): Check Dependency for {ACD97E2A-090D-46ea-9983-6E44BCA28575}: 0
UNK(i) [13:55:25.365] | Main(id == {D52A1D2E-8D7A-4822-9421-3A92C64DB956}, severity == 0, message == ptr(0x16ec0c))
UNK(i) [13:55:25.365] | Main(): Check if need to show VS Integration dialog
PSET(i) [13:55:25.365] | (673.118): Check Dependency for {D52A1D2E-8D7A-4822-9421-3A92C64DB956}: 0
UNK(i) [13:55:25.365] | Main(id == {E3BA8A13-2647-4c01-81D5-77E6D912D9D5}, severity == 0, message == ptr(0x16ec0c))
UNK(i) [13:55:25.365] | Main(): disable VS 11
UNK(i) [13:55:25.365] | Main(): exit with severity == MISSING_DEPENDENCY_COMPONENT_DISABLED, message == String("")
PSET(i) [13:55:25.365] | (673.118): Check Dependency for {E3BA8A13-2647-4c01-81D5-77E6D912D9D5}: 12021
UNK(i) [13:55:25.365] | Main(id == {F3CE10E5-7F75-4356-A379-05F5D6B04FB6}, severity == 0, message == ptr(0x16ec0c))
UNK(i) [13:55:25.365] | Main(): disable VS2008
PSET(i) [13:55:25.365] | (673.118): Check Dependency for {F3CE10E5-7F75-4356-A379-05F5D6B04FB6}: 12021
UNK(i) [13:55:25.366] | pset::abstract_context() return: deps::Context(mode == INSTALL, silent == bool(false), upfront == bool(false), full == bool(true), locale == int("0"))
UNK(i) [13:55:25.366] | Main(id == {3AE471C7-8858-472a-8D7C-48B871B5EBDF}, severity == 0, message == ptr(0x16ec0c))
UNK(i) [13:55:25.366] | Main(): disable VS2010
UNK(i) [13:55:25.366] | Main(): exit with severity == MISSING_DEPENDENCY_COMPONENT_DISABLED, message == String("")
PSET(i) [13:55:25.366] | (673.118): Check Dependency for {3AE471C7-8858-472a-8D7C-48B871B5EBDF}: 12021
UNK(i) [13:55:25.366] | pset::abstract_context(context == pset::ContextInfo(eInstallMode == INSTALL_MODE_COMPLETE, iLog == ptr(0x1563f74), lLocaleID == size_t("1033"), sCurrentArchitecture == String("Intel64"), sLicenseFiles == String(""), sVSPackageNumber == String(""), sPathToLocaleFileFolder == String("C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\1033\"), sSerialNumber == String("")))
UNK(i) [13:55:25.366] | Main(id == {8AA98789-C136-4adc-8269-86F3C222906F}, severity == 0, message == ptr(0x16ec0c))
UNK(i) [13:55:25.366] | Main(): exit with severity == DependencyCode(0), message == String("")
PSET(i) [13:55:25.366] | (673.118): Check Dependency for {8AA98789-C136-4adc-8269-86F3C222906F}: 0
PSET(i) [13:55:25.366] | (673.118): Check Dependency for {97BC3C88-834C-11DE-B575-22C956D89593}: 0
PSET(i) [13:55:25.366] | (4225.1224): Disabled C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs2008-integration.msi
PSET(i) [13:55:25.366] | (4225.285): MsiOpenPackageEx(C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs2008-integration.msi)
PSET(i) [13:55:25.426] | (6497.173): Feature=core PendingAction=5, Action=3
PSET(i) [13:55:25.426] | (6497.176): Call MsiSetFeatureState(core)
PSET(i) [13:55:25.428] | (4225.285): MsiOpenPackageEx(C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs2008-integration.msi)
PSET(i) [13:55:25.487] | (6497.173): Feature=core PendingAction=-1, Action=3
PSET(i) [13:55:25.489] | (4225.1157): msi package: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs2010-integration.msi
PSET(i) [13:55:25.489] | (4225.1158): LicIsValid: 1     InstallOnCurrentArch: 1     Installed State: -1     Pending Action: 3
PSET(i) [13:55:25.489] | (673.178): UpdateNeedforCheck {ACD97E2A-090D-46ea-9983-6E44BCA28575}: Not Need
PSET(i) [13:55:25.489] | (673.178): UpdateNeedforCheck {3AE471C7-8858-472a-8D7C-48B871B5EBDF}: Not Need
PSET(i) [13:55:25.489] | (673.178): UpdateNeedforCheck {D52A1D2E-8D7A-4822-9421-3A92C64DB956}: Not Need
UNK(i) [13:55:25.489] |
UNK(i) [13:55:25.489] | pset::abstract_context(context == pset::ContextInfo(eInstallMode == INSTALL_MODE_COMPLETE, iLog == ptr(0x1563f74), lLocaleID == size_t("1033"), sCurrentArchitecture == String("Intel64"), sLicenseFiles == String(""), sVSPackageNumber == String(""), sPathToLocaleFileFolder == String("C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\1033\"), sSerialNumber == String("")))
UNK(i) [13:55:25.489] | pset::abstract_context() return: deps::Context(mode == INSTALL, silent == bool(false), upfront == bool(false), full == bool(true), locale == int("0"))
UNK(i) [13:55:25.489] | Main(id == {ACD97E2A-090D-46ea-9983-6E44BCA28575}, severity == 0, message == ptr(0x16ec0c))
UNK(i) [13:55:25.489] | Main(): Check dependencies
UNK(i) [13:55:25.489] | Main(): exit with severity == DependencyCode(0), message == String("")
PSET(i) [13:55:25.489] | (673.118): Check Dependency for {ACD97E2A-090D-46ea-9983-6E44BCA28575}: 0
Plugin psetlogger is initialized.
