Analyzers
5307 Discussions
Kernel driver build fails on Fedora 30. Asm macros not substituted.
Chan__Matthew
Hi, I previously posted about this same problem on Fedora 31, an unsupported OS. I tried today on Fedora 30 (a supported OS) and ran into the exact same problem. Here's the previous post with full details: https://software.intel.com/en-us/forums/vtune/topic/850745
AthiraM_Intel
Could you please provide us the steps you used for building the driver, so that we can reproduce the same.
Chan__Matthew
Sure. I replied here: https://software.intel.com/en-us/forums/vtune/topic/850745#comment-1955175
It is the same problem, but being reproduced on two different OS versions it seems.
Egor_S_Intel1
Hi Matthew,
What version of Linux kernel is installed on your system? Could you please send the output of the command:
uname -r
Chan__Matthew
Hi Egor,
I'm running the latest Fedora 30 kernel, which is 5.5.
$ uname -r
5.5.10-100.fc30.x86_64
I tried the patch you linked in the Fedora 31 post and it can find the correct asm macros now, but it gives a different error:
$ sudo make
make[1]: Entering directory '/opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/socperf/src'
make -C /lib/modules/5.5.10-100.fc30.x86_64/build M=/opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/socperf/src LDDINCDIR=/opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/socperf/src/../include LDDINCDIR1=/opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/socperf/src/inc modules PWD=/opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/socperf/src -j4
make[2]: Entering directory '/usr/src/kernels/5.5.10-100.fc30.x86_64'
  CC   /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/socperf/src/socperfdrv.o
  CC   /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/socperf/src/control.o
  CC   /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/socperf/src/utility.o
  CC   /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/socperf/src/pmu_list.o
  CC   /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/socperf/src/pci.o
  CC   /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/socperf/src/soc_uncore.o
  CC   /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/socperf/src/haswellunc_sa.o
  CC   /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/socperf/src/npk_uncore.o
  LD   /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/socperf/src/socperf3.o
  Building modules, stage 2.
  MODPOST 1 modules
  CC   /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/socperf/src/socperf3.mod.o
  LD   /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/socperf/src/socperf3.ko
make[2]: Leaving directory '/usr/src/kernels/5.5.10-100.fc30.x86_64'
cp socperf3.ko socperf3-x32_64-5.5.10-100.fc30.x86_64smp.ko
make[1]: Leaving directory '/opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/socperf/src'
make -C /lib/modules/5.5.10-100.fc30.x86_64/build M=/opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src LDDINCDIR=/opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/../include LDDINCDIR1=/opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/inc modules PWD=/opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src -j4
make[1]: Entering directory '/usr/src/kernels/5.5.10-100.fc30.x86_64'
  CC   /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/lwpmudrv.o
  CC   /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/control.o
  CC   /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/cpumon.o
  CC   /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/eventmux.o
  CC   /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/linuxos.o
  CC   /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/output.o
  CC   /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/pmi.o
  CC   /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/sys_info.o
  CC   /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/utility.o
  CC   /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/valleyview_sochap.o
/opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/utility.c: In function ‘UTILITY_Log’:
/opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/utility.c:846:79: warning: ‘*’ in boolean context, suggest ‘&&’ instead [-Wint-in-bool-context]
  846 |                 if ((category_verbosity & LOG_CHANNEL_PRINTK) * !in_interrupt * !in_notification) {
  CC   /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/unc_power.o
  CC   /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/pmu_list.o
  CC   /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/pci.o
  CC   /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/chap.o
  CC   /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/gmch.o
  CC   /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/gfx.o
  CC   /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/unc_sa.o
  CC   /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/core2.o
  CC   /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/perfver4.o
  AS   /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/sys64.o
/opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/sys64.o: warning: objtool: .text+0x11: unreachable instruction
  CC   /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/silvermont.o
  CC   /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/apic.o
  CC   /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/pebs.o
  CC   /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/unc_gt.o
  CC   /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/unc_mmio.o
  CC   /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/unc_msr.o
  CC   /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/unc_common.o
  CC   /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/unc_pci.o
  CC   /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/sepdrv_p_state.o
  LD   /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/sep5.o
  MODPOST 1 modules
ERROR: "SOCPERF_Switch_Group3" [/opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/sep5.ko] undefined!
