Analyzers
5285 Discussions
PARDISO-calling program crashes when run in Intel Inspector
petersen__Kenni_dine
I am attempting to analyze a program in Intel Inspector, but have experienced that the program crashes when PARDISO-functions are called.
The problem can reproduced by compiling and running one of the test examples from the oneAPI installation, e.g:
C:\Program Files (x86)\Intel\oneAPI\mkl\2023.0.0\examples\examples_core_c.zip\c\sparse_directsolvers\source\pardiso_unsym.c
Code example is in the below.
I build the program using default release settings in visual studio with oneAPI c++ (2023). Linking and include of MKL lib is archived with "Use oneMKL" set to "Parallel". Furthermore static linking of runtimes is employed (/MT).
With such settings, the example program runs without any problems when called normally from Visual Studio or from cmd.
However, when the program is run from Intel Inspector (v. 2023), it crashes.
Further debugging indicates that the crash occurs in first call of PARDISO(...) at line 129 and that it is due to an access violation within this call.
The crash is observed at least for the leak detection configuration runs (with default settings) in Inspector, but also seems to occur in other configurations. Using Inspector for other programs not calling PARDISO routines does not seem to cause any problems.
Is this a problem related to Intel Inspector, or is it perhaps resolvable by changing certain settings?
* Copyright 2004-2022 Intel Corporation.
* This software and the related documents are Intel copyrighted  materials,  and
* your use of  them is  governed by the  express license  under which  they were
* provided to you (License).  Unless the License provides otherwise, you may not
* use, modify, copy, publish, distribute,  disclose or transmit this software or
* the related documents without Intel's prior written permission.
* This software and the related documents  are provided as  is,  with no express
* or implied  warranties,  other  than those  that are  expressly stated  in the
* License.
*   Content : Intel(R) oneAPI Math Kernel Library (oneMKL) PARDISO C example
/* Example program to show the use of the "PARDISO" routine */
/* on unsymmetric linear systems */
/* This program can be downloaded from the following site: */
/* www.pardiso-project.org */
/* (C) Olaf Schenk, Department of Computer Science, */
/* University of Basel, Switzerland. */
/* Email: olaf.schenk@unibas.ch */
#include <stdio.h>
#include <stdlib.h>
#include <math.h>
#include "mkl_pardiso.h"
#include "mkl_types.h"
#include "mkl_spblas.h"
// Define the format to printf MKL_INT values
#if !defined(MKL_ILP64)
#define IFORMAT "%i"
#else
#define IFORMAT "%lli"
#endif
int main (void)
    /* Matrix data. */
    MKL_INT n = 5;
    MKL_INT ia[6] = { 1, 4, 6, 9, 12, 14};
    MKL_INT ja[13] =
    { 1, 2,    4,
      1, 2,
            3, 4, 5,
      1,    3, 4,
         2,       5
    double a[13] =
    { 1.0,-1.0,     -3.0,
     -2.0, 5.0,
                4.0, 6.0, 4.0,
     -4.0,      2.0, 7.0,
           8.0,          -5.0
    MKL_INT mtype = 11;       /* Real unsymmetric matrix */
  // Descriptor of main sparse matrix properties
  struct matrix_descr descrA;
  // Structure with sparse matrix stored in CSR format
  sparse_matrix_t       csrA;
  sparse_operation_t    transA;
    /* RHS and solution vectors. */
    double b[5], x[5], bs[5], res, res0;
    MKL_INT nrhs = 1;     /* Number of right hand sides. */
    /* Internal solver memory pointer pt, */
    /* 32-bit: int pt[64]; 64-bit: long int pt[64] */
    /* or void *pt[64] should be OK on both architectures */
    void *pt[64];
    /* Pardiso control parameters. */
    MKL_INT iparm[64];
    MKL_INT maxfct, mnum, phase, error, msglvl;
    /* Auxiliary variables. */
    MKL_INT i, j;
    double ddum;          /* Double dummy */
    MKL_INT idum;         /* Integer dummy. */
/* .. Setup Pardiso control parameters. */
    for ( i = 0; i < 64; i++ )
        iparm[i] = 0;
    iparm[0] = 1;         /* No solver default */
    iparm[1] = 2;         /* Fill-in reordering from METIS */
    iparm[3] = 0;         /* No iterative-direct algorithm */
    iparm[4] = 0;         /* No user fill-in reducing permutation */
    iparm[5] = 0;         /* Write solution into x */
    iparm[6] = 0;         /* Not in use */
    iparm[7] = 2;         /* Max numbers of iterative refinement steps */
    iparm[8] = 0;         /* Not in use */
    iparm[9] = 13;        /* Perturb the pivot elements with 1E-13 */
    iparm[10] = 1;        /* Use nonsymmetric permutation and scaling MPS */
    iparm[11] = 0;        /* Conjugate transposed/transpose solve */
    iparm[12] = 1;        /* Maximum weighted matching algorithm is switched-on (default for non-symmetric) */
    iparm[13] = 0;        /* Output: Number of perturbed pivots */
    iparm[14] = 0;        /* Not in use */
    iparm[15] = 0;        /* Not in use */
    iparm[16] = 0;        /* Not in use */
    iparm[17] = -1;       /* Output: Number of nonzeros in the factor LU */
    iparm[18] = -1;       /* Output: Mflops for LU factorization */