UNK(i) [13:55:25.489] | Main(id == {D52A1D2E-8D7A-4822-9421-3A92C64DB956}, severity == 0, message == ptr(0x16ec0c))
UNK(i) [13:55:25.489] | Main(): Check if need to show VS Integration dialog
PSET(i) [13:55:25.489] | (673.118): Check Dependency for {D52A1D2E-8D7A-4822-9421-3A92C64DB956}: 0
UNK(i) [13:55:25.490] | pset::abstract_context() return: deps::Context(mode == INSTALL, silent == bool(false), upfront == bool(false), full == bool(true), locale == int("0"))
UNK(i) [13:55:25.490] | Main(id == {E3BA8A13-2647-4c01-81D5-77E6D912D9D5}, severity == 0, message == ptr(0x16ec0c))
UNK(i) [13:55:25.490] | Main(): disable VS 11
UNK(i) [13:55:25.490] | Main(): exit with severity == MISSING_DEPENDENCY_COMPONENT_DISABLED, message == String("")
PSET(i) [13:55:25.490] | (673.118): Check Dependency for {E3BA8A13-2647-4c01-81D5-77E6D912D9D5}: 12021
UNK(i) [13:55:25.490] | pset::abstract_context(context == pset::ContextInfo(eInstallMode == INSTALL_MODE_COMPLETE, iLog == ptr(0x1563f74), lLocaleID == size_t("1033"), sCurrentArchitecture == String("Intel64"), sLicenseFiles == String(""), sVSPackageNumber == String(""), sPathToLocaleFileFolder == String("C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\1033\"), sSerialNumber == String("")))
UNK(i) [13:55:25.490] | Main(id == {F3CE10E5-7F75-4356-A379-05F5D6B04FB6}, severity == 0, message == ptr(0x16ec0c))
UNK(i) [13:55:25.490] | Main(): disable VS2008
PSET(i) [13:55:25.490] | (673.118): Check Dependency for {F3CE10E5-7F75-4356-A379-05F5D6B04FB6}: 12021
UNK(i) [13:55:25.490] | Main(id == {3AE471C7-8858-472a-8D7C-48B871B5EBDF}, severity == 0, message == ptr(0x16ec0c))
UNK(i) [13:55:25.490] | Main(): disable VS2010
PSET(i) [13:55:25.490] | (673.118): Check Dependency for {3AE471C7-8858-472a-8D7C-48B871B5EBDF}: 12021
UNK(i) [13:55:25.490] | Main(id == {8AA98789-C136-4adc-8269-86F3C222906F}, severity == 0, message == ptr(0x16ec0c))
UNK(i) [13:55:25.490] | Main(): exit with severity == DependencyCode(0), message == String("")
PSET(i) [13:55:25.490] | (673.118): Check Dependency for {8AA98789-C136-4adc-8269-86F3C222906F}: 0
PSET(i) [13:55:25.491] | (673.118): Check Dependency for {97BC3C88-834C-11DE-B575-22C956D89593}: 0
PSET(i) [13:55:25.491] | (4225.1224): Disabled C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs2010-integration.msi
PSET(i) [13:55:25.491] | (4225.285): MsiOpenPackageEx(C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs2010-integration.msi)
PSET(i) [13:55:25.549] | (6497.173): Feature=core PendingAction=5, Action=3
PSET(i) [13:55:25.549] | (6497.176): Call MsiSetFeatureState(core)
PSET(i) [13:55:25.550] | (4225.285): MsiOpenPackageEx(C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\vs2010-integration.msi)
PSET(i) [13:55:25.608] | (6497.173): Feature=core PendingAction=-1, Action=3
PSET(i) [13:55:25.609] | (4225.1157): msi package: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\dim\distributed_install.msi
PSET(i) [13:55:25.609] | (4225.1158): LicIsValid: 1     InstallOnCurrentArch: 1     Installed State: 5     Pending Action: 3
PSET(i) [13:55:25.609] | (673.178): UpdateNeedforCheck {97BC3C88-834C-11DE-B575-22C956D89593}: Need
UNK(i) [13:55:25.609] |
UNK(i) [13:55:25.609] | pset::abstract_context(context == pset::ContextInfo(eInstallMode == INSTALL_MODE_COMPLETE, iLog == ptr(0x1563f74), lLocaleID == size_t("1033"), sCurrentArchitecture == String("Intel64"), sLicenseFiles == String(""), sVSPackageNumber == String(""), sPathToLocaleFileFolder == String("C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\1033\"), sSerialNumber == String("")))
UNK(i) [13:55:25.610] | pset::abstract_context() return: deps::Context(mode == INSTALL, silent == bool(false), upfront == bool(false), full == bool(true), locale == int("0"))
UNK(i) [13:55:25.610] | Main(id == {ACD97E2A-090D-46ea-9983-6E44BCA28575}, severity == 0, message == ptr(0x16ec0c))
UNK(i) [13:55:25.610] | Main(): Check dependencies
UNK(i) [13:55:25.610] | Main(): exit with severity == DependencyCode(0), message == String("")
PSET(i) [13:55:25.610] | (673.118): Check Dependency for {ACD97E2A-090D-46ea-9983-6E44BCA28575}: 0
UNK(i) [13:55:25.610] | pset::abstract_context(context == pset::ContextInfo(eInstallMode == INSTALL_MODE_COMPLETE, iLog == ptr(0x1563f74), lLocaleID == size_t("1033"), sCurrentArchitecture == String("Intel64"), sLicenseFiles == String(""), sVSPackageNumber == String(""), sPathToLocaleFileFolder == String("C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\1033\"), sSerialNumber == String("")))
UNK(i) [13:55:25.610] | Main(id == {D52A1D2E-8D7A-4822-9421-3A92C64DB956}, severity == 0, message == ptr(0x16ec0c))
UNK(i) [13:55:25.610] | Main(): Check if need to show VS Integration dialog
PSET(i) [13:55:25.610] | (673.118): Check Dependency for {D52A1D2E-8D7A-4822-9421-3A92C64DB956}: 0
UNK(i) [13:55:25.610] | Main(id == {E3BA8A13-2647-4c01-81D5-77E6D912D9D5}, severity == 0, message == ptr(0x16ec0c))
UNK(i) [13:55:25.610] | Main(): disable VS 11
UNK(i) [13:55:25.610] | Main(): exit with severity == MISSING_DEPENDENCY_COMPONENT_DISABLED, message == String("")
PSET(i) [13:55:25.610] | (673.118): Check Dependency for {E3BA8A13-2647-4c01-81D5-77E6D912D9D5}: 12021
UNK(i) [13:55:25.610] | Main(id == {F3CE10E5-7F75-4356-A379-05F5D6B04FB6}, severity == 0, message == ptr(0x16ec0c))
UNK(i) [13:55:25.610] | Main(): disable VS2008
PSET(i) [13:55:25.610] | (673.118): Check Dependency for {F3CE10E5-7F75-4356-A379-05F5D6B04FB6}: 12021
UNK(i) [13:55:25.610] | Main(id == {3AE471C7-8858-472a-8D7C-48B871B5EBDF}, severity == 0, message == ptr(0x16ec0c))
UNK(i) [13:55:25.610] | Main(): disable VS2010
PSET(i) [13:55:25.610] | (673.118): Check Dependency for {3AE471C7-8858-472a-8D7C-48B871B5EBDF}: 12021
UNK(i) [13:55:25.611] | Main(id == {8AA98789-C136-4adc-8269-86F3C222906F}, severity == 0, message == ptr(0x16ec0c))
UNK(i) [13:55:25.611] | Main(): exit with severity == DependencyCode(0), message == String("")
PSET(i) [13:55:25.611] | (673.118): Check Dependency for {8AA98789-C136-4adc-8269-86F3C222906F}: 0
PSET(i) [13:55:25.611] | (673.118): Check Dependency for {97BC3C88-834C-11DE-B575-22C956D89593}: 0
PSET(i) [13:55:25.611] | (4225.1157): msi package: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\msvcrt_x86.msi
PSET(i) [13:55:25.611] | (4225.1158): LicIsValid: 1     InstallOnCurrentArch: 1     Installed State: -1     Pending Action: 3
PSET(i) [13:55:25.611] | (673.178): UpdateNeedforCheck {ACD97E2A-090D-46ea-9983-6E44BCA28575}: Need
