Analyzers
5260 Discussions
Intel Advisor 2021.1 : What are the percentage numbers next to each module under module filter?
mikeitexpert
New Contributor II
Please let me know.
RashmiP_Intel
Intel® VTune™ Profiler optimizes application performance, system performance, and system configuration for HPC, cloud, IoT, media, storage, and more.
So you can also use vtune for this question.
You can refer to https://software.intel.com/content/www/us/en/develop/documentation/vtune-cookbook/top/tuning-recipes/openmp-imbalance-and-scheduling-overhead.html this cookbook.
Rashmi
Ruslan_M_Intel
It's amount of time spent within corresponding module
mikeitexpert
New Contributor II
Thanks for the input ...
Do you think it is a sign for over parallelization? If so, how would I be able to better  track down the problem? I speculate it has too do with forcing parallelizing using #pragma omp parallel for ... so I may consider using if clauses just to avoid unnecessary parallel execution. However, I am not sure how to verify my guess ...
Please let me know what you think ...
Ruslan_M_Intel
Yes, the overhead you faced with can be caused by the reason you are talking about. You can try playing with OMP_NUM_THREADS env var (e.g. 1, 4 and
mikeitexpert
New Contributor II
Ruslan,
Thanks for the comment I lowered the number of threads to 1 and it turns out it reduces libiomp5md.dll time. Though I am not sure whether it is a good sign or bad sign ??? I am just trying to find whether I have unnecessary parallelizing or not.
mikeitexpert
New Contributor II
Is there any way to force IA (Intel Advisor) use omp debug dlls just to better find out ? I am not sure how I can use debug dlls....
I have tried below but no luck ....
Ruslan_M_Intel
Unfortunately, no. Advisor doesn't do anything like that. Could you tell what you're going to achieve doing that?
RashmiP_Intel
Rashmi
mikeitexpert
New Contributor II
Feel free to close the thread ...
Thank you
RashmiP_Intel
Thanks for accepting our solution. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Rashmi
