Analyzers
5315 Discussions
Intel Advisor crashes when trying to display captured survey data
LM11
Having issues with Intel Advisor 2022.3.0 on a Linux RHEL 7.9 system.  When I attempted to display data that was collected from the command line survey the GUI crashes with a segfault error and the GUI closes out.
The application is a C++ code baseline that contains a number of function calls and only runs on one core (not parallel).
The scenarios I have tested are below:
1) A small sized (~1500 Walltime seconds for the run) survey capture and displaying of data works just fine
2) A medium sized (~3500 Walltime seconds for the run) survey capture works, but displaying analysis data fails with segfault
3) A medium sized (~3500 Walltime seconds for the run) survey capture and displaying of data works with the sampling interval increased to 500ms
4) A large sized (~4800 Walltime seconds for the run) survey capture works, but displaying analysis data fails with a segfault and unable to make it work with the maximum of 1000ms sampling interval
The advisor-gui does not appear to be running out memory and is only using ~4-5GB prior to the crash. The system has 64GB available memory. The ulimit for stack size is also set to unlimited.
It appears that there is some sort of limitation on the amount of data that can displayed. Are there any environment settings or configuration that should be applied when running large data analyses? Is Advisor able to display this much analysis data?
Ruslan_M_Intel
Could you please try to generate advisor report? (See this
E.g.:
advisor --report=survey --format=text --report-output=./survey.txt --project-dir=./advi_results
I assume it could fail here too. Anyway it is important to know where exactly it fails - in GUI or somewhere else.
JaideepK_Intel
Thank you for posting in intel communities.
could you please try the above suggestion provided by Ruslan.
If issue still persist, please provide the below information.
  • Could you please upgrade your Advisor to the latest version, i.e., 2023.0?
  • Since RHEL 7.9 was deprecated, could you please try on a supported OS?
  • Please provide a sample reproducer (a replica of your sample) so that we can reproduce your issue from our end.
Jaideep
LM11
I was able to run the following command with my paths:
The text file was created successfully I believe, although it was not very readable given the tabbing and vertical spacing/paging. Is that to be expected?
--- Additional Notes on the Crash ---
Prior to the GUI crash, Advisor is able to start preparing the data and finalize the frequently used data on the Survey and Roofline tab. It will show a glimpse of the results, times, percentages, etc..., then crash and close out. It seems like it may be having issues after the report data is finalized and displayed.
I also used gdb to run the advisor-gui to see if I could get any details without full debug information.  I found that the segfault is potentially occurring in the "/opt/intel/oneapi/advisor/2022.3.0/lib64/libadvixe_discmodels_recomendations_2.479.so"
We did see this same issue on RHEL7.9 with the older 2021.4 release of Advisor.  We made the upgraded to 2022.3 in the hopes of fixing this issue, but it still persisted.
Upgrading the OS right now may be a bit of a challenge, but I will see if I can get a sample case that reproduces the same issue. If so, the sample case could be ported into a test environment with RHEL 8 and 2023.0 and tested.
Ruslan_M_Intel
Could you please share exact commands you used? If possible please also share the app you used and/or gathered profiles you have. Otherwise please describe what the app does (e.g. heavy compute ops, a lot of sleep commands, single/multithread etc.) and I can try to create something similar for testing purposes
LM11
Text Report  Command:
$ advisor --report=survey --format=text --report-output=./survey.txt --project-dir=/home/<userID>/intel/advixe/projects/AdvTest/
GDB Data Capture Steps/Commands:
$ gdb advisor-gui
Select "Show Result"
The Summary page is displayed showing the data including the "Top Time Consuming Loops" which has the current collected stats
Select "Survey & Roofline" Tab
The status bar is almost 100% complete and spinning.  It also shows "Preparing frequently used data"
Then the window closes out and display the segmentation fault on the terminal window
Application Information:
The code baseline that is causing the crash is a C++ application that is doing an event based simulation that is not extremely heavy in compute. The code fully utilizes object oriented coding aspects with numerous method calls. The entire baseline is around 2.5M lines of code. The application is also single threaded and runs on one core.
We have also started the process for attempting to run this on RHEL8 with the 2022.3 and the latest Advisor version.
Andrey_K
You may also try to collect your results from CLI and then open it in GUI, if it makes sense.
To generate command line use the button on workflow, at the right of the start button. Or "advisor --help collect".
JaideepK_Intel
Are you able to run your application on Advisor2023.0 successfully on RHEL8 without any issues?
Could you please share a sample reproducer so that we can try to reproduce it from our end.
Jaideep
LM11
We are in the process of setting up a RHEL 8 system to test the configuration. Hopefully we will have some results to share shortly.
JaideepK_Intel
Good day to you.
Have you tried installing the latest version of advisor on RHEL8? Is it working fine?
Jaideep
LM11
We have had a bit of a set back on the RHEL 8 instance, but this effort is still underway. Hoping to have something running in the next week.
JaideepK_Intel
Good day to you.
In the meantime, could you please optimize your code? Can you make it run on multiple threads because it is currently running on a single thread?
Jaideep
JaideepK_Intel
Good day to you.
Jaideep
JaideepK_Intel
Good day to you.
We have not heard back from you. This thread will no longer be monitored by Intel. If you need further assistance, please post a new question.
Jaideep.
