Analyzers
5255 Discussions
Invalid Memory Access with MKL Random Number Generation functions
Dmitry_V_
Even though the code seems to be working fine, Intel Inspector 2017 (build 510645) reports two problems: Invalid Memory Access and Invalid Partial Memory Access for the following lines:
Write (Read): vdRngGamma(0, mktStream, numScenOneBlk, tmpSt, 1.0, 0.0, 1.0); Allocation Site: double *tmpSt = new double[numScenOneBlk]; For the Invalid Memory Access problem it shows "Write" for vdRngGamma function and for the Invalid Partial Memory Access it shows "Read". I have another array in this code defined and used in exactly the same way with the only difference that its size is hard coded, whereas numScenOneBlk is a pass by reference parameter. Is it a bug in Intel Inspector or am I doing something wrong? Thanks in advance, Dmitry
