Analyzers
Object size Memory Leak
Matous_S_
Hi there,
in Intel Inspector the Object size column gives the amount of bytes for, e.g., a memory leak. If a memory leak occurred let's say 10 times (code locations), to what exactly refes the object size? To the total amount of memory leakage from all occurrences or to each of the 10 occurrences?
Thanks for a quick answer
Cheers
Matous_S_
Edit: Is there an easy way to show the total amount of leaking memory of all problems together?
Peter_W_Intel
I did an experiment - memory leaks occurred in  a loop, if you changed loop count you will see object size of leaks are different. It means object size of leaks in report indicates total bytes of leaks for one location.
I don't see any way to summarize all leaks for all location:-(