UNK(i) [13:55:25.611] | pset::abstract_context(context == pset::ContextInfo(eInstallMode == INSTALL_MODE_COMPLETE, iLog == ptr(0x1563f74), lLocaleID == size_t("1033"), sCurrentArchitecture == String("Intel64"), sLicenseFiles == String(""), sVSPackageNumber == String(""), sPathToLocaleFileFolder == String("C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\1033\"), sSerialNumber == String("")))
UNK(i) [13:55:25.611] | pset::abstract_context() return: deps::Context(mode == INSTALL, silent == bool(false), upfront == bool(false), full == bool(true), locale == int("0"))
UNK(i) [13:55:25.611] | Main(id == {ACD97E2A-090D-46ea-9983-6E44BCA28575}, severity == 0, message == ptr(0x16ec0c))
UNK(i) [13:55:25.611] | Main(): Check dependencies
PSET(i) [13:55:25.611] | (673.118): Check Dependency for {ACD97E2A-090D-46ea-9983-6E44BCA28575}: 0
UNK(i) [13:55:25.611] | Main(id == {D52A1D2E-8D7A-4822-9421-3A92C64DB956}, severity == 0, message == ptr(0x16ec0c))
UNK(i) [13:55:25.611] | Main(): Check if need to show VS Integration dialog
PSET(i) [13:55:25.611] | (673.118): Check Dependency for {D52A1D2E-8D7A-4822-9421-3A92C64DB956}: 0
UNK(i) [13:55:25.611] | Main(id == {E3BA8A13-2647-4c01-81D5-77E6D912D9D5}, severity == 0, message == ptr(0x16ec0c))
UNK(i) [13:55:25.612] | Main(): disable VS 11
UNK(i) [13:55:25.612] | Main(): exit with severity == MISSING_DEPENDENCY_COMPONENT_DISABLED, message == String("")
PSET(i) [13:55:25.612] | (673.118): Check Dependency for {E3BA8A13-2647-4c01-81D5-77E6D912D9D5}: 12021
UNK(i) [13:55:25.612] | pset::abstract_context(context == pset::ContextInfo(eInstallMode == INSTALL_MODE_COMPLETE, iLog == ptr(0x1563f74), lLocaleID == size_t("1033"), sCurrentArchitecture == String("Intel64"), sLicenseFiles == String(""), sVSPackageNumber == String(""), sPathToLocaleFileFolder == String("C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\1033\"), sSerialNumber == String("")))
UNK(i) [13:55:25.612] | pset::abstract_context() return: deps::Context(mode == INSTALL, silent == bool(false), upfront == bool(false), full == bool(true), locale == int("0"))
UNK(i) [13:55:25.612] | Main(id == {F3CE10E5-7F75-4356-A379-05F5D6B04FB6}, severity == 0, message == ptr(0x16ec0c))
UNK(i) [13:55:25.612] | Main(): disable VS2008
PSET(i) [13:55:25.612] | (673.118): Check Dependency for {F3CE10E5-7F75-4356-A379-05F5D6B04FB6}: 12021
UNK(i) [13:55:25.612] | Main(id == {3AE471C7-8858-472a-8D7C-48B871B5EBDF}, severity == 0, message == ptr(0x16ec0c))
UNK(i) [13:55:25.612] | Main(): disable VS2010
PSET(i) [13:55:25.612] | (673.118): Check Dependency for {3AE471C7-8858-472a-8D7C-48B871B5EBDF}: 12021
UNK(i) [13:55:25.612] | Main(id == {8AA98789-C136-4adc-8269-86F3C222906F}, severity == 0, message == ptr(0x16ec0c))
UNK(i) [13:55:25.612] | Main(): exit with severity == DependencyCode(0), message == String("")
PSET(i) [13:55:25.612] | (673.118): Check Dependency for {8AA98789-C136-4adc-8269-86F3C222906F}: 0
PSET(i) [13:55:25.613] | (673.118): Check Dependency for {97BC3C88-834C-11DE-B575-22C956D89593}: 0
PSET(i) [13:55:25.613] | (4225.1157): msi package: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\msvcrt_x64.msi
PSET(i) [13:55:25.613] | (4225.1158): LicIsValid: 1     InstallOnCurrentArch: 1     Installed State: -1     Pending Action: 3
PSET(i) [13:55:25.613] | (673.178): UpdateNeedforCheck {ACD97E2A-090D-46ea-9983-6E44BCA28575}: Need
UNK(i) [13:55:25.613] |
UNK(i) [13:55:25.613] | pset::abstract_context(context == pset::ContextInfo(eInstallMode == INSTALL_MODE_COMPLETE, iLog == ptr(0x1563f74), lLocaleID == size_t("1033"), sCurrentArchitecture == String("Intel64"), sLicenseFiles == String(""), sVSPackageNumber == String(""), sPathToLocaleFileFolder == String("C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\1033\"), sSerialNumber == String("")))
UNK(i) [13:55:25.613] | pset::abstract_context() return: deps::Context(mode == INSTALL, silent == bool(false), upfront == bool(false), full == bool(true), locale == int("0"))
UNK(i) [13:55:25.613] | Main(id == {ACD97E2A-090D-46ea-9983-6E44BCA28575}, severity == 0, message == ptr(0x16ec0c))
UNK(i) [13:55:25.613] | Main(): Check dependencies
UNK(i) [13:55:25.613] | Main(): exit with severity == DependencyCode(0), message == String("")
PSET(i) [13:55:25.613] | (673.118): Check Dependency for {ACD97E2A-090D-46ea-9983-6E44BCA28575}: 0
UNK(i) [13:55:25.613] | Main(id == {D52A1D2E-8D7A-4822-9421-3A92C64DB956}, severity == 0, message == ptr(0x16ec0c))
UNK(i) [13:55:25.613] | Main(): Check if need to show VS Integration dialog
PSET(i) [13:55:25.613] | (673.118): Check Dependency for {D52A1D2E-8D7A-4822-9421-3A92C64DB956}: 0
UNK(i) [13:55:25.613] | Main(id == {E3BA8A13-2647-4c01-81D5-77E6D912D9D5}, severity == 0, message == ptr(0x16ec0c))
UNK(i) [13:55:25.613] | Main(): disable VS 11
UNK(i) [13:55:25.613] | Main(): exit with severity == MISSING_DEPENDENCY_COMPONENT_DISABLED, message == String("")
PSET(i) [13:55:25.613] | (673.118): Check Dependency for {E3BA8A13-2647-4c01-81D5-77E6D912D9D5}: 12021
UNK(i) [13:55:25.613] | Main(id == {F3CE10E5-7F75-4356-A379-05F5D6B04FB6}, severity == 0, message == ptr(0x16ec0c))
UNK(i) [13:55:25.613] | Main(): disable VS2008
PSET(i) [13:55:25.613] | (673.118): Check Dependency for {F3CE10E5-7F75-4356-A379-05F5D6B04FB6}: 12021
UNK(i) [13:55:25.613] | Main(id == {3AE471C7-8858-472a-8D7C-48B871B5EBDF}, severity == 0, message == ptr(0x16ec0c))
UNK(i) [13:55:25.613] | Main(): disable VS2010
PSET(i) [13:55:25.613] | (673.118): Check Dependency for {3AE471C7-8858-472a-8D7C-48B871B5EBDF}: 12021
UNK(i) [13:55:25.614] | pset::abstract_context(context == pset::ContextInfo(eInstallMode == INSTALL_MODE_COMPLETE, iLog == ptr(0x1563f74), lLocaleID == size_t("1033"), sCurrentArchitecture == String("Intel64"), sLicenseFiles == String(""), sVSPackageNumber == String(""), sPathToLocaleFileFolder == String("C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\1033\"), sSerialNumber == String("")))
UNK(i) [13:55:25.614] | pset::abstract_context() return: deps::Context(mode == INSTALL, silent == bool(false), upfront == bool(false), full == bool(true), locale == int("0"))
UNK(i) [13:55:25.614] | Main(id == {8AA98789-C136-4adc-8269-86F3C222906F}, severity == 0, message == ptr(0x16ec0c))
UNK(i) [13:55:25.614] | Main(): exit with severity == DependencyCode(0), message == String("")
PSET(i) [13:55:25.614] | (673.118): Check Dependency for {8AA98789-C136-4adc-8269-86F3C222906F}: 0
PSET(i) [13:55:25.614] | (673.118): Check Dependency for {97BC3C88-834C-11DE-B575-22C956D89593}: 0
PSET(i) [13:55:25.614] | (4225.1157): msi package: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\ism\ism.msi
PSET(i) [13:55:25.614] | (4225.1158): LicIsValid: 1     InstallOnCurrentArch: 1     Installed State: -1     Pending Action: 3
