Analyzers
5320 Discussions
Installation via apt failed
Gladyshev_mv
After I try to install oneapi like this instruction https://www.intel.com/content/www/us/en/developer/tools/oneapi/vtune-profiler-download.html?operatingsystem=linux&linux-install-type=apt
I got this error:
o unpack .../intel-oneapi-vtune_2024.3.0-29_amd64.deb ...
Warning:  no socwatch driver was found loaded in the kernel.
Using C compiler = gcc
Using kernel build dir = /lib/modules/6.8.2-rt11/build
No module symvers file found
Using common inc dir = /opt/intel/oneapi/vtune/2024.3/sepdk/src/socwatch/socwatch_driver/../common/include
Using file name sw_driver
Make args = KERNEL_SRC_DIR=/lib/modules/6.8.2-rt11/build CPUFREQ_FIX_BACKPORTED=0 CLASSCREATE_CHANGE_BACKPORTED=0 DO_DEBUG_BUILD=0 DO_PROFILING=0 COMMON_INC_DIR=/opt/intel/oneapi/vtune
/2024.3/sepdk/src/socwatch/socwatch_driver/../common/include MODULE_SYMVERS_FILE= FILE_NAME=sw_driver
make -C /lib/modules/6.8.2-rt11/build M=/opt/intel/oneapi/vtune/2024.3/sepdk/src/socwatch/socwatch_driver clean
make[1]: *** /lib/modules/6.8.2-rt11/build: No such file or directory.  Stop.
make: *** [Makefile:122: clean] Error 2
Warning:  no vtsspp driver was found loaded in the kernel.
  CLEAN   /opt/intel/oneapi/vtune/2024.3/sepdk/src/vtsspp
Warning:  the following driver(s) were not found loaded in the kernel:  sep5.
Warning: skipping SOCWATCH driver unload, not built
Warning:  the following driver(s) were not found loaded in the kernel:  socperf3.
The PAX service is not loaded anymore.
No previously installed pax driver boot script was found.
Stop and disable sep5.service ...
Removed "/etc/systemd/system/multi-user.target.wants/sep5.service".
done.
grep: /lib/modules/6.8.2-rt11/build/include/linux/device/class.h: No such file or directory
rm -f sep5*.ko
make[1]: Entering directory '/opt/intel/oneapi/vtune/2024.3/sepdk/src/pax'
rm -f *.o .*.o.cmd .*.o.d .*.ko.cmd .*.ko.unsigned.cmd *.gcno .cache.mk *.o.ur-safe .*.o.tmp *.mod .*.mod.cmd
rm -f pax.ko pax.ko.unsigned pax-x32_64-6.8.2-rt11smp.ko
rm -f Module.symvers Modules.symvers *.mod.c modules.order Module.markers .modules.order.cmd .Module.symvers.cmd
rm -rf .tmp_versions
rm -f pax*.ko
make[1]: Leaving directory '/opt/intel/oneapi/vtune/2024.3/sepdk/src/pax'
make[1]: Entering directory '/opt/intel/oneapi/vtune/2024.3/sepdk/src/socperf/src'
rm -f socperf3.ko socperf3.ko.unsigned
rm -f socperf3*x32_64-6.8.2-rt11smp.ko
rm -f socperf3*.ko
make[1]: Leaving directory '/opt/intel/oneapi/vtune/2024.3/sepdk/src/socperf/src'
Unpacking intel-oneapi-vtune (2024.3.0-29) over (2024.3.0-29) ...
Setting up intel-oneapi-vtune (2024.3.0-29) ...
C compiler version: 13.2.0
Make version: 4.3
Kernel version: 6.8.2
Cleaning workspaces ...
Done
Building socperf driver ...
Done
Building sep driver ...