ERROR: "SOCPERF_Read_Data3" [/opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/sep5.ko] undefined!
make[2]: *** [scripts/Makefile.modpost:94: __modpost] Error 1
make[1]: *** [Makefile:1606: modules] Error 2
Thank you for your help,
Matt
Egor_S_Intel1
Hi Matt,
It looks like the build-driver script is not patched. Please make sure that value for make_args variable at sepdk/src/build-driver:755 also contains KBUILD_EXTRA_SYMBOLS=${DRIVER_SOURCE_DIRECTORY}/socperf/src/Module.symvers argument for make command. Could you please check it?
Chan__Matthew
Hi Egor,
Hmm, it looks like line 755 was patched properly:
make_args="KERNEL_VERSION=$kernel_version KERNEL_SRC_DIR=$KERNEL_SRC_DIR PER_USER_MODE=$PER_USER_MODE NMI_MODE=$NMI_MODE MINLOG_MODE=$MINLOG_MODE MAXLOG_MODE=$MAXLOG_MODE KBUILD_EXTRA_SYMBOLS=${DRIVER_SOURCE_DIRECTORY}/socperf/src/Module.symvers $make_args"
make -n output changes after I apply the patch so I guess it's working to some degree?
Here's the output:
$ make -n
(cd /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/socperf/src && make all)
cp /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/socperf/src/Module*.symvers .
make -f ./scripts/Makefile.build obj=/opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src \
single-build= \
need-builtin=1 need-modorder=1
test -e ./Module.symvers || ( \
echo; \
echo "  WARNING: Symbol version dump ./Module.symvers"; \
echo "           is missing; modules will have no dependencies and modversions."; \
echo )
set -e;
set -e;
set -e;
set -e;
set -e;
set -e;
set -e;
set -e;
set -e;
set -e;
set -e;
set -e;
set -e;
set -e;
set -e;
set -e;
set -e;
set -e;
set -e;
set -e;
set -e;
set -e;
set -e;
set -e;
set -e;
set -e;
set -e;
set -e;
set -e;  echo '  LD   /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/sep5.o'; ld -m elf_x86_64  -z max-page-size=0x200000    -r -o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/sep5.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/lwpmudrv.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/control.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/cpumon.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/eventmux.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/linuxos.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/output.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/pmi.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/sys_info.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/utility.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/valleyview_sochap.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/unc_power.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/pmu_list.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/pci.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/chap.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/gmch.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/gfx.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/unc_sa.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/core2.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/perfver4.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/sys64.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/silvermont.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/apic.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/pebs.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/unc_gt.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/unc_mmio.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/unc_msr.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/unc_common.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/unc_pci.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/sepdrv_p_state.o; printf '%s\n' 'cmd_/opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/sep5.o := ld -m elf_x86_64  -z max-page-size=0x200000    -r -o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/sep5.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/lwpmudrv.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/control.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/cpumon.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/eventmux.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/linuxos.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/output.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/pmi.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/sys_info.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/utility.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/valleyview_sochap.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/unc_power.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/pmu_list.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/pci.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/chap.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/gmch.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/gfx.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/unc_sa.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/core2.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/perfver4.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/sys64.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/silvermont.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/apic.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/pebs.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/unc_gt.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/unc_mmio.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/unc_msr.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/unc_common.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/unc_pci.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/sepdrv_p_state.o' > /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/.sep5.o.cmd
