Analyzers
5275 Discussions
When running the LLM model detected ARC770 dGPU many stalled stage
WeiSeng
Hi Team,
Recently we using the vtune to analysis the LLM model inference on ARC770 DGPU.
From the Vtune trace detected many stalled stages instead of activate stage.
I attached the picture that capture from vtune.
Any suggestion?
NormanS_Intel
Hello WeiSeng,
Thank you for posting in the community!
To further investigate this issue, could you please confirm if you are using Intel® VTune™ Profiler? If not, could you provide the exact name of the software you are using?
Norman S.
WeiSeng
Yes, is using tyhe Intel VTUNE Profiler to capture the ARC770 GPU metrics.
Thanks!
JedG_Intel
Hello WeiSeng,
Thank you for sharing this information.
To ensure you receive the most specialized assistance, we have a dedicated forum that addresses these specific concerns. Therefore, I will be moving this discussion to our Developer Software Forum. This will allow our knowledgeable community and experts to provide you with timely and accurate solutions.
Have a good one!
Jed G.
yuzhang3_intel
In general, Stalled issues are related to memory footprint. Model optimization, like optimizing model compilation time, graph fusing, etc., can also reduce memory usage and inference time. You can also use SLM to improve memory access latency for some kernels. Using oneDNN is also helpful for LLM optimization. There are some documents you can refer to:
https://docs.openvino.ai/2024/learn-openvino/llm_inference_guide.html
https://www.intel.com/content/www/us/en/docs/oneapi/optimization-guide-gpu/2024-2/kernels.html
clevels
@WeiSeng Please see @yuzhang3_intel recommendations above.
