Analyzers
Installation error -- VTune XE 2013
Amit_P_1
While installing a Demo copy of the Vtune XE 2013 (Update 10) on my Windows 7 (32-bit) laptop, I am getting the following error during the installation :
   " An error occured during the installation of assembly component {xxxxxxx Some GUID}. HRESULT: 0x80073712"
  Have attached a doc file which contains the screen shots of the error messages.Appreciate if someone can point me in the right direction on how to resolve the installation issues.
David_A_Intel1
Hi Amit:
The last screen shot shows a link to an error log.  Did you find an error log?
Amit_P_1
  Thanks for the response. Attached is the error log from the installation.
   -Amit
Peter_W_Intel
Please click on the installer and run it as administrator. Also please note that you have to uninstall old product successfully then install the new update. For further investigating, the problem might be caused by.NET issue when installing the tool - it is not Vtune Amplifier XE issue, based on error message "An error occurred during the installation of assembly component", see http://turbotax.intuit.com/support/iq/Install-Product/Error-1935--An-error-occurred-during-the-installation-of-assembly/SLN12416.html to know detail. Hope it helps.
Bernard
Valued Contributor I
IIRC the error seen by you is related to ERROR_SXS_COMPONENT_STORE_CORRUPT and it is probably caused by corrupted SxS assemblies.
GUID is probably the one which is corrupted.
SergeyKostrov
Valued Contributor II
>>...While installing a Demo copy of the Vtune XE 2013 (Update 10) on my Windows 7 (32-bit) laptop, I am getting the following >>error during the installation : >> >>" An error occured during the installation of assembly component {xxxxxxx Some GUID}. HRESULT: 0x80073712" Try to install Initial Release of VTune first followed by Update 10. Also, turn off Microsoft Windows Update during installs.
Peter_W_Intel
Developer said, this installation problem has been fixed in Update 15.
Shyam_P_
I am trying to install trial version of vtune 2015. Installation failed with following errors. Failure log file is attached. Can anyone help me?
Shyam
Each component will be installed individually. If you cancel the installation,
some components might remain on your system. This installation may take several
minutes, depending on your system and the options you selected.
Installing Command line interface component... failed
Installing Sampling Driver kit component... failed
Installing Graphical user interface component... failed
Finalizing product configuration...
Preparing driver configuration scripts... done
TimP
Do you agree with comments in the log, such as:
previous VTune version was removed successfully
no space available in temporary allocation (e.g. /tmp)
your OS is not one for which a pre-built driver is furnished, so the build-driver script has to run
is your OS one of those designated as supported (is it a 32-bit linux)
Peter_W_Intel
@Shyam
Based on information, probably you have uninstalled prior product abnormally  - however installer of VTune Amplifier XE 2015 can detect it but uninstaller cannot uninstall these components which might be removed manually.
You can clean up prior product in these way, then re-install new product.:
1. lsmod grep [sep | pax | vtss]; use "rmmod ???" to remove them from your system.
2. rpm -qa intel-vtune*; remove them in order, according dependencies
Others, please pay attentions on what Tim pointed out.