set -e;  { echo  /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/lwpmudrv.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/control.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/cpumon.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/eventmux.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/linuxos.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/output.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/pmi.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/sys_info.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/utility.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/valleyview_sochap.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/unc_power.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/pmu_list.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/pci.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/chap.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/gmch.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/gfx.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/unc_sa.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/core2.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/perfver4.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/sys64.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/silvermont.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/pci.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/apic.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/pebs.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/unc_gt.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/unc_mmio.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/unc_msr.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/unc_common.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/unc_pci.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/sepdrv_p_state.o; echo; } > /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/sep5.mod; printf '%s\n' 'cmd_/opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/sep5.mod := { echo  /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/lwpmudrv.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/control.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/cpumon.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/eventmux.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/linuxos.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/output.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/pmi.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/sys_info.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/utility.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/valleyview_sochap.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/unc_power.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/pmu_list.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/pci.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/chap.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/gmch.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/gfx.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/unc_sa.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/core2.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/perfver4.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/sys64.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/silvermont.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/pci.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/apic.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/pebs.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/unc_gt.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/unc_mmio.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/unc_msr.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/unc_common.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/unc_pci.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/sepdrv_p_state.o; echo; } > /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/sep5.mod' > /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/.sep5.mod.cmd
{   echo /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/sep5.ko; :; } \
| awk '!x[$0]++' - > /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/modules.order
make -f ./scripts/Makefile.modpost
echo '  Building modules, stage 2.'
set -e;  echo '  MODPOST 1 modules'; sed 's/ko$/o/' /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/modules.order | scripts/mod/modpost   -i ./Module.symvers  -o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/Module.symvers    -s -T -
make -f ./scripts/Makefile.modfinal
