Analyzers
5273 Discussions
Intel VTune - ittnotify and collection control
HPCAnalisys
Hi, I'm trying to evaluate the GFLOPs of my application in a constrained area of the code, thats only on a heavy function (>2sec of execution), using "ittnotify.h".
I've followed the configure your system guide and successful built with:
g++ -g -O3 -std=gnu++0x -I/opt/intel/oneapi/vtune/2022.4.0/sdk/include -L/opt/intel/oneapi/vtune/2022.4.0/sdk/lib64 source.cpp -o source.o -pthread -littnotify -ldl
I'm trying to execute the "Performance snapshot" analysis via CLI to get the number of GFLOPs, starting by paused with:
vtune -collect performance-snapshot -start-paused -finalization-mode=full -r ./result -- ./source.o
And then attempting to resume the analysis from code. Unfortunately it seems to not be able to find the "__itt_resume();" command, since it prints "EMON collector was started in PAUSE mode and never RESUMED". This is how I'm trying to use the library:
int main(int argc, char **argv) {
        ... some code ...
       __itt_resume();
       myFunction(1,2,3);
       __itt_pause();
       .... other code ...
return 0;
 Does anyone know why this is not working? Thanks in advance!
AlekhyaV_Intel
Thank you for posting in Intel Communities. We tried collection control API with an existing C++ code but couldn't reproduce your issue. Could you please provide the below information so that we can debug your issue further?
1) Your System details
2) Sample reproducer so that we can try out from our end.
Alekhya
AlekhyaV_Intel
Could you please give us an update regarding this issue?
Alekhya
AlekhyaV_Intel
We assume that your issue is resolved. If you need any further assistance, please post a new question as this thread will no longer be monitored by Intel.
Alekhya