UNK(i) [13:55:25.614] | Main(id == {ACD97E2A-090D-46ea-9983-6E44BCA28575}, severity == 0, message == ptr(0x16ec0c))
UNK(i) [13:55:25.614] | Main(): Check dependencies
PSET(i) [13:55:25.614] | (673.118): Check Dependency for {ACD97E2A-090D-46ea-9983-6E44BCA28575}: 0
UNK(i) [13:55:25.614] | Main(id == {D52A1D2E-8D7A-4822-9421-3A92C64DB956}, severity == 0, message == ptr(0x16ec0c))
UNK(i) [13:55:25.614] | Main(): Check if need to show VS Integration dialog
PSET(i) [13:55:25.614] | (673.118): Check Dependency for {D52A1D2E-8D7A-4822-9421-3A92C64DB956}: 0
UNK(i) [13:55:25.614] | Main(id == {E3BA8A13-2647-4c01-81D5-77E6D912D9D5}, severity == 0, message == ptr(0x16ec0c))
UNK(i) [13:55:25.614] | Main(): disable VS 11
UNK(i) [13:55:25.614] | Main(): exit with severity == MISSING_DEPENDENCY_COMPONENT_DISABLED, message == String("")
PSET(i) [13:55:25.614] | (673.118): Check Dependency for {E3BA8A13-2647-4c01-81D5-77E6D912D9D5}: 12021
UNK(i) [13:55:25.615] | pset::abstract_context(context == pset::ContextInfo(eInstallMode == INSTALL_MODE_COMPLETE, iLog == ptr(0x1563f74), lLocaleID == size_t("1033"), sCurrentArchitecture == String("Intel64"), sLicenseFiles == String(""), sVSPackageNumber == String(""), sPathToLocaleFileFolder == String("C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\1033\"), sSerialNumber == String("")))
UNK(i) [13:55:25.615] | pset::abstract_context() return: deps::Context(mode == INSTALL, silent == bool(false), upfront == bool(false), full == bool(true), locale == int("0"))
UNK(i) [13:55:25.615] | Main(id == {F3CE10E5-7F75-4356-A379-05F5D6B04FB6}, severity == 0, message == ptr(0x16ec0c))
UNK(i) [13:55:25.615] | Main(): disable VS2008
UNK(i) [13:55:25.615] | Main(): exit with severity == MISSING_DEPENDENCY_COMPONENT_DISABLED, message == String("")
PSET(i) [13:55:25.615] | (673.118): Check Dependency for {F3CE10E5-7F75-4356-A379-05F5D6B04FB6}: 12021
UNK(i) [13:55:25.615] | Main(id == {3AE471C7-8858-472a-8D7C-48B871B5EBDF}, severity == 0, message == ptr(0x16ec0c))
UNK(i) [13:55:25.615] | Main(): disable VS2010
PSET(i) [13:55:25.615] | (673.118): Check Dependency for {3AE471C7-8858-472a-8D7C-48B871B5EBDF}: 12021
UNK(i) [13:55:25.615] | Main(id == {8AA98789-C136-4adc-8269-86F3C222906F}, severity == 0, message == ptr(0x16ec0c))
UNK(i) [13:55:25.615] | Main(): exit with severity == DependencyCode(0), message == String("")
PSET(i) [13:55:25.615] | (673.118): Check Dependency for {8AA98789-C136-4adc-8269-86F3C222906F}: 0
PSET(i) [13:55:25.615] | (673.118): Check Dependency for {97BC3C88-834C-11DE-B575-22C956D89593}: 0
PSET(i) [13:55:25.615] | (4225.1157): msi package:
PSET(i) [13:55:25.615] | (4225.1158): LicIsValid: 1     InstallOnCurrentArch: 1     Installed State: -1     Pending Action: -7
UNK(i) [13:55:25.616] | pset::abstract_context(context == pset::ContextInfo(eInstallMode == INSTALL_MODE_COMPLETE, iLog == ptr(0x1563f74), lLocaleID == size_t("1033"), sCurrentArchitecture == String("Intel64"), sLicenseFiles == String(""), sVSPackageNumber == String(""), sPathToLocaleFileFolder == String("C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\1033\"), sSerialNumber == String("")))
UNK(i) [13:55:25.616] | pset::abstract_context() return: deps::Context(mode == INSTALL, silent == bool(false), upfront == bool(false), full == bool(true), locale == int("0"))
UNK(i) [13:55:25.616] | Main(id == {ACD97E2A-090D-46ea-9983-6E44BCA28575}, severity == 0, message == ptr(0x16ec0c))
UNK(i) [13:55:25.616] | Main(): Check dependencies
UNK(i) [13:55:25.616] | Main(): exit with severity == DependencyCode(0), message == String("")
PSET(i) [13:55:25.616] | (673.118): Check Dependency for {ACD97E2A-090D-46ea-9983-6E44BCA28575}: 0
UNK(i) [13:55:25.616] | Main(id == {D52A1D2E-8D7A-4822-9421-3A92C64DB956}, severity == 0, message == ptr(0x16ec0c))
UNK(i) [13:55:25.616] | Main(): Check if need to show VS Integration dialog
PSET(i) [13:55:25.616] | (673.118): Check Dependency for {D52A1D2E-8D7A-4822-9421-3A92C64DB956}: 0
UNK(i) [13:55:25.616] | Main(id == {E3BA8A13-2647-4c01-81D5-77E6D912D9D5}, severity == 0, message == ptr(0x16ec0c))
UNK(i) [13:55:25.616] | Main(): disable VS 11
UNK(i) [13:55:25.616] | Main(): exit with severity == MISSING_DEPENDENCY_COMPONENT_DISABLED, message == String("")
PSET(i) [13:55:25.616] | (673.118): Check Dependency for {E3BA8A13-2647-4c01-81D5-77E6D912D9D5}: 12021
UNK(i) [13:55:25.616] | Main(id == {F3CE10E5-7F75-4356-A379-05F5D6B04FB6}, severity == 0, message == ptr(0x16ec0c))
UNK(i) [13:55:25.616] | Main(): disable VS2008
PSET(i) [13:55:25.616] | (673.118): Check Dependency for {F3CE10E5-7F75-4356-A379-05F5D6B04FB6}: 12021
UNK(i) [13:55:25.616] | Main(id == {3AE471C7-8858-472a-8D7C-48B871B5EBDF}, severity == 0, message == ptr(0x16ec0c))
UNK(i) [13:55:25.616] | Main(): disable VS2010
PSET(i) [13:55:25.616] | (673.118): Check Dependency for {3AE471C7-8858-472a-8D7C-48B871B5EBDF}: 12021
UNK(i) [13:55:25.616] | Main(id == {8AA98789-C136-4adc-8269-86F3C222906F}, severity == 0, message == ptr(0x16ec0c))
UNK(i) [13:55:25.617] | Main(): exit with severity == DependencyCode(0), message == String("")
PSET(i) [13:55:25.617] | (673.118): Check Dependency for {8AA98789-C136-4adc-8269-86F3C222906F}: 0
PSET(i) [13:55:25.617] | (673.118): Check Dependency for {97BC3C88-834C-11DE-B575-22C956D89593}: 0
PSET(i) [13:55:25.617] | (673.430): InitPlugins(false)
PSET(i) [13:55:25.617] | (673.465): Initialized C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\plugin\distributed_install_detector.dll
UNK(i) [13:55:25.617] | pset::abstract_context(context == pset::ContextInfo(eInstallMode == INSTALL_MODE_COMPLETE, iLog == ptr(0x1563f74), lLocaleID == size_t("1033"), sCurrentArchitecture == String("Intel64"), sLicenseFiles == String(""), sVSPackageNumber == String(""), sPathToLocaleFileFolder == String("C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\1033\"), sSerialNumber == String("")))
UNK(i) [13:55:25.617] | pset::abstract_context() return: deps::Context(mode == INSTALL, silent == bool(false), upfront == bool(false), full == bool(true), locale == int("0"))
UNK(i) [13:55:25.617] | Main(id == {ACD97E2A-090D-46ea-9983-6E44BCA28575}, severity == 0, message == ptr(0x16eca8))
UNK(i) [13:55:25.617] | Main(): Check dependencies
PSET(i) [13:55:25.617] | (673.118): Check Dependency for {ACD97E2A-090D-46ea-9983-6E44BCA28575}: 0
UNK(i) [13:55:25.617] | Main(id == {8AA98789-C136-4adc-8269-86F3C222906F}, severity == 0, message == ptr(0x16eca8))
PSET(i) [13:55:25.618] | (673.118): Check Dependency for {97BC3C88-834C-11DE-B575-22C956D89593}: 0
PSET(i) [13:55:25.618] | (4225.1673):    Checking "C:\Program Files (x86)\Intel\VTune Amplifier XE 2013"...
