Analyzers
5307 Discussions
Issue in running Intel Inspector for multi core designs in gui
AbhayBhatt
I want to know that how we can run the intel Inspector for distributed/multicore designs through GUI and also through command line???
DiyaN_Intel
We saw that you posted a similar question: https://community.intel.com/t5/Analyzers/Intel-Inspector-with-distributed-designs/m-p/1462112
In order to address your query could you please describe your application design in detail?
Is there any cross-node communication like MPI?
Thanks and Regards,
Diya
DiyaN_Intel
Hi ,
We can see your response in the old thread
"Yes Actually we run through MPI for different values of 'n' but how we run this by GUI in Intel Inspector for Data race and Memory issues.
I run it by command line using mpirun ===> inspxe-cl -collect mi-2 -knob still-allocated-memory=true -knob stack-depth=16 -knob enable-on-demand-leak-detection=true -knob enable-dangling-pointer-check=true -knob enable-memory-growth-detection=true -offload-target=default -module-filter-mode=include -appdebug=off -result-dir mem9 -app-working-dir . -- $VMW_HOME/............
But when we launch the results in the GUI it is not shows the issue in summary.
Can you suggest the solution for this and also tell how to run distributed design in Intel Inspector GUI."
Could you please share the following details so that it helps to understand better and investigate from our end?
1. Complete reproducer code that can be compiled and run to verify behavior.
2. Exact steps and the commands used.
3. OS details.
4. Intel Inspector version.
Thanks and Regards,
Diya
AbhayBhatt
Operating System: CentOS Linux 7 (Core)
Intel Inspector version: Version October 2021
Command: <MPI command> /in/iodc290/abhay/inspector/xe-2022.0.0/inspector/2022.0.0/bin64/inspxe-cl -collect ti1 -knob terminate-on-deadlock=false -knob -app-working-dir <working dir>stack-depth=1 -offload-target=default -module-filter-mode=include -appdebug=off -trace-mpi -result-dir <result dir>$VMW_HOME/bin/distrib -vs < arguments>
DiyaN_Intel
Thank you for sharing the details.
Can you please upgrade to the latest version of Intel Inpector i.e. 2023.1.0 and check if the problem still persists?
If the issue still persists then please share the following details:
1. Complete reproducer code to be compiled and run to verify the behavior.
2. Along with that please share the complete MPI commands with arguments.
Thanks and Regards,
Diya
DiyaN_Intel
Good day to you.
We have not heard back from you.
If the issue still persists then please share the details mentioned above, this will help us to investigate further.
Thanks and Regards,
Diya
AbhayBhatt
can you tell how to solve this..
Warning: One or more threads in the application accessed the stack of another thread. This may indicate one or more bugs in your application. Setting the Inspector to detect data races on stack accesses and running another analysis may help you locate these and other bugs.
Warning: Encountered an issue while loading result [......]. Run terminated abnormally. Some data may be lost.
DiyaN_Intel
Are you getting these warnings after you have updated it to Intel Inspector 2023.1.0?
Can you please share the following details (It will help us to debug further):
Thanks and Regards,
Diya
DiyaN_Intel
Can you please share the details mentioned above to help us debug further?
Diya
DiyaN_Intel
We could reproduce the issue from our end and tried with a sample data-race condition program.
We usually get warnings with or without the data-race condition.
We checked with the development team and they confirmed that the warnings you were getting can be ignored and you can run the analysis further.
If this resolves your issue, make sure to accept this as a solution.
This would help others with similar issue. Thank you!
Thanks and Regards,
Diya
DiyaN_Intel
Good day to you.
Is your issue resolved with the above solution?
This would help others with similar issues. Thank you!
Thanks and Regards,
Diya
DiyaN_Intel
Hi ,
Good day to you.
We assume that your issue is resolved with the solution provided.
This thread will no longer be monitored by Intel. If you need further assistance, please post a new question.
Diya
