Analyzers
Memory errors and leaks in Fortran code
jirina
I ran "Memory Error Analysis / Detect Leaks" on my Fortran code (fixed form) and Inspector reported several problems that I don't understand:
1. Kernel resource leak in the following piece of code:
use ifport
character*1024 arg0
character*1024 filename
character*16 dllname
character(3) drive
character(256) dir, name, ext, file
integer*4 length
integer (kind=int_ptr_kind()) handle
type (file$info) info
call getarg ( 0, arg0 )
length = SPLITPATHQQ ( arg0, drive, dir, name, ext )
dllName = 'myDLL.dll'
filename = drive(1:len_trim(drive)) // dir(1:len_trim(dir)) // trim(dllName)
handle = FILE$FIRST
if ( GETFILEINFOQQ(filename, info, handle) .gt. 0 ) then
endif
The kernel resource leak is reported for the line with the function GETFILEINFOQQ; I wonder what I am doing wrong. Is it the size of filename, being character*1024 ?
2. Memory leak or Uninitialized partial memory access in the last line of the code
use ifport
integer(2) status
status = DELFILESQQ('myFile.dat')
By the way, the example in the documentation for the function DELFILESQQ declares the results of the function as integer(4), could this be any problem that integer(2) as the results of the function is assigned to integer(4) variable?
3. Invalid partial memory access or Uninitialized partial memory access in multiple locations:
integer*4 iunx_ew, iunx, ios, iocheck, rcl
character*20 file_ew_text, finame
OPEN ( iunx_ew, FILE=file_ew_text, ACCESS='SEQUENTIAL', ACTION='WRITE', SHARE='DENYWR', IOSTAT=ios )
OPEN ( 99, FILE='myDB.d', ACCESS='DIRECT', STATUS='OLD', RECL=520, IOSTAT=iocheck, SHARE='DENYWR' )
OPEN ( iunx, FILE=finame, ACCESS='DIRECT', RECL=rcl, IOSTAT=iocheck, SHARE='DENYWR' )
All the lines with the OPEN statement exhibit the memory access problem. Why?
SergeyKostrov
Valued Contributor II
I think the thread needs to be moved to Intel Visual Fortran Compiler Forum to help jirina. Thanks.
Mark_D_Intel
1. From the documentation for GETFILEINFOQQ:
 "GETFILEINFOQQ must be called with the handle until GETFILEINFOQQ sets handle to FILE$LAST, or system resources may be lost"
2. This looks like it occurs inside the implementation of DELFILESQQ.  This is a false positive and can be ignored.
3. Assuming the file name  and unit number variables are defined, these are false positives occuring inside OPEN, and can be ignored.
You can use the suppression feature to remove future reporting of these problems.
jirina
The proper coding of GETFILEINFOQQ based on the documentation helped me to get rid of the memory error. Thank you!
I will be looking at the suppression feature later; I don't have so many false positives in my application.