PSET(i) [13:55:25.618] | (4225.1682):         - CreateFile error = 2
PSET(i) [13:55:25.618] | (4225.1673):    Checking "C:\Program Files (x86)\Intel"...
PSET(i) [13:55:25.619] | (4225.1721):        - Granted Access: 0x12019F; Access Status: 1.
PSET(i) [13:55:25.619] | (4225.1673):    Checking "C:\Program Files (x86)\Intel\VTune Amplifier XE 2013"...
PSET(i) [13:55:25.619] | (4225.1682):         - CreateFile error = 2
PSET(i) [13:55:25.619] | (4225.1673):    Checking "C:\Program Files (x86)\Intel"...
PSET(i) [13:55:25.620] | (4225.1721):        - Granted Access: 0x12019F; Access Status: 1.
PSET(i) [13:55:25.620] | (4225.1673):    Checking "C:\Program Files (x86)\Intel\VTune Amplifier XE 2013"...
PSET(i) [13:55:25.620] | (4225.1682):         - CreateFile error = 2
PSET(i) [13:55:25.620] | (4225.1673):    Checking "C:\Program Files (x86)\Intel"...
PSET(i) [13:55:25.621] | (4225.1721):        - Granted Access: 0x12019F; Access Status: 1.
PSET(i) [13:55:25.621] | (4225.1673):    Checking "C:\Program Files (x86)\Intel\VTune Amplifier XE 2013"...
PSET(i) [13:55:25.621] | (4225.1682):         - CreateFile error = 2
PSET(i) [13:55:25.621] | (4225.1673):    Checking "C:\Program Files (x86)\Intel"...
PSET(i) [13:55:25.622] | (4225.1721):        - Granted Access: 0x12019F; Access Status: 1.
PSET(i) [13:55:25.622] | (4225.1673):    Checking "C:\Program Files (x86)\Intel\VTune Amplifier XE 2013"...
PSET(i) [13:55:25.622] | (4225.1682):         - CreateFile error = 2
PSET(i) [13:55:25.622] | (4225.1673):    Checking "C:\Program Files (x86)\Intel"...
PSET(i) [13:55:25.623] | (4225.1721):        - Granted Access: 0x12019F; Access Status: 1.
PSET(i) [13:55:25.623] | (4225.1673):    Checking "C:\Program Files (x86)\Intel\VTune Amplifier XE 2013"...
PSET(i) [13:55:25.623] | (4225.1682):         - CreateFile error = 2
PSET(i) [13:55:25.623] | (4225.1673):    Checking "C:\Program Files (x86)\Intel"...
UNK(i) [13:55:25.626] |
UNK(i) [13:55:25.626] | pset::abstract_context(context == pset::ContextInfo(eInstallMode == INSTALL_MODE_COMPLETE, iLog == ptr(0x1563f74), lLocaleID == size_t("1033"), sCurrentArchitecture == String("Intel64"), sLicenseFiles == String(""), sVSPackageNumber == String(""), sPathToLocaleFileFolder == String("C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\1033\"), sSerialNumber == String("")))
UNK(i) [13:55:25.626] | pset::abstract_context() return: deps::Context(mode == INSTALL, silent == bool(false), upfront == bool(false), full == bool(true), locale == int("0"))
UNK(i) [13:55:25.626] | Main(id == {ACD97E2A-090D-46ea-9983-6E44BCA28575}, severity == 0, message == ptr(0x16eed0))
UNK(i) [13:55:25.626] | Main(): Check dependencies
UNK(i) [13:55:25.626] | Main(): exit with severity == DependencyCode(0), message == String("")
PSET(i) [13:55:25.626] | (673.118): Check Dependency for {ACD97E2A-090D-46ea-9983-6E44BCA28575}: 0
UNK(i) [13:55:25.626] | Main(id == {8AA98789-C136-4adc-8269-86F3C222906F}, severity == 0, message == ptr(0x16eed0))
PSET(i) [13:55:25.626] | (673.118): Check Dependency for {8AA98789-C136-4adc-8269-86F3C222906F}: 0
PSET(i) [13:55:25.626] | (673.118): Check Dependency for {97BC3C88-834C-11DE-B575-22C956D89593}: 0
UNK(i) [13:55:25.628] |
UNK(i) [13:55:25.628] | pset::abstract_context(context == pset::ContextInfo(eInstallMode == INSTALL_MODE_COMPLETE, iLog == ptr(0x1563f74), lLocaleID == size_t("1033"), sCurrentArchitecture == String("Intel64"), sLicenseFiles == String(""), sVSPackageNumber == String(""), sPathToLocaleFileFolder == String("C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\1033\"), sSerialNumber == String("")))
UNK(i) [13:55:25.628] | pset::abstract_context() return: deps::Context(mode == INSTALL, silent == bool(false), upfront == bool(false), full == bool(true), locale == int("0"))
UNK(i) [13:55:25.628] | Main(id == {ACD97E2A-090D-46ea-9983-6E44BCA28575}, severity == 0, message == ptr(0x16f5c8))
UNK(i) [13:55:25.628] | Main(): Check dependencies
UNK(i) [13:55:25.628] | Main(): exit with severity == DependencyCode(0), message == String("")
PSET(i) [13:55:25.628] | (673.118): Check Dependency for {ACD97E2A-090D-46ea-9983-6E44BCA28575}: 0
UNK(i) [13:55:25.628] | Main(id == {8AA98789-C136-4adc-8269-86F3C222906F}, severity == 0, message == ptr(0x16f5c8))
PSET(i) [13:55:25.628] | (673.118): Check Dependency for {8AA98789-C136-4adc-8269-86F3C222906F}: 0
PSET(i) [13:55:25.629] | (673.118): Check Dependency for {97BC3C88-834C-11DE-B575-22C956D89593}: 0
PSET(i) [13:55:25.631] | (4225.3114): (Package: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\Setup\setup.msi) GetInstallStatus returns ""
PSET(i) [13:55:25.631] | (4225.926):
PSET(i) [13:55:25.631] | (4225.3114): (Package: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\indicator\indicator.msi) GetInstallStatus returns ""
PSET(i) [13:55:25.632] | (4225.3114): (Package: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\ps_he_cli\ps_he_cli.msi) GetInstallStatus returns ""
PSET(i) [13:55:25.632] | (4225.926):
PSET(i) [13:55:25.632] | (4225.3114): (Package: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\ps_he_gui\ps_he_gui.msi) GetInstallStatus returns ""
PSET(i) [13:55:25.633] | (4225.3114): (Package: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\sep\sep.msi) GetInstallStatus returns ""
PSET(i) [13:55:25.633] | (4225.926):
PSET(i) [13:55:25.633] | (4225.3114): (Package: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\dim\distributed_install.msi) GetInstallStatus returns "INSTALLS=1.0,1.7,PSHECLI,CmpGui,1.6,1.12,1.8,1.9 "
PSET(i) [13:55:25.633] | (4225.3114): (Package: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\msvcrt_x86.msi) GetInstallStatus returns ""
PSET(i) [13:55:25.634] | (4225.926):
PSET(i) [13:55:25.634] | (4225.3114): (Package: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\msvcrt_x64.msi) GetInstallStatus returns ""
PSET(i) [13:55:25.634] | (4225.3114): (Package: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\ism\ism.msi) GetInstallStatus returns ""
PSET(i) [13:55:26.984] | (4225.3114): (Package: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\Setup\setup.msi) GetInstallStatus returns ""
PSET(i) [13:55:26.984] | (4225.926):
PSET(i) [13:55:26.985] | (4225.3114): (Package: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\indicator\indicator.msi) GetInstallStatus returns ""
PSET(i) [13:55:26.985] | (4225.926):
