Analyzers
5272 Discussions
No complaint about use of uninitialized variables in simple Fortran test cases?
johnappleyard377
Hi
I'm trying to use Inspector on the simple examples in the Polyhedron test suite (http://www.polyhedron.com/wp-content/uploads/2014/04/win32_diagnose_src.zip), but I don't get the error reports I expect.  Am I doing something wrong?
Taking UIN7 as an example, it's compiled from the command line using
ifort uin7.for      /debug:full /Od /libs:dll /threads /dbglibs
and I use the stand-alone GUI to do a "Memory Error Analysis - Locate Memory Problems" analysis, with "Detect uninitialized memory reads" checked.
The command line is:
inspxe-cl -collect mi3 -knob detect-uninit-read=true -knob revert-uninit=false -knob analyze-stack=true -knob detect-leaks-on-exit=true -knob detect-resource-leaks=true -knob enable-memory-growth-detection=true -knob enable-on-demand-leak-detection=true -knob remove-duplicates=true -knob still-allocated-memory=true -knob stack-depth=16 -mrte-mode=auto -module-filter-mode=include -app-working-dir J:\diagnose\windows -- J:\diagnose\windows\uin7.exe
At first, I do get an "uninitialized memory access", but it seems to be unrelated - I get it even if I fix the error in UIN7.
Description    Source    Function    Module    Object Size    Offset
Read    crtexe.c:536    _tmainCRTStartup    uin7.exe
     uin7.exe!main
    >uin7.exe!_tmainCRTStartup - crtexe.c:536
     uin7.exe!mainCRTStartup - crtexe.c:376
     kernel32.dll!BaseThreadInitThunk
     ntdll.dll!RtlInitializeExceptionChain
With that suppressed, I get no error reports.  The other tests behave similarly.
