Analyzers
5340 Discussions
Cannot locate debugging symbol
CWhit10
I'm new in using profiling tools. I have few questions:
1) Does Intel VTune Amplifier XE 2015 currently have the specific feature of analyzing the performance of a source code on implementing OpenMP API?
2) When I tried to run Advanced Hotspots Analysis, it was completed with the warning:
cannot locate debugging symbols for file '/lib/x86_64-linux/libc-2.19.so'.
cannot locate debugging symbols for file '/lib/x86_64-linux/ld-2.19.so'.
3) What is the effect of missing debugging symbols?
4) When I was about to use VTune to perform analysis on OpenMP region, it displayed nothing. It is because of my OS version? Below is the info of my OS:
My OS: Linux Mint 17 Cinnamon 64-bit
Cinnamon Version: 2.2.13
Linux Kernel: 3.13.0-24-generic
David_A_Intel1
Hi Claudia:
  1. Yes, but it requires the Intel OpenMP runtime library. (more info, and this note from release notes: "VTune Amplifier XE supports analysis of OpenMP* applications built with Intel® Fortran Compiler Professional Edition version 11.0 or higher, Intel® C++ Compiler Professional Edition version 11.0 or higher, or GNU* C/C++ Compiler 4.2 or higher.")
  2. This is normal.  Symbols for system runtime libraries are not generally available.  It will not impact your ability to profile your code.  You just won't which system functions where executing, since all the samples will be reported against the module - the lowest level known to VTune Amplifier without symbolic info.
  3. See above.
  4. This is definitely not a supported OS (see Release Notes).  It may or may not work.  Please try one of the sample apps included with the VTune Amplifier.
Bernard
Valued Contributor I
Was the library compiled with debug symbols?
CWhit10
Yup. I use this command to compile it:
gcc -g -fopenmp Matrix.c -o Matrix.exe
David_A_Intel1
Hi Claudia:
  3. See above.
Vitaly_S_Intel
Just a small correction regarding 2 - even with absence of symbol information VTune will be able to recognize function boundaries using static analysis. If function is exported, it'll be even correctly named, but for other functions the name of the function will be represented just as a start address of the function.
Absence of debug info will cause inability to drill down to source for corresponding module and may cause wrong stacks. On Debian-based systems you should be able to install corresponding dbg packages containing symbol information for system modules (e.g. libc6-dbg).