PSET(i) [13:55:26.985] | (4225.3114): (Package: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\ps_he_cli\ps_he_cli.msi) GetInstallStatus returns ""
PSET(i) [13:55:26.986] | (4225.3114): (Package: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\ps_he_gui\ps_he_gui.msi) GetInstallStatus returns ""
PSET(i) [13:55:26.986] | (4225.926):
PSET(i) [13:55:26.987] | (4225.3114): (Package: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\sep\sep.msi) GetInstallStatus returns ""
PSET(i) [13:55:26.987] | (4225.926):
PSET(i) [13:55:26.988] | (4225.3114): (Package: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\dim\distributed_install.msi) GetInstallStatus returns "INSTALLS=1.0,1.7,PSHECLI,CmpGui,1.6,1.12,1.8,1.9 "
PSET(i) [13:55:26.988] | (4225.926):
PSET(i) [13:55:26.988] | (4225.3114): (Package: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\msvcrt_x86.msi) GetInstallStatus returns ""
PSET(i) [13:55:26.989] | (4225.3114): (Package: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\msvcrt_x64.msi) GetInstallStatus returns ""
PSET(i) [13:55:26.989] | (4225.926):
PSET(i) [13:55:26.990] | (4225.3114): (Package: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\ism\ism.msi) GetInstallStatus returns ""
PSET(i) [13:55:26.990] | (4225.926):
PSET(i) [13:55:26.991] | (4225.3114): (Package: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\Setup\setup.msi) GetInstallStatus returns ""
PSET(i) [13:55:26.991] | (4225.926):
PSET(i) [13:55:26.991] | (4225.3114): (Package: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\indicator\indicator.msi) GetInstallStatus returns ""
PSET(i) [13:55:26.992] | (4225.3114): (Package: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\ps_he_cli\ps_he_cli.msi) GetInstallStatus returns ""
PSET(i) [13:55:26.992] | (4225.926):
PSET(i) [13:55:26.992] | (4225.3114): (Package: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\ps_he_gui\ps_he_gui.msi) GetInstallStatus returns ""
PSET(i) [13:55:26.992] | (4225.3114): (Package: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\sep\sep.msi) GetInstallStatus returns ""
PSET(i) [13:55:26.993] | (4225.3114): (Package: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\dim\distributed_install.msi) GetInstallStatus returns "INSTALLS=1.0,1.7,PSHECLI,CmpGui,1.6,1.12,1.8,1.9 "
PSET(i) [13:55:26.993] | (4225.926):
PSET(i) [13:55:26.993] | (4225.3114): (Package: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\msvcrt_x86.msi) GetInstallStatus returns ""
PSET(i) [13:55:26.994] | (4225.3114): (Package: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\msvcrt_x64.msi) GetInstallStatus returns ""
PSET(i) [13:55:26.994] | (4225.926):
PSET(i) [13:55:26.994] | (4225.3114): (Package: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\ism\ism.msi) GetInstallStatus returns ""
PSET(i) [13:55:26.994] | (4225.4036): InstallState from: GetUninstallsForMajorUpgrade = 3
PSET(i) [13:55:26.995] | (4225.788): INSTALLDIR="C:\Program Files (x86)\Intel\VTune Amplifier XE 2013\"
PSET(i) [13:55:26.995] | (4225.3114): (Package: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\Setup\setup.msi) GetInstallStatus returns ""
PSET(i) [13:55:26.995] | (4225.926):
PSET(i) [13:55:26.995] | (4225.3114): (Package: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\indicator\indicator.msi) GetInstallStatus returns ""
PSET(i) [13:55:26.996] | (4225.788): INSTALLDIR="C:\Program Files (x86)\Intel\VTune Amplifier XE 2013\"
PSET(i) [13:55:26.996] | (4225.3114): (Package: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\ps_he_cli\ps_he_cli.msi) GetInstallStatus returns ""
PSET(i) [13:55:26.996] | (4225.926):
PSET(i) [13:55:26.996] | (4225.3114): (Package: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\ps_he_gui\ps_he_gui.msi) GetInstallStatus returns ""
PSET(i) [13:55:26.997] | (4225.788): INSTALLDIR="C:\Program Files (x86)\Intel\VTune Amplifier XE 2013\"
PSET(i) [13:55:26.997] | (4225.3114): (Package: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\sep\sep.msi) GetInstallStatus returns ""
PSET(i) [13:55:26.997] | (4225.926):
PSET(i) [13:55:26.997] | (4225.3114): (Package: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\dim\distributed_install.msi) GetInstallStatus returns "INSTALLS=1.0,1.7,PSHECLI,CmpGui,1.6,1.12,1.8,1.9 "
PSET(i) [13:55:26.998] | (4225.788): INSTALLDIR="C:\Program Files (x86)\Intel\VTune Amplifier XE 2013\"
PSET(i) [13:55:26.998] | (4225.3114): (Package: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\msvcrt_x86.msi) GetInstallStatus returns ""
PSET(i) [13:55:26.998] | (4225.926):
PSET(i) [13:55:26.998] | (4225.3114): (Package: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\msvcrt_x64.msi) GetInstallStatus returns ""
PSET(i) [13:55:26.999] | (4225.788): INSTALLDIR="C:\Program Files (x86)\Intel\VTune Amplifier XE 2013\"
PSET(i) [13:55:26.999] | (4225.3114): (Package: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\ism\ism.msi) GetInstallStatus returns ""
PSET(i) [13:55:26.999] | (4225.926):
PSET(i) [13:55:26.999] | (3073.1111):
PSET(i) [13:55:26.999] | (3073.1114): PackageName: Setup
PSET(i) [13:55:26.999] | (3073.1116): PackageFile: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\Setup\setup.msi
PSET(i) [13:55:26.999] | (3073.1118): CommandLine: INSTALLDIR="C:\Program Files (x86)\Intel\VTune Amplifier XE 2013\" BASEINSTALLDIR="C:\Program Files (x86)\Intel\" ARPNAME="Intel VTune Amplifier XE 2013" ADDLOCAL=CoreAppFiles EXTERNALUI=PSET TOTAL_COST=328853 PSETSETUP="C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\setup.exe" PSET_UI_MODE=Full PSET_INSTALL_MODE=Install EVAL=0
PSET(i) [13:55:26.999] | (3073.1139): Install C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\Setup\setup.msi INSTALLDIR="C:\Program Files (x86)\Intel\VTune Amplifier XE 2013\" BASEINSTALLDIR="C:\Program Files (x86)\Intel\" ARPNAME="Intel VTune Amplifier XE 2013" ADDLOCAL=CoreAppFiles EXTERNALUI=PSET TOTAL_COST=328853 PSETSETUP="C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\setup.exe" PSET_UI_MODE=Full PSET_INSTALL_MODE=Install EVAL=0
PSET(i) [13:55:26.999] | (3073.1167): MsiInstallProduct(C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\Setup\setup.msi, INSTALLDIR="C:\Program Files (x86)\Intel\VTune Amplifier XE 2013\" BASEINSTALLDIR="C:\Program Files (x86)\Intel\" ARPNAME="Intel VTune Amplifier XE 2013" ADDLOCAL=CoreAppFiles EXTERNALUI=PSET TOTAL_COST=328853 PSETSETUP="C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\setup.exe" PSET_UI_MODE=Full PSET_INSTALL_MODE=Install EVAL=0) ...
