Analyzers
5341 Discussions
Intel Advisor Assertion Error (thread_manager_impl:1074)
tharindu
I'm running Intel(R) Advisor 2020 Update 3 (build 607294) Command Line Tool to collect roofline of an application and I'm getting the following error. Any ideas as to what might be causing this problem?
advisor --collect=roofline -project-dir=./roof --stacks --enable-cache-simulation -- MyExecutable [args]
Assertion failed: thread_manager_impl:1074: acquired == tpss_tls_op_err_not_found : thread_acquired == 8
The PBS job I'm running is configured to run on a single node with all 112 cpus exclusively allocated for the job, i.e., #PBS -lselect=1:ncpus=112 -lplace=excl
My linux kernel is Linux 3.10.0-1160.31.1.el7.x86_64.
RaeesaM_Intel
Thank you for posting in Intel Analyzers Forum.
Could you please try the analysis with matrix multiplication sample and see if the same issue is there or not . Refer the link for detailed steps : https://github.com/oneapi-src/oneAPI-samples/tree/master/Tools/Advisor/matrix_multiply_advisor
Also we could observe that you are not using the latest version . Please upgrade to the latest version 2021.3.0 and try.
Download Link : https://registrationcenter.intel.com/en/products/download/3954/
Thanks and Regards,
Raeesa
RaeesaM_Intel
Did you try the sample application ? Did it work? Please let us know the updates so that we can help you further.
Raeesa
RaeesaM_Intel
We haven't heard back from you. We are discontinuing monitoring this thread. Please raise a new query if you have further questions.
Thanks and Regards,
Raeesa
