- Marquer comme nouveau
- Marquer
- S'abonner
- Sourdine
- S'abonner au fil RSS
- Surligner
- Imprimer
Intel Advisor cpu-to-gpu offload modelling for a specific GPU (--config gen9 for example) provides an estimate of GFLOPS for the code we are analysing. Is this GFLOPS for the host CPU or for the GPU we specify?
Lien copié
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Offload Modeling perspective has two workflows:
With CPU-to-GPU modeling, you can profile an application running on a CPU and model its performance on a target GPU device to determine if you should offload parts of your application to the GPU.
With GPU-to-GPU modeling, you can profile an application running on a GPU and model its performance on a different GPU device to estimate a potential speedup from running your application on the different target.
Offload Modeling can predict the code's performance if run on a GPU and lets you experiment with accelerator configuration parameters.
The Intel Advisor produces upper-bound speedup estimates using a bounds and bottlenecks performance model.
It takes measured x86 CPU metrics and application characteristics as an input and applies an analytical model to estimate execution time and speedup on a target GPU.
In CPU-to-GPU modeling, GFLOPS (Offload Modeling) is the "Estimated number of giga floating-point operations per second".
It is collected during the Performance Modeling analysis in the Offload Modeling perspective and found in the Accelerated Regions tab > Code Regions pane > Estimated FLOAT Operations column group.
Also, when profiling a GPU application with Light data transfer simulation mode, you will get memory traffic estimation only for CPU code.
For references please check the below links:
If this resolves your issue, make sure to accept this as a solution. This would help others with similar issue.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Thanks for the information. I will look into the information provided.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
We appreciate your interest in using Intel Advisor.
Please let us know whether we can close this case if you don't have any other issues.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
I had a look. The GFLOP estimates provided by the Advisor varies between runs,. Why does it not give the same GFLOPS number each time I run? What could be the reason for such variation?
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Sorry for the delay in response.
We are checking on this internally and waiting for the updates from the Dev team. We will share the updates with you.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
We tried to reproduce your issue from our end with a simple example (matmul). But the results for the offload modeling looks correct and were in the range of the "real" implementation. Also 2 tests got the same result.
Which means GFLOP numbers should be exact.
Could you please provide the below details to assist you better.
- Could you please provide which application you are using and more details about that application?
- Share the sample reproducer to try from our end (sample reproducer is an exact replica of your working sample)
- Snapshots of the result page showing different GFLOP numbers.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
We haven't heard back from you. Could you please give an update?
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
We have not heard back from you. This thread will no longer be monitored by Intel. If you need further assistance, please post a new question.
- Marquer le sujet comme lu
- Marquer
- S'abonner
- Page imprimable