/opt/intel/oneapi/vtune/2024.3/sepdk/src/sys64.o: warning: objtool: .text+0x35: unreachable instruction
/opt/intel/oneapi/vtune/2024.3/sepdk/src/sys64.o: warning: objtool: .text+0x36: unreachable instruction
/opt/intel/oneapi/vtune/2024.3/sepdk/src/sys64.o: warning: objtool: .text+0x37: unreachable instruction
/opt/intel/oneapi/vtune/2024.3/sepdk/src/sys64.o: warning: objtool: .text+0x3b: unreachable instruction
/opt/intel/oneapi/vtune/2024.3/sepdk/src/sys64.o: warning: objtool: .text+0x40: unreachable instruction
/opt/intel/oneapi/vtune/2024.3/sepdk/src/sys64.o: warning: objtool: .text+0x45: unreachable instruction
/opt/intel/oneapi/vtune/2024.3/sepdk/src/sys64.o: warning: objtool: .text+0x4a: unreachable instruction
/opt/intel/oneapi/vtune/2024.3/sepdk/src/sys64.o: warning: objtool: .text+0x4f: unreachable instruction
/opt/intel/oneapi/vtune/2024.3/sepdk/src/sys64.o: warning: objtool: .text+0x54: unreachable instruction
/opt/intel/oneapi/vtune/2024.3/sepdk/src/sys64.o: warning: objtool: .text+0x59: unreachable instruction
/opt/intel/oneapi/vtune/2024.3/sepdk/src/sys64.o: warning: objtool: .text+0x5e: unreachable instruction
/opt/intel/oneapi/vtune/2024.3/sepdk/src/sys64.o: warning: objtool: .text+0x63: unreachable instruction
/opt/intel/oneapi/vtune/2024.3/sepdk/src/sys64.o: warning: objtool: .text+0x68: unreachable instruction
/opt/intel/oneapi/vtune/2024.3/sepdk/src/sys64.o: warning: objtool: .text+0x6c: unreachable instruction
/opt/intel/oneapi/vtune/2024.3/sepdk/src/sys64.o: warning: objtool: .text+0x71: unreachable instruction
/opt/intel/oneapi/vtune/2024.3/sepdk/src/sys64.o: warning: objtool: .text+0x76: unreachable instruction
/opt/intel/oneapi/vtune/2024.3/sepdk/src/sys64.o: warning: objtool: .text+0x7b: unreachable instruction
/opt/intel/oneapi/vtune/2024.3/sepdk/src/sys64.o: warning: objtool: .text+0x80: unreachable instruction
/opt/intel/oneapi/vtune/2024.3/sepdk/src/sys64.o: warning: objtool: .text+0x85: unreachable instruction
/opt/intel/oneapi/vtune/2024.3/sepdk/src/sys64.o: warning: objtool: .text+0x8a: unreachable instruction
/opt/intel/oneapi/vtune/2024.3/sepdk/src/sys64.o: warning: objtool: .text+0x8c: unreachable instruction
/opt/intel/oneapi/vtune/2024.3/sepdk/src/sys64.o: warning: objtool: .text+0x8e: unreachable instruction
/opt/intel/oneapi/vtune/2024.3/sepdk/src/sys64.o: warning: objtool: .text+0x90: unreachable instruction
/opt/intel/oneapi/vtune/2024.3/sepdk/src/sys64.o: warning: objtool: .text+0x92: unreachable instruction
/opt/intel/oneapi/vtune/2024.3/sepdk/src/sys64.o: warning: objtool: .text+0x95: unreachable instruction
/opt/intel/oneapi/vtune/2024.3/sepdk/src/sys64.o: warning: objtool: .text+0x9a: unreachable instruction
/opt/intel/oneapi/vtune/2024.3/sepdk/src/sys64.o: warning: objtool: .text+0x9d: unreachable instruction
/opt/intel/oneapi/vtune/2024.3/sepdk/src/sys64.o: warning: objtool: .text+0xa2: unreachable instruction
/opt/intel/oneapi/vtune/2024.3/sepdk/src/sys64.o: warning: objtool: .text+0xa3: unreachable instruction
