Analyzers
5307 Discussions
Intel VTune can not collect information & cause core dump
Max_C_
we are using Intel VTune 2015 for profiling our application which is  running under operating system:2.6.32-504.1.3.el6.x86_64 Red Hat Enterprise Linux Server release 6.6 (Santiago)
CPU: Intel(R) Xeon(R) E5/E7 v2 processor
Frequency          2800004679
Logical CPU Count  4
I started four ngss.elf which is our product.
# ps -ef|grep ngss
root       400 31483  0 07:34 pts/0    00:00:00 ./ngss.elf --iomn 294921
root     32508 31483  0 07:34 pts/0    00:00:00 ./ngss.elf --iomn 360459
root     32509 31483  0 07:34 pts/0    00:00:00 ./ngss.elf --iomn 393228
root     32510 31483 36 07:34 pts/0    00:00:47 ./ngss.elf --iomn 425997
Then I used the following command:
# ./amplxe-cl -collect hotspots -run-pass-thru=-no-altstack -target-pid=32510
I used the follow command to stop Vtune. But it didn't work.
#./amplxe-cl -r /opt/intel/vtune_amplifier_xe_2015.1.0.367959/bin64/r007hs -command stop
So I typed CRTL+C here
The thread just became a defunct thread.
root     32510 31483  1 07:34 pts/0    00:00:51 [ngss.elf] <defunct>
Then boom! Coredump happened after a while.
[3] - Memory fault(coredump)   ./ngss.elf --iomn 425997 &
# ps -ef|grep ngss
root       400 31483  0 07:34 pts/0    00:00:02 ./ngss.elf --iomn 294921
root      1468 31483  0 07:48 pts/0    00:00:00 grep ngss
root     32508 31483  0 07:34 pts/0    00:00:02 ./ngss.elf --iomn 360459
root     32509 31483  0 07:34 pts/0    00:00:02 ./ngss.elf --iomn 393228
kill -9 32508
# ./amplxe-cl -collect hotspots -duration 5 -target-pid=32508
amplxe: Collection started. To stop the collection, either press CTRL-C or enter from another console window: amplxe-cl -r /opt/intel/vtune_amplifier_xe_2015.1.0.367959/bin64/r009hs -command stop.
amplxe: Collection detached.
amplxe: Collection stopped.
amplxe: Using result path `/opt/intel/vtune_amplifier_xe_2015.1.0.367959/bin64/r009hs'
amplxe: Executing actions 34 % Precomputing frequently used data
amplxe: Warning: Cannot find data to precompute. Skipping the precomputation step.
amplxe: Executing actions 50 % Generating a report
Collection and Platform Info
Parameter                 r009hs
Application Command Line
Operating System          2.6.32-504.1.3.el6.x86_64 Red Hat Enterprise Linux Server release 6.6 (Santiago)
Computer Name             isc01-s00c02h0
Result Size               1380818
Collection start time     08:45:20 04/02/2015 UTC
Collection stop time      08:45:20 04/02/2015 UTC
CPU
Parameter          r009hs
Name               Intel(R) Xeon(R) E5/E7 v2 processor
Logical CPU Count  4
Summary
Elapsed Time:  0.000
amplxe: Executing actions 100 % done
drwx------  6 root root    4096 Feb  4 08:45 r009hs
# ./amplxe-cl -report hotspots
Empty request output.
amplxe: Error: 0x40000027 (Reporter error)
So, I got three questions:
1.  What happened when I press "CTRL+C"? Did vtune send some signal or some other message to the process?
2. What happened after I input"kill -9 pid"?
3. Why "Empty request output" happened?
Peter_W_Intel
Maybe it was a VTune bug for ctrl-C handler. Is it possible that you can help to send us? Thank you.
Our developer asked to do:
  1.        export AMPLXE_LOG_LEVEL=TRACE
  2.        reproduce the scenario
  3.        send me collected result folder and related logs from /tmp/amplxe-log-<username> (last 3 folders)
I have an idea to use advance-hotspots instead of hotspots, with system wide profiling. Performance data of all active processes will be collected.
For example:
amplxe-cl -collect advanced-hotspots -r r009ah -duration 30
Using amplxe-gui to view report, and you can filter data to narrow down your interest of process(es).