set -e;  echo '  CC   /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/sep5.mod.o'; gcc -Wp,-MD,/opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/.sep5.mod.o.d  -nostdinc -isystem /usr/lib/gcc/x86_64-redhat-linux/9/include -I./arch/x86/include -I./arch/x86/include/generated  -I./include -I./arch/x86/include/uapi -I./arch/x86/include/generated/uapi -I./include/uapi -I./include/generated/uapi -include ./include/linux/kconfig.h -include ./include/linux/compiler_types.h -D__KERNEL__ -Wall -Wundef -Werror=strict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -fshort-wchar -fno-PIE -Werror=implicit-function-declaration -Werror=implicit-int -Wno-format-security -Wno-address-of-packed-member -std=gnu89 -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -m64 -falign-jumps=1 -falign-loops=1 -mno-80387 -mno-fp-ret-in-387 -mpreferred-stack-boundary=3 -mskip-rax-setup -mtune=generic -mno-red-zone -mcmodel=kernel -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -DCONFIG_AS_SSSE3=1 -DCONFIG_AS_AVX=1 -DCONFIG_AS_AVX2=1 -DCONFIG_AS_AVX512=1 -DCONFIG_AS_SHA1_NI=1 -DCONFIG_AS_SHA256_NI=1 -Wno-sign-compare -fno-asynchronous-unwind-tables -mindirect-branch=thunk-extern -mindirect-branch-register -fno-jump-tables -fno-delete-null-pointer-checks -Wno-frame-address -Wno-format-truncation -Wno-format-overflow -Wno-address-of-packed-member -O2 --param=allow-store-data-races=0 -Wframe-larger-than=2048 -fstack-protector-strong -Wno-unused-but-set-variable -Wimplicit-fallthrough -Wno-unused-const-variable -fno-var-tracking-assignments -g -pg -mrecord-mcount -mfentry -DCC_USING_FENTRY -flive-patching=inline-clone -Wdeclaration-after-statement -Wvla -Wno-pointer-sign -Wno-stringop-truncation -fno-strict-overflow -fno-merge-all-constants -fmerge-constants -fno-stack-check -fconserve-stack -Werror=date-time -Werror=incompatible-pointer-types -Werror=designated-init -fmacro-prefix-map=./= -fcf-protection=none -Wno-packed-not-aligned  -DMODULE  -DKBUILD_BASENAME='"sep5.mod"' -DKBUILD_MODNAME='"sep5"' -c -o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/sep5.mod.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/sep5.mod.c; scripts/basic/fixdep /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/.sep5.mod.o.d /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/sep5.mod.o 'gcc -Wp,-MD,/opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/.sep5.mod.o.d  -nostdinc -isystem /usr/lib/gcc/x86_64-redhat-linux/9/include -I./arch/x86/include -I./arch/x86/include/generated  -I./include -I./arch/x86/include/uapi -I./arch/x86/include/generated/uapi -I./include/uapi -I./include/generated/uapi -include ./include/linux/kconfig.h -include ./include/linux/compiler_types.h -D__KERNEL__ -Wall -Wundef -Werror=strict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -fshort-wchar -fno-PIE -Werror=implicit-function-declaration -Werror=implicit-int -Wno-format-security -Wno-address-of-packed-member -std=gnu89 -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -m64 -falign-jumps=1 -falign-loops=1 -mno-80387 -mno-fp-ret-in-387 -mpreferred-stack-boundary=3 -mskip-rax-setup -mtune=generic -mno-red-zone -mcmodel=kernel -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -DCONFIG_AS_SSSE3=1 -DCONFIG_AS_AVX=1 -DCONFIG_AS_AVX2=1 -DCONFIG_AS_AVX512=1 -DCONFIG_AS_SHA1_NI=1 -DCONFIG_AS_SHA256_NI=1 -Wno-sign-compare -fno-asynchronous-unwind-tables -mindirect-branch=thunk-extern -mindirect-branch-register -fno-jump-tables -fno-delete-null-pointer-checks -Wno-frame-address -Wno-format-truncation -Wno-format-overflow -Wno-address-of-packed-member -O2 --param=allow-store-data-races=0 -Wframe-larger-than=2048 -fstack-protector-strong -Wno-unused-but-set-variable -Wimplicit-fallthrough -Wno-unused-const-variable -fno-var-tracking-assignments -g -pg -mrecord-mcount -mfentry -DCC_USING_FENTRY -flive-patching=inline-clone -Wdeclaration-after-statement -Wvla -Wno-pointer-sign -Wno-stringop-truncation -fno-strict-overflow -fno-merge-all-constants -fmerge-constants -fno-stack-check -fconserve-stack -Werror=date-time -Werror=incompatible-pointer-types -Werror=designated-init -fmacro-prefix-map=./= -fcf-protection=none -Wno-packed-not-aligned  -DMODULE  -DKBUILD_BASENAME='\''"sep5.mod"'\'' -DKBUILD_MODNAME='\''"sep5"'\'' -c -o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/sep5.mod.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/sep5.mod.c' > /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/.sep5.mod.o.cmd; rm -f /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/.sep5.mod.o.d
set -e;  echo '  LD   /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/sep5.ko'; ld -r -m elf_x86_64  -z max-page-size=0x200000  --build-id  -T ./scripts/module-common.lds -o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/sep5.ko /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/sep5.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/sep5.mod.o;  true; printf '%s\n' 'cmd_/opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/sep5.ko := ld -r -m elf_x86_64  -z max-page-size=0x200000  --build-id  -T ./scripts/module-common.lds -o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/sep5.ko /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/sep5.o /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/sep5.mod.o;  true' > /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/.sep5.ko.cmd
ld: cannot find /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/sep5.mod.o: No such file or directory
make[3]: *** [scripts/Makefile.modfinal:41: /opt/intel/vtune_profiler_2020.0.0.605129/sepdk/src/sep5.ko] Error 1
make[2]: *** [scripts/Makefile.modpost:95: __modpost] Error 2
make[1]: Leaving directory '/usr/src/kernels/5.5.10-100.fc30.x86_64'
make: *** [Makefile:215: default] Error 2
ArunJ_Intel
Hey Matt,
Closing this case as you have mentioned in the below thread that you issue is resolved
Please feel free to raise a new thread for further issues
Arun Jose