    iparm[19] = 0;        /* Output: Numbers of CG Iterations */
    maxfct = 1;           /* Maximum number of numerical factorizations. */
    mnum = 1;         /* Which factorization to use. */
    msglvl = 0;           /* Print statistical information  */
    error = 0;            /* Initialize error flag */
/* .. Initialize the internal solver memory pointer. This is only */
/* necessary for the FIRST call of the PARDISO solver. */
        pt[i] = 0;
/* .. Reordering and Symbolic Factorization. This step also allocates */
/* all memory that is necessary for the factorization. */
    phase = 11;
    PARDISO (pt, &maxfct, &mnum, &mtype, &phase,
             &n, a, ia, ja, &idum, &nrhs, iparm, &msglvl, &ddum, &ddum, &error);
    if ( error != 0 )
        printf ("\nERROR during symbolic factorization: " IFORMAT, error);
        exit (1);
    printf ("\nReordering completed ... ");
    printf ("\nNumber of nonzeros in factors = " IFORMAT, iparm[17]);
    printf ("\nNumber of factorization MFLOPS = " IFORMAT, iparm[18]);
/* .. Numerical factorization. */
    phase = 22;
    if ( error != 0 )
        printf ("\nERROR during numerical factorization: " IFORMAT, error);
        exit (2);
    printf ("\nFactorization completed ... ");
/* .. Back substitution and iterative refinement. */
    phase = 33;
  descrA.type = SPARSE_MATRIX_TYPE_GENERAL;
  descrA.mode = SPARSE_FILL_MODE_UPPER;
  descrA.diag = SPARSE_DIAG_NON_UNIT;
  mkl_sparse_d_create_csr ( &csrA, SPARSE_INDEX_BASE_ONE, n, n, ia, ia+1, ja, a );
    /* Set right hand side to one. */
    for ( i = 0; i < n; i++ )
        b[i] = 1;
//  Loop over 3 solving steps: Ax=b, AHx=b and ATx=b
    for ( i = 0; i < 3; i++ )
        iparm[11] = i;        /* Conjugate transposed/transpose solve */
        if (i == 0)
            transA = SPARSE_OPERATION_NON_TRANSPOSE;
        else if (i == 1)
            transA = SPARSE_OPERATION_CONJUGATE_TRANSPOSE;
        else
            transA = SPARSE_OPERATION_TRANSPOSE;
      printf ("\n\nSolving system with iparm[11] = " IFORMAT " ...\n", iparm[11]);
                 &n, a, ia, ja, &idum, &nrhs, iparm, &msglvl, b, x, &error);
        if ( error != 0 )
            printf ("\nERROR during solution: " IFORMAT, error);
            exit (3);
        printf ("\nThe solution of the system is: ");
        for ( j = 0; j < n; j++ )
            printf ("\n x [" IFORMAT "] = % f", j, x[j]);
        printf ("\n");
// Compute residual
      mkl_sparse_d_mv( transA, 1.0, csrA, descrA, x, 0.0, bs);
        res = 0.0;
        res0 = 0.0;
        for ( j = 1; j <= n; j++ )
            res += (bs[j - 1] - b[j - 1]) * (bs[j - 1] - b[j - 1]);
            res0 += b[j - 1] * b[j - 1];
        res = sqrt (res) / sqrt (res0);
        printf ("\nRelative residual = %e", res);
// Check residual
        if ( res > 1e-10 )
            printf ("Error: residual is too high!\n");
            exit (10 + i);
    mkl_sparse_destroy(csrA);
/* .. Termination and release of memory. */
    phase = -1;           /* Release internal memory. */
             &n, &ddum, ia, ja, &idum, &nrhs,
    return 0;
Ruslan_M_Intel
Have you tried to run Inspector on debug version of the app? Perhaps some release optimizations impact profiling. Also I don't think Inspector is able to provide useful insights without debug information enabled.  If you are not interested in profiling specific libraries (e.g. MKL) you can exclude them from analysis (See Module Filtering )
Ruslan
Thanks, I also did try running in default configuration with no optimizations, but the problem was the same.
It would be fine not to profile MKL libs, but how would do that specifically? I attempted to filter out all files in the MKL redist folder, but this did not seem to have any effect. The collection log looks like this:
Not sure if any MKL-modules were filtered.
Ruslan_M_Intel
I see suspicious 'dynamiccodebin' image with weird address range. Can you try to exclude it?
Assuming this is done by simply adding  'dynamiccodebin' to list of excluded modules, then this did not seem to have any effect. The log indicated the same result. I also attempted attaching a debugger to the program while running in inspector. It seems like the call to PARDISO occurs before the load of rpct4.dll (fourth last module). The call to PARDISO leads to the load of modules libttnotify.dll and pinjitprofiling.dll, before the access violation. I also tried to ignore those two latter modules as well, but the result was the same.
Ruslan_M_Intel
That is not good.  It seems ITT API flow is broken between MKL and Inspector. Can you temporarily rename 'pinjitprofiling.dll' (e.g. pinjitprofiling.dll.bak) module and then re-run your collection?
Just tried running without those dll's. Still led to crash. Collection log looks like this now:
Debugger indicated crash at same location in beforementioned code (i.e. line 128).
Ruslan_M_Intel
Thanks for the result. It seems debug session on our end is required
RemyaP_Intel
Sorry for the delay. Our team is still working on it. We will get back to you with an update.
Remya Premdas
