Analyzers
5275 Discussions
Intel SDE broken on my system, error code 0xc00007b
_Ivan_
Dear Intel Support Team,
I hope this message finds you well. I am experiencing an issue with the Intel Software Development Emulator (SDE) and would appreciate your assistance.
Issue Description: Whenever I attempt to launch sde.exe from the GUI, I encounter the following error: Error 0xc00007b. However, I can successfully run xed.exe without any issues.
System Information:
  • Operating System: Windows 10 64 bit
  • Intel SDE Version:  (latest version downloaded from the Intel website)
Steps Taken:
  1. Checked for Dependencies:
    • Used sfc /scannow to verify system file integrity. No issues were detected.
  2. .NET Framework:
    • Checked the installed .NET Framework version. I found it was outdated and have now installed .NET SDK 8.0.402, .NET Runtime 8.0.8, and ASP.NET Core Runtime 8.0.8. Installation was successful, but the error persists.
  3. Different Execution:
    • Successfully executed xed.exe with the --help command, which worked as expected.
    • Attempted to run sde.exe with various commands, including sde.exe --help and sde.exe --version, but received the same error and blind crash.
  4. Checked for Missing DLLs:
    • Tried using Dependency Walker on sde.exe to identify any missing DLLs, but I am not sure how to interpret the results.
  5. Event Viewer:
    • Reviewed the Windows Event Viewer for application error logs but found no additional insights regarding the failure.
  6. Reinstallation:
    • Uninstalled and reinstalled Intel SDE, but the issue remains unresolved.
Given the troubleshooting steps above, I am still unable to run sde.exe. I would greatly appreciate any guidance or further steps you recommend to resolve this issue.
Thank you for your time and assistance,
Ivan
yuzhang3_intel
Please take a look at the article below. It has detailed information for Intel SDE.
https://www.intel.com/content/www/us/en/developer/articles/tool/software-development-emulator.html
The Intel AVX and CPU Instructions Forum has been set up to address questions. Intel engineers will monitor it and be available to answer user questions.
yuzhang3_intel
_Ivan_
Hello Yuzhang,
thank you for your prompt reply. The developer website is the first place I have looked and sadly to no avail. I have extensively googled this issue and consulted with chatgpt.
I will then post the question on the forum for engineers provided and am looking forward to getting this issue rectified. Have a great day and thanks again,
Ivan.
