Analyzers
5342 Discussions
VTune Profiler Python support
cesare
Our project is using python 3.10.6 compiled from source, it seems that Vtune Profiler currently are not available for python 3.10.6.
All python execution are presented in CPython code, without python call info.
NOTE: I have tried another project using python 2.7.18 compiled from source, with which Vtune Profiler works file.
AthiraM_Intel
Could you please share the following details:
  1. OS and hardware details
  2. VTune version
  3. Sample reproducer code and the steps to reproduce the issue
  4. The screenshot of the error you are getting
We tried profiling a sample python program with python 3.10.8 using Vtune 2022.4.1. We are not able to see the source code. Is that the issue you are also facing?
cesare
Hi
Thks for your responding
Here is my runtime environment (I have tried two env for profile):
Collect profile env 1:
  • VTune Version: Vtune 2022.1.0 (Command Line)
  • Python Version: Python 3.10.8 Debug Compiled
Collect profile env 2 (Docker) :
  • VTune Version: Vtune 2022.4.1 (Command Line)
Analyse env:
  • Windows GUI: VTune 2022.4.1
Here are the questions i am facing:
1. I cannot see python call stack (Python source code in your way?) when using VTune command line to profile python application
2. You can see that i am using Python Debug Version for profile. The reason is that standard compiled python will trigger assert error like  below, which will prevent futher profile collect
Thks in advance for you comming response.
AthiraM_Intel
Thank you for sharing the details. We are checking on this internally, will let you know the updates.
AthiraM_Intel
Sorry for the inconvenience caused. We have informed the concerned team regarding your issues.
Is it possible to use python 3.8 or python 3.9 for your work as of now?
AthiraM_Intel
Could you please let us know whether you can use python 3.8 or python 3.9 for your work as of now?
cesare
Hey, sorry for the delayed response!
Currently that the profiler is not available won't be the reason for our project to change our python version, so we made a choice hoping for a update on VTune profiler to support the python version. Before the update, we will use its basic feature while the inconvenience can be compromised.
AthiraM_Intel
We apologize for the delay in getting back to you.
As informed from the development team, Intel VTune Profiler will add support for Python 3.10 in future releases.