PSET(i) [13:55:28.432] | (3073.1111):
PSET(i) [13:55:28.432] | (3073.1114): PackageName: Amplifier XE Indicator
PSET(i) [13:55:28.432] | (3073.1116): PackageFile: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\indicator\indicator.msi
PSET(i) [13:55:28.432] | (3073.1118): CommandLine: INSTALLDIR="C:\Program Files (x86)\Intel\VTune Amplifier XE 2013\" BASEINSTALLDIR="C:\Program Files (x86)\Intel\" ADDLOCAL=CoreAppFiles EXTERNALUI=PSET TOTAL_COST=328853 PSETSETUP="C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\setup.exe" PSET_UI_MODE=Full PSET_INSTALL_MODE=Install EVAL=0
PSET(i) [13:55:28.432] | (3073.1139): Install C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\indicator\indicator.msi INSTALLDIR="C:\Program Files (x86)\Intel\VTune Amplifier XE 2013\" BASEINSTALLDIR="C:\Program Files (x86)\Intel\" ADDLOCAL=CoreAppFiles EXTERNALUI=PSET TOTAL_COST=328853 PSETSETUP="C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\setup.exe" PSET_UI_MODE=Full PSET_INSTALL_MODE=Install EVAL=0
PSET(i) [13:55:28.432] | (3073.1167): MsiInstallProduct(C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\indicator\indicator.msi, INSTALLDIR="C:\Program Files (x86)\Intel\VTune Amplifier XE 2013\" BASEINSTALLDIR="C:\Program Files (x86)\Intel\" ADDLOCAL=CoreAppFiles EXTERNALUI=PSET TOTAL_COST=328853 PSETSETUP="C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\setup.exe" PSET_UI_MODE=Full PSET_INSTALL_MODE=Install EVAL=0) ...
PSET(i) [13:55:29.375] | (3073.1111):
PSET(i) [13:55:29.375] | (3073.1114): PackageName: Command-line interface
PSET(i) [13:55:29.375] | (3073.1116): PackageFile: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\ps_he_cli\ps_he_cli.msi
PSET(i) [13:55:29.375] | (3073.1118): CommandLine: INSTALLDIR="C:\Program Files (x86)\Intel\VTune Amplifier XE 2013\" BASEINSTALLDIR="C:\Program Files (x86)\Intel\" ADDLOCAL=CoreAppFiles64,SEPFeature,CoreAppFiles EXTERNALUI=PSET TOTAL_COST=328853 PSETSETUP="C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\setup.exe" PSET_UI_MODE=Full PSET_INSTALL_MODE=Install EVAL=0
PSET(i) [13:55:29.375] | (3073.1139): Install C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\ps_he_cli\ps_he_cli.msi INSTALLDIR="C:\Program Files (x86)\Intel\VTune Amplifier XE 2013\" BASEINSTALLDIR="C:\Program Files (x86)\Intel\" ADDLOCAL=CoreAppFiles64,SEPFeature,CoreAppFiles EXTERNALUI=PSET TOTAL_COST=328853 PSETSETUP="C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\setup.exe" PSET_UI_MODE=Full PSET_INSTALL_MODE=Install EVAL=0
PSET(i) [13:55:29.376] | (3073.1167): MsiInstallProduct(C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\ps_he_cli\ps_he_cli.msi, INSTALLDIR="C:\Program Files (x86)\Intel\VTune Amplifier XE 2013\" BASEINSTALLDIR="C:\Program Files (x86)\Intel\" ADDLOCAL=CoreAppFiles64,SEPFeature,CoreAppFiles EXTERNALUI=PSET TOTAL_COST=328853 PSETSETUP="C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\setup.exe" PSET_UI_MODE=Full PSET_INSTALL_MODE=Install EVAL=0) ...
PSET(i) [13:55:52.110] | (3073.1111):
PSET(i) [13:55:52.110] | (3073.1114): PackageName: Graphical user interface
PSET(i) [13:55:52.110] | (3073.1116): PackageFile: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\ps_he_gui\ps_he_gui.msi
PSET(i) [13:55:52.110] | (3073.1118): CommandLine: INSTALLDIR="C:\Program Files (x86)\Intel\VTune Amplifier XE 2013\" BASEINSTALLDIR="C:\Program Files (x86)\Intel\" ADDLOCAL=CoreAppFiles64,CoreAppFiles EXTERNALUI=PSET TOTAL_COST=328853 PSETSETUP="C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\setup.exe" PSET_UI_MODE=Full PSET_INSTALL_MODE=Install EVAL=0
PSET(i) [13:55:52.110] | (3073.1139): Install C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\ps_he_gui\ps_he_gui.msi INSTALLDIR="C:\Program Files (x86)\Intel\VTune Amplifier XE 2013\" BASEINSTALLDIR="C:\Program Files (x86)\Intel\" ADDLOCAL=CoreAppFiles64,CoreAppFiles EXTERNALUI=PSET TOTAL_COST=328853 PSETSETUP="C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\setup.exe" PSET_UI_MODE=Full PSET_INSTALL_MODE=Install EVAL=0
PSET(i) [13:55:52.110] | (3073.1167): MsiInstallProduct(C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\ps_he_gui\ps_he_gui.msi, INSTALLDIR="C:\Program Files (x86)\Intel\VTune Amplifier XE 2013\" BASEINSTALLDIR="C:\Program Files (x86)\Intel\" ADDLOCAL=CoreAppFiles64,CoreAppFiles EXTERNALUI=PSET TOTAL_COST=328853 PSETSETUP="C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\setup.exe" PSET_UI_MODE=Full PSET_INSTALL_MODE=Install EVAL=0) ...
PSET(i) [13:55:59.396] | (3073.1111):
PSET(i) [13:55:59.396] | (3073.1114): PackageName: Event-based sampling driver
PSET(i) [13:55:59.396] | (3073.1116): PackageFile: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\sep\sep.msi
PSET(i) [13:55:59.396] | (3073.1118): CommandLine: INSTALLDIR="C:\Program Files (x86)\Intel\VTune Amplifier XE 2013\" BASEINSTALLDIR="C:\Program Files (x86)\Intel\" ADDLOCAL=CoreAppFiles EXTERNALUI=PSET TOTAL_COST=328853 PSETSETUP="C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\setup.exe" PSET_UI_MODE=Full PSET_INSTALL_MODE=Install EVAL=0
PSET(i) [13:55:59.396] | (3073.1139): Install C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\sep\sep.msi INSTALLDIR="C:\Program Files (x86)\Intel\VTune Amplifier XE 2013\" BASEINSTALLDIR="C:\Program Files (x86)\Intel\" ADDLOCAL=CoreAppFiles EXTERNALUI=PSET TOTAL_COST=328853 PSETSETUP="C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\setup.exe" PSET_UI_MODE=Full PSET_INSTALL_MODE=Install EVAL=0
PSET(i) [13:55:59.397] | (3073.1167): MsiInstallProduct(C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\sep\sep.msi, INSTALLDIR="C:\Program Files (x86)\Intel\VTune Amplifier XE 2013\" BASEINSTALLDIR="C:\Program Files (x86)\Intel\" ADDLOCAL=CoreAppFiles EXTERNALUI=PSET TOTAL_COST=328853 PSETSETUP="C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\setup.exe" PSET_UI_MODE=Full PSET_INSTALL_MODE=Install EVAL=0) ...
