Analyzers
5307 Discussions
Modifying the VTune sampling drivers to capture the instruction info also and not just the numbers.
HarshVardhanKumar
Is it possible to modify the VTune sampling drivers to also capture the information about the instructions being executed during the time the drivers interrupt the system? This can help me to get information about the list of instructions during the lower port utilization.
If it's not possible, can you explain the reasons?
Harsh
Gopika_Intel
Thank you for reaching out. An opensource version of Vtune in available on Github that can be modified by any user. This is the link: https://github.com/intel/aca
It also comes with documentation on how to build and run it in a linux environment. Hope this helps.
Gopika
Gopika_Intel
We have not heard from you in a while. Has the solution provided helped? Is your query resolved? If yes, can we discontinue monitoring this thread?
Gopika
Bernard
Valued Contributor I
Hi Harsh
Theoretically you can add so called "self-profiling" features to the sepdk drivers. By stating "self-profiling" I meant an
addition of the calls to RDPMC instruction issued by the sepdk routines during the course of their execution.
HarshVardhanKumar
Thanks for the reply. Let me try and come back.
Gopika_Intel
Gopika
HarshVardhanKumar
Sure, you can discontinue monitoring this thread.
Harsh
Gopika_Intel
Thank you for the confirmation. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Gopika