/opt/intel/oneapi/vtune/2024.3/sepdk/src/sys64.o: warning: objtool: .text+0xa5: unreachable instruction
/opt/intel/oneapi/vtune/2024.3/sepdk/src/sys64.o: warning: objtool: .text+0xa7: unreachable instruction
/opt/intel/oneapi/vtune/2024.3/sepdk/src/sys64.o: warning: objtool: .text+0xaa: unreachable instruction
/opt/intel/oneapi/vtune/2024.3/sepdk/src/sys64.o: warning: objtool: .text+0xae: unreachable instruction
/opt/intel/oneapi/vtune/2024.3/sepdk/src/sys64.o: warning: objtool: .text+0xb3: unreachable instruction
/opt/intel/oneapi/vtune/2024.3/sepdk/src/sys64.o: warning: objtool: .text+0xb8: unreachable instruction
/opt/intel/oneapi/vtune/2024.3/sepdk/src/sys64.o: warning: objtool: .text+0xbd: unreachable instruction
/opt/intel/oneapi/vtune/2024.3/sepdk/src/sys64.o: warning: objtool: .text+0xc2: unreachable instruction
/opt/intel/oneapi/vtune/2024.3/sepdk/src/sys64.o: warning: objtool: .text+0xc7: unreachable instruction
/opt/intel/oneapi/vtune/2024.3/sepdk/src/sys64.o: warning: objtool: .text+0xcc: unreachable instruction
/opt/intel/oneapi/vtune/2024.3/sepdk/src/sys64.o: warning: objtool: .text+0xd1: unreachable instruction
/opt/intel/oneapi/vtune/2024.3/sepdk/src/sys64.o: warning: objtool: .text+0xd6: unreachable instruction
/opt/intel/oneapi/vtune/2024.3/sepdk/src/sys64.o: warning: objtool: .text+0xdb: unreachable instruction
/opt/intel/oneapi/vtune/2024.3/sepdk/src/sys64.o: warning: objtool: .text+0xe0: unreachable instruction
/opt/intel/oneapi/vtune/2024.3/sepdk/src/sys64.o: warning: objtool: .text+0xe5: unreachable instruction
/opt/intel/oneapi/vtune/2024.3/sepdk/src/sys64.o: warning: objtool: .text+0xea: unreachable instruction
/opt/intel/oneapi/vtune/2024.3/sepdk/src/sys64.o: warning: objtool: .text+0xef: unreachable instruction
/opt/intel/oneapi/vtune/2024.3/sepdk/src/sys64.o: warning: objtool: .text+0xf4: unreachable instruction
/opt/intel/oneapi/vtune/2024.3/sepdk/src/sys64.o: warning: objtool: .text+0xf8: unreachable instruction
/opt/intel/oneapi/vtune/2024.3/sepdk/src/sys64.o: warning: objtool: .text+0xf9: unreachable instruction
Done
Building pax driver ...
Done
Building vtsspp driver ...
make[1]: Entering directory '/opt/intel/oneapi/vtune/2024.3/sepdk/src/vtsspp'
make[1]: Leaving directory '/opt/intel/oneapi/vtune/2024.3/sepdk/src/vtsspp'
Done
Building socwatch driver ...
Building drivers for Linux target
-n switch is deprecated. Now it does not have any effect.
/usr/src/linux-6.8.2-rt11 will be used as the kernel build directory
Using alternate compiler '/bin/gcc'
Removing previously built driver and scripts from /opt/intel/oneapi/vtune/2024.3/sepdk/src/socwatch/drivers
'-c /bin/gcc -l -k /usr/src/linux-6.8.2-rt11' options will be used to build the SoCWatch driver
************ Building socwatch2_15-x32_64-6.8.2-rt11smp.ko driver ************
Using C compiler = /bin/gcc
Using kernel build dir = /usr/src/linux-6.8.2-rt11
"/usr/src/linux-6.8.2-rt11/include/linux/cpufreq.h" exists!
"/usr/src/linux-6.8.2-rt11/include/linux/device/class.h" exists!
