Analyzers
Locks and Wait failed after few minutes
Alon_A_
I'm trying to run Locks and Wait feature in order to get an analysis for my application.
This experience raised a problem, few minutes after the test had ran and the Vtune had started analyze my app,
I got the following error:
"Analysis is completed successfully.
Failed to finalize the result."
My application runs on Blade HS21 with 16 X Intel(R) Xeon(R) CPU E5620 @ 2.40GHz CPU processors, MemTotal:     12272888 kB
The bin file is compiled by gcc.
The OS details are:
linux 5.8
Kernel: 2.6.18-308.11.1.el5 #1 SMP Tue Jul 10 08:48:43 EDT 2012 x86_64 x86_64 x86_64 GNU/Linux
I appriciate your advice
Alon
Peter_W_Intel
Was your application built with "-g" to generate debug info?
What is Amplifier XE version you used?
Alon_A_
Yes, debug level -g
Vtune_amplifier_xe_2013 - Update2 Build 253325
Peter_W_Intel
Thanks for your update. Is it possible that we can verify it in command line?
$ amplxe-cl -collect locksandwaits -r /tmp/r001lw -- your-app (write permission issue?)
If you still get error, what are outputs?
Is there any problem if you upgrade to latest Update 11?
