Hi Everyone,
Previously I have been able to run Intel's VTune profiler, but a few months ago (I don't recally the exact period) it stopped working.
The issue seems to be that VTune creates self-signed certificates that its various components (GUI, Backend, etc) use to talk to each other on localhost.
Previously this worked, but at some point I assume the security profiles on our machines changed, and so the self-signed cert was no longer acceptable even for localhost communications.
I always used to start all components by running vtune-gui.exe, and this worked.
Now, I get
handshake failed; returned -1, SSL error code 1, net_error -202
PS C:\Users\micha633> & "C:\Program Files (x86)\Intel\oneAPI\vtune\latest\bin64\vtune-gui.exe" --log-to-console --log-level=debug
VTune Profiler GUI is accessible via https://127.0.0.1:53449/
info: UI Backend TCP Socket server listening on port 53450
debug: incoming XML: <msg> <handshake role="common-data-source"> <identityKey>common</identityKey> </handshake> </msg>
info: data source connected: common
[25288:0612/085910.003:ERROR:net\socket\ssl_client_socket_impl.cc:916] handshake failed; returned -1, SSL error code 1, net_error -202
debug: Incoming HTTP request with URL:/ui?passphrase=0c4d3f9f-0469-e457-f068-ff091d5c74d3
Query:{"passphrase":"0c4d3f9f-0469-e457-f068-ff091d5c74d3"}
Body:{}
The log that's shown if I run the backend directly shows explicitly that a self-signed certificate is used:
PS C:\Users\micha633> & "C:\Program Files (x86)\Intel\oneAPI\vtune\latest\bin64\vtune-backend.exe"
No TLS certificate was provided as a --tls-certificate command-line argument thus a self-signed certificate is generated to enable secure HTTPS transport for the web server: C:\Users\INTERNAL_MICHA633_$\AppData\Roaming\Intel\VTune\settings\certificates\middleware.crt.
VTune Profiler GUI is accessible via https://127.0.0.1:57604/
How can I safely and securely continue to use the VTune profiler? Attached screenshot and log file. Thank you.
链接已复制
To safely bypass VTune's net_error -202 localhost SSL block, use one of these quick fixes:
Bypass via CLI (Easiest): Launch the GUI from PowerShell with flags to ignore certificate errors:
PowerShell& "C:\Program Files (x86)\Intel\oneAPI\vtune\latest\bin64\vtune-gui.exe" --disable-web-security --ignore-certificate-errors
Trust the Certificate: Locate middleware.crt at the AppData path shown in your backend log. Right-click, select Install Certificate, and place it into the Trusted Root Certification Authorities store for your current user.
Use your Browser: Copy the https://127.0.0.1:... URL containing the passphrase from your backend log, paste it into Chrome or Edge, and click Advanced -> Proceed to 127.0.0.1 (unsafe).
Hi Liam,
Unfortunately, the first (nicest) option doesn't work:
I get
Unknown arguments: disable-web-security, disableWebSecurity, ignore-certificate-errors, ignoreCertificateErrors
Neither do those arguments work when applied to the vtune-backend program