Peter_W_Intel
This might be another bug report. Thank you.
You may try to user option "-profiling-signal 33" with option "-duration 60" (avoid ctrl-C incorrect handler?), please reference this thread (the bug hasn't be fixed yet...I hope that you can generated expected result). For example: (putting vtune result under vtune/bin64 is not recommended)
amplxe-runss -r r008 --data-limit-mb=500 --stack-stitching --follow-child --itt-config=frame --stackwalk=offline -profiling-signal 33 -duration 30 --type=cpu:counters:nostack --type=cpu:stack --target-pid 32510
Max_C_
Hi Peter,
Thanks for your reply.
I tried the command you mentioned but failed.
I set the duration to 3. Here is the detail:
# ps -ef|grep ngss
root     22545 15238  0 05:43 pts/0    00:00:00 ./ngss.elf --iomn 360459
root     22546 15238  0 05:43 pts/0    00:00:00 ./ngss.elf --iomn 393228
root     22547 15238  0 05:43 pts/0    00:00:00 ./ngss.elf --iomn 425997
root     22902 15238  0 05:44 pts/0    00:00:00 ./ngss.elf --iomn 294921
amplxe-runss -r r008 --data-limit-mb=500 --stack-stitching --follow-child --itt-config=frame --stackwalk=offline -profiling-signal 33 -duration 3 --type=cpu:counters:nostack --type=cpu:stack --target-pid 22902
I waitted for about 1 hour. But it just didn't quit.
So I tried to use kill -9+pid of ngss
output:
amplxe: Detached
amplxe: Collection stopped - application return code is 0
[4] + Killed                   ./ngss.elf --iomn 294921 &
I tried to input CTRL+C
output:
^Camplxe: Collection failed
# amplxe-cl -report summary
amplxe: Using result path `/storage/max/r008'
amplxe: Executing actions 14 % Loading data files
amplxe: Error: Cannot load data file `/storage/max/r008/data.1/systemcollector-isc01-s00c02h0.sc' (File is already loaded).
Parameter              r008
Result Size            1369261
Collection start time  06:01:57 05/02/2015 UTC
Collection stop time   06:01:57 05/02/2015 UTC
CPU
Parameter          r008
Logical CPU Count  4
Summary
Elapsed Time:  0.000
<isc01-s00c02h0:root>/storage/max:
# amplxe-cl -report hotspots
pstree information:
     `-xinetd-+-in.telnetd---login---ksh---su---ksh-+-amplxe-runss-+-pinbin
              |                                     |              `-6*[{amplxe-runss}]
              |                                     `-2*[ngss.elf---32*[{ngss.elf}]]
I start the ngss.elf again and use the following command. Vtune did not quit.
amplxe-runss -r r009 -command=stop
I really did no what happened to Vtune.
Peter_W_Intel
For example:
Max_C_
Hi Peter,
I dowloaded the update 2, and will do what you mentioned and send you the log file later.
Max_C_
Hi Peter,
I had did as you mentioned.:
amplxe-cl -collect advanced-hotspots -r max_test_2_11 -duration 30 --target-pid 7991
Everything is OK!!!
The errors before disappeard......
Thanks for your support!
Max_C_
I considered why did I success.
As I run advanced hotspots instead of basic hotspots. I found the following description:
  • Advanced Hotspots: Event-based sampling analysis that monitors all the software executing on your system including the operating system modules. The collector interrupts the processor at the specified sampling interval and collects samples of instruction addresses.
  • Basic Hotspots: Performance analysis based on user-mode sampling and tracing collection. It focuses on a particular target, identifies functions that took the most CPU time to execute, restores the call tree for each function, and shows thread activity.
One thing I can make sure is my binary has tight connection with operation system. Some how make the basic hotspots fail....
Anyway, I will keep on searching.
BTW: Out company is considering to buy this software. What is the meaning of Floating – 1 user.
I want to konw how many users can share one floating license.
Peter_W_Intel
Thanks for this update - everything is OK after your trying Update 2.
Also thank you for considering to buy this software...you are welcome to discuss any technical issue on this forum, in future:-)
Bernard
Valued Contributor I
Anyway, I will keep on searching.>>>
Do you mean that your application is modifying/hooking some Linux data structures?
