- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
I need help working through the steps getting VTune 2.0 installed. I must say I'm surprised at the age of the release and documents, elsewhere saw a note by jdg dated 5/21/04 saying to expect v3.0 with support for RedHatEL3.0 in about amonth... from then ! My CD is v 2.0.348 dated 12/3/03. Looked under Files Download, only see patches that require installation of 2.0 first.
Anyway, here's what all I have. Any pointers and tips much appreciated !
-rajeev-
Rajeev Rohatgi
Enter 'accept' to continue, 'reject' to exit:accept
Unpacking files ...
The current distribution of Linux on this system is Red Hat Enterprise Linux WS release 3 (Taroon)
This platform is not supported by the product.
The VTune Analyzer 2.0 for Linux* was validated on Red Hat* Linux* 7.2, 7.3, Advanced Server 2.1,
SuSE* 8.1, 8.2, 9.0 and SLES 8.0.
This system configuration doesn't meet the requirements for the VTune Analyzer 2.0 for Linux*.
The VTune Analyzer 2.0 for Linux* may not work on this system or may generate wrong results.
Refer to the release notes for more information.
Proceed with the install? (Yes/No) [Yes] :
My system reports:
[root@daq-ts02 vt_cli_2.0.348]# cat /proc/version
Linux version 2.4.21-4.ELsmp (bhcompile@daffy.perf.redhat.com) (gcc version 3.2.3 20030502 (Red Hat Linux 3.2.3-20)) #1 SMP Fri Oct 3 17:52:56 EDT 2003
My system reports:
[root@daq-ts02 vt_cli_2.0.348]# rpm -q glibc
glibc-2.3.2-95.3
glibc-2.3.2-95.3
libstdc++ version 2.96, 2.95, 3.2, 3.3, or 3.3.1 is required. Please install it and run the installer again.
On my system I have
[root@daq-ts02 vt_cli_2.0.348]# echo $LD_LIBRARY_PATH
/usr/lib
On my system I have
/usr/lib
[root@daq-ts02 vt_cli_2.0.348]# ls /usr/lib/libstdc*
/usr/lib/libstdc++-2-libc6.1-1-2.9.0.so /usr/lib/libstdc++-libc6.2-2.so.3 /usr/lib/libstdc++.so.2.9
/usr/lib/libstdc++-3-libc6.2-2-2.10.0.a /usr/lib/libstdc++.so.2.7.2 /usr/lib/libstdc++.so.2.9.dummy
/usr/lib/libstdc++-3-libc6.2-2-2.10.0.so /usr/lib/libstdc++.so.2.7.2.8 /usr/lib/libstdc++.so.5
/usr/lib/libstdc++-libc6.1-1.so.2 /usr/lib/libstdc++.so.2.8 /usr/lib/libstdc++.so.5.0.3
/usr/lib/libstdc++-libc6.2-2.a.3 /usr/lib/libstdc++.so.2.8.0
Note: Options shown in brackets "[ ... ]" signify defaults
that will be used when only the ENTER key is pressed.
VTune Performance Analyzer 2.0 for Linux* is being installed...
The install destination has been set to /opt/intel/vtune
Registering VTune Performance Analyzer files, please wait...
Failed to load library /opt/intel/vtune/shared/bin/libWorkspaceMgrps.so
Failed to load library /opt/intel/vtune/shared/bin/libPropBag.so
Failed to load library /opt/intel/vtune/shared/bin/ libComInfops.so
Failed to load library /opt/intel/vtune/shared/bin/libDataObjectps.so
Failed to load library /opt/intel/vtune/shared/bin/libFileCopier.so
Failed to load library /opt/intel/vtune/shared/bin/libVTRunps.so
Failed to load library /opt/intel/vtune/shared/bin/libActivity.so
Failed to load library /opt/intel/vtune/shared/bin/libFileCopierps.so
Failed to load library /opt/intel/vtune/shared/bin/libActivityps.so
Failed to load library /opt/intel/vtune/shared/bin/libCollection.so
Failed to load library /opt/intel/vtune/shared/bin/libRunCfg.so
Failed to load library /opt/intel/vtune/shared/bin/libVTRun.so
Failed to load library /opt/intel/vtune/shared/bin/libEnvInfops.so
Failed to load library /opt/intel/vtune/shared/bin/libShellTLB.so
Failed to load library /opt/intel/vtune/shared/bin/libActivityHps.so
Failed to load library /opt/intel/vtune/shared/bin/libStandardExeCtrl.so
Failed to load library /opt/intel/vtune/shared/bin/libShellps.so
Failed to load library /opt/intel/vtune/shared/bin/libReports.so
Failed to load library /opt/intel/vtune/shared/bin/libFileMgr.so
Failed to load library /opt/intel/vtune/shared/bin/libDataObject.so
Failed to load library /opt/intel/vtune/shared/bin/libShell.so
Failed to load library /opt/intel/vtune/shared/bin/libvtlHandlers.so
Failed to load library /opt/intel/vtune/shared/bin/libProductInfo.so
Failed to load library /opt/intel/vtune/shared/bin/libComInfo.so
Failed to load library /opt/intel/vtune/shared/bin/libRunCfgps.so
Failed to load library /opt/intel/vtune/shared/bin/libEnvInfo.so
Failed to load library /opt/intel/vtune/shared/bin/libWorkspaceMgr.so
Failed to load library /opt/intel/vtune/shared/bin/libReportsps.so
1 Error: NTD is not running at the moment, please start it before using NT services.
I don't have a clue about this.
error: %post(intel-vtune-cli-shell-2.0p-341) scriptlet failed, exit status 2
Note: To uninstall the VTune Performance Analyzer 2.0 for Linux*
components please run "/opt/intel/vtune/bin/uninstall_cli.sh" file.
-end-링크가 복사됨
3 응답
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Sorry for the confusion Rajeev!
Hands down, you should be working with vtl 3.0 at this point, which is a very very mature beta product, with general availability due in DEC 2004.
Here's where you register for it (fast and free):
http://www.intel.com/software/products/vtune/beta/vt_pa_linux_beta_external.htm
1) you should uninstall any partial installs of vtl before installing the beta
2) After you register at the above URL, you'll receive a confirmation email with an attached beta software license and detailed download instructions
3) that license is good until the end of DEC 2004, so you can really get the chance to kick the tires before having to make a purchase decision
ALSO, by downloading the beta you gain access to Intel's Premier Suport website, for any issues you may bump into.
cheers
jdg
Message Edited by jdgallag on 10-12-2004 03:05 PM
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Thanks, jdg.
3.0.016 Build 620 is now successfully installed. Now I have to learn to use it ! (I printed out some docs and downloaded a course from the software college.)
-rajeev-
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
CONGRATs, rajeev. Some of my favorite reading:
USER GUIDE, the sections called QUICK START (one for callgraph, one for sampling)
Bring up a browser, and load this file:
/opt/intel/vtune/doc/users_guide/index.htm
also, these man pages:
$ man vtl
$ man vtlec
$ man sampling
$ man callgraph
$ man 7 source
$ man ActivityController (note upper case A and C)
The reference manual is a good encyclopedia of processor events: you may want to kick the tires on reading that soon after you dig in:
/opt/intel/vtune/docs/reference/index.htm
cheers
jdg
