Analyzers
No Event-based sampling on VTune Amplifier 2013 on Microsoft Surface Pro 2
ale_x_
VTune Amplifier 2013 does not detect event-based sampling capabilities on Microsoft Surface Pro 2 running Windows 8.1, which has Intel Core i5 4200U.
Is this Intel Core i5 4200U lacking the Performance Monitoring Unit, or is it Windows 8.1 issues, or something else ?
Please advise.
TimP
Yes, my Windows 8.1 Ultrabook has I5-4200U and the bin64\amplxe-sepreg brought it to life (update 14).
Did you run the amplxe  .bat script in order to get it running in cmd or other shell window?
Peter_W_Intel
In VTune(TM) Amplifier XE 2013 Update 13:
  • Support for Microsoft Windows* 8.1 operating system and integration with Microsoft* Visual Studio* 2013 IDE
What is VTune version you are using?
Can you try amplxe-sepreg​.exe under VTune Amplifier XE 2013\bin32 in cmd to check vtune driver's status? Run "amplxe-sepreg.exe -s"
Peter_W_Intel
If the driver works, you can run "amplxe-runss -event-list" to know all supported events for your running processor.
ale_x_
Hi Peter,
I am running VTune Amplifier XE 2013 Update 13, all drivers failed.
>amplxe-sepreg -s
Checking sepdrv3_10 driver path...FAILED
Checking sepdrv3_10 service...FAILED
Checking sepdal driver path...FAILED
Checking sepdal service...FAILED
Can you please confirm that my CPU Intel Core i5 4200U has event-based sampling support ?
TimP
ale_x_
All good now, it turns out all I needed to do was
amplxe-sepreg -i -v to re-install it
from
http://software.intel.com/en-us/forums/topic/388277