PSET(i) [13:56:01.830] | (3073.1111):
PSET(i) [13:56:01.830] | (3073.1114): PackageName: Distributed Install
PSET(i) [13:56:01.830] | (3073.1116): PackageFile: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\dim\distributed_install.msi
PSET(i) [13:56:01.830] | (3073.1118): CommandLine: INSTALLDIR="C:\Program Files (x86)\Intel\VTune Amplifier XE 2013\" BASEINSTALLDIR="C:\Program Files (x86)\Intel\" INSTALLS=1.0,1.7,PSHECLI,CmpGui,1.6,1.12,1.8,1.9 ADDLOCAL=FlexLMCheck EXTERNALUI=PSET TOTAL_COST=328853 PSETSETUP="C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\setup.exe" PSET_UI_MODE=Full PSET_INSTALL_MODE=Install EVAL=0
PSET(i) [13:56:01.830] | (3073.1139): Install C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\dim\distributed_install.msi INSTALLDIR="C:\Program Files (x86)\Intel\VTune Amplifier XE 2013\" BASEINSTALLDIR="C:\Program Files (x86)\Intel\" INSTALLS=1.0,1.7,PSHECLI,CmpGui,1.6,1.12,1.8,1.9 ADDLOCAL=FlexLMCheck EXTERNALUI=PSET TOTAL_COST=328853 PSETSETUP="C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\setup.exe" PSET_UI_MODE=Full PSET_INSTALL_MODE=Install EVAL=0
PSET(i) [13:56:01.830] | (3073.1167): MsiInstallProduct(C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\dim\distributed_install.msi, INSTALLDIR="C:\Program Files (x86)\Intel\VTune Amplifier XE 2013\" BASEINSTALLDIR="C:\Program Files (x86)\Intel\" INSTALLS=1.0,1.7,PSHECLI,CmpGui,1.6,1.12,1.8,1.9 ADDLOCAL=FlexLMCheck EXTERNALUI=PSET TOTAL_COST=328853 PSETSETUP="C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\setup.exe" PSET_UI_MODE=Full PSET_INSTALL_MODE=Install EVAL=0) ...
PSET(i) [13:56:03.771] | (3073.1111):
PSET(i) [13:56:03.771] | (3073.1114): PackageName: Microsoft* Visual C++ Runtime Libraries for x86.
PSET(i) [13:56:03.771] | (3073.1116): PackageFile: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\msvcrt_x86.msi
PSET(i) [13:56:03.771] | (3073.1118): CommandLine: INSTALLDIR="C:\Program Files (x86)\Intel\VTune Amplifier XE 2013\" BASEINSTALLDIR="C:\Program Files (x86)\Intel\" ADDLOCAL=Core,MS_Runtime_8_0,MS_Runtime_9_0,MS_Runtime_10_0 EXTERNALUI=PSET TOTAL_COST=328853 PSETSETUP="C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\setup.exe" PSET_UI_MODE=Full PSET_INSTALL_MODE=Install EVAL=0
PSET(i) [13:56:03.771] | (3073.1139): Install C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\msvcrt_x86.msi INSTALLDIR="C:\Program Files (x86)\Intel\VTune Amplifier XE 2013\" BASEINSTALLDIR="C:\Program Files (x86)\Intel\" ADDLOCAL=Core,MS_Runtime_8_0,MS_Runtime_9_0,MS_Runtime_10_0 EXTERNALUI=PSET TOTAL_COST=328853 PSETSETUP="C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\setup.exe" PSET_UI_MODE=Full PSET_INSTALL_MODE=Install EVAL=0
PSET(i) [13:56:03.771] | (3073.1167): MsiInstallProduct(C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\msvcrt_x86.msi, INSTALLDIR="C:\Program Files (x86)\Intel\VTune Amplifier XE 2013\" BASEINSTALLDIR="C:\Program Files (x86)\Intel\" ADDLOCAL=Core,MS_Runtime_8_0,MS_Runtime_9_0,MS_Runtime_10_0 EXTERNALUI=PSET TOTAL_COST=328853 PSETSETUP="C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\setup.exe" PSET_UI_MODE=Full PSET_INSTALL_MODE=Install EVAL=0) ...
PSET(i) [13:56:05.104] | (3073.1111):
PSET(i) [13:56:05.104] | (3073.1114): PackageName: Microsoft* Visual C++ Runtime Libraries for x64.
PSET(i) [13:56:05.104] | (3073.1116): PackageFile: C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\msvcrt_x64.msi
PSET(i) [13:56:05.104] | (3073.1118): CommandLine: INSTALLDIR="C:\Program Files (x86)\Intel\VTune Amplifier XE 2013\" BASEINSTALLDIR="C:\Program Files (x86)\Intel\" ADDLOCAL=Core,MS_Runtime_8_0,MS_Runtime_9_0,MS_Runtime_10_0 EXTERNALUI=PSET TOTAL_COST=328853 PSETSETUP="C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\setup.exe" PSET_UI_MODE=Full PSET_INSTALL_MODE=Install EVAL=0
PSET(i) [13:56:05.104] | (3073.1139): Install C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\msvcrt_x64.msi INSTALLDIR="C:\Program Files (x86)\Intel\VTune Amplifier XE 2013\" BASEINSTALLDIR="C:\Program Files (x86)\Intel\" ADDLOCAL=Core,MS_Runtime_8_0,MS_Runtime_9_0,MS_Runtime_10_0 EXTERNALUI=PSET TOTAL_COST=328853 PSETSETUP="C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\setup.exe" PSET_UI_MODE=Full PSET_INSTALL_MODE=Install EVAL=0
PSET(i) [13:56:05.104] | (3073.1167): MsiInstallProduct(C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\msvcrt_x64.msi, INSTALLDIR="C:\Program Files (x86)\Intel\VTune Amplifier XE 2013\" BASEINSTALLDIR="C:\Program Files (x86)\Intel\" ADDLOCAL=Core,MS_Runtime_8_0,MS_Runtime_9_0,MS_Runtime_10_0 EXTERNALUI=PSET TOTAL_COST=328853 PSETSETUP="C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\setup.exe" PSET_UI_MODE=Full PSET_INSTALL_MODE=Install EVAL=0) ...
PSET(i) [13:56:25.987] | (3073.1972): MsiInstallProduct(C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\msvcrt_x86.msi, REMOVE=ALL) ...
PSET(i) [13:56:26.637] | (3073.1972): MsiInstallProduct(C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\sep\sep.msi, REMOVE=ALL) ...
PSET(i) [13:56:27.422] | (3073.1972): MsiInstallProduct(C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\ps_he_gui\ps_he_gui.msi, REMOVE=ALL) ...
PSET(i) [13:56:29.641] | (3073.1972): MsiInstallProduct(C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\ps_he_cli\ps_he_cli.msi, REMOVE=ALL) ...
PSET(i) [13:56:41.870] | (3073.1972): MsiInstallProduct(C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\indicator\indicator.msi, REMOVE=ALL) ...
PSET(i) [13:56:42.949] | (3073.1972): MsiInstallProduct(C:\Program Files (x86)\Intel\Download\VTune_Amplifier_XE_2013_setup\Installs\Setup\setup.msi, REMOVE=ALL) ...
ISSA(i) [13:56:43.876] | (5265.1045): RegCenterAdapter: hmac_hash(): calculated
ISSA(i) [13:56:43.876] | (5265.410): RegCenterAdapter::RecordLicenseInstallData3() - 0000-00000000:BL5:w:        Intel(R) Core(TM) i3-2120 CPU @ 3.30GHz::feature_disabled:62YP::w:INTEL64:ESD:Intel VTune Amplifier XE 2013:::Intel VTune Amplifier XE 2013 - 13.1.5000.243421;:SINGLE:NONEVAL:INT
Ekaterina_L_Intel
Hi Stephanie,
Could You please check against the possible reasons listed below and let know if it helps to your case?
Katya
Bernard
Valued Contributor I
@Ekaterina-logovskaya
>>>UNK(i) [13:55:25.626] | Main(): exit with severity == DependencyCode(0), message == String("")>>>
Could that message point to the reason for failed installation?
