Analyzers
5273 Discussions
No Data Shown After Compilation of C Source Code with OpenMP
CWhit10
I'm now using Intel VTune Amplifier XE 2015. Also, I have no problem in running Tachyon (sample code).
I was trying to analyze an executable file generated after complilation of a C source code with OpenMP API.
When I run Advanced Hotspots Analysis, I can't view the result of analysis at OpenMP region. It stated "No Data To Show".
Below are the steps that I'd taken to run the analysis:
1) source /opt/intel/vtune_amplifier_xe_2015/amplxe-vars.sh
2) gcc -fopenmp -g Matrix.c -O2 -o Matrix.exe
3) export EDITOR=gedit
4) ./amplxe-gui
Thank you.
Peter_W_Intel
I cannot reproduce this issue...
# amplxe-cl -version
Intel(R) VTune(TM) Amplifier XE 2015 Update 2 (build 393444) Command Line Tool
Copyright (C) 2009-2014 Intel Corporation. All rights reserved.
# gcc --version
gcc (GCC) 4.4.6 20110731 (Red Hat 4.4.6-3)
Copyright (C) 2010 Free Software Foundation, Inc.
# gcc -g -fopenmp -O2 matrix.c -o matrix
# amplxe-cl -collect advanced-hotspots -- ./matrix
I suggest to improve this with two ways: (You can see OpenMP region)
1.1. # export KMP_FORKJOIN_FRAMES=1
1.2. # gcc -g -fopenmp -liomp5 -O2 matrix.c -o matrix
2. Use icc instead of gcc
Peter_W_Intel
# gcc --version
