Analyzers
5307 Discussions
Intel Haswell 4770 is not supported in "Microarchitecture exploration" analysis
Michal_Witanowski
I'm getting the following error when trying to use "Microarchitecture exploration" analysis type in VTune Amplifier 2019.4:4770.PNG
Is Haswell architecture not supported anymore? I remember it was working fine in older versions of the VTune.
Cheers,
Michal
Vitaly_S_Intel
Hi Michal,
There is an issue with your CPU detection.
Can you please share the output of the following command:
<VTune installation path>/bin64/sep.exe -version
Michal_Witanowski
Sampling Enabling Product version: 5.9  built on May 14 2019 09:21:02
SEP User Mode Version: 5.9
SEP Driver Version: 5.9
PAX Driver Version: 1.0
Platform type: 88
CPU name: Intel(R) Core(TM) Processor code named Haswell
PMU: haswell
Driver configs: Maskable Interrupt, PEBS OFF (by OS security)
Copyright(C) 2007-2018 Intel Corporation. All rights reserved.
Vitaly_S_Intel
Hmm, so CPU is properly detected on this level. Can you please share the output of the following command?
<VTune installation path>/bin64/amplxe-runss.exe -context-value-list
Michal_Witanowski
Sure, there's the output:
C:\Program Files (x86)\IntelSWTools\VTune Amplifier 2019\bin64>amplxe-runss.exe -context-value-list
targetOS: Windows
OS: Windows
OSBuildNumber: 18362
OSBitness: 64
isPtraceScopeLimited: false
isCATSupportedByCPU: false
isTSXAvailable: false
isHTEnabled: true
fpgaOnBoard: None
omniPathOnBoard: None
pciClassParts:
isSGXAvailable: false
Hypervisor: None
PerfmonVersion: 3
isMaxDRAMBandwidthMeasurementSupported: true
areGpuHardwareMetricsAvailable: true
isPAVPEnabled: true
gpuPlatformIndex: 5
ETW: ACCESS_DENIED
isGpuBusynessAvailable: notAccessible
isGpuBusynessDetailsAvailable: notAccessible
isGpuWaitAvailable: no
isEtwCLRSupported: accessDenied
isFtraceAvailable:
isMdfEtwAvailable: false
isCSwitchAvailable: yes
isFunctionTracingAvailable: no
isIowaitTracingAvailable: no
isVSyncAvailable: na
isPAXDriverLoaded: true
HypervisorType: None
isDeviceOrCredentialGuardEnabled: false
isSEPDriverAvailable: true
platformType:
CPU_NAME:
PMU:
referenceFrequency: 3400000000
isPStateAvailable: true
isVTSSPPDriverAvailable: true
isNMIWatchDogTimerRunning: false
isTPSSAvailable: true
isPytraceAvailable: true
isGENDebugInfoAvailable: true
isGTPinCollectionAvailable: ErrorUnsupportedHardware
isSTTAvailable: no
isEnergyCollectionSupported: false
amplxe: Collection is stopped. Application return code is 0.
Andrey_I_Intel
Hi Michal,
This seems to be a nontrivial issue, could you please collect development log by setting the environment variable. The log would be named like perfrun-*.log and generated in the current dir, so first cd to a writable location:
set PERFRUN_DEBUG=1
amplxe-runss -context-value-list
Please also tell your locale and console codepage by running
chcp
Michal_Witanowski
Hi Andrey,
You will find perfrun*.log file in the attachment. Running "chcp" gave following output:
Active code page: 852
The region and input language is set to Polish, but the "Windows display language" is English.
Cheers,
Michal
Andrey_I_Intel
After a number of tries on different machines (including 4770K), Windows versions, locales I still could not reproduce this issue.
Michal, if you wish to assist with further debugging could you please collect the same log again (with PERFRUN_DEBUG=1) using the attached extended logging runss version? You will have to copy to bin64 subfolder for it to work.
Michal_Witanowski
Sure. Generated file is in the attachment. Here's console output:
targetOS: Windows
OS: Windows
OSBitness: 64
isHTEnabled: true
fpgaOnBoard: None
pciClassParts:
Hypervisor: None
PerfmonVersion: 3
isPAVPEnabled: true
gpuPlatformIndex: 5
ETW: ACCESS_DENIED
isFtraceAvailable:
platformType:
CPU_NAME:
PMU:
isSTTAvailable: no
Marcelis__David
I seem to be encountering the same issue.
This also causes a crash similar to https://software.intel.com/en-us/forums/intel-vtune-amplifier/topic/814206. Turning off "Show additional performance insights" fixes it, but this exactly the information I'm most interested in.
Some information:
CPU: i5-4670K
.\VTune Amplifier 2019\bin64\sep.exe" -version
Sampling Enabling Product version: 5.10  built on Jul 29 2019 15:28:07
SEP User Mode Version: 5.10
SEP Driver Version: 5.10
Platform type: 88
PMU: haswell
Copyright(C) 2007-2019 Intel Corporation. All rights reserved.
.\VTune Amplifier 2019\bin64\amplxe-runss.exe" -context-value-list
targetOS: Windows
OS: Windows
OSBitness: 64
isHTEnabled: false
fpgaOnBoard: None
pciClassParts:
Hypervisor: None
PerfmonVersion: 3
isPAVPEnabled: true
gpuPlatformIndex: 5
ETW: ACCESS_DENIED
isFtraceAvailable:
SEPDriverVersion: 5.10
PAXDriverVersion: 1.0
platformType:
CPU_NAME:
PMU:
isSTTAvailable: no
chcp
Active code page: 850
Cheers,
David
Michal_Witanowski
The issue still persist on VTune Update 5.
Corbo__Azer
Hello guys,
I have the same issue, so far this is the story: https://software.intel.com/en-us/forums/intel-vtune-amplifier/topic/820941#comment-1945688. I hope this will be solved asap.
Azer
van_bergen__jan
I'm still experiencing this exact issue on all 2019 versions and the 2020 version
