Analyzers
5342 Discussions
Intel Inspector 2021 Internal Error
eallgood
Hi all,
I am working on an application that has both a Windows and QNX  build. I was trying to use Intel Inspector 2021 to detect memory leaks in the Windows build version, but after setting the target to my .exe, I received the following error: "Error: An internal error has occurred. Our apologies for this inconvenience. Please gather a description of the steps leading up to the problem and contact the Intel customer support team. Application exit code: -1".
I've attached screenshots of the output as well, in case this is helpful. Does anyone have suggestions of what I ought to do?
E
Gopika_Intel
Hi
Thank you for posting in Intel Analyzers forum. Could you please share us with the following:
1.    The executable, so that we can try it from our end
2.    Whether you’re using command line/GUI
Inspector comes with some samples. We were able to run detect leaks in them. We also suggest you run any one of the samples and see if you could run detect leaks in them. See if the error occurs only while you run your application.
Gopika
Gopika_Intel
We haven’t heard from you in awhile. Is your issue resolved. Let us know your updates.
Gopika
Gopika_Intel
We haven’t heard from you in a while. Assuming your issue is resolved, we’re no longer monitoring this thread. For further issues and queries please raise a new thread. We’d be glad to help you.
Gopika