Make args = KERNEL_SRC_DIR=/usr/src/linux-6.8.2-rt11 CPUFREQ_FIX_BACKPORTED=1 CLASSCREATE_CHANGE_BACKPORTED=1 DO_DEBUG_BUILD=0 DO_PROFILING=0 COMMON_INC_DIR=/opt/intel/oneapi/vtune/202
make[1]: Entering directory '/opt/intel/oneapi/vtune/2024.3/sepdk/src/socwatch/socwatch_driver'
make -C /usr/src/linux-6.8.2-rt11 M=/opt/intel/oneapi/vtune/2024.3/sepdk/src/socwatch/socwatch_driver clean
make[2]: Entering directory '/usr/src/linux-6.8.2-rt11'
make[2]: Leaving directory '/usr/src/linux-6.8.2-rt11'
make[1]: Leaving directory '/opt/intel/oneapi/vtune/2024.3/sepdk/src/socwatch/socwatch_driver'
DO_DRIVER_PROFILING=0
INCDIR_1=/opt/intel/oneapi/vtune/2024.3/sepdk/src/socwatch/socwatch_driver/../common/include
make -C /usr/src/linux-6.8.2-rt11 M=/opt/intel/oneapi/vtune/2024.3/sepdk/src/socwatch/socwatch_driver modules PWD=/opt/intel/oneapi/vtune/2024.3/sepdk/src/socwatch/socwatch_driver
  CC [M]  /opt/intel/oneapi/vtune/2024.3/sepdk/src/socwatch/socwatch_driver/./src/sw_driver.o
  CC [M]  /opt/intel/oneapi/vtune/2024.3/sepdk/src/socwatch/socwatch_driver/./src/sw_hardware_io.o
  CC [M]  /opt/intel/oneapi/vtune/2024.3/sepdk/src/socwatch/socwatch_driver/./src/sw_output_buffer.o
  CC [M]  /opt/intel/oneapi/vtune/2024.3/sepdk/src/socwatch/socwatch_driver/./src/sw_tracepoint_handlers.o
  CC [M]  /opt/intel/oneapi/vtune/2024.3/sepdk/src/socwatch/socwatch_driver/./src/sw_collector.o
  CC [M]  /opt/intel/oneapi/vtune/2024.3/sepdk/src/socwatch/socwatch_driver/./src/sw_mem.o
  CC [M]  /opt/intel/oneapi/vtune/2024.3/sepdk/src/socwatch/socwatch_driver/./src/sw_internal.o
  CC [M]  /opt/intel/oneapi/vtune/2024.3/sepdk/src/socwatch/socwatch_driver/./src/sw_file_ops.o
  CC [M]  /opt/intel/oneapi/vtune/2024.3/sepdk/src/socwatch/socwatch_driver/./src/sw_ops_provider.o
  CC [M]  /opt/intel/oneapi/vtune/2024.3/sepdk/src/socwatch/socwatch_driver/./src/sw_trace_notifier_provider.o
  CC [M]  /opt/intel/oneapi/vtune/2024.3/sepdk/src/socwatch/socwatch_driver/./src/sw_reader.o
  CC [M]  /opt/intel/oneapi/vtune/2024.3/sepdk/src/socwatch/socwatch_driver/./src/sw_telem.o
  CC [M]  /opt/intel/oneapi/vtune/2024.3/sepdk/src/socwatch/socwatch_driver/./src/sw_pmt.o
  CC [M]  /opt/intel/oneapi/vtune/2024.3/sepdk/src/socwatch/socwatch_driver/./src/sw_counter_list.o
  CC [M]  /opt/intel/oneapi/vtune/2024.3/sepdk/src/socwatch/socwatch_driver/./src/sw_pci.o
  LD [M]  /opt/intel/oneapi/vtune/2024.3/sepdk/src/socwatch/socwatch_driver/socwatch2_15.o
  MODPOST /opt/intel/oneapi/vtune/2024.3/sepdk/src/socwatch/socwatch_driver/Module.symvers
  CC [M]  /opt/intel/oneapi/vtune/2024.3/sepdk/src/socwatch/socwatch_driver/socwatch2_15.mod.o
  LD [M]  /opt/intel/oneapi/vtune/2024.3/sepdk/src/socwatch/socwatch_driver/socwatch2_15.ko
************ Built drivers are copied to /opt/intel/oneapi/vtune/2024.3/sepdk/src/socwatch/drivers directory ************
Done
Done building the drivers
PYTHON is set to python3
Detecting Secure Boot status...
