Analyzers
5248 Discussions
Locked out by Vtune after crash
jonathan_z
The machine I was running a VTune activity crashed due to other issues. It was rebooted. When I nowattempt to run VTune via the command line, I get this message:
(grid10) /work/vtune 6 > vtl show -all
VTune Performance Analyzer 9.0 for Linux*
Copyright (C) 2000-2007 Intel Corporation. All rights reserved.
The project is already open and cannot be used. Another VTune Performance Environment session has opened it.
The ActivityController says that I am not running any activities.
Unfortunately the link provided in past responses about this problen is now dead: http://www.intel.com/support/performancetools/sb/cs-006211.htm
What to do next? Note that rebooting the Itanium is not an option.
Thank you for any help!
Jonathan
TimP
Find and kill open processes from your failed job, such as vtl processes. If necessary, run rmmod-vtune and insmod-vtune (in the VTune installation).
jonathan_z
Tim, Since machine crash and rebooted, there were no vtl or related processes...but I double-checked. Ran the rmmod-vtune and insmod-vtune but still same result. I moved my ~/VTune project directory to another location (i.e. essentially deleted the project, according to VTune), and now I can run. Any suggestions on what files fix/delete in the directories to recover this data, or is there some documentation on the file formats and usage so that I can debug this myself? Would like to recover the project since it took about 1 machine-week of runtime to generate the data...
TimP
Since you said you didn't want to reboot, I assumed your old processes might still be running. I have run into the requirement to blow away old projects myself, even though that shouldn't happen. Many of us try to limit data collection to a segment of a run of not more than 5 minutes, so as not to spend too much time collecting data which wont' last long.
jonathan_z
Sorry, should have been clearer -- the crash excited an issue we have with automount that locked up the whole machine -- needed to reboot. I can rerun the data pretty easily -- just need to push out the schedule a bit...! Thanks for advice...unfortunately, the 5 minute time-limit wouldn't even get me past most of the init code. I have tried using the -moi option to be more specific -- but it returns null results if I specify anything other than the top application. Still learning my way around VTune so not sure if it's user error -- will post questions if I can't figure it out..
