Analyzers
5341 Discussions
Instrumentation Popup Error
Dan_Hooper
I am getting errors when trying to instrument my builds from either VTune or Thread Analyzer. If I run it from the thread profiler the executable to blame is AddTraces.exe and if I run it from VTune the error is from Bistro.exe. I have to click OK on the below dialog box for every dll that gets instrumented. The dlls and exes do get instrumented correctly but this error is extremely annoying.
I get the error:
"Bistro.exe - Entry Point Not Found
The procedure entry point priv_free could not be located in the dynamic link library Support.dll."
David_A_Intel1
Hi Dan:
Does this happen if you try to call graph the VTuneDemo example application?
Dan_Hooper
Hi Dan:
Yes It does. I have added the screenshot of when the error occurs, just to show how I produce the problem. I had the same problem on a different PC as well.
--Dan