Secure Boot is disabled
---------------------    Loading PAX driver    ---------------------
Checking for PMU arbitration service (PAX) ... not detected.
Attempting to start PAX service ...
Executing: insmod ./pax/pax-x32_64-6.8.2-rt11smp.ko
Setting group ownership of devices to group "vtune" ... done.
Setting file permissions on devices to "660" ... done.
The pax driver has been successfully loaded.
---------------------  Loading SOCPERF driver  ---------------------
Checking for socperf driver ... not detected.
Attempting to start socperf service ...
Executing: insmod ./socperf/src/socperf3-x32_64-6.8.2-rt11smp.ko
The socperf3 driver has been successfully loaded.
---------------------    Loading SEP driver    ---------------------
Executing: insmod ./sep5-x32_64-6.8.2-rt11smp.ko sym_lookup_func_addr="ffffffffa8007a90"
The sep5 driver has been successfully loaded.
---------------------  Loading VTSSPP driver  ---------------------
Checking for vtsspp driver ... not detected.
Executing: insmod ./vtsspp/vtsspp-x32_64-6.8.2-rt11smp.ko gid=1001 mode=0660 ksyms="ffffffffa8007a90"
The vtsspp driver has been successfully loaded.
--------------------- Loading SOCWATCH driver ---------------------
Checking for socwatch driver ... not detected.
Executing: insmod ./socwatch/drivers/socwatch2_15-x32_64-6.8.2-rt11smp.ko
Setting group ownership of device file to group "vtune" ... done.
Setting file permissions of device file to "660" ... done.
The socwatch2_15-x32_64-6.8.2-rt11smp driver has been successfully loaded.
NOTE:
The driver is accessible only to users under the group 'vtune'.
Please add the users to the group 'vtune' to use the tool.
To change driver access group, reinstall the driver using -g <desired_group> option.
NOTE:
The driver is accessible only to users under the group vtune.
Please add the users to the group vtune to use the tool.
To change driver access group, reload the driver using -g <desired_group> option.
Configuring sep5 boot script with the following options:
    driver files = /opt/intel/oneapi/vtune/2024.3/sepdk/src/.
Creating systemd load script /usr/local/sbin/sep5-load.sh ...
done.
Creating systemd boot config file /usr/lib/systemd/system/sep5.service ...
done.
Configuring autoload of sep5.service service ...
Created symlink /etc/systemd/system/multi-user.target.wants/sep5.service → /usr/lib/systemd/system/sep5.service.
Job for sep5.service failed because the control process exited with error code.
See "systemctl status sep5.service" and "journalctl -xeu sep5.service" for details.
WARNING: systemctl start returned error 1 ...
done.
yuzhang3_intel
Let's reproduce this issue and give you an update then.
Jennifer_D_Intel
This appears to be the same issue someone else reported: https://community.intel.com/t5/Analyzers/Installing-intel-oneapi-vtune-failed-on-Ubuntu-24-04-LTS-Linux/m-p/1635818#M25309. The drivers are built and loaded, but the installer automatically runs the boot script which also tries to load the drivers and fails because they are already loaded.
The installer team is working on the fix, and in the meantime, you can run the following:
$ sudo /opt/intel/oneapi/vtune/2024.3/sepdk/src/boot-script -i -ul
This is similar to the response I gave in the other thread, but you don't need to manually unload the drivers because the -ul option will do that.
cement_head
I just uninstalled intel-oneapi completely.  It is so unbelievably buggy that its comical. Unusable. Can't install or update a component if its compiled with a newer version of the gcc compiler.
